change invensens build method from dynamic library to
static library
- modify CONFIG_INV_MPU, CONFIG_INV_AKM8975, CONFIG_INV_BMP180
to be "=y", build those module as static library
- remove "insmod inv-mpu.ko", "insmod inv-ak8975.ko"
"insmod inv-bmp180.ko" command from init script
- set init priority of akm89xx/bmp180 as late_initcall
That will make sure system always loaded akm89xx/bmp180 after
inv-mpu module when those modules was builded as static library.
Bug 1468040
Change-Id: I0cf43f73b8654cadead45ed60c5f141e9197e111
Signed-off-by: Jajambo Liao <jajambol@nvidia.com>
Reviewed-on: http://git-master/r/424534
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
This patch makes the necessary modifications to the gk20a driver to
allow building it as a module.
Bug 1476801
Change-Id: I88c4e1c1867baa1c2d010ac6e0c30bdb5fd63b91
Signed-off-by: Lauri Peltonen <lpeltonen@nvidia.com>
Reviewed-on: http://git-master/r/380970
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Enable IIO based INA219 device driver config CONFIG_INA219
on tegra11, tegra12 and tegra13 defconfigs.
Change-Id: Id844c13703c83ab49d514d913cd8f1bf8d5a1e6f
Reviewed-on: http://git-master/r/372861
GVS: Gerrit_Virtual_Submit
Enable IIO based INA230 device driver config CONFIG_INA230
on tegra11 and tegra12 defconfigs.
Change-Id: I8149b2cbcf23a438d2cf46a11544b48a37dd6d25
Reviewed-on: http://git-master/r/368428
Enable IIO based INA3221 device driver config CONFIG_INA3221
Change-Id: Iaee69b79330201856e8e8d012ebfece6e431f58f
Reviewed-on: http://git-master/r/367786
Enable PWM based regulator config, REGULATOR_PWM for all
tegra defconfigs used on Tegra124 and Tegra132 platforms.
Change-Id: I4b36780161d66a66a64e06a3f0ca82e3206e6ddc
Reviewed-on: http://git-master/r/361358
Enable CPU_FREQ to allow CPU frequency scaling
Change-Id: I8006e87b921b6521db4341a251c633aaaac8fa7e
Signed-off-by: Vivek Aseeja <vaseeja@nvidia.com>
Reviewed-on: http://git-master/r/357915
Reviewed-by: Kiran Kasamsetty <kkasamsetty@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Enable PINCTRL_AS3722 and POWER_RESET_AS3722
Bug 1409265
Change-Id: I8aee3a59f035f6c04d80ca05ae34eecea1abcd3b
Reviewed-on: http://git-master/r/334160
Reviewed-by: Vivek Aseeja <vaseeja@nvidia.com>
Tested-by: Vivek Aseeja <vaseeja@nvidia.com>
This config is no more used and hence removing from all config files.
Change-Id: Iac39b81f14ec22a20027a2f0b22ce148c6fe7e25
Reviewed-on: http://git-master/r/328691
Enable CONFIG_TEGRA_EMC_SCALING_ENABLE and
CONFIG_TEGRA_CPU_DVFS,CONFIG_TEGRA_USE_NCT
Change-Id: I22cd9122e77381b4314b94684f06c50cd31f1b3a
Signed-off-by: Anand Bhatia <anandb@nvidia.com>
Reviewed-on: http://git-master/r/329071
Enable clock driver for AS3722 to get support for the
CLK32K out from device.
Change-Id: I89943f819eadd1c39616b777825d34dc819cfa34
Reviewed-on: http://git-master/r/328283
With CL http://git-master/r/#/c/304723/, non-android platforms
need not explicitly disable ANDROID_PARANOID_NETWORK in their
defconfigs.
