commit 9276717b9e297a62d1151a43d1cd286213f68eb7 upstream.
Most importantly, solve a crash where %llu was used to format signed
numbers. This would cause a buffer overflow when reading sysfs
writeback_rate_debug, as only 20 bytes were allocated for this and
%llu writes 20 characters plus a null.
Always use the units mechanism rather than having different output
paths for simplicity.
Also, correct problems with display output where 1.10 was a larger
number than 1.09, by multiplying by 10 and then dividing by 1024 instead
of dividing by 100. (Remainders of >= 1000 would print as .10).
Minor changes: Always display the decimal point instead of trying to
omit it based on number of digits shown. Decide what units to use
based on 1000 as a threshold, not 1024 (in other words, always print
at most 3 digits before the decimal point).
Signed-off-by: Michael Lyle <mlyle@lyle.org>
Reported-by: Dmitry Yu Okunev <dyokunev@ut.mephi.ru>
Acked-by: Kent Overstreet <kent.overstreet@gmail.com>
Reviewed-by: Coly Li <colyli@suse.de>
commit 9baf30972b5568d8b5bc8b3c46a6ec5b58100463 upstream.
gc and write-back get raced (see the email "bcache get stucked" I sended
before):
gc thread write-back thread
| |bch_writeback_thread()
|bch_gc_thread() |
| |==>read_dirty()
|==>bch_btree_gc() |
|==>btree_root() //get btree root |
| //node write locker |
|==>bch_btree_gc_root() |
| |==>read_dirty_submit()
| |==>write_dirty()
| |==>continue_at(cl,
| | write_dirty_finish,
| | system_wq);
| |==>write_dirty_finish()//excute
| | //in system_wq
| |==>bch_btree_insert()
| |==>bch_btree_map_leaf_nodes()
| |==>__bch_btree_map_nodes()
| |==>btree_root //try to get btree
| | //root node read
| | //lock
| |-----stuck here
|==>bch_btree_set_root()
|==>bch_journal_meta()
|==>bch_journal()
|==>journal_try_write()
|==>journal_write_unlocked() //journal_full(&c->journal)
| //condition satisfied
|==>continue_at(cl, journal_write, system_wq); //try to excute
| //journal_write in system_wq
| //but work queue is excuting
| //write_dirty_finish()
|==>closure_sync(); //wait journal_write execute
| //over and wake up gc,
|-------------stuck here
|==>release root node write locker
This patch alloc a separate work-queue for write-back thread to avoid such
race.
(Commit log re-organized by Coly Li to pass checkpatch.pl checking)
Signed-off-by: Tang Junhui <tang.junhui@zte.com.cn>
Acked-by: Coly Li <colyli@suse.de>
commit 77fa100f27475d08a569b9d51c17722130f089e7 upstream.
If you encounter any errors in bch_cached_dev_attach it will return
a negative error code. The variable 'v' which stores the result is
unsigned, thus user space sees a very large value returned for bytes
written which can cause incorrect user space behavior. Utilize 1
signed variable to use throughout the function to preserve error return
capability.
Signed-off-by: Tony Asleson <tasleson@redhat.com>
commit a8394090a9129b40f9d90dcb7f4a49d60c727ca6 upstream.
__update_write_rate() uses a Proportion-Differentiation Controller
algorithm to control writeback rate. A dirty target number is used in
this PD controller to control writeback rate. A larger target number
will make the writeback rate smaller, on the versus, a smaller target
number will make the writeback rate larger.
bcache uses the following steps to calculate the target number,
1) cache_sectors = all-buckets-of-cache-set * buckets-size
2) cache_dirty_target = cache_sectors * cached-device-writeback_percent
3) target = cache_dirty_target *
(sectors-of-cached-device/sectors-of-all-cached-devices-of-this-cache-set)
The calculation at step 1) for cache_sectors is incorrect, which does
not consider dirty blocks occupied by flash only volume.
A flash only volume can be took as a bcache device without cached
device. All data sectors allocated for it are persistent on cache device
and marked dirty, they are not touched by bcache writeback and garbage
collection code. So data blocks of flash only volume should be ignore
when calculating cache_sectors of cache set.
Current code does not subtract dirty sectors of flash only volume, which
results a larger target number from the above 3 steps. And in sequence
the cache device's writeback rate is smaller then a correct value,
writeback speed is slower on all cached devices.
This patch fixes the incorrect slower writeback rate by subtracting
dirty sectors of flash only volumes in __update_writeback_rate().
(Commit log composed by Coly Li to pass checkpatch.pl checking)
commit 69daf03adef5f7bc13e0ac86b4b8007df1767aab upstream.
Since bypassed IOs use no bucket, so do not subtract sectors_to_gc to
trigger gc thread.
Signed-off-by: tang.junhui <tang.junhui@zte.com.cn>
Reviewed-by: Eric Wheeler <bcache@linux.ewheeler.net>
commit 4b758df21ee7081ab41448d21d60367efaa625b3 upstream.
If blkdev_get_by_path() in register_bcache() fails, we try to lookup the
block device using lookup_bdev() to detect which situation we are in to
properly report error. However we never drop the reference returned to
us from lookup_bdev(). Fix that.
commit 175206cf9ab63161dec74d9cd7f9992e062491f5 upstream.
bcache uses a Proportion-Differentiation Controller algorithm to control
writeback rate to cached devices. In the PD controller algorithm, dirty
stripes of thin flash device should not be counted in, because flash only
volumes never write back dirty data.
Currently dirty stripe counter for thin flash device is not initialized
when the thin flash device starts. Which means the following calculation
in PD controller will reference an undefined dirty stripes number, and
all cached devices attached to the same cache set where the thin flash
device lies on may have an inaccurate writeback rate.
This patch calles bch_sectors_dirty_init() in flash_dev_run(), to
correctly initialize dirty stripe counter when the thin flash device
starts to run. This patch also does following parameter data type change,
-void bch_sectors_dirty_init(struct cached_dev *dc);
+void bch_sectors_dirty_init(struct bcache_device *);
to call this function conveniently in flash_dev_run().
(Commit log is composed by Coly Li)
commit 9e14de1077e9c34f141cf98bdba60cdd5193d962 upstream.
When the devfreq_add_device fails to register deivce, the memory
leak of devfreq instance happen. So, this patch fix the memory
leak issue. Before freeing the devfreq instance checks whether
devfreq instance is NULL or not because the device_unregister()
frees the devfreq instance when jumping to the 'err_init'.
