commit bed9ff165960921303a100228585f2d1691b42eb upstream.
Signed-off-by: Hector Martin <marcan@marcan.st>
commit ed18c5fa945768a9bec994e786edbbbc7695acf6 upstream.
This optimization significantly reduces xhci driver load time.
In ACPI tables the acpi companion port devices are children of
the hub device. The port devices are identified by their port number
returned by the ACPI _ADR method.
_ADR 0 is reserved for the root hub device.
The current implementation to find a acpi companion port device
loops through all acpi port devices under that parent hub, evaluating
their _ADR method each time a new port device is added.
for a xHC controller with 25 ports under its roothub it
will end up invoking ACPI bytecode 625 times before all ports
are ready, making it really slow.
The _ADR values are already read and cached earler. So instead of
running the bytecode again we can check the cached _ADR value first,
and then fall back to the old way.
As one of the more significant changes, the xhci load time on
Intel kabylake reduced by 70%, (28ms) from
initcall xhci_pci_init+0x0/0x49 returned 0 after 39537 usecs
to
initcall xhci_pci_init+0x0/0x49 returned 0 after 11270 usecs
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit dd1c1f2f2028a7b851f701fc6a8ebe39dcb95e7c upstream.
This was reported many times, and this was even mentioned in commit
52ee2dfdd4f5 ("pids: refactor vnr/nr_ns helpers to make them safe") but
somehow nobody bothered to fix the obvious problem: task_tgid_nr_ns() is
not safe because task->group_leader points to nowhere after the exiting
task passes exit_notify(), rcu_read_lock() can not help.
We really need to change __unhash_process() to nullify group_leader,
parent, and real_parent, but this needs some cleanups. Until then we
can turn task_tgid_nr_ns() into another user of __task_pid_nr_ns() and
fix the problem.
Reported-by: Troy Kensinger <tkensinger@google.com>
commit 197e7e521384a23b9e585178f3f11c9fa08274b9 upstream.
The 'move_paghes()' system call was introduced long long ago with the
same permission checks as for sending a signal (except using
CAP_SYS_NICE instead of CAP_SYS_KILL for the overriding capability).
That turns out to not be a great choice - while the system call really
only moves physical page allocations around (and you need other
capabilities to do a lot of it), you can check the return value to map
out some the virtual address choices and defeat ASLR of a binary that
still shares your uid.
So change the access checks to the more common 'ptrace_may_access()'
model instead.
This tightens the access checks for the uid, and also effectively
changes the CAP_SYS_NICE check to CAP_SYS_PTRACE, but it's unlikely that
anybody really _uses_ this legacy system call any more (we hav ebetter
NUMA placement models these days), so I expect nobody to notice.
Famous last words.
Reported-by: Otto Ebeling <otto.ebeling@iki.fi>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 8fbbe2d7cc478d1544f41f2271787c993c23a4f6 upstream.
Valid CPU ids are [0, nr_cpu_ids-1] inclusive.
Fixes: 3b8e29a82dd1 ("genirq: Implement ipi_send_mask/single()")
Fixes: f9bce791ae2a ("genirq: Add a new function to get IPI reverse mapping")
Link: http://lkml.kernel.org/r/20170819095751.GB27864@avx2
commit e8f241893dfbbebe2813c01eac54f263e6a5e59c upstream.
irq_modify_status starts by clearing the trigger settings from
irq_data before applying the new settings, but doesn't restore them,
leaving them to IRQ_TYPE_NONE.
That's pretty confusing to the potential request_irq() that could
follow. Instead, snapshot the settings before clearing them, and restore
them if the irq_modify_status() invocation was not changing the trigger.
Fixes: 1e2a7d78499e ("irqdomain: Don't set type when mapping an IRQ")
Reported-and-tested-by: jeffy <jeffy.chen@rock-chips.com>
Cc: Jon Hunter <jonathanh@nvidia.com>
Link: http://lkml.kernel.org/r/20170818095345.12378-1-marc.zyngier@arm.com
commit 277867ade8262583f4280cadbe90e0031a3706a7 upstream.
of_find_compatible_node() is calling of_node_put() on its first argument
thus leading to an unbalanced of_node_get/put() issue if the node has not
been retained before that.
Instead of passing the root node, pass NULL, which does exactly the same:
iterate over all DT nodes, starting from the root node.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reported-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fixes: 3d61467f9bab ("irqchip: atmel-aic: Implement RTC irq fixup")
commit 469bcef53c546bb792aa66303933272991b7831d upstream.
aic_common_irq_fixup() is calling twice of_node_put() on the same node
thus leading to an unbalanced refcount on the root node.
Fixes: b2f579b58e93 ("irqchip: atmel-aic: Add irq fixup infrastructure")
commit e93c17301ac55321fc18e0f8316e924e58a83c8c upstream.
