2016-03-09Linux 4.4.5v4.4.5Greg Kroah-Hartman
2016-03-09drm/amdgpu: fix topaz/tonga gmc assignment in 4.4 stableAlex Deucher
When upstream commit 429c45deae6e57f1bb91bfb05b671063fb0cef60 was applied to 4.4 as d60703ca942e8d044d61360bc9792fcab54b95d0 it applied incorrectly to the tonga_ip_blocks array rather than the topaz_ip_blocks array. Fix that up here. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=113951 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09modules: fix longstanding /proc/kallsyms vs module insertion race.Rusty Russell
commit 8244062ef1e54502ef55f54cced659913f244c3e upstream. For CONFIG_KALLSYMS, we keep two symbol tables and two string tables. There's one full copy, marked SHF_ALLOC and laid out at the end of the module's init section. There's also a cut-down version that only contains core symbols and strings, and lives in the module's core section. After module init (and before we free the module memory), we switch the mod->symtab, mod->num_symtab and mod->strtab to point to the core versions. We do this under the module_mutex. However, kallsyms doesn't take the module_mutex: it uses preempt_disable() and rcu tricks to walk through the modules, because it's used in the oops path. It's also used in /proc/kallsyms. There's nothing atomic about the change of these variables, so we can get the old (larger!) num_symtab and the new symtab pointer; in fact this is what I saw when trying to reproduce. By grouping these variables together, we can use a carefully-dereferenced pointer to ensure we always get one or the other (the free of the module init section is already done in an RCU callback, so that's safe). We allocate the init one at the end of the module init section, and keep the core one inside the struct module itself (it could also have been allocated at the end of the module core, but that's probably overkill). [ Rebased for 4.4-stable and older, because the following changes aren't in the older trees: - e0224418516b4d8a6c2160574bac18447c354ef0: adds arg to is_core_symbol - 7523e4dc5057e157212b4741abd6256e03404cf1: module_init/module_core/init_size/core_size become init_layout.base/core_layout.base/init_layout.size/core_layout.size. ] Reported-by: Weilong Chen <chenweilong@huawei.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111541 Cc: stable@kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09drm/i915: refine qemu south bridge detectionGerd Hoffmann
commit f2e305108faba0c85eb4ba4066599decb675117e upstream. The test for the qemu q35 south bridge added by commit "39bfcd52 drm/i915: more virtual south bridge detection" also matches on real hardware. Having the check for virtual systems last in the list is not enough to avoid that ... Refine the check by additionally verifying the pci subsystem id to see whenever it *really* is qemu. [ v2: fix subvendor tyops ] Reported-and-tested-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Tested-by: Bruno Wolff III <bruno@wolff.to> Cc: drm-intel-fixes@lists.freedesktop.org Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1453719748-10944-1-git-send-email-kraxel@redhat.com (cherry picked from commit 1e859111c128265f8d62b39ff322e42b1ddb5a20) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09drm/i915: more virtual south bridge detectionGerd Hoffmann
commit 39bfcd5235e07e95ad3e70eab8e0b85db181de9e upstream. Commit "30c964a drm/i915: Detect virtual south bridge" detects and handles the southbridge emulated by vmware esx. Add the ich9 south bridge emulated by 'qemu -M q35'. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09block: get the 1st and last bvec via helpersMing Lei
commit 25e71a99f10e444cd00bb2ebccb11e1c9fb672b1 upstream. This patch applies the two introduced helpers to figure out the 1st and last bvec, and fixes the original way after bio splitting. Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09block: check virt boundary in bio_will_gap()Ming Lei
commit e0af29171aa8912e1ca95023b75ef336cd70d661 upstream. In the following patch, the way for figuring out the last bvec will be changed with a bit cost introduced, so return immediately if the queue doesn't have virt boundary limit. Actually most of devices have not this limit. Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09drm/amdgpu: Use drm_calloc_large for VM page_tables arrayMichel Dänzer
commit 9571e1d84042f5670df9fabdcbe7dd5da3abe43e upstream. It can be big, depending on the VM address space size, which is tunable via the vm_size module parameter. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=93721 Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09thermal: cpu_cooling: fix out of bounds access in time_in_idleJavi Merino
commit a53b8394ec3c67255928df6ee9cc99dd1cd452e3 upstream. In __cpufreq_cooling_register() we allocate the arrays for time_in_idle and time_in_idle_timestamp to be as big as the number of cpus in this cpufreq device. However, in get_load() we access this array using the cpu number as index, which can result in an out of bound access. Index time_in_idle{,_timestamp} using the index in the cpufreq_device's allowed_cpus mask, as we do for the load_cpu array in cpufreq_get_requested_power() Reported-by: Nicolas Boichat <drinkcat@chromium.org> Cc: Amit Daniel Kachhap <amit.kachhap@gmail.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Tested-by: Nicolas Boichat <drinkcat@chromium.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09i2c: brcmstb: allocate correct amount of memory for regmapWolfram Sang
commit 7314d22a2f5bd40468d57768be368c3d9b4bd726 upstream. We want the size of the struct, not of a pointer to it. To be future proof, just dereference the pointer to get the desired type. Fixes: dd1aa2524bc5 ("i2c: brcmstb: Add Broadcom settop SoC i2c controller driver") Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Reviewed-by: Kamal Dasu <kdasu.kdev@gmail.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ubi: Fix out of bounds write in volume update codeRichard Weinberger
