commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 6ac1dc736b323011a55ecd1fc5897c24c4f77cbd upstream.
Setting si_code to 0 is the same a setting si_code to SI_USER which is definitely
not correct. With si_code set to SI_USER si_pid and si_uid will be copied to
userspace instead of si_addr. Which is very wrong.
So fix this by using a sensible si_code (SEGV_MAPERR) for this failure.
Fixes: b920de1b77b7 ("mn10300: add the MN10300/AM33 architecture to the kernel")
Cc: Masakazu Urade <urade.masakazu@jp.panasonic.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
commit d796e77f1dd541fe34481af2eee6454688d13982 upstream.
As a writable mount, it is not expected for overlayfs to return
EINVAL/EROFS for fsync, even if dir/file is not changed.
This commit fixes the case of fsync of directory, which is easier to
address, because overlayfs already implements fsync file operation for
directories.
The problem reported by Raphael is that new PostgreSQL 10.0 with a
database in overlayfs where lower layer in squashfs fails to start.
The failure is due to fsync error, when PostgreSQL does fsync on all
existing db directories on startup and a specific directory exists
lower layer with no changes.
Reported-by: Raphael Hertzog <raphael@ouaza.com>
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Tested-by: Raphaël Hertzog <hertzog@debian.org>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 23fbd7c70aec7600e3227eb24259fc55bf6e4881 upstream.
A NULL pointer reference kernel bug was observed when
acpi_nfit_add_dimm() called in acpi_nfit_register_dimms() failed. This
error path does not set nfit_mem->nvdimm, but the 2nd
list_for_each_entry() loop in the function assumes it's always set. Add
a check to nfit_mem->nvdimm.
Fixes: ba9c8dd3c222 ("acpi, nfit: add dimm device notification support")
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
commit 43cdd1b716b26f6af16da4e145b6578f98798bf6 upstream.
There's no need to be printing a raw kernel pointer to the kernel log at
every boot. So just remove it, and change the whole message to use the
correct dev_info() call at the same time.
Reported-by: Wang Qize <wang_qize@venustech.com.cn>
commit 5643205c6340b565a3be0fe0e7305dc4aa551c74 upstream.
We store a SW state of the t11_t12 timing in 100usec units but have to
program it in 100msec as required by HW. The rounding used during
programming means there will be a mismatch between the SW and HW states
of this value triggering a "PPS state mismatch" error. Avoid this by
storing the already rounded-up value in the SW state.
Note that we still calculate panel_power_cycle_delay with the finer
100usec granularity to avoid any needless waits using that version of
the delay.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=103903
Cc: joks <joks@linux.pl>
Signed-off-by: Imre Deak <imre.deak@intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171129175137.2889-1-imre.deak@intel.com
commit f3038ee3a3f1017a1cbe9907e31fa12d366c5dcb upstream.
This function was introduced by 247e743cbe6e ("Btrfs: Use async helpers
to deal with pages that have been improperly dirtied") and it didn't do
any error handling then. This function might very well fail in ENOMEM
situation, yet it's not handled, this could lead to inconsistent state.
So let's handle the failure by setting the mapping error bit.
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Reviewed-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 42440c1f9911b4b7b8ba3dc4e90c1197bc561211 upstream.
UBSAN=y fails to build with new GCC/clang:
arch/x86/kernel/head64.o: In function `sanitize_boot_params':
arch/x86/include/asm/bootparam_utils.h:37: undefined reference to `__ubsan_handle_type_mismatch_v1'
because Clang and GCC 8 slightly changed ABI for 'type mismatch' errors.
Compiler now uses new __ubsan_handle_type_mismatch_v1() function with
slightly modified 'struct type_mismatch_data'.
Let's add new 'struct type_mismatch_data_common' which is independent from
compiler's layout of 'struct type_mismatch_data'. And make
__ubsan_handle_type_mismatch[_v1]() functions transform compiler-dependent
type mismatch data to our internal representation. This way, we can
support both old and new compilers with minimal amount of change.
Link: http://lkml.kernel.org/r/20180119152853.16806-1-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reported-by: Sodagudi Prasad <psodagud@codeaurora.org>
commit b8fe1120b4ba342b4f156d24e952d6e686b20298 upstream.
A vist from the spelling fairy.
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit e0aeca3d8cbaea514eb98df1149faa918f9ec42d upstream.
The current code hides a couple of bugs:
- The global variable 'clock_event_ddata' is overwritten each time the
init function is invoked.
This is fixed with a kmemdup() instead of assigning the global variable. That
prevents a memory corruption when several timers are defined in the DT.
- The clockevent's event_handler is NULL if the time framework does
not select the clockevent when registering it, this is fine but the init
code generates in any case an interrupt leading to dereference this
NULL pointer.
