commit 0a94efb5acbb6980d7c9ab604372d93cd507e4d8 upstream.
5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be
ordered") automatically enabled ordered attribute for unbound
workqueues w/ max_active == 1. Because ordered workqueues reject
max_active and some attribute changes, this implicit ordered mode
broke cases where the user creates an unbound workqueue w/ max_active
== 1 and later explicitly changes the related attributes.
This patch distinguishes explicit and implicit ordered setting and
overrides from attribute changes if implict.
Fixes: 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered")
Cc: Holger Hoffstätte <holger@applied-asynchrony.com>
commit 7b9a88a390dacb37b051a7b09b9a08f546edf5eb upstream.
The PHY library does not deal very well with bind and unbind events. The first
thing we would see is that we were not properly canceling the PHY state machine
workqueue, so we would be crashing while dereferencing phydev->drv since there
is no driver attached anymore.
Suggested-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit a5cb659bbc1c8644efa0c3138a757a1e432a4880 ]
Our customer encountered stuck NFS writes for blocks starting at specific
offsets w.r.t. page boundary caused by networking stack sending packets via
UFO enabled device with wrong checksum. The problem can be reproduced by
composing a long UDP datagram from multiple parts using MSG_MORE flag:
sendto(sd, buff, 1000, MSG_MORE, ...);
sendto(sd, buff, 3000, 0, ...);
Assume this packet is to be routed via a device with MTU 1500 and
NETIF_F_UFO enabled. When second sendto() gets into __ip_append_data(),
this condition is tested (among others) to decide whether to call
ip_ufo_append_data():
((length + fragheaderlen) > mtu) || (skb && skb_is_gso(skb))
At the moment, we already have skb with 1028 bytes of data which is not
marked for GSO so that the test is false (fragheaderlen is usually 20).
Thus we append second 1000 bytes to this skb without invoking UFO. Third
sendto(), however, has sufficient length to trigger the UFO path so that we
end up with non-UFO skb followed by a UFO one. Later on, udp_send_skb()
uses udp_csum() to calculate the checksum but that assumes all fragments
have correct checksum in skb->csum which is not true for UFO fragments.
When checking against MTU, we need to add skb->len to length of new segment
if we already have a partially filled skb and fragheaderlen only if there
isn't one.
In the IPv6 case, skb can only be null if this is the first segment so that
we have to use headersize (length of the first IPv6 header) rather than
fragheaderlen (length of IPv6 header of further fragments) for skb == NULL.
Fixes: e89e9cf539a2 ("[IPv4/IPv6]: UFO Scatter-gather approach")
Fixes: e4c5e13aa45c ("ipv6: Should use consistent conditional judgement for
ip6 fragment between __ip6_append_data and ip6_finish_output")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
__ip_append_data and ip_finish_output
[ Upstream commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 ]
There is an inconsistent conditional judgement in __ip_append_data and
ip_finish_output functions, the variable length in __ip_append_data just
include the length of application's payload and udp header, don't include
the length of ip header, but in ip_finish_output use
(skb->len > ip_skb_dst_mtu(skb)) as judgement, and skb->len include the
length of ip header.
That causes some particular application's udp payload whose length is
between (MTU - IP Header) and MTU were fragmented by ip_fragment even
though the rst->dev support UFO feature.
Add the length of ip header to length in __ip_append_data to keep
consistent conditional judgement as ip_finish_output for ip fragment.
Signed-off-by: Zheng Li <james.z.li@ericsson.com>
[ Upstream commit 5bae8c031053c69b4aa74b7f1ba15d4ec8426208 ]
We must re-enable RoCE on the e-switch management port (PF) only after destroying
the FDB in its switchdev/offloaded mode. Otherwise, when encapsulation is supported,
this re-enablement will fail.
Also, it's more natural and symmetric to disable RoCE on the PF before we create
the FDB under switchdev mode, so do that as well and revert if getting into error
during the mode change later.
Fixes: 9da34cd34e85 ('net/mlx5: Disable RoCE on the e-switch management [..]')
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Reviewed-by: Hadar Hen Zion <hadarh@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit f073bdc51771f5a5c7a8d1191bfc3ae371d44de7 ]
The VM_BUG_ON() check in move_freepages() checks whether the node id of
a page matches the node id of its zone. However, it does this before
having checked whether the struct page pointer refers to a valid struct
page to begin with. This is guaranteed in most cases, but may not be
the case if CONFIG_HOLES_IN_ZONE=y.
So reorder the VM_BUG_ON() with the pfn_valid_within() check.
Link: http://lkml.kernel.org/r/1481706707-6211-2-git-send-email-ard.biesheuvel@linaro.org
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Robert Richter <rrichter@cavium.com>
Cc: James Morse <james.morse@arm.com>
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ]
Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we
can now trace init processes. init is initially protected with
SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but
there are a number of paths during tracing where SIGNAL_UNKILLABLE can
be implicitly cleared.
This can result in init becoming stoppable/killable after tracing. For
example, running:
while true; do kill -STOP 1; done &
strace -p 1
and then stopping strace and the kill loop will result in init being
left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but
init will now respond to future SIGSTOP signals rather than ignoring
them.
Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED
that we don't clear SIGNAL_UNKILLABLE.
Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ]
The build of frv allmodconfig was failing with the errors like:
/tmp/cc0JSPc3.s: Assembler messages:
/tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined
/tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined
/tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined
/tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined
Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced
splitting the debug info and keeping that in a separate file. Somehow,
the frv-linux gcc did not like that and I am guessing that instead of
splitting it started copying. The first report about this is at:
https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html.
I will try and see if this can work with frv and if still fails I will
open a bug report with gcc. But meanwhile this is the easiest option to
solve build failure of frv.
Fixes: 866ced950bcd ("kbuild: Support split debug info v4")
Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit bb1107f7c6052c863692a41f78c000db792334bf ]
Andrey Konovalov has reported the following warning triggered by the
syzkaller fuzzer.
WARNING: CPU: 1 PID: 9935 at mm/page_alloc.c:3511 __alloc_pages_nodemask+0x159c/0x1e20
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 9935 Comm: syz-executor0 Not tainted 4.9.0-rc7+ #34
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__alloc_pages_slowpath mm/page_alloc.c:3511
__alloc_pages_nodemask+0x159c/0x1e20 mm/page_alloc.c:3781
alloc_pages_current+0x1c7/0x6b0 mm/mempolicy.c:2072
alloc_pages include/linux/gfp.h:469
kmalloc_order+0x1f/0x70 mm/slab_common.c:1015
kmalloc_order_trace+0x1f/0x160 mm/slab_common.c:1026
kmalloc_large include/linux/slab.h:422
__kmalloc+0x210/0x2d0 mm/slub.c:3723
kmalloc include/linux/slab.h:495
ep_write_iter+0x167/0xb50 drivers/usb/gadget/legacy/inode.c:664
new_sync_write fs/read_write.c:499
__vfs_write+0x483/0x760 fs/read_write.c:512
vfs_write+0x170/0x4e0 fs/read_write.c:560
SYSC_write fs/read_write.c:607
SyS_write+0xfb/0x230 fs/read_write.c:599
entry_SYSCALL_64_fastpath+0x1f/0xc2
The issue is caused by a lack of size check for the request size in
ep_write_iter which should be fixed. It, however, points to another
problem, that SLUB defines KMALLOC_MAX_SIZE too large because the its
KMALLOC_SHIFT_MAX is (MAX_ORDER + PAGE_SHIFT) which means that the
resulting page allocator request might be MAX_ORDER which is too large
(see __alloc_pages_slowpath).
The same applies to the SLOB allocator which allows even larger sizes.
Make sure that they are capped properly and never request more than
MAX_ORDER order.
Link: http://lkml.kernel.org/r/20161220130659.16461-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 270c8cf1cacc69cb8d99dea812f06067a45e4609 ]
ARM has a few system calls (most notably mmap) for which the names of
the functions which are referenced in the syscall table do not match the
names of the syscall tracepoints. As a consequence of this, these
tracepoints are not made available. Implement
arch_syscall_match_sym_name to fix this and allow tracing even these
system calls.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
[ Upstream commit 6bf6b0aa3da84a3d9126919a94c49c0fb7ee2fb3 ]
If blk_mq_init_queue() returns an error, it gets assigned to
vblk->disk->queue. Then, when we call put_disk(), we end up calling
blk_put_queue() with the ERR_PTR, causing a bad dereference. Fix it by
only assigning to vblk->disk->queue on success.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 25b4acfc7de0fc4da3bfea3a316f7282c6fbde81 ]
Additionally, don't assign directly to disk->queue, otherwise
blk_put_queue (called via put_disk) will choke (panic) on the errno
stored there.
Bug found by code inspection after Omar found a similar issue in
virtio_blk. Compile-tested only.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Josef Bacik <jbacik@fb.com>
[ Upstream commit 3bcf96e0183f5c863657cb6ae9adad307a0f6071 ]
Function rx_data(), which handles ingress CPL_RX_DATA messages, was
always sending an RX_DATA_ACK with the goal of updating the credits.
However, if the RDMA connection is moved out of FPDU mode abruptly,
then it is possible for iw_cxgb4 to process queued RX_DATA CPLs after HW
has aborted the connection. These CPLs should not trigger RX_DATA_ACKS.
If they do, HW can see a READ after DELETE of the DB_LE hash entry for
the tid and post a LE_DB HashTblMemCrcError.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 3116d37651d77125bf50f81f859b1278e02ccce6 ]
The node name for the power seq pin is mmc2@0 like the mmc2_pins_a one.
This makes the original node (mmc2_pins_a) scrapped out of the dtb and
result in a unusable eMMC if U-Boot didn't configured the pins to the
correct functions.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit 661ccdc1a95f18ab6c1373322fde09afd5b90a1f ]
The commit 10efbf5f1633 ("ARM: dts: sun8i: Add dts file for NanoPi M1 SBC")
introduced NanoPi M1 board but it's missing in Allwinner H3 DTB build.
Signed-off-by: Milo Kim <woogyom.kim@gmail.com>
[ Upstream commit 71d3f6ef7f5af38dea2975ec5715c88bae92e92d ]
virtio uses normal ram as backing storage for the framebuffer, so we
should assign the address to new screen_buffer (added by commit
17a7b0b4d9749f80d365d7baff5dec2f54b0e992) instead of screen_base.
Reported-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
[ Upstream commit c7702b8c22712a06080e10f1d2dee1a133ec8809 ]
There is a race condition with qla2xxx optrom functions where one thread
might modify optrom buffer, optrom_state while other thread is still
reading from it.
In couple of crashes, it was found that we had successfully passed the
following 'if' check where we confirm optrom_state to be
QLA_SREADING. But by the time we acquired mutex lock to proceed with
memory_read_from_buffer function, some other thread/process had already
modified that option rom buffer and optrom_state from QLA_SREADING to
QLA_SWAITING. Then we got ha->optrom_buffer 0x0 and crashed the system:
if (ha->optrom_state != QLA_SREADING)
return 0;
mutex_lock(&ha->optrom_mutex);
rval = memory_read_from_buffer(buf, count, &off, ha->optrom_buffer,
ha->optrom_region_size);
mutex_unlock(&ha->optrom_mutex);
With current optrom function we get following crash due to a race
condition:
[ 1479.466679] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1479.466707] IP: [<ffffffff81326756>] memcpy+0x6/0x110
[ 1479.473673] Call Trace:
[ 1479.474296] [<ffffffff81225cbc>] ? memory_read_from_buffer+0x3c/0x60
[ 1479.474941] [<ffffffffa01574dc>] qla2x00_sysfs_read_optrom+0x9c/0xc0 [qla2xxx]
[ 1479.475571] [<ffffffff8127e76b>] read+0xdb/0x1f0
[ 1479.476206] [<ffffffff811fdf9e>] vfs_read+0x9e/0x170
[ 1479.476839] [<ffffffff811feb6f>] SyS_read+0x7f/0xe0
[ 1479.477466] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b
Below patch modifies qla2x00_sysfs_read_optrom,
qla2x00_sysfs_write_optrom functions to get the mutex_lock before
checking ha->optrom_state to avoid similar crashes.
The patch was applied and tested and same crashes were no longer
observed again.
Tested-by: Milan P. Gandhi <mgandhi@redhat.com>
Signed-off-by: Milan P. Gandhi <mgandhi@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ Upstream commit 318fa46cc60d37fec1e87dbf03a82aca0f5ce695 ]
Some parent clocks of the Exynos542x clock blocks, which have separate
power domains (like DISP, MFC, MSC, GSC, FSYS and G2D) must be always
enabled to access any register related to power management unit or devices
connected to it. For the time being, until a proper solution based on
runtime PM is applied, mark those clocks as critical (instead of ignore
unused or even no flags) to prevent disabling them.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com> [Exynos5800 Peach Pi Chromebook]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit b007f09072ca8afa118ade333e717ba443e8d807 ]
> cat /proc/sys/net/ipv4/tcp_notsent_lowat
-1
> echo 4294967295 > /proc/sys/net/ipv4/tcp_notsent_lowat
-bash: echo: write error: Invalid argument
> echo -2147483648 > /proc/sys/net/ipv4/tcp_notsent_lowat
-2147483648
but in documentation we have "tcp_notsent_lowat - UNSIGNED INTEGER"
v2: simplify to just proc_douintvec
Signed-off-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
[ Upstream commit 811a919135b980bac8009d042acdccf10dc1ef5e ]
While in RUNNING state, phy_state_machine() checks for link changes by
comparing phydev->link before and after calling phy_read_status().
This works as long as it is guaranteed that phydev->link is never
changed outside the phy_state_machine().
If in some setups this happens, it causes the state machine to miss
a link loss and remain RUNNING despite phydev->link being 0.
This has been observed running a dsa setup with a process continuously
polling the link states over ethtool each second (SNMPD RFC-1213
agent). Disconnecting the link on a phy followed by a ETHTOOL_GSET
causes dsa_slave_get_settings() / dsa_slave_get_link_ksettings() to
call phy_read_status() and with that modify the link status - and
with that bricking the phy state machine.
This patch adds a fail-safe check while in RUNNING, which causes to
move to CHANGELINK when the link is gone and we are still RUNNING.
Signed-off-by: Zefir Kurtisi <zefir.kurtisi@neratec.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit cc31d43b4154ad5a7d8aa5543255a93b7e89edc2 ]
Otherwise, RST packets generated by ipt_REJECT always have mark 0 when
the routing is checked later in the same code path.
Fixes: e110861f8609 ("net: add a sysctl to reflect the fwmark on replies")
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Pau Espin Pedrol <pau.espin@tessares.net>
[ Upstream commit 02c5c03283c52157d336abf5e44ffcda10579fbf ]
The i2s clock pre-divider 1 is used for both i2s1 and sysclk.
The i2s1 is usually used for the main i2s and the pre-divider
will be set in hw_params function.
However, if i2s2 is used, the pre-divider is not set in the hw_params
function and the default value of i2s clock pre-divider 1 is too high
for sysclk and DMIC usage. Fix by overriding default divider value to 2.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=95681
Tested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Signed-off-by: Bard Liao <bardliao@realtek.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 9620ca90115d4bd700f05862d3b210a266a66efe ]
We should go to 'err_put_master' here instead of returning directly.
Otherwise a call to 'spi_master_put' is missing.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
[ Upstream commit fac69d0efad08fc15e4dbfc116830782acc0dc9a ]
Add the missing declarations of basic string functions to string.h to allow
a clean build.
Fixes: 5be865661516 ("String-handling functions for the new x86 setup code.")
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Link: http://lkml.kernel.org/r/1483781911-21399-1-git-send-email-hofrat@osadl.org
[ Upstream commit f5992b72ebe0dde488fa8f706b887194020c66fc ]
The driver's ndo_get_stats64() method is not always called under RTNL.
So it can race with driver close or ethtool reconfigurations. Fix the
race condition by taking tp->lock spinlock in tg3_free_consistent()
when freeing the tp->hw_stats memory block. tg3_get_stats64() is
already taking tp->lock.
Reported-by: Wang Yufen <wangyufen@huawei.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 5ca7d1ca77dc23934504b95a96d2660d345f83c2 ]
For proper IRQ generation by DP83867 phy the INT/PWDN pin has to be
programmed as an interrupt output instead of a Powerdown input in
Configuration Register 3 (CFG3), Address 0x001E, bit 7 INT_OE = 1. The
current driver doesn't do this and as result IRQs will not be generated by
DP83867 phy even if they are properly configured in DT.
Hence, fix IRQ generation by properly configuring CFG3.INT_OE bit and
ensure that Link Status Change (LINK_STATUS_CHNG_INT) and Auto-Negotiation
Complete (AUTONEG_COMP_INT) interrupt are enabled. After this the DP83867
driver will work properly in interrupt enabled mode.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
[ Upstream commit 0f1f9cbc04dbb3cc310f70a11cba0cf1f2109d9c ]
The R8A7740 GEther controller supports the packet checksum offloading
but the 'hw_crc' (bad name, I'll fix it) flag isn't set in the R8A7740
data, thus CSMR isn't cleared...
Fixes: 73a0d907301e ("net: sh_eth: add support R8A7740")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 978d3639fd13d987950e4ce85c8737ae92154b2c ]
As the SH77{34|63} manuals are freely available, I've checked the EESIPR
values written against the manuals, and they appeared to set the reserved
bits 11-15 (which should be 0 on write). Fix those EESIPR values.
Fixes: 380af9e390ec ("net: sh_eth: CPU dependency code collect to "struct sh_eth_cpu_data"")
Fixes: f5d12767c8fd ("sh_eth: get SH77{34|63} support out of #ifdef")
commit 93be2b74279c15c2844684b1a027fdc71dd5d9bf upstream.
gcc-7 complains that wl3501_cs passes NULL into a function that
then uses the argument as the input for memcpy:
drivers/net/wireless/wl3501_cs.c: In function 'wl3501_get_scan':
include/net/iw_handler.h:559:3: error: argument 2 null where non-null expected [-Werror=nonnull]
memcpy(stream + point_len, extra, iwe->u.data.length);
This works fine here because iwe->u.data.length is guaranteed to be 0
and the memcpy doesn't actually have an effect.
Making the length check explicit avoids the warning and should have
no other effect here.
Also check the pointer itself, since otherwise we get warnings
elsewhere in the code.
[ Upstream commit 0ede1c401332173ab0693121dc6cde04a4dbf131 ]
Mikael Pettersson reported that some test programs in the strace-4.18
testsuite cause an OOPS.
After some debugging it turns out that garbage values are returned
when an exception occurs, causing the fixup memset() to be run with
bogus arguments.
The problem is that two of the exception handler stubs write the
successfully copied length into the wrong register.
Fixes: ee841d0aff64 ("sparc64: Convert U3copy_{from,to}_user to accurate exception reporting.")
Reported-by: Mikael Pettersson <mikpelinux@gmail.com>
Tested-by: Mikael Pettersson <mikpelinux@gmail.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ]
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
[ Upstream commit dfa523ae9f2542bee4cddaea37b3be3e157f6e6b ]
Add a flag to indicate if a queue is rate-limited. Test the flag in
NAPI poll handler and avoid rescheduling the queue if true, otherwise
we risk locking up the host. The rescheduling will be done in the
timer callback function.
Reported-by: Jean-Louis Dupond <jean-louis@dupond.be>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Tested-by: Jean-Louis Dupond <jean-louis@dupond.be>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
[ Upstream commit 7ad813f208533cebfcc32d3d7474dc1677d1b09a ]
Marc reported that he was not getting the PHY library adjust_link()
callback function to run when calling phy_stop() + phy_disconnect()
which does not indeed happen because we set the state machine to
PHY_HALTED but we don't get to run it to process this state past that
point.
Fix this with a synchronous call to phy_state_machine() in order to have
the state machine actually act on PHY_HALTED, set the PHY device's link
down, turn the network device's carrier off and finally call the
adjust_link() function.
Reported-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Fixes: a390d1f379cf ("phylib: convert state_queue work to delayed_work")
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
[ Upstream commit f08c39ed0bfb503c7b3e013cd40d036ce6a0941a ]
This is done in order to ensure that work will not run after the cleanup.
Fixes: ef9814deafd0 ('net/mlx5e: Add HW timestamping (TS) support')
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com>
[ Upstream commit d439c84509a510e864fdc6166c760482cd03fc57 ]
The overflow_period is calculated in seconds. In order to use it
for delayed work scheduling translation to jiffies is needed.
[ Upstream commit 0242f4a0bb03906010bbf80495512be00494a0ef ]
outer_header_zero() routine checks if the outer_headers match of a
flow-table entry are all zero.
This function uses the size of whole fte_match_param, instead of just
the outer_headers member, causing failure to detect all-zeros if
any other members of the fte_match_param are non-zero.
Use the correct size for zero check.
Fixes: 6dc6071cfcde ("net/mlx5e: Add ethtool flow steering support")
Signed-off-by: Ilan Tayari <ilant@mellanox.com>
[ Upstream commit 219c81f7d1d5a89656cb3b53d3b4e11e93608d80 ]
When driver fail to allocate an entry to send command to FW, it must
notify the calling function and release the memory allocated for
this command.
Fixes: e126ba97dba9e ('mlx5: Add driver for Mellanox Connect-IB adapters')
Signed-off-by: Moshe Shemesh <moshe@mellanox.com>
Cc: kernel-team@fb.com
[ Upstream commit dc798b4cc0f2a06e7ad7d522403de274b86a0a6f ]
The tx_enabled lag event field is used to determine whether a slave is
active.
Current logic uses this value only if the mode is active-backup.
However, LACP mode, although considered a load balancing mode, can mark
a slave as inactive in certain situations (e.g., LACP timeout).
This fix takes the tx_enabled value into account when remapping, with
no respect to the LAG mode (this should not affect the behavior in XOR
mode, since in this mode both slaves are marked as active).
Fixes: 7907f23adc18 (net/mlx5: Implement RoCE LAG feature)
Signed-off-by: Aviv Heller <avivh@mellanox.com>
[ Upstream commit 6b84202c946cd3da3a8daa92c682510e9ed80321 ]
Commit b1f5bfc27a19 ("sctp: don't dereference ptr before leaving
_sctp_walk_{params, errors}()") tried to fix the issue that it
may overstep the chunk end for _sctp_walk_{params, errors} with
'chunk_end > offset(length) + sizeof(length)'.
But it introduced a side effect: When processing INIT, it verifies
the chunks with 'param.v == chunk_end' after iterating all params
by sctp_walk_params(). With the check 'chunk_end > offset(length)
+ sizeof(length)', it would return when the last param is not yet
accessed. Because the last param usually is fwdtsn supported param
whose size is 4 and 'chunk_end == offset(length) + sizeof(length)'
This is a badly issue even causing sctp couldn't process 4-shakes.
Client would always get abort when connecting to server, due to
the failure of INIT chunk verification on server.
The patch is to use 'chunk_end <= offset(length) + sizeof(length)'
instead of 'chunk_end < offset(length) + sizeof(length)' for both
_sctp_walk_params and _sctp_walk_errors.
Fixes: b1f5bfc27a19 ("sctp: don't dereference ptr before leaving _sctp_walk_{params, errors}()")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit b1f5bfc27a19f214006b9b4db7b9126df2dfdf5a ]
If the length field of the iterator (|pos.p| or |err|) is past the end
of the chunk, we shouldn't access it.
This bug has been detected by KMSAN. For the following pair of system
calls:
socket(PF_INET6, SOCK_STREAM, 0x84 /* IPPROTO_??? */) = 3
sendto(3, "A", 1, MSG_OOB, {sa_family=AF_INET6, sin6_port=htons(0),
inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0,
sin6_scope_id=0}, 28) = 1
the tool has reported a use of uninitialized memory:
BUG: KMSAN: use of uninitialized memory in sctp_rcv+0x17b8/0x43b0
CPU: 1 PID: 2940 Comm: probe Not tainted 4.11.0-rc5+ #2926
01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x172/0x1c0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:927
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:469
__sctp_rcv_init_lookup net/sctp/input.c:1074
__sctp_rcv_lookup_harder net/sctp/input.c:1233
__sctp_rcv_lookup net/sctp/input.c:1255
sctp_rcv+0x17b8/0x43b0 net/sctp/input.c:170
sctp6_rcv+0x32/0x70 net/sctp/ipv6.c:984
ip6_input_finish+0x82f/0x1ee0 net/ipv6/ip6_input.c:279
NF_HOOK ./include/linux/netfilter.h:257
ip6_input+0x239/0x290 net/ipv6/ip6_input.c:322
dst_input ./include/net/dst.h:492
ip6_rcv_finish net/ipv6/ip6_input.c:69
ipv6_rcv+0x1dbd/0x22e0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x2f6f/0x3a20 net/core/dev.c:4208
__netif_receive_skb net/core/dev.c:4246
process_backlog+0x667/0xba0 net/core/dev.c:4866
napi_poll net/core/dev.c:5268
net_rx_action+0xc95/0x1590 net/core/dev.c:5333
__do_softirq+0x485/0x942 kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902
</IRQ>
do_softirq kernel/softirq.c:328
__local_bh_enable_ip+0x25b/0x290 kernel/softirq.c:181
local_bh_enable+0x37/0x40 ./include/linux/bottom_half.h:31
rcu_read_unlock_bh ./include/linux/rcupdate.h:931
ip6_finish_output2+0x19b2/0x1cf0 net/ipv6/ip6_output.c:124
ip6_finish_output+0x764/0x970 net/ipv6/ip6_output.c:149
NF_HOOK_COND ./include/linux/netfilter.h:246
ip6_output+0x456/0x520 net/ipv6/ip6_output.c:163
dst_output ./include/net/dst.h:486
ip6_xmit+0x1841/0x1c00 net/ipv6/ip6_output.c:261
sctp_v6_xmit+0x3b7/0x470 net/sctp/ipv6.c:225
sctp_packet_transmit+0x38cb/0x3a20 net/sctp/output.c:632
sctp_outq_flush+0xeb3/0x46e0 net/sctp/outqueue.c:885
sctp_outq_uncork+0xb2/0xd0 net/sctp/outqueue.c:750
sctp_side_effects net/sctp/sm_sideeffect.c:1773
sctp_do_sm+0x6962/0x6ec0 net/sctp/sm_sideeffect.c:1147
sctp_primitive_ASSOCIATE+0x12c/0x160 net/sctp/primitive.c:88
sctp_sendmsg+0x43e5/0x4f90 net/sctp/socket.c:1954
inet_sendmsg+0x498/0x670 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633
sock_sendmsg net/socket.c:643
SYSC_sendto+0x608/0x710 net/socket.c:1696
SyS_sendto+0x8a/0xb0 net/socket.c:1664
do_syscall_64+0xe6/0x130 arch/x86/entry/common.c:285
entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246
RIP: 0033:0x401133
RSP: 002b:00007fff6d99cd38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000401133
RDX: 0000000000000001 RSI: 0000000000494088 RDI: 0000000000000003
RBP: 00007fff6d99cd90 R08: 00007fff6d99cd50 R09: 000000000000001c
R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000000
R13: 00000000004063d0 R14: 0000000000406460 R15: 0000000000000000
origin:
save_stack_trace+0x37/0x40 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:302
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:198
kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:211
slab_alloc_node mm/slub.c:2743
__kmalloc_node_track_caller+0x200/0x360 mm/slub.c:4351
__kmalloc_reserve net/core/skbuff.c:138
__alloc_skb+0x26b/0x840 net/core/skbuff.c:231
alloc_skb ./include/linux/skbuff.h:933
sctp_packet_transmit+0x31e/0x3a20 net/sctp/output.c:570
return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit e90ce2fc27cad7e7b1e72b9e66201a7a4c124c2b ]
In dccp_feat_init, when ccid_get_builtin_ccids failsto alloc
memory for rx.val, it should free tx.val before returning an
error.
[ Upstream commit b7953d3c0e30a5fc944f6b7bd0bcceb0794bcd85 ]
The patch "dccp: fix a memleak that dccp_ipv6 doesn't put reqsk
properly" fixed reqsk refcnt leak for dccp_ipv6. The same issue
exists on dccp_ipv4.
This patch is to fix it for dccp_ipv4.
[ Upstream commit 0c2232b0a71db0ac1d22f751aa1ac0cadb950fd2 ]
In dccp_v6_conn_request, after reqsk gets alloced and hashed into
ehash table, reqsk's refcnt is set 3. one is for req->rsk_timer,
one is for hlist, and the other one is for current using.
The problem is when dccp_v6_conn_request returns and finishes using
reqsk, it doesn't put reqsk. This will cause reqsk refcnt leaks and
reqsk obj never gets freed.
Jianlin found this issue when running dccp_memleak.c in a loop, the
system memory would run out.
dccp_memleak.c:
int s1 = socket(PF_INET6, 6, IPPROTO_IP);
bind(s1, &sa1, 0x20);
listen(s1, 0x9);
int s2 = socket(PF_INET6, 6, IPPROTO_IP);
connect(s2, &sa1, 0x20);
close(s1);
close(s2);
This patch is to put the reqsk before dccp_v6_conn_request returns,
just as what tcp_conn_request does.
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit 4813497b537c6208c90d6cbecac5072d347de900 ]
Before commit bf8f6952a233 ("Add blurb about RGMII") it was unclear
whose responsibility it was to insert the required clock skew, and
in hindsight, some PHY drivers got it wrong. The solution forward
is to introduce a new property, explicitly requiring skew from the
node to which it is attached. In the interim, this driver will handle
all 4 RGMII modes identically (no skew).
Fixes: 52dfc8301248 ("net: ethernet: add driver for Aurora VLSI NB8800 Ethernet controller")
[ Upstream commit afce615aaabfbaad02550e75c0bec106dafa1adf ]
RFC 2465 defines ipv6IfStatsOutFragFails as:
"The number of IPv6 datagrams that have been discarded
because they needed to be fragmented at this output
interface but could not be."
The existing implementation, instead, would increase the counter
twice in case we fail to allocate room for single fragments:
once for the fragment, once for the datagram.
This didn't look intentional though. In one of the two affected
affected failure paths, the double increase was simply a result
of a new 'goto fail' statement, introduced to avoid a skb leak.
The other path appears to be affected since at least 2.6.12-rc2.
Reported-by: Sabrina Dubroca <sdubroca@redhat.com>
Fixes: 1d325d217c7f ("ipv6: ip6_fragment: fix headroom tests and skb leak")
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit c800aaf8d869f2b9b47b10c5c312fe19f0a94042 ]
There are multiple reports showing we have a use-after-free in
the timer prb_retire_rx_blk_timer_expired(), where we use struct
tpacket_kbdq_core::pkbdq, a pg_vec, after it gets freed by
free_pg_vec().
The interesting part is it is not freed via packet_release() but
via packet_setsockopt(), which means we are not closing the socket.
Looking into the big and fat function packet_set_ring(), this could
happen if we satisfy the following conditions:
1. closing == 0, not on packet_release() path
2. req->tp_block_nr == 0, we don't allocate a new pg_vec
3. rx_ring->pg_vec is already set as V3, which means we already called
packet_set_ring() wtih req->tp_block_nr > 0 previously
4. req->tp_frame_nr == 0, pass sanity check
5. po->mapped == 0, never called mmap()
In this scenario we are clearing the old rx_ring->pg_vec, so we need
to free this pg_vec, but we don't stop the timer on this path because
of closing==0.
The timer has to be stopped as long as we need to free pg_vec, therefore
the check on closing!=0 is wrong, we should check pg_vec!=NULL instead.
Thanks to liujian for testing different fixes.
Reported-by: alexander.levin@verizon.com
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: liujian (CE) <liujian56@huawei.com>
Tested-by: liujian (CE) <liujian56@huawei.com>
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: Willem de Bruijn <willemdebruijn.kernel@gmail.com>
[ Upstream commit 69ec932e364b1ba9c3a2085fe96b76c8a3f71e7c ]
Before the 'type' is validated, we shouldn't use it to fetch the
ovs_ct_attr_lens's minlen and maxlen, else, out of bound access
may happen.
Fixes: 7f8a436eaa2c ("openvswitch: Add conntrack action")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit 9476d393667968b4a02afbe9d35a3558482b943e ]
DMA transfers are not allowed to buffers that are on the stack.
Therefore allocate a buffer to store the result of usb_control_message().
Fixes these bugreports:
https://bugzilla.kernel.org/show_bug.cgi?id=195217
https://bugzilla.redhat.com/show_bug.cgi?id=1421387
https://bugzilla.redhat.com/show_bug.cgi?id=1427398
Shortened kernel backtrace from 4.11.9-200.fc25.x86_64:
kernel: ------------[ cut here ]------------
kernel: WARNING: CPU: 3 PID: 2957 at drivers/usb/core/hcd.c:1587
kernel: transfer buffer not dma capable
kernel: Call Trace:
kernel: dump_stack+0x63/0x86
kernel: __warn+0xcb/0xf0
kernel: warn_slowpath_fmt+0x5a/0x80
kernel: usb_hcd_map_urb_for_dma+0x37f/0x570
kernel: ? try_to_del_timer_sync+0x53/0x80
kernel: usb_hcd_submit_urb+0x34e/0xb90
kernel: ? schedule_timeout+0x17e/0x300
kernel: ? del_timer_sync+0x50/0x50
kernel: ? __slab_free+0xa9/0x300
kernel: usb_submit_urb+0x2f4/0x560
kernel: ? urb_destroy+0x24/0x30
kernel: usb_start_wait_urb+0x6e/0x170
kernel: usb_control_msg+0xdc/0x120
kernel: mcs_get_reg+0x36/0x40 [mcs7780]
kernel: mcs_net_open+0xb5/0x5c0 [mcs7780]
Regression goes back to 4.9, so it's a good candidate for -stable.
Though it's the decision of the maintainer.
Thanks to Dan Williams for adding the "transfer buffer not dma capable"
warning in the first place. It instantly pointed me in the right direction.
Patch has been tested with transferring data from a Polar watch.
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
[ Upstream commit 153711f9421be5dbc973dc57a4109dc9d54c89b1 ]
virtnet_set_mac_address() interprets mac address as struct
sockaddr, but upper layer only allocates dev->addr_len
which is ETH_ALEN + sizeof(sa_family_t) in this case.
We lack a unified definition for mac address, so just fix
the upper layer, this also allows drivers to interpret it
to struct sockaddr freely.
Reported-by: David Ahern <dsahern@gmail.com>
