path: root/MAINTAINERS
2013-10-04Merge tag 'iommu-fixes-v3.12-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull iommu fixes from Joerg Roedel: "A couple of fixes from the IOMMU side: - some small fixes for the new ARM-SMMU driver - a register offset correction for VT-d - add MAINTAINERS entry for drivers/iommu Overall no really big or intrusive changes" * tag 'iommu-fixes-v3.12-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: x86/iommu: correct ICS register offset MAINTAINERS: add overall IOMMU section iommu/arm-smmu: don't enable SMMU device until probing has completed iommu/arm-smmu: fix iommu_present() test in init iommu/arm-smmu: fix a signedness bug
2013-10-02Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We have a fairly large batch of fixes this time around, mostly just due to various platforms all having a fix or two more than usual. Worth pointing out are: - A fix for EDMA on Davinci/OMAP where channel allocation broke with the DT conversion. Due to some miscommunication we didn't understand the impact of the breakage, so we were pushing back on it for 3.12, but it sounds like it's actually breaking quite a few people out there. - A bunch of fixes for Marvell platforms, some straggling fixes for merge window fallout and some fixes for a couple of the platforms (Netgear RN102 in particular). - A fix for a race between multi-cluster power management and cpu hotplug on Versatile Express. And a bunch of other smaller fixes that all add up. We'll be switching over into stricter regressions-only mode from here on out" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits) ARM: multi_v7_defconfig: add SDHCI for i.MX bus: mvebu-mbus: Fix optional pcie-mem/io-aperture properties ARM: mvebu: add missing DT Mbus ranges and relocate PCIe DT nodes for RN102 ARM: at91: sam9g45: shutdown ddr1 too when rebooting MAINTAINERS: ARM: SIRF: use kernel.org mail box MAINTAINERS: ARM: SIRF: add missed drivers into maintain list ARM: edma: Fix clearing of unused list for DT DMA resources ARM: vexpress: tc2: fix hotplug/idle/kexec race on cluster power down ARM: dts: sirf: fix interrupt and dma prop of VIP for prima2 and atlas6 ARM: dts: sirf: fix the ranges of peri-iobrg of prima2 ARM: dts: makefile: build atlas6-evb.dtb for ARCH_ATLAS6 ARM: dts: sirf: fix fifosize, clks, dma channels for UART ARM: mvebu: Add DT entry for ReadyNAS 102 to use gpio-poweroff driver ARM: mvebu: fix ReadyNAS 102 Power button GPIO to make it active high ARM: mach-integrator: Add stub for pci_v3_early_init() for !CONFIG_PCI ARM: shmobile: Remove #gpio-ranges-cells DT property gpio: rcar: Remove #gpio-range-cells DT property usage ARM: shmobile: armadillo: fixup ether pinctrl naming ARM: shmobile: Lager: add Micrel KSZ8041 PHY fixup ARM: shmobile: update SDHI DT compatibility string to the <unit>-<soc> format ...
2013-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking changes from David Miller: 1) Multiply in netfilter IPVS can overflow when calculating destination weight. From Simon Kirby. 2) Use after free fixes in IPVS from Julian Anastasov. 3) SFC driver bug fixes from Daniel Pieczko. 4) Memory leak in pcan_usb_core failure paths, from Alexey Khoroshilov. 5) Locking and encapsulation fixes to serial line CAN driver, from Andrew Naujoks. 6) Duplex and VF handling fixes to bnx2x driver from Yaniv Rosner, Eilon Greenstein, and Ariel Elior. 7) In lapb, if no other packets are outstanding, T1 timeouts actually stall things and no packet gets sent. Fix from Josselin Costanzi. 8) ICMP redirects should not make it to the socket error queues, from Duan Jiong. 9) Fix bugs in skge DMA mapping error handling, from Nikulas Patocka. 10) Fix setting of VLAN priority field on via-rhine driver, from Roget Luethi. 11) Fix TX stalls and VLAN promisc programming in be2net driver from Ajit Khaparde. 12) Packet padding doesn't get handled correctly in new usbnet SG support code, from Ming Lei. 13) Fix races in netdevice teardown wrt. network namespace closing. From Eric W. Biederman. 