path: root/Documentation/sound
2013-06-17ALSA: hda - Add models for Dell headset jacksDavid Henningsson
These headset jacks keep coming in on more and more platforms, and it's possible I don't catch them all. Make it easier to test and verify by making models. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-15Merge tag 'asoc-v3.10' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for v3.10 A bunch of changes here, the most interesting one subsystem wise being Morimoto-san's work to create snd_soc_component which doesn't do much for now but will be pretty important going forwards: - Add a new component object type which will form the basis of moving to a more generic handling of SoC and off-SoC components, contributed by Kuninori Morimoto. - A fairly large set of cleanups for the dmaengine integration from Lars-Peter Clausen, starting to move towards being able to have a generic driver based on the library. - Performance optimisations to DAPM from Ryo Tsutsui. - Support for mixer control sharing in DAPM from Stephen Warren. - Multiplatform ARM cleanups from Arnd Bergmann. - New CODEC drivers for AK5385 and TAS5086 from Daniel Mack.
2013-04-04Revert "ALSA: hda - Allow power_save_controller option override DCAPS"Takashi Iwai
This reverts commit 6ab317419c62850a71e2adfd1573e5ee87d8774f. The commit [6ab317419c: ALSA: hda - Allow power_save_controller option override DCAPS] changed the behavior of power_save_controller so that it can override the driver capability. This assumed that this option is rarely changed dynamically unlike power_save option. Too naive. It turned out that the user-space power-management tool tries to set power_save_controller option to 1 together with power_save option without knowing what's actually doing. This enabled forcibly the runtime PM of the controller, which is known to be broken om many chips thus disabled as default. So, the only sane fix is to revert this commit again. It was intended to ease debugging/testing for runtime PM enablement, but obviously we need another way for it. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=56171 Reported-and-tested-by: Nikita Tsukanov <keks9n@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-18Merge branch 'for-linus' into for-nextTakashi Iwai
Back-merged for refactoring beep stuff.
2013-03-17ALSA: documentation: Fix typo in Documentation/soundMasanari Iida
Correct spelling typos in Documentation/sound/alsa Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-07ALSA: hda - Consolidate add_in_jack_modes and add_out_jack_modes hintsTakashi Iwai
There is no big merit to distinguish these two hints. Instead, just have a single flag, add_jack_modes, for creating the jack mode enum ctls for both I/O directions. The hint string parser code is left and translated as add_jack_modes just for keeping compatibility. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-07ALSA: hda - Add the generic Headphone Mic featureTakashi Iwai
This patch improves the generic parser code to allow to set up the headphone jack as a mic input. User can enable this feature by giving hp_mic hint string. The former shared hp/mic feature for the single built-in mic is still retained. This detection can be disabled now via hp_mic_detect hint string, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-14ALSA: compress: add support for gapless playbackJeeja KP
this add new API for sound compress to support gapless playback. As noted in Documentation change, we add API to send metadata of encoder and padding delay to DSP. Also add API for indicating EOF and switching to subsequent track Also bump the compress API version Signed-off-by: Jeeja KP <jeeja.kp@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-12ALSA: hda - update documentation for no-primary-hp fixupFernando Luis Vázquez Cao
The problem addressed by this fixup is not specific to Vaio Z, affecting some Vaio all-in-one desktop PCs too. Update the code comments accordingly. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-29ALSA: hda - Update documentationTakashi Iwai
2013-01-09ALSA: hda - Allow power_save_controller option override DCAPSTakashi Iwai
Change the power_save_controller option to bint from bool so that user can override the runtime PM capability bit and force to enable or disable the runtime PM. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-21ALSA: usb-audio: Deprecate async_unlink optionTakashi Iwai
The async unlink behavior has been working over years. The option was provided only as a workaround for 2.4.x kernel. Let's get rid of it. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-15Merge branch 'topic/tlv-chmap' into for-nextTakashi Iwai
This is a merge of a topic branch containing the support for the new channel map API using control elements.
