commit f66665c09ab489a11ca490d6a82df57cfc1bea3e upstream.
In eCryptfs, we failed to verify that the authentication token keys are
not revoked before dereferencing their payloads, which is problematic
because the payload of a revoked key is NULL. request_key() *does* skip
revoked keys, but there is still a window where the key can be revoked
before we acquire the key semaphore.
Fix it by updating ecryptfs_get_key_payload_data() to return
-EKEYREVOKED if the key payload is NULL. For completeness we check this
for "encrypted" keys as well as "user" keys, although encrypted keys
cannot be revoked currently.
Alternatively we could use key_validate(), but since we'll also need to
fix ecryptfs_get_key_payload_data() to validate the payload length, it
seems appropriate to just check the payload pointer.
Fixes: 237fead61998 ("[PATCH] ecryptfs: fs/Makefile and fs/Kconfig")
Reviewed-by: James Morris <james.l.morris@oracle.com>
Cc: Michael Halcrow <mhalcrow@google.com>
commit fc1111b885437f374ed54aadda44d8b241ebd2a3 upstream.
The device tree nodes all correctly describe the regulators as
syr827 or syr828, but the I2C device id is currently set to the
wildcard value of syr82x in the driver. This causes udev to fail
to match the driver module with the modalias data from sysfs.
Fix this by replacing the I2C device ids with ones that match the
device tree descriptions, with syr827 and syr828. Tested on
Firefly rk3288 board. The syr82x id was not used anywhere.
Fixes: e80c47bd738b (regulator: fan53555: Export I2C module alias information)
Signed-off-by: Guillaume Tucker <guillaume.tucker@collabora.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 1137b5e2529a8f5ca8ee709288ecba3e68044df2 upstream.
An independent security researcher, Mohamed Ghannam, has reported
this vulnerability to Beyond Security's SecuriTeam Secure Disclosure
program.
The xfrm_dump_policy_done function expects xfrm_dump_policy to
have been called at least once or it will crash. This can be
triggered if a dump fails because the target socket's receive
buffer is full.
This patch fixes it by using the cb->start mechanism to ensure that
the initialisation is always done regardless of the buffer situation.
Fixes: 12a169e7d8f4 ("ipsec: Put dumpers on the dump list")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 51e13359cd5ea34acc62c90627603352956380af upstream.
If we try to connect while already connected/connecting, but
this fails, we set ssid_len=0 but leave current_bss hanging,
leading to errors.
Check all of this better, first of all ensuring that we can't
try to connect to a different SSID while connected/ing; ensure
that prev_bssid is set for re-association attempts even in the
case of the driver supporting the connect() method, and don't
reset ssid_len in the failure cases.
While at it, also reset ssid_len while disconnecting unless we
were connected and expect a disconnected event, and warn on a
successful connection without ssid_len being set.
commit e1d2d1329a5722dbecc9c278303fcc4aa01f8790 upstream.
To avoid kernel warning "Unhandled message (68)", ignore the
CMD_FLUSH_QUEUE_REPLY message for now.
As of Leaf v2 firmware version v4.1.844 (2017-02-15), flush tx queue is
synchronous. There is a capability bit indicating whether flushing tx
queue is synchronous or asynchronous.
A proper solution would be to query the device for capabilities. If the
synchronous tx flush capability bit is set, we should wait for
CMD_FLUSH_QUEUE_REPLY message, while flushing the tx queue.
Signed-off-by: Jimmy Assarsson <jimmyassarsson@gmail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 8f65a923e6b628e187d5e791cf49393dd5e8c2f9 upstream.
If the return value from kvaser_usb_send_simple_msg() was non-zero, the
return value from kvaser_usb_flush_queue() was printed in the kernel
warning.
commit 3a379f5b36ae039dfeb6f73316e47ab1af4945df upstream.
Fix loopback mode by setting the right flag and remove presume mode.
