Provide support for controlling reset pin. If this is not driven
correctly the device will be held in reset and will not respond.
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
(cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f)
This adds a driver which simulates a i2c bus with an attached EDID
memory. The memory content is read from the device tree.
This allows to simulate EDID data which may differ from an attached
display.
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
Commit f84a56f73ddd upstream.
Document the rationale and usage of the new array_index_nospec() helper.
Change-Id: I4b804638bbe9811b82d34cd58314cbb1738d7d25
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: gregkh@linuxfoundation.org
Cc: kernel-hardening@lists.openwall.com
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727413645.33451.15878817161436755393.stgit@dwillia2-desk3.amr.corp.intel.com
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1698397
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
Backlights require a power supply to work properly. This commit adds a
regulator to power up and power down the backlight.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 22ceeee16eb8f0d04de3ef43a5174fb30ec18af9)
Make use of the new enable_gpio field and allow it to be set from DT as
well. Now that all legacy users of platform data have been converted to
initialize this field to an invalid value, it is safe to use the field
from the driver.
(cherry picked from commit 8265b2e4e62632b01f998095d1bbda4d281629fe)
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Bug 1946430
Change-Id: I9a66aabc34b687996fb971e01bb0ef30a3d4de7d
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1509390
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
The m41t0 variant is very similar to the already supported m41t00
variant, with the notable exception of the oscillator fail bit.
The data sheet notes:
If the oscillator fail (OF) bit is internally set to a '1,' this
indicates that the oscillator has either stopped, or was stopped
for some period of time and can be used to judge the validity of
the clock and date data.
The bit will get cleared with a regular write of the system time,
so no changes are needed to clear it.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(backported from commit 8566f70c8a90f3914b06e934852596ba94aaa381)
Added support to use polling mode instead of interrupts
through a property in dt
Bug 1679083
Change-Id: Ic82ab592822cc96bacda05124d38ddd913e09af9
Reviewed-on: http://git-master/r/840233
(cherry picked from commit cd1c4db5adc8317572106099da37fa434245e699)
Reviewed-on: http://git-master/r/1009988
(cherry picked from commit b29ce03a6b7ebb306ff157640470dd5ab99c6f6b)
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1175213
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
SPI register access for T210 and earlier chips depend
on SPI clock frequency. Provided an option to set SPI
clock at max frequency for register access.
Bug 1675625
Change-Id: Ie52c83cd4602604822462d9f02ddf31ead83aafc
Reviewed-on: http://git-master/r/1009782
(cherry picked from commit a2ccd28f2850538064668568432fee5d70a22e82)
Reviewed-on: http://git-master/r/1174581
Bug 200006918
Change-Id: Ibd9a004e10316ab817ca85c9093b094a5cb4fed3
Signed-off-by: Shreshtha SAHU <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/557204
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Add a simple sysfs interface to the generic PWM framework.
/sys/class/pwm/
`-- pwmchipN/ for each PWM chip
|-- export (w/o) ask the kernel to export a PWM channel
|-- npwm (r/o) number of PWM channels in this PWM chip
|-- pwmX/ for each exported PWM channel
| |-- duty_cycle (r/w) duty cycle (in nanoseconds)
| |-- enable (r/w) enable/disable PWM
| |-- period (r/w) period (in nanoseconds)
| `-- polarity (r/w) polarity of PWM (normal/inversed)
`-- unexport (w/o) return a PWM channel to the kernel
Based on work by Lars Poeschel.
Bug 200028381
Change-Id: I0c9c6ad2ca7173e6fc3fbe1d3cd3963cde00539a
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Rob Landley <rob@landley.net>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
(cherry picked from commit 76abbdde2d95a3807d0dc6bf9f84d03d0dbd4f3d)
Reviewed-on: http://git-master/r/455068
(cherry picked from commit b1824bc0325f84ea04dab7d6d4f7c887c80b1982)
Reviewed-on: http://git-master/r/488690
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Tested-by: Winnie Hsu <whsu@nvidia.com>
Update Documentation for device tree update for
optional oc_pg_ctrl_masking feature
Bug 1518725
Bug 1419425
Change-Id: I309533849d48d61aefebd8f477e79b79ed4127fb
Reviewed-on: http://git-master/r/423185
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Add below optional value can be overrid by DT for project.
