2016-11-26Linux 4.4.35v4.4.35Greg Kroah-Hartman
2016-11-26netfilter: nft_dynset: fix element timeout for HZ != 1000Anders K. Pedersen
commit a8b1e36d0d1d6f51490e7adce35367ed6adb10e7 upstream. With HZ=100 element timeout in dynamic sets (i.e. flow tables) is 10 times higher than configured. Add proper conversion to/from jiffies, when interacting with userspace. I tested this on Linux 4.8.1, and it applies cleanly to current nf and nf-next trees. Fixes: 22fe54d5fefc ("netfilter: nf_tables: add support for dynamic set updates") Signed-off-by: Anders K. Pedersen <akp@cohaesio.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/cm: Mark stale CM id's whenever the mad agent was unregisteredMark Bloch
commit 9db0ff53cb9b43ed75bacd42a89c1a0ab048b2b0 upstream. When there is a CM id object that has port assigned to it, it means that the cm-id asked for the specific port that it should go by it, but if that port was removed (hot-unplug event) the cm-id was not updated. In order to fix that the port keeps a list of all the cm-id's that are planning to go by it, whenever the port is removed it marks all of them as invalid. This commit fixes a kernel panic which happens when running traffic between guests and we force reboot a guest mid traffic, it triggers a kernel panic: Call Trace: [<ffffffff815271fa>] ? panic+0xa7/0x16f [<ffffffff8152b534>] ? oops_end+0xe4/0x100 [<ffffffff8104a00b>] ? no_context+0xfb/0x260 [<ffffffff81084db2>] ? del_timer_sync+0x22/0x30 [<ffffffff8104a295>] ? __bad_area_nosemaphore+0x125/0x1e0 [<ffffffff81084240>] ? process_timeout+0x0/0x10 [<ffffffff8104a363>] ? bad_area_nosemaphore+0x13/0x20 [<ffffffff8104aabf>] ? __do_page_fault+0x31f/0x480 [<ffffffff81065df0>] ? default_wake_function+0x0/0x20 [<ffffffffa0752675>] ? free_msg+0x55/0x70 [mlx5_core] [<ffffffffa0753434>] ? cmd_exec+0x124/0x840 [mlx5_core] [<ffffffff8105a924>] ? find_busiest_group+0x244/0x9f0 [<ffffffff8152d45e>] ? do_page_fault+0x3e/0xa0 [<ffffffff8152a815>] ? page_fault+0x25/0x30 [<ffffffffa024da25>] ? cm_alloc_msg+0x35/0xc0 [ib_cm] [<ffffffffa024e821>] ? ib_send_cm_dreq+0xb1/0x1e0 [ib_cm] [<ffffffffa024f836>] ? cm_destroy_id+0x176/0x320 [ib_cm] [<ffffffffa024fb00>] ? ib_destroy_cm_id+0x10/0x20 [ib_cm] [<ffffffffa034f527>] ? ipoib_cm_free_rx_reap_list+0xa7/0x110 [ib_ipoib] [<ffffffffa034f590>] ? ipoib_cm_rx_reap+0x0/0x20 [ib_ipoib] [<ffffffffa034f5a5>] ? ipoib_cm_rx_reap+0x15/0x20 [ib_ipoib] [<ffffffff81094d20>] ? worker_thread+0x170/0x2a0 [<ffffffff8109b2a0>] ? autoremove_wake_function+0x0/0x40 [<ffffffff81094bb0>] ? worker_thread+0x0/0x2a0 [<ffffffff8109aef6>] ? kthread+0x96/0xa0 [<ffffffff8100c20a>] ? child_rip+0xa/0x20 [<ffffffff8109ae60>] ? kthread+0x0/0xa0 [<ffffffff8100c200>] ? child_rip+0x0/0x20 Fixes: a977049dacde ("[PATCH] IB: Add the kernel CM implementation") Signed-off-by: Mark Bloch <markb@mellanox.com> Signed-off-by: Erez Shitrit <erezsh@mellanox.com> Reviewed-by: Maor Gottlieb <maorg@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/uverbs: Fix leak of XRC target QPsTariq Toukan
commit 5b810a242c28e1d8d64d718cebe75b79d86a0b2d upstream. The real QP is destroyed in case of the ref count reaches zero, but for XRC target QPs this call was missed and caused to QP leaks. Let's call to destroy for all flows. Fixes: 0e0ec7e0638e ('RDMA/core: Export ib_open_qp() to share XRC...') Signed-off-by: Tariq Toukan <tariqt@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/core: Avoid unsigned int overflow in sg_alloc_tableMark Bloch
commit 3c7ba5760ab8eedec01159b267bb9bfcffe522ac upstream. sg_alloc_table gets unsigned int as parameter while the driver returns it as size_t. Check npages isn't greater than maximum unsigned int. Fixes: eeb8461e36c9 ("IB: Refactor umem to use linear SG table") Signed-off-by: Mark Bloch <markb@mellanox.com> Signed-off-by: Maor Gottlieb <maorg@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/mlx5: Fix fatal error dispatchingEli Cohen
commit dbaaff2a2caa03d472b5cc53a3fbfd415c97dc26 upstream. When an internal error condition is detected, make sure to set the device inactive after dispatching the event so ULPs can get a notification of this event. Fixes: e126ba97dba9 ('mlx5: Add driver for Mellanox Connect-IB adapters') Signed-off-by: Eli Cohen <eli@mellanox.com> Signed-off-by: Maor Gottlieb <maorg@mellanox.com> Reviewed-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/mlx5: Use cache line size to select CQE strideDaniel Jurgens