2012-09-13ALSA: hda - Allow to pass position_fix=0 explicitlyTakashi Iwai
Set the default value of position_fix -1, and allow user passing position_fix=0 explicitly to set the "auto" position-fix mode. Otherwise the auto mode may be switched to others like COMBO of VIACOMBO when the controller prefers it, thus user can't set the auto mode any longer. Also updated the documentation appropriately, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-12ALSA: Define more channel map positionsTakashi Iwai
For following the standard, define more channel map positions and shuffle the items a bit: - As both PulseAudio and gstreamer define MONO channel position explicitly, we should follow that, too. The mono streams point to this channel position unless they are explicitly assigned to certain channel positions. - Top-front-* and Top-rear-* positions are added, carried from PulseAudio's definitions. - Move NA and MONO definitions at the top of table right after UNKNOWN, since these are more abstract in comparison with other practical positions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-06ALSA: Follow channel position definitions to alsa-lib mixerTakashi Iwai
There is already a set of channel position definitions in alsa-lib mixer.h, and it'd be more practical to keep the same order for the PCM channel map, too. The value is shifted with 1 to keep zero for UNKNOWN. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-06ALSA: Add a documentation for channel mapping APITakashi Iwai
2012-08-15ALSA: hda - Add 3stack-automute model to AD1882 codecTakashi Iwai
Added a simple support of automute for the front HP jack to AD1882 stack model. Such an addition is basically an exception -- we really want to avoid the static quirk codes, but AD1882 parser isn't still ready for moving to the BIOS auto-parser yet. So, as a quick fix, I merged it for now. In near future, we really need the big clean up of patch_analog.c to move on to the auto-parser... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-01Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A collection of small fixes that have been found recently. Most of the commits are regression fixes in HD-audio and some other random drivers." * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: snd-usb: fix clock source validity index ALSA: hda - Fix mute-LED GPIO initialization for IDT codecs ALSA: hda - Add descriptions for missing IDT 92HD83x models ALSA: hda - Fix polarity of mute LED on HP Mini 210 ALSA: es1688 - freeup resources on init failure ALSA: hda - Workaround for silent output on VAIO Z with ALC889 ALSA: hda - Fix WARNING from HDMI/DP parser ALSA: hda - Detach from converter at closing in patch_hdmi.c ALSA: hda - Fix mute-LED GPIO setup for HP Mini 210 ALSA: mpu401: Fix missing initialization of irq field ALSA: hda - Fix invalid D3 of headphone DAC on VT202x codecs
2012-07-31ALSA: hda - Add descriptions for missing IDT 92HD83x modelsTakashi Iwai
2012-07-29ALSA: hda - Workaround for silent output on VAIO Z with ALC889Takashi Iwai
On recent kernels, Realtek codec parser tries to optimize the routing aggressively and take the headphone output as primary at first. This caused a regression on VAIO Z with ALC889, the silent output from the speaker. The problem seems that the speaker pin must be connected to the first DAC (0x02) on this machine by some reason although the codec itself advertises the flexible routing with any DACs. This patch adds a fix-up for choosing the speaker pin as the primary so that the right DAC is assigned on this device. Reported-and-tested-by: Adam Williamson <awilliam@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-24Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound update from Takashi Iwai: "This is a fairly quiet release in all sound area. Only a little bit of changes in the core side while most of changes are seen in the drivers. HD-audio: - A few new codec additions for Nvidia, Realtek and VIA - Intel Haswell audio support - Support for "phantom" jacks for consistent jack reporting - Major clean-ups in HDMI/DP driver codes - A workaround for inverted digital-mic pins with Realtek codecs - Removal of beep_mode=2 option ASoC: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110 - DAPM fixes for the recent locking changes - Fix for _PRE and _POST widgets (which have been broken for a few releases now) - A couple of minor driver updates Misc - Conversion to new dev_pm_ops in platform and PCI drivers - LTC support and some fixes in PCXHR driver - A few fixes and PM support for ISA OPti9xx and WSS cards - Some TLV code cleanup - Move driver-specific headers from include/sound to local dirs" * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (212 commits) ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvements ALSA: hda - add dock support for Thinkpad X230 Tablet ALSA: hda - Turn on PIN_OUT from hdmi playback prepare. ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 define ASoC: littlemill: Add userspace control of the WM1250 I/O ASoC: wm8994: Update micdet for irqdomain conversion ALSA: hda - make sure alc268 does not OOPS on codec parse ALSA: hda - Add support for Realtek ALC282 ALSA: hda - Fix index number conflicts of phantom jacks ALSA: opti9xx: Fix section mismatch by PM support ALSA: snd-opti9xx: Implement suspend/resume ALSA: hda - Add new GPU codec ID to snd-hda ALSA: hda - Fix driver type of Haswell controller to AZX_DRIVER_SCH ALSA: hda - add Haswell HDMI codec id ALSA: hda - Add DeviceID for Haswell HDA ALSA: wss_lib: Fix resume on Yamaha OPL3-SAx ALSA: wss_lib: fix suspend/resume ALSA: es1938: replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE ALSA: tlv: add DECLARE_TLV_DB_RANGE() ALSA: tlv: add DECLARE_TLV_CONTAINER() ...
2012-07-20Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-20ALSA: hda - add dock support for Thinkpad X230 TabletDavid Henningsson
Also add a model/fixup string "lenovo-dock", so that other Thinkpad users will be able to test this fixup easily, to see if it enables dock I/O for them as well. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/1026953 Tested-by: John McCarron <john.mccarron@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-04Merge branch 'topic/hda-beep' into topic/hdaTakashi Iwai
2012-07-03ALSA: hda - Remove beep_mode=2Takashi Iwai
The beep_mode=2 option was introduced to make the beep mixer controlling the beep input allocation/deallocation dynamically, so that a user can switch between HD-audio codec digital beep and the system beep only via mixer API. This was necessary because the keyboard driver took only the first input beep instance at that time. However, the recent keyboard driver already processes the multiple input instances, thus there is no point to keep this mode. Let's remove it. Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-25ALSA: hda - Update documentation for Realtek codecs model stringsTakashi Iwai
2012-05-23Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This is the first big chunk for 3.5 merges of sound stuff. There are a few big changes in different areas. First off, the streaming logic of USB-audio endpoints has been largely rewritten for the better support of "implicit feedback". If anything about USB got broken, this change has to be checked. For HD-audio, the resume procedure was changed; instead of delaying the resume of the hardware until the first use, now waking up immediately at resume. This is for buggy BIOS. For ASoC, dynamic PCM support and the improved support for digital links between off-SoC devices are major framework changes. Some highlights are below: * HD-audio - Avoid accesses of invalid pin-control bits that may stall the codec - V-ref setup cleanups - Fix the races in power-saving code - Fix the races in codec cache hashes and connection lists - Split some common codes for BIOS auto-parser to hda_auto_parser.c - Changed the PM resume code to wake up immediately for buggy BIOS - Creative SoundCore3D support - Add Conexant CX20751/2/3/4 codec support * ASoC - Dynamic PCM support, allowing support for SoCs with internal routing through components with tight sequencing and formatting constraints within their internal paths or where there are multiple components connected with CPU managed DMA controllers inside the SoC. - Greatly improved support for direct digital links between off-SoC devices, providing a much simpler way of connecting things like digital basebands to CODECs. - Much more fine grained and robust locking, cleaning up some of the confusion that crept in with multi-component. - CPU support for nVidia Tegra 30 I2S and audio hub controllers and ST-Ericsson MSP I2S controolers - New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124, Texas Instruments LM49453. - Some regmap changes needed by the Tegra I2S driver. - mc13783 audio support. * Misc - Rewrite with module_pci_driver() - Xonar DGX support for snd-oxygen - Improvement of packet handling in snd-firewire driver - New USB-endpoint streaming logic - Enhanced M-audio FTU quirks and relevant cleanups - Increment the support of OSS devices to 256 - snd-aloop accuracy improvement There are a few more pending changes for 3.5, but they will be sent slightly later as partly depending on the changes of DRM." Fix up conflicts in regmap (due to duplicate patches, with some further updates then having already come in