commit e4f6daac20332448529b11f09388f1d55ef2084c upstream. ubi_start_leb_change() allocates too few bytes. ubi_more_leb_change_data() will write up to req->upd_bytes + ubi->min_io_size bytes. Signed-off-by: Richard Weinberger <richard@nod.at> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09cxl: Fix PSL timebase synchronization detectionFrederic Barrat
commit 923adb1646d5ba739d2a1e63ee20d60574d9da8e upstream. The PSL timebase synchronization is seemingly failing for configuration not including VIRT_CPU_ACCOUNTING_NATIVE. The driver shows the following trace in dmesg: PSL: Timebase sync: giving up! The PSL timebase register is actually syncing correctly, but the cxl driver is not detecting it. Fix is to use the proper timebase-to-time conversion. Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com> Acked-by: Michael Neuling <mikey@neuling.org> Reviewed-by: Matthew R. Ochs <mrochs@linux.vnet.ibm.com> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Reviewed-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09MIPS: traps: Fix SIGFPE information leak from `do_ov' and `do_trap_or_bp'Maciej W. Rozycki
commit e723e3f7f9591b79e8c56b3d7c5a204a9c571b55 upstream. Avoid sending a partially initialised `siginfo_t' structure along SIGFPE signals issued from `do_ov' and `do_trap_or_bp', leading to information leaking from the kernel stack. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09MIPS: scache: Fix scache init with invalid line size.Govindraj Raja
commit 56fa81fc9a5445938f3aa2e63d15ab63dc938ad6 upstream. In current scache init cache line_size is determined from cpu config register, however if there there no scache then mips_sc_probe_cm3 function populates a invalid line_size of 2. The invalid line_size can cause a NULL pointer deference during r4k_dma_cache_inv as r4k_blast_scache is populated based on line_size. Scache line_size of 2 is invalid option in r4k_blast_scache_setup. This issue was faced during a MIPS I6400 based virtual platform bring up where scache was not available in virtual platform model. Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com> Fixes: 7d53e9c4cd21("MIPS: CM3: Add support for CM3 L2 cache.") Cc: Paul Burton <paul.burton@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: James Hartley <James.Hartley@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/12710/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09USB: serial: option: add support for Quectel UC20Yegor Yefremov
commit c0992d0f54847d0d1d85c60fcaa054f175ab1ccd upstream. Add support for Quectel UC20 and blacklist the QMI interface. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> [johan: amend commit message ] Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09USB: serial: option: add support for Telit LE922 PID 0x1045Daniele Palmas
commit 5deef5551c77e488922cc4bf4bc76df63be650d0 upstream. This patch adds support for 0x1045 PID of Telit LE922. Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09USB: qcserial: add Sierra Wireless EM74xx device IDBjørn Mork
commit 04fdbc825ffc02fb098964b92de802fff44e73fd upstream. The MC74xx and EM74xx modules use different IDs by default, according to the Lenovo EM7455 driver for Windows. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09USB: qcserial: add Dell Wireless 5809e Gobi 4G HSPA+ (rev3)Patrik Halfar
commit 013dd239d6220a4e0dfdf0d45a82c34f1fd73deb upstream. New revision of Dell Wireless 5809e Gobi 4G HSPA+ Mobile Broadband Card has new idProduct. Bus 002 Device 006: ID 413c:81b3 Dell Computer Corp. Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x413c Dell Computer Corp. idProduct 0x81b3 bcdDevice 0.06 iManufacturer 1 Sierra Wireless, Incorporated iProduct 2 Dell Wireless 5809e Gobi™ 4G HSPA+ Mobile Broadband Card iSerial 3 bNumConfigurations 2 Signed-off-by: Patrik Halfar <patrik_halfar@halfarit.cz> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09USB: cp210x: Add ID for Parrot NMEA GPS Flight RecorderVittorio Alfieri
commit 3c4c615d70c8cbdc8ba8c79ed702640930652a79 upstream. The Parrot NMEA GPS Flight Recorder is a USB composite device consisting of hub, flash storage, and cp210x usb to serial chip. It is an accessory to the mass-produced Parrot AR Drone 2. The device emits standard NMEA messages which make the it compatible with NMEA compatible software. It was tested using gpsd version 3.11-3 as an NMEA interpreter and using the official Parrot Flight Recorder. Signed-off-by: Vittorio Alfieri <vittorio88@gmail.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09usb: chipidea: otg: change workqueue ci_otg as freezablePeter Chen
commit d144dfea8af7108f613139623e63952ed7e69c0c upstream. If we use USB ID pin as wakeup source, and there is a USB block device on this USB OTG (ID) cable, the system will be deadlock after system resume. The root cause for this problem is: the workqueue ci_otg may try to remove hcd before the driver resume has finished, and hcd will disconnect the device on it, then, it will call device_release_driver, and holds the device lock "dev->mutex", but it is never unlocked since it waits workqueue writeback to run to flush the block information, but the workqueue writeback is freezable, it is not thawed before driver resume has finished. When the driver (device: sd 0:0:0:0:) resume goes to dpm_complete, it tries to get its device lock "dev->mutex", but it can't get it forever, then the deadlock occurs. Below call stacks show the situation. So, in order to fix this problem, we need to change workqueue ci_otg as freezable, then the work item in this workqueue will be run after driver's resume, this