commit b31ff3cdf540110da4572e3e29bd172087af65cc upstream.
If using a kernel with CONFIG_XFS_RT=y and we set the RHINHERIT flag on
a directory in a filesystem that does not have a realtime device and
create a new file in that directory, it gets marked as a real time file.
When data is written and a fsync is issued, the filesystem attempts to
flush a non-existent rt device during the fsync process.
This results in a crash dereferencing a null buftarg pointer in
xfs_blkdev_issue_flush():
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: xfs_blkdev_issue_flush+0xd/0x20
Call Trace:
xfs_file_fsync+0x188/0x1c0
vfs_fsync_range+0x3b/0xa0
do_fsync+0x3d/0x70
SyS_fsync+0x10/0x20
do_syscall_64+0x4d/0xb0
entry_SYSCALL64_slow_path+0x25/0x25
Setting RT inode flags does not require special privileges so any
unprivileged user can cause this oops to occur. To reproduce, confirm
kernel is compiled with CONFIG_XFS_RT=y and run:
# mkfs.xfs -f /dev/pmem0
# mount /dev/pmem0 /mnt/test
# mkdir /mnt/test/foo
# xfs_io -c 'chattr +t' /mnt/test/foo
# xfs_io -f -c 'pwrite 0 5m' -c fsync /mnt/test/foo/bar
Or just run xfstests with MKFS_OPTIONS="-d rtinherit=1" and wait.
Kernels built with CONFIG_XFS_RT=n are not exposed to this bug.
Fixes: f538d4da8d52 ("[XFS] write barrier support")
Signed-off-by: Richard Wareing <rwareing@fb.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit e973b1a5999e57da677ab50da5f5479fdc0f0c31 upstream.
Since commit 18290650b1c8 ("NFS: Move buffered I/O locking into
nfs_file_write()") nfs_file_write() has not flushed the correct byte
range during synchronous writes. generic_write_sync() expects that
iocb->ki_pos points to the right edge of the range rather than the
left edge.
To replicate the problem, open a file with O_DSYNC, have the client
write at increasing offsets, and then print the successful offsets.
Block port 2049 partway through that sequence, and observe that the
client application indicates successful writes in advance of what the
server received.
Fixes: 18290650b1c8 ("NFS: Move buffered I/O locking into nfs_file_write()")
Signed-off-by: Jacob Strauss <jsstraus@amazon.com>
Signed-off-by: Tarang Gupta <tarangg@amazon.com>
Tested-by: Tarang Gupta <tarangg@amazon.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 196639ebbe63a037fe9a80669140bd292d8bcd80 upstream.
The writeback code wants to send a commit after processing the pages,
which is why we want to delay releasing the struct path until after
that's done.
Also, the layout code expects that we do not free the inode before
we've put the layout segments in pnfs_writehdr_free() and
pnfs_readhdr_free()
Fixes: 919e3bd9a875 ("NFS: Ensure we commit after writeback is complete")
Fixes: 4714fb51fd03 ("nfs: remove pgio_header refcount, related cleanup")
commit 746a272e44141af24a02f6c9b0f65f4c4598ed42 upstream.
When there's a fatal signal pending, arm's do_page_fault()
implementation returns 0. The intent is that we'll return to the
faulting userspace instruction, delivering the signal on the way.
However, if we take a fatal signal during fixing up a uaccess, this
results in a return to the faulting kernel instruction, which will be
instantly retried, resulting in the same fault being taken forever. As
the task never reaches userspace, the signal is not delivered, and the
task is left unkillable. While the task is stuck in this state, it can
inhibit the forward progress of the system.
To avoid this, we must ensure that when a fatal signal is pending, we
apply any necessary fixup for a faulting kernel instruction. Thus we
will return to an error path, and it is up to that code to make forward
progress towards delivering the fatal signal.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Steve Capper <steve.capper@arm.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 95696d292e204073433ed2ef3ff4d3d8f42a8248 upstream.
The GIC-500 integrated in the Armada-37xx SoCs is compliant with
the GICv3 architecture, and thus provides a maintenance interrupt
that is required for hypervisors to function correctly.
With the interrupt provided in the DT, KVM now works as it should.
Tested on an Espressobin system.
Fixes: adbc3695d9e4 ("arm64: dts: add the Marvell Armada 3700 family and a development board")
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit e860d2c904d1a9f38a24eb44c9f34b8f915a6ea3 upstream.
Validate the output buffer length for L2CAP config requests and responses
to avoid overflowing the stack buffer used for building the option blocks.
Signed-off-by: Ben Seri <ben@armis.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 20e2b791796bd68816fa115f12be5320de2b8021 upstream.
The ISA msnd drivers have loops fetching the ring-buffer head, tail
and size values inside the loops. Such codes are inefficient and
fragile.
This patch optimizes it, and also adds the sanity check to avoid the
endless loops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196131
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196133
Signed-off-by: grygorii tertychnyi <gtertych@cisco.com>
commit f4dbba591945dc301c302672adefba9e2ec08dc5 upstream.
When running locktorture module with the below commands with kmemleak enabled:
$ modprobe locktorture torture_type=rw_lock_irq
$ rmmod locktorture
The below kmemleak got caught:
root@10:~# echo scan > /sys/kernel/debug/kmemleak
[ 323.197029] kmemleak: 2 new suspected memory leaks (see /sys/kernel/debug/kmemleak)
root@10:~# cat /sys/kernel/debug/kmemleak
unreferenced object 0xffffffc07592d500 (size 128):
comm "modprobe", pid 368, jiffies 4294924118 (age 205.824s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 c3 7b 02 00 00 00 00 00 .........{......
