commit 9ba63e3cc849cdaf3b675c47cc51fe35419e5117 upstream.
Since its initial commit, the driver is buggy for multiple interrupts
handling. The translation from the former lubbock.c file was not
complete, and might stall all interrupt handling when multiple
interrupts occur.
This is especially true when inside the interrupt handler and if a new
interrupt comes and is not handled, leaving the output line still held,
and not creating a transition as the GPIO block behind would expect to
trigger another cplds_irq_handler() call.
For the record, the hardware is working as follows.
The interrupt mechanism relies on :
- one status register
- one mask register
Let's suppose the input irq lines are called :
- i_sa1111
- i_lan91x
- i_mmc_cd
Let's suppose the status register for each irq line is called :
- status_sa1111
- status_lan91x
- status_mmc_cd
Let's suppose the interrupt mask for each irq line is called :
- irqen_sa1111
- irqen_lan91x
- irqen_mmc_cd
Let's suppose the output irq line, connected to GPIO0 is called :
- o_gpio0
The behavior is as follows :
- o_gpio0 = not((status_sa1111 & irqen_sa1111) |
(status_lan91x & irqen_lan91x) |
(status_mmc_cd & irqen_mmc_cd))
=> this is a N-to-1 NOR gate and multiple AND gates
- irqen_* is exactly as programmed by a write to the FPGA
- status_* behavior is governed by a bi-stable D flip-flop
=> on next FPGA clock :
- if i_xxx is high, status_xxx becomes 1
- if i_xxx is low, status_xxx remains as it is
- if software sets status_xxx to 0, the D flip-flop is reset
=> status_xxx becomes 0
=> on next FPGA clock cycle, if i_xxx is high, status_xxx becomes
1 again
Fixes: fc9e38c0f4d3 ("ARM: pxa: lubbock: use new pxa_cplds driver")
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 11b7e154b132232535befe51c55db048069c8461 upstream.
When we merge two contiguous partitions whose signatures are marked
NVRAM_SIG_FREE, We need update prev's length and checksum, then write it
to nvram, not cur's. So lets fix this mistake now.
Also use memset instead of strncpy to set the partition's name. It's
more readable if we want to fill up with duplicate chars .
Fixes: fa2b4e54d41f ("powerpc/nvram: Improve partition removal")
Signed-off-by: Pan Xinhui <xinhui.pan@linux.vnet.ibm.com>
commit 0d667f72b2a20bbac72bec0ab11467fc70bb0f1f upstream.
In _scsih_io_done() we test if the ioc->logging_level does _not_ have
the MPT_DEBUG_REPLY bit set and if it hasn't we print the debug
messages. This unfortunately is the wrong way around.
Note, the actual bug is older than af0094115 but this commit removed the
CONFIG_SCSI_MPT3SAS_LOGGING Kconfig option which hid the bug.
Fixes: af0094115 'mpt2sas, mpt3sas: Remove SCSI_MPTXSAS_LOGGING entry from Kconfig'
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Chaitra P B <chaitra.basappa@broadcom.com>
commit 432746f8e0b6a82ba832b771afe31abd51af6752 upstream.
When we call symbol__fixup_duplicate() we use algorithms to pick the
"best" symbols for cases where there are various functions/aliases to an
address, and those check zero size symbols, which, before calling
symbol__fixup_end() are _all_ symbols in a just parsed kallsyms file.
So first fixup the end, then fixup the duplicates.
Found while trying to figure out why 'perf test vmlinux' failed, see the
output of 'perf test -v vmlinux' to see cases where the symbols picked
as best for vmlinux don't match the ones picked for kallsyms.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: 694bf407b061 ("perf symbols: Add some heuristics for choosing the best duplicate symbol")
Link: http://lkml.kernel.org/n/tip-rxqvdgr0mqjdxee0kf8i2ufn@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit c97b40e4d15f13a36cd037d598e45cbe9e1e5757 upstream.
We can allow aliases to be kept, but we were checking this just when
loading vmlinux files, be consistent, do it for any symbol table loading
code that calls symbol__fixup_duplicate() by making this function check
.allow_aliases instead.