If no add in DT will load default value.
1)integration-time.
Default:"480000"
2)max-range.
Default:"78643.2"
3)resolution.
Default:"307"
4)power-consumed.
Default:"1670"
Bug 1496947
Change-Id: I8718bf5636042bc801574c8e4177a12e5a948540
Signed-off-by: steven <skao@nvidia.com>
Reviewed-on: http://git-master/r/395755
Reviewed-on: http://git-master/r/411415
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: Mitch Luban <mluban@nvidia.com>
into promotion_build
optional backup battery charging feature
Bug 1508216
Change-Id: I4ebd7af6814cddbebd4503c311d3cade7add3bd5
Reviewed-on: http://git-master/r/405115
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
enable safety timer and configure power on register
from ISR and resume path when safety timer expired.
set rtc alarm timer based on parameter value passed through
dt file only when battery in CHARING done state and high charging current
cable connected to wake up device from LP0.
Bug 1440235
Change-Id: I2fb8121c6183a8367c8bd869f43373062fdbb630
Signed-off-by: Venkat Reddy Talla <vreddytalla@nvidia.com>
Reviewed-on: http://git-master/r/392334
Change-Id: Iff93242bdc368f711d06eec1b4ec4ff844df5978
Reviewed-on: http://git-master/r/404465
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
Add Devicetree binding documentation for as3722
from upstream.
This is based on mainline Commit
https://patchwork.kernel.org/patch/2975721/
Contributed by:
Signed-off-by: Florian Lobmaier <florian.lobmaier@ams.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Change-Id: Ie8a17d9aaad883ef59f928f389ac6b6233bbaa6f
Reviewed-on: http://git-master/r/405114
Relocations that require an instruction immediate to be re-encoded must
ensure that the instruction pattern is represented in a little-endian
format for the manipulation code to work correctly.
This patch converts the loaded instruction into native-endianess prior
to encoding and then converts back to little-endian byteorder before
updating memory.
Change-Id: I84a8946f66e6eb303d81b7b9198d95cca6b8d42f
(cherry picked from commit 122e2fa0d310d262cb85cf0b003032e5d2bc2ae7)
Tested-by: Matthew Leach <matthew.leach@arm.com>
TCR.TBI0 can be used to cause hardware address translation to ignore the
top byte of userspace virtual addresses. Whilst not especially useful in
standard C programs, this can be used by JITs to `tag' pointers with
various pieces of metadata.
This patch enables this bit for AArch64 Linux, and adds a new file to
Documentation/arm64/ which describes some potential caveats when using
tagged virtual addresses.
(cherry picked from commit d50240a5f6ceaf690a77b0fccb17be51cfa151c2)
Documentation/arm64/tagged-pointers.txt
Change-Id: I4366318cc1b049e8e9f642fc502e8d0b04e2ed24
Expand the arm64 image header to allow for co-existance with
PE/COFF header required by the EFI stub. The PE/COFF format
requires the "MZ" header to be at offset 0, and the offset
to the PE/COFF header to be at offset 0x3c. The image
header is expanded to allow 2 instructions at the beginning
to accommodate a benign intruction at offset 0 that includes
the "MZ" header, a magic number, and the offset to the PE/COFF
header.
(cherry picked from commit 4370eec05a887b0cd4392cd5dc5b2713174745c0)
Change-Id: If4f180805b305af50f612ef10b37b58c27dfba4d
Signed-off-by: Roy Franz <roy.franz@linaro.org>
-update maxim touch driver to support device tree.