commit 16b0e0695a73b68d8ca40288c8f9614ef208917b upstream. When creating kernel CQs use 128B CQE stride if the cache line size is 128B, 64B otherwise. This prevents multiple CQEs from residing in a 128B cache line, which can cause retries when there are concurrent read and writes in one cache line. Tested with IPoIB on PPC64, saw ~5% throughput improvement. Fixes: e126ba97dba9 ('mlx5: Add driver for Mellanox Connect-IB adapters') Signed-off-by: Daniel Jurgens <danielj@mellanox.com> Signed-off-by: Maor Gottlieb <maorg@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/mlx4: Fix create CQ error flowMatan Barak
commit 593ff73bcfdc79f79a8a0df55504f75ad3e5d1a9 upstream. Currently, if ib_copy_to_udata fails, the CQ won't be deleted from the radix tree and the HW (HW2SW). Fixes: 225c7b1feef1 ('IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adapters') Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Daniel Jurgens <danielj@mellanox.com> Reviewed-by: Mark Bloch <markb@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26IB/mlx4: Check gid_index return valueDaniel Jurgens
commit 37995116fecfce2b61ee3da6e73b3e394c6818f9 upstream. Check the returned GID index value and return an error if it is invalid. Fixes: 5070cd2239bd ('IB/mlx4: Replace mechanism for RoCE GID management') Signed-off-by: Daniel Jurgens <danielj@mellanox.com> Reviewed-by: Mark Bloch <markb@mellanox.com> Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26PM / sleep: don't suspend parent when async child suspend_{noirq, late} failsBrian Norris
commit 6f75c3fd56daf547d684127a7f83c283c3c160d1 upstream. Consider two devices, A and B, where B is a child of A, and B utilizes asynchronous suspend (it does not matter whether A is sync or async). If B fails to suspend_noirq() or suspend_late(), or is interrupted by a wakeup (pm_wakeup_pending()), then it aborts and sets the async_error variable. However, device A does not (immediately) check the async_error variable; it may continue to run its own suspend_noirq()/suspend_late() callback. This is bad. We can resolve this problem by doing our error and wakeup checking (particularly, for the async_error flag) after waiting for children to suspend, instead of before. This also helps align the logic for the noirq and late suspend cases with the logic in __device_suspend(). It's easy to observe this erroneous behavior by, for example, forcing a device to sleep a bit in its suspend_noirq() (to ensure the parent is waiting for the child to complete), then return an error, and watch the parent suspend_noirq() still get called. (Or similarly, fake a wakeup event at the right (or is it wrong?) time.) Fixes: de377b397272 (PM / sleep: Asynchronous threads for suspend_late) Fixes: 28b6fd6e3779 (PM / sleep: Asynchronous threads for suspend_noirq) Reported-by: Jeffy Chen <jeffy.chen@rock-chips.com> Signed-off-by: Brian Norris <briannorris@chromium.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26PM / sleep: fix device reference leak in test_suspendJohan Hovold
commit ceb75787bc75d0a7b88519ab8a68067ac690f55a upstream. Make sure to drop the reference taken by class_find_device() after opening the RTC device. Fixes: 77437fd4e61f (pm: boot time suspend selftest) Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26uwb: fix device reference leaksJohan Hovold
commit d6124b409ca33c100170ffde51cd8dff761454a1 upstream. This subsystem consistently fails to drop the device reference taken by class_find_device(). Note that some of these lookup functions already take a reference to the returned data, while others claim no reference is needed (or does not seem need one). Fixes: 183b9b592a62 ("uwb: add the UWB stack (core files)") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26mfd: core: Fix device reference leak in mfd_clone_cellJohan Hovold
commit 722f191080de641f023feaa7d5648caf377844f5 upstream. Make sure to drop the reference taken by bus_find_device_by_name() before returning from mfd_clone_cell(). Fixes: a9bbba996302 ("mfd: add platform_device sharing support for mfd") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26iwlwifi: pcie: fix SPLC structure parsingLuca Coelho