Fixes: 680d926a8cb0 ("perf symbols: Allow symbol alias when loading map for symbol name")
Link: http://lkml.kernel.org/n/tip-z0avp0s6cfjckc4xj3pdfjdz@git.kernel.org
commit d9ea48bc4e7cc297ca1073fa3f90ed80d964b7b4 upstream.
Milian reported that the event group on TUI shows duplicated overhead.
This was due to a bug on calculating hpp->buf position. The
hpp_advance() was called from __hpp__slsmg_color_printf() on TUI but
it's already called from the hpp__call_print_fn macro in __hpp__fmt().
The end result is that the print function returns number of bytes it
printed but the buffer advanced twice of the length.
This is generally not a problem since it doesn't need to access the
buffer again. But with event group, overhead needs to be printed
multiple times and hist_entry__snprintf_alignment() tries to fill the
space with buffer after it printed. So it (brokenly) showed the last
overhead again.
The bug was there from the beginning, but I think it's only revealed
when the alignment function was added.
Reported-by: Milian Wolff <milian.wolff@kdab.com>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 89fee7094323 ("perf hists: Do column alignment on the format iterator")
Link: http://lkml.kernel.org/r/20160912061958.16656-2-namhyung@kernel.org
commit 2cf9a57811bddb6fa6b0f8d7376da164d5534813 upstream.
clk-divider uses clk_readl()/clk_writel() everywhere, except in
clk_divider_round_rate(), where plain readl() is used. Change this to
clk_readl(), as it makes a difference on powerpc.
Fixes: e6d5e7d90be92cee ("clk-divider: Fix READ_ONLY when divider > 1")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 8964193f6bfda5c4cf14eedb7e94892c1f1c34f0 upstream.
The offset of Core Cluster clock control/status register
on cluster group V3 version is different from others, and
should be plus 0x70000.
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
Reviewed-by: Scott Wood <oss@buserror.net>
Fixes: 9e19ca2f627e ("clk: qoriq: Add ls2080a support.")
commit 6cd997db911f28f2510b771691270c52b63ed2e6 upstream.
con3270 contains an optimisation that reduces the amount of data to be
transmitted to the 3270 terminal by putting a Repeat to Address (RA)
order into the data stream. The RA order itself takes up space, so
con3270 only uses it if there's enough space left in the line
buffer. Otherwise it just pads out the line manually.
For lines that were _just_ short enough that the RA order still fit in
the line buffer, the line was instead padded with an insufficient
amount of spaces. This was caused by examining the size of the
allocated line buffer rather than the length of the string to be
displayed.
For con3270_cline_end(), we just compare against the line length. For
con3270_update_string() however that isn't available anymore, so we
check whether the Repeat to Address order is present.
Fixes: f51320a5 ("[PATCH] s390: new 3270 driver.") (tglx/history.git)
Tested-by: Jing Liu <liujbjl@linux.vnet.ibm.com>
Tested-by: Yang Chen <bjcyang@linux.vnet.ibm.com>
Signed-off-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
commit c14f2aac7aa147861793eed9f41f91dd530f0be1 upstream.
For lines too long to include the RA order, one byte was left
uninitialised. This was caused by an off-by-one bug in the loop that
pads out the line. Since the buffer is allocated from a common pool,
the single byte left uninitialised contained some previous buffer
content. Usually this was just a space or some character (which can
result in clutter but is otherwise harmless). Sometimes, however, it
was a Repeat to Address order, messing up the entire screen layout and
causing the display to send the entire buffer content on every
keystroke.
Reported-by: Liu Jing <liujbjl@linux.vnet.ibm.com>
commit d53c51f26145657aa7c55fa396f93677e613548d upstream.
Since commit 9f3d6d7 chsc_get_channel_measurement_chars is called with
interrupts disabled during resume from hibernate. Since this function
used spin_unlock_irq, interrupts have been enabled accidentally. Fix
this by using the irqsave variant.
Since we can't guarantee the IRQ-enablement state for all (future/
external) callers, change the locking in related functions to prevent
similar bugs in the future.
Fixes: 9f3d6d7 ("s390/cio: update measurement characteristics")
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
commit 86c7e6836479c4045a9a81ed5ea76c51d719f9c1 upstream.
A workaround for a warning introduced a use of the NO_IRQ
macro that should have been gone for a long time.