14) Fix potential missed initialization of net_secret if not TCP connections are openned. From Eric Dumazet. 15) Cinterion PLXX product ID in qmi_wwan driver is wrong, from Aleksander Morgado. 16) skb_cow_head() can change skb->data and thus packet header pointers, don't use stale ip_hdr reference in ip_tunnel code. 17) Backend state transition handling fixes in xen-netback, from Paul Durrant. 18) Packet offset for AH protocol is handled wrong in flow dissector, from Eric Dumazet. 19) Taking down an fq packet scheduler instance can leave stale packets in the queues, fix from Eric Dumazet. 20) Fix performance regressions introduced by TCP Small Queues. From Eric Dumazet. 21) IPV6 GRE tunneling code calculates max_headroom incorrectly, from Hannes Frederic Sowa. 22) Multicast timer handlers in ipv4 and ipv6 can be the last and final reference to the ipv4/ipv6 specific network device state, so use the reference put that will check and release the object if the reference hits zero. From Salam Noureddine. 23) Fix memory corruption in ip_tunnel driver, and use skb_push() instead of __skb_push() so that similar bugs are less hard to find. From Steffen Klassert. 24) Add forgotten hookup of rtnl_ops in SIT and ip6tnl drivers, from Nicolas Dichtel. 25) fq scheduler doesn't accurately rate limit in certain circumstances, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits) pkt_sched: fq: rate limiting improvements ip6tnl: allow to use rtnl ops on fb tunnel sit: allow to use rtnl ops on fb tunnel ip_tunnel: Remove double unregister of the fallback device ip_tunnel_core: Change __skb_push back to skb_push ip_tunnel: Add fallback tunnels to the hash lists ip_tunnel: Fix a memory corruption in ip_tunnel_xmit qlcnic: Fix SR-IOV configuration ll_temac: Reset dma descriptors indexes on ndo_open skbuff: size of hole is wrong in a comment ipv6 mcast: use in6_dev_put in timer handlers instead of __in6_dev_put ipv4 igmp: use in_dev_put in timer handlers instead of __in_dev_put ethernet: moxa: fix incorrect placement of __initdata tag ipv6: gre: correct calculation of max_headroom powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file Revert "powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file" bonding: Fix broken promiscuity reference counting issue tcp: TSQ can use a dynamic limit dm9601: fix IFF_ALLMULTI handling pkt_sched: fq: qdisc dismantle fixes ...
2013-09-30MAINTAINERS: add myself as maintainer of xen-netbackWei Liu
Signed-off-by: Wei Liu <wei.liu2@citrix.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30Merge tag 'for-linus-20130929' of git://github.com/sctscore/official-linuxLinus Torvalds
Pull S+core fixes from Lennox Wu: "These updates include updating information of maintainers, fix some trivial errors, and add a necessary function for supporting ipv6" * tag 'for-linus-20130929' of git://github.com/sctscore/official-linux: Score: Update the information of Score maintaners Score: Modify the Makefile of Score, remove -mlong-calls for compiling Score: Implement the function csum_ipv6_magic Score: The commit is for compiling successfully
2013-09-30MAINTAINERS: ARM: SIRF: use kernel.org mail boxBarry Song
Change my email to kernel.org which is easier for me to catch. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-30MAINTAINERS: ARM: SIRF: add missed drivers into maintain listBarry Song
Take more drivers into maintain list of CSR SiRF SoC machines. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-29Merge tag 'staging-3.12-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging fixes from Greg KH: "Here are some staging driver fixes, MAINTAINER updates, and a new device id. All of these have been in the linux-next tree, and are pretty simple patches" * tag 'staging-3.12-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8188eu: Add new device ID staging: imx-drm: Fix probe failure staging: vt6656: [BUG] iwctl_siwencodeext return if device not open staging: vt6656: [BUG] main_usb.c oops on device_close move flag earlier. staging: vt6656: rxtx.c [BUG] s_vGetFreeContext dead lock on null apTD. Staging: rtl8192u: r819xU_cmdpkt: checking NULL value after doing dev_alloc_skb staging: usbip: Orphan usbip staging: r8188eu: Add files for new drive: Cocci spatch "noderef" staging: r8188eu: Cocci spatch "noderef" staging: octeon-usb: Cocci spatch "noderef" staging: r8188eu: Add files for new drive: Cocci spatch "noderef" MAINTAINERS: staging: dgnc and dgap drivers: add maintainer staging: lustre: Cocci spatch "noderef"