It is to prevent the duplicate the kfee(devfreq).
Fixes: ac4b281176a5 ("PM / devfreq: fix duplicated kfree on devfreq pointer")
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
commit 7e09f7d5c790278ab98e5f2c22307ebe8ad6e8ba upstream.
The size of uvc_control_mapping is user controlled leading to a
potential heap overflow in the uvc driver. This adds a check to verify
the user provided size fits within the bounds of the defined buffer
size.
Originally-from: Richard Simmons <rssimmo@amazon.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 9c7ba1d7634cef490b85bc64c4091ff004821bfd upstream.
Certain syscalls like recvmmsg support 64 bit timespec values for the
X32 ABI. The helper function compat_put_timespec converts a timespec
value to a 32 bit or 64 bit value depending on what ABI is used. The
v4l2 compat layer, however, is not designed to support 64 bit timespec
values and always uses 32 bit values. Hence, compat_put_timespec must
not be used.
Without this patch, user space will be provided with bad timestamp
values from the VIDIOC_DQEVENT ioctl. Also, fields of the struct
v4l2_event32 that come immediately after timestamp get overwritten,
namely the field named id.
Fixes: 81993e81a994 ("compat: Get rid of (get|put)_compat_time(val|spec)")
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Cc: Tiffany Lin <tiffany.lin@mediatek.com>
Cc: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Cc: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Daniel Mentz <danielmentz@google.com>
commit 60f07c8ec5fae06c23e9fd7bab67dabce92b3414 upstream.
The order in __tlb_flush_mm_lazy is to flush TLB first and then clear
the mm->context.flush_mm bit. This can lead to missed flushes as the
bit can be set anytime, the order needs to be the other way aronud.
But this leads to a different race, __tlb_flush_mm_lazy may be called
on two CPUs concurrently. If mm->context.flush_mm is cleared first then
another CPU can bypass __tlb_flush_mm_lazy although the first CPU has
not done the flush yet. In a virtualized environment the time until the
flush is finally completed can be arbitrarily long.
Add a spinlock to serialize __tlb_flush_mm_lazy and use the function
in finish_arch_post_lock_switch as well.
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
commit b3e5dc45fd1ec2aa1de6b80008f9295eb17e0659 upstream.
The local TLB flushing code keeps an additional mask in the mm.context,
the cpu_attach_mask. At the time a global flush of an address space is
done the cpu_attach_mask is copied to the mm_cpumask in order to avoid
future global flushes in case the mm is used by a single CPU only after
the flush.
Trouble is that the reset of the mm_cpumask is racy against the detach
of an mm address space by switch_mm. The current order is first the
global TLB flush and then the copy of the cpu_attach_mask to the
mm_cpumask. The order needs to be the other way around.
commit 3ef0c7a730de0bae03d86c19570af764fa3c4445 upstream.
As we want to remove spin_unlock_wait() and replace it with explicit
spin_lock()/spin_unlock() calls, we can use this to simplify the
locking.
In addition:
- Reading nf_conntrack_locks_all needs ACQUIRE memory ordering.
- The new code avoids the backwards loop.
Only slightly tested, I did not manage to trigger calls to
nf_conntrack_all_lock().
V2: With improved comments, to clearly show how the barriers
pair.
Fixes: b16c29191dc8 ("netfilter: nf_conntrack: use safer way to lock all buckets")
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: netfilter-devel@vger.kernel.org
commit 7612b3b28c0b900dcbcdf5e9b9747cc20a1e2455 upstream.
When a power fault occurs, the power controller sets Power Fault Detected
in the Slot Status register, and pciehp_isr() queues an INT_POWER_FAULT
event to handle it.
It also clears Power Fault Detected, but since nothing has yet changed to
correct the power fault, the power controller will likely set it again
immediately, which may cause an infinite loop when pcie_isr() rechecks
Slot Status.
Fix that by masking off Power Fault Detected from new events if the driver
hasn't seen the power fault clear from the previous handling attempt.
Fixes: fad214b0aa72 ("PCI: pciehp: Process all hotplug events before looking for new ones")
Signed-off-by: Keith Busch <keith.busch@intel.com>
[bhelgaas: changelog, pull test out and add comment]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Mayurkumar Patel <mayurkumar.patel@intel.com>
commit 48b79a14505349a29b3e20f03619ada9b33c4b17 upstream.
An SHPC may generate MSIs to notify software about slot or controller
events (SHPC spec r1.0, sec 4.7). A PCI device can only generate an MSI if
it has bus mastering enabled.
Enable bus mastering if the bridge contains an SHPC that uses MSI for event
notifications.
Signed-off-by: Aleksandr Bezzubikov <zuban32s@gmail.com>
[bhelgaas: changelog]
Reviewed-by: Marcel Apfelbaum <marcel@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
commit 1ee55a8f7f6b7ca4c0c59e0b4b4e3584a085c2d3 upstream.
I recently came upon a scenario where I would get a double fault
machine check exception tiriggered by a kernel module.
However the ensuing crash stacktrace (ksym lookup) was not working
correctly.
Turns out that machine check auto-disables MMU while modules are allocated
in kernel vaddr spapce.
This patch re-enables the MMU before start printing the stacktrace
making stacktracing of modules work upon a fatal exception.
Signed-off-by: Jose Abreu <joabreu@synopsys.com>
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[vgupta: moved code into low level handler to avoid in 2 places]
commit 170b3b1050e28d1ba0700e262f0899ffa4fccc52 upstream.
Currently trace_clock timestamps are applied to both regular and max
buffers only for global trace. For instance trace, trace_clock
timestamps are applied only to regular buffer. But, regular and max
buffers can be swapped, for example, following a snapshot. So, for
instance trace, bad timestamps can be seen following a snapshot.
Let's apply trace_clock timestamps to instance max buffer as well.
Link: http://lkml.kernel.org/r/ebdb168d0be042dcdf51f81e696b17fabe3609c1.1504642143.git.tom.zanussi@linux.intel.com
Fixes: 277ba0446 ("tracing: Add interface to allow multiple trace buffers")
Signed-off-by: Baohong Liu <baohong.liu@intel.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 3d9622c12c8873911f4cc0ccdabd0362c2fca06b upstream.
trace_printk() uses 4 buffers, one for each context (normal, softirq, irq
and NMI), such that it does not need to worry about one context preempting
the other. There's a nesting counter that gets incremented to figure out
which buffer to use. If the context gets preempted by another context which
calls trace_printk() it will increment the counter and use the next buffer,
and restore the counter when it is finished.