00 00 00 00 00 00 00 00 d7 9b 02 00 00 00 00 00 ................
backtrace:
[<ffffff80081e5a88>] create_object+0x110/0x288
[<ffffff80086c6078>] kmemleak_alloc+0x58/0xa0
[<ffffff80081d5acc>] __kmalloc+0x234/0x318
[<ffffff80006fa130>] 0xffffff80006fa130
[<ffffff8008083ae4>] do_one_initcall+0x44/0x138
[<ffffff800817e28c>] do_init_module+0x68/0x1cc
[<ffffff800811c848>] load_module+0x1a68/0x22e0
[<ffffff800811d340>] SyS_finit_module+0xe0/0xf0
[<ffffff80080836f0>] el0_svc_naked+0x24/0x28
[<ffffffffffffffff>] 0xffffffffffffffff
unreferenced object 0xffffffc07592d480 (size 128):
00 00 00 00 00 00 00 00 3b 6f 01 00 00 00 00 00 ........;o......
00 00 00 00 00 00 00 00 23 6a 01 00 00 00 00 00 ........#j......
backtrace:
[<ffffff80006fa22c>] 0xffffff80006fa22c
It is because cxt.lwsa and cxt.lrsa don't get freed in module_exit, so free
them in lock_torture_cleanup() and free writer_tasks if reader_tasks is
failed at memory allocation.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: 石洋 <yang.s@alibaba-inc.com>
commit de0c799bba2610a8e1e9a50d76a28614520a4cd4 upstream.
Seen while reading the code, in handle_mm_fault(), in the case
arch_vma_access_permitted() is failing the call to
mem_cgroup_oom_disable() is not made.
To fix that, move the call to mem_cgroup_oom_enable() after calling
arch_vma_access_permitted() as it should not have entered the memcg OOM.
Link: http://lkml.kernel.org/r/1504625439-31313-1-git-send-email-ldufour@linux.vnet.ibm.com
Fixes: bae473a423f6 ("mm: introduce fault_env")
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
commit 23d98c204386a98d9ef9f9e744f41443ece4929f upstream.
Those are funny cases. Make sure they work.
(Something is screwy with signal handling if a selector is 1, 2, or 3.
Anyone who wants to dive into that rabbit hole is welcome to do so.)
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Chang Seok <chang.seok.bae@intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit 6c6b5a39c4bf3dbd8cf629c9f5450e983c19dbb9 upstream.
Several distributions mount the "proper root" as ro during initrd and
then remount it as rw before pivot_root(2). Thus, if a rescan had been
aborted by a previous shutdown, the rescan would never be resumed.
This issue would manifest itself as several btrfs ioctl(2)s causing the
entire machine to hang when btrfs_qgroup_wait_for_completion was hit
(due to the fs_info->qgroup_rescan_running flag being set but the rescan
itself not being resumed). Notably, Docker's btrfs storage driver makes
regular use of BTRFS_QUOTA_CTL_DISABLE and BTRFS_IOC_QUOTA_RESCAN_WAIT
(causing this problem to be manifested on boot for some machines).
Cc: Jeff Mahoney <jeffm@suse.com>
Fixes: b382a324b60f ("Btrfs: fix qgroup rescan resume on mount")
Signed-off-by: Aleksa Sarai <asarai@suse.de>
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
Tested-by: Nikolay Borisov <nborisov@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 40a5fce495715c48c2e02668144e68a507ac5a30 upstream.
The default host NQN, which is generated based on the host's UUID,
does not follow the UUID-based NQN format laid out in the NVMe 1.3
specification. Remove the "NVMf:" portion of the NQN to match the spec.
Signed-off-by: Daniel Verkamp <daniel.verkamp@intel.com>
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
commit 10777de570016471fd929869c7830a7772893e39 upstream.
The configuration for BCH is not correct in the current driver.
The ECC_CFG_ECC_DISABLE bit defines whether to enable or disable the
BCH ECC in which
0x1 : BCH_DISABLED
0x0 : BCH_ENABLED
But currently host->bch_enabled is being assigned to BCH_DISABLED.
Fixes: c76b78d8ec05a ("mtd: nand: Qualcomm NAND controller driver")
Signed-off-by: Abhishek Sahu <absahu@codeaurora.org>
Reviewed-by: Archit Taneja <architt@codeaurora.org>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
commit d8a9b320a26c1ea28e51e4f3ecfb593d5aac2910 upstream.
The NAND page read fails without complete boot chain since
NAND_DEV_CMD_VLD value is not proper. The default power on reset
value for this register is
0xe - ERASE_START_VALID | WRITE_START_VALID | READ_STOP_VALID
The READ_START_VALID should be enabled for sending PAGE_READ
command. READ_STOP_VALID should be cleared since normal NAND
page read does not require READ_STOP command.
commit 3bff08dffe3115a25ce04b95ea75f6d868572c60 upstream.
Commit a894cf6c5a82 ("mtd: nand: mxc: switch to mtd_ooblayout_ops")
introduced a bug in the OOB layout description. Even if the driver claims
that 3 ECC bytes are reserved to protect 512 bytes of data, it's actually
5 ECC bytes to protect 512+6 bytes of data (some OOB bytes are also
protected using extra ECC bytes).