from the regmap tree). Also some fairly trivial context conflicts in the imx and mcx soc drivers. * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits) ALSA: snd-usb: fix stream info output in /proc ALSA: pcm - Add proper state checks to snd_pcm_drain() ALSA: sh: Fix up namespace collision in sh_dac_audio. ALSA: hda/realtek - Fix unused variable compile warning ASoC: sh: fsi: enable chip specific data transfer mode ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger() ASoC: sh: fsi: use same format for IN/OUT ASoC: sh: fsi: add fsi_version() and removed meaningless version check ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC ASoC: tegra: Add machine driver for WM8753 codec ALSA: hda - Fix possible races of accesses to connection list array ASoC: OMAP: HDMI: Introduce codec ARM: mx31_3ds: Add sound support ASoC: imx-mc13783 cleanup mx31moboard: Add sound support ASoC: mc13783 codec cleanups ASoC: add imx-mc13783 sound support ASoC: Add mc13783 codec mfd: mc13xxx: add codec platform data ASoC: don't flip master of DT-instantiated DAI links ...
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-21Merge branch 'topic/misc' into for-linusTakashi Iwai
2012-05-05ALSA: oxygen: add Xonar DGX supportClemens Ladisch
Add the PCI ID of the Asus Xonar DGX card; it's otherwise identical with the DG. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-16Documentation: Fix typo in multiple files in DocumentationMasanari Iida
Correct multiple spelling typo in Documentation. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Rob Landley <rob@landley.net> Reported-by: Anders Larsen <al@alarsen.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-11ALSA: hda/realtek - Add a few ALC882 model strings backTakashi Iwai
Since there are still many Acer models that might not be covered by the current fixup table, let's add back a few typical model names so that user can test the fixup without recompiling. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-03-30Documentation: replace install commands with softdepsLucas De Marchi
Install commands should not be used to specify soft dependencies among modules. When loading modules it's much better to have a softdep that modprobe knows what's being done than having to fork/exec another instance of modprobe to load the other module. By using a softdep user has also an option to remove the dependencies when removing the module (and if its refcount dropped to 0) Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Email/web address changeJonathan Woithe
This patch updates Jonathan Woithe's contact details across the kernel tree. Signed-off-by: Jonathan Woithe <jwoithe@just42.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-22Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull updates of sound stuff from Takashi Iwai: "Here is the first big update chunk of sound stuff for 3.4-rc1. In the common sound infrastructure, there are a few changes for dynamic PCM support (used in ASoC) and a few clean-ups. Majority of changes are found, as usual, in HD-audio and ASoC. Some highlights of HD-audio changes: - All the long-standing static quirk codes for Realtek codec were finally removed by fixing and extending the Realtek auto-parser. - The mute-LED control is standardized over all HD-audio codec drivers using the extended vmaster hook. - The vmaster slave mixer elements are initialized to 0dB as default so that the user won't be annoyed by the silent output after updates, e.g. due to the additions of new elements. - Other many fix-ups for the misc HD-audio devices. In the ASoC side, this is a very active release, including a quite a few framework enhancements. Some highlights: - Support for widgets not associated with a CODEC, an important part of the dynamic PCM framework. - A library factoring out the common code shared by dmaengine based DMA drivers contributed by Lars-Peter Clausen. This will save a lot of code and make it much easier to deploy enhancements to dmaengine. - Support for binary controls, used for providing runtime configuration of algorithm coefficients. - A new DAPM widget type for regulator supplies allowing drivers for devices that can power down unused supplies while active to do without any per-driver code. - DAPM widgets for DAIs, initially giving a speed boost for playback startup and shutdown and also the basis for CODEC<->CODEC DAI link support. - Support for specifying the number of significant bits on audio interfaces, useful for allowing applications to know how much effort to put into generating data for a larger sample format. - Conversion of the FSI driver used on some SH processors to DMAEngine. - Conversion of EP93xx drivers to DMAEngine. - New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200. - Move audmux driver from arc/arm to sound/soc - McBSP move from arch/ to sound/ and updates Also, a few small updates and fixes for other drivers like au88x0, ymfpci, USB 6fire, USB usx2yaudio are included." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits) ASoC: wm8994: Provide VMID mode control and fix default sequence ASoC: wm8994: Add missing break in resume ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF ASoC: pxa-ssp: atomically set stream active masks ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master ASoC: Samsung: Added to support mono recording ALSA: hda - Fix build with CONFIG_PM=n ALSA: au88x0 - Avoid possible Oops at unbinding ALSA: usb-audio - Fix build error by consitification of rate list ASoC: core: Fix obscure leak of runtime array ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link() ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list ASoC: wm8996: Add 44.1kHz support ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE ASoC: mx27vis-aic32x4: Convert it to platform driver ALSA: hda - fix printing of high HDMI sample rates ALSA: ymfpci - Fix legacy registers on S3/S4 resume ALSA: control - Fixe a trailing white space error ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook() ALSA: hda - Add "Mute-LED Mode" enum control ...
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-28ALSA: hda - Add position_fix=4 (COMBO) optionTakashi Iwai
This patch adds a new position_fix option value, 4, as a combo mode to use LPIB for playbacks and POSBUF for captures. It's the way recommended by Intel hardware guys. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-21ALSA: hda/realtek - Remove the last static quirks for ALC882Takashi Iwai
Resitance is futile. The remaining static model quirks for Apple machines with ALC882-compatible codecs are converted to the auto-parser now. We can remove all alc*_quirks.c finally. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Drop all ALC880 static quirksTakashi Iwai
Finally the all static quirks for ALC880 are converted to the auto-parser. Since we are never sure whether the BIOS on so many old machines are really correct, the quirk table entries are copied as they are, but just providing the proper pin-config values accordingly. Since alc880_quirks.c is removed, alc882_quirks.c has to be adjusted slightly to be built again. There might be some compile warnings due to the remaining alc882 quirks, but these shall be killed sooner or later, I don't care it much at this point. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Drop model=asus* from ALC880Takashi Iwai
It turned out that BIOS on most of ASUS mobo's set the pin-config tables reasonably well for the auto-parser. We'd need GPIO setups, but should work as is other than that. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Rewrite ALC880 model=asus-w1v with auto-parserTakashi Iwai
ASUS W1V has a sane pin-config table set by BIOS. The only missing piece is the setup of GPIO1. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Rewrite ALC880 model=z71v with auto-parserTakashi Iwai
ASUS Z71V has a totally broken BIOS setup (at least the info I got), thus we need to override the whole pin-config table to make the auto-parser working correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Rewrite ALC880 model=uniwill with auto-parserTakashi Iwai
The model=uniwill would work almost as is, but a couple of adjustments are needed to make the mutli-io working correctly. The headphone and speaker pins have to be marked properly in pin configs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Rewrite ALC880 model=F1734 with auto-parserTakashi Iwai
Similar as the previous patch for model=fujitsu, we can now move the static quirk for F1734 to the auto-parser. The only difference is the default pin configurations: F1734 has less pins than Amilo's. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-20ALSA: hda/realtek - Rewrite ALC880 model=futjisu with auto-parserTakashi Iwai
Now adding the support for the volume-knob widget, we can move the static quirk for ALC880 model=fujitsu to the auto-parser completely. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-17ALSA: hda/realtek - Replace ALC880 model=tcl with auto-parserTakashi Iwai
It needs a few extra setups for EAPD, but others look fairly straightforward. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-17ALSA: hda/realtek - Drop ALC880 model=clevoTakashi Iwai
Clevo machines with ALC880 are all well with proper BIOS setup. It seems still requiring the additional COEF setup for the EAPD. Signed-off-by: Takashi Iwai <tiwai@suse.de>
