2018-10-03Linux 4.9.131v4.9.131Greg Kroah-Hartman
2018-10-03media: v4l: event: Prevent freeing event subscriptions while accessedSakari Ailus
commit ad608fbcf166fec809e402d548761768f602702c upstream. The event subscriptions are added to the subscribed event list while holding a spinlock, but that lock is subsequently released while still accessing the subscription object. This makes it possible to unsubscribe the event --- and freeing the subscription object's memory --- while the subscription object is simultaneously accessed. Prevent this by adding a mutex to serialise the event subscription and unsubscription. This also gives a guarantee to the callback ops that the add op has returned before the del op is called. This change also results in making the elems field less special: subscriptions are only added to the event list once they are fully initialised. Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: stable@vger.kernel.org # for 4.14 and up Fixes: c3b5b0241f62 ("V4L/DVB: V4L: Events: Add backend") Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03arm64: KVM: Sanitize PSTATE.M when being set from userspaceMarc Zyngier
commit 2a3f93459d689d990b3ecfbe782fec89b97d3279 upstream. Not all execution modes are valid for a guest, and some of them depend on what the HW actually supports. Let's verify that what userspace provides is compatible with both the VM settings and the HW capabilities. Cc: <stable@vger.kernel.org> Fixes: 0d854a60b1d7 ("arm64: KVM: enable initialization of a 32bit vcpu") Reviewed-by: Christoffer Dall <christoffer.dall@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03i2c: i801: Allow ACPI AML access I/O ports not reserved for SMBusMika Westerberg
[ Upstream commit 7fd6d98b89f382d414e1db528e29a67bbd749457 ] Commit 7ae81952cda ("i2c: i801: Allow ACPI SystemIO OpRegion to conflict with PCI BAR") made it possible for AML code to access SMBus I/O ports by installing custom SystemIO OpRegion handler and blocking i80i driver access upon first AML read/write to this OpRegion. However, while ThinkPad T560 does have SystemIO OpRegion declared under the SMBus device, it does not access any of the SMBus registers: Device (SMBU) { ... OperationRegion (SMBP, PCI_Config, 0x50, 0x04) Field (SMBP, DWordAcc, NoLock, Preserve) { , 5, TCOB, 11, Offset (0x04) } Name (TCBV, 0x00) Method (TCBS, 0, NotSerialized) { If ((TCBV == 0x00)) { TCBV = (\_SB.PCI0.SMBU.TCOB << 0x05) } Return (TCBV) /* \_SB_.PCI0.SMBU.TCBV */ } OperationRegion (TCBA, SystemIO, TCBS (), 0x10) Field (TCBA, ByteAcc, NoLock, Preserve) { Offset (0x04), , 9, CPSC, 1 } } Problem with the current approach is that it blocks all I/O port access and because this system has touchpad connected to the SMBus controller after first AML access (happens during suspend/resume cycle) the touchpad fails to work anymore. Fix this so that we allow ACPI AML I/O port access if it does not touch the region reserved for the SMBus. Fixes: 7ae81952cda ("i2c: i801: Allow ACPI SystemIO OpRegion to conflict with PCI BAR") Link: https://bugzilla.kernel.org/show_bug.cgi?id=200737 Reported-by: Yussuf Khalil <dev@pp3345.net> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03arm/arm64: smccc-1.1: Handle function result as parametersMarc Zyngier
[ Upstream commit 755a8bf5579d22eb5636685c516d8dede799e27b ] If someone has the silly idea to write something along those lines: extern u64 foo(void); void bar(struct arm_smccc_res *res) { arm_smccc_1_1_smc(0xbad, foo(), res); } they are in for a surprise, as this gets compiled as: 0000000000000588 <bar>: 588: a9be7bfd stp x29, x30, [sp, #-32]! 58c: 910003fd mov x29, sp 590: f9000bf3 str x19, [sp, #16] 594: aa0003f3 mov x19, x0 598: aa1e03e0 mov x0, x30 59c: 94000000 bl 0 <_mcount> 5a0: 94000000 bl 0 <foo> 5a4: aa0003e1 mov x1, x0 5a8: d4000003 smc #0x0 5ac: b4000073 cbz x19, 5b8 <bar+0x30> 5b0: a9000660 stp x0, x1, [x19] 5b4: a9010e62 stp x2, x3, [x19, #16] 5b8: f9400bf3 ldr x19, [sp, #16] 5bc: a8c27bfd ldp x29, x30, [sp], #32 5c0: d65f03c0 ret 5c4: d503201f nop The call to foo "overwrites" the x0 register for the return value, and we end up calling the wrong secure service. A solution is to evaluate all the parameters before assigning anything to specific registers, leading to the expected result: 0000000000000588 <bar>: 588: a9be7bfd stp x29, x30, [sp, #-32]! 58c: 910003fd mov x29, sp 590: f9000bf3 str x19, [sp, #16] 594: aa0003f3 mov x19, x0 598: aa1e03e0 mov x0, x30 59c: 94000000 bl 0 <_mcount> 5a0: 94000000 bl 0 <foo> 5a4: aa0003e1 mov x1, x0 5a8: d28175a0 mov x0, #0xbad 5ac: d4000003 smc #0x0 5b0: b4000073 cbz x19, 5bc <bar+0x34> 5b4: a9000660 stp x0, x1, [x19] 5b8: a9010e62 stp x2, x3, [x19, #16] 5bc: f9400bf3 ldr x19, [sp, #16] 5c0: a8c27bfd ldp x29, x30, [sp], #32 5c4: d65f03c0 ret Reported-by: Julien Grall <julien.grall@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03arm/arm64: smccc-1.1: Make return values unsigned longMarc Zyngier