Fix the mxc_v1_ooblayout_{free,ecc}() functions to reflect this behavior.
Fixes: a894cf6c5a82 ("mtd: nand: mxc: switch to mtd_ooblayout_ops")
commit 6d5104c5a6b56385426e15047050584794bb6254 upstream.
In chasing down a previous issue with EDID probing from calling
drm_helper_hpd_irq_event() from irq context, Laurent noticed
that the DRM documentation suggests that
drm_kms_helper_hotplug_event() should be used instead.
Thus this patch replaces drm_helper_hpd_irq_event() with
drm_kms_helper_hotplug_event(), which requires we update the
connector.status entry and only call _hotplug_event() when the
status changes.
Cc: David Airlie <airlied@linux.ie>
Cc: Archit Taneja <architt@codeaurora.org>
Cc: Wolfram Sang <wsa+renesas@sang-engineering.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-3-git-send-email-john.stultz@linaro.org
Signed-off-by: Thong Ho <thong.ho.px@rvc.renesas.com>
Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com>
context
commit 518cb7057a59b9441336d2e88a396d52b6ab0cce upstream.
I was recently seeing issues with EDID probing, where
the logic to wait for the EDID read bit to be set by the
IRQ wasn't happening and the code would time out and fail.
Digging deeper, I found this was due to the fact that
IRQs were disabled as we were running in IRQ context from
the HPD signal.
Thus this patch changes the logic to handle the HPD signal
via a work_struct so we can be out of irq context.
With this patch, the EDID probing on hotplug does not time
out.
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-2-git-send-email-john.stultz@linaro.org
commit 8d26f491116feaa0b16de370b6a7ba40a40fa0b4 upstream.
Commit 1bc0eb044615 ("scsi: sg: protect accesses to 'reserved' page
array") adds needed concurrency protection for the "reserve" buffer.
Some checks that are initially made outside the lock are replicated once
the lock is taken to ensure the checks and resulting decisions are made
using consistent state.
The check that a request with flag SG_FLAG_MMAP_IO set fits in the
reserve buffer also needs to be performed again under the lock to ensure
the reserve buffer length compared against matches the value in effect
when the request is linked to the reserve buffer. An -ENOMEM should be
returned in this case, instead of switching over to an indirect buffer
as for non-MMAP_IO requests.
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
commit 6a8dadcca81fceff9976e8828cceb072873b7bd5 upstream.
Take f_mutex around mmap() processing to protect against races with the
SG_SET_RESERVED_SIZE ioctl. Ensure the reserve buffer length remains
consistent during the mapping operation, and set the "mmap called" flag
to prevent further changes to the reserved buffer size as an atomic
operation with the mapping.
[mkp: fixed whitespace]
commit 591b6bb605785c12a21e8b07a08a277065b655a5 upstream.
Several legacy devices such as Geode-based Cisco ASA appliances
and DB800 development board do possess CS5536 IDE controller
with different PCI id than existing one. Using pata_generic is
not always feasible as at least DB800 requires MSR quirk from
pata_cs5536 to be used with vendor firmware.
Signed-off-by: Andrey Korolyov <andrey@xdel.ru>
commit fbf1c41fc0f4d3574ac2377245efd666c1fa3075 upstream.
Commit 0a94efb5acbb ("workqueue: implicit ordered attribute should be
overridable") introduced a __WQ_ORDERED_EXPLICIT flag but gave it the
same value as __WQ_LEGACY. I don't believe these were intended to
mean the same thing, so renumber __WQ_ORDERED_EXPLICIT.
Fixes: 0a94efb5acbb ("workqueue: implicit ordered attribute should be ...")
commit bc60c90f472b6e762ea96ef384072145adc8d4af upstream.
It appears that MSI does not work on either G5 PPC nor on a E5500-based
platform, where other hardware is reported to work fine with MSI.
Both tests were conducted with NV4x hardware, so perhaps other (or even
this) hardware can be made to work. It's still possible to force-enable
with config=NvMSI=1 on load.
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit fa41ba0d08de7c975c3e94d0067553f9b934221f upstream.
Right now there is a potential hang situation for postcopy migrations,
if the guest is enabling storage keys on the target system during the
postcopy process.
For storage key virtualization, we have to forbid the empty zero page as
the storage key is a property of the physical page frame. As we enable
storage key handling lazily we then drop all mappings for empty zero
pages for lazy refaulting later on.
This does not work with the postcopy migration, which relies on the
empty zero page never triggering a fault again in the future. The reason
is that postcopy migration will simply read a page on the target system
if that page is a known zero page to fault in an empty zero page. At
the same time postcopy remembers that this page was already transferred
- so any future userfault on that page will NOT be retransmitted again
to avoid races.
If now the guest enters the storage key mode while in postcopy, we will
break this assumption of postcopy.
The solution is to disable the empty zero page for KVM guests early on
and not during storage key enablement. With this change, the postcopy
migration process is guaranteed to start after no zero pages are left.
As guest pages are very likely not empty zero pages anyway the memory
overhead is also pretty small.
While at it this also adds proper page table locking to the zero page
removal.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Janosch Frank <frankja@linux.vnet.ibm.com>
commit acf5e051ac44d5dc60b21bc4734ef1b844d55551 upstream.
This patch adds the resources and DMI ID's for the MEN SC31,
which uses a different address region to map the LPC bus than
the one used for the existing SC24.