2013-09-25staging: usbip: Orphan usbipTobias Polzer
The domain of Matt Mooneey's email doesn't exist anymore. Setting usbip to Oprhan. Signed-off-by: Tobias Polzer <tobias.polzer@fau.de> Signed-off-by: Dominik Paulus <dominik.paulus@fau.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-25MAINTAINERS: staging: dgnc and dgap drivers: add maintainerLidza Louina
This patch adds the staging/dgnc [DIGI NEO AND CLASSIC PCI PRODUCTS] and staging/dgap [DIGI EPCA PCI PRODUCTS] drivers to the MAINTAINERS file. I am listed as the maintainer and the driverdev-devel list is the mailing list for these drivers. Signed-off-by: Lidza Louina <lidza.louina@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-25update contact information for Mikael PetterssonMikael Pettersson
My old @it.uu.se email address is going away, so update relevant files to point to my @gmail.com address instead. In sata_promise.c just delete the address, people can get it from MAINTAINERS. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-26Score: Update the information of Score maintanersLennox Wu
Signed-off-by: Lennox Wu <lennox.wu@gmail.com>
2013-09-24MAINTAINERS: update mach-bcm related email addressChristian Daudt
Update email address on mach-bcm + drivers for Broadcom mobile SoCs. Signed-off-by: Christian Daudt <csd@broadcom.com> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24MAINTAINERS: add overall IOMMU sectionStephen Warren
I believe that Joerg Roedel is at least the path through which drivers/iommu changes should be merged. Add a MAINTAINERS entry to make this clear, so that he's Cd'd on all relevant patches. This is relevant for non-AMD/Intel IOMMUs, where get_maintainers.pl doesn't currently remind anyone to Cc Joerg on patches. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-09-11Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - Some pidns/fork/exec tweaks - OCFS2 updates - Most of MM - there remain quite a few memcg parts which depend on pending core cgroups changes. Which might have been already merged - I'll check tomorrow... - Various misc stuff all over the place - A few block bits which I never got around to sending to Jens - relatively minor things. - MAINTAINERS maintenance - A small number of lib/ updates - checkpatch updates - epoll - firmware/dmi-scan - Some kprobes work for S390 - drivers/rtc updates - hfsplus feature work - vmcore feature work - rbtree upgrades - AOE updates - pktcdvd cleanups - PPS - memstick - w1 - New "inittmpfs" feature, which does the obvious - More IPC work from Davidlohr. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (303 commits) lz4: fix compression/decompression signedness mismatch ipc: drop ipc_lock_check ipc, shm: drop shm_lock_check ipc: drop ipc_lock_by_ptr ipc, shm: guard against non-existant vma in shmdt(2) ipc: document general ipc locking scheme ipc,msg: drop msg_unlock ipc: rename ids->rw_mutex ipc,shm: shorten critical region for shmat ipc,shm: cleanup do_shmat pasta ipc,shm: shorten critical region for shmctl ipc,shm: make shmctl_nolock lockless ipc,shm: introduce shmctl_nolock ipc: drop ipcctl_pre_down ipc,shm: shorten critical region in shmctl_down ipc,shm: introduce lockless functions to obtain the ipc object initmpfs: use initramfs if rootfstype= or root= specified initmpfs: make rootfs use tmpfs when CONFIG_TMPFS enabled initmpfs: move rootfs code from fs/ramfs/ to init/ initmpfs: move bdi setup from init_rootfs to init_ramfs ...
