commit 888022c0473d079bff9b47fb50434b1f20f8f37f upstream.
Add compat ioctl support to dma-buf. This lets one to use DMA_BUF_IOCTL_SYNC
ioctl from 32bit application on 64bit kernel. Data structures for both 32
and 64bit modes are same, so there is no need for additional translation
layer.
Reviewed-by: Christian König <christian.koenig@amd.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1487683261-2655-1-git-send-email-m.szyprowski@samsung.com
transitions
commit 7c3945bc2073554bb2ecf983e073dee686679c53 upstream.
Save the qp context flags byte containing the flag disabling vlan stripping
in the RESET to INIT qp transition, rather than in the INIT to RTR
transition. Per the firmware spec, the flags in this byte are active
in the RESET to INIT transition.
As a result of saving the flags in the incorrect qp transition, when
switching dynamically from VGT to VST and back to VGT, the vlan
remained stripped (as is required for VST) and did not return to
not-stripped (as is required for VGT).
Fixes: f0f829bf42cd ("net/mlx4_core: Add immediate activate for VGT->VST->VGT")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
commit 291c566a28910614ce42d0ffe82196eddd6346f4 upstream.
In function mlx4_cq_completion() and mlx4_cq_event(), the
radix_tree_lookup requires a rcu_read_lock.
This is mandatory: if another core frees the CQ, it could
run the radix_tree_node_rcu_free() call_rcu() callback while
its being used by the radix tree lookup function.
Additionally, in function mlx4_cq_event(), since we are adding
the rcu lock around the radix-tree lookup, we no longer need to take
the spinlock. Also, the synchronize_irq() call for the async event
eliminates the need for incrementing the cq reference count in
mlx4_cq_event().
Other changes:
1. In function mlx4_cq_free(), replace spin_lock_irq with spin_lock:
we no longer take this spinlock in the interrupt context.
The spinlock here, therefore, simply protects against different
threads simultaneously invoking mlx4_cq_free() for different cq's.
2. In function mlx4_cq_free(), we move the radix tree delete to before
the synchronize_irq() calls. This guarantees that we will not
access this cq during any subsequent interrupts, and therefore can
safely free the CQ after the synchronize_irq calls. The rcu_read_lock
in the interrupt handlers only needs to protect against corrupting the
radix tree; the interrupt handlers may access the cq outside the
rcu_read_lock due to the synchronize_irq calls which protect against
premature freeing of the cq.
3. In function mlx4_cq_event(), we change the mlx_warn message to mlx4_dbg.
4. We leave the cq reference count mechanism in place, because it is
still needed for the cq completion tasklet mechanism.
Fixes: 6d90aa5cf17b ("net/mlx4_core: Make sure there are no pending async events when freeing CQ")
Fixes: 225c7b1feef1 ("IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adapters")
Signed-off-by: Matan Barak <matanb@mellanox.com>
commit 6496bbf0ec481966ef9ffe5b6660d8d1b55c60cc upstream.
Single send WQE in RX buffer should be stamped with software
ownership in order to prevent the flow of QP in error in FW
once UPDATE_QP is called.
Fixes: 9f519f68cfff ('mlx4_en: Not using Shared Receive Queues')
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com>
commit 22547c4cc4fe20698a6a85a55b8788859134b8e4 upstream.
On a system with a defective USB device connected to an USB hub,
an endless sequence of port connect events was observed. The sequence
of events as observed is as follows:
- Port reports connected event (port status=USB_PORT_STAT_CONNECTION).
- Event handler debounces port and resets it by calling hub_port_reset().
- hub_port_reset() calls hub_port_wait_reset() to wait for the reset
to complete.
- The reset completes, but USB_PORT_STAT_CONNECTION is not immediately
set in the port status register.
- hub_port_wait_reset() returns -ENOTCONN.
- Port initialization sequence is aborted.
- A few milliseconds later, the port again reports a connected event,
and the sequence repeats.
This continues either forever or, randomly, stops if the connection
is already re-established when the port status is read. It results in
a high rate of udev events. This in turn destabilizes userspace since
the above sequence holds the device mutex pretty much continuously
and prevents userspace from actually reading the device status.
To prevent the problem from happening, let's wait for the connection
to be re-established after a port reset. If the device was actually
disconnected, the code will still return an error, but it will do so
only after the long reset timeout.
Cc: Douglas Anderson <dianders@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 36e1f3d107867b25c616c2fd294f5a1c9d4e5d09 upstream.
While stressing memory and IO at the same time we changed SMT settings,
we were able to consistently trigger deadlocks in the mm system, which
froze the entire machine.
I think that under memory stress conditions, the large allocations
performed by blk_mq_init_rq_map may trigger a reclaim, which stalls
waiting on the block layer remmaping completion, thus deadlocking the
system. The trace below was collected after the machine stalled,
waiting for the hotplug event completion.
The simplest fix for this is to make allocations in this path
non-reclaimable, with GFP_NOIO. With this patch, We couldn't hit the
issue anymore.
This should apply on top of Jens's for-next branch cleanly.
Changes since v1:
- Use GFP_NOIO instead of GFP_NOWAIT.
Call Trace:
[c000000f0160aaf0] [c000000f0160ab50] 0xc000000f0160ab50 (unreliable)
[c000000f0160acc0] [c000000000016624] __switch_to+0x2e4/0x430
[c000000f0160ad20] [c000000000b1a880] __schedule+0x310/0x9b0
[c000000f0160ae00] [c000000000b1af68] schedule+0x48/0xc0
[c000000f0160ae30] [c000000000b1b4b0] schedule_preempt_disabled+0x20/0x30
[c000000f0160ae50] [c000000000b1d4fc] __mutex_lock_slowpath+0xec/0x1f0
[c000000f0160aed0] [c000000000b1d678] mutex_lock+0x78/0xa0
[c000000f0160af00] [d000000019413cac] xfs_reclaim_inodes_ag+0x33c/0x380 [xfs]
[c000000f0160b0b0] [d000000019415164] xfs_reclaim_inodes_nr+0x54/0x70 [xfs]
[c000000f0160b0f0] [d0000000194297f8] xfs_fs_free_cached_objects+0x38/0x60 [xfs]
[c000000f0160b120] [c0000000003172c8] super_cache_scan+0x1f8/0x210
[c000000f0160b190] [c00000000026301c] shrink_slab.part.13+0x21c/0x4c0
[c000000f0160b2d0] [c000000000268088] shrink_zone+0x2d8/0x3c0
[c000000f0160b380] [c00000000026834c] do_try_to_free_pages+0x1dc/0x520
[c000000f0160b450] [c00000000026876c] try_to_free_pages+0xdc/0x250
[c000000f0160b4e0] [c000000000251978] __alloc_pages_nodemask+0x868/0x10d0
[c000000f0160b6f0] [c000000000567030] blk_mq_init_rq_map+0x160/0x380
[c000000f0160b7a0] [c00000000056758c] blk_mq_map_swqueue+0x33c/0x360
[c000000f0160b820] [c000000000567904] blk_mq_queue_reinit+0x64/0xb0
[c000000f0160b850] [c00000000056a16c] blk_mq_queue_reinit_notify+0x19c/0x250
[c000000f0160b8a0] [c0000000000f5d38] notifier_call_chain+0x98/0x100
[c000000f0160b8f0] [c0000000000c5fb0] __cpu_notify+0x70/0xe0
[c000000f0160b930] [c0000000000c63c4] notify_prepare+0x44/0xb0
[c000000f0160b9b0] [c0000000000c52f4] cpuhp_invoke_callback+0x84/0x250
[c000000f0160ba10] [c0000000000c570c] cpuhp_up_callbacks+0x5c/0x120
[c000000f0160ba60] [c0000000000c7cb8] _cpu_up+0xf8/0x1d0
[c000000f0160bac0] [c0000000000c7eb0] do_cpu_up+0x120/0x150
[c000000f0160bb40] [c0000000006fe024] cpu_subsys_online+0x64/0xe0
[c000000f0160bb90] [c0000000006f5124] device_online+0xb4/0x120
[c000000f0160bbd0] [c0000000006f5244] online_store+0xb4/0xc0
[c000000f0160bc20] [c0000000006f0a68] dev_attr_store+0x68/0xa0
[c000000f0160bc60] [c0000000003ccc30] sysfs_kf_write+0x80/0xb0
[c000000f0160bca0] [c0000000003cbabc] kernfs_fop_write+0x17c/0x250
[c000000f0160bcf0] [c00000000030fe6c] __vfs_write+0x6c/0x1e0
[c000000f0160bd90] [c000000000311490] vfs_write+0xd0/0x270
[c000000f0160bde0] [c0000000003131fc] SyS_write+0x6c/0x110
[c000000f0160be30] [c000000000009204] system_call+0x38/0xec
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Brian King <brking@linux.vnet.ibm.com>
Cc: Douglas Miller <dougmill@linux.vnet.ibm.com>
Cc: linux-block@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 2b6867c2ce76c596676bec7d2d525af525fdc6e2 upstream.