Signed-off-by: Gerhard Bertelsmann <info@gerhard-bertelsmann.de>
commit 8b95f4f730cba02ef6febbdc4ca7e55ca045b00e upstream.
refresh_rate was not initialized when program
display gap.
this patch can fix vce ring test failed
when do S3 on Polaris10.
bug: https://bugs.freedesktop.org/show_bug.cgi?id=103102
bug: https://bugzilla.kernel.org/show_bug.cgi?id=196615
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 587c3c9f286cee5c9cac38d28c8ae1875f4ec85b upstream.
Commit 109bade9c625 ("scsi: sg: use standard lists for sg_requests")
introduced an off-by-one error in sg_ioctl(), which was fixed by commit
bd46fc406b30 ("scsi: sg: off by one in sg_ioctl()").
Unfortunately commit 4759df905a47 ("scsi: sg: factor out
sg_fill_request_table()") moved that code, and reintroduced the
bug (perhaps due to a botched rebase). Fix it again.
Fixes: 4759df905a47 ("scsi: sg: factor out sg_fill_request_table()")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
commit ab31fd0ce65ec93828b617123792c1bb7c6dcc42 upstream.
v4.10 commit 6f2ce1c6af37 ("scsi: zfcp: fix rport unblock race with LUN
recovery") extended accessing parent pointer fields of struct
zfcp_erp_action for tracing. If an erp_action has never been enqueued
before, these parent pointer fields are uninitialized and NULL. Examples
are zfcp objects freshly added to the parent object's children list,
before enqueueing their first recovery subsequently. In
zfcp_erp_try_rport_unblock(), we iterate such list. Accessing erp_action
fields can cause a NULL pointer dereference. Since the kernel can read
from lowcore on s390, it does not immediately cause a kernel page
fault. Instead it can cause hangs on trying to acquire the wrong
erp_action->adapter->dbf->rec_lock in zfcp_dbf_rec_action_lvl()
^bogus^
while holding already other locks with IRQs disabled.
Real life example from attaching lots of LUNs in parallel on many CPUs:
crash> bt 17723
PID: 17723 TASK: ... CPU: 25 COMMAND: "zfcperp0.0.1800"
LOWCORE INFO:
-psw : 0x0404300180000000 0x000000000038e424
-function : _raw_spin_lock_wait_flags at 38e424
#0 [fdde8fc90] zfcp_dbf_rec_action_lvl at 3e0004e9862 [zfcp]
#1 [fdde8fce8] zfcp_erp_try_rport_unblock at 3e0004dfddc [zfcp]
#2 [fdde8fd38] zfcp_erp_strategy at 3e0004e0234 [zfcp]
#3 [fdde8fda8] zfcp_erp_thread at 3e0004e0a12 [zfcp]
#4 [fdde8fe60] kthread at 173550
#5 [fdde8feb8] kernel_thread_starter at 10add2
zfcp_adapter
zfcp_port
zfcp_unit <address>, 0x404040d600000000
scsi_device NULL, returning early!
zfcp_scsi_dev.status = 0x40000000
0x40000000 ZFCP_STATUS_COMMON_RUNNING
crash> zfcp_unit <address>
struct zfcp_unit {
erp_action = {
adapter = 0x0,
port = 0x0,
unit = 0x0,
zfcp_erp_action is always fully embedded into its container object. Such
container object is never moved in its object tree (only add or delete).
Hence, erp_action parent pointers can never change.
To fix the issue, initialize the erp_action parent pointers before
adding the erp_action container to any list and thus before it becomes
accessible from outside of its initializing function.
In order to also close the time window between zfcp_erp_setup_act()
memsetting the entire erp_action to zero and setting the parent pointers
again, drop the memset and instead explicitly initialize individually
all erp_action fields except for parent pointers. To be extra careful
not to introduce any other unintended side effect, even keep zeroing the
erp_action fields for list and timer. Also double-check with
WARN_ON_ONCE that erp_action parent pointers never change, so we get to
know when we would deviate from previous behavior.
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
Fixes: 6f2ce1c6af37 ("scsi: zfcp: fix rport unblock race with LUN recovery")
Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com>
commit ea6789980fdaa610d7eb63602c746bf6ec70cd2b upstream.
This fixes CVE-2017-12193.
Fix a case in the assoc_array implementation in which a new leaf is
added that needs to go into a node that happens to be full, where the
existing leaves in that node cluster together at that level to the
exclusion of new leaf.
