path: root/Documentation/DocBook
2013-09-26media: DocBook: upgrade media_api DocBook version to 4.2Andrzej Hajda
commit 8bfd4a68ecc003c1a142f35551be846d6b13e822 upstream. Fixes the last three errors of media_api DocBook validatation: (...) media_api.xml:414: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set media_api.xml:432: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set media_api.xml:452: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set (...) Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "Series of fixes for 3.10. There are some usual driver fixes (mostly on s5p/exynos playform drivers), plus some fixes at V4L2 core" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (40 commits) [media] soc_camera: error dev remove and v4l2 call [media] sh_veu: fix the buffer size calculation [media] sh_veu: keep power supply until the m2m context is released [media] sh_veu: invoke v4l2_m2m_job_finish() even if a job has been aborted [media] v4l2-ioctl: don't print the clips list [media] v4l2-ctrls: V4L2_CTRL_CLASS_FM_RX controls are also valid radio controls [media] cx88: fix NULL pointer dereference [media] DocBook/media/v4l: update version number [media] exynos4-is: Remove "sysreg" clock handling [media] exynos4-is: Fix reported colorspace at FIMC-IS-ISP subdev [media] exynos4-is: Ensure fimc-is clocks are not enabled until properly configured [media] exynos4-is: Prevent NULL pointer dereference when firmware isn't loaded [media] s5p-mfc: Add NULL check for allocated buffer [media] s5p-mfc: added missing end-of-lines in debug messages [media] s5p-mfc: v4l2 controls setup routine moved to initialization code [media] s5p-mfc: separate encoder parameters for h264 and mpeg4 [media] s5p-mfc: Remove special clock usage in driver [media] s5p-mfc: Remove unused s5p_mfc_get_decoded_status_v6() function [media] v4l2: mem2mem: save irq flags correctly [media] coda: v4l2-compliance fix: add VIDIOC_CREATE_BUFS support ...
2013-06-08[media] DocBook/media/v4l: update version numberHans Verkuil
The version number was still 3.9: update to 3.10. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-05-21[media] DocBook: media: update codec section, drop obsolete 'suspended' stateHans Verkuil
The Codec section in the V4L2 specification was marked as 'suspended', even though codec support has been around for quite some time. Update this section, explaining a bit about memory-to-memory devices and pointing to the MPEG controls section. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-05-03Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Mostly many small changes spread as seen in diffstat in sound/* directory by this update. A significant change in the subsystem level is the introduction of snd_soc_component, which will help more generic handling of SoC and off-SoC components. Also, snd_BUG_ON() macro is enabled unconditionally now due to its misuses, so people might hit kernel warnings (it's a good thing for us). - compress-offload: support for capture by Charles Keepax - HD-audio: codec delay support by Dylan Reid - HD-audio: improvements/fixes in generic parser: better headphone mic and headset mic support, jack_modes hint consolidation, proper beep attach/detachment, generalized power filter controls by David Henningsson, et al - HD-audio: Improved management of HDMI codec pins/converters - HD-audio: Better pin/DAC assignment for VIA codecs - HD-audio: Haswell HDMI workarounds - HD-audio: ALC268 codec support, a few new quirks for Chromebooks - USB: regression fixes: USB-MIDI autopm fix, the recent ISO latency fix by Clemens Ladisch - USB: support for DSD formats by Daniel Mack - USB: A few UAC2 device endian/cock fixes by Eldad Zack - USB: quirks for Emu 192kHz support, Novation Twitch DJ controller, Yamaha THRxx devices - HDSPM: updates for TCO controls by Adrian Knoth - ASoC: Add a snd_soc_component object type for generic handling of SoC and off-SoC components by Kuninori Morimoto, - dmaengine: a large set of cleanups and conversions by Lars-Peter Clausen - ASoC DAPM: performance optimizations from Ryo Tsutsui - ASoC DAPM: support for mixer control sharing by Stephen Warren - ASoC: multiplatform ARM cleanups from Arnd Bergmann - ASoC: new codec drivers for AK5385 and TAS5086 from Daniel Mack" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (315 commits) ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatch ALSA: asihpi: add format support check in snd_card_asihpi_capture_formats ALSA: pcm_format_to_bits strong-typed conversion ALSA: compress: fix the states to check for allowing read ALSA: hda - Move Thinkpad X220 