Subtracting tp_sizeof_priv from tp_block_size and casting to int
to check whether one is less then the other doesn't always work
(both of them are unsigned ints).
Compare them as is instead.
Also cast tp_sizeof_priv to u64 before using BLK_PLUS_PRIV, as
it can overflow inside BLK_PLUS_PRIV otherwise.
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
This reverts commit f2a0409a08502d64fbe3990354dff5902b08d2fb which is
commit bafb2f7d4755bf1571bd5e9a03b97f3fc4fe69ae upstream.
It was reported to have problems.
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Eric Blau <eblau1@gmail.com>
Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
commit 33fa46d7b310e06d2cb2ab5417c100af120bfb65 upstream.
In case caam_jr_alloc() fails, ctx->dev carries the error code,
thus accessing it with dev_err() is incorrect.
Fixes: 8c419778ab57e ("crypto: caam - add support for RSA algorithm")
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit 40c98cb57cdbc377456116ad4582c89e329721b0 upstream.
RNG instantiation was previously fixed by
commit 62743a4145bb9 ("crypto: caam - fix RNG init descriptor ret. code checking")
while deinstantiation was not addressed.
Since the descriptors used are similar, in the sense that they both end
with a JUMP HALT command, checking for errors should be similar too,
i.e. status code 7000_0000h should be considered successful.
Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles")
commit c25f8064c1d5731a2ce5664def890140dcdd3e5c upstream.
Commit dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts")
changed both the normal and vectored interrupt handlers. Unfortunately
the vectored version, "except_vec_vi_handler", was incorrectly modified
to unconditionally jal to plat_irq_dispatch, rather than doing a jalr to
the vectored handler that has been set up. This is ok for many platforms
which set the vectored handler to plat_irq_dispatch anyway, but will
cause problems with platforms that use other handlers.
Fixes: dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts")
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15110/
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 3cc3434fd6307d06b53b98ce83e76bf9807689b9 upstream.
Since do_IRQ is now invoked on a separate IRQ stack, we select
HAVE_IRQ_EXIT_ON_IRQ_STACK so that softirq's may be invoked directly
from irq_exit(), rather than requiring do_softirq_own_stack.
Acked-by: Jason A. Donenfeld <jason@zx2c4.com>
Patchwork: https://patchwork.linux-mips.org/patch/14744/
commit dda45f701c9d7ad4ac0bb446e3a96f6df9a468d9 upstream.
When enterring interrupt context via handle_int or except_vec_vi, switch
to the irq_stack of the current CPU if it is not already in use.
The current stack pointer is masked with the thread size and compared to
the base or the irq stack. If it does not match then the stack pointer
is set to the top of that stack, otherwise this is a nested irq being
handled on the irq stack so the stack pointer should be left as it was.
The in-use stack pointer is placed in the callee saved register s1. It
will be saved to the stack when plat_irq_dispatch is invoked and can be
restored once control returns here.
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14743/
commit 510d86362a27577f5ee23f46cfb354ad49731e61 upstream.
The SAVE_SOME macro is used to save the execution context on all
exceptions.
If an exception occurs while executing user code, the stack is switched
to the kernel's stack for the current task, and register $28 is switched
to point to the current_thread_info, which is at the bottom of the stack
region.
If the exception occurs while executing kernel code, the stack is left,
and this change ensures that register $28 is not updated. This is the
correct behaviour when the kernel can be executing on the separate irq
stack, because the thread_info will not be at the base of it.
With this change, register $28 is only switched to it's kernel
conventional usage of the currrent thread info pointer at the point at
which execution enters kernel space. Doing it on every exception was
redundant, but OK without an IRQ stack, but will be erroneous once that
is introduced.
Patchwork: https://patchwork.linux-mips.org/patch/14742/
commit d42d8d106b0275b027c1e8992c42aecf933436ea upstream.
Within unwind stack, check if the stack pointer being unwound is within
the CPU's irq_stack and if so use that page rather than the task's stack
page.
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: Maciej W. Rozycki <macro@imgtec.com>
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Patchwork: https://patchwork.linux-mips.org/patch/14741/
commit fe8bd18ffea5327344d4ec2bf11f47951212abd0 upstream.
Allocate a per-cpu irq stack for use within interrupt handlers.
Also add a utility function on_irq_stack to determine if a given stack
pointer is within the irq stack for that cpu.
Cc: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Patchwork: https://patchwork.linux-mips.org/patch/14740/
commit bd5d21310133921021d78995ad6346f908483124 upstream.
After parsing TRX we should skip to the first block placed behind it.
Our code was working only with TRX with length not aligned to the
blocksize. In other cases (length aligned) it was missing the block
places right after TRX.
This fixes calculation and simplifies the comment.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit a083c8fd277b4122c804f18ec8c84165f345c71c upstream.
In device removal routine, usage of "#ifdef CONFIG_RT2X00_LIB_USB"
will not cover the case when it is configured as module. This will
omit the entire if-block which does cleanup of URBs and cancellation
of pending work. Changing the #ifdef to #if IS_ENABLED() to fix it.
Signed-off-by: Vishal Thanki <vishalthanki@gmail.com>
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 93c7018ec16bb83399dd4db61c361a6d6aba0d5a upstream.
We might kill TX or RX urb during rt2x00usb_flush_entry(), what can
cause anchor list corruption like shown below:
[ 2074.035633] WARNING: CPU: 2 PID: 14480 at lib/list_debug.c:33 __list_add+0xac/0xc0
[ 2074.035634] list_add corruption. prev->next should be next (ffff88020f362c28), but was dead000000000100. (prev=ffff8801d161bb70).