Signed-off-by: Michael Moese <michael.moese@men.de>
[jth add stable tag]
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 4b5dde2d6234ff5bc68e97e6901d1f2a0a7f3749 upstream.
mwifiex records information about various channels as it receives scan
information. It does this by appending to a buffer that was sized
to the max number of supported channels on any band, but there are
numerous problems:
(a) scans can return info from more than one band (e.g., both 2.4 and 5
GHz), so the determined "max" is not large enough
(b) some firmware appears to return multiple results for a given
channel, so the max *really* isn't large enough
(c) there is no bounds checking when stashing these stats, so problems
(a) and (b) can easily lead to buffer overflows
Let's patch this by setting a slightly-more-correct max (that accounts
for a combination of both 2.4G and 5G bands) and adding a bounds check
when writing to our statistics buffer.
Due to problem (b), we still might not properly report all known survey
information (e.g., with "iw <dev> survey dump"), since duplicate results
(or otherwise "larger than expected" results) will cause some
truncation. But that's a problem for a future bugfix.
(And because of this known deficiency, only log the excess at the WARN
level, since that isn't visible by default in this driver and would
otherwise be a bit too noisy.)
Fixes: bf35443314ac ("mwifiex: channel statistics support for mwifiex")
Cc: Avinash Patil <patila@marvell.com>
Cc: Xinming Hu <huxm@marvell.com>
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Ganapathi Bhat <gbhat@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 55acdd926f6b21a5cdba23da98a48aedf19ac9c3 upstream.
Can be reproduced when running dlm_controld (tested on 4.4.x, 4.12.4):
# seq 1 100 | xargs -P0 -n1 dlm_tool join
# seq 1 100 | xargs -P0 -n1 dlm_tool leave
misc_register fails due to duplicate sysfs entry, which causes
dlm_device_register to free ls->ls_device.name.
In dlm_device_deregister the name was freed again, causing memory
corruption.
According to the comment in dlm_device_deregister the name should've been
set to NULL when registration fails,
so this patch does that.
sysfs: cannot create duplicate filename '/dev/char/10:1'
warning: cpu: 1 pid: 4450 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x56/0x70
modules linked in: msr rfcomm dlm ccm bnep dm_crypt uvcvideo
videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core videodev
btusb media btrtl btbcm btintel bluetooth ecdh_generic intel_rapl
x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm
snd_hda_codec_hdmi irqbypass crct10dif_pclmul crc32_pclmul
ghash_clmulni_intel thinkpad_acpi pcbc nvram snd_seq_midi
snd_seq_midi_event aesni_intel snd_hda_codec_realtek snd_hda_codec_generic
snd_rawmidi aes_x86_64 crypto_simd glue_helper snd_hda_intel snd_hda_codec
cryptd intel_cstate arc4 snd_hda_core snd_seq snd_seq_device snd_hwdep
iwldvm intel_rapl_perf mac80211 joydev input_leds iwlwifi serio_raw
cfg80211 snd_pcm shpchp snd_timer snd mac_hid mei_me lpc_ich mei soundcore
sunrpc parport_pc ppdev lp parport autofs4 i915 psmouse
e1000e ahci libahci i2c_algo_bit sdhci_pci ptp drm_kms_helper sdhci
pps_core syscopyarea sysfillrect sysimgblt fb_sys_fops drm wmi video
cpu: 1 pid: 4450 comm: dlm_test.exe not tainted 4.12.4-041204-generic
hardware name: lenovo 232425u/232425u, bios g2et82ww (2.02 ) 09/11/2012
task: ffff96b0cbabe140 task.stack: ffffb199027d0000
rip: 0010:sysfs_warn_dup+0x56/0x70
rsp: 0018:ffffb199027d3c58 eflags: 00010282
rax: 0000000000000038 rbx: ffff96b0e2c49158 rcx: 0000000000000006
rdx: 0000000000000000 rsi: 0000000000000086 rdi: ffff96b15e24dcc0
rbp: ffffb199027d3c70 r08: 0000000000000001 r09: 0000000000000721
r10: ffffb199027d3c00 r11: 0000000000000721 r12: ffffb199027d3cd1
r13: ffff96b1592088f0 r14: 0000000000000001 r15: ffffffffffffffef
fs: 00007f78069c0700(0000) gs:ffff96b15e240000(0000)
knlgs:0000000000000000
cs: 0010 ds: 0000 es: 0000 cr0: 0000000080050033
cr2: 000000178625ed28 cr3: 0000000091d3e000 cr4: 00000000001406e0
call trace:
sysfs_do_create_link_sd.isra.2+0x9e/0xb0
sysfs_create_link+0x25/0x40
device_add+0x5a9/0x640
device_create_groups_vargs+0xe0/0xf0
device_create_with_groups+0x3f/0x60
? snprintf+0x45/0x70
misc_register+0x140/0x180
device_write+0x6a8/0x790 [dlm]
__vfs_write+0x37/0x160
? apparmor_file_permission+0x1a/0x20
? security_file_permission+0x3b/0xc0
vfs_write+0xb5/0x1a0
sys_write+0x55/0xc0
? sys_fcntl+0x5d/0xb0
entry_syscall_64_fastpath+0x1e/0xa9
rip: 0033:0x7f78083454bd
rsp: 002b:00007f78069bbd30 eflags: 00000293 orig_rax: 0000000000000001
rax: ffffffffffffffda rbx: 0000000000000006 rcx: 00007f78083454bd
rdx: 000000000000009c rsi: 00007f78069bee00 rdi: 0000000000000005
rbp: 00007f77f8000a20 r08: 000000000000fcf0 r09: 0000000000000032
r10: 0000000000000024 r11: 0000000000000293 r12: 00007f78069bde00
r13: 00007f78069bee00 r14: 000000000000000a r15: 00007f78069bbd70
code: 85 c0 48 89 c3 74 12 b9 00 10 00 00 48 89 c2 31 f6 4c 89 ef e8 2c c8
ff ff 4c 89 e2 48 89 de 48 c7 c7 b0 8e 0c a8 e8 41 e8 ed ff <0f> ff 48 89
df e8 00 d5 f4 ff 5b 41 5c 41 5d 5d c3 66 0f 1f 84
---[ end trace 40412246357cc9e0 ]---
dlm: 59f24629-ae39-44e2-9030-397ebc2eda26: leaving the lockspace group...