2013-09-11memstick: add support for legacy memorysticksMaxim Levitsky
Based partially on MS standard spec quotes from Alex Dubov. As any code that works with user data this driver isn't recommended to use to write cards that contain valuable data. It tries its best though to avoid data corruption and possible damage to the card. Tested on MS DUO 64 MB card on Ricoh R592 card reader. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alex Dubov <oakad@yahoo.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: append "/" to directory patternsJoe Perches
It's clearer to have patterns marked as directories. Change the directory patterns without terminating slashes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: add mach-bcm and driversChristian Daudt
Add ownership to maintainers file for the mach-bcm related files, including drivers that are used for the SoCs defined in mach-bcm. Signed-off-by: Christian Daudt <csd@broadcom.com> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: update GRE DEMUX patternsJoe Perches
Commit c50cd357887a ("net: gre: move GSO functions to gre_offload") renamed and separated the file into multiple files. Update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Dmitry Kozlov <xeb@mail.ru> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: usb: phy: update patternsJoe Perches
Commit a0e631235a04 ("usb: phy: move all PHY drivers to drivers/usb/phy/") deleted the files, remove the file pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: update USB EHCI platform patternJoe Perches
Commit f3bc64d6d1f2 ("USB: EHCI: DT support for generic bus glue") removed the ehci-vt8500.c file, update the file pattern to include ehci-platform.c. Signed-off-by: Joe Perches <joe@perches.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: update file pattern for ARC uartJoe Perches
Commit 6659a20a76e0 ("ARC: MAINTAINERS update for ARC") typoed the file pattern. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: update ssbi patternsJoe Perches
Commit 45fcac1aad5d ("mfd: Move ssbi driver into drivers/mfd") move the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: update it913x patternsJoe Perches
Commit d7104bffcfb7 ("[media] MAINTAINERS: add drivers/media/tuners/it913x*") used the incorrect file patterns. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Antti Palosaari <crope@iki.fi> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: SI4713: fix file patternJoe Perches
Commit c937ca034a03 ("[media] MAINTAINERS: Add maintainer entry for si4713 FM transmitter driver") typoed the pattern, fix it. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Eduardo Valentin <edubezval@gmail.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: update SIANO driversJoe Perches
Commit 786baecfe78f ("[media] dvb-usb: move it to drivers/media/usb/dvb-usb") moved the files, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: ghes_edac: update patternJoe Perches
Commit 77c5f5d2f212 ("ghes_edac: Register at EDAC core the BIOS report") typoed the file pattern. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: ARM: S3C24XX: remove plat-s3c24xxJoe Perches
Commit 09ec1d7ea67f ("ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/") moved the files, remove the pattern. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: ARM: plat-nomadik: update patternsJoe Perches
Commit 694e33a7f42d ("ARM: plat-nomadik: move MTU, kill plat-nomadik") moved the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: ARM: spear: consolidate sectionsJoe Perches
Commit a7ed099ffc8e ("ARM: spear: move all files to mach-spear") moved all the files into a single directory, delete the now unnecessary duplicate sections and update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: ARM: S3C2410: update patternsJoe Perches
Commit 85fd6d63bf29 ("ARM: S3C2410: move mach-s3c2410/* into mach-s3c24xx/") moved the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: OMAP POWERDOMAIN, update patternsJoe Perches
Commit 498153995b9f ("ARM: OMAP2+: powerdomain/PRM: move the low-level powerdomain") renamed the files, update the patterns. Identical to a patch earlier sent by Cesar Eduardo Barros. Signed-off-by: Joe Perches <joe@perches.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Cesar Eduardo Barros <cesarb@cesarb.eti.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: ARM: OMAP2/3: remove unused clockdomain filesJoe Perches
Commit 4bd5259e53ac ("ARM: OMAP2/3: clockdomain/PRM/CM: move the low-level clockdomain functions into PRM/CM") deleted the files, update the pattern. Identical to a patch earlier sent by Cesar Eduardo Barros. Signed-off-by: Joe Perches <joe@perches.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Cesar Eduardo Barros <cesarb@cesarb.eti.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11MAINTAINERS: EXYNOS: remove board filesJoe Perches
Commit ca9143501c30 ("ARM: EXYNOS: Remove unused board files") removed the files, remove the patterns too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Tomasz Figa <t.figa@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Brown paper bag fix in HTB scheduler, class options set incorrectly due to a typoe. Fix from Vimalkumar. 2) It's possible for the ipv6 FIB garbage collector to run before all the necessary datastructure are setup during init, defer the notifier registry to avoid this problem. Fix from Michal Kubecek. 3) New i40e ethernet driver from the Intel folks. 4) Add new qmi wwan device IDs, from Bjørn Mork. 5) Doorbell lock in bnx2x driver is not initialized properly in some configurations, fix from Ariel Elior. 6) Revert an ipv6 packet option padding change that broke standardized ipv6 implementation test suites. From Jiri Pirko. 7) Fix synchronization of ARP information in bonding layer, from Nikolay Aleksandrov. 8) Fix missing error return resulting in illegal memory accesses in openvswitch, from Daniel Borkmann. 9) SCTP doesn't signal poll events properly due to mistaken operator precedence, fix also from Daniel Borkmann. 10) __netdev_pick_tx() passes wrong index to sk_tx_queue_set() which essentially disables caching of TX queue in sockets :-/ Fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits) net_sched: htb: fix a typo in htb_change_class() net: qmi_wwan: add new Qualcomm devices ipv6: don't call fib6_run_gc() until routing is ready net: tilegx driver: avoid compiler warning fib6_rules: fix indentation irda: vlsi_ir: Remove casting the return value which is a void pointer irda: donauboe: Remove casting the return value which is a void pointer net: fix multiqueue selection net: sctp: fix smatch warning in sctp_send_asconf_del_ip net: sctp: fix bug in sctp_poll for SOCK_SELECT_ERR_QUEUE net: fib: fib6_add: fix potential NULL pointer dereference net: ovs: flow: fix potential illegal memory access in __parse_flow_nlattrs bcm63xx_enet: remove deprecated IRQF_DISABLED net: korina: remove deprecated IRQF_DISABLED macvlan: Move skb_clone check closer to call qlcnic: Fix warning reported by kbuild test robot. bonding: fix bond_arp_rcv setting and arp validate desync state bonding: fix store_arp_validate race with mode change ipv6/exthdrs: accept tlv which includes only padding bnx2x: avoid atomic allocations during initialization ...