<snip>
[ 2074.035670] Call Trace:
[ 2074.035672] [<ffffffff813bde47>] dump_stack+0x63/0x8c
[ 2074.035674] [<ffffffff810a2231>] __warn+0xd1/0xf0
[ 2074.035676] [<ffffffff810a22af>] warn_slowpath_fmt+0x5f/0x80
[ 2074.035678] [<ffffffffa073855d>] ? rt2x00usb_register_write_lock+0x3d/0x60 [rt2800usb]
[ 2074.035679] [<ffffffff813dbe4c>] __list_add+0xac/0xc0
[ 2074.035681] [<ffffffff81591c6c>] usb_anchor_urb+0x4c/0xa0
[ 2074.035683] [<ffffffffa07322af>] rt2x00usb_kick_rx_entry+0xaf/0x100 [rt2x00usb]
[ 2074.035684] [<ffffffffa0732322>] rt2x00usb_clear_entry+0x22/0x30 [rt2x00usb]
To fix do not anchor TX and RX urb's, it is not needed as during
shutdown we kill those urbs in rt2x00usb_free_entries().
Cc: Vishal Thanki <vishalthanki@gmail.com>
Fixes: 8b4c0009313f ("rt2x00usb: Use usb anchor to manage URB")
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0488a6121dfe6cbd44de15ea3627913b7549a1e9 upstream.
If device fail to initialize we can OOPS in rt2x00lib_remove_dev(), due
to using uninitialized usb_anchor structure:
[ 855.435820] ieee80211 phy3: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1000 with error -19
[ 855.435826] ieee80211 phy3: rt2800_probe_rt: Error - Invalid RT chipset 0x0000, rev 0000 detected
[ 855.435829] ieee80211 phy3: rt2x00lib_probe_dev: Error - Failed to allocate device
[ 855.435845] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
[ 855.435900] IP: _raw_spin_lock_irq+0xd/0x30
[ 855.435926] PGD 0
[ 855.435953] Oops: 0002 [#1] SMP
<snip>
[ 855.437011] Call Trace:
[ 855.437029] ? usb_kill_anchored_urbs+0x27/0xc0
[ 855.437061] rt2x00lib_remove_dev+0x190/0x1c0 [rt2x00lib]
[ 855.437097] rt2x00lib_probe_dev+0x246/0x7a0 [rt2x00lib]
[ 855.437149] ? ieee80211_roc_setup+0x9e/0xd0 [mac80211]
[ 855.437183] ? __kmalloc+0x1af/0x1f0
[ 855.437207] ? rt2x00usb_probe+0x13d/0xc50 [rt2x00usb]
[ 855.437240] rt2x00usb_probe+0x155/0xc50 [rt2x00usb]
[ 855.437273] rt2800usb_probe+0x15/0x20 [rt2800usb]
[ 855.437304] usb_probe_interface+0x159/0x2d0
[ 855.437333] driver_probe_device+0x2bb/0x460
Patch changes initialization sequence to fix the problem.
Cc: Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit e2474541032db65d02bf88b6a8c2f954654b443f upstream.
Writing messages larger than the FIFO size results in a hang, rendering
the machine unusable. This is because the RXD status flag is set on the
first interrupt which results in bcm2835_drain_rxfifo() stealing bytes
from the buffer. The controller continues to trigger interrupts waiting
for the missing bytes, but bcm2835_fill_txfifo() has none to give.
In this situation wait_for_completion_timeout() apparently is unable to
stop the madness.
The BCM2835 ARM Peripherals datasheet has this to say about the flags:
TXD: is set when the FIFO has space for at least one byte of data.
RXD: is set when the FIFO contains at least one byte of data.
TXW: is set during a write transfer and the FIFO is less than full.
RXR: is set during a read transfer and the FIFO is or more full.
Implementing the logic from the downstream i2c-bcm2708 driver solved
the hang problem.
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
Reviewed-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Martin Sperl <kernel@martin.sperl.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit eb68d0324dc4d88ab0d6159bdcd98c247a3a8954 upstream.
The deamon through which the kernel module communicates with the userspace
part of Orangefs, the "client-core", sends initialization data to the
kernel module with ioctl. The initialization data was built by the
client-core in a 2k buffer and copy_from_user'd into a 1k buffer
in the kernel module. When more than 1k of initialization data needed
to be sent, some was lost, reducing the usability of the control by which
debug levels are set. This patch sets the kernel side buffer to 2K to
match the userspace side...
Signed-off-by: Mike Marshall <hubcap@omnibond.com>
Signed-off-by: Martin Brandenburg <martin@omnibond.com>
commit 05973c2efb40122f2a9ecde2d065f7ea5068d024 upstream.
This patch is simlar to one Dan Carpenter sent me, cleans
up some return codes and whitespace errors. There was one
place where he thought inserting an error message into
the ring buffer might be too chatty, I hope I convinced him
othewise. As a consolation <g> I changed a truly chatty
error message in another location into a debug message,
system-admins had already yelled at me about that one...
commit 4defb5f912a0ba60e07e91a4b62634814cd99b7f upstream.
allocates string 'new' is not free'd on the exit path when
cdm_element_count <= 0. Fix this by kfree'ing it.
Fixes CoverityScan CID#1375923 "Resource Leak"
commit 3d3d18f086cdda72ee18a454db70ca72c6e3246c upstream.
The rcu_barrier() takes the cpu_hotplug mutex which itself is not
reclaim-safe, and so rcu_barrier() is illegal from inside the shrinker.
[ 309.661373] =========================================================
[ 309.661376] [ INFO: possible irq lock inversion dependency detected ]
[ 309.661380] 4.11.0-rc1-CI-CI_DRM_2333+ #1 Tainted: G W
[ 309.661383] ---------------------------------------------------------
[ 309.661386] gem_exec_gttfil/6435 just changed the state of lock:
[ 309.661389] (rcu_preempt_state.barrier_mutex){+.+.-.}, at: [<ffffffff81100731>] _rcu_barrier+0x31/0x160
[ 309.661399] but this lock took another, RECLAIM_FS-unsafe lock in the past:
[ 309.661402] (cpu_hotplug.lock){+.+.+.}
[ 309.661404]
and interrupts could create inverse lock ordering between them.