workqueue will not be blocked forever like above case since the workqueue writeback has been thawed too. Tested at: i.mx6qdl-sabresd and i.mx6sx-sdb. [ 555.178869] kworker/u2:13 D c07de74c 0 826 2 0x00000000 [ 555.185310] Workqueue: ci_otg ci_otg_work [ 555.189353] Backtrace: [ 555.191849] [<c07de4fc>] (__schedule) from [<c07dec6c>] (schedule+0x48/0xa0) [ 555.198912] r10:ee471ba0 r9:00000000 r8:00000000 r7:00000002 r6:ee470000 r5:ee471ba4 [ 555.206867] r4:ee470000 [ 555.209453] [<c07dec24>] (schedule) from [<c07e2fc4>] (schedule_timeout+0x15c/0x1e0) [ 555.217212] r4:7fffffff r3:edc2b000 [ 555.220862] [<c07e2e68>] (schedule_timeout) from [<c07df6c8>] (wait_for_common+0x94/0x144) [ 555.229140] r8:00000000 r7:00000002 r6:ee470000 r5:ee471ba4 r4:7fffffff [ 555.235980] [<c07df634>] (wait_for_common) from [<c07df790>] (wait_for_completion+0x18/0x1c) [ 555.244430] r10:00000001 r9:c0b5563c r8:c0042e48 r7:ef086000 r6:eea4372c r5:ef131b00 [ 555.252383] r4:00000000 [ 555.254970] [<c07df778>] (wait_for_completion) from [<c0043cb8>] (flush_work+0x19c/0x234) [ 555.263177] [<c0043b1c>] (flush_work) from [<c0043fac>] (flush_delayed_work+0x48/0x4c) [ 555.271106] r8:ed5b5000 r7:c0b38a3c r6:eea439cc r5:eea4372c r4:eea4372c [ 555.277958] [<c0043f64>] (flush_delayed_work) from [<c00eae18>] (bdi_unregister+0x84/0xec) [ 555.286236] r4:eea43520 r3:20000153 [ 555.289885] [<c00ead94>] (bdi_unregister) from [<c02c2154>] (blk_cleanup_queue+0x180/0x29c) [ 555.298250] r5:eea43808 r4:eea43400 [ 555.301909] [<c02c1fd4>] (blk_cleanup_queue) from [<c0417914>] (__scsi_remove_device+0x48/0xb8) [ 555.310623] r7:00000000 r6:20000153 r5:ededa950 r4:ededa800 [ 555.316403] [<c04178cc>] (__scsi_remove_device) from [<c0415e90>] (scsi_forget_host+0x64/0x68) [ 555.325028] r5:ededa800 r4:ed5b5000 [ 555.328689] [<c0415e2c>] (scsi_forget_host) from [<c0409828>] (scsi_remove_host+0x78/0x104) [ 555.337054] r5:ed5b5068 r4:ed5b5000 [ 555.340709] [<c04097b0>] (scsi_remove_host) from [<c04cdfcc>] (usb_stor_disconnect+0x50/0xb4) [ 555.349247] r6:ed5b56e4 r5:ed5b5818 r4:ed5b5690 r3:00000008 [ 555.355025] [<c04cdf7c>] (usb_stor_disconnect) from [<c04b3bc8>] (usb_unbind_interface+0x78/0x25c) [ 555.363997] r8:c13919b4 r7:edd3c000 r6:edd3c020 r5:ee551c68 r4:ee551c00 r3:c04cdf7c [ 555.371892] [<c04b3b50>] (usb_unbind_interface) from [<c03dc248>] (__device_release_driver+0x8c/0x118) [ 555.381213] r10:00000001 r9:edd90c00 r8:c13919b4 r7:ee551c68 r6:c0b546e0 r5:c0b5563c [ 555.389167] r4:edd3c020 [ 555.391752] [<c03dc1bc>] (__device_release_driver) from [<c03dc2fc>] (device_release_driver+0x28/0x34) [ 555.401071] r5:edd3c020 r4:edd3c054 [ 555.404721] [<c03dc2d4>] (device_release_driver) from [<c03db304>] (bus_remove_device+0xe0/0x110) [ 555.413607] r5:edd3c020 r4:ef17f04c [ 555.417253] [<c03db224>] (bus_remove_device) from [<c03d8128>] (device_del+0x114/0x21c) [ 555.425270] r6:edd3c028 r5:edd3c020 r4:ee551c00 r3:00000000 [ 555.431045] [<c03d8014>] (device_del) from [<c04b1560>] (usb_disable_device+0xa4/0x1e8) [ 555.439061] r8:edd3c000 r7:eded8000 r6:00000000 r5:00000001 r4:ee551c00 [ 555.445906] [<c04b14bc>] (usb_disable_device) from [<c04a8e54>] (usb_disconnect+0x74/0x224) [ 555.454271] r9:edd90c00 r8:ee551000 r7:ee551c68 r6:ee551c9c r5:ee551c00 r4:00000001 [ 555.462156] [<c04a8de0>] (usb_disconnect) from [<c04a8fb8>] (usb_disconnect+0x1d8/0x224) [ 555.470259] r10:00000001 r9:edd90000 r8:ee471e2c r7:ee551468 r6:ee55149c r5:ee551400 [ 555.478213] r4:00000001 [ 555.480797] [<c04a8de0>] (usb_disconnect) from [<c04ae5ec>] (usb_remove_hcd+0xa0/0x1ac) [ 555.488813] r10:00000001 r9:ee471eb0 r8:00000000 r7:ef3d9500 r6:eded810c r5:eded80b0 [ 555.496765] r4:eded8000 [ 555.499351] [<c04ae54c>] (usb_remove_hcd) from [<c04d4158>] (host_stop+0x28/0x64) [ 555.506847] r6:eeb50010 r5:eded8000 r4:eeb51010 [ 555.511563] [<c04d4130>] (host_stop) from [<c04d09b8>] (ci_otg_work+0xc4/0x124) [ 555.518885] r6:00000001 r5:eeb50010 r4:eeb502a0 r3:c04d4130 [ 555.524665] [<c04d08f4>] (ci_otg_work) from [<c00454f0>] (process_one_work+0x194/0x420) [ 555.532682] r6:ef086000 r5:eeb502a0 r4:edc44480 [ 555.537393] [<c004535c>] (process_one_work) from [<c00457b0>] (worker_thread+0x34/0x514) [ 555.545496] r10:edc44480 r9:ef086000 r8:c0b1a100 r7:ef086034 r6:00000088 r5:edc44498 [ 555.553450] r4:ef086000 [ 555.556032] [<c004577c>] (worker_thread) from [<c004bab4>] (kthread+0xdc/0xf8) [ 555.563268] r10:00000000 r9:00000000 r8:00000000 r7:c004577c r6:edc44480 r5:eddc15c0 [ 555.571221] r4:00000000 [ 555.573804] [<c004b9d8>] (kthread) from [<c000fef0>] (ret_from_fork+0x14/0x24) [ 555.581040] r7:00000000 r6:00000000 r5:c004b9d8 r4:eddc15c0 [ 553.429383] sh D c07de74c 0 694 691 0x00000000 [ 553.435801] Backtrace: [ 553.438295] [<c07de4fc>] (__schedule) from [<c07dec6c>] (schedule+0x48/0xa0) [ 553.445358] r10:edd3c054 r9:edd3c078 r8:edddbd50 r7:edcbbc00 r6:c1377c34 r5:60000153 [ 553.453313] r4:eddda000 [ 553.455896] [<c07dec24>] (schedule) from [<c07deff8>] (schedule_preempt_disabled+0x10/0x14) [ 553.464261] r4:edd3c058 r3:0000000a [ 553.467910] [<c07defe8>] (schedule_preempt_disabled) from [<c07e0bbc>] (mutex_lock_nested+0x1a0/0x3e8) [ 553.477254] [<c07e0a1c>] (mutex_lock_nested) from [<c03e927c>] (dpm_complete+0xc0/0x1b0) [ 553.485358] r10:00561408 r9:edd3c054 r8:c0b4863c r7:edddbd90 r6:c0b485d8 r5:edd3c020 [ 553.493313] r4:edd3c0d0 [ 553.495896] [<c03e91bc>] (dpm_complete) from [<c03e9388>] (dpm_resume_end+0x1c/0x20) [ 553.503652] r9:00000000 r8:c0b1a9d0 r7:c1334ec0 r6:c1334edc r5:00000003 r4:00000010 [ 553.511544] [<c03e936c>] (dpm_resume_end) from [<c0079894>] (suspend_devices_and_enter+0x158/0x504) [ 553.520604] r4:00000000 r3:c1334efc [ 553.524250] [<c007973c>] (suspend_devices_and_enter) from [<c0079e74>] (pm_suspend+0x234/0x2cc) [ 553.532961] r10:00561408 r9:ed6b7300 r8:00000004 r7:c1334eec r6:00000000 r5:c1334ee8 [ 553.540914] r4:00000003 [ 553.543493] [<c0079c40>] (pm_suspend) from [<c0078a6c>] (state_store+0x6c/0xc0) [ 555.703684] 7 locks held by kworker/u2:13/826: [ 555.708140] #0: ("%s""ci_otg"){++++.