to use auto parser ALSA: USB: adjust for changed 3.8 USB API ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sources sound: oss/dmabuf: use dma_map_single ALSA: ali5451: use mdelay instead of large udelay constants ALSA: hda - Add the support for ALC286 codec ALSA: usb-audio: USB quirk for Yamaha THR10C ALSA: usb-audio: USB quirk for Yamaha THR5A ALSA: usb-audio: USB quirk for Yamaha THR10 ALSA: usb-audio: Fix autopm error during probing ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINT ALSA: sound kconfig typo ALSA: emu10k1: Fix dock firmware loading ASoC: ux500: forward declare msp_i2s_platform_data ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modes ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializers ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-30Merge branch 'devel-for-v3.10' into v4l_for_linusMauro Carvalho Chehab
* patchwork: (831 commits) [media] cx88: make core less verbose [media] em28xx: fix oops at em28xx_dvb_bus_ctrl() [media] s5c73m3: fix indentation of the help section in Kconfig [media] cx25821-alsa: get rid of a __must_check warning [media] cx25821-video: declare cx25821_vidioc_s_std as static [media] cx25821-video: remove maxw from cx25821_vidioc_try_fmt_vid_cap [media] r820t: Remove a warning for an unused value [media] dib0090: Fix a warning at dib0090_set_EFUSE [media] dib8000: fix a warning [media] dib8000: Fix sub-channel range [media] dib8000: store dtv_property_cache in a temp var [media] dib8000: warning fix: declare internal functions as static [media] r820t: quiet gcc warning on n_ring [media] r820t: memory leak in release() [media] r820t: precendence bug in r820t_xtal_check() [media] videodev2.h: Remove the unused old V4L1 buffer types [media] anysee: Grammar s/report the/report to/ [media] anysee: Initialize ret = 0 in anysee_frontend_attach() [media] media: videobuf2: fix the length check for mmap [media] em28xx: save isoc endpoint number for DVB only if endpoint has alt settings with xMaxPacketSize != 0 ... Conflicts: drivers/media/pci/cx25821/cx25821-video.c drivers/media/platform/Kconfig
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-18Merge tag 'asoc-v3.10-2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: More updates for v3.10 The main additional change here is Lars-Peter's DMA work plus the platform conversions which have been tested - getting this in mainline will make life easier for development after the merge window. These factor a large chunk of code out of the drivers for the platforms using dmaengine, greatly simplifying development.
2013-04-14[media] v4l2: rename VIDIOC_DBG_G_CHIP_NAME to _CHIP_INFOHans Verkuil
This ioctl will be extended to return more information than just the name. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-14[media] v4l2: drop V4L2_CHIP_MATCH_SUBDEV_NAMEHans Verkuil
After using the new VIDIOC_DBG_G_CHIP_NAME ioctl I realized that the matching by name possibility is useless. Just drop it and rename MATCH_SUBDEV_IDX to just MATCH_SUBDEV. The v4l2-dbg utility is much better placed to match by name by just enumerating all bridge and subdev devices until chip_name.name matches. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-14[media] v4l2: put VIDIOC_DBG_G_CHIP_NAME under ADV_DEBUGHans Verkuil
Only enable this ioctl if the VIDEO_ADV_DEBUG config option is set. This prevents abuse from both userspace and kernelspace (some bridge drivers abuse DBG_G_CHIP_IDENT, lets prevent that from happening again with this ioctl). Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-04[media] soc_camera: Add RGB666 & RGB888 formatsPhil Edworthy
Based on work done by Katsuya Matsubara. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-03tty: Documentation: fix a path in a DocBook templateGuennadi Liakhovetski
A wrong path to a driver breaks DocBook built. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-31[media] V4L: Add MATRIX option to V4L2_CID_EXPOSURE_METERING controlSylwester Nawrocki
This patch adds a menu option to the V4L2_CID_EXPOSURE_METERING control for multi-zone metering. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-29[media] v4l2: Add documentation for the FM RX controlsAndrey Smirnov
Add appropriate documentation for all the newly added standard controls. Based on the patch by Manjunatha Halli [1] [1] http://lists-archives.com/linux-kernel/27641303-media-update-docs-for-v4l2-fm-new-features.html Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-29[media] v4l2: Fix the type of V4L2_CID_TUNE_PREEMPHASIS in the documentationAndrey Smirnov