[ 309.661410]
[ 309.661414] Possible interrupt unsafe locking scenario:
[ 309.661417] CPU0 CPU1
[ 309.661419] ---- ----
[ 309.661421] lock(cpu_hotplug.lock);
[ 309.661425] local_irq_disable();
[ 309.661432] lock(rcu_preempt_state.barrier_mutex);
[ 309.661441] lock(cpu_hotplug.lock);
[ 309.661446] <Interrupt>
[ 309.661448] lock(rcu_preempt_state.barrier_mutex);
[ 309.661453]
*** DEADLOCK ***
[ 309.661460] 4 locks held by gem_exec_gttfil/6435:
[ 309.661464] #0: (sb_writers#10){.+.+.+}, at: [<ffffffff8120d83d>] vfs_write+0x17d/0x1f0
[ 309.661475] #1: (debugfs_srcu){......}, at: [<ffffffff81320491>] debugfs_use_file_start+0x41/0xa0
[ 309.661486] #2: (&attr->mutex){+.+.+.}, at: [<ffffffff8123a3e7>] simple_attr_write+0x37/0xe0
[ 309.661495] #3: (&dev->struct_mutex){+.+.+.}, at: [<ffffffffa0091b4a>] i915_drop_caches_set+0x3a/0x150 [i915]
[ 309.661540]
the shortest dependencies between 2nd lock and 1st lock:
[ 309.661547] -> (cpu_hotplug.lock){+.+.+.} ops: 829 {
[ 309.661553] HARDIRQ-ON-W at:
[ 309.661560] __lock_acquire+0x5e5/0x1b50
[ 309.661565] lock_acquire+0xc9/0x220
[ 309.661572] __mutex_lock+0x6e/0x990
[ 309.661576] mutex_lock_nested+0x16/0x20
[ 309.661583] get_online_cpus+0x61/0x80
[ 309.661590] kmem_cache_create+0x25/0x1d0
[ 309.661596] debug_objects_mem_init+0x30/0x249
[ 309.661602] start_kernel+0x341/0x3fe
[ 309.661607] x86_64_start_reservations+0x2a/0x2c
[ 309.661612] x86_64_start_kernel+0x173/0x186
[ 309.661619] verify_cpu+0x0/0xfc
[ 309.661622] SOFTIRQ-ON-W at:
[ 309.661627] __lock_acquire+0x611/0x1b50
[ 309.661632] lock_acquire+0xc9/0x220
[ 309.661636] __mutex_lock+0x6e/0x990
[ 309.661641] mutex_lock_nested+0x16/0x20
[ 309.661646] get_online_cpus+0x61/0x80
[ 309.661650] kmem_cache_create+0x25/0x1d0
[ 309.661655] debug_objects_mem_init+0x30/0x249
[ 309.661660] start_kernel+0x341/0x3fe
[ 309.661664] x86_64_start_reservations+0x2a/0x2c
[ 309.661669] x86_64_start_kernel+0x173/0x186
[ 309.661674] verify_cpu+0x0/0xfc
[ 309.661677] RECLAIM_FS-ON-W at:
[ 309.661682] mark_held_locks+0x6f/0xa0
[ 309.661687] lockdep_trace_alloc+0xb3/0x100
[ 309.661693] kmem_cache_alloc_trace+0x31/0x2e0
[ 309.661699] __smpboot_create_thread.part.1+0x27/0xe0
[ 309.661704] smpboot_create_threads+0x61/0x90
[ 309.661709] cpuhp_invoke_callback+0x9c/0x8a0
[ 309.661713] cpuhp_up_callbacks+0x31/0xb0
[ 309.661718] _cpu_up+0x7a/0xc0
[ 309.661723] do_cpu_up+0x5f/0x80
[ 309.661727] cpu_up+0xe/0x10
[ 309.661734] smp_init+0x71/0xb3
[ 309.661738] kernel_init_freeable+0x94/0x19e
[ 309.661743] kernel_init+0x9/0xf0
[ 309.661748] ret_from_fork+0x2e/0x40
[ 309.661752] INITIAL USE at:
[ 309.661757] __lock_acquire+0x234/0x1b50
[ 309.661761] lock_acquire+0xc9/0x220
[ 309.661766] __mutex_lock+0x6e/0x990
[ 309.661771] mutex_lock_nested+0x16/0x20
[ 309.661775] get_online_cpus+0x61/0x80
[ 309.661780] __cpuhp_setup_state+0x44/0x170
[ 309.661785] page_alloc_init+0x23/0x3a
[ 309.661790] start_kernel+0x124/0x3fe
[ 309.661794] x86_64_start_reservations+0x2a/0x2c
[ 309.661799] x86_64_start_kernel+0x173/0x186
[ 309.661804] verify_cpu+0x0/0xfc
[ 309.661807] }
[ 309.661813] ... key at: [<ffffffff81e37690>] cpu_hotplug+0xb0/0x100
[ 309.661817] ... acquired at:
[ 309.661821] lock_acquire+0xc9/0x220
[ 309.661825] __mutex_lock+0x6e/0x990
[ 309.661829] mutex_lock_nested+0x16/0x20
[ 309.661833] get_online_cpus+0x61/0x80
[ 309.661837] _rcu_barrier+0x9f/0x160
[ 309.661841] rcu_barrier+0x10/0x20
[ 309.661847] netdev_run_todo+0x5f/0x310
[ 309.661852] rtnl_unlock+0x9/0x10
[ 309.661856] default_device_exit_batch+0x133/0x150
[ 309.661862] ops_exit_list.isra.0+0x4d/0x60
[ 309.661866] cleanup_net+0x1d8/0x2c0
[ 309.661872] process_one_work+0x1f4/0x6d0
[ 309.661876] worker_thread+0x49/0x4a0
[ 309.661881] kthread+0x107/0x140
[ 309.661884] ret_from_fork+0x2e/0x40
[ 309.661890] -> (rcu_preempt_state.barrier_mutex){+.+.-.} ops: 179 {
[ 309.661896] HARDIRQ-ON-W at:
[ 309.661901] __lock_acquire+0x5e5/0x1b50
[ 309.661905] lock_acquire+0xc9/0x220
[ 309.661910] __mutex_lock+0x6e/0x990
[ 309.661914] mutex_lock_nested+0x16/0x20
[ 309.661919] _rcu_barrier+0x31/0x160
[ 309.661923] rcu_barrier+0x10/0x20
[ 309.661928] netdev_run_todo+0x5f/0x310
[ 309.661932] rtnl_unlock+0x9/0x10
[ 309.661936] default_device_exit_batch+0x133/0x150
[ 309.661941] ops_exit_list.isra.0+0x4d/0x60
[ 309.661946] cleanup_net+0x1d8/0x2c0
[ 309.661951] process_one_work+0x1f4/0x6d0
[ 309.661955] worker_thread+0x49/0x4a0
[ 309.661960] kthread+0x107/0x140
[ 309.661964] ret_from_fork+0x2e/0x40
[ 309.661968] SOFTIRQ-ON-W at:
[ 309.661972] __lock_acquire+0x611/0x1b50
[ 309.661977] lock_acquire+0xc9/0x220
[ 309.661981] __mutex_lock+0x6e/0x990
[ 309.661986] mutex_lock_nested+0x16/0x20
[ 309.661990] _rcu_barrier+0x31/0x160
[ 309.661995] rcu_barrier+0x10/0x20
[ 309.661999] netdev_run_todo+0x5f/0x310
[ 309.662003] rtnl_unlock+0x9/0x10
[ 309.662008] default_device_exit_batch+0x133/0x150
[ 309.662013] ops_exit_list.isra.0+0x4d/0x60
[ 309.662017] cleanup_net+0x1d8/0x2c0
[ 309.662022] process_one_work+0x1f4/0x6d0
[ 309.662027] worker_thread+0x49/0x4a0
[ 309.662031] kthread+0x107/0x140
[ 309.662035] ret_from_fork+0x2e/0x40
[ 309.662039] IN-RECLAIM_FS-W at:
[ 309.662043] __lock_acquire+0x638/0x1b50
[ 309.662048] lock_acquire+0xc9/0x220
[ 309.662053] __mutex_lock+0x6e/0x990
[ 309.662058] mutex_lock_nested+0x16/0x20
[ 309.662062] _rcu_barrier+0x31/0x160
[ 309.662067] rcu_barrier+0x10/0x20
[ 309.662089] i915_gem_shrink_all+0x33/0x40 [i915]
[ 309.662109] i915_drop_caches_set+0x141/0x150 [i915]