+}, at: [<c0045484>] process_one_work+0x128/0x420 [ 555.716277] #1: ((&ci->work)){+.+.+.}, at: [<c0045484>] process_one_work+0x128/0x420 [ 555.724317] #2: (usb_bus_list_lock){+.+.+.}, at: [<c04ae5e4>] usb_remove_hcd+0x98/0x1ac [ 555.732626] #3: (&dev->mutex){......}, at: [<c04a8e28>] usb_disconnect+0x48/0x224 [ 555.740403] #4: (&dev->mutex){......}, at: [<c04a8e28>] usb_disconnect+0x48/0x224 [ 555.748179] #5: (&dev->mutex){......}, at: [<c03dc2f4>] device_release_driver+0x20/0x34 [ 555.756487] #6: (&shost->scan_mutex){+.+.+.}, at: [<c04097d0>] scsi_remove_host+0x20/0x104 Cc: Jun Li <jun.li@nxp.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: timer: Fix broken compat timer user status ioctlTakashi Iwai
commit 3a72494ac2a3bd229db941d51e7efe2f6ccd947b upstream. The timer user status compat ioctl returned the bogus struct used for 64bit architectures instead of the 32bit one. This patch addresses it to return the proper struct. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: hdspm: Fix zero-divisionTakashi Iwai
commit c1099c3294c2344110085a38c50e478a5992b368 upstream. HDSPM driver contains a code issuing zero-division potentially in system sample rate ctl code. This patch fixes it by not processing a zero or invalid rate value as a divisor, as well as excluding the invalid value to be passed via the given ctl element. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: hdsp: Fix wrong boolean ctl value accessesTakashi Iwai
commit eab3c4db193f5fcccf70e884de9a922ca2c63d80 upstream. snd-hdsp driver accesses enum item values (int) instead of boolean values (long) wrongly for some ctl elements. This patch fixes them. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: hdspm: Fix wrong boolean ctl value accessesTakashi Iwai
commit 537e48136295c5860a92138c5ea3959b9542868b upstream. snd-hdspm driver accesses enum item values (int) instead of boolean values (long) wrongly for some ctl elements. This patch fixes them. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: seq: oss: Don't drain at closing a clientTakashi Iwai
commit 197b958c1e76a575d77038cc98b4bebc2134279f upstream. The OSS sequencer client tries to drain the pending events at releasing. Unfortunately, as spotted by syzkaller fuzzer, this may lead to an unkillable process state when the event has been queued at the far future. Since the process being released can't be signaled any longer, it remains and waits for the echo-back event in that far future. Back to history, the draining feature was implemented at the time we misinterpreted POSIX definition for blocking file operation. Actually, such a behavior is superfluous at release, and we should just release the device as is instead of keeping it up forever. This patch just removes the draining call that may block the release for too long time unexpectedly. BugLink: http://lkml.kernel.org/r/CACT4Y+Y4kD-aBGj37rf-xBw9bH3GMU6P+MYg4W1e-s-paVD2pg@mail.gmail.com Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: pcm: Fix ioctls for X32 ABITakashi Iwai
commit 513ace79b657e2022a592e77f24074e088681ecc upstream. X32 ABI uses the 64bit timespec in addition to 64bit alignment of 64bit values. This leads to incompatibilities in some PCM ioctls involved with snd_pcm_channel_info, snd_pcm_status and snd_pcm_sync_ptr structs. Fix the PCM compat ABI for these ioctls like the previous commit for ctl API. Reported-by: Steven Newbury <steve@snewbury.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: timer: Fix ioctls for X32 ABITakashi Iwai
commit b24e7ad1fdc22177eb3e51584e1cfcb45d818488 upstream. X32 ABI takes the 64bit timespec, thus the timer user status ioctl becomes incompatible with IA32. This results in NOTTY error when the ioctl is issued. Meanwhile, this struct in X32 is essentially identical with the one in X86-64, so we can just bypassing to the existing code for this specific compat ioctl. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: rawmidi: Fix ioctls X32 ABITakashi Iwai
commit 2251fbbc1539f05b0b206b37a602d5776be37252 upstream. Like the previous fixes for ctl and PCM, we need a fix for incompatible X32 ABI regarding the rawmidi: namely, struct snd_rawmidi_status has the timespec, and the size and the alignment on X32 differ from IA32. This patch fixes the incompatible ioctl for X32. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: hda - Fix mic issues on Acer Aspire E1-472Simon South
commit 02322ac9dee9aff8d8862e8d6660ebe102f492ea upstream. This patch applies the microphone-related fix created for the Acer Aspire E1-572 to the E1-472 as well, as it uses the same Realtek ALC282 CODEC and demonstrates the same issues. This patch allows an external, headset microphone to be used and limits the gain on the (quite noisy) internal microphone. Signed-off-by: Simon South <simon@simonsouth.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: ctl: Fix ioctls for X32 ABITakashi Iwai
commit 6236d8bb2afcfe71b88ecea554e0dc638090a45f upstream. The X32 ABI takes the same alignment like x86-64, and this may result in the incompatible struct size from ia32. Unfortunately, we hit this in some control ABI: struct snd_ctl_elem_value differs between them due to the position of 64bit variable array. This ends up with the unknown ioctl (ENOTTY) error. The fix is to add the compat entries for the new aligned struct. Reported-and-tested-by: Steven Newbury <steve@snewbury.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ALSA: usb-audio: Add a quirk for Plantronics DA45Dennis Kadioglu
