Don't enable REGULATOR_DUMMY, it is only intended for development / testing.
There doesn't seem to be any value in setting it here and doing
so was an error on my part.
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
The motivation for this change is:
* It is consistent with all other shmobile boards and;
* Allows the kzm9g-reference code to work with CONFIG_SMP
and thus the new defconfig
* Enable ARM_APPENDED_DTB
Typically the bootloader of a kzm9g board does not support DT
so this option is useful.
* Use voltage regulators by default
* Move command line to dts
This brings us one small step closer to sharing defconfig
between kzm9g and other boards
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/boards
From Simon Horman:
"I will work on the suggestions by Arnd to reduce the number
of defconfigs for shmobile - in essence moving towards one or
two generic configs rather than per-board configs. However,
this seems to be somewhat non-trivial and in the mean time
I would like to keep updating the existing defcoings."
* 'defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: leave CONFIG_INOTIFY_USER enabled by default
ARM: shmobile: armadillo800eva: enable L2X0 cache on defconfig
ARM: shmobile: mackerel: defconfig update
CONFIG_INOTIFY_USER is enabled by default in its Kconfig. Disabling it
breaks udevd. Fix shmobile defconfig files to not specify this option
explicitly.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Simon Horman <horms@verge.net.au>
This patch enables three-axis digital accelerometer ADXL345.
Test:
sudo cat /dev/input/event2
then tip up the board. You get something from /dev/input/event2.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
This patch enables magnetometer ak8975.
I checked ak8975_probe() returns successfully.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"So this is the LW GPIO patch stack for v3.7:
- refactoring from Thierry Redding at Arnd Bergmann's request to use
the seq_file iterator interface in gpiolib.
- A new driver for Avionic Design's N-bit GPIO expander.
- Two instances of mutexes replaced by spinlocks from Axel Lin to
code that is supposed to be fastpath compliant.
- IRQ demuxer and gpio_to_irq() support for pcf857x by Kuninori
Morimoto.
- Dynamic GPIO numbers, device tree support, daisy chaining and some
other fixes for the 74x164 driver by Maxime Ripard.
- IRQ domain and device tree support for the tc3589x driver by Lee
Jones.
- Some conversion to use managed resources devm_* code.
- Some instances of clk_prepare() or clk_prepare_enable() added to
support the new, stricter common clock framework.
- Some for_each_set_bit() simplifications.
- Then a lot of fixes as we fixed up all of the above tripping over
our own shoelaces and that kind of thing."
* tag 'gpio-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (34 commits)
gpio: pcf857x: select IRQ_DOMAIN
gpio: Document device_node's det_debounce
gpio-lpc32xx: Add GPI_28
gpio: adnp: dt: Reference generic interrupt binding
gpio: Add Avionic Design N-bit GPIO expander support
gpio: pxa: using for_each_set_bit to simplify the code
gpio_msm: using for_each_set_bit to simplify the code
gpio: Enable the tc3298x GPIO expander driver for Device Tree
gpio: Provide the tc3589x GPIO expander driver with an IRQ domain
ARM: shmobile: kzm9g: use gpio-keys instead of gpio-keys-polled
gpio: pcf857x: fixup smatch WARNING
gpio: 74x164: Add support for the daisy-chaining
gpio: 74x164: dts: Add documentation for the dt binding
dt: Fix incorrect reference in gpio-led documentation
gpio: 74x164: Add device tree support
gpio: 74x164: Use dynamic gpio number assignment if no pdata is present
gpio: 74x164: Use devm_kzalloc
gpio: 74x164: Use module_spi_driver boiler plate function
gpio: sx150x: Use irq_data_get_irq_chip_data() at appropriate places
gpio: em: Use irq_data_get_irq_chip_data() at appropriate places
6e20a0a429bd4dc07d6de16d9c247270e04e4aa0
(gpio: pcf857x: enable gpio_to_irq() support) supports
gpio_to_irq() on pcf857x driver.
Now, we can use gpio-keys driver instead of gpio-keys-polled.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
This patch enables PMU(Performance Monitoring Unit) for sh73a0.
This is required for udev to run which is common to many user-spaces.
It is my understanding that this is a requirement for automated
testing conducted by Iwamatsu-san.
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Magnus Damm <damm@opensource.se>
This patch enable USB function on CN17
KZM-A9-GT board has RTC device r2025d at I2C channel 0
with slave address 0x64.
This patch enables reading and writing hardware real time clock on
KZM-A9-GT board. Interrupt is not yet supported.
How to test this patch using user space command.
Read RTC
# hwclock -r
Copy system clock to RTC
# hwclock -w
Shutdown and power off the board, and wait a while, then power on again.
Check RTC still keeps correct date.
Tested-by: Simon Horman <horms@verge.net.au>
Update the KZM9G defconfig and the code in platsmp.c to support SMP on
the sh73a0 based KZM9G board. Also fix up the earlyprintk setting that
was previously incorrect.
This patch enable GPIO-KEY/FSI,
and remove debug settings,
and be cleanuped by c2330e286f68f1c408b4aa6515ba49d57f05beae script
Acked-by: Simon Horman <horms@verge.net.au>