The problem is that gcc may optimize the modification of the buffer nesting
counter and it may not be incremented in memory before the buffer is used.
If this happens, and the context gets interrupted by another context, it
could pick the same buffer and corrupt the one that is being used.
Compiler barriers need to be added after the nesting variable is incremented
and before it is decremented to prevent usage of the context buffers by more
than one context at the same time.
Fixes: e2ace00117 ("tracing: Choose static tp_printk buffer by explicit nesting count")
Hat-tip-to: Peter Zijlstra <peterz@infradead.org>
commit edb096e00724f02db5f6ec7900f3bbd465c6c76f upstream.
If function tracing is disabled by the user via the function-trace option or
the proc sysctl file, and a ftrace_ops that was allocated on the heap is
unregistered, then the shutdown code exits out without doing the proper
clean up. This was found via kmemleak and running the ftrace selftests, as
one of the tests unregisters with function tracing disabled.
# cat kmemleak
unreferenced object 0xffffffffa0020000 (size 4096):
comm "swapper/0", pid 1, jiffies 4294668889 (age 569.209s)
hex dump (first 32 bytes):
55 ff 74 24 10 55 48 89 e5 ff 74 24 18 55 48 89 U.t$.UH...t$.UH.
e5 48 81 ec a8 00 00 00 48 89 44 24 50 48 89 4c .H......H.D$PH.L
backtrace:
[<ffffffff81d64665>] kmemleak_vmalloc+0x85/0xf0
[<ffffffff81355631>] __vmalloc_node_range+0x281/0x3e0
[<ffffffff8109697f>] module_alloc+0x4f/0x90
[<ffffffff81091170>] arch_ftrace_update_trampoline+0x160/0x420
[<ffffffff81249947>] ftrace_startup+0xe7/0x300
[<ffffffff81249bd2>] register_ftrace_function+0x72/0x90
[<ffffffff81263786>] trace_selftest_ops+0x204/0x397
[<ffffffff82bb8971>] trace_selftest_startup_function+0x394/0x624
[<ffffffff81263a75>] run_tracer_selftest+0x15c/0x1d7
[<ffffffff82bb83f1>] init_trace_selftests+0x75/0x192
[<ffffffff81002230>] do_one_initcall+0x90/0x1e2
[<ffffffff82b7d620>] kernel_init_freeable+0x350/0x3fe
[<ffffffff81d61ec3>] kernel_init+0x13/0x122
[<ffffffff81d72c6a>] ret_from_fork+0x2a/0x40
[<ffffffffffffffff>] 0xffffffffffffffff
Fixes: 12cce594fa ("ftrace/x86: Allow !CONFIG_PREEMPT dynamic ops to use allocated trampolines")
commit 46320a6acc4fb58f04bcf78c4c942cc43b20f986 upstream.
In the second iteration of trace_selftest_ops(), the error goto label is
wrong in the case where trace_selftest_test_global_cnt is off. In the
case of error, it leaks the dynamic ops that was allocated.
Fixes: 95950c2e ("ftrace: Add self-tests for multiple function trace users")
commit e6f77540c067b48dee10f1e33678415bfcc89017 upstream.
The value of "size" comes from the user. When we add "start + size" it
could lead to an integer overflow bug.
It means we vmalloc() a lot more memory than we had intended. I believe
that on 64 bit systems vmalloc() can succeed even if we ask it to
allocate huge 4GB buffers. So we would get memory corruption and likely
a crash when we call ha->isp_ops->write_optrom() and ->read_optrom().
Only root can trigger this bug.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=194061
Fixes: b7cc176c9eb3 ("[SCSI] qla2xxx: Allow region-based flash-part accesses.")
Reported-by: shqking <shqking@gmail.com>
commit 6e98095f8fb6d98da34c4e6c34e69e7c638d79c0 upstream.
Fix incorrect second argument for wait_event_timeout()
Fixes: c4a9b538ab2a ("qla2xxx: Allow vref count to timeout on vport delete.")
Signed-off-by: Joe Carnuccio <joe.carnuccio@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
commit 3e0097499839e0fe3af380410eababe5a47c4cf9 upstream.
When calling SG_GET_REQUEST_TABLE ioctl only a half-filled table is
returned; the remaining part will then contain stale kernel memory
information. This patch zeroes out the entire table to avoid this
issue.
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit 4759df905a474d245752c9dc94288e779b8734dd upstream.
Factor out sg_fill_request_table() for better readability.
[mkp: typos, applied by hand]
commit bd46fc406b30d1db1aff8dabaff8d18bb423fdcf upstream.
If "val" is SG_MAX_QUEUE then we are one element beyond the end of the
"rinfo" array so the > should be >=.
Fixes: 109bade9c625 ("scsi: sg: use standard lists for sg_requests")
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
commit 109bade9c625c89bb5ea753aaa1a0a97e6fbb548 upstream.
'Sg_request' is using a private list implementation; convert it to
standard lists.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 136e57bf43dc4babbfb8783abbf707d483cacbe3 upstream.
Unused.
commit 0208eeaa650c5c866a3242201678a19e6dc4a14e upstream.
When storvsc is sending I/O to Hyper-v, it may allocate a bigger buffer
descriptor for large data payload that can't fit into a pre-allocated
buffer descriptor. This bigger buffer is freed on return path.
If I/O request to Hyper-v fails due to ring buffer busy, the storvsc
allocated buffer descriptor should also be freed.
[mkp: applied by hand]
Fixes: be0cf6ca301c ("scsi: storvsc: Set the tablesize based on the information given by the host")
Signed-off-by: Long Li <longli@microsoft.com>
MFI_STAT_WRONG_STATE in case adapter is dead
commit eb3fe263a48b0d27b229c213929c4cb3b1b39a0f upstream.
After a kill adapter, since the cmd_status is not set, the IOCTLs will
be hung in driver resulting in application hang. Set cmd_status
MFI_STAT_WRONG_STATE when completing pended IOCTLs.
Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com>
Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
commit 91b3d9f0069c8307d0b3a4c6843b65a439183318 upstream.
commit e636a7a430f41efb0ff2727960ce61ef9f8f6769 upstream.
