commit 9bb2289f90e671bdb78e306974187424ac19ff8e upstream.
Implement adjust_link function that allows to overwrite default CPU port
setting using fixed-link device tree subnode.
Signed-off-by: Michal Vokáč <michal.vokac@ysoft.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
commit 218bbea11a777c156eb7bcbdc72867b32ae10985 upstream.
Add support for the four-port variant of the Qualcomm QCA833x switch.
The CPU port default link settings can be reconfigured using
a fixed-link sub-node.
Reviewed-by: Rob Herring <robh@kernel.org>
commit eee1fe64765c562d8bcaf95e5631a8ea2f760f34 upstream.
When a port is brought up/down do not enable/disable only the TXMAC
but the RXMAC as well. This is essential for the CPU port to work.
Fixes: 6b93fb46480a ("net-next: dsa: add new driver for qca8xxx family")
commit 79a4ed4f0f93fc65e48a0fc5247ffa5645f7b0cc upstream.
By default autonegotiation is enabled to configure MAC on all ports.
For the CPU port autonegotiation can not be used so we need to set
some sensible defaults manually.
This patch forces the default setting of the CPU port to 1000Mbps/full
duplex which is the chip maximum capability.
Also correct size of the bit field used to configure link speed.
commit 940efcc8889f0d15567eb07fc9fd69b06e366aa5 upstream.
Flows can be created on UD and RAW_PACKET QP types. Attempts to provide
other QP types as an input causes to various unpredictable failures.
The reason is that in order to support all various types (e.g. XRC), we
are supposed to use real_qp handle and not qp handle and expect to
driver/FW to fail such (XRC) flows. The simpler and safer variant is to
ban all QP types except UD and RAW_PACKET, instead of relying on
driver/FW.
Cc: <stable@vger.kernel.org> # 3.11
Fixes: 436f2ad05a0b ("IB/core: Export ib_create/destroy_flow through uverbs")
Cc: syzkaller <syzkaller@googlegroups.com>
Reported-by: Noa Osherovich <noaos@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 8d5a803c6a6ce4ec258e31f76059ea5153ba46ef upstream.
With commit 044e6e3d74a3: "ext4: don't update checksum of new
initialized bitmaps" the buffer valid bit will get set without
actually setting up the checksum for the allocation bitmap, since the
checksum will get calculated once we actually allocate an inode or
block.
If we are doing this, then we need to (re-)check the verified bit
after we take the block group lock. Otherwise, we could race with
another process reading and verifying the bitmap, which would then
complain about the checksum being invalid.
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1780137
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
commit 362eca70b53389bddf3143fe20f53dcce2cfdf61 upstream.
The inline data code was updating the raw inode directly; this is
problematic since if metadata checksums are enabled,
ext4_mark_inode_dirty() must be called to update the inode's checksum.
In addition, the jbd2 layer requires that get_write_access() be called
before the metadata buffer is modified. Fix both of these problems.
https://bugzilla.kernel.org/show_bug.cgi?id=200443
Cc: stable@vger.kernel.org
commit 01cfb7937a9af2abb1136c7e89fbf3fd92952956 upstream.
Anatoly Trosinenko reports that a corrupted squashfs image can cause a
kernel oops. It turns out that squashfs can end up being confused about
negative fragment lengths.
The regular squashfs_read_data() does check for negative lengths, but
squashfs_read_metadata() did not, and the fragment size code just
blindly trusted the on-disk value. Fix both the fragment parsing and
the metadata reading code.
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
commit 81e69df38e2911b642ec121dec319fad2a4782f3 upstream.
Fedora has integrated the jitter entropy daemon to work around slow
boot problems, especially on VM's that don't support virtio-rng:
https://bugzilla.redhat.com/show_bug.cgi?id=1572944
It's understandable why they did this, but the Jitter entropy daemon
works fundamentally on the principle: "the CPU microarchitecture is
**so** complicated and we can't figure it out, so it *must* be
random". Yes, it uses statistical tests to "prove" it is secure, but
AES_ENCRYPT(NSA_KEY, COUNTER++) will also pass statistical tests with
flying colors.