commit 17e2df4613be57d0fab68df749f6b8114e453152 upstream. Plantronics DA45 does not support reading the sample rate which leads to many lines of "cannot get freq at ep 0x4" and "cannot get freq at ep 0x84". This patch adds the USB ID of the DA45 to quirks.c and avoids those error messages. Signed-off-by: Dennis Kadioglu <denk@post.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09adv7604: fix tx 5v detect regressionHans Verkuil
commit 0ba4581c84cfb39fd527f6b3457f1c97f6356c04 upstream. The 5 volt detect functionality broke in 3.14: the code reads IO register 0x70 again after it has already been cleared. Instead it should use the cached irq_reg_0x70 value and the io_write to 0x71 to clear 0x70 can be dropped since this has already been done. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09dmaengine: pxa_dma: fix cyclic transfersRobert Jarzmik
commit f16921275cc3c2442d0b95225785a601603b990f upstream. While testing audio with pxa2xx-ac97, underrun were happening while the user application was correctly feeding the music. Debug proved that the cyclic transfer is not cyclic, ie. the last descriptor did not loop on the first. Another issue is that the descriptor length was always set to 8192, because of an trivial operator issue. This was tested on a pxa27x platform. Fixes: a57e16cf0333 ("dmaengine: pxa: add pxa dmaengine driver") Reported-by: Vasily Khoruzhick <anarsoul@gmail.com> Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09Fix directory hardlinks from deleted directoriesDavid Woodhouse
commit be629c62a603e5935f8177fd8a19e014100a259e upstream. When a directory is deleted, we don't take too much care about killing off all the dirents that belong to it — on the basis that on remount, the scan will conclude that the directory is dead anyway. This doesn't work though, when the deleted directory contained a child directory which was moved *out*. In the early stages of the fs build we can then end up with an apparent hard link, with the child directory appearing both in its true location, and as a child of the original directory which are this stage of the mount process we don't *yet* know is defunct. To resolve this, take out the early special-casing of the "directories shall not have hard links" rule in jffs2_build_inode_pass1(), and let the normal nlink processing happen for directories as well as other inodes. Then later in the build process we can set ic->pino_nlink to the parent inode#, as is required for directories during normal operaton, instead of the nlink. And complain only *then* about hard links which are still in evidence even after killing off all the unreachable paths. Reported-by: Liu Song <liu.song11@zte.com.cn> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09jffs2: Fix page lock / f->sem deadlockDavid Woodhouse
commit 49e91e7079febe59a20ca885a87dd1c54240d0f1 upstream. With this fix, all code paths should now be obtaining the page lock before f->sem. Reported-by: Szabó Tamás <sztomi89@gmail.com> Tested-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09Revert "jffs2: Fix lock acquisition order bug in jffs2_write_begin"Thomas Betker
commit 157078f64b8a9cd7011b6b900b2f2498df850748 upstream. This reverts commit 5ffd3412ae55 ("jffs2: Fix lock acquisition order bug in jffs2_write_begin"). The commit modified jffs2_write_begin() to remove a deadlock with jffs2_garbage_collect_live(), but this introduced new deadlocks found by multiple users. page_lock() actually has to be called before mutex_lock(&c->alloc_sem) or mutex_lock(&f->sem) because jffs2_write_end() and jffs2_readpage() are called with the page locked, and they acquire c->alloc_sem and f->sem, resp. In other words, the lock order in jffs2_write_begin() was correct, and it is the jffs2_garbage_collect_live() path that has to be changed. Revert the commit to get rid of the new deadlocks, and to clear the way for a better fix of the original deadlock. Reported-by: Deng Chao <deng.chao1@zte.com.cn> Reported-by: Ming Liu <liu.ming50@gmail.com> Reported-by: wangzaiwei <wangzaiwei@top-vision.cn> Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09Btrfs: fix loading of orphan roots leading to BUG_ONFilipe Manana
commit 909c3a22da3b8d2cfd3505ca5658f0176859d400 upstream. When looking for orphan roots during mount we can end up hitting a BUG_ON() (at root-item.c:btrfs_find_orphan_roots()) if a log tree is replayed and qgroups are enabled. This is because after a log tree is replayed, a transaction commit is made, which triggers qgroup extent accounting which in turn does backref walking which ends up reading and inserting all roots in the radix tree fs_info->fs_root_radix, including orphan roots (deleted snapshots). So after the log tree is replayed, when finding orphan roots we hit the BUG_ON with the following trace: [118209.182438] ------------[ cut here ]------------ [118209.183279] kernel BUG at fs/btrfs/root-tree.c:314! [118209.184074] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC [118209.185123] Modules linked in: btrfs dm_flakey dm_mod crc32c_generic ppdev xor raid6_pq evdev sg parport_pc parport acpi_cpufreq tpm_tis tpm psmouse processor i2c_piix4 serio_raw pcspkr i2c_core button loop autofs4 ext4 crc16 mbcache jbd2 sd_mod sr_mod cdrom ata_generic virtio_scsi ata_piix libata virtio_pci virtio_ring virtio scsi_mod e1000 floppy [last unloaded: btrfs] [118209.186318] CPU: 14 PID: 28428 Comm: mount Tainted: G W 4.5.0-rc5-btrfs-next-24+ #1 [118209.186318] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS by qemu-project.org 04/01/2014 [118209.186318] task: ffff8801ec131040 ti: ffff8800af34c000 task.ti: ffff8800af34c000 [118209.186318] RIP: 0010:[<ffffffffa04237d7>] [<ffffffffa04237d7>] btrfs_find_orphan_roots+0x1fc/0x244 [btrfs] [118209.186318] RSP: 0018:ffff8800af34faa8 EFLAGS: 00010246 [118209.186318] RAX: 00000000ffffffef RBX: 00000000ffffffef