[ 309.662114] simple_attr_write+0xc7/0xe0
[ 309.662119] full_proxy_write+0x4f/0x70
[ 309.662124] __vfs_write+0x23/0x120
[ 309.662128] vfs_write+0xc6/0x1f0
[ 309.662133] SyS_write+0x44/0xb0
[ 309.662138] entry_SYSCALL_64_fastpath+0x1c/0xb1
[ 309.662142] INITIAL USE at:
[ 309.662147] __lock_acquire+0x234/0x1b50
[ 309.662151] lock_acquire+0xc9/0x220
[ 309.662156] __mutex_lock+0x6e/0x990
[ 309.662160] mutex_lock_nested+0x16/0x20
[ 309.662165] _rcu_barrier+0x31/0x160
[ 309.662169] rcu_barrier+0x10/0x20
[ 309.662174] netdev_run_todo+0x5f/0x310
[ 309.662178] rtnl_unlock+0x9/0x10
[ 309.662183] default_device_exit_batch+0x133/0x150
[ 309.662188] ops_exit_list.isra.0+0x4d/0x60
[ 309.662192] cleanup_net+0x1d8/0x2c0
[ 309.662197] process_one_work+0x1f4/0x6d0
[ 309.662202] worker_thread+0x49/0x4a0
[ 309.662206] kthread+0x107/0x140
[ 309.662210] ret_from_fork+0x2e/0x40
[ 309.662214] }
[ 309.662220] ... key at: [<ffffffff81e4e1c8>] rcu_preempt_state+0x508/0x780
[ 309.662225] ... acquired at:
[ 309.662229] check_usage_forwards+0x12b/0x130
[ 309.662233] mark_lock+0x360/0x6f0
[ 309.662237] __lock_acquire+0x638/0x1b50
[ 309.662241] lock_acquire+0xc9/0x220
[ 309.662245] __mutex_lock+0x6e/0x990
[ 309.662249] mutex_lock_nested+0x16/0x20
[ 309.662253] _rcu_barrier+0x31/0x160
[ 309.662257] rcu_barrier+0x10/0x20
[ 309.662279] i915_gem_shrink_all+0x33/0x40 [i915]
[ 309.662298] i915_drop_caches_set+0x141/0x150 [i915]
[ 309.662303] simple_attr_write+0xc7/0xe0
[ 309.662307] full_proxy_write+0x4f/0x70
[ 309.662311] __vfs_write+0x23/0x120
[ 309.662315] vfs_write+0xc6/0x1f0
[ 309.662319] SyS_write+0x44/0xb0
[ 309.662323] entry_SYSCALL_64_fastpath+0x1c/0xb1
[ 309.662329]
stack backtrace:
[ 309.662335] CPU: 1 PID: 6435 Comm: gem_exec_gttfil Tainted: G W 4.11.0-rc1-CI-CI_DRM_2333+ #1
[ 309.662342] Hardware name: Hewlett-Packard HP Compaq 8100 Elite SFF PC/304Ah, BIOS 786H1 v01.13 07/14/2011
[ 309.662348] Call Trace:
[ 309.662354] dump_stack+0x67/0x92
[ 309.662359] print_irq_inversion_bug.part.19+0x1a4/0x1b0
[ 309.662365] check_usage_forwards+0x12b/0x130
[ 309.662369] mark_lock+0x360/0x6f0
[ 309.662374] ? print_shortest_lock_dependencies+0x1a0/0x1a0
[ 309.662379] __lock_acquire+0x638/0x1b50
[ 309.662383] ? __mutex_unlock_slowpath+0x3e/0x2e0
[ 309.662388] ? trace_hardirqs_on+0xd/0x10
[ 309.662392] ? _rcu_barrier+0x31/0x160
[ 309.662396] lock_acquire+0xc9/0x220
[ 309.662400] ? _rcu_barrier+0x31/0x160
[ 309.662404] ? _rcu_barrier+0x31/0x160
[ 309.662409] __mutex_lock+0x6e/0x990
[ 309.662412] ? _rcu_barrier+0x31/0x160
[ 309.662416] ? _rcu_barrier+0x31/0x160
[ 309.662421] ? synchronize_rcu_expedited+0x35/0xb0
[ 309.662426] ? _raw_spin_unlock_irqrestore+0x52/0x60
[ 309.662434] mutex_lock_nested+0x16/0x20
[ 309.662438] _rcu_barrier+0x31/0x160
[ 309.662442] rcu_barrier+0x10/0x20
[ 309.662464] i915_gem_shrink_all+0x33/0x40 [i915]
[ 309.662484] i915_drop_caches_set+0x141/0x150 [i915]
[ 309.662489] simple_attr_write+0xc7/0xe0
[ 309.662494] full_proxy_write+0x4f/0x70
[ 309.662498] __vfs_write+0x23/0x120
[ 309.662503] ? rcu_read_lock_sched_held+0x75/0x80
[ 309.662507] ? rcu_sync_lockdep_assert+0x2a/0x50
[ 309.662512] ? __sb_start_write+0x102/0x210
[ 309.662516] ? vfs_write+0x17d/0x1f0
[ 309.662520] vfs_write+0xc6/0x1f0
[ 309.662524] ? trace_hardirqs_on_caller+0xe7/0x200
[ 309.662529] SyS_write+0x44/0xb0
[ 309.662533] entry_SYSCALL_64_fastpath+0x1c/0xb1
[ 309.662537] RIP: 0033:0x7f507eac24a0
[ 309.662541] RSP: 002b:00007fffda8720e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 309.662548] RAX: ffffffffffffffda RBX: ffffffff81482bd3 RCX: 00007f507eac24a0
[ 309.662552] RDX: 0000000000000005 RSI: 00007fffda8720f0 RDI: 0000000000000005
[ 309.662557] RBP: ffffc9000048bf88 R08: 0000000000000000 R09: 000000000000002c
[ 309.662561] R10: 0000000000000014 R11: 0000000000000246 R12: 00007fffda872230
[ 309.662566] R13: 00007fffda872228 R14: 0000000000000201 R15: 00007fffda8720f0
[ 309.662572] ? __this_cpu_preempt_check+0x13/0x20
Fixes: 0eafec6d3244 ("drm/i915: Enable lockless lookup of request tracking via RCU")
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=100192
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20170314115019.18127-1-chris@chris-wilson.co.uk
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
(cherry picked from commit bd784b7cc41af7a19cfb705fa6d800e511c4ab02)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170321144531.12344-1-chris@chris-wilson.co.uk
commit 8f68d591d4765b2e1ce9d916ac7bc5583285c4ad upstream.
On Baytrail, we manually calculate busyness over the evaluation interval
to avoid issues with miscaluations with RC6 enabled. However, it turns
out that the DOWN_EI interrupt generator is completely bust - it
operates in two modes, continuous or never. Neither of which are
conducive to good behaviour. Stop unmask the DOWN_EI interrupt and just
compute everything from the UP_EI which does seem to correspond to the
desired interval.
v2: Fixup gen6_rps_pm_mask() as well
v3: Inline vlv_c0_above() to combine the now identical elapsed
calculation for up/down and simplify the threshold testing
Fixes: 43cf3bf084ba ("drm/i915: Improved w/a for rps on Baytrail")
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170309211232.28878-1-chris@chris-wilson.co.uk
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170617.31564-1-chris@chris-wilson.co.uk
(cherry picked from commit e0e8c7cb6eb68e9256de2d8cbeb481d3701c05ac)
commit 0f5418e564ac6452b9086295646e602a9addc4bf upstream.