The stm32 timer works with shadow registers, a mechanism to cache the
registers. When a change is done in one buffered register, we need to
artificially generate an event to force the timer to copy the content
of the register to the shadowed register.
The auto-reload register (ARR) is one of the shadowed register as well as
the prescaler register (PSC), so in order to force the copy, we issue an
event which in turn leads to an interrupt and the NULL dereference.
This is fixed by inverting two lines where we clear the status register
before enabling the update event interrupt.
As this kernel crash is resulting from the combination of these two bugs,
the fixes are grouped into a single patch.
Tested-by: Benjamin Gaignard <benjamin.gaignard@st.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Benjamin Gaignard <benjamin.gaignard@st.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Link: http://lkml.kernel.org/r/1515418139-23276-11-git-send-email-daniel.lezcano@linaro.org
commit 5a0ec388ef0f6e33841aeb810d7fa23f049ec4cd upstream.
Commit 523e1d399ce0 ("block: make gendisk hold a reference to its queue")
modified add_disk() and disk_release() but did not update any of the
error paths that trigger a put_disk() call after disk->queue has been
assigned. That introduced the following behavior in the pktcdvd driver
if pkt_new_dev() fails:
Kernel BUG at 00000000e98fd882 [verbose debug info unavailable]
Since disk_release() calls blk_put_queue() anyway if disk->queue != NULL,
fix this by removing the blk_cleanup_queue() call from the pkt_setup_dev()
error path.
Fixes: commit 523e1d399ce0 ("block: make gendisk hold a reference to its queue")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
commit f5a26acf0162477af6ee4c11b4fb9cffe5d3e257 upstream.
When a GPIO is requested using gpiod_get_* APIs the intel pinctrl driver
switches the pin to GPIO mode and makes sure interrupts are routed to
the GPIO hardware instead of IOAPIC. However, if the GPIO is used
directly through irqchip, as is the case with many I2C-HID devices where
I2C core automatically configures interrupt for the device, the pin is
not initialized as GPIO. Instead we rely that the BIOS configures the
pin accordingly which seems not to be the case at least in Asus X540NA
SKU3 with Focaltech touchpad.
When the pin is not properly configured it might result weird behaviour
like interrupts suddenly stop firing completely and the touchpad stops
responding to user input.
Fix this by properly initializing the pin to GPIO mode also when it is
used directly through irqchip.
Fixes: 7981c0015af2 ("pinctrl: intel: Add Intel Sunrisepoint pin controller and GPIO support")
Reported-by: Daniel Drake <drake@endlessm.com>
Reported-and-tested-by: Chris Chiu <chiu@endlessm.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit 544e92581a2ac44607d7cc602c6b54d18656f56d upstream.
Fix an uninitialized variable warning in the Octeon EDAC driver, as seen
in MIPS cavium_octeon_defconfig builds since v4.14 with Codescape GNU
Tools 2016.05-03:
drivers/edac/octeon_edac-lmc.c In function ‘octeon_lmc_edac_poll_o2’:
drivers/edac/octeon_edac-lmc.c:87:24: warning: ‘((long unsigned int*)&int_reg)[1]’ may \
be used uninitialized in this function [-Wmaybe-uninitialized]
if (int_reg.s.sec_err || int_reg.s.ded_err) {
Iinitialise the whole int_reg variable to zero before the conditional
assignments in the error injection case.
Signed-off-by: James Hogan <jhogan@kernel.org>
Acked-by: David Daney <david.daney@cavium.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: linux-mips@linux-mips.org
Fixes: 1bc021e81565 ("EDAC: Octeon: Add error injection support")
Link: http://lkml.kernel.org/r/20171113161206.20990-1-james.hogan@mips.com
commit ca47480921587ae30417dd234a9f79af188e3666 upstream.
Return 0 if the operation was successful, not the userspace memory
value. Check that userspace value equals passed oldval, not itself.
Don't update *uval if the value wasn't read from userspace memory.
This fixes process hang due to infinite loop in futex_lock_pi.
It also fixes a bunch of glibc tests nptl/tst-mutexpi*.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 4b01abdb32fc36abe877503bfbd33019159fad71 upstream.
Since version 4.9, the kernel automatically breaks printk calls into
multiple newlines unless pr_cont is used. Fix the alpha stacktrace code,
so that it prints stack trace in four columns, as it was initially
intended.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
commit 55fc633c41a08ce9244ff5f528f420b16b1e04d6 upstream.
We need to define NEED_SRM_SAVE_RESTORE on the Avanti, otherwise we get
machine check exception when attempting to reboot the machine.
commit 21ffceda1c8b3807615c40d440d7815e0c85d366 upstream.