Change the type of V4L2_CID_TUNE_PREEMPHASIS from 'integer' to 'enum v4l2_preemphasis' Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-25[media] DocBook media: document 3.10 changesHans Verkuil
2013-03-25[media] DocBook media: add VIDIOC_DBG_G_CHIP_NAME documentationHans Verkuil
And update the other debug ioctls accordingly. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-25[media] DocBook media: fix syntax problems in dvbproperty.xmlHans Verkuil
Caught by xmllint. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] DocBook/media/v4l: Update version number and document 3.10 changesHans Verkuil
2013-03-24[media] DocBook/media/v4l: remove the documentation of the obsolete ↵Hans Verkuil
dv_preset API This API is no longer used by any driver and so can be removed from the documentation. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] v4l2-ctrls: add V4L2_CID_MPEG_VIDEO_REPEAT_SEQ_HEADER controlHans Verkuil
Control whether video sequence headers should be repeated. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] documentation: DocBook/media : Fix typo in dvbproperty.xmlMasanari Iida
Correct spelling typos. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-21[media] media: add support for decoder as one of media entity typesManjunath Hadli
A lot of SOCs including Texas Instruments Davinci family mainly use video decoders as input devices. This patch adds a flag 'MEDIA_ENT_T_V4L2_SUBDEV_DECODER' media entity type for decoder's. Along side updates the documentation for this media entity type. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-11ALSA: Make snd_BUG_ON() always evaluate and return the conditional expressionChristine Spang
Having snd_BUG_ON() only evaluate its conditional when CONFIG_SND_DEBUG is set leads to frequent bugs, since other similar macros in the kernel have different behavior. Let's make snd_BUG_ON() act like those macros so it will stop being accidentally misused. Signed-off-by: Christine Spang <christine.spang@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-07mac80211: provide ieee80211_sta_eosp()Johannes Berg
The irqsafe version ieee80211_sta_eosp_irqsafe() exists, but drivers must not mix calls to any irqsafe/non-irqsafe function. Both ath9k and iwlwifi, the likely first users of this interface, use non-irqsafe RX/TX/TX status so must also use a non-irqsafe version of this function. Since no driver uses the _irqsafe() version, remove that. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-05[media] v4l: Define video buffer flag for the COPY timestamp typeKamil Debski
Define video buffer flag for the COPY timestamp. In this case the timestamp value is copied from the OUTPUT to the corresponding CAPTURE buffer. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-25Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm merge from Dave Airlie: "Highlights: - TI LCD controller KMS driver - TI OMAP KMS driver merged from staging - drop gma500 stub driver - the fbcon locking fixes - the vgacon dirty like zebra fix. - open firmware videomode and hdmi common code helpers - major locking rework for kms object handling - pageflip/cursor won't block on polling anymore! - fbcon helper and prime helper cleanups - i915: all over the map, haswell power well enhancements, valleyview macro horrors cleaned up, killing lots of legacy GTT code, - radeon: CS ioctl unification, deprecated UMS support, gpu reset rework, VM fixes - nouveau: reworked thermal code, external dp/tmds encoder support (anx9805), fences sleep instead of polling, - exynos: all over the driver fixes." Lovely conflict in radeon/evergreen_cs.c between commit de0babd60d8d ("drm/radeon: enforce use of radeon_get_ib_value when reading user cmd") and the new changes that modified that evergreen_dma_cs_parse() function. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (508 commits) drm/tilcdc: only build on arm drm/i915: Revert hdmi HDP pin checks drm/tegra: Add list of framebuffers to debugfs drm/tegra: Fix color expansion drm/tegra: Split DC_CMD_STATE_CONTROL register write drm/tegra: Implement page-flipping support drm/tegra: Implement VBLANK support drm/tegra: Implement .mode_set_base() drm/tegra: Add plane support drm/tegra: Remove bogus tegra_framebuffer structure drm: Add consistency check for page-flipping drm/radeon: Use generic HDMI infoframe helpers drm/tegra: Use generic HDMI infoframe helpers drm: Add EDID helper documentation drm: Add HDMI infoframe helpers video: Add generic HDMI infoframe helpers drm: Add some missing forward declarations drm: Move mode tables to drm_edid.c drm: Remove duplicate drm_mode_cea_vic() gma500: Fix n, m1 and m2 clock limits for sdvo and lvds ...