bug: unable to handle kernel null pointer dereference at 0000000000000001
ip: [<ffffffff811a3b4a>] kmem_cache_alloc+0x7a/0x140
pgd 0
oops: 0000 [#1] smp
modules linked in: dlm 8021q garp mrp stp llc openvswitch nf_defrag_ipv6
nf_conntrack libcrc32c iptable_filter dm_multipath crc32_pclmul dm_mod
aesni_intel psmouse aes_x86_64 sg ablk_helper cryptd lrw gf128mul
glue_helper i2c_piix4 nls_utf8 tpm_tis tpm isofs nfsd auth_rpcgss
oid_registry nfs_acl lockd grace sunrpc xen_wdt ip_tables x_tables autofs4
hid_generic usbhid hid sr_mod cdrom sd_mod ata_generic pata_acpi 8139too
serio_raw ata_piix 8139cp mii uhci_hcd ehci_pci ehci_hcd libata
scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh_alua scsi_mod ipv6
cpu: 0 pid: 394 comm: systemd-udevd tainted: g w 4.4.0+0 #1
hardware name: xen hvm domu, bios 4.7.2-2.2 05/11/2017
task: ffff880002410000 ti: ffff88000243c000 task.ti: ffff88000243c000
rip: e030:[<ffffffff811a3b4a>] [<ffffffff811a3b4a>]
rsp: e02b:ffff88000243fd90 eflags: 00010202
rax: 0000000000000000 rbx: ffff8800029864d0 rcx: 000000000007b36c
rdx: 000000000007b36b rsi: 00000000024000c0 rdi: ffff880036801c00
rbp: ffff88000243fdc0 r08: 0000000000018880 r09: 0000000000000054
r10: 000000000000004a r11: ffff880034ace6c0 r12: 00000000024000c0
r13: ffff880036801c00 r14: 0000000000000001 r15: ffffffff8118dcc2
fs: 00007f0ab77548c0(0000) gs:ffff880036e00000(0000) knlgs:0000000000000000
cs: e033 ds: 0000 es: 0000 cr0: 0000000080050033
cr2: 0000000000000001 cr3: 000000000332d000 cr4: 0000000000040660
stack:
ffffffff8118dc90 ffff8800029864d0 0000000000000000 ffff88003430b0b0
ffff880034b78320 ffff88003430b0b0 ffff88000243fdf8 ffffffff8118dcc2
ffff8800349c6700 ffff8800029864d0 000000000000000b 00007f0ab7754b90
call trace:
[<ffffffff8118dc90>] ? anon_vma_fork+0x60/0x140
[<ffffffff8118dcc2>] anon_vma_fork+0x92/0x140
[<ffffffff8107033e>] copy_process+0xcae/0x1a80
[<ffffffff8107128b>] _do_fork+0x8b/0x2d0
[<ffffffff81071579>] sys_clone+0x19/0x20
[<ffffffff815a30ae>] entry_syscall_64_fastpath+0x12/0x71
] code: f6 75 1c 4c 89 fa 44 89 e6 4c 89 ef e8 a7 e4 00 00 41 f7 c4 00 80
00 00 49 89 c6 74 47 eb 32 49 63 45 20 48 8d 4a 01 4d 8b 45 00 <49> 8b 1c
06 4c 89 f0 65 49 0f c7 08 0f 94 c0 84 c0 74 ac 49 63
rip [<ffffffff811a3b4a>] kmem_cache_alloc+0x7a/0x140
rsp <ffff88000243fd90>
--[ end trace 70cb9fd1b164a0e8 ]--
Signed-off-by: Edwin Török <edvin.torok@citrix.com>
Signed-off-by: David Teigland <teigland@redhat.com>
commit 3f7a5e13e85026b6e460bbd6e87f87379421d272 upstream.
We have a new PCI subsystem ID for 7265D. Add it to the list.
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit a81d72d2002d6a932bd83022cbf8c442b1b97512 upstream.
T: Bus=02 Lev=01 Prnt=01 Port=03 Cnt=03 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=13d3 ProdID=3494 Rev= 2.00
S: Manufacturer=Realtek
S: Product=Bluetooth Radio
S: SerialNumber=00e04c000001
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
commit fc81bab5eeb103711925d7510157cf5cd2b153f4 upstream.
_rtl_pci_find_adapter fail path will jump to label fail3 for
unsupported adapter types.
However, on course for fail3 there will be call rtl_deinit_core
before rtl_init_core.
For the inclusion of checking pci_iounmap this fail can be moved to
fail2.