[ Upstream commit 1d8f574708a3fb6f18c85486d0c5217df893c0cf ] An unfortunate consequence of having a strong typing for the input values to the SMC call is that it also affects the type of the return values, limiting r0 to 32 bits and r{1,2,3} to whatever was passed as an input. Let's turn everything into "unsigned long", which satisfies the requirements of both architectures, and allows for the full range of return values. Reported-by: Julien Grall <julien.grall@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03drm/amdgpu: Update power state at the end of smu hw_init.Rex Zhu
[ Upstream commit 2ab4d0e74256fc49b7b270f63c1d1e47c2455abc ] For SI/Kv, the power state is managed by function amdgpu_pm_compute_clocks. when dpm enabled, we should call amdgpu_pm_compute_clocks to update current power state instand of set boot state. this change can fix the oops when kfd driver was enabled on Kv. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Tested-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Rex Zhu <Rex.Zhu@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03drm/amdgpu: Enable/disable gfx PG feature in rlc safe modeRex Zhu
[ Upstream commit 8ef23364b654d44244400d79988e677e504b21ba ] This is required by gfx hw and can fix the rlc hang when do s3 stree test on Cz/St. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Hang Zhou <hang.zhou@amd.com> Signed-off-by: Rex Zhu <Rex.Zhu@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03hwmon: (adt7475) Make adt7475_read_word() return errorsDan Carpenter
[ Upstream commit f196dec6d50abb2e65fb54a0621b2f1b4d922995 ] The adt7475_read_word() function was meant to return negative error codes on failure. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Tokunori Ikegami <ikegami@allied-telesis.co.jp> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03hwmon: (ina2xx) fix sysfs shunt resistor read accessLothar Felten
[ Upstream commit 3ad867001c91657c46dcf6656d52eb6080286fd5 ] fix the sysfs shunt resistor read access: return the shunt resistor value, not the calibration register contents. update email address Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03e1000: ensure to free old tx/rx rings in set_ringparam()Bo Chen
[ Upstream commit ee400a3f1bfe7004a3e14b81c38ccc5583c26295 ] In 'e1000_set_ringparam()', the tx_ring and rx_ring are updated with new value and the old tx/rx rings are freed only when the device is up. There are resource leaks on old tx/rx rings when the device is not up. This bug is reported by COD, a tool for testing kernel module binaries I am building. This patch fixes the bug by always calling 'kfree()' on old tx/rx rings in 'e1000_set_ringparam()'. Signed-off-by: Bo Chen <chenbo@pdx.edu> Reviewed-by: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03e1000: check on netif_running() before calling e1000_up()Bo Chen
[ Upstream commit cf1acec008f8d7761aa3fd7c4bca7e17b2d2512d ] When the device is not up, the call to 'e1000_up()' from the error handling path of 'e1000_set_ringparam()' causes a kernel oops with a null-pointer dereference. The null-pointer dereference is triggered in function 'e1000_alloc_rx_buffers()' at line 'buffer_info = &rx_ring->buffer_info[i]'. This bug was reported by COD, a tool for testing kernel module binaries I am building. This bug was also detected by KFI from Dr. Kai Cong. This patch fixes the bug by checking on 'netif_running()' before calling 'e1000_up()' in 'e1000_set_ringparam()'. Signed-off-by: Bo Chen <chenbo@pdx.edu> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03net: hns: fix skb->truesize underestimationHuazhong Tan