-add sample maxim touch device tree in documentation
Bug 1468560
Change-Id: Id7a99ca9bdeb53f7d817e33874dac9bca48965a9
Signed-off-by: Andrew Tran <atran@nvidia.com>
Reviewed-on: http://git-master/r/383999
(cherry picked from commit 86384c3e1db348509887c7bbdbe9f3e3c5be8941)
Reviewed-on: http://git-master/r/383268
nvidia,dc-connection property will indicate
if target dc device is used for internal lcd
or external display.
For internal lcd, it will get dc output type from
selected panel node among device tree multiple
panel nodes: It can be TEGRA_DC_OUT_DSI or
TEGRA_DC_OUT_DP, etc.
For external display, dc output type will be set
to TEGRA_DC_OUT_HDMI.
Bug 1371533
Change-Id: I94f7f0a2e93c5550aa2ea8f7e2069e52bdc799df
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/395028
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
The lc709203f driver provided the property to measure battery current now.
The battery current can be read from the IIO interface with monitor.
This patch explain about the properties on nodes to measure the current.
bug 1413219
Change-Id: Ib1346f445f90d3a40cbf7ab7338c382ae8b3d120
Reviewed-on: http://git-master/r/395551
Update the INA3221x DT binding documents and add dt-binding header to use
the macro from DTS file.
The updates details how it can be instantiated as iio channels and client
driver use this from DT node for measuring different parameters of different
channels. It also details the index for different signal monitor which
is require for iio channel consumer interface.
bug 1413219
Change-Id: I1c31322d4d905983e16ef132c0bd75af29fd0583
Reviewed-on: http://git-master/r/395549
This is driver side change to work with
reorganized display system device tree
for proper panel detection from among
multiple panel nodes in device tree level.
Bug 1371533
Change-Id: Iad0b1aacfc6633945c6696b524e43a87150e9c90
Reviewed-on: http://git-master/r/384373
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Bug 1451748
Change-Id: I634ac9226ce763ec2518e08c74d163886e114609
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-on: http://git-master/r/394188
Provide initial documentation for tegra
camera ioctls
Bug 1466413
Change-Id: I5d460ec3e98f10ea03f0f0a452d20e93d5c19c7a
Signed-off-by: Anton Kondratenko <akondratenko@nvidia.com>
Reviewed-on: http://git-master/r/390380
Add DT support for the power_supply-extcon driver
Added DT binding documents also.
Change-Id: Id7d612032cac82eecadae6c24a3c1e0c82b60a27
Reviewed-on: http://git-master/r/387063
implement interrupt support to generate low voltage/soc
events when battery voltage measured below threshold value.
update binding doc with lc709203f parameters.
Bug 1474634
Change-Id: I89f3b009548132d1e00bc28fb202e1f6babdfab1
Reviewed-on: http://git-master/r/383844
Added support for AC adapter detection through GPIO
in bq2477x charger.
Bug 1457299
Change-Id: I344d264312142121342403194aa5adeaec66d47d
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/380285
Added device tree support for bq2477x.
Change-Id: I5dc928c609c8b4d6d9e8d09f46382307315f4f1c
Reviewed-on: http://git-master/r/381886
Bug 1456092
Change-Id: Ic563f451abb08754fea0e2bbf0ce065ca2e6e770
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Add bindings file for tegra-fuse driver and add tegra fuse specific
read and write functions to tegra-fuse driver.
Bug 1449516
Change-Id: I1d15dd1341b27eb370fd56be0ecce40726701499
Signed-off-by: Salona Sinha <salonas@nvidia.com>
Reviewed-on: http://git-master/r/367716
Reviewed-by: Shardar Mohammed <smohammed@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
The maximum charging voltage depends on the battery temperature.
Add DT porperty and mechanims to set different charging voltage
for different temperature.
bug 1472161
Change-Id: Ia6fa3ee84cfd1f9ad8359e8249ffb268330f90cf
Reviewed-on: http://git-master/r/379575
1)
New device tree properties are added
for tmds configuration.
- version
- pad_ctls0_mask
- pad_ctls0_setting
2)
For "nvidia,out-max-pixclk", device tree
needs to write in pico seconds unit.