On alpha, a process will crash if it attempts to start a thread and a
signal is delivered at the same time. The crash can be reproduced with
this program: https://cygwin.com/ml/cygwin/2014-11/msg00473.html
The reason for the crash is this:
* we call the clone syscall
* we go to the function copy_process
* copy process calls copy_thread_tls, it is a wrapper around copy_thread
* copy_thread sets the tls pointer: childti->pcb.unique = regs->r20
* copy_thread sets regs->r20 to zero
* we go back to copy_process
* copy process checks "if (signal_pending(current))" and returns
-ERESTARTNOINTR
* the clone syscall is restarted, but this time, regs->r20 is zero, so
the new thread is created with zero tls pointer
* the new thread crashes in start_thread when attempting to access tls
The comment in the code says that setting the register r20 is some
compatibility with OSF/1. But OSF/1 doesn't use the CLONE_SETTLS flag, so
we don't have to zero r20 if CLONE_SETTLS is set. This patch fixes the bug
by zeroing regs->r20 only if CLONE_SETTLS is not set.
commit 0e88bb002a9b2ee8cc3cc9478ce2dc126f849696 upstream.
Set si_signo.
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: linux-sh@vger.kernel.org
Fixes: 0983b31849bb ("sh: Wire up division and address error exceptions on SH-2A.")
commit 500d58300571b6602341b041f97c082a461ef994 upstream.
While reviewing the signal sending on openrisc the do_unaligned_access
function stood out because it is obviously wrong. A comment about an
si_code set above when actually si_code is never set. Leading to a
random si_code being sent to userspace in the event of an unaligned
access.
Looking further SIGBUS BUS_ADRALN is the proper pair of signal and
si_code to send for an unaligned access. That is what other
architectures do and what is required by posix.
Given that do_unaligned_access is broken in a way that no one can be
relying on it on openrisc fix the code to just do the right thing.
Fixes: 769a8a96229e ("OpenRISC: Traps")
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Stafford Horne <shorne@gmail.com>
Cc: openrisc@lists.librecores.org
Acked-by: Stafford Horne <shorne@gmail.com>
commit 61f5acea8737d9b717fcc22bb6679924f3c82b98 upstream.
Commit 7d06d5895c15 ("Revert "Bluetooth: btusb: fix QCA...suspend/resume"")
removed the setting of the BTUSB_RESET_RESUME quirk for QCA Rome devices,
instead favoring adding USB_QUIRK_RESET_RESUME quirks in usb/core/quirks.c.
This was done because the DIY BTUSB_RESET_RESUME reset-resume handling
has several issues (see the original commit message). An added advantage
of moving over to the USB-core reset-resume handling is that it also
disables autosuspend for these devices, which is similarly broken on these.
But there are 2 issues with this approach:
1) It leaves the broken DIY BTUSB_RESET_RESUME code in place for Realtek
devices.
2) Sofar only 2 of the 10 QCA devices known to the btusb code have been
added to usb/core/quirks.c and if we fix the Realtek case the same way
we need to add an additional 14 entries. So in essence we need to
duplicate a large part of the usb_device_id table in btusb.c in
usb/core/quirks.c and manually keep them in sync.
This commit instead restores setting a reset-resume quirk for QCA devices
in the btusb.c code, avoiding the duplicate usb_device_id table problem.
This commit avoids the problems with the original DIY BTUSB_RESET_RESUME
code by simply setting the USB_QUIRK_RESET_RESUME quirk directly on the
usb_device.
This commit also moves the BTUSB_REALTEK case over to directly setting the
USB_QUIRK_RESET_RESUME on the usb_device and removes the now unused
BTUSB_RESET_RESUME code.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1514836
Fixes: 7d06d5895c15 ("Revert "Bluetooth: btusb: fix QCA...suspend/resume"")
Cc: Leif Liddy <leif.linux@gmail.com>
Cc: Matthias Kaehlcke <mka@chromium.org>
Cc: Brian Norris <briannorris@chromium.org>
Cc: Daniel Drake <drake@endlessm.com>
Cc: Kai-Heng Feng <kai.heng.feng@canonical.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 7d06d5895c159f64c46560dc258e553ad8670fe0 upstream.
This reverts commit fd865802c66bc451dc515ed89360f84376ce1a56.
This commit causes a regression on some QCA ROME chips. The USB device
reset happens in btusb_open(), hence firmware loading gets interrupted.
Furthermore, this commit stops working after commit
("a0085f2510e8976614ad8f766b209448b385492f Bluetooth: btusb: driver to
enable the usb-wakeup feature"). Reset-resume quirk only gets enabled in
btusb_suspend() when it's not a wakeup source.
If we really want to reset the USB device, we need to do it before
btusb_open(). Let's handle it in drivers/usb/core/quirks.c.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
Tested-by: Brian Norris <briannorris@chromium.org>
commit b4cdaba274247c9c841c6a682c08fa91fb3aa549 upstream.