[ Upstream commit b1ccd4c0ab6ef499f47dd84ed4920502a7147bba ] skb->truesize is not meant to be tracking amount of used bytes in a skb, but amount of reserved/consumed bytes in memory. For instance, if we use a single byte in last page fragment, we have to account the full size of the fragment. So skb_add_rx_frag needs to calculate the length of the entire buffer into turesize. Fixes: 9cbe9fd5214e ("net: hns: optimize XGE capability by reducing cpu usage") Signed-off-by: Huazhong tan <tanhuazhong@huawei.com> Signed-off-by: Salil Mehta <salil.mehta@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03net: hns: fix length and page_offset overflow when CONFIG_ARM64_64K_PAGESHuazhong Tan
[ Upstream commit 3ed614dce3ca9912d22be215ff0f11104b69fe62 ] When enable the config item "CONFIG_ARM64_64K_PAGES", the size of PAGE_SIZE is 65536(64K). But the type of length and page_offset are u16, they will overflow. So change them to u32. Fixes: 6fe6611ff275 ("net: add Hisilicon Network Subsystem hnae framework support") Signed-off-by: Huazhong Tan <tanhuazhong@huawei.com> Signed-off-by: Salil Mehta <salil.mehta@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03thermal: of-thermal: disable passive polling when thermal zone is disabledAnson Huang
[ Upstream commit 152395fd03d4ce1e535a75cdbf58105e50587611 ] When thermal zone is in passive mode, disabling its mode from sysfs is NOT taking effect at all, it is still polling the temperature of the disabled thermal zone and handling all thermal trips, it makes user confused. The disabling operation should disable the thermal zone behavior completely, for both active and passive mode, this patch clears the passive_delay when thermal zone is disabled and restores it when it is enabled. Signed-off-by: Anson Huang <Anson.Huang@nxp.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03qed: Wait for MCP halt and resume commands to take placeTomer Tayar
[ Upstream commit 76271809f49056f079e202bf6513d17b0d6dd34d ] Successive iterations of halting and resuming the management chip (MCP) might fail, since currently the driver doesn't wait for these operations to actually take place. This patch prevents the driver from moving forward before the operations are reflected in the state register. Signed-off-by: Tomer Tayar <Tomer.Tayar@cavium.com> Signed-off-by: Ariel Elior <Ariel.Elior@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03qed: Wait for ready indication before rereading the shmemTomer Tayar
[ Upstream commit f00d25f3154b676fcea4502a25b94bd7f142ca74 ] The MFW might be reset and re-update its shared memory. Upon the detection of such a reset the driver rereads this memory, but it has to wait till the data is valid. This patch adds the missing wait for a data ready indication. Signed-off-by: Tomer Tayar <Tomer.Tayar@cavium.com> Signed-off-by: Ariel Elior <Ariel.Elior@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03ext4: never move the system.data xattr out of the inode bodyTheodore Ts'o
commit 8cdb5240ec5928b20490a2bb34cb87e9a5f40226 upstream. When expanding the extra isize space, we must never move the system.data xattr out of the inode body. For performance reasons, it doesn't make any sense, and the inline data implementation assumes that system.data xattr is never in the external xattr block. This addresses CVE-2018-10880 https://bugzilla.kernel.org/show_bug.cgi?id=200005 Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@kernel.org [groeck: Context changes] Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03arm64: KVM: Tighten guest core register access from userspaceDave Martin
commit d26c25a9d19b5976b319af528886f89cf455692d upstream. We currently allow userspace to access the core register file in about any possible way, including straddling multiple registers and doing unaligned accesses. This is not the expected use of the ABI, and nobody is actually using it that way. Let's tighten it by explicitly checking the size and alignment for each field of the register file. Cc: <stable@vger.kernel.org> Fixes: 2f4a07c5f9fe ("arm64: KVM: guest one-reg interface") Reviewed-by: Christoffer Dall <christoffer.dall@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Dave Martin <Dave.Martin@arm.com> [maz: rewrote Dave's initial patch to be more easily backported] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03IB/hfi1: Fix SL array bounds checkIra Weiny