What needs to happen is that the existing leaves get moved out to a new
node, N1, at level + 1 and the existing node needs replacing with one,
N0, that has pointers to the new leaf and to N1.
The code that tries to do this gets this wrong in two ways:
(1) The pointer that should've pointed from N0 to N1 is set to point
recursively to N0 instead.
(2) The backpointer from N0 needs to be set correctly in the case N0 is
either the root node or reached through a shortcut.
Fix this by removing this path and using the split_node path instead,
which achieves the same end, but in a more general way (thanks to Eric
Biggers for spotting the redundancy).
The problem manifests itself as:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: assoc_array_apply_edit+0x59/0xe5
Fixes: 3cb989501c26 ("Add a generic associative array implementation.")
Reported-and-tested-by: WU Fan <u3536072@connect.hku.hk>
commit a50829479f58416a013a4ccca791336af3c584c7 upstream.
parse_hid_report_descriptor() has a while (i < length) loop, which
only guarantees that there's at least 1 byte in the buffer, but the
loop body can read multiple bytes which causes out-of-bounds access.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Reviewed-by: Andrey Konovalov <andreyknvl@google.com>
commit 57a95b41869b8f0d1949c24df2a9dac1ca7082ee upstream.
ELAN0611 touchpad uses elan_i2c as its driver. It can be found
on Lenovo ideapad 320-15IKB.
So add it to ACPI table to enable the touchpad.
[Ido Adiv <idoad123@gmail.com> reports that the same ACPI ID is used for
Elan touchpad in ideapad 520].
BugLink: https://bugs.launchpad.net/bugs/1723736
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 298d275d4d9bea3524ff4bc76678c140611d8a8d upstream.
In case gntdev_mmap() succeeds only partially in mapping grant pages
it will leave some vital information uninitialized needed later for
cleanup. This will lead to an out of bounds array access when unmapping
the already mapped pages.
So just initialize the data needed for unmapping the pages a little bit
earlier.
Reported-by: Arthur Borsboom <arthurborsboom@gmail.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit c6cdd51404b7ac12dd95173ddfc548c59ecf037f upstream.
Marios Titas running a Haskell program noticed a problem with fuse's
readdirplus: when it is interrupted by a signal, it skips one directory
entry.
The reason is that fuse erronously updates ctx->pos after a failed
dir_emit().
The issue originates from the patch adding readdirplus support.
Reported-by: Jakob Unterwurzacher <jakobunt@gmail.com>
Tested-by: Marios Titas <redneb@gmx.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Fixes: 0b05b18381ee ("fuse: implement NFS-like readdirplus support")
commit c0368e4db4a3e8a3dce40f3f621c06e14c560d79 upstream.
There was an inversion in how the error path in bcm_qspi_probe() is done
which would make us trip over a KASAN use-after-free report. Turns out
that qspi->dev_ids does not get allocated until later in the probe
process. Fix this by introducing a new lable: qspi_resource_err which
takes care of cleaning up the SPI master instance.
Fixes: fa236a7ef240 ("spi: bcm-qspi: Add Broadcom MSPI driver")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit a2b4a79b88b24c49d98d45a06a014ffd22ada1a4 upstream.
The SPI_IOC_MESSAGE() macro references _IOC_SIZEBITS. Add linux/ioctl.h
to make sure this macro is defined. This fixes the following build
failure of lcdproc with the musl libc:
In file included from .../sysroot/usr/include/sys/ioctl.h:7:0,
from hd44780-spi.c:31:
hd44780-spi.c: In function 'spi_transfer':
hd44780-spi.c:89:24: error: '_IOC_SIZEBITS' undeclared (first use in this function)
status = ioctl(p->fd, SPI_IOC_MESSAGE(1), &xfer);
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
commit ac64115a66c18c01745bbd3c47a36b124e5fd8c0 upstream.