2013-09-11i40e: include i40e in kernel properJesse Brandeburg
This patch adds the changes for Kconfig, i40e.txt, MAINTAINERS, Kbuild and new i40e/Makefile to build i40e with the kernel. New driver build option is CONFIG_I40E Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> CC: PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com> CC: e1000-devel@lists.sourceforge.net Tested-by: Kavindya Deegala <kavindya.s.deegala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-09-10Merge tag 'for-v3.12' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery/power supply driver updates from Anton Vorontsov: "New drivers: - APM X-Gene system reboot driver by Feng Kan and Loc Ho (APM). - Qualcomm MSM reboot/poweroff driver by Abhimanyu Kapur (Codeaurora). - Texas Instruments BQ24190 charger driver by Mark A. Greer (Animal Creek Technologies). - Texas Instruments TWL4030 MADC battery driver by Lukas Märdian and Marek Belisko (Golden Delicious Computers). The driver is used on Freerunner GTA04 phones. Highlighted fixes and improvements: - Suspend/wakeup logic improvements: power supply objects will block system suspend until all power supply events are processed. Thanks to Zoran Markovic (Linaro), Arve Hjonnevag and Todd Poynor (Google)" * tag 'for-v3.12' of git://git.infradead.org/battery-2.6: rx51_battery: Fix channel number when reading adc value power: Add twl4030_madc battery driver. bq24190_charger: Workaround SS definition problem on i386 builds power_supply: Prevent suspend until power supply events are processed vexpress-poweroff: Should depend on the required infrastructure twl4030-charger: Fix compiler warning with regulator_enable() rx51_battery: Replace hardcoded channels values. bq24190_charger: Add support for TI BQ24190 Battery Charger ab8500-charger: We print an unintended error message max8925_power: Fix missing of_node_put power_supply: Replace strict_strtol() with kstrtol() power: Add APM X-Gene system reboot driver power_supply: tosa_battery: Get rid of irq_to_gpio usage power supply: collie_battery: Convert to use dev_pm_ops power_supply: Make goldfish_battery depend on GOLDFISH || COMPILE_TEST power: reset: Add msm restart support MAINTAINERS: drivers/power: add entry for SmartReflex AVS drivers
2013-09-10Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This pull brings: - Andy's DW driver updates - Guennadi's sh driver updates - Pl08x driver fixes from Tomasz & Alban - Improvements to mmp_pdma by Daniel - TI EDMA fixes by Joel - New drivers: - Hisilicon k3dma driver - Renesas rcar dma driver - New API for publishing slave driver capablities - Various fixes across the subsystem by Andy, Jingoo, Sachin etc..." * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (94 commits) dma: edma: Remove limits on number of slots dma: edma: Leave linked to Null slot instead of DUMMY slot dma: edma: Find missed events and issue them ARM: edma: Add function to manually trigger an EDMA channel dma: edma: Write out and handle MAX_NR_SG at a given time dma: edma: Setup parameters to DMA MAX_NR_SG at a time dmaengine: pl330: use dma_set_max_seg_size to set the sg limit dmaengine: dma_slave_caps: remove sg entries dma: replace devm_request_and_ioremap by devm_ioremap_resource dma: ste_dma40: Fix potential null pointer dereference dma: ste_dma40: Remove duplicate const dma: imx-dma: Remove redundant NULL check dma: dmagengine: fix function names in comments dma: add driver for R-Car HPB-DMAC dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap() dma: imx-sdma: Staticize sdma_driver_data structures pch_dma: Add MODULE_DEVICE_TABLE dmaengine: PL08x: Add cyclic transfer support dmaengine: PL08x: Fix reading the byte count in cctl dmaengine: PL08x: Add support for different maximum transfer size ...
