Change-Id: I4a6e88f47803e88b0ce2d913be4aeb299ca858b4
Signed-off-by: Rom Lemarchand <romlem@android.com>
Change-Id: Ifbda55e570a22ace98d7d74b057ba21a597e0826
Change-Id: I8fe033090e38523152225dcfb7a1828f530a0757
Signed-off-by: JP Abgrall <jpa@google.com>
(cherry picked from commit 7aee29d6482954ac9fecae3ce8a90b6759158107)
The Logitech unifying driver depends on hidraw being available.
Recommending one without the other will cause the Logitech driver to
silently fail when connecting Logitech devices.
Change-Id: I92ed2b6803537d9da6eed7fcada8f329cb4469a2
Signed-off-by: Michael Wright <michaelwr@google.com>
TCPMSS is required for the Android Vpn service to correctly
handle the MTU on tun/ppp devices. Bug: 11579326
We don't really need SCHED_TRACER and the TIMER_STATS.
Change-Id: I10c5767a6324a496713752d4fe9eff361dc8e06a
(cherry picked from commit 23f01e8e81f3c53985958fa291b39c84293ad047)
Change-Id: I5ee4b794dcc00f74f26562e49a406ea292af63ee
(cherry picked from commit 9ebedefd06142c9bc812bfa23401031525002a76)
Discontinued in favor of future userspace charging helpers.
Change-Id: I840a94ff42e2219cfd8759f919f6188355a63d92
Signed-off-by: Todd Poynor <toddpoynor@google.com>
We don't like CONFIG_MODULES anymore.
Connection tracker handling of large SIP fails.
Change-Id: Ie3c65aefcc6181752d6656c97e63035e5b5653ff
Because there is not tool to consistently generate these config
fragments, lets keep the alphabetical instead of random.
Change-Id: I0f098f6be6bdd272544295a3d5a48d04411e4514
This will be a noop unless the KSM thread is enabled by userspace
Change-Id: Ia5fde14504cc0da50522e2f875d8d021f9e054ba
Signed-off-by: Rom Lemarchand <romlem@google.com>
Change-Id: I7647cd7037731df69dfdd513a0808b396d9d5bdd
Signed-off-by: Michael Wright <michaelwr@android.com>
- Add 2 files that contain the minimal and recommended kernel config
options respectively.
- Add a README to explain their purpose and how to use them to
generate a device config compatible with Android.
Change-Id: I3a4883f3b04d2820e90ceb3c4d02390d6458d6ce