BCM43341 devices soldered onto the PCB (non-removable) always (AFAICT)
use an UART connection for bluetooth. But they also advertise btsdio
support on their 3th sdio function, this causes 2 problems:
1) A non functioning BT HCI getting registered
2) Since the btsdio driver does not have suspend/resume callbacks,
mmc_sdio_pre_suspend will return -ENOSYS, causing mmc_pm_notify()
to react as if the SDIO-card is removed and since the slot is
marked as non-removable it will never get detected as inserted again.
Which results in wifi no longer working after a suspend/resume.
This commit fixes both by making btsdio ignore BCM43341 devices
when connected to a slot which is marked non-removable.
commit edfc3722cfef4217c7fe92b272cbe0288ba1ff57 upstream.
The Toshiba Click Mini uses an i2c attached keyboard/touchpad combo
(single i2c_hid device for both) which has a vid:pid of 04F3:0401,
which is also used by a bunch of Elan touchpads which are handled by the
drivers/input/mouse/elan_i2c driver, but that driver deals with pure
touchpads and does not work for a combo device such as the one on the
Toshiba Click Mini.
The combo on the Mini has an ACPI id of ELAN0800, which is not claimed
by the elan_i2c driver, so check for that and if it is found do not ignore
the device. This fixes the keyboard/touchpad combo on the Mini not working
(although with the touchpad in mouse emulation mode).
commit 9903a91c763ecdae333a04a9d89d79d2b8966503 upstream.
With pipe-user-pages-hard set to 'N', users were actually only allowed up
to 'N - 1' buffers; and likewise for pipe-user-pages-soft.
Fix this to allow up to 'N' buffers, as would be expected.
Link: http://lkml.kernel.org/r/20180111052902.14409-5-ebiggers3@gmail.com
Fixes: b0b91d18e2e9 ("pipe: fix limit checking in pipe_set_size()")
Acked-by: Willy Tarreau <w@1wt.eu>
Acked-by: Joe Lawrence <joe.lawrence@redhat.com>
Cc: "Luis R . Rodriguez" <mcgrof@kernel.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Mikulas Patocka <mpatocka@redhat.com>
commit 85c2dd5473b2718b4b63e74bfeb1ca876868e11f upstream.
pipe-user-pages-hard and pipe-user-pages-soft are only supposed to apply
to unprivileged users, as documented in both Documentation/sysctl/fs.txt
and the pipe(7) man page.
However, the capabilities are actually only checked when increasing a
pipe's size using F_SETPIPE_SZ, not when creating a new pipe. Therefore,
if pipe-user-pages-hard has been set, the root user can run into it and be
unable to create pipes. Similarly, if pipe-user-pages-soft has been set,
the root user can run into it and have their pipes limited to 1 page each.
Fix this by allowing the privileged override in both cases.
Link: http://lkml.kernel.org/r/20180111052902.14409-4-ebiggers3@gmail.com
Fixes: 759c01142a5d ("pipe: limit the per-user amount of pages allocated in pipes")
Cc: Willy Tarreau <w@1wt.eu>
commit a1be1f3931bfe0a42b46fef77a04593c2b136e7f upstream.
This reverts commit ba62bafe942b ("kernel/relay.c: fix potential memory leak").
This commit introduced a double free bug, because 'chan' is already
freed by the line:
kref_put(&chan->kref, relay_destroy_channel);
This bug was found by syzkaller, using the BLKTRACESETUP ioctl.
Link: http://lkml.kernel.org/r/20180127004759.101823-1-ebiggers3@gmail.com
Fixes: ba62bafe942b ("kernel/relay.c: fix potential memory leak")
Reported-by: syzbot <syzkaller@googlegroups.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Zhouyi Zhou <yizhouzhou@ict.ac.cn>
commit 4f7e988e63e336827f4150de48163bed05d653bd upstream.
This reverts commit 92266d6ef60c ("async: simplify lowest_in_progress()")
which was simply wrong: In the case where domain is NULL, we now use the
wrong offsetof() in the list_first_entry macro, so we don't actually
fetch the ->cookie value, but rather the eight bytes located
sizeof(struct list_head) further into the struct async_entry.
On 64 bit, that's the data member, while on 32 bit, that's a u64 built
from func and data in some order.
I think the bug happens to be harmless in practice: It obviously only
affects callers which pass a NULL domain, and AFAICT the only such
caller is
async_synchronize_full() ->
async_synchronize_full_domain(NULL) ->
async_synchronize_cookie_domain(ASYNC_COOKIE_MAX, NULL)
and the ASYNC_COOKIE_MAX means that in practice we end up waiting for
the async_global_pending list to be empty - but it would break if
somebody happened to pass (void*)-1 as the data element to
async_schedule, and of course also if somebody ever does a
async_synchronize_cookie_domain(, NULL) with a "finite" cookie value.
