commit 69d3973af1acd4c0989ec8218c05f12d303cd7cf upstream.
gcc-7.0.1 warns about old code in ttpci:
In file included from drivers/media/pci/ttpci/av7110.c:63:0:
In function 'irdebi.isra.2',
inlined from 'start_debi_dma' at drivers/media/pci/ttpci/av7110.c:376:3,
inlined from 'gpioirq' at drivers/media/pci/ttpci/av7110.c:659:3:
drivers/media/pci/ttpci/av7110_hw.h:406:3: warning: 'memcpy': specified size between 18446744071562067968 and 18446744073709551615 exceeds maximum object size 9223372036854775807 [-Wstringop-overflow=]
memcpy(av7110->debi_virt, (char *) &res, count);
inlined from 'gpioirq' at drivers/media/pci/ttpci/av7110.c:668:3:
Apparently, 'count' can be negative here, which will then get turned
into a giant size argument for memcpy. Changing the sizes to 'unsigned
int' instead seems safe as we already check for maximum sizes, and it
also simplifies the code a bit.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 13f99ebdd602ebdafb909e15ec6ffb1e34690167 upstream.
The latest gcc-7.0.1 snapshot points out that we if nr_ch is zero, we never
initialize some variables:
sound/pci/au88x0/au88x0_core.c: In function 'vortex_adb_allocroute':
sound/pci/au88x0/au88x0_core.c:2304:68: error: 'mix[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
sound/pci/au88x0/au88x0_core.c:2305:58: error: 'src[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
I assume this can never happen in practice, but adding a check here doesn't
hurt either and avoids the warning. The code has been unchanged since
the start of git history.
commit 0527873b29b077fc8e656acd63e1866b429fef55 upstream.
gcc-7 warns about some declarations that are more 'const' than necessary:
arch/arm/mach-at91/pm.c:338:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const ramc_ids[] __initconst = {
arch/arm/mach-bcm/bcm_kona_smc.c:36:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const bcm_kona_smc_ids[] __initconst = {
arch/arm/mach-spear/time.c:207:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const timer_of_match[] __initconst = {
arch/arm/mach-omap2/prm_common.c:714:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const omap_prcm_dt_match_table[] __initconst = {
arch/arm/mach-omap2/vc.c:562:35: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct i2c_init_data const omap4_i2c_timing_data[] __initconst = {
The ones in arch/arm were apparently all introduced accidentally by one
commit that correctly marked a lot of variables as __initconst.
Fixes: 19c233b79d1a ("ARM: appropriate __init annotation for const data")
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Krzysztof Hałasa <khalasa@piap.pl>
commit f6aafac184a3e46e919769dd4faa8bf0dc436534 upstream.
aarch64-linux-gcc-7 complains about code it doesn't fully understand:
drivers/infiniband/hw/qib/qib_iba7322.c: In function 'qib_7322_txchk_change':
include/asm-generic/bitops/non-atomic.h:105:35: error: 'shadow' may be used uninitialized in this function [-Werror=maybe-uninitialized]
The code is right, and despite trying hard, I could not come up with a version
that I liked better than just adding a fake initialization here to shut up the
warning.
Fixes: f931551bafe1 ("IB/qib: Add new qib driver for QLogic PCIe InfiniBand adapters")
Acked-by: Ira Weiny <ira.weiny@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 1d2d8de44a6c20af262b4c3d3b93ef7ec3c5488e upstream.
This is to fix below sparse warning:
drivers/firmware/psci.c:mmm:nn: warning: duplicate const
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
[ Upstream commit d85fc67dd11e9a32966140677d4d6429ca540b25 ]
Without this patch, failed probe would not free resources like irq.
ata port tdev object currently hold a reference to the ata port
object. Therefore the ata port object release function will not get
called until the ata_tport_release is called. But that would never
happen, releasing the last reference of ata port dev is done by
scsi_host_release, which is called by ata_host_release when the ata
port object is released.
The ata device objects actually do not need to explicitly hold a
reference to their real counterpart, given the transport objects are
the children of these objects and device_add() is call for each child.
We know the parent will not be deleted until we call the child's
device_del().