This closes a hole in our SMAP implementation.
This patch comes from grsecurity. Good catch!
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/314cc9f294e8f14ed85485727556ad4f15bb1659.1502159503.git.luto@kernel.org
commit b15bd8cb37598afb2963f7eb9e2de468d2d60a2f upstream.
Since commit d05d7f40791c ("Merge branch 'for-4.8/core' of
git://git.kernel.dk/linux-block") and 3fc9d690936f ("Merge branch
'for-4.8/drivers' of git://git.kernel.dk/linux-block"), blkfront_resume()
has been using an index for iterating ring_info to check request when
iterating blk_shadow in an inner loop. This seems to have been
accidentally introduced during the massive rewrite of the block layer
macros in the commits.
This may cause crash like this:
[11798.057074] BUG: unable to handle kernel NULL pointer dereference at 0000000000000048
[11798.058832] IP: [<ffffffff814411fa>] blkfront_resume+0x10a/0x610
[11798.061063] Call Trace:
[11798.061063] [<ffffffff8139ce93>] xenbus_dev_resume+0x53/0x140
[11798.061063] [<ffffffff8139ce40>] ? xenbus_dev_probe+0x150/0x150
[11798.061063] [<ffffffff813f359e>] dpm_run_callback+0x3e/0x110
[11798.061063] [<ffffffff813f3a08>] device_resume+0x88/0x190
[11798.061063] [<ffffffff813f4cc0>] dpm_resume+0x100/0x2d0
[11798.061063] [<ffffffff813f5221>] dpm_resume_end+0x11/0x20
[11798.061063] [<ffffffff813950a8>] do_suspend+0xe8/0x1a0
[11798.061063] [<ffffffff813954bd>] shutdown_handler+0xfd/0x130
[11798.061063] [<ffffffff8139aba0>] ? split+0x110/0x110
[11798.061063] [<ffffffff8139ac26>] xenwatch_thread+0x86/0x120
[11798.061063] [<ffffffff810b4570>] ? prepare_to_wait_event+0x110/0x110
[11798.061063] [<ffffffff8108fe57>] kthread+0xd7/0xf0
[11798.061063] [<ffffffff811da811>] ? kfree+0x121/0x170
[11798.061063] [<ffffffff8108fd80>] ? kthread_park+0x60/0x60
[11798.061063] [<ffffffff810863b0>] ? call_usermodehelper_exec_work+0xb0/0xb0
[11798.061063] [<ffffffff810864ea>] ? call_usermodehelper_exec_async+0x13a/0x140
[11798.061063] [<ffffffff81534a45>] ret_from_fork+0x25/0x30
Use the right index in the inner loop.
Fixes: d05d7f40791c ("Merge branch 'for-4.8/core' of git://git.kernel.dk/linux-block")
Fixes: 3fc9d690936f ("Merge branch 'for-4.8/drivers' of git://git.kernel.dk/linux-block")
Signed-off-by: Munehisa Kamata <kamatam@amazon.com>
Reviewed-by: Thomas Friebel <friebelt@amazon.de>
Reviewed-by: Eduardo Valentin <eduval@amazon.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Roger Pau Monne <roger.pau@citrix.com>
Cc: xen-devel@lists.xenproject.org
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 5a69aec945d27e78abac9fd032533d3aaebf7c1e upstream.
VSX uses a combination of the old vector registers, the old FP
registers and new "second halves" of the FP registers.
Thus when we need to see the VSX state in the thread struct
(flush_vsx_to_thread()) or when we'll use the VSX in the kernel
(enable_kernel_vsx()) we need to ensure they are all flushed into
the thread struct if either of them is individually enabled.
Unfortunately we only tested if the whole VSX was enabled, not if they
were individually enabled.
Fixes: 72cd7b44bc99 ("powerpc: Uncomment and make enable_kernel_vsx() routine available")
commit c005390374957baacbc38eef96ea360559510aa7 upstream.
While pci_irq_get_affinity should never fail for SMP kernel that
implement the affinity mapping, it will always return NULL in the
UP case, so provide a fallback mapping of all queues to CPU 0 in
that case.
Reviewed-by: Omar Sandoval <osandov@fb.com>
commit 462cdace790ac2ed6aad1b19c9c0af0143b6aab0 upstream.
The current test for bio vec merging is not fully accurate and can be
tricked into merging bios when certain grant combinations are used.
The result of these malicious bio merges is a bio that extends past
the memory page used by any of the originating bios.
Take into account the following scenario, where a guest creates two
grant references that point to the same mfn, ie: grant 1 -> mfn A,
grant 2 -> mfn A.
These references are then used in a PV block request, and mapped by
the backend domain, thus obtaining two different pfns that point to
the same mfn, pfn B -> mfn A, pfn C -> mfn A.