So if RDRAND is available, mix it into entropy submitted from
userspace. It can't hurt, and if you believe the NSA has backdoored
RDRAND, then they probably have enough details about the Intel
microarchitecture that they can reverse engineer how the Jitter
entropy daemon affects the microarchitecture, and attack its output
stream. And if RDRAND is in fact an honest DRNG, it will immeasurably
improve on what the Jitter entropy daemon might produce.
This also provides some protection against someone who is able to read
or set the entropy seed file.
[ Upstream commit 4f212e40468650e220c1770876c7f25b8e0c1ff5 ]
To comply with eDP1.4a this bit should be set when enabling PSR2.
Signed-off-by: José Roberto de Souza <jose.souza@intel.com>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180328223046.16125-1-jose.souza@intel.com
[ Upstream commit 90db5c829692a0a7845e977e45719b4699216bd4 ]
The annotations there are wrong as warned:
drivers/media/radio/si470x/radio-si470x-i2c.c:107:35: warning: cast to restricted __be16
drivers/media/radio/si470x/radio-si470x-i2c.c:129:24: warning: incorrect type in assignment (different base types)
drivers/media/radio/si470x/radio-si470x-i2c.c:129:24: expected unsigned short [unsigned] [short] <noident>
drivers/media/radio/si470x/radio-si470x-i2c.c:129:24: got restricted __be16 [usertype] <noident>
drivers/media/radio/si470x/radio-si470x-i2c.c:163:39: warning: cast to restricted __be16
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 3239b8cd28fd849a2023483257d35d68c5876c74 ]
Hardware could time out Fastpath IOs one second earlier than the timeout
provided by the host.
For non-RAID devices, driver provides timeout value based on OS provided
timeout value. Under certain scenarios, if the OS provides a timeout
value of 1 second, due to above behavior hardware will timeout
immediately.
Increase timeout value for non-RAID fastpath IOs by 1 second.
Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com>
[ Upstream commit 37b37d2609cb0ac267280ef27350b962d16d272e ]
SGI/TP9100 is not an RDAC array:
https://git.opensvc.com/gitweb.cgi?p=multipath-tools/.git;a=blob;f=libmultipath/hwtable.c;h=88b4700beb1d8940008020fbe4c3cd97d62f4a56;hb=HEAD#l235
This partially reverts commit 35204772ea03 ("[SCSI] scsi_dh_rdac :
Consolidate rdac strings together")
[mkp: fixed up the new entries to align with rest of struct]
Cc: NetApp RDAC team <ng-eseries-upstream-maintainers@netapp.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: James E.J. Bottomley <jejb@linux.vnet.ibm.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: SCSI ML <linux-scsi@vger.kernel.org>
Cc: DM ML <dm-devel@redhat.com>
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
[ Upstream commit b7e1e6859fbf60519fd82d7120cee106a6019512 ]
The OMAP3 ISP driver manages its MMU mappings through the IOMMU-aware
ARM DMA backend. The current code creates a dma_iommu_mapping and
attaches this to the ISP device, but never detaches the mapping in
either the probe failure paths or the driver remove path resulting
in an unbalanced mapping refcount and a memory leak. Fix this properly.
Reported-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Suman Anna <s-anna@ti.com>
Tested-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
[ Upstream commit ad2fdcdf75d169e7a5aec6c7cb421c0bec8ec711 ]
In crypto_authenc_setkey we save pointers to the authenc keys in
a local variable of type struct crypto_authenc_keys and we don't
zeroize it after use. Fix this and don't leak pointers to the
authenc keys.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
[ Upstream commit 31545df391d58a3bb60e29b1192644a6f2b5a8dd ]
In crypto_authenc_esn_setkey we save pointers to the authenc keys
in a local variable of type struct crypto_authenc_keys and we don't
authenc keys.
[ Upstream commit 5d111f5190848d6fb1c414dc57797efea3526a2f ]
wait_for_connected() wait till a port change status to
USB_PORT_STAT_CONNECTION, but this is not possible if
the port is unpowered. The loop will only exit at timeout.
Such case take place if an over-current incident happen
while system is in S3. Then during resume wait_for_connected()
will wait 2s, which may be noticeable by the user.
Signed-off-by: Dominik Bozek <dominikx.bozek@intel.com>
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
[ Upstream commit ece97f3a5fb50cf5f98886fbc63c9665f2bb199d ]
simpleImage generation was broken for some time. This patch is fixing
steps how simpleImage.*.ub file is generated. Steps are objdump of
vmlinux and create .ub.