2013-09-09Merge tag 'dmaengine-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine update from Dan Williams: "Collection of random updates to the core and some end-driver fixups for ioatdma and mv_xor: - NUMA aware channel allocation - Cleanup dmatest debugfs interface - ioat: make raid-support Atom only - mv_xor: big endian Aside from the top three commits these have all had some soak time in -next. The top commit fixes a recent build breakage. It has been a long while since my last pull request, hopefully it does not show. Thanks to Vinod for keeping an eye on drivers/dma/ this past year" * tag 'dmaengine-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: dmaengine: dma_sync_wait and dma_find_channel undefined MAINTAINERS: update email for Dan Williams dma: mv_xor: Fix incorrect error path ioatdma: silence GCC warnings dmaengine: make dma_channel_rebalance() NUMA aware dmaengine: make dma_submit_error() return an error code ioatdma: disable RAID on non-Atom platforms and reenable unaligned copies mv_xor: support big endian systems using descriptor swap feature mv_xor: use {readl, writel}_relaxed instead of __raw_{readl, writel} dmatest: print message on debug level in case of no error dmatest: remove IS_ERR_OR_NULL checks of debugfs calls dmatest: make module parameters writable
2013-09-09Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver update from Kevin Hilman: "This contains the ARM SoC related driver updates for v3.12. The only thing this cycle are core PM updates and CPUidle support for ARM's TC2 big.LITTLE development platform" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: cpuidle: big.LITTLE: vexpress-TC2 CPU idle driver ARM: vexpress: tc2: disable GIC CPU IF in tc2_pm_suspend drivers: irq-chip: irq-gic: introduce gic_cpu_if_down()
2013-09-09MAINTAINERS: update email for Dan WilliamsDan Williams
Returned to intel.com Cc: Vinod Koul <vinod.koul@intel.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Jon Mason <jon.mason@intel.com> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Neil Brown <neilb@suse.de> Cc: Shaohua Li <shli@kernel.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-09-09Merge tag 'metag-for-v3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag architecture changes from James Hogan: - Device tree updates for TZ1090 GPIO drivers merged via GPIO tree. - Add driver for ImgTec PDC irqchip as found in TZ1090 SoC. - Add linux-metag mailing list to MAINTAINERS file. * tag 'metag-for-v3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: irq-imgpdc: add ImgTec PDC irqchip driver MAINTAINERS: add linux-metag mailing list metag: tz1090: instantiate gpio-tz1090-pdc metag: tz1090: select and instantiate gpio-tz1090 metag: tz1090: select and instantiate irq-imgpdc
2013-09-07Merge tag 'ntb-3.12' of git://github.com/jonmason/ntbLinus Torvalds
Pull NTB (non-transparent bridge) updates from Jon Mason: "NTB driver bug fixes to address issues in NTB-RP enablement, spad, debugfs, and USD/DSD identification. Add a workaround on Xeon NTB devices for b2bdoorbell errata. Also, add new NTB driver features to support 32bit x86, DMA engine support, and NTB-RP support. Finally, a few clean-ups and update to MAINTAINERS for the NTB git tree and wiki location" * tag 'ntb-3.12' of git://github.com/jonmason/ntb: ntb: clean up unnecessary MSI/MSI-X capability find MAINTAINERS: Add Website and Git Tree for NTB NTB: Update Version NTB: Comment Fix NTB: Remove unused variable NTB: Remove References of non-B2B BWD HW NTB: NTB-RP support NTB: Rename Variables for NTB-RP NTB: Use DMA Engine to Transmit and Receive NTB: Enable 32bit Support NTB: Update Device IDs NTB: BWD Link Recovery NTB: Xeon Errata Workaround NTB: Correct debugfs to work with more than 1 NTB Device NTB: Correct USD/DSD Identification NTB: Correct Number of Scratch Pad Registers NTB: Add Error Handling in ntb_device_setup