commit e0d9727c111a5917a1184c71c1a8e6f78c7fc41d upstream. The SPLC data parsing is too restrictive and was not trying find the correct element for WiFi. This causes problems with some BIOSes where the SPLC method exists, but doesn't have a WiFi entry on the first element of the list. The domain type values are also incorrect according to the specification. Fix this by complying with the actual specification. Additionally, replace all occurrences of SPLX to SPLC, since SPLX is only a structure internal to the ACPI tables, and may not even exist. Fixes: bcb079a14d75 ("iwlwifi: pcie: retrieve and parse ACPI power limitations") Reported-by: Chris Rorvick <chris@rorvick.com> Tested-by: Paul Bolle <pebolle@tiscali.nl> Tested-by: Chris Rorvick <chris@rorvick.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26rtc: omap: Fix selecting external oscLokesh Vutla
commit 3984903a2e3906d3def220e688040ce93368200a upstream. RTC can be clocked from an external 32KHz oscillator, or from the Peripheral PLL. The RTC has an internal oscillator buffer to support direct operation with a crystal. ---------------------------------------- | Device --------- | | | | | | | RTCSS | | | --------- | | | OSC |<------| RTC | | | | |------>| OSC |--- | | | | -------- | | | | | ----|clk | | | -------- | | | | | | PRCM |--- | | | | -------- -------- | ---------------------------------------- The RTC functional clock is sourced by default from the clock derived from the Peripheral PLL. In order to select source as external osc clk the following changes needs to be done: - Enable the RTC OSC (RTC_OSC_REG[4]OSC32K_GZ = 0) - Enable the clock mux(RTC_OSC_REG[6]K32CLK_EN = 1) - Select the external clock source (RTC_OSC_REG[3]32KCLK_SEL = 1) Fixes: 399cf0f63f6f2 ("rtc: omap: Add external clock enabling support") Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26clk: mmp: mmp2: fix return value check in mmp2_clk_init()Wei Yongjun
commit a29e52a6e66f4c0c895e7083e4bad2e7957f1fb5 upstream. Fix the retrn value check which testing the wrong variable in mmp2_clk_init(). Fixes: 1ec770d92a62 ("clk: mmp: add mmp2 DT support for clock driver") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26clk: mmp: pxa168: fix return value check in pxa168_clk_init()Wei Yongjun
commit deab07261d54b4db7b627d38e0efac97f176c6d6 upstream. Fix the retrn value check which testing the wrong variable in pxa168_clk_init(). Fixes: ab08aefcd12d ("clk: mmp: add pxa168 DT support for clock driver") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26clk: mmp: pxa910: fix return value check in pxa910_clk_init()Wei Yongjun
commit 10f2bfb092e3b49000526c02cfe8b2abbbdbb752 upstream. Fix the retrn value check which testing the wrong variable in pxa910_clk_init(). Fixes: 2bc61da9f7ff ("clk: mmp: add pxa910 DT support for clock driver") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26drm/amdgpu: Attach exclusive fence to prime exported bo's. (v5)Mario Kleiner
commit 8e94a46c1770884166b31adc99eba7da65a446a7 upstream. External clients which import our bo's wait only for exclusive dmabuf-fences, not on shared ones, ditto for bo's which we import from external providers and write to. Therefore attach exclusive fences on prime shared buffers if our exported buffer gets imported by an external client, or if we import a buffer from an external exporter. See discussion in thread: https://lists.freedesktop.org/archives/dri-devel/2016-October/122370.html Prime export tested on Intel iGPU + AMD Tonga dGPU as DRI3/Present Prime render offload, and with the Tonga standalone as primary gpu. v2: Add a wait for all shared fences before prime export, as suggested by Christian Koenig. v3: - Mark buffer prime_exported in amdgpu_gem_prime_pin, so we only use the exclusive fence when exporting a bo to external clients like a separate iGPU, but not when exporting/importing from/to ourselves as part of regular DRI3 fd passing. - Propagate failure of reservation_object_wait_rcu back to caller. v4: - Switch to a prime_shared_count counter instead of a flag, which gets in/decremented on prime_pin/unpin, so we can switch back to shared fences if all clients detach from our exported bo. - Also switch to exclusive fence for prime imported bo's. v5: - Drop lret, instead use int ret -> long ret, as proposed by Christian. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=95472 Tested-by: Mike Lothian <mike@fireburn.co.uk> (v1) Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com> Reviewed-by: Christian König <christian.koenig@amd.com>. Cc: Christian König <christian.koenig@amd.com> Cc: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26crypto: caam - do not register AES-XTS mode on LP unitsSven Ebenfeld