Reported-by: Matthew Whitehead <tedheadster@gmail.com>
Tested-by: Matthew Whitehead <tedheadster@gmail.com>
Suggested-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Gwendal Grignou <gwendal@chromium.org>
[ Upstream commit 08b005f1333154ae5b404ca28766e0ffb9f1c150 ]
The sole remaining caller of kmem_zalloc_greedy is bulkstat, which uses
it to grab 1-4 pages for staging of inobt records. The infinite loop in
the greedy allocation function is causing hangs[1] in generic/269, so
just get rid of the greedy allocator in favor of kmem_zalloc_large.
This makes bulkstat somewhat more likely to ENOMEM if there's really no
pages to spare, but eliminates a source of hangs.
[1] http://lkml.kernel.org/r/20170301044634.rgidgdqqiiwsmfpj%40XZHOUW.usersys.redhat.com
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
[ Upstream commit 3b0277f198ac928f323c42e180680d2f79aa980d ]
Most likely a copy & paste error.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Acked-by: Jerome Brunet <jbrunet@baylibre.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Fixes: 30021e3707a7 ("i2c: add support for Amlogic Meson I2C controller")
[ Upstream commit 6d399783e9d4e9bd44931501948059d24ad96ff8 ]
Commit 57c67df(md/raid10: submit IO from originating thread instead of
md thread) submits bio directly for normal disks but not for replacement
disks. There is no point we shouldn't do this for replacement disks.
Cc: NeilBrown <neilb@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit 3b12f73a5c2977153f28a224392fd4729b50d1dc ]
In the function rds_ib_setup_qp, the error handle is missing. When some
error occurs, it is possible that memory leak occurs. As such, error
handle is added.
Cc: Joe Jin <joe.jin@oracle.com>
Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Guanglei Li <guanglei.li@oracle.com>
Signed-off-by: Zhu Yanjun <yanjun.zhu@oracle.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit ed46e66cc1b3d684042f92dfa2ab15ee917b4cac ]
Do a check for already installed leaf entry at the current level before
dereferencing it in order to avoid walking the page table down with
wrong pointer to the next level.
Signed-off-by: Oleksandr Tyshchenko <oleksandr_tyshchenko@epam.com>
CC: Will Deacon <will.deacon@arm.com>
CC: Robin Murphy <robin.murphy@arm.com>
[ Upstream commit 74e3f6e63da6c8e8246fba1689e040bc926b4a1a ]
Fix potential NULL pointer dereference and clean up
coding style errors (code indent, trailing whitespaces).
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit ae5c682113f9f94cc5e76f92cf041ee624c173ee ]
The helper->expect_class_max must be set to the total number of
expect_policy minus 1, since we will use the statement "if (class >
helper->expect_class_max)" to validate the CTA_EXPECT_CLASS attr in
ctnetlink_alloc_expect.
So for compatibility, set the helper->expect_class_max to the
NFCTH_POLICY_SET_NUM attr's value minus 1.
Also: it's invalid when the NFCTH_POLICY_SET_NUM attr's value is zero.
1. this will result "expect_policy = kzalloc(0, GFP_KERNEL);";
2. we cannot set the helper->expect_class_max to a proper value.
So if nla_get_be32(tb[NFCTH_POLICY_SET_NUM]) is zero, report -EINVAL to
the userspace.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
[ Upstream commit d7f3e33df4fbdc9855fb151f4a328ec46447e3ba ]
In the case of semi planar formats cb and cr are in the same plane
in memory, meaning that will be set to 'cb' whatever the format is,
and whatever the (packed) order of those components are.
Suggested-by: Nicolas Dufresne <nicolas.dufresne@collabora.com>
Signed-off-by: Thibault Saunier <thibault.saunier@osg.samsung.com>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[ Upstream commit db8466c581cca1a08b505f1319c3ecd246f16fa8 ]
When the separate IRQ stack was introduced, stack unwinding only
proceeded as far as the top of the IRQ stack, leading to kernel
backtraces being less useful, lacking the trace of what was interrupted.
Fix this by providing a means for the kernel to unwind the IRQ stack
onto the interrupted task stack. The processor state is saved to the
kernel task stack on interrupt. The IRQ_STACK_START macro reserves an
unsigned long at the top of the IRQ stack where the interrupted task
stack pointer can be saved. After the active stack is switched to the
IRQ stack, save the interrupted tasks stack pointer to the reserved
location.