2013-09-07Merge tag 'gpio-v3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v3.12 series: - A new driver for the TZ1090 PDC which is used on the metag architecture. - A new driver for the Kontron ETX or COMexpress GPIO block. This is found on some ETX x86 devices. - A new driver for the Fintek Super-I/O chips, used on some x86 boards. - Added device tree probing on a few select GPIO blocks. - Drop the Exynos support from the Samsung GPIO driver. The Samsung maintainers have moved over to use the modernized pin control driver to provide GPIO for the modern platforms instead. - The usual bunch of non-critical fixes and cleanups" * tag 'gpio-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (36 commits) gpio: return -ENOTSUPP if debounce cannot be set gpio: improve error path in gpiolib gpio: add GPIO support for F71882FG and F71889F of: add vendor prefix for Microchip Technology Inc gpio: mcp23s08: rename the device tree property gpio: samsung: Drop support for Exynos SoCs gpio: pcf857x: Remove pdata argument to pcf857x_irq_domain_init() gpio: pcf857x: Sort headers alphabetically gpio: max7301: Reverting "Do not force SPI speed when using OF Platform" gpio: Fix bit masking in Kontron PLD GPIO driver gpio: pca953x: fix gpio input on gpio offsets >= 8 drivers/gpio: simplify use of devm_ioremap_resource drivers/gpio/gpio-omap.c: convert comma to semicolon gpio-lynxpoint: Fix warning about unbalanced pm_runtime_enable gpio: Fix platform driver name in Kontron PLD GPIO driver gpio: adnp: Fix segfault if request_threaded_irq fails gpio: msm: Staticize local variable 'msm_gpio' gpio: gpiolib-of.c: make error message more meaningful by adding the node name and index gpio: use dev_get_platdata() gpio/mxc: add chained_irq_enter/exit() to mx2_gpio_irq_handler ...
2013-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A new driver for slidebar on Ideapad laptops and a bunch of assorted driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits) Input: add SYN_MAX and SYN_CNT constants Input: max11801_ts - convert to devm Input: egalax-ts - fix typo and improve text Input: MAINTAINERS - change maintainer for cyttsp driver Input: cyttsp4 - kill 'defined but not used' compiler warnings Input: add driver for slidebar on Lenovo IdeaPad laptops Input: omap-keypad - set up irq type from DT Input: omap-keypad - enable wakeup capability for keypad. Input: omap-keypad - clear interrupts on open Input: omap-keypad - convert to threaded IRQ Input: omap-keypad - use bitfiled instead of hardcoded values Input: cyttsp4 - remove useless NULL test from cyttsp4_watchdog_timer() Input: wacom - fix error return code in wacom_probe() Input: as5011 - fix error return code in as5011_probe() Input: keyboard, serio - simplify use of devm_ioremap_resource Input: tegra-kbc - simplify use of devm_ioremap_resource Input: htcpen - fix incorrect placement of __initdata Input: qt1070 - add power management ops Input: wistron_btns - add MODULE_DEVICE_TABLE Input: wistron_btns - mark the Medion MD96500 keymap as tested ...
2013-09-06Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This branch contains mostly additions and changes to platform enablement and SoC-level drivers. Since there's sometimes a dependency on device-tree changes, there's also a fair amount of those in this branch. Pieces worth mentioning are: - Mbus driver for Marvell platforms, allowing kernel configuration and resource allocation of on-chip peripherals. - Enablement of the mbus infrastructure from Marvell PCI-e drivers. - Preparation of MSI support for Marvell platforms. - Addition of new PCI-e host controller driver for Tegra platforms - Some churn caused by sharing of macro names between i.MX 6Q and 6DL platforms in the device tree sources and header files. - Various suspend/PM updates for Tegra, including LP1 support. - Versatile Express support for MCPM, part of big little support. - Allwinner platform support for A20 and A31 SoCs (dual and quad Cortex-A7) - OMAP2+ support for DRA7, a new Cortex-A15-based SoC. The code that touches other architectures are patches moving MSI arch-specific functions over to weak symbols and removal of ARCH_SUPPORTS_MSI, acked by PCI maintainers" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits) tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list ARM: dts: vf610-twr: enable i2c0 device ARM: dts: i.MX51: Add one more I2C2 pinmux entry ARM: dts: i.MX51: Move pins configuration under "iomuxc" label ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX ARM: dts: i.MX27: Disable AUDMUX in the template ARM: dts: wandboard: Add support for SDIO bcm4329 ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template ARM: dts: imx53-qsb: Make USBH1 functional ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module ARM: dts: imx6qdl-sabresd: Add touchscreen support ARM: imx: add ocram clock for imx53 ARM: dts: imx: ocram size is different between imx6q and imx6dl ARM: dts: imx27-phytec-phycore-som: Fix regulator settings ARM: dts: i.MX27: Remove clock name from CPU node ...
