commit 90cae1fe1c3540f791d5b8e025985fa5e699b2bb upstream.
As a part of memory initialisation the architecture passes an array to
free_area_init_nodes() which specifies the max PFN of each memory zone.
This array is not necessarily monotonic (due to unused zones) so this
array is parsed to build monotonic lists of the min and max PFN for each
zone. ZONE_MOVABLE is special cased here as its limits are managed by
the mm subsystem rather than the architecture. Unfortunately, this
special casing is broken when ZONE_MOVABLE is the not the last zone in
the zone list. The core of the issue is:
if (i == ZONE_MOVABLE)
continue;
arch_zone_lowest_possible_pfn[i] =
arch_zone_highest_possible_pfn[i-1];
As ZONE_MOVABLE is skipped the lowest_possible_pfn of the next zone will
be set to zero. This patch fixes this bug by adding explicitly tracking
where the next zone should start rather than relying on the contents
arch_zone_highest_possible_pfn[].
Thie is low priority. To get bitten by this you need to enable a zone
that appears after ZONE_MOVABLE in the zone_type enum. As far as I can
tell this means running a kernel with ZONE_DEVICE or ZONE_CMA enabled,
so I can't see this affecting too many people.
I only noticed this because I've been fiddling with ZONE_DEVICE on
powerpc and 4.6 broke my test kernel. This bug, in conjunction with the
changes in Taku Izumi's kernelcore=mirror patch (d91749c1dda71) and
powerpc being the odd architecture which initialises max_zone_pfn[] to
~0ul instead of 0 caused all of system memory to be placed into
ZONE_DEVICE at boot, followed a panic since device memory cannot be used
for kernel allocations. I've already submitted a patch to fix the
powerpc specific bits, but I figured this should be fixed too.
Link: http://lkml.kernel.org/r/1462435033-15601-1-git-send-email-oohall@gmail.com
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
commit 2e40795c3bf344cfb5220d94566205796e3ef19a upstream.
Plantronics BT600 does not support reading the sample rate which leads
to many lines of "cannot get freq at ep 0x1" and "cannot get freq at
ep 0x82". This patch adds the USB ID of the BT600 to quirks.c and
avoids those error messages.
Signed-off-by: Dennis Kadioglu <denk@post.com>
commit 7243e0b20729d372e97763617a7a9c89f29b33e1 upstream.
The calculation of SPR and SPPR doesn't round correctly at several
places which might result in baud rates that are too big. For example
with tclk_hz = 250000001 and target rate 25000000 it determined a
divider of 10 which is wrong.
Instead of fixing all the corner cases replace the calculation by an
algorithm without a loop which should even be quicker to execute apart
from being correct.
Fixes: df59fa7f4bca ("spi: orion: support armada extended baud rates")
Signed-off-by: Mark Brown <broonie@kernel.org>
commit cbf2642872333547b56b8c4d943f5ed04ac9a4ee upstream.
We don't want to fall through to a bunch of errors for retention
if PM_OMAP4_CPU_OSWR_DISABLE is not configured for a SoC.
Fixes: 6099dd37c669 ("ARM: OMAP5 / DRA7: Enable CPU RET on suspend")
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
commit 7a3cc2a7b2c723aa552028f4e66841cec183756d upstream.
On Zynq, we haven't been reserving the correct amount of DMA-incapable
RAM to keep DMA away from it (per the Zynq TRM Section 4.1, it should be
the first 512k). In older kernels, this was masked by the
memblock_reserve call in arm_memblock_init(). Now, reserve the correct
amount excplicitly rather than relying on swapper_pg_dir, which is an
address and not a size anyway.
Fixes: 46f5b96 ("ARM: zynq: Reserve not DMAable space in front of the kernel")
Signed-off-by: Kyle Roeschley <kyle.roeschley@ni.com>
Tested-by: Nathan Rossi <nathan@nathanrossi.com>
commit 8ae679c4bc2ea2d16d92620da8e3e9332fa4039f upstream.