bug 1394512
Change-Id: Ie0c4fb765e115966c5e766f86cc68be6254b6acd
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/309441
add loki support and CONFIG_NFS_V4
remove TEGRA_GPU_DVFS and CONFIG_ANDROID_PARANOID_NETWORK
Bug 1355741
Change-Id: Ic216227ff2aa55c82e37c465f934fd11812ce8c1
Signed-off-by: Tope Yang <topey@nvidia.com>
Reviewed-on: http://git-master/r/300293
Reviewed-by: Lael Jones <lajones@nvidia.com>
Tested-by: Lael Jones <lajones@nvidia.com>
Reviewed-by: Anders Ma <andersm@nvidia.com>
Disable HS200 Mode at boot for EMMC
Change-Id: I155c33eb5273ce1aae1c521d1f034f86f77fc82d
Reviewed-on: http://git-master/r/299041
Both CONFIG_TRACEDUMP and CONFIG_TRACEDUMP_PROCFS are disabled
since they give build error on kernel 3.10
kernel/kernel/trace/tracedump.c: In function 'iter_init':
kernel/kernel/trace/tracedump.c:155:3: error: 'struct trace_array' has no member named 'data'
kernel/kernel/trace/tracedump.c:167:36: error: 'struct trace_array' has no member named 'buffer'
kernel/kernel/trace/tracedump.c: In function 'iter_deinit':
kernel/kernel/trace/tracedump.c:209:3: error: 'struct trace_array' has no member named 'data'
kernel/kernel/trace/tracedump.c: In function 'pager_init':
kernel/kernel/trace/tracedump.c:227:3: error: 'struct trace_array' has no member named 'data'
kernel/kernel/trace/tracedump.c: In function 'pager_next':
kernel/kernel/trace/tracedump.c:261:53: error: 'struct trace_array' has no member named 'buffer'
kernel/kernel/trace/tracedump.c:267:38: error: 'struct trace_array' has no member named 'buffer'
kernel/kernel/trace/tracedump.c: In function 'pager_deinit':
kernel/kernel/trace/tracedump.c:281:38: error: 'struct trace_array' has no member named 'buffer'
kernel/kernel/trace/tracedump.c:284:3: error: 'struct trace_array' has no member named 'data'
kernel/kernel/trace/tracedump.c: In function 'consume_events':
kernel/kernel/trace/tracedump.c:320:30: error: 'struct trace_array' has no member named 'buffer'
kernel/kernel/trace/tracedump.c: In function 'tracedump_initcall':
kernel/kernel/trace/tracedump.c:667:2: error: implicit declaration of function 'create_proc_entry' [-Werror=implicit-function-declaration]
kernel/kernel/trace/tracedump.c:667:8: warning: assignment makes pointer from integer without a cast [enabled by default]
kernel/kernel/trace/tracedump.c:671:8: error: dereferencing pointer to incomplete type
cc1: some warnings being treated as errors
Once these errors are resolved, we can re-enable the config.
Bug 1385705
Change-Id: I7f9224ff21fc0541a88d910b981902640dcc6fad
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/284353
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Tested-by: Sridhar Lavu <slavu@nvidia.com>
Enable CLK_PALMAS to supports clock from Palmas devices.
Change-Id: I8af130c4b03f019d55a275c3c05668d5cc8b7c93
Reviewed-on: http://git-master/r/279803
(cherry picked from commit 45e9601557a285f63bfcdeb0ce6b7b31d72914ca)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Enabled config options TEGRA_PCI, PCIEPORTBUS, PCIAER,
PCIEASPM, PCI_MSI.
Change-Id: I8be6992aa5c825244910363392b489f6fa2c646d
Reviewed-on: http://git-master/r/270225
Enable POWER_SUPPLY_EXTCON for T124 platform to support the
power supply notification and status through extcon.
Change-Id: I779428a92d7ca97e8d678757699a19c1696e17f2
Reviewed-on: http://git-master/r/269481
Bug 1349683
Change-Id: I86f97e07157f6aa42cfc22fe0c7cbf53375e6f4c
Signed-off-by: Matt Craighead <mcraighead@nvidia.com>
Reviewed-on: http://git-master/r/267460
Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
Enable SQUASHFS, RAISERFS, FSCACHE, TMPFS etc
Disable PPP support
Change-Id: I16eda205066ad64bac84a54edb4fdd88eb732c51
Reviewed-on: http://git-master/r/264118
Enable renamed config variable TEGRA_CLOCK_DEBUG_FUNC
Change-Id: I357e97965e7f4f15b1b773ed887e7aa0e0c13606
Reviewed-on: http://git-master/r/262597
enable CONFIG_TEGRA_CLOCK_DEBUG_MODS support in mods defconfig
Change-Id: I781c090056075bb31732b033c96ecbe6d0ab13b9
Reviewed-on: http://git-master/r/255152
disable CPUQUIET, CPU_FREQ and CPU_IDLE support in mods defconfig
Change-Id: I4b9d11c12e45c219c5259f5629da181127eedbe1
Reviewed-on: http://git-master/r/252008
Change thermal governor to step wise for mods kernel config
This is in sync with Android configuration
Change-Id: I8e0633ce1756e4e8897af0d4d27f0ae7cbc8668f
Reviewed-on: http://git-master/r/250473
Bug 1323816
Change-Id: Ied4c0ea60f0cebd1d1481c55e66884d32dec1ca1
Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com>
Reviewed-on: http://git-master/r/250422
disable USB drivers since they conflict with MODS tests
disable sound drivers
Change-Id: Id5c880b4f96bf5fed11ac0139e9e38da2d41db06
Reviewed-on: http://git-master/r/246891
Reviewed-by: Chao Xu <cxu@nvidia.com>
disable GK20A and GRHOST drivers
disable camera and DSI drivers
Change-Id: Ide9727ba0e88193800339c6dfbd041b0723a0851
Reviewed-on: http://git-master/r/245287
disable bluetooth, SE, wireless, HDA drivers
disable USB modem, IOMMU, APBDMA drivers
Change-Id: I8801b5aa8b800bf501ce1c18def2a0e7b788d307
Reviewed-on: http://git-master/r/244801
Add t124 mods defconfig, currently a duplicate of android defconfig
Change-Id: If1e3ac237e187f39940ce9a1980650dc103d21ea
Reviewed-on: http://git-master/r/242565