commit 0dbfaa9f2813787679e296eb5476e40938ab48c8 upstream. The SL specified by a user needs to be a valid SL. Add a range check to the user specified SL value which protects from running off the end of the SL to SC table. CC: stable@vger.kernel.org Fixes: 7724105686e7 ("IB/hfi1: add driver files") Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03serial: imx: restore handshaking irq for imx1Uwe Kleine-König
commit 7e620984b62532783912312e334f3c48cdacbd5d upstream. Back in 2015 when irda was dropped from the driver imx1 was broken. This change reintroduces the support for the third interrupt of the UART. Fixes: afe9cbb1a6ad ("serial: imx: drop support for IRDA") Cc: stable <stable@vger.kernel.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reviewed-by: Leonard Crestez <leonard.crestez@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03scsi: target: iscsi: Use bin2hex instead of a re-implementationVincent Pelletier
commit 8c39e2699f8acb2e29782a834e56306da24937fe upstream. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> [plr.vincent@gmail.com: hunk context change for 4.4 and 4.9, no code change] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03IB/hfi1: Fix context recovery when PBC has an UnsupportedVLMichael J. Ruhl
commit d623500b3c4efd8d4e945ac9003c6b87b469a9ab upstream. If a packet stream uses an UnsupportedVL (virtual lane), the send engine will not send the packet, and it will not indicate that an error has occurred. This will cause the packet stream to block. HFI has 8 virtual lanes available for packet streams. Each lane can be enabled or disabled using the UnsupportedVL mask. If a lane is disabled, adding a packet to the send context must be disallowed. The current mask for determining unsupported VLs defaults to 0 (allow all). This is incorrect. Only the VLs that are defined should be allowed. Determine which VLs are disabled (mtu == 0), and set the appropriate unsupported bit in the mask. The correct mask will allow the send engine to error on the invalid VL, and error recovery will work correctly. Cc: <stable@vger.kernel.org> # 4.9.x+ Fixes: 7724105686e7 ("IB/hfi1: add driver files") Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Lukasz Odzioba <lukasz.odzioba@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03IB/hfi1: Invalid user input can result in crashMichael J. Ruhl
commit 94694d18cf27a6faad91487a38ce516c2b16e7d9 upstream. If the number of packets in a user sdma request does not match the actual iovectors being sent, sdma_cleanup can be called on an uninitialized request structure, resulting in a crash similar to this: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffffc0ae8bb7>] __sdma_txclean+0x57/0x1e0 [hfi1] PGD 8000001044f61067 PUD 1052706067 PMD 0 Oops: 0000 [#1] SMP CPU: 30 PID: 69912 Comm: upsm Kdump: loaded Tainted: G OE ------------ 3.10.0-862.el7.x86_64 #1 Hardware name: Intel Corporation S2600KPR/S2600KPR, BIOS SE5C610.86B.01.01.0019.101220160604 10/12/2016 task: ffff8b331c890000 ti: ffff8b2ed1f98000 task.ti: ffff8b2ed1f98000 RIP: 0010:[<ffffffffc0ae8bb7>] [<ffffffffc0ae8bb7>] __sdma_txclean+0x57/0x1e0 [hfi1] RSP: 0018:ffff8b2ed1f9bab0 EFLAGS: 00010286 RAX: 0000000000008b2b RBX: ffff8b2adf6e0000 RCX: 0000000000000000 RDX: 00000000000000a0 RSI: ffff8b2e9eedc540 RDI: ffff8b2adf6e0000 RBP: ffff8b2ed1f9bad8 R08: 0000000000000000 R09: ffffffffc0b04a06 R10: ffff8b331c890190 R11: ffffe6ed00bf1840 R12: ffff8b3315480000 R13: ffff8b33154800f0 R14: 00000000fffffff2 R15: ffff8b2e9eedc540 FS: 00007f035ac47740(0000) GS:ffff8b331e100000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000008 CR3: 0000000c03fe6000 CR4: 00000000001607e0 Call Trace: [<ffffffffc0b0570d>] user_sdma_send_pkts+0xdcd/0x1990 [hfi1] [<ffffffff9fe75fb0>] ? gup_pud_range+0x140/0x290 [<ffffffffc0ad3105>] ? hfi1_mmu_rb_insert+0x155/0x1b0 [hfi1] [<ffffffffc0b0777b>] hfi1_user_sdma_process_request+0xc5b/0x11b0 [hfi1] [<ffffffffc0ac193a>] hfi1_aio_write+0xba/0x110 [hfi1] [<ffffffffa001a2bb>] do_sync_readv_writev+0x7b/0xd0 [<ffffffffa001bede>] do_readv_writev+0xce/0x260 [<ffffffffa022b089>] ? tty_ldisc_deref+0x19/0x20 [<ffffffffa02268c0>] ? n_tty_ioctl+0xe0/0xe0 [<ffffffffa001c105>] vfs_writev+0x35/0x60 [<ffffffffa001c2bf>] SyS_writev+0x7f/0x110 [<ffffffffa051f7d5>] system_call_fastpath+0x1c/0x21 Code: 06 49 c7 47 18 00 00 00 00 0f 87 89 01 00 00 