commit 83d2c9a9c17b1e9f23a3a0c24c03cd18e4b02520 upstream. When using AES-XTS on a Wandboard, we receive a Mode error: caam_jr 2102000.jr1: 20001311: CCB: desc idx 19: AES: Mode error. According to the Security Reference Manual, the Low Power AES units of the i.MX6 do not support the XTS mode. Therefore we must not register XTS implementations in the Crypto API. Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Fixes: c6415a6016bf "crypto: caam - add support for acipher xts(aes)" Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-11-26ext4: sanity check the block and cluster size at mount timeTheodore Ts'o
commit 8cdf3372fe8368f56315e66bea9f35053c418093 upstream. If the block size or cluster size is insane, reject the mount. This is important for security reasons (although we shouldn't be just depending on this check). Ref: http://www.securityfocus.com/archive/1/539661 Ref: https://bugzilla.redhat.com/show_bug.cgi?id=1332506 Reported-by: Borislav Petkov <bp@alien8.de> Reported-by: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26kbuild: Steal gcc's pie from the very beginningBorislav Petkov
commit c6a385539175ebc603da53aafb7753d39089f32e upstream. So Sebastian turned off the PIE for kernel builds but that was too late - Kbuild.include already uses KBUILD_CFLAGS and trying to disable gcc options with, say cc-disable-warning, fails: gcc -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs ... -Wno-sign-compare -fno-asynchronous-unwind-tables -Wframe-address -c -x c /dev/null -o .31392.tmp /dev/null:1:0: error: code model kernel does not support PIC mode because that returns an error and we can't disable the warning. For example in this case: KBUILD_CFLAGS += $(call cc-disable-warning,frame-address,) which leads to gcc issuing all those warnings again. So let's turn off PIE/PIC at the earliest possible moment, when we declare KBUILD_CFLAGS so that cc-disable-warning picks it up too. Also, we need the $(call cc-option ...) because -fno-PIE is supported since gcc v3.4 and our lowest supported gcc version is 3.2 right now. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26x86/kexec: add -fno-PIESebastian Andrzej Siewior
commit 90944e40ba1838de4b2a9290cf273f9d76bd3bdd upstream. If the gcc is configured to do -fPIE by default then the build aborts later with: | Unsupported relocation type: unknown type rel type name (29) Tagging it stable so it is possible to compile recent stable kernels as well. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26scripts/has-stack-protector: add -fno-PIESebastian Andrzej Siewior
commit 82031ea29e454b574bc6f49a33683a693ca5d907 upstream. Adding -no-PIE to the fstack protector check. -no-PIE was introduced before -fstack-protector so there is no need for a runtime check. Without it the build stops: |Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong available but compiler is broken due to -mcmodel=kernel + -fPIE if -fPIE is enabled by default. Tagging it stable so it is possible to compile recent stable kernels as well. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26kbuild: add -fno-PIESebastian Andrzej Siewior
commit 8ae94224c9d72fc4d9aaac93b2d7833cf46d7141 upstream. Debian started to build the gcc with -fPIE by default so the kernel build ends before it starts properly with: |kernel/bounds.c:1:0: error: code model kernel does not support PIC mode Also add to KBUILD_AFLAGS due to: |gcc -Wp,-MD,arch/x86/entry/vdso/vdso32/.note.o.d … -mfentry -DCC_USING_FENTRY … vdso/vdso32/note.S |arch/x86/entry/vdso/vdso32/note.S:1:0: sorry, unimplemented: -mfentry isn’t supported for 32-bit in combination with -fpic Tagging it stable so it is possible to compile recent stable kernels as well. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26i2c: mux: fix up dependenciesLinus Walleij
commit 93d710a65ef02fb7fd48ae207e78f460bd7a6089 upstream. We get the following build error from UM Linux after adding an entry to drivers/iio/gyro/Kconfig that issues "select I2C_MUX": ERROR: "devm_ioremap_resource" [drivers/i2c/muxes/i2c-mux-reg.ko] undefined! ERROR: "of_address_to_resource" [drivers/i2c/muxes/i2c-mux-reg.ko] undefined! It appears that the I2C mux core code depends on HAS_IOMEM for historical reasons, while CONFIG_I2C_MUX_REG does *not* have a direct dependency on HAS_IOMEM. This creates a situation where a allyesconfig or allmodconfig for UM Linux will select I2C_MUX, and will implicitly enable I2C_MUX_REG as well, and the compilation will fail for the register driver. Fix this up by making I2C_MUX_REG depend on HAS_IOMEM and removing the dependency from I2C_MUX. Reported-by: kbuild test robot <fengguang.wu@intel.com> Reported-by: Jonathan Cameron <jic23@jic23.retrosnub.co.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Peter Rosin <peda@axentia.se> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26can: bcm: fix warning in bcm_connect/proc_registerOliver Hartkopp
commit deb507f91f1adbf64317ad24ac46c56eeccfb754 upstream. Andrey Konovalov reported an issue with proc_register in bcm.c. As suggested by Cong Wang this patch adds a lock_sock() protection and a check for unsuccessful proc_create_data() in bcm_connect(). Reference: http://marc.info/?l=linux-netdev&m=147732648731237 Reported-by: Andrey Konovalov <andreyknvl@google.com> Suggested-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26mfd: intel-lpss: Do not put device in reset state on suspendAzhar Shaikh
commit 274e43edcda6f709aa67e436b3123e45a6270923 upstream. Commit 41a3da2b8e163 ("mfd: intel-lpss: Save register context on suspend") saved the register context while going to suspend and also put the device in reset state. Due to the resetting of device, system cannot enter S3/S0ix states when no_console_suspend flag is enabled. The system and serial console both hang. The resetting of device is not needed while going to suspend. Hence remove this code. Fixes: 41a3da2b8e163 ("mfd: intel-lpss: Save register context on suspend") Signed-off-by: Azhar Shaikh <azhar.shaikh@intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26fuse: fix fuse_write_end() if zero bytes were copiedMiklos Szeredi
commit 59c3b76cc61d1d676f965c192cc7969aa5cb2744 upstream. If pos is at the beginning of a page and copied is zero then page is not zeroed but is marked uptodate. Fix by skipping everything except unlock/put of page if zero bytes were copied. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Fixes: 6b12c1b37e55 ("fuse: Implement write_begin/write_end callbacks") Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26KVM: Disable irq while unregistering user notifierIgnacio Alvarado
commit 1650b4ebc99da4c137bfbfc531be4a2405f951dd upstream. Function user_notifier_unregister should be called only once for each registered user notifier. Function kvm_arch_hardware_disable can be executed from an IPI context which could cause a race condition with a VCPU returning to user mode and attempting to unregister the notifier. Signed-off-by: Ignacio Alvarado <ikalvarado@google.com> Fixes: 18863bdd60f8 ("KVM: x86 shared msr infrastructure") Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26KVM: x86: fix missed SRCU usage in kvm_lapic_set_vapic_addrPaolo Bonzini
commit 7301d6abaea926d685832f7e1f0c37dd206b01f4 upstream. Reported by syzkaller: [ INFO: suspicious RCU usage. ] 4.9.0-rc4+ #47 Not tainted ------------------------------- ./include/linux/kvm_host.h:536 suspicious rcu_dereference_check() usage! stack backtrace: CPU: 1 PID: 6679 Comm: syz-executor Not tainted 4.9.0-rc4+ #47 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 ffff880039e2f6d0 ffffffff81c2e46b ffff88003e3a5b40 0000000000000000 0000000000000001 ffffffff83215600 ffff880039e2f700 ffffffff81334ea9 ffffc9000730b000 0000000000000004 ffff88003c4f8420 ffff88003d3f8000 Call Trace: [< inline >] __dump_stack lib/dump_stack.c:15 [<ffffffff81c2e46b>] dump_stack+0xb3/0x118 lib/dump_stack.c:51 [<ffffffff81334ea9>] lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4445 [< inline >] __kvm_memslots include/linux/kvm_host.h:534 [< inline >] kvm_memslots include/linux/kvm_host.h:541 [<ffffffff8105d6ae>] kvm_gfn_to_hva_cache_init+0xa1e/0xce0 virt/kvm/kvm_main.c:1941 [<ffffffff8112685d>] kvm_lapic_set_vapic_addr+0xed/0x140 arch/x86/kvm/lapic.c:2217 Reported-by: Dmitry Vyukov <dvyukov@google.com> Fixes: fda4e2e85589191b123d31cdc21fd33ee70f50fd Cc: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: David Hildenbrand <david@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26x86/cpu/AMD: Fix cpu_llc_id for AMD Fam17h systemsYazen Ghannam
commit b0b6e86846093c5f8820386bc01515f857dd8faa upstream. cpu_llc_id (Last Level Cache ID) derivation on AMD Fam17h has an underflow bug when extracting the socket_id value. It starts from 0 so subtracting 1 from it will result in an invalid value. This breaks scheduling topology later on since the cpu_llc_id will be incorrect. For example, the the cpu_llc_id of the *other* CPU in the loops in set_cpu_sibling_map() underflows and we're generating the funniest thread_siblings masks and then when I run 8 threads of nbench, they get spread around the LLC domains in a very strange pattern which doesn't give you the normal scheduling spread one would expect for performance. Other things like EDAC use cpu_llc_id so they will be b0rked too. So, the APIC ID is preset in APICx020 for bits 3 and above: they contain the core complex, node and socket IDs. The LLC is at the core complex level so we can find a unique cpu_llc_id by right shifting the APICID by 3 because then the least significant bit will be the Core Complex ID. Tested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com> [ Cleaned up and extended the commit message. ] Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Aravind Gopalakrishnan <aravindksg.lkml@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Fixes: 3849e91f571d ("x86/AMD: Fix last level cache topology for AMD Fam17h systems") Link: http://lkml.kernel.org/r/20161108083506.rvqb5h4chrcptj7d@pd.tnic Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21Linux 4.4.34v4.4.34Greg Kroah-Hartman
2016-11-21sparc64: Delete now unused user copy fixup functions.David S. Miller
[ Upstream commit 0fd0ff01d4c3c01e7fe69b762ee1a13236639acc ] Now that all of the user copy routines are converted to return accurate residual lengths when an exception occurs, we no longer need the broken fixup routines. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Delete now unused user copy assembler helpers.David S. Miller
[ Upstream commit 614da3d9685b67917cab48c8452fd8bf93de0867 ] All of __ret{,l}_mone{_asi,_fp,_asi_fpu} are now unused. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert U3copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit ee841d0aff649164080e445e84885015958d8ff4 ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert NG2copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit e93704e4464fdc191f73fce35129c18de2ebf95d ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert NGcopy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit 7ae3aaf53f1695877ccd5ebbc49ea65991e41f1e ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert NG4copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit 95707704800988093a9b9a27e0f2f67f5b4bf2fa ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert U1copy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit cb736fdbb208eb3420f1a2eb2bfc024a6e9dcada ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert GENcopy_{from,to}_user to accurate exception reporting.David S. Miller
[ Upstream commit d0796b555ba60c22eb41ae39a8362156cb08eee9 ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Convert copy_in_user to accurate exception reporting.David S. Miller
[ Upstream commit 0096ac9f47b1a2e851b3165d44065d18e5f13d58 ] Report the exact number of bytes which have not been successfully copied when an exception occurs, using the running remaining length. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Prepare to move to more saner user copy exception handling.David S. Miller
[ Upstream commit 83a17d2661674d8c198adc0e183418f72aabab79 ] The fixup helper function mechanism for handling user copy fault handling is not %100 accurrate, and can never be made so. We are going to transition the code to return the running return return length, which is always kept track in one or more registers of each of these routines. In order to convert them one by one, we have to allow the existing behavior to continue functioning. Therefore make all the copy code that wants the fixup helper to be used return negative one. After all of the user copy routines have been converted, this logic and the fixup helpers themselves can be removed completely. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Delete __ret_efault.David S. Miller
[ Upstream commit aa95ce361ed95c72ac42dcb315166bce5cf1a014 ] It is completely unused. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Handle extremely large kernel TLB range flushes more gracefully.David S. Miller
[ Upstream commit a74ad5e660a9ee1d071665e7e8ad822784a2dc7f ] When the vmalloc area gets fragmented, and because the firmware mapping area sits between where modules live and the vmalloc area, we can sometimes receive requests for enormous kernel TLB range flushes. When this happens the cpu just spins flushing billions of pages and this triggers the NMI watchdog and other problems. We took care of this on the TSB side by doing a linear scan of the table once we pass a certain threshold. Do something similar for the TLB flush, however we are limited by the TLB flush facilities provided by the different chip variants. First of all we use an (mostly arbitrary) cut-off of 256K which is about 32 pages. This can be tuned in the future. The huge range code path for each chip works as follows: 1) On spitfire we flush all non-locked TLB entries using diagnostic acceses. 2) On cheetah we use the "flush all" TLB flush. 3) On sun4v/hypervisor we do a TLB context flush on context 0, which unlike previous chips does not remove "permanent" or locked entries. We could probably do something better on spitfire, such as limiting the flush to kernel TLB entries or even doing range comparisons. However that probably isn't worth it since those chips are old and the TLB only had 64 entries. Reported-by: James Clarke <jrtc27@jrtc27.com> Tested-by: James Clarke <jrtc27@jrtc27.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Fix illegal relative branches in hypervisor patched TLB cross-call ↵David S. Miller
code. [ Upstream commit a236441bb69723032db94128761a469030c3fe6d ] Just like the non-cross-call TLB flush handlers, the cross-call ones need to avoid doing PC-relative branches outside of their code blocks. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Fix instruction count in comment for __hypervisor_flush_tlb_pending.David S. Miller
[ Upstream commit 830cda3f9855ff092b0e9610346d110846fc497c ] Noticed by James Clarke. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Fix illegal relative branches in hypervisor patched TLB code.David S. Miller
[ Upstream commit b429ae4d5b565a71dfffd759dfcd4f6c093ced94 ] When we copy code over to patch another piece of code, we can only use PC-relative branches that target code within that piece of code. Such PC-relative branches cannot be made to external symbols because the patch moves the location of the code and thus modifies the relative address of external symbols. Use an absolute jmpl to fix this problem. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc64: Handle extremely large kernel TSB range flushes sanely.David S. Miller
[ Upstream commit 849c498766060a16aad5b0e0d03206726e7d2fa4 ] If the number of pages we are flushing is more than twice the number of entries in the TSB, just scan the TSB table for matches rather than probing each and every page in the range. Based upon a patch and report by James Clarke. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21sparc: Handle negative offsets in arch_jump_label_transformJames Clarke
[ Upstream commit 9d9fa230206a3aea6ef451646c97122f04777983 ] Additionally, if the offset will overflow the immediate for a ba,pt instruction, fall back on a standard ba to get an extra 3 bits. Signed-off-by: James Clarke <jrtc27@jrtc27.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
