path: root/arch/arm/configs/s3c2410_defconfig
2012-03-03ARM: s3c2410_defconfig: update s3c2410_defconfigKukjin Kim
According to merging s3c24xx, updates the current s3c2410_defconfig. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-03-03ARM: S3C24XX: change the ARCH_S3C2410 to ARCH_S3C24XXKukjin Kim
This patch changes the ARCH name to "ARCH_S3C24XX" for Samsung S3C2410, S3C2412, S3C2413, S3C2416, S3C2440, S3C2442, S3C2443, and S3C2450 SoCs so that we can merge the mach-xxx directories and plat-s3c24xx dir. to just one mach-s3c24xx for them. I think this should be sent to upstream via samsung tree because this touches many samsung stuff. Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Greg Kroah-Hartman <gregkh@suse.de> [for the gadget part:] Acked-by: Felipe Balbi <balbi@ti.com> [for the framebuffer (video) part:] Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> [For the watchdog-part:] Acked-by: Wim Van Sebroeck <wim@iguana.be> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2010-05-28ARM: s3c2410_defconfig: Add new machinesBen Dooks
Add the SMDK2416, and the GTA02 to the list of machines that are included in the s3c2410_defconfig. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-26ARM: s3c2410_defconfig: Update s3c2410_defconfig to v2.6.34-gitBen Dooks
Update the s3c2410_defconfig to the latest kernel version v2.6.34-git Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-23ARM: s3c2410_defconfig: Update s3c2410_defconfig to v2.6.34Ben Dooks
Update the s3c2410_defconfig to the latest kernel version v2.6.34 Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-21ARM: SAMSUNG: Move pm-check.c to plat-samsungBen Dooks
Move the pm-check.c file to plat-samsung for all Samsung SoC users, and update Kconfig names to make them SAMSUNG_ instead of S3C2410_ Sed expresions used to make the change: s/S3C2410_PM_DEBUG/SAMSUNG_PM_DEBUG/g s/S3C2410_PM_CHECK/SAMSUNG_PM_CHECK/g Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-18ARM: SAMSUNG: Move S3C24XX ADC driver to plat-samsungMaurus Cuelenaere
Move S3C24XX ADC driver to plat-samsung Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-23[ARM] s3c2410_defconfig: add MINI2440 machine to buildBen Dooks
Add the MINI2440 to the list of machines built by the central defconfig. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-06-23[ARM] S3C: Remove unused CONFIG_DEBUG_S3C_PORTBen Dooks
Remove the unused CONFIG_DEBUG_S3C_PORT as we currently only have support for using the S3C UARTs via the low-level debug code. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-16[ARM] s3c2410_defconfig: Update miscellaneous driversBen Dooks
Update the driver build in the s3c2410_defconfig for the LED, IDE, Input and EEPROM options Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-16[ARM] s3c2410_defconfig: Update USB device driversBen Dooks
Add more USB device driver options to the s3c2410_defconfig, mostly as modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-16[ARM] s3c2410_defconfig: Update filesystem optionsBen Dooks
Update the filesystem options in the s3c2410_defconfig, such as building ext4, enable the automounter as modules and update the network filesysyem choices. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-16[ARM] s3c2410_defconfig: Add video/radio driversBen Dooks
Add a set of various video and radio drivers to the s3c2410_defconfig as modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-16[ARM] s3c2410_defconfig: Add sound driversBen Dooks
Add sound drivers to the s3c2410_defconfig. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-15[ARM] s3c2410_defconfig: Add MMC/SD core and driversBen Dooks
Add SD/MMC to the s3c2410_defconfig, building in the core and adding the rest of the drivers as modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-15[ARM] s3c2410_defconfig: Update machine configurationBen Dooks
Update the machine configuration of s3c2410_defconfig to add support for newer machines, and update the s3c24xx specific options. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-15[ARM] s3c2410_defconfig: Update network optionsBen Dooks
Update the list of modules being built for the network core of the s3c2410_defconfig. This update adds such items as TCP congestion, netfilter for IPv4 and IPv6. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-15[ARM] s3c2410_defconfig: update to 2.6.30-rc2Ben Dooks
Update arch/arm/configs/s3c2410_defconfig to the latest kernel release (2.6.30-rc2). Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-07-10Merge branches 'at91', 'dyntick', 'ep93xx', 'iop', 'ixp', 'misc', 'orion', ↵Russell King
'omap-reviewed', 'rpc', 'rtc' and 's3c' into devel
2008-07-07[ARM] s3c2410_defconfig: update for current buildBen Dooks
Update the s3c2410_defconfig for the current set of added patches. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: Split serial driver into core and per-cpu driversBen Dooks
The S3C2410 serial driver in drivers/serial/s3c2410.c has been growing bigger with the addition of more variants of this hardware with the growing Samsung SoCs range. As such, it would be easier to split this code up into a core and per-cpu drivers to make driver addition easier, and the core smaller. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: enable USB subset of driversBen Dooks