Maybe the "harmless in practice" means this isn't -stable material. But
I'm not completely confident my quick git grep'ing is enough, and there
might be affected code in one of the earlier kernels that has since been
removed, so I'll leave the decision to the stable guys.
Link: http://lkml.kernel.org/r/20171128104938.3921-1-linux@rasmusvillemoes.dk
Fixes: 92266d6ef60c "async: simplify lowest_in_progress()"
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Adam Wallis <awallis@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit d0290bc20d4739b7a900ae37eb5d4cc3be2b393f upstream.
Commit df04abfd181a ("fs/proc/kcore.c: Add bounce buffer for ktext
data") added a bounce buffer to avoid hardened usercopy checks. Copying
to the bounce buffer was implemented with a simple memcpy() assuming
that it is always valid to read from kernel memory iff the
kern_addr_valid() check passed.
A simple, but pointless, test case like "dd if=/proc/kcore of=/dev/null"
now can easily crash the kernel, since the former execption handling on
invalid kernel addresses now doesn't work anymore.
Also adding a kern_addr_valid() implementation wouldn't help here. Most
architectures simply return 1 here, while a couple implemented a page
table walk to figure out if something is mapped at the address in
question.
With DEBUG_PAGEALLOC active mappings are established and removed all the
time, so that relying on the result of kern_addr_valid() before
executing the memcpy() also doesn't work.
Therefore simply use probe_kernel_read() to copy to the bounce buffer.
This also allows to simplify read_kcore().
At least on s390 this fixes the observed crashes and doesn't introduce
warnings that were removed with df04abfd181a ("fs/proc/kcore.c: Add
bounce buffer for ktext data"), even though the generic
probe_kernel_read() implementation uses uaccess functions.
While looking into this I'm also wondering if kern_addr_valid() could be
completely removed...(?)
Link: http://lkml.kernel.org/r/20171202132739.99971-1-heiko.carstens@de.ibm.com
Fixes: df04abfd181a ("fs/proc/kcore.c: Add bounce buffer for ktext data")
Fixes: f5509cc18daa ("mm: Hardened usercopy")
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
commit 9893b905e743ded332575ca04486bd586c0772f7 upstream.
The XC2028_I2C_FLUSH only needs to be implemented on a few
devices. Others can safely ignore it.
That prevents filling the dmesg with lots of messages like:
dib0700: stk7700ph_xc3028_callback: unknown command 2, arg 0
Fixes: 4d37ece757a8 ("[media] tuner/xc2028: Add I2C flush callback")
Reported-by: Enrico Mioso <mrkiko.rs@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 81742be14b6a90c9fd0ff6eb4218bdf696ad8e46 upstream.
Before this patch, when compiled for arm32, the signal strength
were reported as:
Lock (0x1f) Signal= 4294908.66dBm C/N= 12.79dB
Because of a 32 bit integer overflow. After it, it is properly
reported as:
Lock (0x1f) Signal= -58.64dBm C/N= 12.79dB
Fixes: 0f91c9d6bab9 ("[media] TS2020: Calculate tuner gain correctly")
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 3cd890dbe2a4f14cc44c85bb6cf37e5e22d4dd0e upstream.
A typical code fragment was copied across many dvb-frontend drivers and
causes large stack frames when built with with CONFIG_KASAN on gcc-5/6/7:
drivers/media/dvb-frontends/cxd2841er.c:3225:1: error: the frame size of 3992 bytes is larger than 3072 bytes [-Werror=frame-larger-than=]
drivers/media/dvb-frontends/cxd2841er.c:3404:1: error: the frame size of 3136 bytes is larger than 3072 bytes [-Werror=frame-larger-than=]
drivers/media/dvb-frontends/stv0367.c:3143:1: error: the frame size of 4016 bytes is larger than 3072 bytes [-Werror=frame-larger-than=]
drivers/media/dvb-frontends/stv090x.c:3430:1: error: the frame size of 5312 bytes is larger than 3072 bytes [-Werror=frame-larger-than=]
drivers/media/dvb-frontends/stv090x.c:4248:1: error: the frame size of 4872 bytes is larger than 3072 bytes [-Werror=frame-larger-than=]
gcc-8 now solves this by consolidating the stack slots for the argument
variables, but on older compilers we can get the same behavior by taking
the pointer of a local variable rather than the inline function argument.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715
commit 0be267255cef64e1c58475baa7b25568355a3816 upstream.
When the watchdog device is suspended, its timeout is set to the maximum
value. During resume, the previously set timeout should be restored.
This does not work at the moment.