If those grants happen to be used in two consecutive sectors of a disk
IO operation becoming two different bios in the backend domain, the
checks in xen_biovec_phys_mergeable will succeed, because bfn1 == bfn2
(they both point to the same mfn). However due to the bio merging,
the backend domain will end up with a bio that expands past mfn A into
mfn A + 1.
Fix this by making sure the check in xen_biovec_phys_mergeable takes
into account the offset and the length of the bio, this basically
replicates whats done in __BIOVEC_PHYS_MERGEABLE using mfns (bus
addresses). While there also remove the usage of
__BIOVEC_PHYS_MERGEABLE, since that's already checked by the callers
of xen_biovec_phys_mergeable.
Reported-by: "Jan H. Schönherr" <jschoenh@amazon.de>
Signed-off-by: Roger Pau Monné <roger.pau@citrix.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
commit c715b72c1ba406f133217b509044c38d8e714a37 upstream.
Moving the x86_64 and arm64 PIE base from 0x555555554000 to 0x000100000000
broke AddressSanitizer. This is a partial revert of:
eab09532d400 ("binfmt_elf: use ELF_ET_DYN_BASE only for PIE")
02445990a96e ("arm64: move ELF_ET_DYN_BASE to 4GB / 4MB")
The AddressSanitizer tool has hard-coded expectations about where
executable mappings are loaded.
The motivation for changing the PIE base in the above commits was to
avoid the Stack-Clash CVEs that allowed executable mappings to get too
close to heap and stack. This was mainly a problem on 32-bit, but the
64-bit bases were moved too, in an effort to proactively protect those
systems (proofs of concept do exist that show 64-bit collisions, but
other recent changes to fix stack accounting and setuid behaviors will
minimize the impact).
The new 32-bit PIE base is fine for ASan (since it matches the ET_EXEC
base), so only the 64-bit PIE base needs to be reverted to let x86 and
arm64 ASan binaries run again. Future changes to the 64-bit PIE base on
these architectures can be made optional once a more dynamic method for
dealing with AddressSanitizer is found. (e.g. always loading PIE into
the mmap region for marked binaries.)
Link: http://lkml.kernel.org/r/20170807201542.GA21271@beast
Fixes: eab09532d400 ("binfmt_elf: use ELF_ET_DYN_BASE only for PIE")
Fixes: 02445990a96e ("arm64: move ELF_ET_DYN_BASE to 4GB / 4MB")
Reported-by: Kostya Serebryany <kcc@google.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit 73223e4e2e3867ebf033a5a8eb2e5df0158ccc99 upstream.
I hit a use after free issue when executing trinity and repoduced it
with KASAN enabled. The related call trace is as follows.
BUG: KASan: use after free in SyS_get_mempolicy+0x3c8/0x960 at addr ffff8801f582d766
Read of size 2 by task syz-executor1/798
INFO: Allocated in mpol_new.part.2+0x74/0x160 age=3 cpu=1 pid=799
__slab_alloc+0x768/0x970
kmem_cache_alloc+0x2e7/0x450
mpol_new+0x66/0x80
SyS_mbind+0x267/0x9f0
system_call_fastpath+0x16/0x1b
INFO: Freed in __mpol_put+0x2b/0x40 age=4 cpu=1 pid=799
__slab_free+0x495/0x8e0
kmem_cache_free+0x2f3/0x4c0
SyS_mbind+0x383/0x9f0
INFO: Slab 0xffffea0009cb8dc0 objects=23 used=8 fp=0xffff8801f582de40 flags=0x200000000004080
INFO: Object 0xffff8801f582d760 @offset=5984 fp=0xffff8801f582d600
Bytes b4 ffff8801f582d750: ae 01 ff ff 00 00 00 00 5a 5a 5a 5a 5a 5a 5a 5a ........ZZZZZZZZ
Object ffff8801f582d760: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ffff8801f582d770: 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkk.
Redzone ffff8801f582d778: bb bb bb bb bb bb bb bb ........
Padding ffff8801f582d8b8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
Memory state around the buggy address:
ffff8801f582d600: fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801f582d680: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff8801f582d700: fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb fc
!shared memory policy is not protected against parallel removal by other
thread which is normally protected by the mmap_sem. do_get_mempolicy,
however, drops the lock midway while we can still access it later.
Early premature up_read is a historical artifact from times when
put_user was called in this path see https://lwn.net/Articles/124754/
but that is gone since 8bccd85ffbaf ("[PATCH] Implement sys_* do_*
layering in the memory policy layer."). but when we have the the
current mempolicy ref count model. The issue was introduced
accordingly.
Fix the issue by removing the premature release.
Link: http://lkml.kernel.org/r/1502950924-27521-1-git-send-email-zhongjiang@huawei.com
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
commit 5b53a6ea886700a128b697a6fe8375340dea2c30 upstream.