2013-02-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Some cleanups at V4L2 documentation - new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor, sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging driver - Lots of missing MAINTAINERS entries added - several em28xx driver improvements, including its conversion to videobuf2 - several fixups on drivers to make them to better comply with the API - DVB core: add support for DVBv5 stats, allowing the implementation of statistics for new standards like ISDB - mb86a20s: add statistics to the driver - lots of new board additions, cleanups, and driver improvements. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits) [media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff) [media] rtl28xxu: Add USB IDs for Compro VideoMate U620F [media] em28xx: add usb id for terratec h5 rev. 3 [media] media: rc: gpio-ir-recv: add support for device tree parsing [media] mceusb: move check earlier to make smatch happy [media] radio-si470x doc: add info about v4l2-ctl and sox+alsa [media] staging: media: Remove unnecessary OOM messages [media] sh_vou: Use vou_dev instead of vou_file wherever possible [media] sh_vou: Use video_drvdata() [media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions [media] mt9t112: mt9t111 format set up differs from mt9t112 [media] sh-mobile-ceu-camera: fix SHARPNESS control default Revert "[media] fc0011: Return early, if the frequency is already tuned" [media] cx18/ivtv: fix regression: remove __init from a non-init function [media] em28xx: fix analog streaming with USB bulk transfers [media] stv0900: remove unnecessary null pointer check [media] fc0011: Return early, if the frequency is already tuned [media] fc0011: Add some sanity checks and cleanups [media] fc0011: Fix xin value clamping Revert "[media] [PATH,1/2] mxl5007 move reset to attach" ...
2013-02-24Merge branch 'drm/hdmi-for-3.9' of git://anongit.freedesktop.org/tegra/linux ↵Dave Airlie
into drm-next Thierry writes: "Remove a duplicate implementation of the CEA VIC lookup and move the CEA and other mode tables to drm_edid.c to make it more difficult to create duplicates of the tables. Add some helpers to pack CEA-861/HDMI AVI, audio and SPD infoframes into binary buffers that can easily be written into hardware registers. A new helper function makes it easy construct an AVI infoframe from a DRM display mode. Convert the Tegra and Radeon drivers to use the new HDMI helpers." * 'drm/hdmi-for-3.9' of git://anongit.freedesktop.org/tegra/linux: drm/radeon: Use generic HDMI infoframe helpers drm/tegra: Use generic HDMI infoframe helpers drm: Add EDID helper documentation drm: Add HDMI infoframe helpers video: Add generic HDMI infoframe helpers drm: Add some missing forward declarations drm: Move mode tables to drm_edid.c drm: Remove duplicate drm_mode_cea_vic()
2013-02-22drm: Add consistency check for page-flippingThierry Reding
Driver implementations of the drm_crtc's .page_flip() function are required to update the crtc->fb field on success to reflect that the new framebuffer is now in use. This is important to keep reference counting on the framebuffers balanced. While at it, document this requirement to keep others from falling into the same trap. Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-22drm: Add EDID helper documentationThierry Reding
Add a reference section about the EDID helper functions to the DRM documentation. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg Kroah-Hartman: "Here's the big char/misc driver patches for 3.9-rc1. Nothing major here, just lots of different driver updates (mei, hyperv, ipack, extcon, vmci, etc.). All of these have been in the linux-next tree for a while." * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits) w1: w1_therm: Add force-pullup option for "broken" sensors w1: ds2482: Added 1-Wire pull-up support to the driver vme: add missing put_device() after device_register() fails extcon: max8997: Use workqueue to check cable state after completing boot of platform extcon: max8997: Set default UART/USB path on probe extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type extcon: max8997: Set default of ADC debounce time during initialization extcon: max8997: Remove duplicate code related to set H/W line path extcon: max8997: Move defined constant to header file extcon: max77693: Make max77693_extcon_cable static extcon: max8997: Remove unreachable code extcon: max8997: Make max8997_extcon_cable static extcon: max77693: Remove unnecessary goto statement to improve readability extcon: max77693: Convert to devm_input_allocate_device() extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style CREDITS: update email and address of Harald Hoyer extcon: arizona: Use MICDET for final microphone identification extcon: arizona: Always take the first HPDET reading as the final one extcon: arizona: Clear _trig_sts bits after jack detection extcon: arizona: Don't HPDET magic when headphones are enabled ...