Fix the stack unwinding code to look for the frame being the top of the
IRQ stack and if so get the next frame from the saved location. The
existing test does not work with the separate stack since the ra is no
longer pointed at ret_from_{irq,exception}.
The test to stop unwinding the stack 32 bytes from the top of a stack
must be modified to allow unwinding to continue up to the location of
the saved task stack pointer when on the IRQ stack. The low / high marks
of the stack are set depending on whether the sp is on an irq stack or
not.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Jason A. Donenfeld <jason@zx2c4.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15788/
[ Upstream commit 3b7dabf029478bb80507a6c4500ca94132a2bc0b ]
Otherwise, another CPU may access the invalid pointer. For example:
CPU0 CPU1
- rcu_read_lock();
- pfunc = _hook_;
_hook_ = NULL; -
mod unload -
- pfunc(); // invalid, panic
- rcu_read_unlock();
So we must call synchronize_rcu() to wait the rcu reader to finish.
Also note, in nf_nat_snmp_basic_fini, synchronize_rcu() will be invoked
by later nf_conntrack_helper_unregister, but I'm inclined to add a
explicit synchronize_rcu after set the nf_nat_snmp_hook to NULL. Depend
on such obscure assumptions is not a good idea.
Last, in nfnetlink_cttimeout, we use kfree_rcu to free the time object,
so in cttimeout_exit, invoking rcu_barrier() is not necessary at all,
remove it too.
[ Upstream commit 5b8d5429daa05bebef6ffd3297df3b502cc6f184 ]
Peter reported a kernel oops when executing the following command:
$ ip link add name test type bridge vlan_default_pvid 1
[13634.939408] BUG: unable to handle kernel NULL pointer dereference at
0000000000000190
[13634.939436] IP: __vlan_add+0x73/0x5f0
[13634.939783] Call Trace:
[13634.939791] ? pcpu_next_unpop+0x3b/0x50
[13634.939801] ? pcpu_alloc+0x3d2/0x680
[13634.939810] ? br_vlan_add+0x135/0x1b0
[13634.939820] ? __br_vlan_set_default_pvid.part.28+0x204/0x2b0
[13634.939834] ? br_changelink+0x120/0x4e0
[13634.939844] ? br_dev_newlink+0x50/0x70
[13634.939854] ? rtnl_newlink+0x5f5/0x8a0
[13634.939864] ? rtnl_newlink+0x176/0x8a0
[13634.939874] ? mem_cgroup_commit_charge+0x7c/0x4e0
[13634.939886] ? rtnetlink_rcv_msg+0xe1/0x220
[13634.939896] ? lookup_fast+0x52/0x370
[13634.939905] ? rtnl_newlink+0x8a0/0x8a0
[13634.939915] ? netlink_rcv_skb+0xa1/0xc0
[13634.939925] ? rtnetlink_rcv+0x24/0x30
[13634.939934] ? netlink_unicast+0x177/0x220
[13634.939944] ? netlink_sendmsg+0x2fe/0x3b0
[13634.939954] ? _copy_from_user+0x39/0x40
[13634.939964] ? sock_sendmsg+0x30/0x40
[13634.940159] ? ___sys_sendmsg+0x29d/0x2b0
[13634.940326] ? __alloc_pages_nodemask+0xdf/0x230
[13634.940478] ? mem_cgroup_commit_charge+0x7c/0x4e0
[13634.940592] ? mem_cgroup_try_charge+0x76/0x1a0
[13634.940701] ? __handle_mm_fault+0xdb9/0x10b0
[13634.940809] ? __sys_sendmsg+0x51/0x90
[13634.940917] ? entry_SYSCALL_64_fastpath+0x1e/0xad
The problem is that the bridge's VLAN group is created after setting the
default PVID, when registering the netdevice and executing its
ndo_init().
Fix this by changing the order of both operations, so that
br_changelink() is only processed after the netdevice is registered,
when the VLAN group is already initialized.
Fixes: b6677449dff6 ("bridge: netlink: call br_changelink() during br_dev_newlink()")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Peter V. Saveliev <peter@svinota.eu>
Tested-by: Peter V. Saveliev <peter@svinota.eu>
[ Upstream commit 5ef1ecf060f28ecef313b5723f1fd39bf5a35f56 ]
Certain 64-bit systems (e.g. Amlogic Meson GX) require buffers to be
used for DMA to be 8-byte-aligned. struct sdio_func has an embedded
small DMA buffer not meeting this requirement.