Tetsuo Handa has noticed that MMF_UNSTABLE SIGBUS path in
handle_mm_fault causes a lockdep splat
Out of memory: Kill process 1056 (a.out) score 603 or sacrifice child
Killed process 1056 (a.out) total-vm:4268108kB, anon-rss:2246048kB, file-rss:0kB, shmem-rss:0kB
a.out (1169) used greatest stack depth: 11664 bytes left
DEBUG_LOCKS_WARN_ON(depth <= 0)
WARNING: CPU: 6 PID: 1339 at kernel/locking/lockdep.c:3617 lock_release+0x172/0x1e0
CPU: 6 PID: 1339 Comm: a.out Not tainted 4.13.0-rc3-next-20170803+ #142
Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
RIP: 0010:lock_release+0x172/0x1e0
Call Trace:
up_read+0x1a/0x40
__do_page_fault+0x28e/0x4c0
do_page_fault+0x30/0x80
page_fault+0x28/0x30
The reason is that the page fault path might have dropped the mmap_sem
and returned with VM_FAULT_RETRY. MMF_UNSTABLE check however rewrites
the error path to VM_FAULT_SIGBUS and we always expect mmap_sem taken in
that path. Fix this by taking mmap_sem when VM_FAULT_RETRY is held in
the MMF_UNSTABLE path.
We cannot simply add VM_FAULT_SIGBUS to the existing error code because
all arch specific page fault handlers and g-u-p would have to learn a
new error code combination.
Link: http://lkml.kernel.org/r/20170807113839.16695-2-mhocko@kernel.org
Fixes: 3f70dc38cec2 ("mm: make sure that kthreads will not refault oom reaped memory")
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Andrea Argangeli <andrea@kernel.org>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Wenwei Tao <wenwei.tww@alibaba-inc.com>
commit 3010f876500f9ba921afaeccec30c45ca6584dc8 upstream.
There is existing use after free bug when deferred struct pages are
enabled:
The memblock_add() allocates memory for the memory array if more than
128 entries are needed. See comment in e820__memblock_setup():
* The bootstrap memblock region count maximum is 128 entries
* (INIT_MEMBLOCK_REGIONS), but EFI might pass us more E820 entries
* than that - so allow memblock resizing.
This memblock memory is freed here:
free_low_memory_core_early()
We access the freed memblock.memory later in boot when deferred pages
are initialized in this path:
deferred_init_memmap()
for_each_mem_pfn_range()
__next_mem_pfn_range()
type = &memblock.memory;
One possible explanation for why this use-after-free hasn't been hit
before is that the limit of INIT_MEMBLOCK_REGIONS has never been
exceeded at least on systems where deferred struct pages were enabled.
Tested by reducing INIT_MEMBLOCK_REGIONS down to 4 from the current 128,
and verifying in qemu that this code is getting excuted and that the
freed pages are sane.
Link: http://lkml.kernel.org/r/1502485554-318703-2-git-send-email-pasha.tatashin@oracle.com
Fixes: 7e18adb4f80b ("mm: meminit: initialise remaining struct pages in parallel with kswapd")
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
Reviewed-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Reviewed-by: Bob Picco <bob.picco@oracle.com>
commit 0f174b3525a43bd51f9397394763925e0ebe7bc7 upstream.
C-Media devices (at least some models) mute the playback stream when
volumes are set to the minimum value. But this isn't informed via TLV
and the user-space, typically PulseAudio, gets confused as if it's
still played in a low volume.
This patch adds the new flag, min_mute, to struct usb_mixer_elem_info
for indicating that the mixer element is with the minimum-mute volume.
This flag is set for known C-Media devices in
snd_usb_mixer_fu_apply_quirk() in turn.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196669
commit a8e800fe0f68bc28ce309914f47e432742b865ed upstream.
A Senheisser headset requires the typical sample-rate quirk for
avoiding spurious errors from inquiring the current sample rate like:
usb 1-1: 2:1: cannot get freq at ep 0x4
usb 1-1: 3:1: cannot get freq at ep 0x83
The USB ID 1395:740a has to be added to the entries in
snd_usb_get_sample_rate_quirk().
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1052580
commit 7e1d90f60a0d501c8503e636942ca704a454d910 upstream.
commit 4842e98f26dd80be3623c4714a244ba52ea096a8 ("ALSA: seq: Fix race at
creating a queue") attempted to fix a race reported by syzkaller. That
fix has been described as follows:
When a sequencer queue is created in snd_seq_queue_alloc(),it adds the
new queue element to the public list before referencing it. Thus the
queue might be deleted before the call of snd_seq_queue_use(), and it
results in the use-after-free error, as spotted by syzkaller.
The fix is to reference the queue object at the right time.
Even with that fix in place, syzkaller reported a use-after-free error.