Also make sure that there is striped elf version with .strip suffix.
[ Upstream commit c1c734cb1f54b062f7e67ffc9656d82f5b412b9c ]
As part of bringup I ended up wanting to call an earlycon driver by a
name that was exactly 16-bytes big, specifically "qcom_geni_serial".
Unfortunately, when I tried this I found that things compiled just
fine. They just didn't work.
Specifically the compiler felt perfectly justified in initting the
".name" field of "struct earlycon_id" with the full 16-bytes and just
skipping the '\0'. Needless to say, that behavior didn't seem ideal,
but I guess someone must have allowed it for a reason.
One way to fix this is to shorten the name field to 15 bytes and then
add an extra byte after that nobody touches. This should always be
initted to 0 and we're golden.
There are, of course, other ways to fix this too. We could audit all
the users of the "name" field and make them stop at both null
termination or at 16 bytes. We could also just make the name field
much bigger so that we're not likely to run into this. ...but both
seem like we'll just hit the bug again.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
[ Upstream commit d8caf662b4aeeb2ac83ac0b22e40db88e9360c77 ]
ldlm_lock_create() gets a resource, but don't put it on
all failure paths. It should.
Signed-off-by: NeilBrown <neilb@suse.com>
Reviewed-by: James Simmons <jsimmons@infradead.org>
[ Upstream commit 1b60f6dfa38403ff7c4d0b4b7ecdb810f9789a2a ]
In ll_xattr_set_common() detect the removexattr() case correctly by
testing for a NULL value as well as XATTR_REPLACE.
Signed-off-by: John L. Hammond <john.hammond@intel.com>
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-10787
Reviewed-on: https://review.whamcloud.com/
Reviewed-by: Dmitry Eremin <dmitry.eremin@intel.com>
Reviewed-by: James Simmons <uja.ornl@yahoo.com>
Signed-off-by: James Simmons <jsimmons@infradead.org>
[ Upstream commit 23bcc480dac204c7dbdf49d96b2c918ed98223c2 ]
Current implementation of auditing by executable name only implements
the 'equal' operator. This patch extends it to also support the 'not
equal' operator.
See: https://github.com/linux-audit/audit-kernel/issues/53
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 78e450719c702784e42af6da912d3692fd3da0cb ]
While performing cleanup, driver is messing with card->ocr
value by not masking rocr against ocr_avail. Below panic
is observed with some of the SDIO host controllers due to
this. Issue is resolved by reverting incorrect modifications
to vdd.
[ 927.423821] mmc1: Invalid vdd 0x1f
[ 927.423925] Modules linked in: rsi_sdio(+) cmac bnep arc4 rsi_91x
mac80211 cfg80211 btrsi rfcomm bluetooth ecdh_generic
[ 927.424073] CPU: 0 PID: 1624 Comm: insmod Tainted: G W 4.15.0-1000-caracalla #1
[ 927.424075] Hardware name: Dell Inc. Edge Gateway 3003/ , BIOS 01.00.06 01/22/2018
[ 927.424082] RIP: 0010:sdhci_set_power_noreg+0xdd/0x190[sdhci]
[ 927.424085] RSP: 0018:ffffac3fc064b930 EFLAGS: 00010282
[ 927.424107] Call Trace:
[ 927.424118] sdhci_set_power+0x5a/0x60 [sdhci]
[ 927.424125] sdhci_set_ios+0x360/0x3b0 [sdhci]
[ 927.424133] mmc_set_initial_state+0x92/0x120
[ 927.424137] mmc_power_up.part.34+0x33/0x1d0
[ 927.424141] mmc_power_up+0x17/0x20
[ 927.424147] mmc_sdio_runtime_resume+0x2d/0x50
[ 927.424151] mmc_runtime_resume+0x17/0x20
[ 927.424156] __rpm_callback+0xc4/0x200
[ 927.424161] ? idr_alloc_cyclic+0x57/0xd0
[ 927.424165] ? mmc_runtime_suspend+0x20/0x20
[ 927.424169] rpm_callback+0x24/0x80
[ 927.424172] ? mmc_runtime_suspend+0x20/0x20
[ 927.424176] rpm_resume+0x4b3/0x6c0
[ 927.424181] __pm_runtime_resume+0x4e/0x80
[ 927.424188] driver_probe_device+0x41/0x490
[ 927.424192] __driver_attach+0xdf/0xf0
[ 927.424196] ? driver_probe_device+0x490/0x490
[ 927.424201] bus_for_each_dev+0x6c/0xc0
[ 927.424205] driver_attach+0x1e/0x20
[ 927.424209] bus_add_driver+0x1f4/0x270
[ 927.424217] ? rsi_sdio_ack_intr+0x50/0x50 [rsi_sdio]