The following program causes a kernel oops:
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/kvm.h>
main()
int fd = open("/dev/kvm", O_RDWR);
ioctl(fd, KVM_CHECK_EXTENSION, KVM_CAP_PPC_HTM);
This happens because when using the global KVM fd with
KVM_CHECK_EXTENSION, kvm_vm_ioctl_check_extension() gets
called with a NULL kvm argument, which gets dereferenced
in is_kvmppc_hv_enabled(). Spotted while reading the code.
Let's use the hv_enabled fallback variable, like everywhere
else in this function.
Fixes: 23528bb21ee2 ("KVM: PPC: Introduce KVM_CAP_PPC_HTM")
Signed-off-by: Greg Kurz <groug@kaod.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Reviewed-by: Thomas Huth <thuth@redhat.com>
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
commit b3207c65dfafae27e7c492cb9188c0dc0eeaf3fd upstream.
xhci_stop_device() calls xhci_queue_stop_endpoint() multiple times
without checking the return value. xhci_queue_stop_endpoint() can
return error if the HC is already halted or unable to queue commands.
This can cause a deadlock condition as xhci_stop_device() would
end up waiting indefinitely for a completion for the command that
didn't get queued. Fix this by checking the return value and bailing
out of xhci_stop_device() in case of error. This patch happens to fix
potential memory leaks of the allocated command structures as well.
Fixes: c311e391a7ef ("xhci: rework command timeout and cancellation,")
Signed-off-by: Mayank Rana <mrana@codeaurora.org>
Signed-off-by: Jack Pham <jackp@codeaurora.org>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 6c2838fbdedb9b72a81c931d49e56b229b6cdbca upstream.
sparse warns:
fs/ceph/caps.c:2042:9: warning: context imbalance in 'try_flush_caps' - wrong count at exit
We need to exit this function with the lock unlocked, but a couple of
cases leave it locked.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: "Yan, Zheng" <zyan@redhat.com>
Reviewed-by: Ilya Dryomov <idryomov@gmail.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit f265788c336979090ac80b9ae173aa817c4fe40d upstream.
We have several Dell laptops which use the codec alc236, the headset
mic can't work on these machines. Following the commit 736f20a70, we
add the pin cfg table to make the headset mic work.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 736f20a7060857ff569e9e9586ae6c1204a73e07 upstream.
Add support for ALC236/ALC3204.
Add headset mode support for ALC236/ALC3204.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 692b48258dda7c302e777d7d5f4217244478f1f6 upstream.
Josef reported a HARDIRQ-safe -> HARDIRQ-unsafe lock order detected by
lockdep:
[ 1270.472259] WARNING: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected
[ 1270.472783] 4.14.0-rc1-xfstests-12888-g76833e8 #110 Not tainted
[ 1270.473240] -----------------------------------------------------
[ 1270.473710] kworker/u5:2/5157 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire:
[ 1270.474239] (&(&lock->wait_lock)->rlock){+.+.}, at: [<ffffffff8da253d2>] __mutex_unlock_slowpath+0xa2/0x280
[ 1270.474994]
[ 1270.474994] and this task is already holding:
[ 1270.475440] (&pool->lock/1){-.-.}, at: [<ffffffff8d2992f6>] worker_thread+0x366/0x3c0
[ 1270.476046] which would create a new lock dependency:
[ 1270.476436] (&pool->lock/1){-.-.} -> (&(&lock->wait_lock)->rlock){+.+.}
[ 1270.476949]
[ 1270.476949] but this new dependency connects a HARDIRQ-irq-safe lock:
[ 1270.477553] (&pool->lock/1){-.-.}
[ 1270.488900] to a HARDIRQ-irq-unsafe lock:
[ 1270.489327] (&(&lock->wait_lock)->rlock){+.+.}
[ 1270.494735] Possible interrupt unsafe locking scenario:
[ 1270.494735]
[ 1270.495250] CPU0 CPU1
[ 1270.495600] ---- ----
[ 1270.495947] lock(&(&lock->wait_lock)->rlock);
[ 1270.496295] local_irq_disable();
[ 1270.496753] lock(&pool->lock/1);
[ 1270.497205] lock(&(&lock->wait_lock)->rlock);
[ 1270.497744] <Interrupt>
[ 1270.497948] lock(&pool->lock/1);
, which will cause a irq inversion deadlock if the above lock scenario
happens.