It specifically pointed to the last instruction "return q->queue" in
snd_seq_queue_alloc(). The pointer q is being used after kfree() has
been called on it.
It turned out that there is still a small window where a race can
happen. The window opens at
snd_seq_ioctl_create_queue()->snd_seq_queue_alloc()->queue_list_add()
and closes at
snd_seq_ioctl_create_queue()->queueptr()->snd_use_lock_use(). Between
these two calls, a different thread could delete the queue and possibly
re-create a different queue in the same location in queue_list.
This change prevents this situation by calling snd_use_lock_use() from
snd_seq_queue_alloc() prior to calling queue_list_add(). It is then the
caller's responsibility to call snd_use_lock_free(&q->use_lock).
Fixes: 4842e98f26dd ("ALSA: seq: Fix race at creating a queue")
Signed-off-by: Daniel Mentz <danielmentz@google.com>
commit 76988690402dde2880bfe06ecccf381d48ba8e1c upstream.
Add 2 new IDs (ELAN0609 and ELAN060B) to the list of ACPI IDs that should
be handled by the driver.
Signed-off-by: KT Liao <kt.liao@emc.com.tw>
commit 1874064eed0502bd9bef7be8023757b0c4f26883 upstream.
Similar to commit 722c5ac708b4f ("Input: elan_i2c - add ELAN0605 to the
ACPI table"), ELAN0608 should be handled by elan_i2c.
This touchpad can be found in Lenovo ideapad 320-14IKB.
BugLink: https://bugs.launchpad.net/bugs/1708852
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 8861249c740fc4af9ddc5aee321eafefb960d7c6 upstream.
It was reported that the sha1 AVX2 function(sha1_transform_avx2) is
reading ahead beyond its intended data, and causing a crash if the next
block is beyond page boundary:
http://marc.info/?l=linux-crypto-vger&m=149373371023377
This patch makes sure that there is no overflow for any buffer length.
It passes the tests written by Jan Stancek that revealed this problem:
https://github.com/jstancek/sha1-avx2-crash
I have re-enabled sha1-avx2 by reverting commit
b82ce24426a4071da9529d726057e4e642948667
Fixes: b82ce24426a4 ("crypto: sha1-ssse3 - Disable avx2")
Originally-by: Ilya Albrekht <ilya.albrekht@intel.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: Megha Dey <megha.dey@linux.intel.com>
Reported-by: Jan Stancek <jstancek@redhat.com>
commit 28389575a8cf933a5f3c378556b9f4d3cce0efd2 upstream.
In commit 0f987e25cb8a, the source processing has been moved in front of
the destination processing, but the error handling path has not been
modified accordingly.
Free resources in the correct order to avoid some leaks.
Fixes: 0f987e25cb8a ("crypto: ixp4xx - Fix false lastlen uninitialised warning")
Reported-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
commit 4098116039911e8870d84c975e2ec22dab65a909 upstream.
For 64bit kernels the lmmio_space_offset of the host bridge window
isn't set correctly on systems with dino/cujo PCI host bridges.
This leads to not assigned memory bars and failing drivers, which
need to use these bars.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Acked-by: Helge Deller <deller@gmx.de>
Signed-off-by: Helge Deller <deller@gmx.de>
commit d76036ab47eafa6ce52b69482e91ca3ba337d6d6 upstream.
audit_remove_watch_rule() drops watch's reference to parent but then
continues to work with it. That is not safe as parent can get freed once
we drop our reference. The following is a trivial reproducer:
mount -o loop image /mnt
touch /mnt/file
auditctl -w /mnt/file -p wax
umount /mnt
auditctl -D
<crash in fsnotify_destroy_mark()>
Grab our own reference in audit_remove_watch_rule() earlier to make sure
mark does not get freed under us.
Reported-by: Tony Jones <tonyj@suse.de>
Tested-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Paul Moore <paul@paul-moore.com>
commit 9c3f3794926a997b1cab6c42480ff300efa2d162 upstream.
If one cpu is doing nf_ct_extend_unregister while another cpu is doing
__nf_ct_ext_add_length, then we may hit BUG_ON(t == NULL). Moreover,
there's no synchronize_rcu invocation after set nf_ct_ext_types[id] to
NULL, so it's possible that we may access invalid pointer.
But actually, most of the ct extends are built-in, so the problem listed
above will not happen. However, there are two exceptions: NF_CT_EXT_NAT
and NF_CT_EXT_SYNPROXY.
For _EXT_NAT, the panic will not happen, since adding the nat extend and
unregistering the nat extend are located in the same file(nf_nat_core.c),
this means that after the nat module is removed, we cannot add the nat
extend too.
For _EXT_SYNPROXY, synproxy extend may be added by init_conntrack, while
synproxy extend unregister will be done by synproxy_core_exit. So after
nf_synproxy_core.ko is removed, we may still try to add the synproxy
extend, then kernel panic may happen.