The suspend function calls
imx2_wdt_set_timeout(wdog, IMX2_WDT_MAX_TIME);
and resume reverts this by calling
imx2_wdt_set_timeout(wdog, wdog->timeout);
However, imx2_wdt_set_timeout() updates wdog->timeout. Therefore,
wdog->timeout is set to IMX2_WDT_MAX_TIME when we enter the resume
function.
Fix this by adding a new function __imx2_wdt_set_timeout() which
only updates the hardware settings. imx2_wdt_set_timeout() now calls
__imx2_wdt_set_timeout() and then saves the new timeout to
wdog->timeout.
During suspend, we call __imx2_wdt_set_timeout() directly so that
wdog->timeout won't be updated and we can restore the previous value
during resume. This approach makes wdog->timeout different from the
actual setting in the hardware which is usually not a good thing.
However, the two differ only while we're suspended and no kernel code is
running, so it should be ok in this case.
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 20a1ea2222e7cbf96e9bf8579362e971491e6aea upstream.
I got the following kernel warning when loading snd-soc-skl module on
Dell Latitude 7270 laptop:
memremap attempted on mixed range 0x0000000000000000 size: 0x0
WARNING: CPU: 0 PID: 484 at kernel/memremap.c:98 memremap+0x8a/0x180
Call Trace:
skl_nhlt_init+0x82/0xf0 [snd_soc_skl]
skl_probe+0x2ee/0x7c0 [snd_soc_skl]
It seems that the machine doesn't support the SKL DSP gives the empty
NHLT entry, and it triggers the warning. For avoiding it, let do the
zero check before calling memremap().
Signed-off-by: Mark Brown <broonie@kernel.org>
commit c66234cfedfc3e6e3b62563a5f2c1562be09a35d upstream.
When restoring registers during runtime resume, we must not write to
I2S_TXDR which is the transmit FIFO as this queues up a sample to be
output and pushes all of the output channels down by one.
This can be demonstrated with the speaker-test utility:
for i in a b c; do speaker-test -c 2 -s 1; done
which should play a test through the left speaker three times but if the
I2S hardware starts runtime suspended the first sample will be played
through the right speaker.
Fix this by marking I2S_TXDR as volatile (which also requires marking it
as readble, even though it technically isn't). This seems to be the
most robust fix, the alternative of giving I2S_TXDR a default value is
more fragile since it does not prevent regcache writing to the register
in all circumstances.
While here, also fix the configuration of I2S_RXDR and I2S_FIFOLR; these
are not writable so they do not suffer from the same problem as I2S_TXDR
but reading from I2S_RXDR does suffer from a similar problem.
Fixes: f0447f6cbb20 ("ASoC: rockchip: i2s: restore register during runtime_suspend/resume cycle", 2016-09-07)
Signed-off-by: John Keeping <john@metanate.com>
commit 58d6b15e9da5042a99c9c30ad725792e4569150e upstream.
cpu_pm_enter() calls the pm notifier chain with CPU_PM_ENTER, then if
there is a failure: CPU_PM_ENTER_FAILED.
When KVM receives CPU_PM_ENTER it calls cpu_hyp_reset() which will
return us to the hyp-stub. If we subsequently get a CPU_PM_ENTER_FAILED,
KVM does nothing, leaving the CPU running with the hyp-stub, at odds
with kvm_arm_hardware_enabled.
Add CPU_PM_ENTER_FAILED as a fallthrough for CPU_PM_EXIT, this reloads
KVM based on kvm_arm_hardware_enabled. This is safe even if CPU_PM_ENTER
never gets as far as KVM, as cpu_hyp_reinit() calls cpu_hyp_reset()
to make sure the hyp-stub is loaded before reloading KVM.
Fixes: 67f691976662 ("arm64: kvm: allows kvm cpu hotplug")
CC: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: James Morse <james.morse@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 6b6977117f50d60455ace86b2d256f6fb4f3de05 upstream.
Consider the following scenario:
1. CPU A calls vmx_deliver_nested_posted_interrupt() to send an IPI
to CPU B via virtual posted-interrupt mechanism.
2. CPU B is currently executing L2 guest.
3. vmx_deliver_nested_posted_interrupt() calls
kvm_vcpu_trigger_posted_interrupt() which will note that
vcpu->mode == IN_GUEST_MODE.
4. Assume that before CPU A sends the physical POSTED_INTR_NESTED_VECTOR
IPI, CPU B exits from L2 to L0 during event-delivery
(valid IDT-vectoring-info).
5. CPU A now sends the physical IPI. The IPI is received in host and
it's handler (smp_kvm_posted_intr_nested_ipi()) does nothing.
6. Assume that before CPU A sets pi_pending=true and KVM_REQ_EVENT,
CPU B continues to run in L0 and reach vcpu_enter_guest(). As
KVM_REQ_EVENT is not set yet, vcpu_enter_guest() will continue and resume
L2 guest.