The root cause of this safe -> unsafe lock order is the
mutex_unlock(pool->manager_arb) in manage_workers() with pool->lock
held.
Unlocking mutex while holding an irq spinlock was never safe and this
problem has been around forever but it never got noticed because the
only time the mutex is usually trylocked while holding irqlock making
actual failures very unlikely and lockdep annotation missed the
condition until the recent b9c16a0e1f73 ("locking/mutex: Fix
lockdep_assert_held() fail").
Using mutex for pool->manager_arb has always been a bit of stretch.
It primarily is an mechanism to arbitrate managership between workers
which can easily be done with a pool flag. The only reason it became
a mutex is that pool destruction path wants to exclude parallel
managing operations.
This patch replaces the mutex with a new pool flag POOL_MANAGER_ACTIVE
and make the destruction path wait for the current manager on a wait
queue.
v2: Drop unnecessary flag clearing before pool destruction as
suggested by Boqun.
Reported-by: Josef Bacik <josef@toxicpanda.com>
Reviewed-by: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
commit d124b2c53c7bee6569d2a2d0b18b4a1afde00134 upstream.
When the file /proc/fs/fscache/objects (available with
CONFIG_FSCACHE_OBJECT_LIST=y) is opened, we request a user key with
description "fscache:objlist", then access its payload. However, a
revoked key has a NULL payload, and we failed to check for this.
request_key() *does* skip revoked keys, but there is still a window
where the key can be revoked before we access its payload.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
Fixes: 4fbf4291aa15 ("FS-Cache: Allow the current state of all objects to be dumped")
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
commit d60b5b7854c3d135b869f74fb93eaf63cbb1991a upstream.
When an fscrypt-encrypted file is opened, we request the file's master
key from the keyrings service as a logon key, then access its payload.
However, a revoked key has a NULL payload, and we failed to check for
this. request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fixes: 88bd6ccdcdd6 ("ext4 crypto: add encryption key management facilities")
commit 40214d128e07dd21bb07a8ed6a7fe2f911281ab2 upstream.
The writeback rework in commit fbcc02561359 ("xfs: Introduce
writeback context for writepages") introduced a subtle change in
behavior with regard to the block mapping used across the
->writepages() sequence. The previous xfs_cluster_write() code would
only flush pages up to EOF at the time of the writepage, thus
ensuring that any pages due to file-extending writes would be
handled on a separate cycle and with a new, updated block mapping.
The updated code establishes a block mapping in xfs_writepage_map()
that could extend beyond EOF if the file has post-eof preallocation.
Because we now use the generic writeback infrastructure and pass the
cached mapping to each writepage call, there is no implicit EOF
limit in place. If eofblocks trimming occurs during ->writepages(),
any post-eof portion of the cached mapping becomes invalid. The
eofblocks code has no means to serialize against writeback because
there are no pages associated with post-eof blocks. Therefore if an
eofblocks trim occurs and is followed by a file-extending buffered
write, not only has the mapping become invalid, but we could end up
writing a page to disk based on the invalid mapping.
Consider the following sequence of events:
- A buffered write creates a delalloc extent and post-eof
speculative preallocation.
- Writeback starts and on the first writepage cycle, the delalloc
extent is converted to real blocks (including the post-eof blocks)
and the mapping is cached.
- The file is closed and xfs_release() trims post-eof blocks. The
cached writeback mapping is now invalid.
- Another buffered write appends the file with a delalloc extent.
- The concurrent writeback cycle picks up the just written page
because the writeback range end is LLONG_MAX. xfs_writepage_map()
attributes it to the (now invalid) cached mapping and writes the
data to an incorrect location on disk (and where the file offset is
still backed by a delalloc extent).
This problem is reproduced by xfstests test generic/464, which
triggers racing writes, appends, open/closes and writeback requests.
To address this problem, trim the mapping used during writeback to
within EOF when the mapping is validated. This ensures the mapping
is revalidated for any pages encountered beyond EOF as of the time
the current mapping was cached or last validated.