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-21Merge tag 'sound-3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "The biggest change in this update is the unification of HD-audio codec parsers. Now the HD-audio codec is parsed in a generic parser code which is invoked by each HD-audio codec driver. Some background information is found in David Henningsson's blog entry: http://voices.canonical.com/david.henningsson/2013/01/18/upcoming-changes-to-the-intel-hda-drivers/ Other than that, some random updates/fixes like USB-audio and a bunch of small AoC updates as usual. Highlights: - Unification of HD-audio parser code (aka generic parser) - Support of new Intel HD-audio controller, new IDT codecs - Fixes for HD-audio HDMI audio hotplug - Haswell HDMI audio fixup - Support of Creative CA0132 DSP code - A few fixes of HDSP driver - USB-audio fix for Roland A-PRO, M-Audio FT C600 - Support PM for aloop driver (and fixes Oops) - Compress API updates for gapless playback support For ASoC part: - Support for a wider range of hardware in the compressed stream code - The ability to mute capture streams as well as playback streams while inactive - DT support for AK4642, FSI, Samsung I2S and WM8962 - AC'97 support for Tegra - New driver for max98090, replacing the stub which was there - A new driver from Dialog Note that due to dependencies, DTification of DMA support for Samsung platforms (used only by the and I2S driver and SPI) is merged here as well." Fix up trivial conflict in drivers/spi/spi-s3c64xx.c due to removed code being changed. * tag 'sound-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (453 commits) ALSA: usb: Fix Processing Unit Descriptor parsers ALSA: hda - hdmi: Notify userspace when ELD control changes ALSA: hda - hdmi: Protect ELD buffer ALSA: hda - hdmi: Refactor hdmi_eld into parsed_hdmi_eld ALSA: hda - hdmi: Do not expose eld data when eld is invalid ALSA: hda - hdmi: ELD shouldn't be valid after unplug ALSA: hda - Fix the silent speaker output on Fujitsu S7020 laptop ALSA: hda - add quirks for mute LED on two HP machines ALSA: usb/quirks, fix out-of-bounds access ASoC: codecs: Add da7213 codec ALSA: au88x0 - Define channel map for au88x0 ALSA: compress: add support for gapless playback ALSA: hda - Remove speaker clicks on CX20549 ALSA: hda - Disable runtime PM for Intel 5 Series/3400 ALSA: hda - Increase badness for missing multi-io ASoC: arizona: Automatically manage input mutes ALSA: hda - Fix broken workaround for HDMI/SPDIF conflicts ALSA: hda/ca0132 - Add missing \n to debug prints ALSA: hda/ca0132 - Fix type of INVALID_CHIP_ADDRESS ALSA: hda - update documentation for no-primary-hp fixup ...
2013-02-19Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2013-02-18cfg80211: add correct docbook entriesJohannes Berg
Update the 802.11 book to list the correct data structures. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-18DocBook: update EXPORT_SYMBOL entry to point at export.hPaul Gortmaker
Previously we used to get EXPORT_SYMBOL and friends from module.h but we moved away from that since module.h largely includes the entire header space one way or another. As most users just wanted the simple export related macros, they were spun off into a separate new header -- export.h Update the docs to reflect that. Suggested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-14drm/fb-helper: improve kerneldocDaniel Vetter
Now that the fbdev helper interface for drivers is trimmed down, update the kerneldoc for all the remaining exported functions. I've tried to beat the DocBook a bit by reordering the function references a bit into a more sensible ordering. But that didn't work out at all. Hence just extend the in-code DOC: section a bit. Also remove the LOCKING: sections - especially for the setup functions they're totally bogus. But that's not a documentation problem, but simply an artifact of the current rather hazardous locking around drm init and even more so around fbdev setup ... v2: Some further improvements: - Also add documentation for drm_fb_helper_single_add_all_connectors, Dave Airlie didn't want me to kill this one from the fb helper interface. - Update docs for drm_fb_helper_fill_var/fix - they should be used from the driver's ->fb_probe callback to setup the fbdev info structure. - Clarify what the ->fb_probe callback should all do - it needs to setup both the fbdev info and allocate the drm framebuffer used as backing storage. - Add basic documentaation for the drm_fb_helper_funcs driver callback vfunc. v3: Implement clarifications Laurent Pinchart suggested in his review. v4: Fix another mispelling Laurent spotted. Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-08drm: add prime helpersAaron Plattner