I am getting the following warning when I build kernel 4.9-git on my
PowerBook G4 with a 32-bit PPC processor:
AS arch/powerpc/kernel/misc_32.o
arch/powerpc/kernel/misc_32.S:299:7: warning: "CONFIG_FSL_BOOKE" is not defined [-Wundef]
This problem is evident after commit 989cea5c14be ("kbuild: prevent
lib-ksyms.o rebuilds"); however, this change in kbuild only exposes an
error that has been in the code since 2005 when this source file was
created. That was with commit 9994a33865f4 ("powerpc: Introduce
entry_{32,64}.S, misc_{32,64}.S, systbl.S").
The offending line does not make a lot of sense. This error does not
seem to cause any errors in the executable, thus I am not recommending
that it be applied to any stable versions.
Thanks to Nicholas Piggin for suggesting this solution.
Fixes: 9994a33865f4 ("powerpc: Introduce entry_{32,64}.S, misc_{32,64}.S, systbl.S")
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
commit 6a2a2f45560a9cb7bc49820883b042e44f83726c upstream.
This module has a bug not to return error code in a case that data
structure for transmitted packets fails to be initialized.
This commit fixes the bug.
Fixes: 35efa5c489de ("ALSA: firewire-tascam: add streaming functionality")
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 1ebb71143758f45dc0fa76e2f48429e13b16d110 upstream.
Make sure we have enough of a report structure to validate before
looking at it.
Reported-by: Benoit Camredon <benoit.camredon@airbus.com>
Tested-by: Benoit Camredon <benoit.camredon@airbus.com>
[ Upstream commit 24c63bbc18e25d5d8439422aa5fd2d66390b88eb ]
Frank reported that vrf devices can be created with a table id of 0.
This breaks many of the run time table id checks and should not be
allowed. Detect this condition at create time and fail with EINVAL.
Fixes: 193125dbd8eb ("net: Introduce VRF device driver")
Reported-by: Frank Kellermann <frank.kellermann@atos.net>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit 7a18c5b9fb31a999afc62b0e60978aa896fc89e9 ]
fib_select_path does not call fib_select_multipath if oif is set in the
flow struct. For VRF use cases oif is always set, so multipath route
selection is bypassed. Use the FLOWI_FLAG_SKIP_NH_OIF to skip the oif
check similar to what is done in fib_table_lookup.
Add saddr and proto to the flow struct for the fib lookup done by the
VRF driver to better match hash computation for a flow.
Fixes: 613d09b30f8b ("net: Use VRF device index for lookups on TX")
[ Upstream commit 57ea52a865144aedbcd619ee0081155e658b6f7d ]
The GRO fast path caches the frag0 address. This address becomes
invalid if frag0 is modified by pskb_may_pull or its variants.
So whenever that happens we must disable the frag0 optimization.
This is usually done through the combination of gro_header_hard
and gro_header_slow, however, the IPv6 extension header path did
the pulling directly and would continue to use the GRO fast path
incorrectly.
This patch fixes it by disabling the fast path when we enter the
IPv6 extension header path.
Fixes: 78a478d0efd9 ("gro: Inline skb_gro_header and cache frag0 virtual address")
Reported-by: Slava Shwartsman <slavash@mellanox.com>
[ Upstream commit 7cfd5fd5a9813f1430290d20c0fead9b4582a307 ]
On 32bit arches, (skb->end - skb->data) is not 'unsigned int',
so we shall use min_t() instead of min() to avoid a compiler error.
Fixes: 1272ce87fa01 ("gro: Enter slow-path if there is no tailroom")
Reported-by: kernel test robot <fengguang.wu@intel.com>
[ Upstream commit 1272ce87fa017ca4cf32920764d879656b7a005a ]
The GRO path has a fast-path where we avoid calling pskb_may_pull
and pskb_expand by directly accessing frag0. However, this should
only be done if we have enough tailroom in the skb as otherwise
we'll have to expand it later anyway.