Setting resetwaittime to 0 during a FW fault will result in driver not
calling the OCR.
commit 5d4a3d0a2ff23799b956e5962b886287614e7fad upstream.
Complements debugging aspects of the otherwise functionally complete
v3.17 commit 9cb78c16f5da ("scsi: use 64-bit LUNs").
While I don't have access to a target exporting 3 or 4 level LUNs,
I did test it by explicitly attaching a non-existent fake 4 level LUN
by means of zfcp sysfs attribute "unit_add".
In order to see corresponding trace records of otherwise successful
events, we had to increase the trace level of area SCSI and HBA to 6.
$ echo 6 > /sys/kernel/debug/s390dbf/zfcp_0.0.1880_scsi/level
$ echo 6 > /sys/kernel/debug/s390dbf/zfcp_0.0.1880_hba/level
$ echo 0x4011402240334044 > \
/sys/bus/ccw/drivers/zfcp/0.0.1880/0x50050763031bd327/unit_add
Example output formatted by an updated zfcpdbf from the s390-tools
package interspersed with kernel messages at scsi_logging_level=4605:
Timestamp : ...
Area : REC
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : scsla_1
LUN : 0x4011402240334044
WWPN : 0x50050763031bd327
D_ID : 0x00......
Adapter status : 0x5400050b
Port status : 0x54000001
LUN status : 0x41000000
Ready count : 0x00000001
Running count : 0x00000000
ERP want : 0x01
ERP need : 0x01
scsi 2:0:0:4630896905707208721: scsi scan: INQUIRY pass 1 length 36
scsi 2:0:0:4630896905707208721: scsi scan: INQUIRY successful with code 0x0
Timestamp : ...
Area : HBA
Subarea : 00
Level : 6
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : fs_norm
Request ID : 0x<inquiry2-req-id>
Request status : 0x00000010
FSF cmnd : 0x00000001
FSF sequence no: 0x...
FSF issued : ...
FSF stat : 0x00000000
FSF stat qual : 00000000 00000000 00000000 00000000
Prot stat : 0x00000001
Prot stat qual : ........ ........ 00000000 00000000
Port handle : 0x...
LUN handle : 0x...
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 6
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : rsl_nor
SCSI ID : 0x00000000
SCSI LUN : 0x40224011
SCSI LUN high : 0x40444033 <=======================
SCSI result : 0x00000000
SCSI retries : 0x00
SCSI allowed : 0x03
SCSI scribble : 0x<inquiry2-req-id>
SCSI opcode : 12000000 a4000000 00000000 00000000
FCP rsp inf cod: 0x00
FCP rsp IU : 00000000 00000000 00000000 00000000
00000000 00000000
scsi 2:0:0:4630896905707208721: scsi scan: INQUIRY pass 2 length 164
scsi 2:0:0:4630896905707208721: scsi scan: peripheral device type of 31, \
no device added
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
Fixes: 9cb78c16f5da ("scsi: use 64-bit LUNs")
Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com>
Reviewed-by: Jens Remus <jremus@linux.vnet.ibm.com>
Signed-off-by: Benjamin Block <bblock@linux.vnet.ibm.com>
response
commit fdb7cee3b9e3c561502e58137a837341f10cbf8b upstream.
At the default trace level, we only trace unsuccessful events including
FSF responses.
zfcp_dbf_hba_fsf_response() only used protocol status and FSF status to
decide on an unsuccessful response. However, this is only one of multiple
possible sources determining a failed struct zfcp_fsf_req.
An FSF request can also "fail" if its response runs into an ERP timeout
or if it gets dismissed because a higher level recovery was triggered
[trace tags "erscf_1" or "erscf_2" in zfcp_erp_strategy_check_fsfreq()].
FSF requests with ERP timeout are:
FSF_QTCB_EXCHANGE_CONFIG_DATA, FSF_QTCB_EXCHANGE_PORT_DATA,
FSF_QTCB_OPEN_PORT_WITH_DID or FSF_QTCB_CLOSE_PORT or
FSF_QTCB_CLOSE_PHYSICAL_PORT for target ports,
FSF_QTCB_OPEN_LUN, FSF_QTCB_CLOSE_LUN.
One example is slow queue processing which can cause follow-on errors,
e.g. FSF_PORT_ALREADY_OPEN after FSF_QTCB_OPEN_PORT_WITH_DID timed out.
In order to see the root cause, we need to see late responses even if the
channel presented them successfully with FSF_PROT_GOOD and FSF_GOOD.
Example trace records formatted with zfcpdbf from the s390-tools package:
Timestamp : ...
Area : REC
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : ...
Record ID : 1
Tag : fcegpf1
LUN : 0xffffffffffffffff
WWPN : 0x<WWPN>
D_ID : 0x00<D_ID>
Port status : 0x41200000
LUN status : 0x00000000
Running count : 0x...
ERP want : 0x02 ZFCP_ERP_ACTION_REOPEN_PORT
ERP need : 0x02 ZFCP_ERP_ACTION_REOPEN_PORT
Timestamp : ... 30 seconds later
Area : REC
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : ...
Record ID : 2
Tag : erscf_2
WWPN : 0x<WWPN>
D_ID : 0x00<D_ID>
Request ID : 0x<request_ID>
ERP status : 0x10000000 ZFCP_STATUS_ERP_TIMEDOUT
ERP step : 0x0800 ZFCP_ERP_STEP_PORT_OPENING
ERP action : 0x02 ZFCP_ERP_ACTION_REOPEN_PORT
ERP count : 0x00
Timestamp : ... later than previous record
Area : HBA
Subarea : 00
Level : 5 > default level => 3 <= default level
Exception : -
CPU ID : 00
Caller : ...
Record ID : 1
Tag : fs_qtcb => fs_rerr
Request status : 0x00001010 ZFCP_STATUS_FSFREQ_DISMISSED
| ZFCP_STATUS_FSFREQ_CLEANUP
FSF cmnd : 0x00000005
FSF issued : ... > 30 seconds ago
FSF stat : 0x00000000 FSF_GOOD
Prot stat : 0x00000001 FSF_PROT_GOOD
Prot stat qual : 00000000 00000000 00000000 00000000
Port handle : 0x...
LUN handle : 0x00000000
QTCB log length: ...
QTCB log info : ...
In case of problems detecting that new responses are waiting on the input
queue, we sooner or later trigger adapter recovery due to an FSF request
timeout (trace tag "fsrth_1").