I know it's very hard to reproduce this issue, but I can play a tricky
game to make it happen very easily :)
Step 1. Enable SYNPROXY for tcp dport 1234 at FORWARD hook:
# iptables -I FORWARD -p tcp --dport 1234 -j SYNPROXY
Step 2. Queue the syn packet to the userspace at raw table OUTPUT hook.
Also note, in the userspace we only add a 20s' delay, then
reinject the syn packet to the kernel:
# iptables -t raw -I OUTPUT -p tcp --syn -j NFQUEUE --queue-num 1
Step 3. Using "nc 2.2.2.2 1234" to connect the server.
Step 4. Now remove the nf_synproxy_core.ko quickly:
# iptables -F FORWARD
# rmmod ipt_SYNPROXY
# rmmod nf_synproxy_core
Step 5. After 20s' delay, the syn packet is reinjected to the kernel.
Now you will see the panic like this:
kernel BUG at net/netfilter/nf_conntrack_extend.c:91!
Call Trace:
? __nf_ct_ext_add_length+0x53/0x3c0 [nf_conntrack]
init_conntrack+0x12b/0x600 [nf_conntrack]
nf_conntrack_in+0x4cc/0x580 [nf_conntrack]
ipv4_conntrack_local+0x48/0x50 [nf_conntrack_ipv4]
nf_reinject+0x104/0x270
nfqnl_recv_verdict+0x3e1/0x5f9 [nfnetlink_queue]
? nfqnl_recv_verdict+0x5/0x5f9 [nfnetlink_queue]
? nla_parse+0xa0/0x100
nfnetlink_rcv_msg+0x175/0x6a9 [nfnetlink]
One possible solution is to make NF_CT_EXT_SYNPROXY extend built-in, i.e.
introduce nf_conntrack_synproxy.c and only do ct extend register and
unregister in it, similar to nf_conntrack_timeout.c.
But having such a obscure restriction of nf_ct_extend_unregister is not a
good idea, so we should invoke synchronize_rcu after set nf_ct_ext_types
to NULL, and check the NULL pointer when do __nf_ct_ext_add_length. Then
it will be easier if we add new ct extend in the future.
Last, we use kfree_rcu to free nf_ct_ext, so rcu_barrier() is unnecessary
anymore, remove it too.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
Acked-by: Florian Westphal <fw@strlen.de>
Cc: Stefan Bader <stefan.bader@canonical.com>
commit 68fe55680d0f3342969f49412fceabb90bdfadba upstream.
Fix a commit 3021773c7c3e ("MIPS: DEC: Avoid la pseudo-instruction in
delay slots") regression and remove assembly errors:
arch/mips/dec/int-handler.S: Assembler messages:
arch/mips/dec/int-handler.S:162: Error: Macro used $at after ".set noat"
arch/mips/dec/int-handler.S:163: Error: Macro used $at after ".set noat"
arch/mips/dec/int-handler.S:229: Error: Macro used $at after ".set noat"
arch/mips/dec/int-handler.S:230: Error: Macro used $at after ".set noat"
triggering with with the CPU_DADDI_WORKAROUNDS option set and the DADDIU
instruction. This is because with that option in place the instruction
becomes a macro, which expands to an LI/DADDU (or actually ADDIU/DADDU)
sequence that uses $at as a temporary register.
With CPU_DADDI_WORKAROUNDS we only support `-msym32' compilation though,
and this is already enforced in arch/mips/Makefile, so choose the 32-bit
expansion variant for the supported configurations and then replace the
64-bit variant with #error just in case.
Fixes: 3021773c7c3e ("MIPS: DEC: Avoid la pseudo-instruction in delay slots")
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/16893/
commit 34e61801a3b9df74b69f0e359d64a197a77dd6ac upstream.
GPIODV_18 entry was missing in the original driver push.
Fixes: 468c234f9ed7 ("pinctrl: amlogic: Add support for Amlogic Meson GXBB SoC")
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Jerome Brunet <jbrunet@baylibre.com>
commit 3fa53ec2ed885b0aec3f0472e3b4a8a6f1cd748c upstream.
The irq chip callbacks irq_request/release_resources() have absolutely no
business with masking and unmasking the irq.
The core code unmasks the interrupt after complete setup and masks it
before invoking irq_release_resources().
The unmask is actually harmful as it happens before the interrupt is
completely initialized in __setup_irq().
Remove it.
Fixes: f6a8249f9e55 ("pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs")
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
commit 1bd303dc04c3f744474e77c153575087b657f7e1 upstream.
The pingroups dump of debugfs hits WARN_ON() in pinctrl_groups_show().
Filling non-existing ports with '-1' turned out a bad idea.