This patch adds the check by capping frag0_len with the skb tailroom.
Fixes: cb18978cbf45 ("gro: Open-code final pskb_may_pull")
[ Upstream commit 75dc692eda114cb234a46cb11893a9c3ea520934 ]
Pause the rx and make sure the rx fifo is empty when the autosuspend
occurs.
If the rx data comes when the driver is canceling the rx urb, the host
controller would stop getting the data from the device and continue
it after next rx urb is submitted. That is, one continuing data is
split into two different urb buffers. That let the driver take the
data as a rx descriptor, and unexpected behavior happens.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
[ Upstream commit 8fb280616878b81c0790a0c33acbeec59c5711f4 ]
Split rtl8152_suspend() into rtl8152_system_suspend() and
rtl8152_rumtime_suspend().
[ Upstream commit 5350d54f6cd12eaff623e890744c79b700bd3f17 ]
In the case of custom rules being present we need to handle the case of the
LOCAL table being intialized after the new rule has been added. To address
that I am adding a new check so that we can make certain we don't use an
alias of MAIN for LOCAL when allocating a new table.
Fixes: 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
Reported-by: Oliver Brunel <jjk@jjacky.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 7ababb782690e03b78657e27bd051e20163af2d6 ]
5.2. Action on Reception of a Query
When a system receives a Query, it does not respond immediately.
Instead, it delays its response by a random amount of time, bounded
by the Max Resp Time value derived from the Max Resp Code in the
received Query message. A system may receive a variety of Queries on
different interfaces and of different kinds (e.g., General Queries,
Group-Specific Queries, and Group-and-Source-Specific Queries), each
of which may require its own delayed response.
Before scheduling a response to a Query, the system must first
consider previously scheduled pending responses and in many cases
schedule a combined response. Therefore, the system must be able to
maintain the following state:
o A timer per interface for scheduling responses to General Queries.
o A per-group and interface timer for scheduling responses to Group-
Specific and Group-and-Source-Specific Queries.
o A per-group and interface list of sources to be reported in the
response to a Group-and-Source-Specific Query.
When a new Query with the Router-Alert option arrives on an
interface, provided the system has state to report, a delay for a
response is randomly selected in the range (0, [Max Resp Time]) where
Max Resp Time is derived from Max Resp Code in the received Query
message. The following rules are then used to determine if a Report
needs to be scheduled and the type of Report to schedule. The rules
are considered in order and only the first matching rule is applied.
1. If there is a pending response to a previous General Query
scheduled sooner than the selected delay, no additional response
needs to be scheduled.
2. If the received Query is a General Query, the interface timer is
used to schedule a response to the General Query after the
selected delay. Any previously pending response to a General
Query is canceled.
--8<--
Currently the timer is rearmed with new random expiration time for
every incoming query regardless of possibly already pending report.
Which is not aligned with the above RFE.
It also might happen that higher rate of incoming queries can
postpone the report after the expiration time of the first query
causing group membership loss.
Now the per interface general query timer is rearmed only
when there is no pending report already scheduled on that interface or
the newly selected expiration time is before the already pending
scheduled report.
Signed-off-by: Michal Tesar <mtesar@redhat.com>
[ Upstream commit 3b48ab2248e61408910e792fe84d6ec466084c1a ]
Final nlmsg_len field update must reflect inserted net_dm_drop_point
data.
This patch depends on previous patch:
"drop_monitor: add missing call to genlmsg_end"
Signed-off-by: Reiter Wolfgang <wr0112358@gmail.com>
[ Upstream commit 4200462d88f47f3759bdf4705f87e207b0f5b2e4 ]
Update nlmsg_len field with genlmsg_end to enable userspace processing
using nlmsg_next helper. Also adds error handling.
[ Upstream commit d151d73dcc99de87c63bdefebcc4cb69de1cdc40 ]
Avoid using a local variable named numa_node to avoid shadowing a public
one.