It is clear from the code that the value cannot actually
be used, but apparently there was a configuration at
some point that caused a warning, so instead of just
reverting that patch, this rearranges the code in a way that
the warning cannot reappear.
Fixes: 6ef41cf6f721 ("dmaengine :ipu: change ipu_irq_handler() to remove compile warning")
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 0610735928ee47870e083d5901caa371089216f1 upstream.
bq->charger is initialized in bq24257_power_supply_init.
Therefore, bq24257_power_supply_init should be called before the
registration of the IRQ handler bq24257_irq_handler_thread that calls
power_supply_changed(bq->charger).
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Cc: Aurelien Chanot <chanot.a@gmail.com>
Cc: Andreas Dannenberg <dannenberg@ti.com>
Cc: Sebastian Reichel <sre@kernel.org>
Fixes: 2219a935963e ("power_supply: Add TI BQ24257 charger driver")
Signed-off-by: Sebastian Reichel <sre@kernel.org>
commit 1335a9516d3d52f157ad87456efdd8dc9ae1747b upstream.
Commit fadbe0cd5292851608e2e01b91d9295fa287b9fe ("staging: rtl8188eu:
Remove rtw_zmalloc(), wrapper for kzalloc()") changed all allocation
calls to be GFP_KERNEL even though the original wrapper was testing
to determine if the caller was in atomic mode. Most of the mistakes
were corrected with commit 33dc85c3c667209c930b2dac5ccbc2a365e06b7a
("staging: r8188eu: Fix scheduling while atomic error introduced in
commit fadbe0cd"); however, two kzalloc calls were missed as the
call only happens when the driver is shutting down.
Fixes: fadbe0cd5292851608e2e01b91d9295fa287b9fe ("staging: rtl8188eu: Remove rtw_zmalloc(), wrapper for kzalloc()")
Cc: navin patidar <navin.patidar@gmail.com>
commit a3930ed060df4ccf2a06cf0b68738dec3e6ff89a upstream.
Commit d88429a695a4 ("ASoC: dapm: Add output driver widget") added
the snd_soc_dapm_out_drv ID for the output driver widget, which is
the same as the PGA widget, with a later power sequence number.
Commit 19a2557b76d6 ("ASoC: dapm: Add kcontrol support for PGAs")
then added kcontrol support for PGA widgets, but failed to account
for output driver widgets. Attempts to use kcontrols with output
driver widgets result in silent failures, with the developer having
little idea about what went on.
Add snd_soc_dapm_out_drv to the switch/case block under snd_soc_dapm_pga
in dapm_create_or_share_kcontrol, since they are essentially the same.
Fixes: 19a2557b76d6 (ASoC: dapm: Add kcontrol support for PGAs)
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 071133a209354f39d4e5785d5a6a390e03241841 upstream.
The value for the second channel in _ENUM_DOUBLE (double channel) MUXs
is not correctly updated, due to using the wrong bit shift.
Use the correct bit shift, so both channels toggle together.
Fixes: 3727b4968453 (ASoC: dapm: Consolidate MUXs and value MUXs)
Reviewed-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
commit 01ad5e7de67b408d9b48b437b06a9938ddf460b5 upstream.
If soc_dapm_read() fails, val will be uninitialized, and bogus values
will be written later:
ret = soc_dapm_read(dapm, reg, &val);
val = (val >> shift) & mask;
However, the compiler does not give a warning. Return on error before
val is really used to avoid this.
This is similar to the commit 6912831623c5 ("ASoC: dapm: Fix
uninitialized variable in snd_soc_dapm_get_enum_double()")
Fixes: ce0fc93ae56e (ASoC: Add DAPM support at the component level)
commit 8ae3ea48df0d746b663057cf0b972a18d0777b7b upstream.
Fix to return error code -ENOMEM instead of 0 when failed to create
widget, as done elsewhere in this function.
Fixes: 8a9782346dcc ("ASoC: topology: Add topology core")
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
commit ad8529fde9e3601180a839867a8ab041109aebb5 upstream.
Currently omap-rng checks the return value of pm_runtime_get_sync and
reports failure if anything is returned, however it should be checking
if ret < 0 as pm_runtime_get_sync return 0 on success but also can return
1 if the device was already active which is not a failure case. Only
values < 0 are actual failures.