When testing switching to descriptor chain mode in meson-gx driver
SDIO is broken therefore. Fix this by allocating the small DMA buffer
separately as kmalloc ensures that the returned memory area is
properly aligned for every basic data type.
Tested-by: Helmut Klein <hgkr.klein@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 6f2aee0c0de65013333bbc26fe50c9c7b09a37f7 ]
This patch adds support for the PL-27A1 by adding the appropriate
USB ID's. This chip is used in the goobay Active USB 3.0 Data Link
and Unitek Y-3501 cables.
Signed-off-by: Roman Spychała <roed@onet.eu>
[ Upstream commit 72ec0bc64b9a5d8e0efcb717abfc757746b101b7 ]
In functions team_nl_send_port_list_get() and
team_nl_send_options_get(), pointer skb keeps the return value of
nlmsg_new(). When the call to genlmsg_put() fails, the memory is not
freed(). This will result in memory leak bugs.
Fixes: 9b00cf2d1024 ("team: implement multipart netlink messages for options transfers")
Signed-off-by: Pan Bian <bianpan2016@163.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit fd2c83b35752f0a8236b976978ad4658df14a59f ]
In the case getsockopt() is called with PACKET_HDRLEN and optlen < 4
|val| remains uninitialized and the syscall may behave differently
depending on its value, and even copy garbage to userspace on certain
architectures. To fix this we now return -EINVAL if optlen is too small.
This bug has been detected with KMSAN.
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 9899886d5e8ec5b343b1efe44f185a0e68dc6454 ]
Added NULL check to make __dev_kfree_skb_irq consistent with kfree
family of functions.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=195289
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
[ Upstream commit 98ea51cb0c8ce009d9da1fd7b48f0ff1d7a9bbb0 ]
Hauke already fixed a couple of them, but one instance remains
that checks for a negative integer when it should check
for a NULL pointer:
arch/mips/lantiq/xway/sysctrl.c: In function 'ltq_soc_init':
arch/mips/lantiq/xway/sysctrl.c:473:19: error: ordered comparison of pointer with integer zero [-Werror=extra]
Fixes: 6e807852676a ("MIPS: Lantiq: Fix check for return value of request_mem_region()")
Cc: John Crispin <john@phrozen.org>
Patchwork: https://patchwork.linux-mips.org/patch/15043/
[ Upstream commit 639467c8f26d834c934215e8b59129ce442475fe ]
commit 66feeec9322132689d42723df2537d60f96f8e44
"RFC: ASoC: dapm: handle probe deferrals"
forgot a to update some two sites where the call
was used. The static codechecks quickly found them.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 66feeec93221 ("RFC: ASoC: dapm: handle probe deferrals")
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit c3b674a04b8ab62a1d35e86714d466af0a0ecc18 ]
At some situations, the vbus may already be there before starting
gadget. So we need to check vbus event after switching to gadget in
order to handle missing vbus event. The typical use cases are plugging
vbus cable before driver load or the vbus has already been there
after stopping host but before starting gadget.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Tested-by: Stephen Boyd <stephen.boyd@linaro.org>
Reported-by: Stephen Boyd <stephen.boyd@linaro.org>
[ Upstream commit 62bc306e2083436675e33b5bdeb6a77907d35971 ]
32-bit socketcalls were not being logged by audit on x86_64 systems.
Log them. This is basically a duplicate of the call from
net/socket.c:sys_socketcall(), but it addresses the impedance mismatch
between 32-bit userspace process and 64-bit kernel audit.
See: https://github.com/linux-audit/audit-kernel/issues/14
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 37e1df8c95e2c8a57c77eafc097648f6e40a60ff ]
This starts to handle probe deferrals on regulators and clocks
on the ASoC DAPM.