[ 927.424221] driver_register+0x60/0xe0
[ 927.424227] ? rsi_sdio_ack_intr+0x50/0x50 [rsi_sdio]
[ 927.424231] sdio_register_driver+0x20/0x30
[ 927.424237] rsi_module_init+0x16/0x40 [rsi_sdio]
Signed-off-by: Siva Rebbagondla <siva.rebbagondla@redpinesignals.com>
Signed-off-by: Amitkumar Karwar <amit.karwar@redpinesignals.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 300eec7c0a2495f771709c7642aa15f7cc148b83 ]
ic_nameservers, which stores the list of name servers discovered by
ipconfig, is initialised (i.e. has all of its elements set to NONE, or
0xffffffff) by ic_nameservers_predef() in the following scenarios:
- before the "ip=" and "nfsaddrs=" kernel command line parameters are
parsed (in ip_auto_config_setup());
- before autoconfiguring via DHCP or BOOTP (in ic_bootp_init()), in
order to clear any values that may have been set after parsing "ip="
or "nfsaddrs=" and are no longer needed.
This means that ic_nameservers_predef() is not called when neither "ip="
nor "nfsaddrs=" is specified on the kernel command line. In this
scenario, every element in ic_nameservers remains set to 0x00000000,
which is indistinguishable from ANY and causes pnp_seq_show() to write
the following (bogus) information to /proc/net/pnp:
#MANUAL
nameserver 0.0.0.0
nameserver 0.0.0.0
nameserver 0.0.0.0
This is potentially problematic for systems that blindly link
/etc/resolv.conf to /proc/net/pnp.
Ensure that ic_nameservers is also initialised when neither "ip=" nor
"nfsaddrs=" are specified by calling ic_nameservers_predef() in
ip_auto_config(), but only when ip_auto_config_setup() was not called
earlier. This causes the following to be written to /proc/net/pnp, and
is consistent with what gets written when ipconfig is configured
manually but no name servers are specified on the kernel command line:
#MANUAL
Signed-off-by: Chris Novakovic <chris@chrisn.me.uk>
[ Upstream commit 2ea009095c6e7396915a1d0dd480c41f02985f79 ]
The method struct drm_connector_helper_funcs::mode_valid is defined
as returning an 'enum drm_mode_status' but the driver implementation
for this method, psb_intel_lvds_mode_valid(), uses an 'int' for it.
Fix this by using 'enum drm_mode_status' for psb_intel_lvds_mode_valid().
Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20180424131458.2060-1-luc.vanoostenryck@gmail.com
[ Upstream commit 7c8b77f81552c2b0e5d9c560da70bc4149ce66a5 ]
Heiko Stübner justified pretty well the change in commit e330eb86ba0b
("ARM: multi_v7_defconfig: enable Rockchip io-domain driver"). This
change is also needed for arm64 rockchip boards, so, do the same for arm64.
The io-domain driver is necessary to notify the soc about voltages
changes happening on supplying regulators. Probably the most important
user right now is the mmc tuning code, where the soc needs to get
notified when the voltage is dropped to the 1.8V point.
As this option is necessary to successfully tune UHS cards etc, it
should get built in. Otherwise, tuning will fail with,
dwmmc_rockchip fe320000.dwmmc: All phases bad!
mmc0: tuning execution failed: -5
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit 1c74d5c0de0c2cc29fef97a19251da2ad6f579bd ]
Currently we are enabling handling of interrupts specific to Tegra124+
which happen to overlap with previous generations. Let's specify
interrupts mask per SoC generation for consistency and in a preparation
of squashing of Tegra20 driver into the common one that will enable
handling of GART faults which may be undesirable by newer generations.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit bf3fbdfbec947cdd04b2f2c4bce11534c8786eee ]
The ISR reads interrupts-enable mask, but doesn't utilize it. Apply the
mask to the interrupt status and don't handle interrupts that MC driver
haven't asked for. Kernel would disable spurious MC IRQ and report the
error. This would happen only in a case of a very severe bug.
