commit 0eec880966e77bdbee0112989a2be67d92e39929 upstream.
HP Spectre x360 with CX20724 codec has two speaker outputs while the
BIOS sets up only the bottom one (NID 0x17) and disables the top one
(NID 0x1d).
This patch adds a fixup simply defining the proper pincfg for NID 0x1d
so that the top speaker works as is.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=169071
commit 3f640970a41429f0a076c01270bbd014c9eae61c upstream.
One of the laptops has the codec ALC256 on it, applying the
ALC255_FIXUP_DELL1_MIC_NO_PRESENCE can fix the problem, the rest
of laptops have the codec ALC295 on them, they are similar to machines
with ALC225, applying the ALC269_FIXUP_DELL1_MIC_NO_PRESENCE can fix
the problem.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit a59b679ab85635737947310323f2f2bcfa0664a7 upstream.
ACPICA commit 7bb77313091e52a846df4c9c2bea90be31bfb9d8
Eliminate warnings for "not found" _Sx errors, since these
are optional. Original NOT_FOUND status is still returned.
Original changes by Prarit Bhargava.
ACPICA BZ 1208.
Link: https://github.com/acpica/acpica/commit/7bb77313
Link: https://bugs.acpica.org/show_bug.cgi?id=1208
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Cc: "Charles (Chas) Williams" <ciwillia@brocade.com>
commit 392c9da24a994f238c5d7ea611c6245be4617014 upstream.
We have two new Dell laptop models, they have the same ALC255 pin
definition, but not in the pin quirk table yet, as a result, the
headset microphone can't work. After adding the definition in the
table, the headset microphone works well.
commit ab21b63e8aedfc73565dd9cdd51eb338341177cb upstream.
This reverts commit e6c7efdcb76f11b04e3d3f71c8d764ab75c9423b.
Turns out it was totally wrong. The memory is supposed to be bound to
the kref, as the original code was doing correctly, not the
device/driver binding as the devm_kzalloc() would cause.
This fixes an oops when read would be called after the device was
unbound from the driver.
Reported-by: Ladislav Michl <ladis@linux-mips.org>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
commit decc5360f23e9efe0252094f47f57f254dcbb3a9 upstream.
Signed-off-by: Kyle Jones <kyle@kf5jwc.us>
commit fc1e2c8ea85e109acf09e74789e9b852f6eed251 upstream.
Commit 367e8560e8d7a62d96e9b1d644028a3816e04206 introduced a bug
in fbtft-core where fps is always 0, this is because variable
update_time is not assigned correctly.
Signed-off-by: Ksenija Stanojevic <ksenija.stanojevic@gmail.com>
Fixes: 367e8560e8d7 ("Staging: fbtbt: Replace timespec with ktime_t")
commit 2fae9e5a7babada041e2e161699ade2447a01989 upstream.
This patch fixes a NULL pointer dereference caused by a race codition in
the probe function of the legousbtower driver. It re-structures the
probe function to only register the interface after successfully reading
the board's firmware ID.
The probe function does not deregister the usb interface after an error
receiving the devices firmware ID. The device file registered
(/dev/usb/legousbtower%d) may be read/written globally before the probe
function returns. When tower_delete is called in the probe function
(after an r/w has been initiated), core dev structures are deleted while
the file operation functions are still running. If the 0 address is
mappable on the machine, this vulnerability can be used to create a
Local Priviege Escalation exploit via a write-what-where condition by
remapping dev->interrupt_out_buffer in tower_write. A forged USB device
and local program execution would be required for LPE. The USB device
would have to delay the control message in tower_probe and accept
the control urb in tower_open whilst guest code initiated a write to the
device file as tower_delete is called from the error in tower_probe.
This bug has existed since 2003. Patch tested by emulated device.
Reported-by: James Patrick-Evans <james@jmp-e.com>
Tested-by: James Patrick-Evans <james@jmp-e.com>
Signed-off-by: James Patrick-Evans <james@jmp-e.com>
commit a377f9e906af4df9071ba8ddba60188cb4013d93 upstream.
A bug in the CRTSCTS handling caused RTS to alternate between
CRTSCTS=0 => "RTS is transmit active signal" and
CRTSCTS=1 => "RTS is used for receive flow control"
instead of
CRTSCTS=0 => "RTS is statically active" and
This only happened after first having enabled CRTSCTS.
Signed-off-by: Konstantin Shkolnyy <konstantin.shkolnyy@gmail.com>
Fixes: 39a66b8d22a3 ("[PATCH] USB: CP2101 Add support for flow control")
[johan: reword commit message ]
Signed-off-by: Johan Hovold <johan@kernel.org>
[johan: backport to 4.4 ]
commit 7efb367320f56fc4d549875b6f3a6940018ef2e5 upstream.
bio_alloc() can allocate a bio with at most BIO_MAX_PAGES (256) vector
entries. However, the incoming bio may have more vector entries if it
was allocated by other means. For example, bcache submits bios with
more than BIO_MAX_PAGES entries. This results in bio_alloc() failure.
To avoid the failure, change the code so that it allocates bio with at
most BIO_MAX_PAGES entries. If the incoming bio has more entries,
bio_add_page() will fail and a new bio will be allocated - the code that
handles bio_add_page() failure already exists in the dm-log-writes
target.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Reviewed-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 0f4c7a138dfefb0ebdbaf56e3ba2acd2958a6605 upstream.
In the initial fix for non-zero divider shift value, the parenthesis
was missing after the negate operation. This patch adds the required
parenthesis. Otherwise, lower bits may be cleared unintentionally.