Fixes: db058a186f98 ('net/mlx5_core: Set irq affinity hints')
Signed-off-by: Eli Cohen <eli@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit 883371c453b937f9eb581fb4915210865982736f ]
When setting HCA capabilities, set log_max_qp to be the minimum
between the selected profile's value and the HCA limitation.
Fixes: 938fe83c8dcb ('net/mlx5_core: New device capabilities...')
Signed-off-by: Noa Osherovich <noaos@mellanox.com>
[ Upstream commit 5701659004d68085182d2fd4199c79172165fa65 ]
There is currently a small window during which the network device registered by
stmmac can be made visible, yet all resources, including and clock and MDIO bus
have not had a chance to be set up, this can lead to the following error to
occur:
[ 473.919358] stmmaceth 0000:01:00.0 (unnamed net_device) (uninitialized):
stmmac_dvr_probe: warning: cannot get CSR clock
[ 473.919382] stmmaceth 0000:01:00.0: no reset control found
[ 473.919412] stmmac - user ID: 0x10, Synopsys ID: 0x42
[ 473.919429] stmmaceth 0000:01:00.0: DMA HW capability register supported
[ 473.919436] stmmaceth 0000:01:00.0: RX Checksum Offload Engine supported
[ 473.919443] stmmaceth 0000:01:00.0: TX Checksum insertion supported
[ 473.919451] stmmaceth 0000:01:00.0 (unnamed net_device) (uninitialized):
Enable RX Mitigation via HW Watchdog Timer
[ 473.921395] libphy: PHY stmmac-1:00 not found
[ 473.921417] stmmaceth 0000:01:00.0 eth0: Could not attach to PHY
[ 473.921427] stmmaceth 0000:01:00.0 eth0: stmmac_open: Cannot attach to
PHY (error: -19)
[ 473.959710] libphy: stmmac: probed
[ 473.959724] stmmaceth 0000:01:00.0 eth0: PHY ID 01410cc2 at 0 IRQ POLL
(stmmac-1:00) active
[ 473.959728] stmmaceth 0000:01:00.0 eth0: PHY ID 01410cc2 at 1 IRQ POLL
(stmmac-1:01)
[ 473.959731] stmmaceth 0000:01:00.0 eth0: PHY ID 01410cc2 at 2 IRQ POLL
(stmmac-1:02)
[ 473.959734] stmmaceth 0000:01:00.0 eth0: PHY ID 01410cc2 at 3 IRQ POLL
(stmmac-1:03)
Fix this by making sure that register_netdev() is the last thing being done,
which guarantees that the clock and the MDIO bus are available.
Fixes: 4bfcbd7abce2 ("stmmac: Move the mdio_register/_unregister in probe/remove")
Reported-by: Kweh, Hock Leong <hock.leong.kweh@intel.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 628185cfddf1dfb701c4efe2cfd72cf5b09f5702 ]
Shahar reported a soft lockup in tc_classify(), where we run into an
endless loop when walking the classifier chain due to tp->next == tp
which is a state we should never run into. The issue only seems to
trigger under load in the tc control path.
What happens is that in tc_ctl_tfilter(), thread A allocates a new
tp, initializes it, sets tp_created to 1, and calls into tp->ops->change()
with it. In that classifier callback we had to unlock/lock the rtnl
mutex and returned with -EAGAIN. One reason why we need to drop there
is, for example, that we need to request an action module to be loaded.
This happens via tcf_exts_validate() -> tcf_action_init/_1() meaning
after we loaded and found the requested action, we need to redo the
whole request so we don't race against others. While we had to unlock
rtnl in that time, thread B's request was processed next on that CPU.
Thread B added a new tp instance successfully to the classifier chain.
When thread A returned grabbing the rtnl mutex again, propagating -EAGAIN
and destroying its tp instance which never got linked, we goto replay
and redo A's request.
This time when walking the classifier chain in tc_ctl_tfilter() for
checking for existing tp instances we had a priority match and found
the tp instance that was created and linked by thread B. Now calling
again into tp->ops->change() with that tp was successful and returned
without error.
tp_created was never cleared in the second round, thus kernel thinks
that we need to link it into the classifier chain (once again). tp and
*back point to the same object due to the match we had earlier on. Thus
for thread B's already public tp, we reset tp->next to tp itself and
link it into the chain, which eventually causes the mentioned endless
loop in tc_classify() once a packet hits the data path.
Fix is to clear tp_created at the beginning of each request, also when
we replay it. On the paths that can cause -EAGAIN we already destroy
the original tp instance we had and on replay we really need to start
from scratch. It seems that this issue was first introduced in commit
12186be7d2e1 ("net_cls: fix unconfigured struct tcf_proto keeps chaining
and avoid kernel panic when we use cls_cgroup").
Fixes: 12186be7d2e1 ("net_cls: fix unconfigured struct tcf_proto keeps chaining and avoid kernel panic when we use cls_cgroup")
Reported-by: Shahar Klein <shahark@mellanox.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Tested-by: Shahar Klein <shahark@mellanox.com>
[ Upstream commit a98f91758995cb59611e61318dddd8a6956b52c3 ]
By setting certain socket options on ipv6 raw sockets, we can confuse the
length calculation in rawv6_push_pending_frames triggering a BUG_ON.
RIP: 0010:[<ffffffff817c6390>] [<ffffffff817c6390>] rawv6_sendmsg+0xc30/0xc40
RSP: 0018:ffff881f6c4a7c18 EFLAGS: 00010282
RAX: 00000000fffffff2 RBX: ffff881f6c681680 RCX: 0000000000000002
RDX: ffff881f6c4a7cf8 RSI: 0000000000000030 RDI: ffff881fed0f6a00
RBP: ffff881f6c4a7da8 R08: 0000000000000000 R09: 0000000000000009
R10: ffff881fed0f6a00 R11: 0000000000000009 R12: 0000000000000030
R13: ffff881fed0f6a00 R14: ffff881fee39ba00 R15: ffff881fefa93a80
Call Trace:
[<ffffffff8118ba23>] ? unmap_page_range+0x693/0x830
[<ffffffff81772697>] inet_sendmsg+0x67/0xa0
[<ffffffff816d93f8>] sock_sendmsg+0x38/0x50
[<ffffffff816d982f>] SYSC_sendto+0xef/0x170
[<ffffffff816da27e>] SyS_sendto+0xe/0x10
[<ffffffff81002910>] do_syscall_64+0x50/0xa0
[<ffffffff817f7cbc>] entry_SYSCALL64_slow_path+0x25/0x25
Handle by jumping to the failure path if skb_copy_bits gets an EFAULT.
Reproducer:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#define LEN 504
int main(int argc, char* argv[])
int fd;
int zero = 0;
char buf[LEN];
memset(buf, 0, LEN);
fd = socket(AF_INET6, SOCK_RAW, 7);
setsockopt(fd, SOL_IPV6, IPV6_CHECKSUM, &zero, 4);
setsockopt(fd, SOL_IPV6, IPV6_DSTOPTS, &buf, LEN);
sendto(fd, buf, 1, 0, (struct sockaddr *) buf, 110);
Signed-off-by: Dave Jones <davej@codemonkey.org.uk>
[ Upstream commit eb63ecc1706b3e094d0f57438b6c2067cfc299f2 ]
Locally originated traffic in a VRF fails in the presence of a POSTROUTING
rule. For example,
$ iptables -t nat -A POSTROUTING -s 11.1.1.0/24 -j MASQUERADE
$ ping -I red -c1 11.1.1.3
ping: Warning: source address might be selected on device other than red.
PING 11.1.1.3 (11.1.1.3) from 11.1.1.2 red: 56(84) bytes of data.
ping: sendmsg: Operation not permitted
Worse, the above causes random corruption resulting in a panic in random
places (I have not seen a consistent backtrace).
Call nf_reset to drop the conntrack info following the pass through the
VRF device. The nf_reset is needed on Tx but not Rx because of the order
in which NF_HOOK's are hit: on Rx the VRF device is after the real ingress
device and on Tx it is is before the real egress device. Connection
tracking should be tied to the real egress device and not the VRF device.
Fixes: 8f58336d3f78a ("net: Add ethernet header for pass through VRF device")
Fixes: 35402e3136634 ("net: Add IPv6 support to VRF device")
[ Upstream commit 93a97c50cbf1c007caf12db5cc23e0d5b9c8473c ]
If we can't allocate the resources in gigaset_initdriver() then we
should return -ENOMEM instead of zero.
Fixes: 2869b23e4b95 ("[PATCH] drivers/isdn/gigaset: new M101 driver (v2)")
[ Upstream commit a50af86dd49ee1851d1ccf06dd0019c05b95e297 ]
Hyper-V (and Azure) support using NVGRE which requires some extra space
for encapsulation headers. Because of this the largest allowed TSO
packet is reduced.
For older releases, hard code a fixed reduced value. For next release,
there is a better solution which uses result of host offload
negotiation.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
commit eaa496ffaaf19591fe471a36cef366146eeb9153 upstream.
ep->mult is supposed to be set to Isochronous and
Interrupt Endapoint's multiplier value. This value
is computed from different places depending on the
link speed.
If we're dealing with HighSpeed, then it's part of
bits [12:11] of wMaxPacketSize. This case wasn't
taken into consideration before.
While at that, also make sure the ep->mult defaults
to one so drivers can use it unconditionally and
assume they'll never multiply ep->maxpacket to zero.
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
This reverts commit c53af76d5de1af844a71e673ae4a02f1786c1b9c which is
commit eaa496ffaaf19591fe471a36cef366146eeb9153 upstream as it was
incorrect.
Reported-by: Bin Liu <b-liu@ti.com>
Cc: Felipe Balbi <balbi@kernel.org>
commit c1a9eeb938b5433947e5ea22f89baff3182e7075 upstream.
When a disfunctional timer, e.g. dummy timer, is installed, the tick core
tries to setup the broadcast timer.
If no broadcast device is installed, the kernel crashes with a NULL pointer
dereference in tick_broadcast_setup_oneshot() because the function has no
sanity check.
Reported-by: Mason <slash.tmp@free.fr>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: Richard Cochran <rcochran@linutronix.de>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Peter Zijlstra <peterz@infradead.org>,
Cc: Sebastian Frias <sf84@laposte.net>
Cc: Thibaud Cornic <thibaud_cornic@sigmadesigns.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Link: http://lkml.kernel.org/r/1147ef90-7877-e4d2-bb2b-5c4fa8d3144b@free.fr
commit 4349bd775cc8fd75cb648e3a2036a690f497de5c upstream.
We were storing viewport relative coordinates for AVIVO/DCE display
engines. However, radeon_crtc_cursor_set2 and radeon_cursor_reset pass
radeon_crtc->cursor_x/y as the x/y parameters of
radeon_cursor_move_locked, which would break if the CRTC isn't located
at (0, 0).
Cc: stable@vger.kernel.org
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit f0b0faff78c2c2e8efe843de55405a1f0470b8c4 upstream.
Smatch complains about where the au8293_data is placed:
drivers/media/pci/cx23885/cx23885-dvb.c:2174 dvb_register() info: 'a8293_pdata' is not actually initialized (unreached code).
It is not actually expected to have such initialization at
switch {
foo = bar;
case:
Not really sure how gcc does that, but this is something that I would
expect that different compilers would do different things.
David Howells checked with the compiler people: it's not really expected to
initialise as expected.
So, move the initialization outside the switch(), making smatch to
shut up one warning.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 57e7c8cef224af166b8ec932b5e383641418c005 upstream.
When CONFIG_PCI_MSI is disabled, we get warnings about unused functions
in the vxge driver:
drivers/net/ethernet/neterion/vxge/vxge-main.c:2121:13: warning: 'adaptive_coalesce_tx_interrupts' defined but not used [-Wunused-function]
drivers/net/ethernet/neterion/vxge/vxge-main.c:2149:13: warning: 'adaptive_coalesce_rx_interrupts' defined but not used [-Wunused-function]
We could add another #ifdef here, but it's nicer to avoid those warnings
for good by converting the existing #ifdef to if(IS_ENABLED()), which has
the same effect but provides better compile-time coverage in general,
and lets the compiler understand better when the function is intentionally
unused.
commit 2f5281ba2a8feaf6f0aee93356f350855bb530fc upstream.
cpmac_start_xmit() used the max() macro on skb->len (an unsigned int)
and ETH_ZLEN (a signed int literal). This led to the following compiler
warning:
In file included from include/linux/list.h:8:0,
from include/linux/module.h:9,
from drivers/net/ethernet/ti/cpmac.c:19:
drivers/net/ethernet/ti/cpmac.c: In function 'cpmac_start_xmit':
include/linux/kernel.h:748:17: warning: comparison of distinct pointer
types lacks a cast
(void) (&_max1 == &_max2); \
drivers/net/ethernet/ti/cpmac.c:560:8: note: in expansion of macro 'max'
len = max(skb->len, ETH_ZLEN);
On top of this, it assigned the result of the max() macro to a signed
integer whilst all further uses of it result in it being cast to varying
widths of unsigned integer.
Fix this up by using max_t to ensure the comparison is performed as
unsigned integers, and for consistency change the type of the len
variable to unsigned int.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
commit 0335695dfa4df01edff5bb102b9a82a0668ee51e upstream.
The current_user_ns() macro currently returns &init_user_ns when user
namespaces are disabled, and that causes several warnings when building
with gcc-6.0 in code that compares the result of the macro to
&init_user_ns itself:
fs/xfs/xfs_ioctl.c: In function 'xfs_ioctl_setattr_check_projid':
fs/xfs/xfs_ioctl.c:1249:22: error: self-comparison always evaluates to true [-Werror=tautological-compare]
if (current_user_ns() == &init_user_ns)
This is a legitimate warning in principle, but here it isn't really
helpful, so I'm reprasing the definition in a way that shuts up the
warning. Apparently gcc only warns when comparing identical literals,
but it can figure out that the result of an inline function can be
identical to a constant expression in order to optimize a condition yet
not warn about the fact that the condition is known at compile time.
This is exactly what we want here, and it looks reasonable because we
generally prefer inline functions over macros anyway.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Yaowei Bai <baiyaowei@cmss.chinamobile.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit f6b1160eb27f990cc1c48b67a5f83cb63115284e upstream.
Arnd Bergmann pointed out that gcc-6 warns about passing negative signed
integer into swab16() due to the macro expansion of 'outw'.
It appears that the register map constants are causing the warnings.
Actually, it might just be the (1 << 15) ones...
Convert all the constants as suggested by checkpatch.pl:
CHECK: Prefer using the BIT macro
The BIT() macro will make all the constants explicitly 'unsigned', which
helps to avoid the warning.
Fix the, unsused, DT2821_CHANCSR_PRESLA() macro. The "Present List
Address" (PRESLA) bits in the CHANCSR register are read only. This
define was meant to extract the bits from the read value.
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
Tested-by: Arnd Bergmann <arnd@arndb.de>
commit 99e5cde5eae78bef95bfe7c16ccda87fb070149b upstream.
Make sure to drop any device reference taken by vio_find_node() when
adding and removing virtual I/O slots.
Fixes: 5eeb8c63a38f ("[PATCH] PCI Hotplug: rpaphp: Move VIO registration")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 82a301cb0ea2df8a5c88213094a01660067c7fb4 upstream.
Fixes: 90f5f7ad4f38("md: Wait for md_check_recovery before attempting device
removal.")
Reviewed-by: NeilBrown <neilb@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit 1803b9a52c4e5a5dbb8a27126f6bc06939359753 upstream.
The core AES cipher implementation that uses ARMv8 Crypto Extensions
instructions erroneously loads the round keys as 64-bit quantities,
which causes the algorithm to fail when built for big endian. In
addition, the key schedule generation routine fails to take endianness
into account as well, when loading the combining the input key with
the round constants. So fix both issues.
Fixes: 12ac3efe74f8 ("arm64/crypto: use crypto instructions to generate AES key schedule")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit caf4b9e2b326cc2a5005a5c557274306536ace61 upstream.
Emit the XTS tweak literal constants in the appropriate order for a
single 128-bit scalar literal load.
Fixes: 49788fe2a128 ("arm64/crypto: AES-ECB/CBC/CTR/XTS using ARMv8 NEON and Crypto Extensions")
commit ee71e5f1e7d25543ee63a80451871f8985b8d431 upstream.
The SHA1 digest is an array of 5 32-bit quantities, so we should refer
to them as such in order for this code to work correctly when built for
big endian. So replace 16 byte scalar loads and stores with 4x4 vector
ones where appropriate.
Fixes: 2c98833a42cd ("arm64/crypto: SHA-1 using ARMv8 Crypto Extensions")
commit a2c435cc99862fd3d165e1b66bf48ac72c839c62 upstream.
The AES implementation using pure NEON instructions relies on the generic
AES key schedule generation routines, which store the round keys as arrays
of 32-bit quantities stored in memory using native endianness. This means
we should refer to these round keys using 4x4 loads rather than 16x1 loads.
In addition, the ShiftRows tables are loading using a single scalar load,
which is also affected by endianness, so emit these tables in the correct
order depending on whether we are building for big endian or not.
commit 56e4e76c68fcb51547b5299e5b66a135935ff414 upstream.
The AES-CCM implementation that uses ARMv8 Crypto Extensions instructions
refers to the AES round keys as pairs of 64-bit quantities, which causes
failures when building the code for big endian. In addition, it byte swaps
the input counter unconditionally, while this is only required for little
endian builds. So fix both issues.
commit 58010fa6f71c9577922b22e46014b95a4ec80fa0 upstream.
The AES key schedule generation is mostly endian agnostic, with the
exception of the rotation and the incorporation of the round constant
at the start of each round. So implement a big endian specific version
of that part to make the whole routine big endian compatible.
Fixes: 86464859cc77 ("crypto: arm - AES in ECB/CBC/CTR/XTS modes using ARMv8 Crypto Extensions")
commit 9c433ad5083fd4a4a3c721d86cbfbd0b2a2326a5 upstream.
The GHASH key and digest are both pairs of 64-bit quantities, but the
GHASH code does not always refer to them as such, causing failures when
built for big endian. So replace the 16x1 loads and stores with 2x8 ones.
Fixes: b913a6404ce2 ("arm64/crypto: improve performance of GHASH algorithm")
commit 174122c39c369ed924d2608fc0be0171997ce800 upstream.
The SHA256 digest is an array of 8 32-bit quantities, so we should refer
big endian. So replace 16 byte scalar loads and stores with 4x32 vector
Fixes: 6ba6c74dfc6b ("arm64/crypto: SHA-224/SHA-256 using ARMv8 Crypto Extensions")
commit 9e6e7c74315095fd40f41003850690c711e44420 upstream.
We added some new locking but forgot to unlock on error.
Fixes: 57127645d79d ("s390/zcrypt: Introduce new SHA-512 based Pseudo Random Generator.")
commit 16652a936e96f5dae53c3fbd38a570497baadaa8 upstream.
We never set "ret" to RESULT_OK.
Fixes: 9f9c4180f88d ("mmc: mmc_test: add test for non-blocking transfers")
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