Reported-by: Eryu Guan <eguan@redhat.com>
Diagnosed-by: Eryu Guan <eguan@redhat.com>
Signed-off-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit 793d7dbe6d82a50b9d14bf992b9eaacb70a11ce6 upstream.
Recently we've had warnings arise from the vm handing us pages
without bufferheads attached to them. This should not ever occur
in XFS, but we don't defend against it properly if it does. The only
place where we remove bufferheads from a page is in
xfs_vm_releasepage(), but we can't tell the difference here between
"page is dirty so don't release" and "page is dirty but is being
invalidated so release it".
In some places that are invalidating pages ask for pages to be
released and follow up afterward calling ->releasepage by checking
whether the page was dirty and then aborting the invalidation. This
is a possible vector for releasing buffers from a page but then
leaving it in the mapping, so we really do need to avoid dirty pages
in xfs_vm_releasepage().
To differentiate between invalidated pages and normal pages, we need
to clear the page dirty flag when invalidating the pages. This can
be done through xfs_vm_invalidatepage(), and will result
xfs_vm_releasepage() seeing the page as clean which matches the
bufferhead state on the page after calling block_invalidatepage().
Hence we can re-add the page dirty check in xfs_vm_releasepage to
catch the case where we might be releasing a page that is actually
dirty and so should not have the bufferheads on it removed. This
will remove one possible vector of "dirty page with no bufferheads"
and so help narrow down the search for the root cause of that
problem.
Signed-Off-By: Dave Chinner <dchinner@redhat.com>
commit 93e8befc17f6d6ea92b0aee3741ceac8bca4590f upstream.
Jason reported that a corrupted filesystem failed to replay
the log with a metadata block out of bounds warning:
XFS (dm-2): _xfs_buf_find: Block out of range: block 0x80270fff8, EOFS 0x9c40000
_xfs_buf_find() and xfs_btree_get_bufs() return NULL if
that happens, and then when xfs_alloc_fix_freelist() calls
xfs_trans_binval() on that NULL bp, we oops with:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000f8
We don't handle _xfs_buf_find errors very well, every
caller higher up the stack gets to guess at why it failed.
But we should at least handle it somehow, so return
EFSCORRUPTED here.
Reported-by: Jason L Tibbitts III <tibbs@math.uh.edu>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit f35c5e10c6ed6ba52a8dd8573924a80b6a02f03f upstream.
xfs_attr3_root_inactive() walks the attr fork tree to invalidate the
associated blocks. xfs_attr3_node_inactive() recursively descends
from internal blocks to leaf blocks, caching block address values
along the way to revisit parent blocks, locate the next entry and
descend down that branch of the tree.
The code that attempts to reread the parent block is unsafe because
it assumes that the local xfs_da_node_entry pointer remains valid
after an xfs_trans_brelse() and re-read of the parent buffer. Under
heavy memory pressure, it is possible that the buffer has been
reclaimed and reallocated by the time the parent block is reread.
This means that 'btree' can point to an invalid memory address, lead
to a random/garbage value for child_fsb and cause the subsequent
read of the attr fork to go off the rails and return a NULL buffer
for an attr fork offset that is most likely not allocated.
Note that this problem can be manufactured by setting
XFS_ATTR_BTREE_REF to 0 to prevent LRU caching of attr buffers,
creating a file with a multi-level attr fork and removing it to
trigger inactivation.
To address this problem, reinit the node/btree pointers to the
parent buffer after it has been re-read. This ensures btree points
to a valid record and allows the walk to proceed.
commit 67f2ffe31d1a683170c2ba0ecc643e42a5fdd397 upstream.
If we get ENOSPC half way through setting the ACL, the inode mode
can still be changed even though the ACL does not exist. Reorder the
operation to only change the mode of the inode if the ACL is set
correctly.
Whilst this does not fix the problem with crash consistency (that requires
attribute addition to be a deferred op) it does prevent ENOSPC and other
non-fatal errors setting an xattr to be handled sanely.
This fixes xfstests generic/449.
Reviewed-by: Brian Foster <bfoster@redhat.com>
commit bb9c2e5433250f5b477035dc478314f8e6dd5e36 upstream.