Fixes: 61dc0a446e5d ("hwrng: omap - Fix assumption that runtime_get_sync will always succeed")
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
commit ed4767d612fd2c39e2c4c69eba484c1219dcddb6 upstream.
Since commit 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero"),
all ahash drivers are required to implement import()/export(), and must have
a non-zero statesize. Fix this for the ARM Crypto Extensions GHASH
implementation.
Fixes: 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 50d2e6dc1f83db0563c7d6603967bf9585ce934b upstream.
The cipher block size for GCM is 16 bytes, and thus the CTR transform
used in crypto_gcm_setkey() will also expect a 16-byte IV. However,
the code currently reserves only 8 bytes for the IV, causing
an out-of-bounds access in the CTR transform. This patch fixes
the issue by setting the size of the IV buffer to 16 bytes.
Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers")
Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com>
commit b64db1b252e9974a43a51ba083fa7d03e4716167 upstream.
AID gets updated during TDLS setup, but modified value isn't reflected
in "priv->assoc_rsp_buf". This causes TDLS setup failure. The problem is
fixed here.
Fixes: 4aff53ef18e4a4 ("mwifiex: parsing aid while receiving..")
Signed-off-by: Xinming Hu <huxm@marvell.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 6999aeabbb703a81a204cb6f9f8f151759a99ac4 upstream.
The call sequence spi_alloc_master/spi_register_master/spi_unregister_master
is complete; it reduces the device reference count to zero, which and results
in device memory being freed. The subsequent call to spi_master_put is
unnecessary and results in an access to free memory. Drop it.
Fixes: 9298bc727385 ("spi: spi-fsl-dspi: Remove spi-bitbang")
commit fcff03813a7c612873303037cef5ba0329850c35 upstream.
This fixes
[ 0.000000] i.MX clk 82: register failed with -17
because the name is duplicated.
Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc")
Acked-by: Shawn Guo <shawnguo@kernel.org>
commit 4d31a2588ae37a5d0f61f4d956454e9504846aeb upstream.
The variable i contains a total number of resources (including
IORESOURCE_IRQ). However, we want the dmem_region_start to point
after the last resource of type IORESOURCE_MEM. The original behaviour
leads (very likely) to skipping several UIO mapping regions and makes
them useless. Fix this by computing dmem_region_start from the uiomem
which points to the last used UIO mapping.
Fixes: 0a0c3b5a24bd ("Add new uio device for dynamic memory allocation")
Signed-off-by: Jan Viktorin <viktorin@rehivetech.com>
commit ee26c013cdee0b947e29d6cadfb9ff3341c69ff9 upstream.
Without this patch irq_domain_disassociate() cannot properly release the
interrupt. In fact, irq_map_generic_chip() checks a bit on 'gc->installed'
but said bit is never cleared, only set.
Commit 088f40b7b027 ("genirq: Generic chip: Add linear irq domain support")
added irq_map_generic_chip() function and also stated "This lacks a removal
function for now".
This commit provides an implementation of an unmap function that can be
called by irq_domain_disassociate().
[ tglx: Made the function static and removed the export as we have neither
a prototype nor a modular user. ]
Fixes: 088f40b7b027 ("genirq: Generic chip: Add linear irq domain support")
Signed-off-by: Sebastian Frias <sf84@laposte.net>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Mason <slash.tmp@free.fr>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/579F5C5A.2070507@laposte.net
commit 51fd2df1e882a3c2a3f4b6c9ff243a93c9046dba upstream.
We broke interval data displays with commit:
3f416f22d1e2 ("perf stat: Do not clean event's private stats")
This commit removed stats cleaning, which is important for '-r' option
to carry counters data over the whole run. But it's necessary to clean
it for interval mode, otherwise the displayed value is avg of all
previous values.
Before:
$ perf stat -e cycles -a -I 1000 record
# time counts unit events
1.000240796 75,216,287 cycles
2.000512791 107,823,524 cycles
$ perf stat report
2.000512791 91,519,906 cycles
Now:
$ perf stat report
Notice the second value being bigger (91,.. < 107,..).
