path: root/arch/arm/lib/lib1funcs.S
2011-05-27ARM: 6945/1: Add unwinding support for division functionsLaura Abbott
The software division functions never had unwinding annotations added. Currently, when a division by zero occurs the backtrace shown will stop at Ldiv0 or some completely unrelated function. Add unwinding annotations in hopes of getting a more useful backtrace when a division by zero occurs. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Acked-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3104/1: ARM EABI: new helper function namesNicolas Pitre
Patch from Nicolas Pitre The ARM EABI defines new names for GCC helper functions. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3103/1: ARM EABI: stack pointer must be 64-bit aligned (part 2)Nicolas Pitre
Patch from Nicolas Pitre We must make sure that assembly code that modifies the stack pointer before calling a C function does it so it remains 64-bit aligned. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