Enable a subset of USB drivers which are useful for using on these devices. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: add SCSI supportBen Dooks
Enable SCSI support, mainly to help with adding USB storage support later and for the imminent changes for libata. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: update networking optionsBen Dooks
Add the following to the networking confgiuration: 1) Packet socket support (useful for userland dhcp) 2) Add bluetooth and USB bluetooth drivers as modules 3) Add basic IPv6 support as modules. 4) Add the wireless core as modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: update miscellaneous optionsBen Dooks
Add some basic config filesystem, ensure errors are verbose by default. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: update filesystem optionsBen Dooks
Enable new filesystem options, such as: - JFFS2 summary nodes - Ext2/3 externed options - Standard CDROM filesystems Also add NTFS as a module. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: enable useful NLS optionsBen Dooks
Enable some useful NLS codepages to be built into the kernel, and build the rest as modules. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: update list of used driversBen Dooks
Update the drivers built, such as the SM501 and parallel port. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: s3c2410_defconfig: update to rc8Ben Dooks
Update the s3c2410_defconfig to rc8 Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-05-12[ARM] dyntick: Remove obsolete and unused ARM dyntick supportRussell King
dyntick is superseded by the clocksource/clockevent infrastructure, using the NO_HZ configuration option. No one implements dyntick on ARM anymore, so it's pointless keeping it around. Remove dyntick support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4518/1: S3C: Rename watchdog configuration optionsBen Dooks
Rename the S3C24XX configuration options for the watchdog boot controls for moving to the arch/arm/plat-s3c moves. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UARTBen Dooks
Rename DEBUG_S3C2410_PORT to DEBUG_S3C_PORT as well as DEBUG_S3C2410_UART to DEBUG_S3C_UART as part of the updates to moving to plat-s3c for S3C base support. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORTBen Dooks
Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT to be CONFIG_S3C_LOWLEVEL_UART_PORT as we move to using plat-s3c for base of S3C operations. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-19i2c: Delete the i2c-isa pseudo bus driverJean Delvare
There are no users of i2c-isa left, so we can finally get rid of it. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-04-16[ARM] 4313/1: S3C24XX: Update s3c2410 defconfig to 2.6.21-rc6Ben Dooks
Update defconfig to the latest kernel version and enable the h1940 LED driver Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-22[ARM] 4229/1: S3C2410: Add MACH_QT2410 to s3c2410_defconfigBen Dooks
Add the Armzone QT2410 to the list of built machines in the s3c2410_defconfig Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-22[ARM] 4228/2: S3C24XX: update s3c2410_defconfig for 2.6.21-rc1Ben Dooks
Udpate s3c2410_defconfig for 2.6.21-rc1 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-16[ARM] 4200/1: S3C2443: Update s3c2410_defconfig to add SMDK2443Ben Dooks
Add SMDK2443 to s3c2410_defconfig Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4188/1: S3C24XX: add CRAMFS to s3c2410_defconfigBen Dooks
Add cramfs support in by default, as a lot of our initrds are cramfs images. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-12[ARM] 4162/1: S3C24XX: update defconfig_s3c2410 after moveBen Dooks
Update the s3c2410_defconfig after the movement of arch/arm/mach-s3c2410 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4160/1: S3C24XX: defconfig update for 2.6.20Ben Dooks
Update defconfig for the 2.6.20 release, and ensure that the AML5900 machine is built. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-11[ARM] Remove PM_LEGACY=y from selected ARM defconfigsRussell King
Most ARM defconfigs don't actually need to have PM_LEGACY enabled. Disable it for ATEB9200, Collie, IXP4xx, OMAP H2, S3C2410 and Versatile. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-03[ARM] 3923/1: S3C24XX: update s3c2410_defconfig with new driversBen Dooks
Add the new drivers, such as SPI, LED and RTC core, to the s3c2410_defconfig. Signed-off-by: Ben Dooks <ben-linux@fluff.irg> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-03[ARM] 3922/1: S3C24XX: update s3c2410_defconfig to 2.6.19-rc4Ben Dooks
Update the s3c2410_defconfig to 2.6.19-rc4 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3844/1: S3C24XX: update s3c2410_defconfigBen Dooks
New s3c2410_defconfig, updated 2.6.18 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26[ARM] 3650/1: S3C2412: Update s3c2410_defconfigBen Dooks
Patch from Ben Dooks Add SMDK2413 to the list of the machines being built for ARCH_S3C2410, thus ensursing our all machines build has an representitive of the S3C2412/S3C2413 CPU series-- Signed-off-by: Ben Dooks <ben-linux@fluff.org>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
