path: root/arch/arm/configs
2020-04-16ARM: apalisi-tk1: enable options for backportsApalis-TK1_LXDE-Image_2.8b7.-20200610Apalis-TK1_Console-Image_3.0b4.254-20200421toradex_tk1_l4t_r21.7-nexttoradex_tk1_l4t_r21.7Oleksandr Suvorov
Enable WIRELESS_EXT and WEXT_PRIV options for the backported rtl81288eu driver. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-16ARM: apalis-tk1: disable wireless driversOleksandr Suvorov
Disabling all wireless drivers and cfg80211 module makes able to completely avoid interferences with backported drivers. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-09ARM: defconfig: tk1: enable CRYPTO_HASH_INFOOleksandr Suvorov
Backports-5.4 requires the config option CRYPTO_HASH_INFO. Enable it in the default config file. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-09ARM: defconfig: tk1: unblock backported rtl8188euOleksandr Suvorov
The module staging/rtl8188eu in backports-5.4 depends on hidden config options WIRELESS_EXT and WEXT_PRIV. Enable both of them. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-04ARM: defconfig: tk1: enable building backports-5.4Oleksandr Suvorov
Backports-5.4 requires the undocumented build option CRYPTO_HASH_INFO. This option is selected by enabled ASYMMETRIC_PUBLIC_KEY_SUBTYPE. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-08-16ARM: config: apalis-tk1: Make USB a modulePhilippe Schenker
2019-04-23apalis-tk1: mmc: enable HS200 mode for eMMCOleksandr Suvorov
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Related to: #40373
2018-09-27apalis-tk1: build SELinux supportDominik Sliwa
Build SELinux support in kernel, but keep it disabled. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-21apalis-tk1: disable crypto devMarcel Ziswiler
Disable Tegra SE crypto dev as done in NVIDIA L4T R21.7. Similar to commit a7e55a39cdd1 ("CRYPTO: disable crypto dev fot t124"). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-06-21Merge tag 'tegra-l4t-r21.7' into toradex_tk1_l4t_r21.7-nextMarcel Ziswiler
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes from git://nv-tegra.nvidia.com/linux-3.10.git commit: e78bb38b883c42edf81766a1d557aed74458e08f Conflicts involved missing 24-bit LVDS support and a single whitespace aka tab difference in drivers/video/tegra/dc/sor.c. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-28apalis-tk1: handle backlight in the device treeApalis-TK1_LXDE-Image_2.8b2.97-20180331toradex_tk1_l4t_r21.6Dominik Sliwa
2018-03-28apalis-tk1: add atmel mxt to defconfigDominik Sliwa
2018-02-06CRYPTO: disable crypto dev fot t124Konduri Praveen
disabling tegra SE crypto dev for t124 platform. Bug 1927682 Change-Id: I16a24009e8f528df4be40ec65aa621b4ac779e41 Signed-off-by: Konduri Praveen <kondurip@nvidia.com> Reviewed-on: https://git-master.nvidia.com/r/1582395 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-12-21apalis-tk1_defconfig: enable user debugStefan Agner
Let the kernel print some debug messages when a user program crashes due to an exception. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20apalis-tk1: enable large physical address extension lpaeMarcel Ziswiler
Enable support for the Large Physical Address Extension aka LPAE. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-09-20apalis-tk1: update defconfig for wifiDominik Sliwa
2017-06-30apalis-tk1: snapd squashfs configurationApalis-TK1_LXDE-Image_2.7b3-20170630Marcel Ziswiler
Prepare for snapd integration. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30apalis-tk1: add multitouch hid supportStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 15e73283a975a1b899d7f6807aa882ef885573dd) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30apalis-tk1-k20: can and spi improvementsDominik Sliwa
This patch includes CAN driver and improvements in SPI communications for Apalis TK1 k20 based MFD. Requires firmware version 0.9. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11apalis_tk1: Support for K20 based MFDApalis_TK1_LinuxImageV2.7Beta1_20170112Dominik Sliwa
On Apalis TK1 boards K20 MCU is used for CAN, GPIO, ADC and touch screen. This patch includes support for core MFD device, GPIO, ADC and touch screen. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-11-21apalis-tk1: configure IPv6 SIT driver as moduleStefan Agner
SIT tunnels (IPv6 over IPv4) are not often used hence configure the driver as a module. This also gets rid of the extra network interface sit0 by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-11-21apalis-tk1: integrate adv7280-m, ap1302, ov5640 and tc358743 supportMarcel Ziswiler
Integrate SoC camera support for the following CSI-2 codecs/sensors: - Analog Devices ADV7280-M, analog camera decoder with deinterlacer, PAL/NTSC@60fps - ON Semiconductor (formerly Aptina) AP1302 ISP + AR1820 image sensor, 13Mpx, 1080p@30fps - OmniVision OV5640, 5Mpx sensor, 1080p@30fps - Toshiba TC358743 HDMI to CSI-2 bridge, 1080p@60fps Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-11-21apalis-tk1: re-add soc camera platform dataMarcel Ziswiler
Re-add SoC camera platform data from Ardbeg/Jetson TK1 board files. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-11-21apalis-tk1: clean-up defconfigMarcel Ziswiler
2016-06-29arm: tegra: initial support for apalis tk1Apalis_TK1_LinuxImageV2.6Beta2_20160701Marcel Ziswiler
This patch adds support for the Toradex Apalis TK1 acomputer on module which can be used on different carrier boards. The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec. Furthermore, there is a Kinetis MK20DN512 companion micro controller for analogue, CAN and resistive touch functionality which is not yet supported. This is known to boot into either a basic Angstrom/OpenEmbedded/Yocto or L4T/JetPack Ubuntu based image. The following things are known to work to a certain extend: - analogue/digital audio - debug UART1 - DVFS power management incl. low power core migration - eMMC - gigabit Ethernet - GPIOs - HDMI (incl. HDA audio) - I2C - LVDS - PCIe - SATA - SD/MMC cards - temperature sensor - USB host ports The rest is untested. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-05-02arm: config: T124: L4T: systemd related configsNinad Malwade
Added kernel configurations to support systemd functionality boot.img size is increased by 69632 bytes Bug 1731796 Change-Id: I4209fee15843ac645600500ed8c9fc37b7ff0c04 Signed-off-by: Ninad Malwade <nmalwade@nvidia.com> Reviewed-on: http://git-master/r/1134828 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Rajkumar Kasirajan <rkasirajan@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2016-01-12watchdog: enable TEGRA_WATCHDOG_ENABLE_ON_PROBEJeetesh Burman
enable TEGRA_WATCHDOG_ENABLE_ON_PROBE to set "timeout" in probe call Bug 200160105 Change-Id: Ifcef77b3229acee821c5cdd2f31e449e010b9d2f Signed-off-by: Jeetesh Burman <jburman@nvidia.com> Reviewed-on: http://git-master/r/927464 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2015-08-07arm: tegra12: disable USB_NET_RAW_IPBibek Basu
drop support for USB_NET_RAW_IP as its unused Bug 200092344 Change-Id: I085330c2ed8a83f83c027d91a03d13d1ce23e4f0 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/780277 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2015-07-14arm: tegra12: disable CONFIG_UID_STATBibek Basu
CONFIG_UID_STAT is buggy and not needed Bug 200115637 Change-Id: I105a46e91cba63508115be6fdd1c2e49962d25e8 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/764550 GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2015-06-08watchdog: use FIQ WDT for soft lockup stack dumpRenn Wu
Using Tegra WDT to trigger FIQ when system is in soft lockup. Bug 1581432 Change-Id: I853a88a3f6e9402c978db18c5a63e903c582040a Signed-off-by: Renn Wu <rewu@nvidia.com> Reviewed-on: http://git-master/r/265871 (cherry picked from commit f115f435d471af22ddec5e9d969662f79193f846) Reviewed-on: http://git-master/r/680353 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2015-05-19arm: tegra: enable dnotify config for t124Bibek Basu
Enable CONFIG_DNOTIFY for L4T kernel config Bug 1627091 Bug 200097847 Change-Id: I30d53089df825a776f03e1f0f08f1d6d8b1c9bb0 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/741517 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2015-04-15kernel: add imx185 sensor supportKassey Li
Bug 200044433 Change-Id: I792062649c247229270678a44d10323d2744b569 Signed-off-by: Kassey Li <kasseyl@nvidia.com> Reviewed-on: http://git-master/r/721561 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2015-04-15config: fix config conflict for wdtRenn Wu
Fix config conflict for watchdog. Tegra watchdog is disabled by default. Users can access /dev/watchdog0 to operate it. Bug 1557390 Change-Id: Ia1bb6c91dfbea85375d84bef10a10209b2fcef9f Signed-off-by: Renn Wu <rewu@nvidia.com> Reviewed-on: http://git-master/r/712938 Reviewed-by: Winnie Hsu <whsu@nvidia.com> Tested-by: Winnie Hsu <whsu@nvidia.com>
2015-03-17ARM: config: Enable Android Sync on LinuxNaveen Kumar S
Currently Android sync framework is used only in Android side, however, it provides a generic synchronization framework that can be used also in Linux. This patch enables Android Sync framework on T124, T132 and T210 on Linux. Bug 1601262 Change-Id: I46530a9b1b2245c0ddf8f7bc52b28af247350e14 Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Signed-off-by: Naveen Kumar S <nkumars@nvidia.com> Reviewed-on: http://git-master/r/677655 (cherry picked from commit 5998cc1d0d861986e34a74787650a79f3b1cd999) Reviewed-on: http://git-master/r/714740 GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2015-02-26kernel: add support for ar1335Ming Wong
Bug 1598204 Change-Id: I453d18ce570e57c0feab8dc3b24cc2c957b95301 Signed-off-by: Ming Wong <miwong@nvidia.com> Reviewed-on: http://git-master/r/672147 GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2015-02-09Kernel: add ov4689 kernel driverHu He
Bug 1600299 Change-Id: I63f4d597bcc8b960407a7291fde6aa2ddb5bec25 Signed-off-by: Ming Wong <miwong@nvidia.com> Reviewed-on: http://git-master/r/674099 Reviewed-by: Winnie Hsu <whsu@nvidia.com> GVS: Gerrit_Virtual_Submit
2015-01-29config: add L4T tegra watchdog supportXiming Chen
Tegra watchdog is disabled by default. Users can access /dev/watchdog0 to operate it. Bug 1557390 Change-Id: I0ee4f787336fc566900ffeb5c26c6fde6530b904 Signed-off-by: Ximing Chen <ximingc@nvidia.com> Reviewed-on: http://git-master/r/674635 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bibek Basu <bbasu@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2015-01-20FIQ: Implement WDT FIQ debuggerRenn Wu
Implement Tegra WDT FIQ debug function. Default is disabled. Bug 1581432 Change-Id: Ic81ab4cd3285080016b37191e6e0fab18e330a30 Signed-off-by: Renn Wu <rewu@nvidia.com> Reviewed-on: http://git-master/r/#/c/271988 Reviewed-on: http://git-master/r/662550 Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2015-01-16ARM: config: tegra: add ramoops support for JetsonXiming Chen
Enabling PSTORE configrations for L4T Bug 1581073 Change-Id: Ic54616379a5a279117ae85cb0e3465ef5c2c70b8 Signed-off-by: Ximing Chen <ximingc@nvidia.com> Reviewed-on: http://git-master/r/661347 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Reviewed-by: Rui Zhuo <rzhuo@nvidia.com> Reviewed-by: Renn Wu <rewu@nvidia.com> Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2014-12-10arm: tegra12: enable gpu edp capping for jetsonBibek Basu
Enable GPU edp capping for jetson-tk1.Also update the max_cpu_current and max_gpu_current for PM375 Bug 1563635 Change-Id: I165440959ba0f23d102f1d89a6c6e9191329305d Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/590332 GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2014-11-04config: add ar0330 supportMing Wong
Bug 1552628 Change-Id: I959eb0e54966d0ad163920a187e37b0b76142433 Signed-off-by: Ming Wong <miwong@nvidia.com> Signed-off-by: Mihir Thakkar <mthakkar@nvidia.com> Reviewed-on: http://git-master/r/562206 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2014-10-27arm: tegra12: Enable CPU CVB supportsreenivasulu velpula
- Add cl-dvfs platform data - Add function call to get cpu clock switch cooling device trip points. Bug 1563635 Change-Id: I07e0a9e8d170543906f91979fb35b98c02fe18cb Signed-off-by: sreenivasulu velpula <svelpula@nvidia.com> Reviewed-on: http://git-master/r/437195 (cherry picked from commit 55321cec6a72dd9b2e0ad6fb94ff2cc42937a14a) Reviewed-on: http://git-master/r/559393 Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2014-10-24arm: configs: L4T config for intel7260 wirelessPhilip Rakity
bug 1567414 Change-Id: I9f41f991940016ce6b66777ec10703acef1c96b5 Signed-off-by: Philip Rakity <prakity@nvidia.com> Reviewed-on: http://git-master/r/561969 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2014-10-07arm: tegra12_defconfig: set 3GB-16MB task sizetegra-l4t-r21.1daily-2014.11.07.1_l4t/l4t-r21Zheng Liu
The previously used 3GB-24MB task size caused relocation failures when loading kernel modules. This happened because part of the module loading area got beyond the 32MB relocation range from kernel .text segment. This problem is ARM32-specific and does not affect ARM64. Bug 1489463 Change-Id: I255eb605988b3095d49f05d4d4b199bf2c796bfd Signed-off-by: Zheng Liu <zhliu@nvidia.com> Reviewed-on: http://git-master/r/553996 Reviewed-by: Winnie Hsu <whsu@nvidia.com> Tested-by: Winnie Hsu <whsu@nvidia.com>
2014-10-07arm: tegra12_defconfig: make audio drivers inbuiltZheng Liu
Revert previous changes to modularize the audio drivers. The module probe/remove paths of these drivers are untested and buggy. Make these drivers built-in until the bugs are worked out, and schedule allows for thorough testing. Bug 1536426 Change-Id: Ic1698e7205b1d97461051cd1e25a513dac9649fe Signed-off-by: Zheng Liu <zhliu@nvidia.com> Reviewed-on: http://git-master/r/554287 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-10-01arm: tegra12_defconfig: max98090 as loadable moduleShreshtha SAHU
Bug 1550880 Change-Id: I6278cde7643dd3b298d72c54497cb5274a5de544 Signed-off-by: Shreshtha SAHU <ssahu@nvidia.com> Reviewed-on: http://git-master/r/551903 Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2014-09-24ARM: tegra12: config: enable clock preinit codeBryan Wu
Enable clock preinit code by default for U-Boot. Bug 1482099 Change-Id: I72fa1e9b45f580813846c7506efec5a03347efcd Signed-off-by: Bryan Wu <pengw@nvidia.com> Signed-off-by: Prabhu Kuttiyam <pkuttiyam@nvidia.com> Reviewed-on: http://git-master/r/408428 (cherry picked from commit 8f2ff20c410a8b7a25e4132e6a194117e4f74361) Reviewed-on: http://git-master/r/500874 Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-09-12Arm: config: tegra12: Enable interactive governorRajkumar Kasirajan
The interactive governor provides better performance than ondemand governor. Enable it to improve the performance. Bug 1359622 Change-Id: Ibc51285531ce2ef0d20fc668e240ef59db1322b1 Signed-off-by: Rajkumar Kasirajan <rkasirajan@nvidia.com> (cherry picked from commit 42ad40e52df0423d1622b1aa9835033c1c8ef890) Reviewed-on: http://git-master/r/#/c/488018/ Reviewed-on: http://git-master/r/488030 Reviewed-by: Winnie Hsu <whsu@nvidia.com> Tested-by: Winnie Hsu <whsu@nvidia.com>
2014-09-08arm: configs: vcm30t124: enable Tegra ProfilerIgor Nabirushkin
Enable Tegra Profiler for vcm30t124 board. Bug 1540280 Change-Id: I75263020677b0dd7f210bbdc72a775a05370ef81 Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com> Reviewed-on: http://git-master/r/437635 (cherry picked from commit f0cd768a1d49bcadc0ced238b0ce24272219cd2f) Reviewed-on: http://git-master/r/481972 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Andrey Trachenko <atrachenko@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-09-08arm: configs: tegra12: enable Tegra ProfilerIgor Nabirushkin
Enable Tegra Profiler for L4T. Bug 1540280 Change-Id: I700401a44e91370f3e811999b0017ac6ef2ff28a Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com> Reviewed-on: http://git-master/r/453861 (cherry picked from commit 25cfc076fc7b4133d4d3027c9530723325b8fa3d) Reviewed-on: http://git-master/r/481968 Reviewed-by: Winnie Hsu <whsu@nvidia.com> Tested-by: Winnie Hsu <whsu@nvidia.com>