2013-09-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull Tile arch updates from Chris Metcalf: "These changes bring in a bunch of new functionality that has been maintained internally at Tilera over the last year, plus other stray bits of work that I've taken into the tile tree from other folks. The changes include some PCI root complex work, interrupt-driven console support, support for performing fast-path unaligned data fixups by kernel-based JIT code generation, CONFIG_PREEMPT support, vDSO support for gettimeofday(), a serial driver for the tilegx on-chip UART, KGDB support, more optimized string routines, support for ftrace and kprobes, improved ASLR, and many bug fixes. We also remove support for the old TILE64 chip, which is no longer buildable" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits) tile: refresh tile defconfig files tile: rework <asm/cmpxchg.h> tile PCI RC: make default consistent DMA mask 32-bit tile: add null check for kzalloc in tile/kernel/setup.c tile: make __write_once a synonym for __read_mostly tile: remove support for TILE64 tile: use asm-generic/bitops/builtin-*.h tile: eliminate no-op "noatomichash" boot argument tile: use standard tile_bundle_bits type in traps.c tile: simplify code referencing hypervisor API addresses tile: change <asm/system.h> to <asm/switch_to.h> in comments tile: mark pcibios_init() as __init tile: check for correct compiler earlier in asm-offsets.c tile: use standard 'generic-y' model for <asm/hw_irq.h> tile: use asm-generic version of <asm/local64.h> tile PCI RC: add comment about "PCI hole" problem tile: remove DEBUG_EXTRA_FLAGS kernel config option tile: add virt_to_kpte() API and clean up and document behavior tile: support FRAME_POINTER tile: support reporting Tilera hypervisor statistics ...
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: "Highlights: - conversion of HID subsystem to use devm-based resource management, from Benjamin Tissoires - i2c-hid support for DT bindings, from Benjamin Tissoires - much improved support for Win8-multitouch devices, from Benjamin Tissoires - cleanup of core code using common hidinput_input_event(), from David Herrmann - fix for bug in implement() access to the bit stream (causing oops) that has been present in the code for ages, but devices that are able to trigger it have started to appear only now, from Jiri Kosina - fixes for CVE-2013-2899, CVE-2013-2898, CVE-2013-2896, CVE-2013-2892, CVE-2013-2888 (all triggerable only by specially crafted malicious HW devices plugged into the system), from Kees Cook - hidraw oops fix, from Manoj Chourasia - various smaller fixes here and there, support for a bunch of new devices by various contributors" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (53 commits) HID: MAINTAINERS: add roccat drivers HID: hid-sensor-hub: change kmalloc + memcpy by kmemdup HID: hid-sensor-hub: move to devm_kzalloc HID: hid-sensor-hub: fix indentation accross the code HID: move HID_REPORT_TYPES closer to the report-definitions HID: check for NULL field when setting values HID: picolcd_core: validate output report details HID: sensor-hub: validate feature report details HID: ntrig: validate feature report details HID: pantherlord: validate output report details HID: hid-wiimote: print small buffers via %*phC HID: uhid: improve uhid example client HID: Correct the USB IDs for the new Macbook Air 6 HID: wiimote: add support for Guitar-Hero guitars HID: wiimote: add support for Guitar-Hero drums Input: introduce BTN/ABS bits for drums and guitars HID: battery: don't do DMA from stack HID: roccat: add support for KonePureOptical v2 HID: picolcd: Prevent NULL pointer dereference on _remove() HID: usbhid: quirk for N-Trig DuoSense Touch Screen ...
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Fix for the annoying paravirt.o build warning under allmodconfig, and a MAINTAINERS file update" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, doc: Add an entry in MAINTAINERS for arch/x86/kernel/cpu/vmware.c x86, paravirt: Remove duplicate definition for DEF_NATIVE