This could be easily verified by using perf script which displays raw
stat data:
$ perf script
CPU THREAD VAL ENA RUN TIME EVENT
0 -1 23855779 1000209530 1000209530 1000240796 cycles
1 -1 33340397 1000224964 1000224964 1000240796 cycles
2 -1 15835415 1000226695 1000226695 1000240796 cycles
3 -1 2184696 1000228245 1000228245 1000240796 cycles
0 -1 97014312 2000514533 2000514533 2000512791 cycles
1 -1 46121497 2000543795 2000543795 2000512791 cycles
2 -1 32269530 2000543566 2000543566 2000512791 cycles
3 -1 7634472 2000544108 2000544108 2000512791 cycles
The sum of the first 4 values is the first interval aggregated value:
23855779 + 33340397 + 15835415 + 2184696 = 75,216,287
The sum of the second 4 values minus first value is the second interval
aggregated value:
97014312 + 46121497 + 32269530 + 7634472 - 75216287 = 107,823,524
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1454485436-20639-1-git-send-email-jolsa@kernel.org
Cc: Jeremy Linton <jeremy.linton@arm.com>
commit 04fec21c06e35b169a83e75a84a015ab4606bf5e upstream.
eeh_pe_bus_get() can return NULL if a PCI bus isn't found for a given PE.
Some callers don't check this, and can cause a null pointer dereference
under certain circumstances.
Fix this by checking NULL everywhere eeh_pe_bus_get() is called.
Fixes: 8a6b1bc70dbb ("powerpc/eeh: EEH core to handle special event")
Cc: stable@vger.kernel.org # v3.11+
Signed-off-by: Russell Currey <ruscur@russell.cc>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit a09a4c8dd1ec7f830e1fb9e59eb72bddc965d168 upstream.
If a packet is either locally encapsulated or processed through GRO
it is marked with the offloads that it requires. However, when it is
decapsulated these tunnel offload indications are not removed. This
means that if we receive an encapsulated TCP packet, aggregate it with
GRO, decapsulate, and retransmit the resulting frame on a NIC that does
not support encapsulation, we won't be able to take advantage of hardware
offloads even though it is just a simple TCP packet at this point.
This fixes the problem by stripping off encapsulation offload indications
when packets are decapsulated.
The performance impacts of this bug are significant. In a test where a
Geneve encapsulated TCP stream is sent to a hypervisor, GRO'ed, decapsulated,
and bridged to a VM performance is improved by 60% (5Gbps->8Gbps) as a
result of avoiding unnecessary segmentation at the VM tap interface.
Reported-by: Ramu Ramamurthy <sramamur@linux.vnet.ibm.com>
Fixes: 68c33163 ("v4 GRE: Add TCP segmentation offload for GRE")
Signed-off-by: Jesse Gross <jesse@kernel.org>
(backported from commit a09a4c8dd1ec7f830e1fb9e59eb72bddc965d168)
[adapt iptunnel_pull_header arguments, avoid 7f290c9]
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit fac8e0f579695a3ecbc4d3cac369139d7f819971 upstream.
When drivers express support for TSO of encapsulated packets, they
only mean that they can do it for one layer of encapsulation.
Supporting additional levels would mean updating, at a minimum,
more IP length fields and they are unaware of this.
No encapsulation device expresses support for handling offloaded
encapsulated packets, so we won't generate these types of frames
in the transmit path. However, GRO doesn't have a check for
multiple levels of encapsulation and will attempt to build them.
UDP tunnel GRO actually does prevent this situation but it only
handles multiple UDP tunnels stacked on top of each other. This
generalizes that solution to prevent any kind of tunnel stacking
that would cause problems.
Fixes: bf5a755f ("net-gre-gro: Add GRE support to the GRO stack")
commit b8cba75bdf6a48ea4811bbefb11a94a5c7281b68 upstream.
ipip encapsulated packets can be merged together by GRO but the result
does not have the proper GSO type set or even marked as being
encapsulated at all. Later retransmission of these packets will likely
fail if the device does not support ipip offloads. This is similar to
the issue resolved in IPv6 sit in feec0cb3
("ipv6: gro: support sit protocol").
Reported-by: Patrick Boutilier <boutilpj@ednet.ns.ca>
Fixes: 9667e9bb ("ipip: Add gro callbacks to ipip offload")
Tested-by: Patrick Boutilier <boutilpj@ednet.ns.ca>
commit 073931017b49d9458aa351605b43a7e34598caef upstream.