Instead of reimplementing all of the dma_buf functionality in every driver, create helpers drm_prime_import and drm_prime_export that implement them in terms of new, lower-level hook functions: gem_prime_pin: callback when a buffer is created, used to pin buffers into GTT gem_prime_get_sg_table: convert a drm_gem_object to an sg_table for export gem_prime_import_sg_table: convert an sg_table into a drm_gem_object gem_prime_vmap, gem_prime_vunmap: map and unmap an object These hooks are optional; drivers can opt in by using drm_gem_prime_import and drm_gem_prime_export as the .gem_prime_import and .gem_prime_export fields of struct drm_driver. v2: - Drop .begin_cpu_access. None of the drivers this code replaces implemented it. Having it here was a leftover from when I was trying to include i915 in this rework. - Use mutex_lock instead of mutex_lock_interruptible, as these three drivers did. This patch series shouldn't change that behavior. - Rename helpers to gem_prime_get_sg_table and gem_prime_import_sg_table. Rename struct sg_table* variables to 'sgt' for clarity. - Update drm.tmpl for these new hooks. v3: - Pass the vaddr down to the driver. This lets drivers that just call vunmap on the pointer avoid having to store the pointer in their GEM private structures. - Move documentation into a /** DOC */ comment in drm_prime.c and include it in drm.tmpl with a !P line. I tried to use !F lines to include documentation of the individual functions from drmP.h, but the docproc / kernel-doc scripts barf on that file, so hopefully this is good enough for now. - apply refcount fix from commit be8a42ae60addd8b6092535c11b42d099d6470ec ("drm/prime: drop reference on imported dma-buf come from gem") Signed-off-by: Aaron Plattner <aplattner@nvidia.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-02-06[media] DocBook: mention that EINVAL can be returned for invalid menu indicesHans Verkuil
The documentation suggested that if the control value is wrong only ERANGE can be returned. But in some cases (an invalid menu index) EINVAL can also be returned. Clarify this. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-06[media] DocBook: improve the error_idx field documentationHans Verkuil
The documentation of the error_idx field was incomplete and confusing. This patch improves it. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-06[media] DocBook: fix various validation errorsHans Verkuil
Fixed the following errors (with exception of the SVG errors): GEN /home/hans/work/src/v4l/media-git/Documentation/DocBook//v4l2.xml rm -rf Documentation/DocBook/index.html; echo '<h1>Linux Kernel HTML Documentation</h1>' >> Documentation/DocBook/index.html && echo '<h2>Kernel Version: 3.8.0-rc1</h2>' >> Documentation/DocBook/index.html && cat Documentation/DocBook/media_api.html >> Documentation/DocBook/index.html /tmp/x.xml:883: element revremark: validity error : Element structname is not declared in revremark list of possible children /tmp/x.xml:883: element revremark: validity error : Element xref is not declared in revremark list of possible children /tmp/x.xml:9580: element xref: validity error : Element xref was declared EMPTY this one has content /tmp/x.xml:13508: element link: validity error : Element link does not carry attribute linkend /tmp/x.xml:13508: element link: validity error : No declaration for attribute linked of element link /tmp/x.xml:16986: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set /tmp/x.xml:17003: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set /tmp/x.xml:17022: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-05[media] DocBook: media: struct v4l2_capability card field is a UTF-8 stringLaurent Pinchart
The struct v4l2_capability card field stores the device name. That name can be hardcoded in drivers, or be retrieved directly from the device. The later is very common with USB devices. As several devices already report names that include non-ASCII characters, update the field description to use UTF-8. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-05[media] v4l2-ctrl: Add helper function for the controls range updateSylwester Nawrocki
This patch adds a helper function that allows to modify range, i.e. minimum, maximum, step and default value of a v4l2 control, after the control has been created and initialized. This is helpful in situations when range of a control depends on user configurable parameters, e.g. camera sensor absolute exposure time depending on an output image resolution and frame rate. v4l2_ctrl_modify_range() function allows to modify range of an INTEGER, BOOL, MENU, INTEGER_MENU and BITMASK type controls. Based on a patch from Hans Verkuil http://patchwork.linuxtv.org/patch/8654. Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-05ALSA: Replace 0 with NULL in writing-an-alsa-driver.tmplTakashi Iwai
Spotted while correcting the sentences. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-05ALSA: Fix wrong description about hw constraintsTakashi Iwai
The definitions of hw constraint functions are wrongly placed, and the description about the function is also wrong. hw_rule_channels_by_format actually refines the channels depending on the format, not vice versa. Reported-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-29ALSA: Documentation: fix some typosAntonio Ospite
s/PAUSE_PUSE/PAUSE_PUSH/ s/happense/happens/ Signed-off-by: Antonio Ospite <ao2@amarulasolutions.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