[ Upstream commit de5b55c1d4e30740009864eb35ce4ed856aac01d ]
Use raw-locks in stop_machine() to allow locking in irq-off and
preempt-disabled regions on -RT. This also documents the possible locking
context in general.
[bigeasy: update patch description.]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: https://lkml.kernel.org/r/20180423191635.6014-1-bigeasy@linutronix.de
[ Upstream commit 7e5d05e18ba1ed491c6f836edee7f0b90f3167bc ]
We need to introduce a new compatible name for the Meson-AXG SoC
in order to support the RMII 100M ethernet PHY, since the PRG_ETH0
register of the dwmac glue layer is changed from previous old SoC.
Signed-off-by: Yixun Lan <yixun.lan@amlogic.com>
[ Upstream commit 03d9fbc39730b3e6b2e7047dc85f0f70de8fb97d ]
The Meson8m2 SoC is a variant of Meson8 with some updates from Meson8b
(such as the Gigabit capable DesignWare MAC).
It is mostly pin compatible with Meson8, only 10 (existing) CBUS pins
get an additional function (four of these are Ethernet RXD2, RXD3, TXD2
and TXD3 which are required when the board uses an RGMII PHY).
The AOBUS pins seem to be identical on Meson8 and Meson8m2.
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
[ Upstream commit 486e6661367b40f927aadbed73237693396cbf94 ]
The use of stack Variable Length Arrays needs to be avoided, as they
can be a vector for stack exhaustion, which can be both a runtime bug
(kernel Oops) or a security flaw (overwriting memory beyond the
stack). Also, in general, as code evolves it is easy to lose track of
how big a VLA can get. Thus, we can end up having runtime failures
that are hard to debug. As part of the directive[1] to remove all VLAs
from the kernel, and build with -Wvla.
Currently driver is using a VLA declared using the number of descriptors. This
array is used to store integer values and is later used as an argument to
`gpiod_set_array_value_cansleep()` This can be avoided by using
`kmalloc_array()` to allocate memory for the array of integer values. Memory is
free'd before return from function.
>From the code it appears that it is safe to sleep so we can use GFP_KERNEL
(based _cansleep() suffix of function `gpiod_set_array_value_cansleep()`.
It can be expected that this patch will result in a small increase in overhead
due to the use of `kmalloc_array()`
[1] https://lkml.org/lkml/2018/3/7/621
Signed-off-by: Tobin C. Harding <me@tobin.cc>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit ff178981bd5fd1667f373098740cb1c6d6efa1ba ]
Respect the actual clock for mmc debugfs to help better debug
the hardware.
mmc_host mmc0: Bus speed (slot 0) = 135475200Hz (slot req 150000000Hz,
actual 135475200HZ div = 0)
cat /sys/kernel/debug/mmc0/ios
clock: 150000000 Hz
actual clock: 135475200 Hz
vdd: 21 (3.3 ~ 3.4 V)
bus mode: 2 (push-pull)
chip select: 0 (don't care)
power mode: 2 (on)
bus width: 3 (8 bits)
timing spec: 9 (mmc HS200)
signal voltage: 0 (1.80 V)
driver type: 0 (driver type B)
Cc: Xiao Yao <xiaoyao@rock-chips.com>
Cc: Ziyuan <xzy.xu@rock-chips.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
[ Upstream commit 8e142e9e628975b0dddd05cf1b095331dff6e2de ]
DECLARE_TLV_DB_SCALE (alias of SNDRV_CTL_TLVD_DECLARE_DB_SCALE) is used but
tlv.h is not included. This causes build failure when local macro is
defined by comment-out.