Fixes
[ 4.492963] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 4.493067] IP: rtl_deinit_core+0x31/0x90 [rtlwifi]
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 293b915fd9bebf33cdc906516fb28d54649a25ac upstream.
Trackpoint buttons detection fails on ThinkPad 570 and 470 series,
this makes the middle button of the trackpoint to not being recogized.
As I don't believe there is any trackpoint with less than 3 buttons this
patch just assumes three buttons when the extended button information
read fails.
Signed-off-by: Oscar Campos <oscar.campos@member.fsf.org>
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
commit f35a7f91f66af528b3ee1921de16bea31d347ab0 upstream.
The rx ring buffers are added to a hash table if
firmware support full rx reorder. If the full rx
reorder support flag is not set before allocating
the rx ring buffers, none of the buffers are added
to the hash table.
There is a race condition between rx ring refill and
rx buffer replenish from napi poll. The interrupts are
enabled in hif start, before the rx ring is refilled during init.
We replenish buffers from napi poll due to the interrupts which
get enabled after hif start. Hence before the entire rx ring is
refilled during the init, the napi poll replenishes a few buffers
in steps of 100 buffers per attempt. During this rx ring replenish
from napi poll, the rx reorder flag has not been set due to which
the replenished buffers are not added to the hash table
Set the rx full reorder support flag before we allocate
the rx ring buffer to avoid the memory leak.
Signed-off-by: Rakesh Pillai <pillair@qti.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
commit efb3669e14fe17d0ec4ecf57d0365039fe726f59 upstream.
This adds Intel(R) Trace Hub PCI ID for Cannon Lake PCH-LP.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
commit 84331e1390b6378a5129a3678c87a42c6f697d29 upstream.
This adds Intel(R) Trace Hub PCI ID for Cannon Lake PCH-H.
commit 0f9b011d3321ca1079c7a46c18cb1956fbdb7bcb upstream.
The .release function of driver_ktype is 'driver_release()'.
This function frees the container_of this kobject.
So, this memory must not be freed explicitly in the error handling path of
'bus_add_driver()'. Otherwise a double free will occur.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
commit 4744d4e2afebf9644a439da9ca73d822fdd67bd9 upstream.
This driver assumes that the device is operating in the continuous
conversion mode which performs the conversion continuously. So this driver
inserts a wait time before reading the conversion register if the
configuration is changed from a previous request.
Currently, the wait time is only the period required for a single
conversion that is calculated as the reciprocal of the sampling frequency.
However we also need to wait for the the previous conversion to complete.
Otherwise we probably get the conversion result for the previous
configuration when the sampling frequency is lower.
Cc: Daniel Baluta <daniel.baluta@gmail.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit a6fe5e52d5ecfc98530034d6c9db73777cf41ede upstream.
pm_runtime_get_sync() and pm_runtime_put_autosuspend() return 0 on
success, 1 if the device's runtime PM status was already requested status
or error code on failure. So a positive return value doesn't indicate an
error condition.
However, any non-zero return values from buffer preenable and postdisable
callbacks are recognized as an error and this driver reuses the return
value from pm_runtime_get_sync() and pm_runtime_put_autosuspend() in
these callbacks. This change fixes the false error detections.
commit 73e3e3fc50de50cfd68e945d85679c983ed31bd9 upstream.
doesn't insert a wait time before reading the conversion register if the
configuration is not changed from a previous request.
This assumption is broken if the device is runtime suspended and entered
a power-down state. The forthcoming request causes reading a stale result
from the conversion register as the device is runtime resumed just before.
Fix it by adding a flag to detect that condition and insert a necessary
wait time.
commit e8245c68350104b6022b6783719e843d69ea7c43 upstream.
The ADS1015 device have two operating modes, continuous conversion mode
and single-shot mode. This driver assumes that the continuous conversion
mode is selected by runtime resume callback when the ADC result is
requested.
If CONFIG_PM is disabled, the device is always in the default single-shot
mode and no one begins a single conversion. So the conversion register
doesn't contain valid ADC result. Fix it by changing the continuous mode
in probe function.
commit 8d0e8e795623bd6229cf48bb7777a1c456c370ed upstream.
The ti-ads1015 driver supports ADS1015 and ADS1115 devices. The same
scale information is used for both devices in this driver, however they
have actually different values and the ADS1115's one is not correct.
These devices have the same full-scale input voltage range for each PGA
selection. So instead of adding another hardcoded scale information,
compute a correct scale on demand from each device's resolution.
commit 0d106b74c558e3000aa0e058b4725cacb70ce77a upstream.
The ti-ads1015 driver has eight iio voltage channels and each iio channel
can hold own sampling frequency information.
The ADS1015 device only have a single config register which contains an
input multiplexer selection, PGA and data rate settings. So the driver
should load the correct settings when the input multiplexer selection is
changed.
However, regardless of which channlel is currently selected, changing any
iio channel's sampling frequency information immediately overwrites the
current data rate setting in the config register.
It breaks the current data rate setting if the different channel's sampling
frequency information is changed because the data rate setting is not
reloaded when the input multiplexer is switched.
This removes the unexpected config register update and correctly load the
data rate setting before getting adc result.
commit 34ff1bf4920471cff66775dc39537b15c5f0feff upstream.