This patch makes the I915_PARAM_HAS_EXEC_CONSTANTS getparam return 0
(indicating the optional feature is not supported), and makes execbuf
always return -EINVAL if the flags are used.
Apparently, no userspace ever shipped which used this optional feature:
I checked the git history of Mesa, xf86-video-intel, libva, and Beignet,
and there were zero commits showing a use of these flags. Kernel commit
72bfa19c8deb4 apparently introduced the feature prematurely. According
to Chris, the intention was to use this in cairo-drm, but "the use was
broken for gen6", so I don't think it ever happened.
'relative_constants_mode' has always been tracked per-device, but this
has actually been wrong ever since hardware contexts were introduced, as
the INSTPM register is saved (and automatically restored) as part of the
render ring context. The software per-device value could therefore get
out of sync with the hardware per-context value. This meant that using
them is actually unsafe: a client which tried to use them could damage
the state of other clients, causing the GPU to interpret their BO
offsets as absolute pointers, leading to bogus memory reads.
These flags were also never ported to execlist mode, making them no-ops
on Gen9+ (which requires execlists), and Gen8 in the default mode.
On Gen8+, userspace can write these registers directly, achieving the
same effect. On Gen6-7.5, it likely makes sense to extend the command
parser to support them. I don't think anyone wants this on Gen4-5.
Based on a patch by Dave Gordon.
v3: Return -ENODEV for the getparam, as this is what we do for other
obsolete features. Suggested by Chris Wilson.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92448
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/20170215093446.21291-1-kenneth@whitecape.org
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170433.26843-1-chris@chris-wilson.co.uk
(cherry picked from commit ef0f411f51475f4eebf9fc1b19a85be698af19ff)
commit 35a3abfd198e6c69a6644784bb09a2d951fc6b21 upstream.
In order to prevent accessing the hpd registers outside of the display
power wells, we should refrain from writing to the registers before the
display interrupts are enabled.
[ 4.740136] WARNING: CPU: 1 PID: 221 at drivers/gpu/drm/i915/intel_uncore.c:795 __unclaimed_reg_debug+0x44/0x50 [i915]
[ 4.740155] Unclaimed read from register 0x1e1110
[ 4.740168] Modules linked in: i915(+) intel_gtt drm_kms_helper prime_numbers
[ 4.740190] CPU: 1 PID: 221 Comm: systemd-udevd Not tainted 4.10.0-rc6+ #384
[ 4.740203] Hardware name: / , BIOS PYBSWCEL.86A.0027.2015.0507.1758 05/07/2015
[ 4.740220] Call Trace:
[ 4.740236] dump_stack+0x4d/0x6f
[ 4.740251] __warn+0xc1/0xe0
[ 4.740265] warn_slowpath_fmt+0x4a/0x50
[ 4.740281] ? insert_work+0x77/0xc0
[ 4.740355] ? fwtable_write32+0x90/0x130 [i915]
[ 4.740431] __unclaimed_reg_debug+0x44/0x50 [i915]
[ 4.740507] fwtable_read32+0xd8/0x130 [i915]
[ 4.740575] i915_hpd_irq_setup+0xa5/0x100 [i915]
[ 4.740649] intel_hpd_init+0x68/0x80 [i915]
[ 4.740716] i915_driver_load+0xe19/0x1380 [i915]
[ 4.740784] i915_pci_probe+0x32/0x90 [i915]
[ 4.740799] pci_device_probe+0x8b/0xf0
[ 4.740815] driver_probe_device+0x2b6/0x450
[ 4.740828] __driver_attach+0xda/0xe0
[ 4.740841] ? driver_probe_device+0x450/0x450
[ 4.740853] bus_for_each_dev+0x5b/0x90
[ 4.740865] driver_attach+0x19/0x20
[ 4.740878] bus_add_driver+0x166/0x260
[ 4.740892] driver_register+0x5b/0xd0
[ 4.740906] ? 0xffffffffa0166000
[ 4.740920] __pci_register_driver+0x47/0x50
[ 4.740985] i915_init+0x5c/0x5e [i915]
[ 4.740999] do_one_initcall+0x3e/0x160
[ 4.741015] ? __vunmap+0x7c/0xc0
[ 4.741029] ? kmem_cache_alloc+0xcf/0x120
[ 4.741045] do_init_module+0x55/0x1c4
[ 4.741060] load_module+0x1f3f/0x25b0
[ 4.741073] ? __symbol_put+0x40/0x40
[ 4.741086] ? kernel_read_file+0x100/0x190
[ 4.741100] SYSC_finit_module+0xbc/0xf0
[ 4.741112] SyS_finit_module+0x9/0x10
[ 4.741125] entry_SYSCALL_64_fastpath+0x17/0x98
[ 4.741135] RIP: 0033:0x7f8559a140f9
[ 4.741145] RSP: 002b:00007fff7509a3e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 4.741161] RAX: ffffffffffffffda RBX: 00007f855aba02d1 RCX: 00007f8559a140f9
[ 4.741172] RDX: 0000000000000000 RSI: 000055b6db0914f0 RDI: 0000000000000011
[ 4.741183] RBP: 0000000000020000 R08: 0000000000000000 R09: 000000000000000e
[ 4.741193] R10: 0000000000000011 R11: 0000000000000246 R12: 000055b6db0854d0
[ 4.741204] R13: 000055b6db091150 R14: 0000000000000000 R15: 000055b6db035924
v2: Set dev_priv->display_irqs_enabled to true for all platforms other
than vlv/chv that manually control the display power domain.
Fixes: 19625e85c6ec ("drm/i915: Enable polling when we don't have hpd")
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97798
Suggested-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Lyude <cpaul@redhat.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Hans de Goede <jwrdegoede@fedoraproject.org>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170215131547.5064-1-chris@chris-wilson.co.uk
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170231.18633-1-chris@chris-wilson.co.uk
(cherry picked from commit 262fd485ac6b476479f41f00bb104f6a1766ae66)
commit 34dc8993eef63681b062871413a9484008a2a78f upstream.
Certain Baytrails, namely the 4 cpu core variants, have been
plaqued by spurious system hangs, mostly occurring with light loads.
Multiple bisects by various people point to a commit which changes the
reclocking strategy for Baytrail to follow its bigger brethen:
commit 8fb55197e64d ("drm/i915: Agressive downclocking on Baytrail")
There is also a review comment attached to this commit from Deepak S
on avoiding punit access on Cherryview and thus it was excluded on
common reclocking path. By taking the same approach and omitting
the punit access by not tweaking the thresholds when the hardware
has been asked to move into different frequency, considerable gains
in stability have been observed.
With J1900 box, light render/video load would end up in system hang
in usually less than 12 hours. With this patch applied, the cumulative
uptime has now been 34 days without issues. To provoke system hang,
light loads on both render and bsd engines in parallel have been used:
glxgears >/dev/null 2>/dev/null &
mpv --vo=vaapi --hwdec=vaapi --loop=inf vid.mp4
So far, author has not witnessed system hang with above load
and this patch applied. Reports from the tenacious people at
kernel bugzilla are also promising.
Considering that the punit access frequency with this patch is
considerably less, there is a possibility that this will push
the, still unknown, root cause past the triggering point on most loads.
But as we now can reliably reproduce the hang independently,
we can reduce the pain that users are having and use a
static thresholds until a root cause is found.
v3: don't break debugfs and simplification (Chris Wilson)
References: https://bugzilla.kernel.org/show_bug.cgi?id=109051
Cc: Len Brown <len.brown@intel.com>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: fritsch@xbmc.org
Cc: miku@iki.fi
Cc: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
CC: Michal Feix <michal@feix.cz>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Deepak S <deepak.s@linux.intel.com>
Cc: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1487166779-26945-1-git-send-email-mika.kuoppala@intel.com
(cherry picked from commit 6067a27d1f0184596d51decbac1c1fdc4acb012f)
commit edd06b8353772dca7afcd4640dafa83b521edd55 upstream.
printks are slow so we should not be doing them from the vblank evade
critical section. These could explain why we sometimes seem to
blow past our 100 usec deadline.
The problem has been there ever since commit bfd16b2a23dc ("drm/i915:
Make updating pipe without modeset atomic.") but it may not have
been readily visible until commit e1edbd44e23b ("drm/i915: Complain
if we take too long under vblank evasion.") increased our chances
of noticing it.
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Fixes: bfd16b2a23dc ("drm/i915: Make updating pipe without modeset atomic.")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170307205419.19447-1-ville.syrjala@linux.intel.com
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
(cherry picked from commit c3f8ad57a01a31397e5a0349a226a32f35ddc19c)
commit d253371c4c2f5fc2d884ef25f64decd7549aff5a upstream.
After
commit 2c7d0602c815277f7cb7c932b091288710d8aba7
Author: Imre Deak <imre.deak@intel.com>
Date: Mon Dec 5 18:27:37 2016 +0200
drm/i915/gen9: Fix PCODE polling during CDCLK change notification
there is still one report of the CDCLK-change request timing out on a
KBL machine, see the Reference link. On that machine the maximum time
the request took to succeed was 34ms, so increase the timeout to 50ms.
v2:
- Change timeout from 100 to 50 ms to maintain the current 50 ms limit
for atomic waits in the driver. (Chris, Tvrtko)
Reference: https://bugs.freedesktop.org/show_bug.cgi?id=99345
Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Signed-off-by: Imre Deak <imre.deak@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1487946730-17162-1-git-send-email-imre.deak@intel.com
(cherry picked from commit 0129936ddda26afd5d9d207c4e86b2425952579f)
[ Upstream commit bba8376aea1dcbbe22bbda118c52abee317c7609 ]
The reboot quirk for ASUS EeeBook X205TA contains a typo in
DMI_PRODUCT_NAME, improperly referring to X205TAW instead of
X205TA, which prevents the quirk from being triggered. The
model X205TAW already has a reboot quirk of its own.
This fix simply removes the inappropriate final letter W.
Fixes: 90b28ded88dd ("x86/reboot/quirks: Add ASUS EeeBook X205TA reboot quirk")
Signed-off-by: Matjaz Hegedic <matjaz.hegedic@gmail.com>
Link: http://lkml.kernel.org/r/1489064417-7445-1-git-send-email-matjaz.hegedic@gmail.com
[ Upstream commit d595259fbb7a7afed241b1afb2c4fe4b47de47fa ]
This USB-SATA bridge chip is used in a StarTech enclosure for
optical drives.
Without the quirk MakeMKV fails during the key exchange with an
installed BluRay drive:
> Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED'
> occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:2'
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
[ Upstream commit 3b3e78552d3077ec70d2640e629e07e3ab416a6a ]
Without the parameter reboot=a, ASUS EeeBook X205TA/W will hang
when it should reboot. This adds the appropriate quirk, thus
fixing the problem.
Link: http://lkml.kernel.org/r/1488737804-20681-1-git-send-email-matjaz.hegedic@gmail.com
[ Upstream commit 90b28ded88dda8bea82b4a86923e73ba0746d884 ]
Without the parameter reboot=a, ASUS EeeBook X205TA will hang when it should reboot.
This adds the appropriate quirk, thus fixing the problem.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
[ Upstream commit 71050ae7bf83e4d71a859257d11adc5de517073e ]
Some Asus laptops that have an airplane-mode indicator LED, also have
the WMI WLAN user bit set, and the following bits in their DSDT:
Scope (_SB)
Device (ATKD)
Method (WMNB, 3, Serialized)
If (LEqual (IIA0, 0x00010002))
OWGD (IIA1)
Return (One)
So when asus-wmi uses ASUS_WMI_DEVID_WLAN_LED (0x00010002) to store the
wlan state, it drives the airplane-mode indicator LED (through the call
to OWGD) in an inverted fashion: the LED is ON when airplane mode is OFF
(since wlan is ON), and vice-versa.
This commit skips registering RFKill switches at all for these laptops,
to allow the asus-wireless driver to drive the airplane mode LED
correctly through the ASHS ACPI device. Relying on the presence of ASHS
and ASUS_WMI_DSTS_USER_BIT avoids adding DMI-based quirks for at least
21 different laptops.
Signed-off-by: João Paulo Rechi Vita <jprvita@endlessm.com>
[ Upstream commit 8023eff10e7b0327898f17f0b553d2e45c71cef3 ]
The bluetooth adapter Atheros AR3012 can't be enumerated
and make the bluetooth function broken.
T: Bus=02 Lev=01 Prnt=01 Port=05 Cnt=02 Dev#= 5 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=13d3 ProdID=3362 Rev=00.02
S: Manufacturer=Atheros Communications
S: Product=Bluetooth USB Host Controller
S: SerialNumber=Alaska Day 2006
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
The error is:
usb 2-6: device not accepting address 7, error -62
usb usb2-port6: unable to enumerate USB device
It is caused by adapter's connected port is mapped to xHC
controller, but the xHCI is not supported by the usb device.
The output of 'sudo lspci -nnxxx -s 00:14.0':
00:14.0 USB controller [0c03]: Intel Corporation 8 Series USB xHCI HC [8086:9c31] (rev 04)
00: 86 80 31 9c 06 04 90 02 04 30 03 0c 00 00 00 00
10: 04 00 a0 f7 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 1f 20
30: 00 00 00 00 70 00 00 00 00 00 00 00 0b 01 00 00
40: fd 01 36 80 89 c6 0f 80 00 00 00 00 00 00 00 00
50: 5f 2e ce 0f 00 00 00 00 00 00 00 00 00 00 00 00
60: 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70: 01 80 c2 c1 08 00 00 00 00 00 00 00 00 00 00 00
80: 05 00 87 00 0c a0 e0 fe 00 00 00 00 a1 41 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
a0: 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 0f 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 03 c0 30 00 00 00 00 00 03 0c 00 00 00 00 00 00
d0: f9 01 00 00 f9 01 00 00 0f 00 00 00 0f 00 00 00
e0: 00 08 00 00 00 00 00 00 00 00 00 00 d8 d8 00 00
f0: 00 00 00 00 00 00 00 00 b1 0f 04 08 00 00 00 00
By referencing Intel Platform Controller Hub(PCH) datasheet,
the xHC USB 2.0 Port Routing(XUSB2PR) at offset 0xD0-0xD3h
decides the setting of mapping the port to EHCI controller or
xHC controller. And the port mapped to xHC will enable xHCI
during bus resume.
The setting of disabling bluetooth adapter's connected port is
0x000001D9. The value can be obtained by few times 1 bit flip
operation. The suited configuration should have the 'lsusb -t'
result with bluetooth using ehci:
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/9p, 480M
|__ Port 5: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 5: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
|__ Port 6: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 6: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
Signed-off-by: Kai-Chuan Hsieh <kai.chiuan@gmail.com>
Acked-by: Corentin Chary <corentin.chary@gmail.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
[andy: resolve merge conflict in asus-wmi.h]
[ Upstream commit 0b445549ea6f91ffea78a976fe89b932db6e077a ]
In soft (no-reboot) mode, the driver self-pings watchdog upon expiration
of an interrupt. However the interrupt itself was not cleared thus on
first hit, the system enters infinite interrupt handling loop.
On Odroid U3 (Exynos4412), when booted with s3c2410_wdt.soft_noboot=1
argument the console is flooded:
# killall -9 watchdog
[ 60.523760] s3c2410-wdt 10060000.watchdog: watchdog timer expired (irq)
[ 60.536744] s3c2410-wdt 10060000.watchdog: watchdog timer expired (irq)
Fix this by writing something to the WTCLRINT register to clear the
interrupt. The register WTCLRINT however appeared in S3C6410 so a new
watchdog quirk and flavor are needed.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit 33be632b8443b6ac74aa293504f430604fb9abeb ]
The Qualcomm QDF2xxx root ports don't advertise an ACS capability, but they
do provide ACS-like features to disable peer transactions and validate bus
numbers in requests.
To be specific:
* Hardware supports source validation but it will report the issue as
Completer Abort instead of ACS Violation.
* Hardware doesn't support peer-to-peer and each root port is a root
complex with unique segment numbers.
* It is not possible for one root port to pass traffic to the other root
port. All PCIe transactions are terminated inside the root port.
Add an ACS quirk for the QDF2400 and QDF2432 products.
[bhelgaas: changelog]
Signed-off-by: Sinan Kaya <okaya@codeaurora.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit cd3e2eb8905d14fe28a2fc75362b8ecec16f0fb6 ]
Sort the list of Intel devices that have no PCI D3 delay by ID. Add a
comment for group of devices that had not been marked yet.
There is no functional change.
[ Upstream commit e9acc77dd046b22c7ebf70e35f68968978445f8b ]
Initially all QorIQ platforms were PowerPC architecture and they didn't
support card detection except several platforms. The driver added the
quirk SDHCI_QUIRK_BROKEN_CARD_DETECTION as default and this made broken-cd
property in dts node didn't work. Now QorIQ platform turns to ARM
architecture and most of them could support card detection. However it's
a large number of dts trees that need to be fixed with broken-cd if we
remove the default SDHCI_QUIRK_BROKEN_CARD_DETECTION in driver. And the
users don't want to see this. So this patch is to remove this default
quirk just for ARM and keep it for PowerPC.(Note, QorIQ PowerPC platform
only has big-endian eSDHC while QorIQ ARM platform has big-endian or
little-endian eSDHC) This makes broken-cd property work again for ARM.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 72f2ff0deb870145a5a2d24cd75b4f9936159a62 ]
The PCIe Root Port in Hip06/Hip07 SoCs advertises an MSI capability, but it
cannot generate MSIs. It can transfer MSI/MSI-X from downstream devices,
but does not support MSI/MSI-X itself.
Add a quirk to prevent use of MSI/MSI-X by the Root Port.
[bhelgaas: changelog, sort vendor ID #define, drop device ID #define]
Signed-off-by: Dongdong Liu <liudongdong3@huawei.com>
Reviewed-by: Gabriele Paoloni <gabriele.paoloni@huawei.com>
Reviewed-by: Zhou Wang <wangzhou1@hisilicon.com>
[ Upstream commit ce709f86501a013e941e9986cb072eae375ddf3e ]
The Broadcom Northstar2 SoC has a number of quirks for the PAXC
(internal/fake) PCI bus. Specifically, the PCI config space is shared
between the root port and the first PF (ie., PF0), and a number of fields
are tied to zero (thus preventing them from being set). These cannot be
"fixed" in device firmware, so we must fix them with a quirk.
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
[ Upstream commit 3046ec674d441562c6bb3e4284cd866743042ef3 ]
Commit 680a0873e193 ("arm: kernel: Add SMC structure parameter") added
a new "quirk" parameter to the SMC and HVC SMCCC backends, but only
updated the comment for the SMC version. This patch adds the new
paramater to the comment describing the HVC version too.
[ Upstream commit a5725ab0497ad91a2df7c01a78bf1a0cc5be4526 ]
We get 2 warnings when building kernel with W=1:
drivers/gpu/drm/msm/adreno/a3xx_gpu.c:535:17: warning: no previous prototype for 'a3xx_gpu_init' [-Wmissing-prototypes]
drivers/gpu/drm/msm/adreno/a4xx_gpu.c:624:17: warning: no previous prototype for 'a4xx_gpu_init' [-Wmissing-prototypes]
In fact, both functions are declared in
drivers/gpu/drm/msm/adreno/adreno_device.c, but should be declared
in a header file. So this patch moves both function declarations to
drivers/gpu/drm/msm/adreno/adreno_gpu.h.
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1477127865-9381-1-git-send-email-baoyou.xie@linaro.org
[ Upstream commit 82bcd087029f6056506ea929f11af02622230901 ]
This patch adds a Qualcomm specific quirk to the arm_smccc_smc call.
On Qualcomm ARM64 platforms, the SMC call can return before it has
completed. If this occurs, the call can be restarted, but it requires
using the returned session ID value from the interrupted SMC call.
The quirk stores off the session ID from the interrupted call in the
quirk structure so that it can be used by the caller.
This patch folds in a fix given by Sricharan R:
https://lkml.org/lkml/2016/9/28/272
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
[ Upstream commit 680a0873e193bae666439f4b5e32c758e68f114c ]
This patch adds a quirk parameter to the arm_smccc_(smc/hvc) calls.
The quirk structure allows for specialized SMC operations due to SoC
specific requirements. The current arm_smccc_(smc/hvc) is renamed and
macros are used instead to specify the standard arm_smccc_(smc/hvc) or
the arm_smccc_(smc/hvc)_quirk function.
This patch and partial implementation was suggested by Will Deacon.
[ Upstream commit e7deb1570a527d3c74be4e21a72b1b459605c501 ]
Non-generic devices have numbered_buttons set for both pen and
touch interfaces by default. The actual number of buttons on the
interface is normally manually decided later, which is different
from what those HID generic devices are processed, where number
of buttons are directly retrieved from HID descriptors.
This patch adds the missed HID_GENERIC check and moves the statement
to wacom_setup_pad_input_capabilities since it's not a quirk anymore.
Signed-off-by: Ping Cheng <ping.cheng@wacom.com>
Reviewed-by: Jason Gerecke <jason.gerecke@wacom.com>
