path: root/arch/arm/lib/delay.S
2011-01-10ARM: udelay: prevent math rounding resulting in short udelaysRussell King
We perform the microseconds to loops calculation using a number of multiplies and shift rights. Each shift right rounds down the resulting value, which can result in delays shorter than requested. Ensure that we always round up. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove RETINSTR macroRussell King
RETINSTR is a left-over from the days when we had 26-bit and 32-bit CPU support integrated into the same tree. Since this is no longer the case, we can now remove RETINSTR. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3346/1: Fix udelay() for HZ values different from 100Peter Teichmann
Patch from Peter Teichmann Currently, if the kernels HZ value is greater than 100, delays with the udelay function are too short. This can cause trouble for instance with the zd1201 usb wlan driver. This patch suggests a solution that keeps the overhead small and maintains (hopefully) sufficient resolution. Signed-off-by: Peter Teichmann Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-11[ARM] 3152/1: make various assembly local labels actually local (the rest)Nicolas Pitre
Patch from Nicolas Pitre For assembly labels to actually be local they must start with ".L" and not only "." otherwise they still remain visible in the final link and clutter kallsyms needlessly, and possibly make for unclear symbolic backtrace. This patch simply inserts a"L" where appropriate. The code itself is unchanged. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