FSF requests with FSF request timeout are:
typically FSF_QTCB_ABORT_FCP_CMND; but theoretically also
FSF_QTCB_EXCHANGE_CONFIG_DATA or FSF_QTCB_EXCHANGE_PORT_DATA via sysfs,
FSF_QTCB_OPEN_PORT_WITH_DID or FSF_QTCB_CLOSE_PORT for WKA ports,
FSF_QTCB_FCP_CMND for task management function (LUN / target reset).
One or more pending requests can meanwhile have FSF_PROT_GOOD and FSF_GOOD
because the channel filled in the response via DMA into the request's QTCB.
In a theroretical case, inject code can create an erroneous FSF request
on purpose. If data router is enabled, it uses deferred error reporting.
A READ SCSI command can succeed with FSF_PROT_GOOD, FSF_GOOD, and
SAM_STAT_GOOD. But on writing the read data to host memory via DMA,
it can still fail, e.g. if an intentionally wrong scatter list does not
provide enough space. Rather than getting an unsuccessful response,
we get a QDIO activate check which in turn triggers adapter recovery.
Timestamp : ...
Area : HBA
Subarea : 00
Level : 6 > default level => 3 <= default level
Exception : -
CPU ID : ..
Caller : ...
Record ID : 1
Tag : fs_norm => fs_rerr
Request ID : 0x<request_ID2>
FSF issued : ...
Port handle : 0x...
LUN handle : 0x...
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 3
Exception : -
CPU ID : ..
Caller : ...
Record ID : 1
Tag : rsl_err
SCSI ID : 0x...
SCSI LUN : 0x...
SCSI result : 0x000e0000 DID_TRANSPORT_DISRUPTED
SCSI retries : 0x00
SCSI allowed : 0x05
SCSI scribble : 0x<request_ID2>
SCSI opcode : 28... Read(10)
^^ SAM_STAT_GOOD
00000000 00000000
Only with luck in both above cases, we could see a follow-on trace record
of an unsuccesful event following a successful but late FSF response with
FSF_PROT_GOOD and FSF_GOOD. Typically this was the case for I/O requests
resulting in a SCSI trace record "rsl_err" with DID_TRANSPORT_DISRUPTED
[On ZFCP_STATUS_FSFREQ_DISMISSED, zfcp_fsf_protstatus_eval() sets
ZFCP_STATUS_FSFREQ_ERROR seen by the request handler functions as failure].
However, the reason for this follow-on trace was invisible because the
corresponding HBA trace record was missing at the default trace level
(by default hidden records with tags "fs_norm", "fs_qtcb", or "fs_open").
On adapter recovery, after we had shut down the QDIO queues, we perform
unsuccessful pseudo completions with flag ZFCP_STATUS_FSFREQ_DISMISSED
for each pending FSF request in zfcp_fsf_req_dismiss_all().
In order to find the root cause, we need to see all pseudo responses even
if the channel presented them successfully with FSF_PROT_GOOD and FSF_GOOD.
Therefore, check zfcp_fsf_req.status for ZFCP_STATUS_FSFREQ_DISMISSED
or ZFCP_STATUS_FSFREQ_ERROR and trace with a new tag "fs_rerr".
It does not matter that there are numerous places which set
ZFCP_STATUS_FSFREQ_ERROR after the location where we trace an FSF response
early. These cases are based on protocol status != FSF_PROT_GOOD or
== FSF_PROT_FSF_STATUS_PRESENTED and are thus already traced by default
as trace tag "fs_perr" or "fs_ferr" respectively.
NB: The trace record with tag "fssrh_1" for status read buffers on dismiss
all remains. zfcp_fsf_req_complete() handles this and returns early.
All other FSF request types are handled separately and as described above.
Fixes: 8a36e4532ea1 ("[SCSI] zfcp: enhancement of zfcp debug features")
Fixes: 2e261af84cdb ("[SCSI] zfcp: Only collect FSF/HBA debug data for matching trace levels")
commit 12c3e5754c8022a4f2fd1e9f00d19e99ee0d3cc1 upstream.
If the FCP_RSP UI has optional parts (FCP_SNS_INFO or FCP_RSP_INFO) and
thus does not fit into the fsp_rsp field built into a SCSI trace record,
trace the full FCP_RSP UI with all optional parts as payload record
instead of just FCP_SNS_INFO as payload and
a 1 byte RSP_INFO_CODE part of FCP_RSP_INFO built into the SCSI record.
That way we would also get the full FCP_SNS_INFO in case a
target would ever send more than
min(SCSI_SENSE_BUFFERSIZE==96, ZFCP_DBF_PAY_MAX_REC==256)==96.
The mandatory part of FCP_RSP IU is only 24 bytes.
PAYload costs at least one full PAY record of 256 bytes anyway.
We cap to the hardware response size which is only FSF_FCP_RSP_SIZE==128.
So we can just put the whole FCP_RSP IU with any optional parts into
PAYload similarly as we do for SAN PAY since v4.9 commit aceeffbb59bb
("zfcp: trace full payload of all SAN records (req,resp,iels)").
This does not cause any additional trace records wasting memory.
Decoded trace records were confusing because they showed a hard-coded
sense data length of 96 even if the FCP_RSP_IU field FCP_SNS_LEN showed
actually less.
Since the same commit, we set pl_len for SAN traces to the full length of a
request/response even if we cap the corresponding trace.
In contrast, here for SCSI traces we set pl_len to the pre-computed
length of FCP_RSP IU considering SNS_LEN or RSP_LEN if valid.
Nonetheless we trace a hardcoded payload of length FSF_FCP_RSP_SIZE==128
if there were optional parts.
This makes it easier for the zfcpdbf tool to format only the relevant
part of the long FCP_RSP UI buffer. And any trailing information is still
available in the payload trace record just in case.
Rename the payload record tag from "fcp_sns" to "fcp_riu" to make the new
content explicit to zfcpdbf which can then pick a suitable field name such
as "FCP rsp IU all:" instead of "Sense info :"
Also, the same zfcpdbf can still be backwards compatible with "fcp_sns".
Old example trace record before this fix, formatted with the tool zfcpdbf
from s390-tools:
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 3
Exception : -
CPU id : ..
Caller : 0x...
Record id : 1
Tag : rsl_err
Request id : 0x<request_id>
SCSI ID : 0x...