7. At this point, CPU A sets pi_pending=true and KVM_REQ_EVENT but
it's too late! CPU B already entered L2 and KVM_REQ_EVENT will only be
consumed at next L2 entry!
Another scenario to consider:
2. Assume that before CPU A calls kvm_vcpu_trigger_posted_interrupt(),
CPU B is at L0 and is about to resume into L2. Further assume that it is
in vcpu_enter_guest() after check for KVM_REQ_EVENT.
3. At this point, CPU A calls kvm_vcpu_trigger_posted_interrupt() which
will note that vcpu->mode != IN_GUEST_MODE. Therefore, do nothing and
return false. Then, will set pi_pending=true and KVM_REQ_EVENT.
4. Now CPU B continue and resumes into L2 guest without processing
the posted-interrupt until next L2 entry!
To fix both issues, we just need to change
vmx_deliver_nested_posted_interrupt() to set pi_pending=true and
KVM_REQ_EVENT before calling kvm_vcpu_trigger_posted_interrupt().
It will fix the first scenario by chaging step (6) to note that
KVM_REQ_EVENT and pi_pending=true and therefore process
nested posted-interrupt.
It will fix the second scenario by two possible ways:
1. If kvm_vcpu_trigger_posted_interrupt() is called while CPU B has changed
vcpu->mode to IN_GUEST_MODE, physical IPI will be sent and will be received
when CPU resumes into L2.
2. If kvm_vcpu_trigger_posted_interrupt() is called while CPU B hasn't yet
changed vcpu->mode to IN_GUEST_MODE, then after CPU B will change
vcpu->mode it will call kvm_request_pending() which will return true and
therefore force another round of vcpu_enter_guest() which will note that
KVM_REQ_EVENT and pi_pending=true and therefore process nested
posted-interrupt.
Fixes: 705699a13994 ("KVM: nVMX: Enable nested posted interrupt processing")
Signed-off-by: Liran Alon <liran.alon@oracle.com>
Reviewed-by: Nikita Leshenko <nikita.leshchenko@oracle.com>
Reviewed-by: Krish Sadhukhan <krish.sadhukhan@oracle.com>
[Add kvm_vcpu_kick to also handle the case where L1 doesn't intercept L2 HLT
and L2 executes HLT instruction. - Paolo]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 20e8175d246e9f9deb377f2784b3e7dfb2ad3e86 upstream.
KVM doesn't follow the SMCCC when it comes to unimplemented calls,
and inject an UNDEF instead of returning an error. Since firmware
calls are now used for security mitigation, they are becoming more
common, and the undef is counter productive.
Instead, let's follow the SMCCC which states that -1 must be returned
to the caller when getting an unknown function number.
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit eff84b379089cd8b4e83599639c1f5f6e34ef7bf upstream.
The SHA-512 multibuffer code keeps track of the number of blocks pending
in each lane. The minimum of these values is used to identify the next
lane that will be completed. Unused lanes are set to a large number
(0xFFFFFFFF) so that they don't affect this calculation.
However, it was forgotten to set the lengths to this value in the
initial state, where all lanes are unused. As a result it was possible
for sha512_mb_mgr_get_comp_job_avx2() to select an unused lane, causing
a NULL pointer dereference. Specifically this could happen in the case
where ->update() was passed fewer than SHA512_BLOCK_SIZE bytes of data,
so it then called sha_complete_job() without having actually submitted
any blocks to the multi-buffer code. This hit a NULL pointer
dereference if another task happened to have submitted blocks
concurrently to the same CPU and the flush timer had not yet expired.
Fix this by initializing sha512_mb_mgr->lens correctly.
As usual, this bug was found by syzkaller.
Fixes: 45691e2d9b18 ("crypto: sha512-mb - submit/flush routines for AVX2")
commit 225ece3e7dad4cfc44cca38ce7a3a80f255ea8f1 upstream.
In case DECO0 cannot be acquired - i.e. run_descriptor_deco0() fails
with -ENODEV, caam_probe() enters an endless loop:
ret -ENODEV
-> instantiate_rng
-ENODEV, overwritten by -EAGAIN
ret -EAGAIN
-> caam_probe
-EAGAIN results in endless loop
It turns out the error path in instantiate_rng() is incorrect,
the checks are done in the wrong order.
Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles")
Reported-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Suggested-by: Auer Lukas <lukas.auer@aisec.fraunhofer.de>
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit a1dfb4c48cc1e64eeb7800a27c66a6f7e88d075a upstream.
The 32-bit compat v4l2 ioctl handling is implemented based on its 64-bit
equivalent. It converts 32-bit data structures into its 64-bit
equivalents and needs to provide the data to the 64-bit ioctl in user
space memory which is commonly allocated using
compat_alloc_user_space().
However, due to how that function is implemented, it can only be called
a single time for every syscall invocation.