I came to this patch after audio stopped working on Ux500 ages
ago and I finally looked into it to see what is wrong. I had
messages like this in the console since a while back:
ab8500-codec.0: ASoC: Failed to request audioclk: -517
ab8500-codec.0: ASoC: Failed to create DAPM control audioclk
ab8500-codec.0: Failed to create new controls -12
snd-soc-mop500.0: ASoC: failed to instantiate card -12
snd-soc-mop500.0: Error: snd_soc_register_card failed (-12)!
snd-soc-mop500: probe of snd-soc-mop500.0 failed with error -12
Apparently because the widget table for the codec looks like
this (sound/soc/codecs/ab8500-codec.c):
static const struct snd_soc_dapm_widget ab8500_dapm_widgets[] = {
/* Clocks */
SND_SOC_DAPM_CLOCK_SUPPLY("audioclk"),
/* Regulators */
SND_SOC_DAPM_REGULATOR_SUPPLY("V-AUD", 0, 0),
SND_SOC_DAPM_REGULATOR_SUPPLY("V-AMIC1", 0, 0),
SND_SOC_DAPM_REGULATOR_SUPPLY("V-AMIC2", 0, 0),
SND_SOC_DAPM_REGULATOR_SUPPLY("V-DMIC", 0, 0),
So when we call snd_soc_register_codec() and any of these widgets
get a deferred probe we do not get an -EPROBE_DEFER (-517) back as
we should and instead we just fail. Apparently the code assumes
that clocks and regulators must be available at this point and
not defer.
After this patch it rather looks like this:
ab8500-codec.0: Failed to create new controls -517
snd-soc-mop500.0: ASoC: failed to instantiate card -517
snd-soc-mop500.0: Error: snd_soc_register_card failed (-517)!
abx500-clk.0: registered clocks for ab850x
snd-soc-mop500.0: ab8500-codec-dai.0 <-> ux500-msp-i2s.1 mapping ok
snd-soc-mop500.0: ab8500-codec-dai.1 <-> ux500-msp-i2s.3 mapping ok
I'm pretty happy about the patch as it it, but I'm a bit
uncertain on how to proceed: there are a lot of users of the
external functions snd_soc_dapm_new_control() (111 sites)
and that will now return an occassional error pointer, which
is not handled in the calling sites.
I want an indication from the maintainers whether I should just
go in and augment all these call sites, or if deferred probe
is frowned upon when it leads to this much overhead.
[ Upstream commit c5082b70adfe8e1ea1cf4a8eff92c9f260e364d2 ]
If a GUID Partition Table claims to have more than 2**25 entries, the
calculation of the partition table size in alloc_read_gpt_entries() will
overflow a 32-bit integer and not enough space will be allocated for the
table.
Nothing seems to get written out of bounds, but later efi_partition() will
read up to 32768 bytes from a 128 byte buffer, possibly OOPSing or exposing
information to /proc/partitions and uevents.
The problem exists on both 64-bit and 32-bit platforms.
Fix the overflow and also print a meaningful debug message if the table
size is too large.
Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit cd8db057e93ddaacbec025b567490555d2bca280 ]
Make sure to detect short transfers when reading a device register.
The modem-status handling had sufficient error checks in place, but move
handling of short transfers into the register accessor function itself
for consistency.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 0d130367abf582e7cbf60075c2a7ab53817b1d14 ]
Make sure to log an error on short transfers when reading a device
register.
Also clear the provided buffer (which if often an uninitialised
automatic variable) on errors as the driver currently does not bother to
check for errors.
[ Upstream commit 8bf793883da213864efc50c274d2b38ec0ca58b2 ]
In function kfd_wait_on_events(), when the call to copy_from_user()
fails, the value of return variable ret is 0. 0 indicates success, which
is inconsistent with the execution status. This patch fixes the bug by
assigning "-EFAULT" to ret when copy_from_user() returns an unexpected
value.
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
[ Upstream commit c586071d1dc8227a7182179b8e50ee92cc43f6d2 ]
In order to resolve a situation where a few process delete
the same list element in sequence and cause panic, list_del
is replaced with list_del_init. In this case if the first
process that calls list_del releases the lock before acquiring
it again, other processes who can acquire the lock will call
list_del_init.
Fixes: b63b70d87741 ("IPoIB: Use a private hash table for path lookup")
Signed-off-by: Feras Daoud <ferasda@mellanox.com>
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
Reviewed-by: Alex Vesker <valex@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
[ Upstream commit 89a3987ab7a923c047c6dec008e60ad6f41fac22 ]
The ipoib_vlan_add function calls rtnl_unlock after free_netdev,
rtnl_unlock not only releases the lock, but also calls netdev_run_todo.
