path: root/Documentation/m68k
2013-05-17block: remove refs to XD disks from documentationLinus Walleij
Commit d1a6f4f19728d6e90480e53601a90fc9f6a348ad "block: delete super ancient PC-XT driver for 1980's hardware" deleted the XD disk driver, but there are still a few references to it in the documentation directory. Delete the remnants and thus also free up the major block device 13 for reuse. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-08-03Documentation: add pointer to name_to_dev_t for root= valuesWill Drewry
Update kernel-parameters.txt to point users to the authoritative comment for name_to_dev_t. In addition, updates other places where some name_to_dev_t behavior was discussed. All other references to root= appear to be for explicit sample usage or just side comments when discussing other kernel parameters. Signed-off-by: Will Drewry <wad@chromium.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11[SCSI] 53c7xx: fix removal falloutAdrian Bunk
This patch does some additional cleanups after the 53c7xx removal. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-19Documentation: Remove references to dead "noasync" kernel parmRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17Remove final traces of long-deprecated "ramdisk" kernel parmRobert P. J. Day
Since the "ramdisk" kernel parameter has been officially deprecated since at least 2.6.18, might as well finally get rid of it. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16more ACSI removalAdrian Bunk
This patch removes some code that became dead code after the ATARI_ACSI removal. It also indirectly fixes the following bug introduced by commit c2bcf3b8978c291e1b7f6499475c8403a259d4d6: config ATARI_SLM tristate "Atari SLM laser printer support" - depends on ATARI && ATARI_ACSI!=n + depends on ATARI Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-28[PATCH] Typo fixesAlexey Dobriyan
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: m68k kill stram swapHugh Dickins
Please, please now delete the Atari CONFIG_STRAM_SWAP code. It may be excellent and ingenious code, but its reference to swap_vfsmnt betrays that it hasn't been built since 2.5.1 (four years old come December), it's delving deep into matters which are the preserve of core mm code, its only purpose is to give the more conscientious mm guys an anxiety attack from time to time; yet we keep on breaking it more and more. If you want to use RAM for swap, then if the MTD driver does not already provide just what you need, I'm sure David could be persuaded to add the extra. But you'd also like to be able to allocate extents of that swap for other use: we can give you a core interface for that if you need. But unbuilt for four years suggests to me that there's no need at all. I cannot swear the patch below won't break your build, but believe so. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