Fixes: 336306ee1f2d ("pinctrl: uniphier: add UniPhier PH1-LD20 pinctrl driver")
commit 9592bc256d50481dfcdba93890e576a728fb373c upstream.
Fixes: 70f2f9c4cf25 ("pinctrl: uniphier: add UniPhier PH1-LD11 pinctrl driver")
commit 5d996132d921c391af5f267123eca1a6a3148ecd upstream.
UART pin lists consist GPIO numbers which is simply wrong.
Replace it by pin numbers.
Fixes: 4e80c8f50574 ("pinctrl: intel: Add Intel Merrifield pin controller support")
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit d81ece747d8727bb8b1cfc9a20dbe62f09a4e35a upstream.
The PH16 pin has a function with mux id 0x5, which is the DET pin of the
"sim" (smart card reader) IP block.
This function is missing in old versions of A10/A20 SoCs' datasheets and
user manuals, so it's also missing in the old drivers. The newest A10
Datasheet V1.70 and A20 Datasheet V1.41 contain this pin function, and
it's discovered during implementing R40 pinctrl driver.
Add it to the driver. As we now merged A20 pinctrl driver to the A10
one, we need to only fix the A10 driver now.
Fixes: f2821b1ca3a2 ("pinctrl: sunxi: Move Allwinner A10 pinctrl
driver to a driver of its own")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
commit 8a9d6e964d318533ba3d2901ce153ba317c99a89 upstream.
The blocklayout code does not compile cleanly for a 32-bit sector_t,
and also has no reliable checks for devices sizes, which makes it
unsafe to use with a kernel that doesn't support large block devices.
Fixes: 5c83746a0cf2 ("pnfs/blocklayout: in-kernel GETDEVICEINFO XDR parsing")
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit d466d3c1217406b14b834335b5b4b33c0d45bd09 upstream.
In order to select the alternate voltage reference pair (VALTH/VALTL), the
right value for the REFSEL field in the ADCx_CFG register is "01", leading
to 0x800 as register mask. See section 8.2.6.4 in the reference manual[1].
[1] http://www.nxp.com/docs/en/reference-manual/VFXXXRM.pdf
Fixes: a775427632fd ("iio:adc:imx: add Freescale Vybrid vf610 adc driver")
Signed-off-by: Stefan-Gabriel Mirea <stefan-gabriel.mirea@nxp.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit e788787ef4f9c24aafefc480a8da5f92b914e5e6 upstream.
Certain HP keyboards would keep inputting a character automatically which
is the wake-up key after S3 resume
On some AMD platforms USB host fails to respond (by holding resume-K) to
USB device (an HP keyboard) resume request within 1ms (TURSM) and ensures
that resume is signaled for at least 20 ms (TDRSMDN), which is defined in
USB 2.0 spec. The result is that the keyboard is out of function.
In SNPS USB design, the host responds to the resume request only after
system gets back to S0 and the host gets to functional after the internal
HW restore operation that is more than 1 second after the initial resume
request from the USB device.
As a workaround for specific keyboard ID(HP Keyboards), applying port reset
after resume when the keyboard is plugged in.
Signed-off-by: Sandeep Singh <Sandeep.Singh@amd.com>
Signed-off-by: Shyam Sundar S K <Shyam-sundar.S-k@amd.com>
cc: Nehal Shah <Nehal-bakulchandra.Shah@amd.com>
Reviewed-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 7496cfe5431f21da5d27a8388c326397e3f0a5db upstream.
Moshi USB to Ethernet Adapter internally uses a Genesys Logic hub to
connect to Realtek r8153.
The Realtek r8153 ethernet does not work on the internal hub, no-lpm quirk
can make it work.
Since another r8153 dongle at my hand does not have the issue, so add
the quirk to the Genesys Logic hub instead.
commit 2eac13624364db5b5e1666ae0bb3a4d36bc56b6e upstream.
While unlink an urb, if the urb has been programmed in the controller,
the controller driver might do some hw related actions to tear down the
urb.
Currently usb_hcd_flush_endpoint() passes each urb from the head of the
endpoint's urb_list to the controller driver, which could make the
controller driver think each urb has been programmed and take the
unnecessary actions for each urb.
This patch changes the behavior in usb_hcd_flush_endpoint() to pass the
urbs from the tail of the list, to avoid any unnecessary actions in an
controller driver.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit 94c43b9897abf4ea366ed4dba027494e080c7050 upstream.
Some buggy USB disk adapters disconnect and reconnect multiple times
during the enumeration procedure. This may lead to a device
connecting at full speed instead of high speed, because when the USB
stack sees that a device isn't able to enumerate at high speed, it
tries to hand the connection over to a full-speed companion
controller.
The logic for doing this is careful to check that the device is still
connected. But this check is inadequate if the device disconnects and
reconnects before the check is done. The symptom is that a device
works, but much more slowly than it is capable of operating.