RCX: 0000000000000001 [118209.186318] RDX: 0000000080000000 RSI: 0000000000000001 RDI: 00000000ffffffff [118209.186318] RBP: ffff8800af34fb08 R08: 0000000000000001 R09: 0000000000000000 [118209.186318] R10: ffff8800af34f9f0 R11: 6db6db6db6db6db7 R12: ffff880171b97000 [118209.186318] R13: ffff8801ca9d65e0 R14: ffff8800afa2e000 R15: 0000160000000000 [118209.186318] FS: 00007f5bcb914840(0000) GS:ffff88023edc0000(0000) knlGS:0000000000000000 [118209.186318] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [118209.186318] CR2: 00007f5bcaceb5d9 CR3: 00000000b49b5000 CR4: 00000000000006e0 [118209.186318] Stack: [118209.186318] fffffbffffffffff 010230ffffffffff 0101000000000000 ff84000000000000 [118209.186318] fbffffffffffffff 30ffffffffffffff 0000000000000101 ffff880082348000 [118209.186318] 0000000000000000 ffff8800afa2e000 ffff8800afa2e000 0000000000000000 [118209.186318] Call Trace: [118209.186318] [<ffffffffa042e2db>] open_ctree+0x1e37/0x21b9 [btrfs] [118209.186318] [<ffffffffa040a753>] btrfs_mount+0x97e/0xaed [btrfs] [118209.186318] [<ffffffff8108e1c0>] ? trace_hardirqs_on+0xd/0xf [118209.186318] [<ffffffff8117b87e>] mount_fs+0x67/0x131 [118209.186318] [<ffffffff81192d2b>] vfs_kern_mount+0x6c/0xde [118209.186318] [<ffffffffa0409f81>] btrfs_mount+0x1ac/0xaed [btrfs] [118209.186318] [<ffffffff8108e1c0>] ? trace_hardirqs_on+0xd/0xf [118209.186318] [<ffffffff8108c26b>] ? lockdep_init_map+0xb9/0x1b3 [118209.186318] [<ffffffff8117b87e>] mount_fs+0x67/0x131 [118209.186318] [<ffffffff81192d2b>] vfs_kern_mount+0x6c/0xde [118209.186318] [<ffffffff81195637>] do_mount+0x8a6/0x9e8 [118209.186318] [<ffffffff8119598d>] SyS_mount+0x77/0x9f [118209.186318] [<ffffffff81493017>] entry_SYSCALL_64_fastpath+0x12/0x6b [118209.186318] Code: 64 00 00 85 c0 89 c3 75 24 f0 41 80 4c 24 20 20 49 8b bc 24 f0 01 00 00 4c 89 e6 e8 e8 65 00 00 85 c0 89 c3 74 11 83 f8 ef 75 02 <0f> 0b 4c 89 e7 e8 da 72 00 00 eb 1c 41 83 bc 24 00 01 00 00 00 [118209.186318] RIP [<ffffffffa04237d7>] btrfs_find_orphan_roots+0x1fc/0x244 [btrfs] [118209.186318] RSP <ffff8800af34faa8> [118209.230735] ---[ end trace 83938f987d85d477 ]--- So fix this by not treating the error -EEXIST, returned when attempting to insert a root already inserted by the backref walking code, as an error. The following test case for xfstests reproduces the bug: seq=`basename $0` seqres=$RESULT_DIR/$seq echo "QA output created by $seq" tmp=/tmp/$$ status=1 # failure is the default! trap "_cleanup; exit \$status" 0 1 2 3 15 _cleanup() { _cleanup_flakey cd / rm -f $tmp.* } # get standard environment, filters and checks . ./common/rc . ./common/filter . ./common/dmflakey # real QA test starts here _supported_fs btrfs _supported_os Linux _require_scratch _require_dm_target flakey _require_metadata_journaling $SCRATCH_DEV rm -f $seqres.full _scratch_mkfs >>$seqres.full 2>&1 _init_flakey _mount_flakey _run_btrfs_util_prog quota enable $SCRATCH_MNT # Create 2 directories with one file in one of them. # We use these just to trigger a transaction commit later, moving the file from # directory a to directory b and doing an fsync against directory a. mkdir $SCRATCH_MNT/a mkdir $SCRATCH_MNT/b touch $SCRATCH_MNT/a/f sync # Create our test file with 2 4K extents. $XFS_IO_PROG -f -s -c "pwrite -S 0xaa 0 8K" $SCRATCH_MNT/foobar | _filter_xfs_io # Create a snapshot and delete it. This doesn't really delete the snapshot # immediately, just makes it inaccessible and invisible to user space, the # snapshot is deleted later by a dedicated kernel thread (cleaner kthread) # which is woke up at the next transaction commit. # A root orphan item is inserted into the tree of tree roots, so that if a # power failure happens before the dedicated kernel thread does the snapshot # deletion, the next time the filesystem is mounted it resumes the snapshot # deletion. _run_btrfs_util_prog subvolume snapshot $SCRATCH_MNT $SCRATCH_MNT/snap _run_btrfs_util_prog subvolume delete $SCRATCH_MNT/snap # Now overwrite half of the extents we wrote before. Because we made a snapshpot # before, which isn't really deleted yet (since no transaction commit happened # after we did the snapshot delete request), the non overwritten extents get # referenced twice, once by the default subvolume and once by the snapshot. $XFS_IO_PROG -c "pwrite -S 0xbb 4K 8K" $SCRATCH_MNT/foobar | _filter_xfs_io # Now move file f from directory a to directory b and fsync directory a. # The fsync on the directory a triggers a transaction commit (because a file # was moved from it to another directory) and the file fsync leaves a log tree # with file extent items to replay. mv $SCRATCH_MNT/a/f $SCRATCH_MNT/a/b $XFS_IO_PROG -c "fsync" $SCRATCH_MNT/a $XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foobar echo "File digest before power failure:" md5sum $SCRATCH_MNT/foobar | _filter_scratch # Now simulate a power failure and mount the filesystem to replay the log tree. # After the log tree was replayed, we used to hit a BUG_ON() when processing # the root orphan item for the deleted snapshot. This is because when processing # an orphan root the code expected to be the first code inserting the root into # the fs_info->fs_root_radix radix tree, while in reallity it was the second # caller attempting to do it - the first caller was the transaction commit that # took place after replaying the log tree, when updating the qgroup counters. _flakey_drop_and_remount echo "File digest before after failure:" # Must match what he got before the power failure. md5sum $SCRATCH_MNT/foobar | _filter_scratch _unmount_flakey status=0 exit Fixes: 2d9e97761087 ("Btrfs: use btrfs_get_fs_root in resolve_indirect_ref") Signed-off-by: Filipe Manana <fdmanana@suse.com> Reviewed-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09pata-rb532-cf: get rid of the irq_to_gpio() callGabor Juhos