5b 41 5c 41 5d 41 5e 41 5f 5d c3 66 2e 0f 1f 84 00 00 00 00 00 48 8b 4e 10 48 89 fb <48> 8b 51 08 49 89 d4 83 e2 0c 41 81 e4 00 e0 00 00 48 c1 ea 02 RIP [<ffffffffc0ae8bb7>] __sdma_txclean+0x57/0x1e0 [hfi1] RSP <ffff8b2ed1f9bab0> CR2: 0000000000000008 There are two exit points from user_sdma_send_pkts(). One (free_tx) merely frees the slab entry and one (free_txreq) cleans the sdma_txreq prior to freeing the slab entry. The free_txreq variation can only be called after one of the sdma_init*() variations has been called. In the panic case, the slab entry had been allocated but not inited. Fix the issue by exiting through free_tx thus avoiding sdma_clean(). Cc: <stable@vger.kernel.org> # 4.9.x+ Fixes: 7724105686e7 ("IB/hfi1: add driver files") Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Lukasz Odzioba <lukasz.odzioba@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2018-10-03IB/srp: Avoid that sg_reset -d ${srp_device} triggers an infinite loopBart Van Assche
commit ee92efe41cf358f4b99e73509f2bfd4733609f26 upstream. Use different loop variables for the inner and outer loop. This avoids that an infinite loop occurs if there are more RDMA channels than target->req_ring_size. Fixes: d92c0da71a35 ("IB/srp: Add multichannel support") Cc: <stable@vger.kernel.org> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03Input: elantech - enable middle button of touchpad on ThinkPad P72Aaron Ma
commit 91a97507323e1ad4bfc10f4a5922e67cdaf8b3cd upstream. Adding 2 new touchpad IDs to support middle button support. Cc: stable@vger.kernel.org Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03USB: remove LPM management from usb_driver_claim_interface()Alan Stern
commit c183813fcee44a249339b7c46e1ad271ca1870aa upstream. usb_driver_claim_interface() disables and re-enables Link Power Management, but it shouldn't do either one, for the reasons listed below. This patch removes the two LPM-related function calls from the routine. The reason for disabling LPM in the analogous function usb_probe_interface() is so that drivers won't have to deal with unwanted LPM transitions in their probe routine. But usb_driver_claim_interface() doesn't call the driver's probe routine (or any other callbacks), so that reason doesn't apply here. Furthermore, no driver other than usbfs will ever call usb_driver_claim_interface() unless it is already bound to another interface in the same device, which means disabling LPM here would be redundant. usbfs doesn't interact with LPM at all. Lastly, the error return from usb_unlocked_disable_lpm() isn't handled properly; the code doesn't clean up its earlier actions before returning. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Fixes: 8306095fd2c1 ("USB: Disable USB 3.0 LPM in critical sections.") CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03Revert "usb: cdc-wdm: Fix a sleep-in-atomic-context bug in ↵Sebastian Andrzej Siewior
service_outstanding_interrupt()" commit e871db8d78df1c411032cbb3acfdf8930509360e upstream. This reverts commit 6e22e3af7bb3a7b9dc53cb4687659f6e63fca427. The bug the patch describes to, has been already fixed in commit 2df6948428542 ("USB: cdc-wdm: don't enable interrupts in USB-giveback") so need to this, revert it. Fixes: 6e22e3af7bb3 ("usb: cdc-wdm: Fix a sleep-in-atomic-context bug in service_outstanding_interrupt()") Cc: stable <stable@vger.kernel.org> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03USB: usbdevfs: restore warning for nonsensical flagsOliver Neukum
commit 81e0403b26d94360abd1f6a57311337973bc82cd upstream. If we filter flags before they reach the core we need to generate our own warnings. Signed-off-by: Oliver Neukum <oneukum@suse.com> Fixes: 0cb54a3e47cb ("USB: debugging code shouldn't alter control flow") Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03USB: usbdevfs: sanitize flags moreOliver Neukum
commit 7a68d9fb851012829c29e770621905529bd9490b upstream. Requesting a ZERO_PACKET or not is sensible only for output. In the input direction the device decides. Likewise accepting short packets makes sense only for input. This allows operation with panic_on_warn without opening up a local DOS. Signed-off-by: Oliver Neukum <oneukum@suse.com> Reported-by: syzbot+843efa30c8821bd69f53@syzkaller.appspotmail.com Fixes: 0cb54a3e47cb ("USB: debugging code shouldn't alter control flow") Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03media: uvcvideo: Support realtek's UVC 1.5 deviceming_qian