Various utility functions and interfaces that iterate internal
devices try to reference the realtime device even when RT support is
not compiled into the kernel.
Make sure this code is excluded from the CONFIG_XFS_RT=n build,
and where appropriate stub functions to return fatal errors if
they ever get called when RT support is not present.
commit 20413e37d71befd02b5846acdaf5e2564dd1c38e upstream.
Prevent kmemcheck from throwing warnings about reading uninitialised
memory when formatting inodes into the incore log buffer. There are
several issues here - we don't always log all the fields in the
inode log format item, and we never log the inode the
di_next_unlinked field.
In the case of the inode log format item, this is exacerbated
by the old xfs_inode_log_format structure padding issue. Hence make
the padded, 64 bit aligned version of the structure the one we always
use for formatting the log and get rid of the 64 bit variant. This
means we'll always log the 64-bit version and so recovery only needs
to convert from the unpadded 32 bit version from older 32 bit
kernels.
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
commit e12199f85d0ad1b04ce6c425ad93cd847fe930bb upstream.
If we got two AIO writes into a COW area the second one might not have any
COW extents left to convert. Handle that case gracefully instead of
triggering an assert or accessing beyond the bounds of the extent list.
commit 52bfcdd7adbc26639bc7b2356ab9a3f5dad68ad6 upstream.
Since the CoW fork exists as a secondary data structure to the data
fork, we must always swap cow forks during swapext. We also need to
swap the extent counts and reset the cowblocks tags.
commit 842f6e9f786226c58fcbd5ef80eadca72fdfe652 upstream.
My previous patch: d3a304b6292168b83b45d624784f973fdc1ca674 check for
XFS_LI_FAILED flag xfs_iflush done, so the failed item can be properly
resubmitted.
In the loop scanning other inodes being completed, it should check the
current item for the XFS_LI_FAILED, and not the initial one.
The state of the initial inode is checked after the loop ends
Kudos to Eric for catching this.
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
commit 9789dd9e1d939232e8ff4c50ef8e75aa6781b3fb upstream.
We call __xfs_ag_resv_init to make a per-AG reservation for each AG.
This makes the reservation per-AG, not per-filesystem. Therefore, it
is incorrect to adjust m_ag_max_usable for each AG. Adjust it only
when we're reserving AG 0's blocks so that we only do it once per fs.
commit ee70daaba82d70766d0723b743d9fdeb3b06102a upstream.
Since commit d531d91d6990 ("xfs: always use unwritten extents for
direct I/O writes"), we start allocating unwritten extents for all
direct writes to allow appending aio in XFS.
But for dio writes that could extend file size we update the in-core
inode size first, then convert the unwritten extents to real
allocations at dio completion time in xfs_dio_write_end_io(). Thus a
racing direct read could see the new i_size and find the unwritten
extents first and read zeros instead of actual data, if the direct
writer also takes a shared iolock.
Fix it by updating the in-core inode size after the unwritten extent
conversion. To do this, introduce a new boolean argument to
xfs_iomap_write_unwritten() to tell if we want to update in-core
i_size or not.
Suggested-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Eryu Guan <eguan@redhat.com>
[hch: backported to the old direct I/O code before Linux 4.10]
commit d20a5e3851969fa685f118a80e4df670255a4e8d upstream.
The 'did_zero' param of xfs_zero_range() was not passed to
iomap_zero_range() correctly. This was introduced by commit
7bb41db3ea16 ("xfs: handle 64-bit length in xfs_iozero"), and found
by code inspection.
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
commit e150dcd459e1b441eaf08f341a986f04e61bf3b8 upstream.
Use the %pS instead of the %pF printk format specifier for printing symbols
from direct addresses. This is needed for the ia64, ppc64 and parisc64
architectures.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 3af423b03435c81036fa710623d3ae92fbe346a3 upstream.
When we perform an finsert/fcollapse operation, cancel all the CoW
extents for the affected file offset range so that they don't end up
pointing to the wrong blocks.
Reported-by: Amir Goldstein <amir73il@gmail.com>
commit cc6f77710a6de6210f9feda7cd53e2f5ee7a7e69 upstream.