The situation was made worse recently by commit 22547c4cc4fe ("usb:
hub: Wait for connection to be reestablished after port reset"), which
increases the delay following a reset before a disconnect is
recognized, thus giving the device more time to reconnect.
This patch makes the check more robust. If the device was
disconnected at any time during enumeration, we will now skip the
full-speed handover.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Zdenek Kabelac <zkabelac@redhat.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit 2acecd58969897795cf015c9057ebd349a3fda8a upstream.
The latest HW manual (Rev.0.55) shows us this UGCTRL2.VBUSSEL bit.
If the bit sets to 1, the VBUS drive is controlled by phy related
registers (called "UCOM Registers" on the manual). Since R-Car Gen3
environment will control VBUS by phy-rcar-gen3-usb2 driver,
the UGCTRL2.VBUSSEL bit should be set to 1. So, this patch fixes
the register's value. Otherwise, even if the ID pin indicates to
peripheral, the R-Car will output USBn_PWEN to 1 when a host driver
is running.
Fixes: de18757e272d ("usb: renesas_usbhs: add R-Car Gen3 power control"
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit aca5b9ebd096039657417c321a9252c696b359c2 upstream.
According to the gadget.h, a "complete" function will always be called
with interrupts disabled. However, sometimes usb3_request_done() function
is called with interrupts enabled. So, this function should be held
by spin_lock_irqsave() to disable interruption. Also, this driver has
to call spin_unlock() to avoid spinlock recursion by this driver before
calling usb_gadget_giveback_request().
Reported-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
Tested-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
Fixes: 746bfe63bba3 ("usb: gadget: renesas_usb3: add support for Renesas USB3.0 peripheral controller")
commit 89f23d51defcb94a5026d4b5da13faf4e1150a6f upstream.
Similar to commit d595259fbb7a ("usb-storage: Add ignore-residue quirk for
Initio INIC-3619") for INIC-3169 in unusual_devs.h but INIC-3069 already
present in unusual_uas.h. Both in same controller IC family.
Issue is that MakeMKV fails during key exchange with installed bluray drive
with following error:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED'
occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
Signed-off-by: Alan Swanson <reiver@improbability.net>
Acked-by: Oliver Neukum <oneukum@suse.com>
commit cef988642cdac44e910a27cb6e8166c96f86a0df upstream.
Comedi's read and write file operation handlers (`comedi_read()` and
`comedi_write()`) currently call `copy_to_user()` or `copy_from_user()`
whilst in the `TASK_INTERRUPTIBLE` state, which falls foul of the
`might_fault()` checks when enabled. Fix it by setting the current task
state back to `TASK_RUNNING` a bit earlier before calling these
functions.
Reported-by: Piotr Gregor <piotrgregor@rsyncme.org>
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit a3507e48d3f99a93a3056a34a5365f310434570f upstream.
The TSL2563 driver provides three iio channels, two of which are raw ADC
channels (channel 0 and channel 1) in the device and the remaining one
is calculated by the two. The ADC channel 0 only supports programmable
interrupt with threshold settings and this driver supports the event but
the generated event code does not contain the corresponding iio channel
type.
This is going to change userspace ABI. Hopefully fixing this to be
what it should always have been won't break any userspace code.
Cc: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit e59e18989c68a8d7941005f81ad6abc4ca682de0 upstream.
After probe we would put the device in normal mode, after a runtime
suspend-resume we would put it back in normal mode. But for a regular
suspend-resume we would only put it back in normal mode if triggers
or events have been requested. This is not consistent and breaks
reading raw values after a suspend-resume.
This commit changes the regular resume path to also unconditionally put
the device back in normal mode, fixing reading of raw values not working
after a regular suspend-resume cycle.
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit 105967ad68d2eb1a041bc041f9cf96af2a653b65 upstream.
gcc-7 points out an older regression:
drivers/staging/iio/resolver/ad2s1210.c: In function 'ad2s1210_read_raw':
drivers/staging/iio/resolver/ad2s1210.c:515:42: error: '<<' in boolean context, did you mean '<' ? [-Werror=int-in-bool-context]
The original code had 'unsigned short' here, but incorrectly got
converted to 'bool'. This reverts the regression and uses a normal
type instead.
Fixes: 29148543c521 ("staging:iio:resolver:ad2s1210 minimal chan spec conversion.")
commit cd5a6a4fdaba150089af2afc220eae0fef74878a upstream.
Make usb_hc_died() clear the HCD_FLAG_RH_RUNNING flag for the shared
HCD and set HCD_FLAG_DEAD for it, in analogy with what is done for
the primary one.
Among other thigs, this prevents check_root_hub_suspended() from
returning -EBUSY for dead HCDs which helps to work around system
suspend issues in some situations.
This actually fixes occasional suspend failures on one of my test
machines.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