commit f620d1d7afc7db57ab59f35000752840c91f67e7 upstream. media: uvcvideo: Support UVC 1.5 video probe & commit controls The length of UVC 1.5 video control is 48, and it is 34 for UVC 1.1. Change it to 48 for UVC 1.5 device, and the UVC 1.5 device can be recognized. More changes to the driver are needed for full UVC 1.5 compatibility. However, at least the UVC 1.5 Realtek RTS5847/RTS5852 cameras have been reported to work well. [laurent.pinchart@ideasonboard.com: Factor out code to helper function, update size checks] Cc: stable@vger.kernel.org Signed-off-by: ming_qian <ming_qian@realsil.com.cn> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Tested-by: Ana Guerrero Lopez <ana.guerrero@collabora.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03slub: make ->cpu_partial unsigned intAlexey Dobriyan
commit e5d9998f3e09359b372a037a6ac55ba235d95d57 upstream. /* * cpu_partial determined the maximum number of objects * kept in the per cpu partial lists of a processor. */ Can't be negative. Link: http://lkml.kernel.org/r/20180305200730.15812-15-adobriyan@gmail.com Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: zhong jiang <zhongjiang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03USB: handle NULL config in usb_find_alt_setting()Alan Stern
commit c9a4cb204e9eb7fa7dfbe3f7d3a674fa530aa193 upstream. usb_find_alt_setting() takes a pointer to a struct usb_host_config as an argument; it searches for an interface with specified interface and alternate setting numbers in that config. However, it crashes if the usb_host_config pointer argument is NULL. Since this is a general-purpose routine, available for use in many places, we want to to be more robust. This patch makes it return NULL whenever the config argument is NULL. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: syzbot+19c3aaef85a89d451eac@syzkaller.appspotmail.com CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03USB: fix error handling in usb_driver_claim_interface()Alan Stern
commit bd729f9d67aa9a303d8925bb8c4f06af25f407d1 upstream. The syzbot fuzzing project found a use-after-free bug in the USB core. The bug was caused by usbfs not unbinding from an interface when the USB device file was closed, which led another process to attempt the unbind later on, after the private data structure had been deallocated. The reason usbfs did not unbind the interface at the appropriate time was because it thought the interface had never been claimed in the first place. This was caused by the fact that usb_driver_claim_interface() does not clean up properly when device_bind_driver() returns an error. Although the error code gets passed back to the caller, the iface->dev.driver pointer remains set and iface->condition remains equal to USB_INTERFACE_BOUND. This patch adds proper error handling to usb_driver_claim_interface(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: syzbot+f84aa7209ccec829536f@syzkaller.appspotmail.com CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03regulator: fix crash caused by null driver dataYu Zhao
commit fb6de923ca3358a91525552b4907d4cb38730bdd upstream. dev_set_drvdata() needs to be called before device_register() exposes device to userspace. Otherwise kernel crashes after it gets null pointer from dev_get_drvdata() when userspace tries to access sysfs entries. [Removed backtrace for length -- broonie] Signed-off-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03spi: rspi: Fix interrupted DMA transfersGeert Uytterhoeven
commit 8dbbaa47b96f6ea5f09f922b4effff3c505cd8cf upstream. When interrupted, wait_event_interruptible_timeout() returns -ERESTARTSYS, and the SPI transfer in progress will fail, as expected: m25p80 spi0.0: SPI transfer failed: -512 spi_master spi0: failed to transfer one message from queue However, as the underlying DMA transfers may not have completed, all subsequent SPI transfers may start to fail: spi_master spi0: receive timeout qspi_transfer_out_in() returned -110 m25p80 spi0.0: SPI transfer failed: -110 spi_master spi0: failed to transfer one message from queue Fix this by calling dmaengine_terminate_all() not only for timeouts, but also for errors. This can be reproduced on r8a7991/koelsch, using "hd /dev/mtd0" followed by CTRL-C. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03spi: rspi: Fix invalid SPI use during system suspendGeert Uytterhoeven