The latter function browses the net_todo_list array and completes the
unregistration of all its net_device instances. If we call free_netdev
before rtnl_unlock, then netdev_run_todo call over the freed device causes
panic.
To fix, move rtnl_unlock call before free_netdev call.
Fixes: 9baa0b036410 ("IB/ipoib: Add rtnl_link_ops support")
Cc: Or Gerlitz <ogerlitz@mellanox.com>
[ Upstream commit 1c3098cdb05207e740715857df7b0998e372f527 ]
This patch fixes Deadlock while executing ipoib_vlan_delete.
The function takes the vlan_rwsem semaphore and calls
unregister_netdevice. The later function calls
ipoib_mcast_stop_thread that cause workqueue flush.
When the queue has one of the ipoib_ib_dev_flush_xxx events,
a deadlock occur because these events also tries to catch the
same vlan_rwsem semaphore.
To fix, unregister_netdevice should be called after releasing
the semaphore.
Fixes: cbbe1efa4972 ("IPoIB: Fix deadlock between ipoib_open() and child interface create")
[ Upstream commit 1a5c2d1de7d35f5eb9793266237903348989502b ]
'request_irq()' and 'free_irq()' should be called with the same dev_id.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit 8a792e9afbce84a0fdaf213fe42bb97382487094 ]
REMAP_VECTORS_TO_RAM depends on DRAM_BASE, but since DRAM_BASE is a
hex, REMAP_VECTORS_TO_RAM could never get enabled. Also depending on
DRAM_BASE is redundant as whenever REMAP_VECTORS_TO_RAM makes itself
available to Kconfig, DRAM_BASE also is available as the Kconfig
gets sourced on !MMU.
Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Reviewed-by: Vladimir Murzin <vladimir.murzin@arm.com>
[ Upstream commit ff1293f67734da68e23fecb6ecdae7112b8c43f9 ]
Add DT bindings for avia,hx711
Add vendor avia to vendor list
Signed-off-by: Andreas Klinger <ak@it-klinger.de>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit fa2849e9649b5180ffc4cb3c3b005261c403093a ]
For some reason the axp288_adc driver was modifying the
AXP288_ADC_TS_PIN_CTRL register, changing bits 0-1 depending on
whether the GP_ADC channel or another channel was written.
These bits control when a bias current is send to the TS_PIN, the
GP_ADC has its own pin and a separate bit in another register to
control the bias current.
Not only does changing when to enable the TS_PIN bias current
(always or only when sampling) when reading the GP_ADC make no sense
at all, the code is modifying these bits is writing the entire register,
assuming that all the other bits have their default value.
So if the firmware has configured a different bias-current for either
pin, then that change gets clobbered by the write, likewise if the
firmware has set bit 2 to indicate that the battery has no thermal sensor,
this will get clobbered by the write.
This commit fixes all this, by simply removing all writes to the
AXP288_ADC_TS_PIN_CTRL register, they are not needed to read the
GP_ADC pin, and can actually be harmful.
Acked-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit 87cdfa9d60f4f40e6d71b04b10b36d9df3c89282 ]
Writes into limit attributes can overflow due to multplications and
additions with unbound input values. Writing into fan limit attributes
can result in a crash with a division by zero if very large values are
written and the fan divider is larger than 1.
[ Upstream commit 6dcf45e514974a1ff10755015b5e06746a033e5f ]
This bit was wrongly named due to a typo, Sergei checked the SH7734/63
manuals and this bit should be named MPDE.
Suggested-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
[ Upstream commit 5757aca10146061befd168dab37fb0db1ccd8f73 ]
The vbus-present bit in the power status register also gets set to 1
when a usb-host cable (id-pin shorted to ground) is plugged in and a 5v
boost converter is supplying 5v to the otg usb bus.
This causes a "disconnect or unknown or ID event" warning in dmesg as
well as the extcon device to report the last detected charger cable
type as being connected even though none is connected.
This commit switches to checking the vbus-valid bit instead, which is
only 1 when both vbus is present and the vbus-path is enabled in the
vbus-path control register (the vbus-path gets disabled when a usb-host
cable is detected, to avoid the pmic drawing power from the 5v boost
converter).