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
commit ded89912156b1a47d940a0c954c43afbabd0c42c upstream.
User-space can choose to omit NL80211_ATTR_SSID and only provide raw
IE TLV data. When doing so it can provide SSID IE with length exceeding
the allowed size. The driver further processes this IE copying it
into a local variable without checking the length. Hence stack can be
corrupted and used as exploit.
Reported-by: Daxing Guo <freener.gdx@gmail.com>
Reviewed-by: Hante Meuleman <hante.meuleman@broadcom.com>
Reviewed-by: Pieter-Paul Giesberts <pieter-paul.giesberts@broadcom.com>
Reviewed-by: Franky Lin <franky.lin@broadcom.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
commit 2247bb335ab9c40058484cac36ea74ee652f3b7b upstream.
Patch series "mm/hugetlb: memory offline issues with hugepages", v4.
This addresses several issues with hugepages and memory offline. While
the first patch fixes a panic, and is therefore rather important, the
last patch is just a performance optimization.
The second patch fixes a theoretical issue with reserved hugepages,
while still leaving some ugly usability issue, see description.
This patch (of 3):
dissolve_free_huge_pages() will either run into the VM_BUG_ON() or a
list corruption and addressing exception when trying to set a memory
block offline that is part (but not the first part) of a "gigantic"
hugetlb page with a size > memory block size.
When no other smaller hugetlb page sizes are present, the VM_BUG_ON()
will trigger directly. In the other case we will run into an addressing
exception later, because dissolve_free_huge_page() will not work on the
head page of the compound hugetlb page which will result in a NULL
hstate from page_hstate().
To fix this, first remove the VM_BUG_ON() because it is wrong, and then
use the compound head page in dissolve_free_huge_page(). This means
that an unused pre-allocated gigantic page that has any part of itself
inside the memory block that is going offline will be dissolved
completely. Losing an unused gigantic hugepage is preferable to failing
the memory offline, for example in the situation where a (possibly
faulty) memory DIMM needs to go offline.
Changes for v4.4 stable:
- make it apply w/o commit c1470b33 "mm/hugetlb: fix incorrect
hugepages count during mem hotplug"
Fixes: c8721bbb ("mm: memory-hotplug: enable memory hotplug to handle hugepage")
Link: http://lkml.kernel.org/r/20160926172811.94033-2-gerald.schaefer@de.ibm.com
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Rui Teng <rui.teng@linux.vnet.ibm.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: <stable@vger.kernel.org>
commit ca5732c53bf66ad755284786897e0dd10330de87 upstream.
We use obj->phys_handle to choose the pread/pwrite path, but as
obj->phys_handle is a union with obj->userptr, we then mistakenly use
the phys_handle path for userptr objects within pread/pwrite.
Testcase: igt/gem_userptr_blits/forbidden-operations
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97519
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161003124516.12388-2-chris@chris-wilson.co.uk
(cherry picked from commit 5f12b80a0b42da253691ca03828033014bb786eb)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit d721b02fd00bf133580f431b82ef37f3b746dfb2 upstream.
Looks like the TSEG lives just above TOUD, stolen comes after TSEG.
The spec seems somewhat self-contradictory in places, in the ESMRAMC
register desctription it says:
TSEG Size:
10=(TOUD + 512 KB) to TOUD
11 =(TOUD + 1 MB) to TOUD
so that agrees with TSEG being at TOUD. But the example given
elsehwere in the spec says:
TOUD equals 62.5 MB = 03E7FFFFh
TSEG selected as 512 KB in size,
Graphics local memory selected as 1 MB in size
General System RAM available in system = 62.5 MB
General system RAM range00000000h to 03E7FFFFh
TSEG address range03F80000h to 03FFFFFFh
TSEG pre-allocated from03F80000h to 03FFFFFFh
Graphics local memory pre-allocated from03E80000h to 03F7FFFFh
so here we have TSEG above stolen.
Real world evidence agrees with the TOUD->TSEG->stolen order however, so
let's fix up the code to account for the TSEG size.