commit c1ca59c22c56930b377a665fdd1b43351887830b upstream. If the SPI queue is running during system suspend, the system may lock up. Fix this by stopping/restarting the queue during system suspend/resume, by calling spi_master_suspend()/spi_master_resume() from the PM callbacks. In-kernel users will receive an -ESHUTDOWN error while system suspend/resume is in progress. Based on a patch for sh-msiof by Gaku Inami. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03spi: sh-msiof: Fix handling of write value for SISTR registerHiromitsu Yamasaki
commit 31a5fae4c5a009898da6d177901d5328051641ff upstream. This patch changes writing to the SISTR register according to the H/W user's manual. The TDREQ bit and RDREQ bits of SISTR are read-only, and must be written their initial values of zero. Signed-off-by: Hiromitsu Yamasaki <hiromitsu.yamasaki.ym@renesas.com> [geert: reword] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03spi: sh-msiof: Fix invalid SPI use during system suspendGaku Inami
commit ffa69d6a16f686efe45269342474e421f2aa58b2 upstream. If the SPI queue is running during system suspend, the system may lock up. Fix this by stopping/restarting the queue during system suspend/resume by calling spi_master_suspend()/spi_master_resume() from the PM callbacks. In-kernel users will receive an -ESHUTDOWN error while system suspend/resume is in progress. Signed-off-by: Gaku Inami <gaku.inami.xw@bp.renesas.com> Signed-off-by: Hiromitsu Yamasaki <hiromitsu.yamasaki.ym@renesas.com> [geert: Cleanup, reword] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03spi: tegra20-slink: explicitly enable/disable clockMarcel Ziswiler
commit 7001cab1dabc0b72b2b672ef58a90ab64f5e2343 upstream. Depending on the SPI instance one may get an interrupt storm upon requesting resp. interrupt unless the clock is explicitly enabled beforehand. This has been observed trying to bring up instance 4 on T20. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03serial: cpm_uart: return immediately from console pollChristophe Leroy
commit be28c1e3ca29887e207f0cbcd294cefe5074bab6 upstream. kgdb expects poll function to return immediately and returning NO_POLL_CHAR when no character is available. Fixes: f5316b4aea024 ("kgdb,8250,pl011: Return immediately from console poll") Cc: Jason Wessel <jason.wessel@windriver.com> Cc: <stable@vger.kernel.org> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03tty: serial: lpuart: avoid leaking struct tty_structStefan Agner
commit 3216c622a24b0ebb9c159a8d1daf7f17a106b3f5 upstream. The function tty_port_tty_get() gets a reference to the tty. Since the code is not using tty_port_tty_set(), the reference is kept even after closing the tty. Avoid using tty_port_tty_get() by directly access the tty instance. Since lpuart_start_rx_dma() is called from the .startup() and .set_termios() callback, it is safe to assume the tty instance is valid. Cc: stable@vger.kernel.org # v4.9+ Fixes: 5887ad43ee02 ("tty: serial: fsl_lpuart: Use cyclic DMA for Rx") Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03floppy: Do not copy a kernel pointer to user memory in FDGETPRM ioctlAndy Whitcroft
commit 65eea8edc315589d6c993cf12dbb5d0e9ef1fe4e upstream. The final field of a floppy_struct is the field "name", which is a pointer to a string in kernel memory. The kernel pointer should not be copied to user memory. The FDGETPRM ioctl copies a floppy_struct to user memory, including this "name" field. This pointer cannot be used by the user and it will leak a kernel address to user-space, which will reveal the location of kernel code and data and undermine KASLR protection. Model this code after the compat ioctl which copies the returned data to a previously cleared temporary structure on the stack (excluding the name pointer) and copy out to userspace from there. As we already have an inparam union with an appropriate member and that memory is already cleared even for read only calls make use of that as a temporary store. Based on an initial patch by Brian Belleville. CVE-2018-7755 Signed-off-by: Andy Whitcroft <apw@canonical.com> Broke up long line. Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03ARM: dts: dra7: fix DCAN node addressesKevin Hilman