This commit fixes the bug. At the same time, the alias macro is replaced
with a destination macro added at a commit 46e860f76804 ("ALSA: rename
TLV-related macros so that they're friendly to user applications")
Reported-by: Connor McAdams <conmanx360@gmail.com>
Fixes: 44f0c9782cc6 ('ALSA: hda/ca0132: Add tuning controls')
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
[ Upstream commit fc2a69f3903dfd97cd47f593e642b47918c949df ]
In the func drm_atomic_set_crtc_for_plane, with the current code,
if crtc of the plane_state and crtc passed as argument to the func
are same, entire func will executed in vein.
It will get state of crtc and clear and set the bits in plane_mask.
All these steps are not required for same old crtc.
Ideally, we should do nothing in this case, this patch handles the same,
and causes the program to return without doing anything in such scenario.
Signed-off-by: Satendra Singh Thakur <satendra.t@samsung.com>
Cc: Madhur Verma <madhur.verma@samsung.com>
Cc: Hemanshu Srivastava <hemanshu.s@samsung.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1525326572-25854-1-git-send-email-satendra.t@samsung.com
[ Upstream commit e1b7f11b37def5f3021c06e8c2b4953e099357aa ]
Those are all false-positives that appear with smatch when building for
arm:
drivers/media/common/siano/smsendian.c:38:36: warning: cast to restricted __le32
drivers/media/common/siano/smsendian.c:47:44: warning: cast to restricted __le32
drivers/media/common/siano/smsendian.c:67:35: warning: cast to restricted __le16
drivers/media/common/siano/smsendian.c:84:44: warning: cast to restricted __le32
drivers/media/common/siano/smsendian.c:98:26: warning: cast to restricted __le16
drivers/media/common/siano/smsendian.c:99:28: warning: cast to restricted __le16
drivers/media/common/siano/smsendian.c:100:27: warning: cast to restricted __le16
Get rid of them by adding explicit forced casts.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit ab7f5bf0928be2f148d000a6eaa6c0a36e74750e ]
Comments in the verifier refer to free_bpf_prog_info() which
seems to have never existed in tree. Replace it with
free_used_maps().
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 8bfc218d0ebbabcba8ed2b8ec1831e0cf1f71629 ]
Add missing clearing of the previous value when setting rising
temperature threshold.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
[ Upstream commit cf04968efe341b9b1c30a527e5dd61b2af9c43d2 ]
cmid will be destroyed at OFED if kiblnd_cm_callback return error.
if error happen before the end of kiblnd_connect_peer, it will touch
destroyed cmid and fail as
(o2iblnd_cb.c:1315:kiblnd_connect_peer())
ASSERTION( cmid->device != ((void *)0) ) failed:
Signed-off-by: Alexander Boyko <alexander.boyko@seagate.com>
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-10015
Reviewed-by: Alexey Lyashkov <c17817@cray.com>
Reviewed-by: Doug Oucharek <dougso@me.com>
Reviewed-by: John L. Hammond <john.hammond@intel.com>
Signed-off-by: Doug Oucharek <dougso@me.com>
[ Upstream commit 27e833dabab74ee665e487e291c9afc6d71effba ]
If we had more than 32 megaraid cards then it would cause memory
corruption. That's not likely, of course, but it's handy to enforce it
and make the static checker happy.
[ Upstream commit 9899e4d3523faaef17c67141aa80ff2088f17871 ]
In tw_chrdev_ioctl(), the length of the data buffer is firstly copied
from the userspace pointer 'argp' and saved to the kernel object
'data_buffer_length'. Then a security check is performed on it to make
sure that the length is not more than 'TW_MAX_IOCTL_SECTORS *
512'. Otherwise, an error code -EINVAL is returned. If the security
check is passed, the entire ioctl command is copied again from the
'argp' pointer and saved to the kernel object 'tw_ioctl'. Then, various
operations are performed on 'tw_ioctl' according to the 'cmd'. Given
that the 'argp' pointer resides in userspace, a malicious userspace
process can race to change the buffer length between the two
copies. This way, the user can bypass the security check and inject
invalid data buffer length. This can cause potential security issues in
the following execution.