Supposedly to avoid this limitation, the existing code uses a mix of
memory from the kernel stack and memory allocated through
Under normal circumstances, this would not work, because the 64-bit
ioctl expects all pointers to point to user space memory. As a
workaround, set_fs(KERNEL_DS) is called to temporarily disable this
extra safety check and allow kernel pointers. However, this might
introduce a security vulnerability: The result of the 32-bit to 64-bit
conversion is writeable by user space because the output buffer has been
allocated via compat_alloc_user_space(). A malicious user space process
could then manipulate pointers inside this output buffer, and due to the
previous set_fs(KERNEL_DS) call, functions like get_user() or put_user()
no longer prevent kernel memory access.
The new approach is to pre-calculate the total amount of user space
memory that is needed, allocate it using compat_alloc_user_space() and
then divide up the allocated memory to accommodate all data structures
that need to be converted.
An alternative approach would have been to retain the union type karg
that they allocated on the kernel stack in do_video_ioctl(), copy all
data from user space into karg and then back to user space. However, we
decided against this approach because it does not align with other
compat syscall implementations. Instead, we tried to replicate the
get_user/put_user pairs as found in other places in the kernel:
if (get_user(clipcount, &up->clipcount) ||
put_user(clipcount, &kp->clipcount)) return -EFAULT;
Notes from hans.verkuil@cisco.com:
This patch was taken from:
https://github.com/LineageOS/android_kernel_samsung_apq8084/commit/97b733953c06e4f0398ade18850f0817778255f7
Clearly nobody could be bothered to upstream this patch or at minimum
tell us :-( We only heard about this a week ago.
This patch was rebased and cleaned up. Compared to the original I
also swapped the order of the convert_in_user arguments so that they
matched copy_in_user. It was hard to review otherwise. I also replaced
the ALLOC_USER_SPACE/ALLOC_AND_GET by a normal function.
Fixes: 6b5a9492ca ("v4l: introduce string control support.")
Signed-off-by: Daniel Mentz <danielmentz@google.com>
Co-developed-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit d83a8243aaefe62ace433e4384a4f077bed86acb upstream.
Some ioctls need to copy back the result even if the ioctl returned
an error. However, don't do this for the error code -ENOTTY.
It makes no sense in that cases.
commit 169f24ca68bf0f247d111aef07af00dd3a02ae88 upstream.
There is nothing wrong with using an unknown buffer type. So
stop spamming the kernel log whenever this happens. The kernel
will just return -EINVAL to signal this.
commit a751be5b142ef6bcbbb96d9899516f4d9c8d0ef4 upstream.
put_v4l2_window32() didn't copy back the clip list to userspace.
Drivers can update the clip rectangles, so this should be done.
commit 025a26fa14f8fd55d50ab284a30c016a5be953d0 upstream.
Commit b2787845fb91 ("V4L/DVB (5289): Add support for video output
overlays.") added the field global_alpha to struct v4l2_window but did
not update the compat layer accordingly. This change adds global_alpha
to struct v4l2_window32 and copies the value for global_alpha back and
forth.
commit 273caa260035c03d89ad63d72d8cd3d9e5c5e3f1 upstream.
If the device is of type VFL_TYPE_SUBDEV then vdev->ioctl_ops
is NULL so the 'if (!ops->vidioc_query_ext_ctrl)' check would crash.
Add a test for !ops to the condition.
All sub-devices that have controls will use the control framework,
so they do not have an equivalent to ops->vidioc_query_ext_ctrl.
Returning false if ops is NULL is the correct thing to do here.
Fixes: b8c601e8af ("v4l2-compat-ioctl32.c: fix ctrl_is_pointer")
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit b8c601e8af2d08f733d74defa8465303391bb930 upstream.
ctrl_is_pointer just hardcoded two known string controls, but that
caused problems when using e.g. custom controls that use a pointer
for the payload.
Reimplement this function: it now finds the v4l2_ctrl (if the driver
uses the control framework) or it calls vidioc_query_ext_ctrl (if the
driver implements that directly).
In both cases it can now check if the control is a pointer control
or not.
commit 8ed5a59dcb47a6f76034ee760b36e089f3e82529 upstream.
The struct v4l2_plane32 should set m.userptr as well. The same
happens in v4l2_buffer32 and v4l2-compliance tests for this.
commit 333b1e9f96ce05f7498b581509bb30cde03018bf upstream.
Instead of doing sizeof(struct foo) use sizeof(*up). There even were
cases where 4 * sizeof(__u32) was used instead of sizeof(kp->reserved),
which is very dangerous when the size of the reserved array changes.
commit 486c521510c44a04cd756a9267e7d1e271c8a4ba upstream.
These helper functions do not really help. Move the code to the
__get/put_v4l2_format32 functions.