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
[ Upstream commit 69b97cf6dbce7403845a28bbc75d57f5be7b12ac ]
Whenever the igb driver detects the result of a read operation returns
a value composed only by F's (like 0xFFFFFFFF), it will detach the
net_device, clear the hw_addr pointer and warn to the user that adapter's
link is lost - those steps happen on igb_rd32().
In case a PCI error happens on Power architecture, there's a recovery
mechanism called EEH, that will reset the PCI slot and call driver's
handlers to reset the adapter and network functionality as well.
We observed that once hw_addr is NULL after the error is detected on
igb_rd32(), it's never assigned back, so in the process of resetting
the network functionality we got a NULL pointer dereference in both
igb_configure_tx_ring() and igb_configure_rx_ring(). In order to avoid
such bug, this patch re-assigns the hw_addr value in the slot_reset
handler.
Reported-by: Anthony H Thai <ahthai@us.ibm.com>
Reported-by: Harsha Thyagaraja <hathyaga@in.ibm.com>
Signed-off-by: Guilherme G Piccoli <gpiccoli@linux.vnet.ibm.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
[ Upstream commit 08d90c81b714482dceb5323d14f6617bcf55ee61 ]
ralink_soc sould be assigned to RT3883_SOC, replace incorrect
comparision with assignment.
Fixes: 418d29c87061 ("MIPS: ralink: Unify SoC id handling")
Patchwork: https://patchwork.linux-mips.org/patch/14903/
[ Upstream commit 3f00f4d8f083bc61005d0a1ef592b149f5c88bbd ]
When clearing the .bss section in kernel_entry we do so using LONG_S
instructions, and branch whilst the current write address doesn't equal
the end of the .bss section minus the size of a long integer. The .bss
section always begins at a long-aligned address and we always increment
the write pointer by the size of a long integer - we therefore rely upon
the .bss section ending at a long-aligned address. If this is not the
case then the long-aligned write address can never be equal to the
non-long-aligned end address & we will continue to increment past the
end of the .bss section, attempting to zero the rest of memory.
Despite this requirement that .bss end at a long-aligned address we pass
0 as the end alignment requirement to the BSS_SECTION macro and thus
don't guarantee any particular alignment, allowing us to hit the error
condition described above.
Fix this by instead passing 8 bytes as the end alignment argument to
the BSS_SECTION macro, ensuring that the end of the .bss section is
always at least long-aligned.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14526/
[ Upstream commit 654450baf2afba86cf328e1849ccac61ec4630af ]
Use recently added R-Car Gen 2 fallback binding for msiof nodes in
DT for r8a7790 SoC.
This has no run-time effect for the current driver as the initialisation
sequence is the same for the SoC-specific binding for r8a7790 and the
fallback binding for R-Car Gen 2.
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 941f8d55f6d613a460a5e080d25a38509f45eb75 ]
When application sends an RDS RDMA composite message consist of
RDMA transfer to be followed up by non RDMA payload, it expect to
be notified *only* when the full message gets delivered. RDS RDMA
notification doesn't behave this way though.
Thanks to Venkat for debug and root casuing the issue
where only first part of the message(RDMA) was
successfully delivered but remainder payload delivery failed.
In that case, application should not be notified with
a false positive of message delivery success.
Fix this case by making sure the user gets notified only after
the full message delivery.
Reviewed-by: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit 14d37564fa3dc4e5d4c6828afcd26ac14e6796c5 ]
This patch fixes a place where function gfs2_glock_iter_next can
reference an invalid error pointer.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
[ Upstream commit 2e644be30fcc08c736f66b60f4898d274d4873ab ]
THS8135 is a configurable video DAC. Add DT bindings for this chip.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1481623759-12786-3-git-send-email-bgolaszewski@baylibre.com
[ Upstream commit af913418261d6d3e7a29f06cf35f04610ead667c ]
We need to define DRM_FORMAT_MOD_VENDOR_NONE for the fourcc_mod_code()
macro to work correctly.
Signed-off-by: Kristian H. Kristensen <hoegsberg@google.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1481657272-25975-1-git-send-email-hoegsberg@google.com