commit 018361767a21fb2d5ebd3ac182c04baf8a8b4e08 upstream. The RB532 platform specific irq_to_gpio() implementation has been removed with commit 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h"). Now the platform uses the generic stub which causes the following error: pata-rb532-cf pata-rb532-cf: no GPIO found for irq149 pata-rb532-cf: probe of pata-rb532-cf failed with error -2 Drop the irq_to_gpio() call and get the GPIO number from platform data instead. After this change, the driver works again: scsi host0: pata-rb532-cf ata1: PATA max PIO4 irq 149 ata1.00: CFA: CF 1GB, 20080820, max MWDMA4 ata1.00: 1989792 sectors, multi 0: LBA ata1.00: configured for PIO4 scsi 0:0:0:0: Direct-Access ATA CF 1GB 0820 PQ: 0\ ANSI: 5 sd 0:0:0:0: [sda] 1989792 512-byte logical blocks: (1.01 GB/971 MiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't\ support DPO or FUA sda: sda1 sda2 sd 0:0:0:0: [sda] Attached SCSI disk Fixes: 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h") Cc: Alban Bedel <albeu@free.fr> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09tracing: Do not have 'comm' filter override event 'comm' fieldSteven Rostedt (Red Hat)
commit e57cbaf0eb006eaa207395f3bfd7ce52c1b5539c upstream. Commit 9f61668073a8d "tracing: Allow triggers to filter for CPU ids and process names" added a 'comm' filter that will filter events based on the current tasks struct 'comm'. But this now hides the ability to filter events that have a 'comm' field too. For example, sched_migrate_task trace event. That has a 'comm' field of the task to be migrated. echo 'comm == "bash"' > events/sched_migrate_task/filter will now filter all sched_migrate_task events for tasks named "bash" that migrates other tasks (in interrupt context), instead of seeing when "bash" itself gets migrated. This fix requires a couple of changes. 1) Change the look up order for filter predicates to look at the events fields before looking at the generic filters. 2) Instead of basing the filter function off of the "comm" name, have the generic "comm" filter have its own filter_type (FILTER_COMM). Test against the type instead of the name to assign the filter function. 3) Add a new "COMM" filter that works just like "comm" but will filter based on the current task, even if the trace event contains a "comm" field. Do the same for "cpu" field, adding a FILTER_CPU and a filter "CPU". Fixes: 9f61668073a8d "tracing: Allow triggers to filter for CPU ids and process names" Reported-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09ata: ahci: don't mark HotPlugCapable Ports as external/removableManuel Lauss
commit dc8b4afc4a04fac8ee55a19b59f2356a25e7e778 upstream. The HPCP bit is set by bioses for on-board sata ports either because they think sata is hotplug capable in general or to allow Windows to display a "device eject" icon on ports which are routed to an external connector bracket. However in Redhat Bugzilla #1310682, users report that with kernel 4.4, where this bit test first appeared, a lot of partitions on sata drives are now mounted automatically. This patch should fix redhat and a lot of other distros which unconditionally automount all devices which have the "removable" bit set. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 8a3e33cf92c7 ("ata: ahci: find eSATA ports and flag them as removable" changes userspace behavior) Link: http://lkml.kernel.org/g/56CF35FA.1070500@redhat.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09PM / sleep / x86: Fix crash on graph trace through x86 suspendTodd E Brandt
commit 92f9e179a702a6adbc11e2fedc76ecd6ffc9e3f7 upstream. Pause/unpause graph tracing around do_suspend_lowlevel as it has inconsistent call/return info after it jumps to the wakeup vector. The graph trace buffer will otherwise become misaligned and may eventually crash and hang on suspend. To reproduce the issue and test the fix: Run a function_graph trace over suspend/resume and set the graph function to suspend_devices_and_enter. This consistently hangs the system without this fix. Signed-off-by: Todd Brandt <todd.e.brandt@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09arm64: vmemmap: use virtual projection of linear regionArd Biesheuvel
commit dfd55ad85e4a7fbaa82df12467515ac3c81e8a3e upstream. Commit dd006da21646 ("arm64: mm: increase VA range of identity map") made some changes to the memory mapping code to allow physical memory to reside at an offset that exceeds the size of the virtual mapping. However, since the size of the vmemmap area is proportional to the size of the VA area, but it is populated relative to the physical space, we may end up with the struct page array being mapped outside of the vmemmap region. For instance, on my Seattle A0 box, I can see the following output in the dmesg log. vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) 0xffffffbfc0000000 - 0xffffffbfd0000000 ( 256 MB actual) We can fix this by deciding that the vmemmap region is not a projection of the physical space, but of the virtual space above PAGE_OFFSET, i.e., the linear region. This way, we are guaranteed that the vmemmap region is of sufficient size, and we can even reduce the size by half. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09Adding Intel Lewisburg device IDs for SATAAlexandra Yates
commit f5bdd66c705484b4bc77eb914be15c1b7881fae7 upstream. This patch complements the list of device IDs previously added for lewisburg sata. Signed-off-by: Alexandra Yates <alexandra.yates@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09writeback: flush inode cgroup wb switches instead of pinning super_blockTejun Heo