SCSI LUN : 0x...
SCSI result : 0x00000002
SCSI retries : 0x00
SCSI allowed : 0x05
SCSI scribble : 0x<request_id>
SCSI opcode : 00000000 00000000 00000000 00000000
FCP rsp IU : 00000000 00000000 00000202 00000000
^^==FCP_SNS_LEN_VALID
00000020 00000000
^^^^^^^^==FCP_SNS_LEN==32
Sense len : 96 <==min(SCSI_SENSE_BUFFERSIZE,ZFCP_DBF_PAY_MAX_REC)
Sense info : 70000600 00000018 00000000 29000000
00000400 00000000 00000000 00000000
00000000 00000000 00000000 00000000<==superfluous
New example trace records with this fix:
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 3
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : rsl_err
Request ID : 0x<request_id>
SCSI ID : 0x...
SCSI LUN : 0x...
SCSI retries : 0x00
SCSI allowed : 0x03
SCSI opcode : a30c0112 00000000 02000000 00000000
FCP rsp IU : 00000000 00000000 00000a02 00000200
00000020 00000000
FCP rsp IU len : 56
FCP rsp IU all : 00000000 00000000 00000a02 00000200
^^=FCP_RESID_UNDER|FCP_SNS_LEN_VALID
00000020 00000000 70000500 00000018
00000000 240000cb 00011100 00000000
00000000 00000000
^^^^^^^^^^^^^^^^^==FCP_SNS_INFO
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : lr_okay
SCSI ID : 0x...
SCSI LUN : 0x...
SCSI retries : 0x00
SCSI allowed : 0x05
SCSI opcode : <CDB of unrelated SCSI command passed to eh handler>
FCP rsp IU : 00000000 00000000 00000100 00000000
00000000 00000008
FCP rsp IU len : 32
FCP rsp IU all : 00000000 00000000 00000100 00000000
^^==FCP_RSP_LEN_VALID
00000000 00000008 00000000 00000000
^^^^^^^^==FCP_RSP_LEN
^^^^^^^^^^^^^^^^^==FCP_RSP_INFO
Fixes: 250a1352b95e ("[SCSI] zfcp: Redesign of the debug tracing for SCSI records.")
commit 1a5d999ebfc7bfe28deb48931bb57faa8e4102b6 upstream.
For problem determination we need to see that we were in scsi_eh
as well as whether and why we were successful or not.
The following commits introduced new early returns without adding
a trace record:
v2.6.35 commit a1dbfddd02d2
("[SCSI] zfcp: Pass return code from fc_block_scsi_eh to scsi eh")
on fc_block_scsi_eh() returning != 0 which is FAST_IO_FAIL,
v2.6.30 commit 63caf367e1c9
("[SCSI] zfcp: Improve reliability of SCSI eh handlers in zfcp")
on not having gotten an FSF request after the maximum number of retry
attempts and thus could not issue a TMF and has to return FAILED.
Fixes: a1dbfddd02d2 ("[SCSI] zfcp: Pass return code from fc_block_scsi_eh to scsi eh")
Fixes: 63caf367e1c9 ("[SCSI] zfcp: Improve reliability of SCSI eh handlers in zfcp")
commit 9fe5d2b2fd30aa8c7827ec62cbbe6d30df4fe3e3 upstream.
Without this fix we get SCSI trace records on task management functions
which cannot be correlated to HBA trace records because all fields
related to the FSF request are empty (zero).
Also, the FCP_RSP_IU is missing as well as any sense data if available.
This was caused by v2.6.14 commit 8a36e4532ea1 ("[SCSI] zfcp: enhancement
of zfcp debug features") introducing trace records for TMFs but
hard coding NULL for a possibly existing TMF FSF request.
The scsi_cmnd scribble is also zero or unrelated for the TMF request
so it also could not lookup a suitable FSF request from there.
A broken example trace record formatted with zfcpdbf from the s390-tools
package:
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : lr_fail
Request ID : 0x0000000000000000
^^^^^^^^^^^^^^^^ no correlation to HBA record
SCSI ID : 0x<scsitarget>
SCSI LUN : 0x<scsilun>
SCSI retries : 0x00
SCSI allowed : 0x05
SCSI scribble : 0x0000000000000000
SCSI opcode : 2a000017 3bb80000 08000000 00000000
^^ no TMF response
00000000 00000000
^^^^^^^^^^^^^^^^^ no interesting FCP_RSP_IU
Sense len : ...
^^^^^^^^^^^^^^^^^^^^ no sense data length
Sense info : ...
^^^^^^^^^^^^^^^^^^^^ no sense data content, even if present
There are some true cases where we really do not have an FSF request:
"rsl_fai" from zfcp_dbf_scsi_fail_send() called for early
returns / completions in zfcp_scsi_queuecommand(),
"abrt_or", "abrt_bl", "abrt_ru", "abrt_ar" from
zfcp_scsi_eh_abort_handler() where we did not get as far,
"lr_nres", "tr_nres" from zfcp_task_mgmt_function() where we're
successful and do not need to do anything because adapter stopped.
For these cases it's correct to pass NULL for fsf_req to _zfcp_dbf_scsi().
commit 975171b4461be296a35e83ebd748946b81cf0635 upstream.
v4.9 commit aceeffbb59bb ("zfcp: trace full payload of all SAN records
(req,resp,iels)") fixed trace data loss of 2.6.38 commit 2c55b750a884
("[SCSI] zfcp: Redesign of the debug tracing for SAN records.")
necessary for problem determination, e.g. to see the
currently active zone set during automatic port scan.
While it already saves space by not dumping any empty residual entries
of the large successful GPN_FT response (4 pages), there are seldom cases
where the GPN_FT response is unsuccessful and likely does not have
FC_NS_FID_LAST set in fp_flags so we did not cap the trace record.
We typically see such case for an initiator WWPN, which is not in any zone.
Cap unsuccessful responses to at least the actual basic CT_IU response
plus whatever fits the SAN trace record built-in "payload" buffer
just in case there's trailing information
of which we would at least see the existence and its beginning.
In order not to erroneously cap successful responses, we need to swap
calling the trace function and setting the CT / ELS status to success (0).
Example trace record pair formatted with zfcpdbf:
Timestamp : ...
Area : SAN
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : fssct_1
Destination ID : 0x00fffffc
SAN req short : 01000000 fc020000 01720ffc 00000000
00000008
SAN req length : 20
Timestamp : ...
Area : SAN
Subarea : 00
Level : 1
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 2
Tag : fsscth2
SAN resp short : 01000000 fc020000 80010000 00090700
00000000 00000000 00000000 00000000 [trailing info]
SAN resp length: 16384
San resp info : 01000000 fc020000 80010000 00090700
The fix saves all but one of the previously associated 64 PAYload trace
record chunks of size 256 bytes each.
Fixes: aceeffbb59bb ("zfcp: trace full payload of all SAN records (req,resp,iels)")
Fixes: 2c55b750a884 ("[SCSI] zfcp: Redesign of the debug tracing for SAN records.")
commit a099b7b1fc1f0418ab8d79ecf98153e1e134656e upstream.
Up until now zfcp would just ignore the FCP_RESID_OVER flag in the FCP
response IU. When this flag is set, it is possible, in regards to the
FCP standard, that the storage-server processes the command normally, up
to the point where data is missing and simply ignores those.
In this case no CHECK CONDITION would be set, and because we ignored the
FCP_RESID_OVER flag we resulted in at least a data loss or even
-corruption as a follow-up error, depending on how the
applications/layers on top behave. To prevent this, we now set the
host-byte of the corresponding scsi_cmnd to DID_ERROR.
Other storage-behaviors, where the same condition results in a CHECK
CONDITION set in the answer, don't need to be changed as they are
handled in the mid-layer already.
Following is an example trace record decoded with zfcpdbf from the
s390-tools package. We forcefully injected a fc_dl which is one byte too
small:
Timestamp : ...
Area : SCSI
Subarea : 00
Level : 3
Exception : -
CPU ID : ..
Caller : 0x...
Record ID : 1
Tag : rsl_err
Request ID : 0x...
SCSI ID : 0x...
SCSI LUN : 0x...
SCSI result : 0x00070000
^^DID_ERROR
SCSI retries : 0x..
SCSI allowed : 0x..
SCSI scribble : 0x...
SCSI opcode : 2a000000 00000000 08000000 00000000
FCP rsp IU : 00000000 00000000 00000400 00000001
^^fr_flags==FCP_RESID_OVER
^^fr_status==SAM_STAT_GOOD
^^^^^^^^fr_resid
00000000 00000000
As of now, we don't actively handle to possibility that a response IU
has both flags - FCP_RESID_OVER and FCP_RESID_UNDER - set at once.
Reported-by: Luke M. Hopkins <lmhopkin@us.ibm.com>
Reviewed-by: Steffen Maier <maier@linux.vnet.ibm.com>
Fixes: 553448f6c483 ("[SCSI] zfcp: Message cleanup")
Fixes: ea127f975424 ("[PATCH] s390 (7/7): zfcp host adapter.") (tglx/history.git)
commit 71b8e45da51a7b64a23378221c0a5868bd79da4f upstream.
Since commit db007fc5e20c ("[SCSI] Command protection operation"),
scsi_eh_prep_cmnd() saves scmd->prot_op and temporarily resets it to
SCSI_PROT_NORMAL.
Other FCP LLDDs such as qla2xxx and lpfc shield their queuecommand()
to only access any of scsi_prot_sg...() if
(scsi_get_prot_op(cmd) != SCSI_PROT_NORMAL).
Do the same thing for zfcp, which introduced DIX support with
commit ef3eb71d8ba4 ("[SCSI] zfcp: Introduce experimental support for
DIF/DIX").
Otherwise, TUR SCSI commands as part of scsi_eh likely fail in zfcp,
because the regular SCSI command with DIX protection data, that scsi_eh
re-uses in scsi_send_eh_cmnd(), of course still has
(scsi_prot_sg_count() != 0) and so zfcp sends down bogus requests to the
FCP channel hardware.
This causes scsi_eh_test_devices() to have (finish_cmds == 0)
[not SCSI device is online or not scsi_eh_tur() failed]
so regular SCSI commands, that caused / were affected by scsi_eh,
are moved to work_q and scsi_eh_test_devices() itself returns false.
In turn, it unnecessarily escalates in our case in scsi_eh_ready_devs()
beyond host reset to finally scsi_eh_offline_sdevs()
which sets affected SCSI devices offline with the following kernel message:
"kernel: sd H:0:T:L: Device offlined - not ready after error recovery"
Fixes: ef3eb71d8ba4 ("[SCSI] zfcp: Introduce experimental support for DIF/DIX")
commit 5fbd545cd3fd311ea1d6e8be4cedddd0ee5684c7 upstream.
Ensure that the members of struct skd_msg_buf have been transferred
to the PCIe adapter before the doorbell is triggered. This patch
avoids that I/O fails sporadically and that the following error
message is reported:
(skd0:STM000196603:[0000:00:09.0]): Completion mismatch comp_id=0x0000 skreq=0x0400 new=0x0000
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
commit 7277cc67b3916eed47558c64f9c9c0de00a35cda upstream.
Since put_disk() triggers a disk_release() call and since that
last function calls blk_put_queue() if disk->queue != NULL, clear
the disk->queue pointer before calling put_disk(). This avoids
that unloading the skd kernel module triggers the following
use-after-free:
WARNING: CPU: 8 PID: 297 at lib/refcount.c:128 refcount_sub_and_test+0x70/0x80
refcount_t: underflow; use-after-free.
CPU: 8 PID: 297 Comm: kworker/8:1 Not tainted 4.11.10-300.fc26.x86_64 #1
Workqueue: events work_for_cpu_fn
Call Trace:
dump_stack+0x63/0x84
__warn+0xcb/0xf0
warn_slowpath_fmt+0x5a/0x80
refcount_dec_and_test+0x11/0x20
kobject_put+0x1f/0x50
blk_put_queue+0x15/0x20
disk_release+0xae/0xf0
device_release+0x32/0x90
kobject_release+0x67/0x170
kobject_put+0x2b/0x50
put_disk+0x17/0x20
skd_destruct+0x5c/0x890 [skd]
skd_pci_probe+0x124d/0x13a0 [skd]
local_pci_probe+0x42/0xa0
work_for_cpu_fn+0x14/0x20
process_one_work+0x19e/0x470
worker_thread+0x1dc/0x4a0
kthread+0x125/0x140
ret_from_fork+0x25/0x30
commit e8a27f836f165c26f867ece7f31eb5c811692319 upstream.
bitmap_resize() does not work for file-backed bitmaps.
The buffer_heads are allocated and initialized when
the bitmap is read from the file, but resize doesn't
read from the file, it loads from the internal bitmap.
When it comes time to write the new bitmap, the bh is
non-existent and we crash.
The common case when growing an array involves making the array larger,
and that normally means making the bitmap larger. Doing
that inside the kernel is possible, but would need more code.
It is probably easier to require people who use file-backed
bitmaps to remove them and re-add after a reshape.
So this patch disables the resizing of arrays which have
file-backed bitmaps. This is better than crashing.
Reported-by: Zhilong Liu <zlliu@suse.com>
Fixes: d60b479d177a ("md/bitmap: add bitmap_resize function to allow bitmap resizing.")
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit 4ddd56b003f251091a67c15ae3fe4a5c5c5e390a upstream.
Calling blk_start_queue() from interrupt context with the queue
lock held and without disabling IRQs, as the skd driver does, is
safe. This patch avoids that loading the skd driver triggers the
following warning:
WARNING: CPU: 11 PID: 1348 at block/blk-core.c:283 blk_start_queue+0x84/0xa0
RIP: 0010:blk_start_queue+0x84/0xa0
Call Trace:
skd_unquiesce_dev+0x12a/0x1d0 [skd]
skd_complete_internal+0x1e7/0x5a0 [skd]
skd_complete_other+0xc2/0xd0 [skd]
skd_isr_completion_posted.isra.30+0x2a5/0x470 [skd]
skd_isr+0x14f/0x180 [skd]
irq_forced_thread_fn+0x2a/0x70
irq_thread+0x144/0x1a0
kthread+0x125/0x140
Fixes: commit a038e2536472 ("[PATCH] blk_start_queue() must be called with irq disabled - add warning")
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Andrew Morton <akpm@osdl.org>
commit f9effe925039cf54489b5c04e0d40073bb3a123d upstream.
Anton noticed that if we fault part way through emulating an unaligned
instruction, we don't update the DAR to reflect that.
The DAR value is eventually reported back to userspace as the address
in the SEGV signal, and if userspace is using that value to demand
fault then it can be confused by us not setting the value correctly.
This patch is ugly as hell, but is intended to be the minimal fix and
back ports easily.
Reviewed-by: Paul Mackerras <paulus@ozlabs.org>
commit 95f1fda47c9d8738f858c3861add7bf0a36a7c0b upstream.
Quota does not get enabled for read-only mounts if filesystem
has quota feature, so that quotas cannot updated during orphan
cleanup, which will lead to quota inconsistency.
This patch turn on quotas during orphan cleanup for this case,
make sure quotas can be updated correctly.
Reported-by: Jan Kara <jack@suse.cz>
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit b0a5a9589decd07db755d6a8d9c0910d96ff7992 upstream.
Current ext4 quota should always "usage enabled" if the
quota feautre is enabled. But in ext4_orphan_cleanup(), it
turn quotas off directly (used for the older journaled
quota), so we cannot turn it on again via "quotaon" unless
umount and remount ext4.
Simple reproduce:
mkfs.ext4 -O project,quota /dev/vdb1
mount -o prjquota /dev/vdb1 /mnt
chattr -p 123 /mnt
chattr +P /mnt
touch /mnt/aa /mnt/bb
exec 100<>/mnt/aa
rm -f /mnt/aa
sync
echo c > /proc/sysrq-trigger
#reboot and mount
#query status
quotaon -Ppv /dev/vdb1
#output
quotaon: Cannot find mountpoint for device /dev/vdb1
quotaon: No correct mountpoint specified.
This patch add check for journaled quotas to avoid incorrect
quotaoff when ext4 has quota feautre.
Fixed differently upstream as commit 2d97591ef43d ("crypto: af_alg - consolidation of duplicate code")
The SGL is MAX_SGL_ENTS + 1 in size. The last SG entry is used for the
chaining and is properly updated with the sg_chain invocation. During
the filling-in of the initial SG entries, sg_mark_end is called for each
SG entry. This is appropriate as long as no additional SGL is chained
with the current SGL. However, when a new SGL is chained and the last
SG entry is updated with sg_chain, the last but one entry still contains
the end marker from the sg_mark_end. This end marker must be removed as
otherwise a walk of the chained SGLs will cause a NULL pointer
dereference at the last but one SG entry, because sg_next will return
NULL.
The patch only applies to all kernels up to and including 4.13. The
patch 2d97591ef43d0587be22ad1b0d758d6df4999a0b added to 4.14-rc1
introduced a complete new code base which addresses this bug in
a different way. Yet, that patch is too invasive for stable kernels
and was therefore not marked for stable.
Fixes: 8ff590903d5fc ("crypto: algif_skcipher - User-space interface for skcipher operations")
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit e652399edba99a5497f0d80f240c9075d3b43493 upstream.
Version 5 CCPs have some new requirements for XTS-AES: the type field
must be specified, and the key requires 512 bits, with each part
occupying 256 bits and padded with zeroes.
Signed-off-by: Gary R Hook <ghook@amd.com>
commit 2cfa58259f4b65b33ebe8f167019a1f89c6c3289 upstream.
Implement fused multiply-add with correct accuracy.
Fused multiply-add operation has better accuracy than respective
sequential execution of multiply and add operations applied on the
same inputs. This is because accuracy errors accumulate in latter
case.
This patch implements fused multiply-add with the same accuracy
as it is implemented in hardware, using 128-bit intermediate
calculations.
One test case example (raw bits) that this patch fixes:
MADDF.D fd,fs,ft:
fd = 0x00000ca000000000
fs = ft = 0x3f40624dd2f1a9fc
Fixes: e24c3bec3e8e ("MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction")
Fixes: 83d43305a1df ("MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction")
Signed-off-by: Douglas Leung <douglas.leung@imgtec.com>
Signed-off-by: Miodrag Dinic <miodrag.dinic@imgtec.com>
Signed-off-by: Goran Ferenc <goran.ferenc@imgtec.com>
Signed-off-by: Aleksandar Markovic <aleksandar.markovic@imgtec.com>
Cc: Douglas Leung <douglas.leung@imgtec.com>
Cc: Bo Hu <bohu@google.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jin Qian <jinqian@google.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Petar Jovanovic <petar.jovanovic@imgtec.com>
Cc: Raghu Gandham <raghu.gandham@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/16891/