If we have speculative cow preallocations hanging around in the cow
fork, don't let a truncate operation clear the reflink flag because if
we do then there's a chance we'll forget to free those extents when we
destroy the incore inode.
[Fixes upstream in a much larger set of patches that are not worth backporting
to 4.9 - gregkh]
When the space available before start of reading (cached_write_sz)
is the same as the host required space (pending_sz), we need to
still signal host.
Fixes: 433e19cf33d3 ("Drivers: hv: vmbus: finally fix hv_need_to_signal_on_read()")
Signed-off-by: John Starks <jon.Starks@microsoft.com>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
commit 68a1fdbbf8bd3378325e45c19e167a165f9ffc3a upstream.
The ASN.1 parser does not necessarily set the sinfo field,
this patch prevents a NULL pointer dereference on broken
input.
Fixes: 99db44350672 ("PKCS#7: Appropriately restrict authenticated attributes and content type")
Signed-off-by: Eric Sesterhenn <eric.sesterhenn@x41-dsec.de>
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream.
Currently, when passed a key that already exists, add_key() will call the
key's ->update() method if such exists. But this is heavily broken in the
case where the key is uninstantiated because it doesn't call
__key_instantiate_and_link(). Consequently, it doesn't do most of the
things that are supposed to happen when the key is instantiated, such as
setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and
awakening tasks waiting on it, and incrementing key->user->nikeys.
It also never takes key_construction_mutex, which means that
->instantiate() can run concurrently with ->update() on the same key. In
the case of the "user" and "logon" key types this causes a memory leak, at
best. Maybe even worse, the ->update() methods of the "encrypted" and
"trusted" key types actually just dereference a NULL pointer when passed an
uninstantiated key.
Change key_create_or_update() to wait interruptibly for the key to finish
construction before continuing.
This patch only affects *uninstantiated* keys. For now we still allow a
negatively instantiated key to be updated (thereby positively
instantiating it), although that's broken too (the next patch fixes it)
and I'm not sure that anyone actually uses that functionality either.
Here is a simple reproducer for the bug using the "encrypted" key type
(requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug
pertained to more than just the "encrypted" key type:
#include <stdlib.h>
#include <unistd.h>
#include <keyutils.h>
int main(void)
int ringid = keyctl_join_session_keyring(NULL);
if (fork()) {
for (;;) {
const char payload[] = "update user:foo 32";
usleep(rand() % 10000);
add_key("encrypted", "desc", payload, sizeof(payload), ringid);
keyctl_clear(ringid);
} else {
for (;;)
request_key("encrypted", "desc", "callout_info", ringid);
It causes:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: encrypted_update+0xb0/0x170
PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0
PREEMPT SMP
CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff8a467a39a340 task.stack: ffffb15c40770000
RIP: 0010:encrypted_update+0xb0/0x170
RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000
RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303
RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17
R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f
FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000
CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0
Call Trace:
key_create_or_update+0x2bc/0x460
SyS_add_key+0x10c/0x1d0
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x7f5d7f211259
RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259
RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04
RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004
R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868
R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000
Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b
RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8
cc: Eric Biggers <ebiggers@google.com>
commit 192cabd6a296cbc57b3d8c05c4c89d87fc102506 upstream.
digsig_verify() requests a user key, then accesses its payload.
Fixes: 051dbb918c7f ("crypto: digital signature verification support")
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream.
A key of type "encrypted" references a "master key" which is used to
encrypt and decrypt the encrypted key's payload. However, when we
accessed the master key's payload, we failed to handle the case where
the master key has been revoked, which sets the payload pointer to NULL.
Note that request_key() *does* skip revoked keys, but there is still a
This was an issue for master keys of type "user" only. Master keys can
also be of type "trusted", but those cannot be revoked.
Fixes: 7e70cb497850 ("keys: add new key-type encrypted")
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: David Safford <safford@us.ibm.com>
commit 723f2828a98c8ca19842042f418fb30dd8cfc0f7 upstream.
Blacklist Broadwell X model 79 for late loading due to an erratum.
Acked-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/20171018111225.25635-1-bp@alien8.de