commit a1a0e23e49037c23ea84bc8cc146a03584d13577 upstream. If cgroup writeback is in use, inodes can be scheduled for asynchronous wb switching. Before 5ff8eaac1636 ("writeback: keep superblock pinned during cgroup writeback association switches"), this could race with umount leading to super_block being destroyed while inodes are pinned for wb switching. 5ff8eaac1636 fixed it by bumping s_active while wb switches are in flight; however, this allowed in-flight wb switches to make umounts asynchronous when the userland expected synchronosity - e.g. fsck immediately following umount may fail because the device is still busy. This patch removes the problematic super_block pinning and instead makes generic_shutdown_super() flush in-flight wb switches. wb switches are now executed on a dedicated isw_wq so that they can be flushed and isw_nr_in_flight keeps track of the number of in-flight wb switches so that flushing can be avoided in most cases. v2: Move cgroup_writeback_umount() further below and add MS_ACTIVE check in inode_switch_wbs() as Jan an Al suggested. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Tahsin Erdogan <tahsin@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@ZenIV.linux.org.uk> Link: http://lkml.kernel.org/g/CAAeU0aNCq7LGODvVGRU-oU_o-6enii5ey0p1c26D1ZzYwkDc5A@mail.gmail.com Fixes: 5ff8eaac1636 ("writeback: keep superblock pinned during cgroup writeback association switches") Reviewed-by: Jan Kara <jack@suse.cz> Tested-by: Tahsin Erdogan <tahsin@google.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09block: bio: introduce helpers to get the 1st and last bvecMing Lei
commit 7bcd79ac50d9d83350a835bdb91c04ac9e098412 upstream. The bio passed to bio_will_gap() may be fast cloned from upper layer(dm, md, bcache, fs, ...), or from bio splitting in block core. Unfortunately bio_will_gap() just figures out the last bvec via 'bi_io_vec[prev->bi_vcnt - 1]' directly, and this way is obviously wrong. This patch introduces two helpers for getting the first and last bvec of one bio for fixing the issue. Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09libata: Align ata_device's id on a cachelineHarvey Hunt
commit 4ee34ea3a12396f35b26d90a094c75db95080baa upstream. The id buffer in ata_device is a DMA target, but it isn't explicitly cacheline aligned. Due to this, adjacent fields can be overwritten with stale data from memory on non coherent architectures. As a result, the kernel is sometimes unable to communicate with an ATA device. Fix this by ensuring that the id buffer is cacheline aligned. This issue is similar to that fixed by Commit 84bda12af31f ("libata: align ap->sector_buf"). Signed-off-by: Harvey Hunt <harvey.hunt@imgtec.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09libata: fix HDIO_GET_32BIT ioctlArnd Bergmann
commit 287e6611ab1eac76c2c5ebf6e345e04c80ca9c61 upstream. As reported by Soohoon Lee, the HDIO_GET_32BIT ioctl does not work correctly in compat mode with libata. I have investigated the issue further and found multiple problems that all appeared with the same commit that originally introduced HDIO_GET_32BIT handling in libata back in linux-2.6.8 and presumably also linux-2.4, as the code uses "copy_to_user(arg, &val, 1)" to copy a 'long' variable containing either 0 or 1 to user space. The problems with this are: * On big-endian machines, this will always write a zero because it stores the wrong byte into user space. * In compat mode, the upper three bytes of the variable are updated by the compat_hdio_ioctl() function, but they now contain uninitialized stack data. * The hdparm tool calling this ioctl uses a 'static long' variable to store the result. This means at least the upper bytes are initialized to zero, but calling another ioctl like HDIO_GET_MULTCOUNT would fill them with data that remains stale when the low byte is overwritten. Fortunately libata doesn't implement any of the affected ioctl commands, so this would only happen when we query both an IDE and an ATA device in the same command such as "hdparm -N -c /dev/hda /dev/sda" * The libata code for unknown reasons started using ATA_IOC_GET_IO32 and ATA_IOC_SET_IO32 as aliases for HDIO_GET_32BIT and HDIO_SET_32BIT, while the ioctl commands that were added later use the normal HDIO_* names. This is harmless but rather confusing. This addresses all four issues by changing the code to use put_user() on an 'unsigned long' variable in HDIO_GET_32BIT, like the IDE subsystem does, and by clarifying the names of the ioctl commands. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Soohoon Lee <Soohoon.Lee@f5.com> Tested-by: Soohoon Lee <Soohoon.Lee@f5.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09drm/amdgpu: return from atombios_dp_get_dpcd only when errorArindam Nath
commit 0b39c531cfa12dad54eac238c2e303b994df1ef7 upstream. In amdgpu_connector_hotplug(), we need to start DP link training only after we have received DPCD. The function amdgpu_atombios_dp_get_dpcd() returns non-zero value only when an error condition is met, otherwise returns zero. So in case the function encounters an error, we need to skip rest of the code and return from amdgpu_connector_hotplug() immediately. Only when we are successfull in reading DPCD pin, we should carry on with turning-on the monitor. Signed-off-by: Arindam Nath <arindam.nath@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09drm/amdgpu/gfx8: specify which engine to wait before vm flushChunming Zhou
commit 9cac537332f5502c103415b25609548c276a09f8 upstream. Select between me and pfp properly. Signed-off-by: Chunming Zhou <David1.Zhou@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09drm/amdgpu: apply gfx_v8 fixes to gfx_v7 as wellChristian König
commit feebe91aa9a9d99d9ec157612a614fadb79beb99 upstream. We never ported that back to CIK, so we could run into VM faults here. Signed-off-by: Christian König <christian.koenig@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