The mask of sns_key_info1 suggests the upper nybble is being extracted
however the following shift of 8 bits is too large and always results in
0. Fix this by shifting only by 4 bits to correctly get the upper nybble.
Detected by CoverityScan, CID#142891 ("Operands don't affect result")
Fixes: fa590c222fba ("staging: rts5208: add support for rts5208 and rts5288")
commit ed62ca2f4f51c17841ea39d98c0c409cb53a3e10 upstream.
While running reboot tests w/ a specific set of USB devices (and
slub_debug enabled), I found that once every few hours my device would
be crashed with a stack that looked like this:
[ 14.012445] BUG: spinlock bad magic on CPU#0, modprobe/2091
[ 14.012460] lock: 0xffffffc0cb055978, .magic: ffffffc0, .owner: cryption contexts: %lu/%lu
[ 14.012460] /1025536097, .owner_cpu: 0
[ 14.012466] CPU: 0 PID: 2091 Comm: modprobe Not tainted 4.4.79 #352
[ 14.012468] Hardware name: Google Kevin (DT)
[ 14.012471] Call trace:
[ 14.012483] [<....>] dump_backtrace+0x0/0x160
[ 14.012487] [<....>] show_stack+0x20/0x28
[ 14.012494] [<....>] dump_stack+0xb4/0xf0
[ 14.012500] [<....>] spin_dump+0x8c/0x98
[ 14.012504] [<....>] spin_bug+0x30/0x3c
[ 14.012508] [<....>] do_raw_spin_lock+0x40/0x164
[ 14.012515] [<....>] _raw_spin_lock_irqsave+0x64/0x74
[ 14.012521] [<....>] __wake_up+0x2c/0x60
[ 14.012528] [<....>] async_completed+0x2d0/0x300
[ 14.012534] [<....>] __usb_hcd_giveback_urb+0xc4/0x138
[ 14.012538] [<....>] usb_hcd_giveback_urb+0x54/0xf0
[ 14.012544] [<....>] xhci_irq+0x1314/0x1348
[ 14.012548] [<....>] usb_hcd_irq+0x40/0x50
[ 14.012553] [<....>] handle_irq_event_percpu+0x1b4/0x3f0
[ 14.012556] [<....>] handle_irq_event+0x4c/0x7c
[ 14.012561] [<....>] handle_fasteoi_irq+0x158/0x1c8
[ 14.012564] [<....>] generic_handle_irq+0x30/0x44
[ 14.012568] [<....>] __handle_domain_irq+0x90/0xbc
[ 14.012572] [<....>] gic_handle_irq+0xcc/0x18c
Investigation using kgdb() found that the wait queue that was passed
into wake_up() had been freed (it was filled with slub_debug poison).
I analyzed and instrumented the code and reproduced. My current
belief is that this is happening:
1. async_completed() is called (from IRQ). Moves "as" onto the
completed list.
2. On another CPU, proc_reapurbnonblock_compat() calls
async_getcompleted(). Blocks on spinlock.
3. async_completed() releases the lock; keeps running; gets blocked
midway through wake_up().
4. proc_reapurbnonblock_compat() => async_getcompleted() gets the
lock; removes "as" from completed list and frees it.
5. usbdev_release() is called. Frees "ps".
6. async_completed() finally continues running wake_up(). ...but
wake_up() has a pointer to the freed "ps".
The instrumentation that led me to believe this was based on adding
some trace_printk() calls in a select few functions and then using
kdb's "ftdump" at crash time. The trace follows (NOTE: in the trace
below I cheated a little bit and added a udelay(1000) in
async_completed() after releasing the spinlock because I wanted it to
trigger quicker):
<...>-2104 0d.h2 13759034us!: async_completed at start: as=ffffffc0cc638200
mtpd-2055 3.... 13759356us : async_getcompleted before spin_lock_irqsave
mtpd-2055 3d..1 13759362us : async_getcompleted after list_del_init: as=ffffffc0cc638200
mtpd-2055 3.... 13759371us+: proc_reapurbnonblock_compat: free_async(ffffffc0cc638200)
mtpd-2055 3.... 13759422us+: async_getcompleted before spin_lock_irqsave
mtpd-2055 3.... 13759479us : usbdev_release at start: ps=ffffffc0cc042080
mtpd-2055 3.... 13759487us : async_getcompleted before spin_lock_irqsave
mtpd-2055 3.... 13759497us!: usbdev_release after kfree(ps): ps=ffffffc0cc042080
<...>-2104 0d.h2 13760294us : async_completed before wake_up(): as=ffffffc0cc638200
To fix this problem we can just move the wake_up() under the ps->lock.
There should be no issues there that I'm aware of.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 082df8be455ade361748f0385aa6c9c8d07be167 upstream.
Make sure that the controller is runtime resumed when system suspending
to avoid an external abort when accessing the interrupt registers:
Unhandled fault: external abort on non-linefetch (0x1008) at 0xd025840a
[<c05481a4>] (musb_default_readb) from [<c0545abc>] (musb_disable_interrupts+0x84/0xa8)
[<c0545abc>] (musb_disable_interrupts) from [<c0546b08>] (musb_suspend+0x38/0xb8)
[<c0546b08>] (musb_suspend) from [<c04a57f8>] (platform_pm_suspend+0x3c/0x64)
This is easily reproduced on a BBB by enabling the peripheral port only
(as the host port may enable the shared clock) and keeping it
disconnected so that the controller is runtime suspended. (Well, you
would also need to the not-yet-merged am33xx-suspend patches by Dave
Gerlach to be able to suspend the BBB.)