Cc: Taketo Kabe <fdporg@vega.pgw.jp>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: x86@kernel.org
Fixes: 0ad98c74e093 ("drm/i915: Determine the stolen memory base address on gen2")
Fixes: a4dff76924fe ("x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms")
Reported-by: Taketo Kabe <fdporg@vega.pgw.jp>
Tested-by: Taketo Kabe <fdporg@vega.pgw.jp>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96473
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1470653919-27251-1-git-send-email-ville.syrjala@linux.intel.com
Link: http://download.intel.com/design/chipsets/datashts/25251405.pdf
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 23f889bdf6ee5cfff012d8b09f6bec920c691696 upstream.
This reverts commit 237ed86c693d8a8e4db476976aeb30df4deac74b.
Our current implementation of live status check (repeat 9 times
with 10ms delays between each attempt as a workaround for
buggy displays) imposes a rather serious penalty, time wise,
on intel_hdmi_detect(). Since we we already skip live status
checks on platforms before gen 7, and since we seem to have
coped quite well before the live status check was introduced
for newer platforms too, the previous behaviour is probably
preferable, at least unless someone can point to a use-case
that the live status check improves (apart from "Bspec says so".)
Signed-off-by: David Weinehall <david.weinehall@linux.intel.com>
Fixes: 237ed86c693d ("drm/i915: Check live status before reading edid")
Fixes: f8d03ea0053b ("drm/i915: increase the tries for HDMI hotplug live status checking")
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97139
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=94014
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/20160817124748.31208-1-david.weinehall@linux.intel.com
commit 4e4d3814a9bb4d71cd3ff0701d8d7041edefd8f0 upstream.
Bspec says:
"The mailbox response data may not account for memory read latency.
If the mailbox response data for level 0 is 0us, add 2 microseconds
to the result for each valid level."
This means we should only do the +2 in case wm[0] == 0, not always.
So split the sanitizing implementation from the WA implementation and
fix the WA implementation.
v2: Add Fixes tag (Maarten).
Fixes: 367294be7c25 ("drm/i915/gen9: Add 2us read latency to WM level")
Cc: Vandana Kannan <vandana.kannan@intel.com>
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1474578035-424-5-git-send-email-paulo.r.zanoni@intel.com
(cherry picked from commit 0727e40a48a1d08cf54ce2c01e120864b92e59bf)
commit 9a035a40f7f3f6708b79224b86c5777a3334f7ea upstream.
This should really only be done for XS_TRANSACTION_END messages, or
else at least some of the xenstore-* tools don't work anymore.
Fixes: 0beef634b8 ("xenbus: don't BUG() on user mode induced condition")
Reported-by: Richard Schütz <rschuetz@uni-koblenz.de>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Tested-by: Richard Schütz <rschuetz@uni-koblenz.de>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: "M. Vefa Bicakci" <m.v.b@runbox.com>
commit 51ab70bed997f64f091a639dbe22b629725a7faf upstream.
With older hardware versions, the user could specify arbitrarily large
command buffer sizes, causing a vmalloc / vmap space exhaustion.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Brian Paul <brianp@vmware.com>
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
error.
commit 02cfb5fccb0f9f968f0e208d89d9769aa16267bc upstream.
Ported from Rex's amdgpu change.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 427920292b00474d978d632bc03a8e4e50029af3 upstream.
Used the wrong index to setup the phase shedding mask.
commit 884031f0aacf57dad1575f96714efc80de9b19cc upstream.
Only needed on CIK+ due to the way pci reset is handled
by the GPU.
error.
commit dc8184aa8621ee8048652496884d9f40d4bb407f upstream.
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 140c94da3c3338c0ff4cc127cf9bec87905ca83c upstream.
All other amdgpu/dce_v* files have this call, it's only mysteriously
missing from dce_v11_0.c since the file was added and causes leaks.
Fixes: aaa36a976bbb ("drm/amdgpu: Add initial VI support")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
commit 3a9d993ee9809c217f4322623a9b78c8d17fdd1f upstream.
Otherwise we can get a hotplug interrupt storm when
we turn the panel off if hpd interrupts were enabled
by the bios.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=97471
commit 324082586cc5918e3230f0b2f326656c653201eb upstream.
by the bios.
bug:
commit e96ec90f496603c48e0945f8bdeb4cdf3088cbba upstream.
by the bios.
bug:
