Enable WIRELESS_EXT and WEXT_PRIV options for the backported
rtl81288eu driver.
Related-to: ELB-2388
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Disabling all wireless drivers and cfg80211 module makes able
to completely avoid interferences with backported drivers.
Backports-5.4 requires the config option CRYPTO_HASH_INFO.
Enable it in the default config file.
The module staging/rtl8188eu in backports-5.4 depends on hidden
config options WIRELESS_EXT and WEXT_PRIV. Enable both of them.
Backports-5.4 requires the undocumented build option CRYPTO_HASH_INFO.
This option is selected by enabled ASYMMETRIC_PUBLIC_KEY_SUBTYPE.
Related to: #40373
Build SELinux support in kernel, but keep it disabled.
Disable Tegra SE crypto dev as done in NVIDIA L4T R21.7.
Similar to commit a7e55a39cdd1 ("CRYPTO: disable crypto dev fot t124").
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
disabling tegra SE crypto dev for
t124 platform.
Bug 1927682
Change-Id: I16a24009e8f528df4be40ec65aa621b4ac779e41
Signed-off-by: Konduri Praveen <kondurip@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1582395
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Let the kernel print some debug messages when a user program
crashes due to an exception.
Enable support for the Large Physical Address Extension aka LPAE.
Prepare for snapd integration.
(cherry picked from commit 15e73283a975a1b899d7f6807aa882ef885573dd)
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Integrate SoC camera support for the following CSI-2 codecs/sensors:
- Analog Devices ADV7280-M, analog camera decoder with deinterlacer,
PAL/NTSC@60fps
- ON Semiconductor (formerly Aptina) AP1302 ISP + AR1820 image sensor,
13Mpx, 1080p@30fps
- OmniVision OV5640, 5Mpx sensor, 1080p@30fps
- Toshiba TC358743 HDMI to CSI-2 bridge, 1080p@60fps
Re-add SoC camera platform data from Ardbeg/Jetson TK1 board files.
This patch adds support for the Toradex Apalis TK1 acomputer on module
which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality which is not yet
supported.
This is known to boot into either a basic Angstrom/OpenEmbedded/Yocto
or L4T/JetPack Ubuntu based image.
The following things are known to work to a certain extend:
- analogue/digital audio
- debug UART1
- DVFS power management incl. low power core migration
- eMMC
- gigabit Ethernet
- GPIOs
- HDMI (incl. HDA audio)
- I2C
- LVDS
- PCIe
- SATA
- SD/MMC cards
- temperature sensor
- USB host ports
The rest is untested.
Added kernel configurations to support
systemd functionality
boot.img size is increased by 69632 bytes
Bug 1731796
Change-Id: I4209fee15843ac645600500ed8c9fc37b7ff0c04
Signed-off-by: Ninad Malwade <nmalwade@nvidia.com>
Reviewed-on: http://git-master/r/1134828
Reviewed-by: Rajkumar Kasirajan <rkasirajan@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
enable TEGRA_WATCHDOG_ENABLE_ON_PROBE to set "timeout" in probe call
Bug 200160105
Change-Id: Ifcef77b3229acee821c5cdd2f31e449e010b9d2f
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: http://git-master/r/927464
drop support for USB_NET_RAW_IP as its unused
Bug 200092344
Change-Id: I085330c2ed8a83f83c027d91a03d13d1ce23e4f0
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/780277
CONFIG_UID_STAT is buggy and not needed
Bug 200115637
Change-Id: I105a46e91cba63508115be6fdd1c2e49962d25e8
Reviewed-on: http://git-master/r/764550
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Using Tegra WDT to trigger FIQ when system is in soft lockup.
Bug 1581432
Change-Id: I853a88a3f6e9402c978db18c5a63e903c582040a
Signed-off-by: Renn Wu <rewu@nvidia.com>
Reviewed-on: http://git-master/r/265871
(cherry picked from commit f115f435d471af22ddec5e9d969662f79193f846)
Reviewed-on: http://git-master/r/680353
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Enable CONFIG_DNOTIFY for L4T kernel config
Bug 1627091
Bug 200097847
Change-Id: I30d53089df825a776f03e1f0f08f1d6d8b1c9bb0
Reviewed-on: http://git-master/r/741517
Bug 200044433
Change-Id: I792062649c247229270678a44d10323d2744b569
Signed-off-by: Kassey Li <kasseyl@nvidia.com>
Reviewed-on: http://git-master/r/721561
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Fix config conflict for watchdog.
Tegra watchdog is disabled by default.
Users can access /dev/watchdog0 to operate it.
Bug 1557390
Change-Id: Ia1bb6c91dfbea85375d84bef10a10209b2fcef9f
Reviewed-on: http://git-master/r/712938
Tested-by: Winnie Hsu <whsu@nvidia.com>
Currently Android sync framework is used only in Android side,
however, it provides a generic synchronization framework that
can be used also in Linux.
This patch enables Android Sync framework on T124, T132 and T210
on Linux.
Bug 1601262
Change-Id: I46530a9b1b2245c0ddf8f7bc52b28af247350e14
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/677655
(cherry picked from commit 5998cc1d0d861986e34a74787650a79f3b1cd999)
Reviewed-on: http://git-master/r/714740
Bug 1598204
Change-Id: I453d18ce570e57c0feab8dc3b24cc2c957b95301
Signed-off-by: Ming Wong <miwong@nvidia.com>
Reviewed-on: http://git-master/r/672147
Bug 1600299
Change-Id: I63f4d597bcc8b960407a7291fde6aa2ddb5bec25
Reviewed-on: http://git-master/r/674099
Bug 1557390
Change-Id: I0ee4f787336fc566900ffeb5c26c6fde6530b904
Signed-off-by: Ximing Chen <ximingc@nvidia.com>
Reviewed-on: http://git-master/r/674635
Implement Tegra WDT FIQ debug function.
Default is disabled.
Bug 1581432
Change-Id: Ic81ab4cd3285080016b37191e6e0fab18e330a30
Reviewed-on: http://git-master/r/#/c/271988
Reviewed-on: http://git-master/r/662550
Enabling PSTORE configrations for L4T
Bug 1581073
Change-Id: Ic54616379a5a279117ae85cb0e3465ef5c2c70b8
Reviewed-on: http://git-master/r/661347
Reviewed-by: Rui Zhuo <rzhuo@nvidia.com>
Reviewed-by: Renn Wu <rewu@nvidia.com>
Enable GPU edp capping for jetson-tk1.Also
update the max_cpu_current and max_gpu_current for
PM375
Bug 1563635
Change-Id: I165440959ba0f23d102f1d89a6c6e9191329305d
Reviewed-on: http://git-master/r/590332
Bug 1552628
Change-Id: I959eb0e54966d0ad163920a187e37b0b76142433
Signed-off-by: Mihir Thakkar <mthakkar@nvidia.com>
Reviewed-on: http://git-master/r/562206
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
- Add cl-dvfs platform data
- Add function call to get cpu clock switch cooling
device trip points.
Bug 1563635
Change-Id: I07e0a9e8d170543906f91979fb35b98c02fe18cb
Signed-off-by: sreenivasulu velpula <svelpula@nvidia.com>
Reviewed-on: http://git-master/r/437195
(cherry picked from commit 55321cec6a72dd9b2e0ad6fb94ff2cc42937a14a)
Reviewed-on: http://git-master/r/559393
Tested-by: Bibek Basu <bbasu@nvidia.com>
bug 1567414
Change-Id: I9f41f991940016ce6b66777ec10703acef1c96b5
Signed-off-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/561969
The previously used 3GB-24MB task size caused relocation failures when
loading kernel modules. This happened because part of the module loading
area got beyond the 32MB relocation range from kernel .text segment.
This problem is ARM32-specific and does not affect ARM64.
Bug 1489463
Change-Id: I255eb605988b3095d49f05d4d4b199bf2c796bfd
Signed-off-by: Zheng Liu <zhliu@nvidia.com>
Reviewed-on: http://git-master/r/553996
Revert previous changes to modularize the audio drivers. The module
probe/remove paths of these drivers are untested and buggy. Make these
drivers built-in until the bugs are worked out, and schedule allows
for thorough testing.
Bug 1536426
Change-Id: Ic1698e7205b1d97461051cd1e25a513dac9649fe
Reviewed-on: http://git-master/r/554287
Bug 1550880
Change-Id: I6278cde7643dd3b298d72c54497cb5274a5de544
Signed-off-by: Shreshtha SAHU <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/551903
Enable clock preinit code by default for U-Boot.
Bug 1482099
Change-Id: I72fa1e9b45f580813846c7506efec5a03347efcd
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Signed-off-by: Prabhu Kuttiyam <pkuttiyam@nvidia.com>
Reviewed-on: http://git-master/r/408428
(cherry picked from commit 8f2ff20c410a8b7a25e4132e6a194117e4f74361)
Reviewed-on: http://git-master/r/500874
The interactive governor provides better performance than
ondemand governor. Enable it to improve the performance.
Bug 1359622
Change-Id: Ibc51285531ce2ef0d20fc668e240ef59db1322b1
Signed-off-by: Rajkumar Kasirajan <rkasirajan@nvidia.com>
(cherry picked from commit 42ad40e52df0423d1622b1aa9835033c1c8ef890)
Reviewed-on: http://git-master/r/#/c/488018/
Reviewed-on: http://git-master/r/488030
Enable Tegra Profiler for vcm30t124 board.
Bug 1540280
Change-Id: I75263020677b0dd7f210bbdc72a775a05370ef81
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/437635
(cherry picked from commit f0cd768a1d49bcadc0ced238b0ce24272219cd2f)
Reviewed-on: http://git-master/r/481972
Reviewed-by: Andrey Trachenko <atrachenko@nvidia.com>
Enable Tegra Profiler for L4T.
Bug 1540280
Change-Id: I700401a44e91370f3e811999b0017ac6ef2ff28a
Reviewed-on: http://git-master/r/453861
(cherry picked from commit 25cfc076fc7b4133d4d3027c9530723325b8fa3d)
Reviewed-on: http://git-master/r/481968