Bug 1371533
Change-Id: I73cb0605144f3951aea172cde7a527aeffbb368d
Reviewed-on: http://git-master/r/378810
Bug 1456092
Change-Id: Idd03c5e52e7aac49f4adede54802ca66f22d2ee3
Bug 1456092
Change-Id: I87b6b883c382000fc0dfee7c8d8f36269f504e46
- Add regulator support for vdd, vled
- Check sensor's presence during probe
- Add device tree support and the bindings file
Bug 1469642
Change-Id: Ib6e80149bd424852ee3e343e92ac091204c87f2f
Reviewed-on: http://git-master/r/377082
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
- Add support to configure gain from dt
- Also get als_resolution from dt
- Add als_resolution sysfs
- Add dt bindings for max44005
Bug 1462476
Change-Id: I58f05a0971cf063ab14f4cd331b30e537cf989a5
Reviewed-on: http://git-master/r/369337
(cherry picked from commit 0928174f846de5e6ffce0dee31c3a538ea8fadfe)
Reviewed-on: http://git-master/r/374281
This patch changes the cpufreq-cpu0 driver to consider if
a cpu needs cooling (with cpufreq). In case the cooling is needed,
the cpu0 device tree node needs to be properly configured
with cooling device properties.
In case these properties are present,, the driver will
load a cpufreq cooling device in the system. The cpufreq-cpu0
driver is not interested in determining how the system should
be using the cooling device. The driver is responsible
only of loading the cooling device.
Describing how the cooling device will be used can be
accomplished by setting up a thermal zone that references
and is composed by the cpufreq cooling device.
Change-Id: Ie5f85e314cb45f977d9484220e4778cccaad8b4c
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: cpufreq@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: devicetree-discuss@lists.ozlabs.org
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
Signed-off-by: Paul Walmsley <pwalmsley@nvidia.com> # for the NVIDIA downstream kernel
Signed-off-by: Christina Guertin <cguertin@nvidia.com>
Reviewed-on: http://git-master/r/356897
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
This patch introduces a device tree bindings for
describing the hardware thermal behavior and limits.
Also a parser to read and interpret the data and feed
it in the thermal framework is presented.
This patch introduces a thermal data parser for device
tree. The parsed data is used to build thermal zones
and thermal binding parameters. The output data
can then be used to deploy thermal policies.
This patch adds also documentation regarding this
API and how to define tree nodes to use
this infrastructure.
Note that, in order to be able to have control
on the sensor registration on the DT thermal zone,
it was required to allow changing the thermal zone
.get_temp callback. For this reason, this patch
also removes the 'const' modifier from the .ops
field of thermal zone devices.
Change-Id: I5f6150963b24b702b230746f669ebaaac507cac5
Cc: Zhang Rui <rui.zhang@intel.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-on: http://git-master/r/356894
Added Tegra DFLL binding compatibility with T132 SoC.
Bug 1442709
Change-Id: Ib15b9a73e634d4de97d1a17079c5637b27d3b86f
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/373259
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Add devicetree binding document and example for the iio/meter
based ina219 driver.
Change-Id: I7d3fac2b852992f3e91982964b356d049094aa1c
Reviewed-on: http://git-master/r/372860
For following properties' item, dc macro
is utilized from this change. Macro is defined
in /include/dt-bindings/display/tegra-dc.h.
- nvidia,dc-flags
- nvidia,out-type
- nvidia,out-flags
- nvidia,fb-flags
- nvidia,out-align
- nvidia,out-order
Bug 1371533
Change-Id: I33eed200f9ac3f43e5ad57b2059455b41430727f
Reviewed-on: http://git-master/r/367575
Add two device tree properties.
1. nvidia,out-rotation to specify panel
rotation.
2. nvidia,dsi-ulpm-not-support. With
enabled, dsi do not enter ulpm mode.
Bug 1371533
Change-Id: Ie6bfb35aec5ed01f5161754873ede598b687f384
Change-Id: I3a2fbd5e6b8335428ba9b7a0411669c918c582d1
Reviewed-on: http://git-master/r/367623