[ Upstream commit 949bdcc8a97c6078f21c8d4966436b117f2e4cd3 ] Fix the DT node addresses to match the reg property addresses, which were verified to match the TRM: http://www.ti.com/lit/pdf/sprui30 Cc: Roger Quadros <rogerq@ti.com> Signed-off-by: Kevin Hilman <khilman@baylibre.com> Acked-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03EDAC: Fix memleak in module init error pathJohan Hovold
[ Upstream commit 4708aa85d50cc6e962dfa8acf5ad4e0d290a21db ] Make sure to use put_device() to free the initialised struct device so that resources managed by driver core also gets released in the event of a registration failure. Signed-off-by: Johan Hovold <johan@kernel.org> Cc: Denis Kirjanov <kirjanov@gmail.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: linux-edac <linux-edac@vger.kernel.org> Fixes: 2d56b109e3a5 ("EDAC: Handle error path in edac_mc_sysfs_init() properly") Link: http://lkml.kernel.org/r/20180612124335.6420-1-johan@kernel.org Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03nfsd: fix corrupted reply to badly ordered compoundJ. Bruce Fields
[ Upstream commit 5b7b15aee641904ae269be9846610a3950cbd64c ] We're encoding a single op in the reply but leaving the number of ops zero, so the reply makes no sense. Somewhat academic as this isn't a case any real client will hit, though in theory perhaps that could change in a future protocol extension. Reviewed-by: Jeff Layton <jlayton@kernel.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03gpio: Fix wrong rounding in gpio-menz127Nadav Amit
[ Upstream commit 7279d9917560bbd0d82813d6bf00490a82c06783 ] men_z127_debounce() tries to round up and down, but uses functions which are only suitable when the divider is a power of two, which is not the case. Use the appropriate ones. Found by static check. Compile tested. Fixes: f436bc2726c64 ("gpio: add driver for MEN 16Z127 GPIO controller") Signed-off-by: Nadav Amit <namit@vmware.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03module: exclude SHN_UNDEF symbols from kallsyms apiJessica Yu
[ Upstream commit 9f2d1e68cf4d641def734adaccfc3823d3575e6c ] Livepatch modules are special in that we preserve their entire symbol tables in order to be able to apply relocations after module load. The unwanted side effect of this is that undefined (SHN_UNDEF) symbols of livepatch modules are accessible via the kallsyms api and this can confuse symbol resolution in livepatch (klp_find_object_symbol()) and cause subtle bugs in livepatch. Have the module kallsyms api skip over SHN_UNDEF symbols. These symbols are usually not available for normal modules anyway as we cut down their symbol tables to just the core (non-undefined) symbols, so this should really just affect livepatch modules. Note that this patch doesn't affect the display of undefined symbols in /proc/kallsyms. Reported-by: Josh Poimboeuf <jpoimboe@redhat.com> Tested-by: Josh Poimboeuf <jpoimboe@redhat.com> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Jessica Yu <jeyu@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03ASoC: dapm: Fix potential DAI widget pointer deref when linking DAIsLiam Girdwood
[ Upstream commit e01b4f624278d5efe5fb5da585ca371947b16680 ] Sometime a component or topology may configure a DAI widget with no private data leading to a dev_dbg() dereferencne of this data. Fix this to check for non NULL private data and let users know if widget is missing DAI. Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-03EDAC, i7core: Fix memleaks and use-after-free on probe and removeJohan Hovold
[ Upstream commit 6c974d4dfafe5e9ee754f2a6fba0eb1864f1649e ] Make sure to free and deregister the addrmatch and chancounts devices allocated during probe in all error paths. Also fix use-after-free in a probe error path and in the remove success path where the devices were being put before before deregistration. Signed-off-by: Johan Hovold <johan@kernel.org> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: linux-edac <linux-edac@vger.kernel.org> Fixes: 356f0a30860d ("i7core_edac: change the mem allocation scheme to make Documentation/kobject.txt happy") Link: http://lkml.kernel.org/r/20180612124335.6420-2-johan@kernel.org Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