This patch checks for capable(CAP_SYS_ADMIN) in tw_chrdev_open() to
avoid the above issues.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
Acked-by: Adam Radford <aradford@gmail.com>
[ Upstream commit c9318a3e0218bc9dacc25be46b9eec363259536f ]
In twa_chrdev_ioctl(), the ioctl driver command is firstly copied from
'driver_command'. Then a security check is performed on the data buffer
size indicated by 'driver_command', which is
'driver_command.buffer_length'. If the security check is passed, the
entire ioctl command is copied again from the 'argp' pointer and saved
to the kernel object 'tw_ioctl'. Then, various operations are performed
on 'tw_ioctl' according to the 'cmd'. Given that the 'argp' pointer
resides in userspace, a malicious userspace process can race to change
the buffer size between the two copies. This way, the user can bypass
the security check and inject invalid data buffer size. This can cause
potential security issues in the following execution.
This patch checks for capable(CAP_SYS_ADMIN) in twa_chrdev_open()t o
[ Upstream commit dac0490718bd17df5e3995ffca14255e5f9ed22d ]
Only non-NPAR PFs need to actively check and manage unsupported link
speeds. NPAR functions and VFs do not control the link speed and
should skip the unsupported speed detection logic, to avoid warning
messages from firmware rejecting the unsupported firmware calls.
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 3c0a83b14ea71fef5ccc93a3bd2de5f892be3194 ]
The s390 CPU measurement facility sampling mode supports basic entries
and diagnostic entries. Each entry has a valid bit to indicate the
status of the entry as valid or invalid.
This bit is bit 31 in the diagnostic entry, but the bit mask definition
refers to bit 30.
Fix this by making the reserved field one bit larger.
Fixes: 7e75fc3ff4cf ("s390/cpum_sf: Add raw data sampling to support the diagnostic-sampling function")
Signed-off-by: Thomas Richter <tmricht@linux.ibm.com>
Reviewed-by: Hendrik Brueckner <brueckner@linux.ibm.com>
[ Upstream commit 77715b7ddb446bd39a06f3376e85f4bb95b29bb8 ]
The CPU Measurement sampling facility creates a trailer entry for each
Sample-Data-Block of stored samples. The trailer entry contains the sizes
(in bytes) of the stored sampling types:
- basic-sampling data entry size
- diagnostic-sampling data entry size
Both sizes are 2 bytes long.
This patch changes the trailer entry definition to reflect this.
Fixes: fcc77f507333 ("s390/cpum_sf: Atomically reset trailer entry fields of sample-data-blocks")
[ Upstream commit 9c4a121e82634aa000a702c98cd6f05b27d6e186 ]
Add support for the BCM43364 chipset via an SDIO interface, as used in
e.g. the Murata 1FX module.
The BCM43364 uses the same firmware as the BCM43430 (which is already
included), the only difference is the omission of Bluetooth.
However, the SDIO_ID for the BCM43364 is 02D0:A9A4, giving it a MODALIAS
of sdio:c00v02D0dA9A4, which doesn't get recognised and hence doesn't
load the brcmfmac module. Adding the 'A9A4' ID in the appropriate place
triggers the brcmfmac driver to load, and then correctly use the
firmware file 'brcmfmac43430-sdio.bin'.
Signed-off-by: Sean Lanigan <sean@lano.id.au>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit a75bbe71a27875fdc61cde1af6d799037cef6bed ]
Per ONFI specification (Rev. 4.0), if the CRC of the first parameter page
read is not valid, the host should read redundant parameter page copies.
Fix FSL NAND driver to read the two redundant copies which are mandatory
in the specification.
Signed-off-by: Jane Wan <Jane.Wan@nokia.com>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
[ Upstream commit 0cc4655cb57af0b7e105d075c4f83f8046efafe7 ]
This issue was reported by a user who downloaded a corrupt saa7164
firmware, then went looking for a valid xc5000 firmware to fix the
error displayed...but the device in question has no xc5000, thus after
much effort, the wild goose chase eventually led to a support call.
The xc5000 has nothing to do with saa7164 (as far as I can tell),
so replace the string with saa7164 as well as give a meaningful
hint on the firmware mismatch.
Signed-off-by: Brad Love <brad@nextdimension.cc>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[ Upstream commit daa36370b62428cca6d48d1b2530a8419f631c8c ]
This change fixes function types for media device ioctls to avoid
indirect call mismatches with Control-Flow Integrity checking.
Signed-off-by: Sami Tolvanen <samitolvanen@google.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