This is a regression that was introduced by commit 1c4d0b4e1806 ("usb:
musb: Remove pm_runtime_set_irq_safe") which allowed the parent glue
device to runtime suspend and thereby exposed a couple of older issues:
Register accesses without explicitly making sure the controller is
runtime resumed during suspend was first introduced by commit c338412b5ded
("usb: musb: unconditionally save and restore the context on suspend")
in 3.14.
Commit a1fc1920aaaa ("usb: musb: core: make sure musb is in RPM_ACTIVE on
resume") later started setting the RPM status to active during resume,
and this was also implicitly relying on the parent always being active.
Since commit 71723f95463d ("PM / runtime: print error when activating a
child to unactive parent") this now also results in the following
warning:
musb-hdrc musb-hdrc.0: runtime PM trying to activate child device
musb-hdrc.0 but parent (47401400.usb) is not active
This patch has been verified on 4.13-rc2, 4.12 and 4.9 using a BBB
(the dsps glue would always be active also in 4.8).
Fixes: c338412b5ded ("usb: musb: unconditionally save and restore the context on suspend")
Fixes: a1fc1920aaaa ("usb: musb: core: make sure musb is in RPM_ACTIVE on resume")
Fixes: 1c4d0b4e1806 ("usb: musb: Remove pm_runtime_set_irq_safe")
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Daniel Mack <zonque@gmail.com>
Cc: Dave Gerlach <d-gerlach@ti.com>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit e6b422b88b46353cf596e0db6dc0e39d50d90d6e upstream.
The following commit cause a regression on ATI chipsets.
'commit e788787ef4f9 ("usb:xhci:Add quirk for Certain
failing HP keyboard on reset after resume")'
This causes pinfo->smbus_dev to be wrongly set to NULL on
systems with the ATI chipset that this function checks for first.
Added conditional check for AMD chipsets to avoid the overwriting
pinfo->smbus_dev.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Fixes: e788787ef4f9 ("usb:xhci:Add quirk for Certain
cc: Nehal Shah <Nehal-bakulchandra.Shah@amd.com>
Signed-off-by: Sandeep Singh <Sandeep.Singh@amd.com>
Signed-off-by: Shyam Sundar S K <Shyam-sundar.S-k@amd.com>
commit a1279ef74eeeb5f627f091c71d80dd7ac766c99d upstream.
Commit e0429362ab15
("usb: Add device quirk for Logitech HD Pro Webcams C920 and C930e")
introduced quirk to workaround an issue with some Logitech webcams.
Apparently model C920-C has the same issue so applying
the same quirk as well.
See aforementioned commit message for detailed explanation of the problem.
Signed-off-by: Dmitry Fleytman <dmitry@daynix.com>
commit 169e86546f5712179709de23cd64bbb15f199fab upstream.
This commit adds support (an ID, really) for D-Link DWM-157 hardware
version C1 USB modem to option driver.
According to manufacturer-provided Windows INF file the device has four
serial ports:
"D-Link HSPA+DataCard Diagnostics Interface" (interface 2; modem port),
"D-Link HSPA+DataCard NMEA Device" (interface 3),
"D-Link HSPA+DataCard Speech Port" (interface 4),
"D-Link HSPA+DataCard Debug Port" (interface 5).
usb-devices output:
T: Bus=05 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2001 ProdID=7d0e Rev=03.00
S: Manufacturer=D-Link,Inc
S: Product=D-Link DWM-157
C: #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=0e Prot=00 Driver=cdc_mbim
I: If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=option
I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 6 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
commit de3af5bf259d7a0bfaac70441c8568ab5998d80c upstream.
Corsair Strafe RGB keyboard has trouble to initialize:
[ 1.679455] usb 3-6: new full-speed USB device number 4 using xhci_hcd
[ 6.871136] usb 3-6: unable to read config index 0 descriptor/all
[ 6.871138] usb 3-6: can't read configurations, error -110
[ 6.991019] usb 3-6: new full-speed USB device number 5 using xhci_hcd
[ 12.246642] usb 3-6: unable to read config index 0 descriptor/all
[ 12.246644] usb 3-6: can't read configurations, error -110
[ 12.366555] usb 3-6: new full-speed USB device number 6 using xhci_hcd
[ 17.622145] usb 3-6: unable to read config index 0 descriptor/all
[ 17.622147] usb 3-6: can't read configurations, error -110
[ 17.742093] usb 3-6: new full-speed USB device number 7 using xhci_hcd
[ 22.997715] usb 3-6: unable to read config index 0 descriptor/all
[ 22.997716] usb 3-6: can't read configurations, error -110
Although it may work after several times unpluging/pluging:
[ 68.195240] usb 3-6: new full-speed USB device number 11 using xhci_hcd
[ 68.337459] usb 3-6: New USB device found, idVendor=1b1c, idProduct=1b20
[ 68.337463] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 68.337466] usb 3-6: Product: Corsair STRAFE RGB Gaming Keyboard
[ 68.337468] usb 3-6: Manufacturer: Corsair
[ 68.337470] usb 3-6: SerialNumber: 0F013021AEB8046755A93ED3F5001941
Tried three quirks: USB_QUIRK_DELAY_INIT, USB_QUIRK_NO_LPM and
USB_QUIRK_DEVICE_QUALIFIER, user confirmed that USB_QUIRK_DELAY_INIT alone
can workaround this issue. Hence add the quirk for Corsair Strafe RGB.
BugLink: https://bugs.launchpad.net/bugs/1678477
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