Signed-off-by: Loc Ho <lho@apm.com>
Acked-by: Toan Le <toanle@apm.com>
Fixes: 1382ea631ddd ("clk: xgene: Fix divider with non-zero shift value")
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 22f6b4d34fcf039c63a94e7670e0da24f8575a5a upstream.
This ensures that do_mmap() won't implicitly make AIO memory mappings
executable if the READ_IMPLIES_EXEC personality flag is set. Such
behavior is problematic because the security_mmap_file LSM hook doesn't
catch this case, potentially permitting an attacker to bypass a W^X
policy enforced by SELinux.
I have tested the patch on my machine.
To test the behavior, compile and run this:
#define _GNU_SOURCE
#include <unistd.h>
#include <sys/personality.h>
#include <linux/aio_abi.h>
#include <err.h>
#include <stdlib.h>
#include <stdio.h>
#include <sys/syscall.h>
int main(void) {
personality(READ_IMPLIES_EXEC);
aio_context_t ctx = 0;
if (syscall(__NR_io_setup, 1, &ctx))
err(1, "io_setup");
char cmd[1000];
sprintf(cmd, "cat /proc/%d/maps | grep -F '/[aio]'",
(int)getpid());
system(cmd);
return 0;
In the output, "rw-s" is good, "rwxs" is bad.
Signed-off-by: Jann Horn <jann@thejh.net>
commit d9f179877e50ae2681fe7b0b83e0d9f63b6165ad upstream.
Reported-by: Lars Bußmann <ffsoest@kill-you.net>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
[sven@narfation.org: rewritten commit message to make clear that it is an
bugfix to an user reported crash]
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
commit 8ec07bf8a8b57d6c58927a16a0a22c0115cf2855 upstream.
When sending QP1 MAD packets which use a GRH, the source GID
(which consists of the 64-bit subnet prefix, and the 64 bit port GUID)
must be included in the packet GRH.
For SR-IOV, a GID cache is used, since the source GID needs to be the
slave's source GID, and not the Hypervisor's GID. This cache also
included a subnet_prefix. Unfortunately, the subnet_prefix field in
the cache was never initialized (to the default subnet prefix 0xfe80::0).
As a result, this field remained all zeroes. Therefore, when SR-IOV
was active, all QP1 packets which included a GRH had a source GID
subnet prefix of all-zeroes.
However, the subnet-prefix should initially be 0xfe80::0 (the default
subnet prefix). In addition, if OpenSM modifies a port's subnet prefix,
the new subnet prefix must be used in the GRH when sending QP1 packets.
To fix this we now initialize the subnet prefix in the SR-IOV GID cache
to the default subnet prefix. We update the cached value if/when OpenSM
modifies the port's subnet prefix. We take this cached value when sending
QP1 packets when SR-IOV is active.
Note that the value is stored as an atomic64. This eliminates any need
for locking when the subnet prefix is being updated.
Note also that we depend on the FW generating the "port management change"
event for tracking subnet-prefix changes performed by OpenSM. If running
early FW (before 2.9.4630), subnet prefix changes will not be tracked (but
the default subnet prefix still will be stored in the cache; therefore
users who do not modify the subnet prefix will not have a problem).
IF there is a need for such tracking also for early FW, we will add that
capability in a subsequent patch.
Fixes: 1ffeb2eb8be9 ("IB/mlx4: SR-IOV IB context objects and proxy/tunnel SQP support")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit baa0be7026e2f7d1d40bfd45909044169e9e3c68 upstream.
The indentation in the QP1 GRH flow in procedure build_mlx_header is
really confusing. Fix it, in preparation for a commit which touches
this code.
commit e5ac40cd66c2f3cd11bc5edc658f012661b16347 upstream.
Because of an incorrect bit-masking done on the join state bits, when
handling a join request we failed to detect a difference between the
group join state and the request join state when joining as send only
full member (0x8). This caused the MC join request not to be sent.
This issue is relevant only when SRIOV is enabled and SM supports
send only full member.
This fix separates scope bits and join states bits a nibble each.
Fixes: b9c5d6a64358 ('IB/mlx4: Add multicast group (MCG) paravirtualization for SR-IOV')
Signed-off-by: Alex Vesker <valex@mellanox.com>
commit 344bacca8cd811809fc33a249f2738ab757d327f upstream.
This fix solves a race between light flush and on the fly joins.
Light flush doesn't set the device to down and unset IPOIB_OPER_UP
flag, this means that if while flushing we have a MC join in progress
and the QP was attached to BC MGID we can have a mismatches when
re-attaching a QP to the BC MGID.
The light flush would set the broadcast group to NULL causing an on
the fly join to rejoin and reattach to the BC MCG as well as adding
the BC MGID to the multicast list. The flush process would later on
remove the BC MGID and detach it from the QP. On the next flush
the BC MGID is present in the multicast list but not found when trying
to detach it because of the previous double attach and single detach.
[18332.714265] ------------[ cut here ]------------
[18332.717775] WARNING: CPU: 6 PID: 3767 at drivers/infiniband/core/verbs.c:280 ib_dealloc_pd+0xff/0x120 [ib_core]
[18332.775198] Hardware name: Red Hat KVM, BIOS Bochs 01/01/2011
[18332.779411] 0000000000000000 ffff8800b50dfbb0 ffffffff813fed47 0000000000000000
[18332.784960] 0000000000000000 ffff8800b50dfbf0 ffffffff8109add1 0000011832f58300
[18332.790547] ffff880226a596c0 ffff880032482000 ffff880032482830 ffff880226a59280
[18332.796199] Call Trace:
[18332.798015] [<ffffffff813fed47>] dump_stack+0x63/0x8c
[18332.801831] [<ffffffff8109add1>] __warn+0xd1/0xf0
[18332.805403] [<ffffffff8109aebd>] warn_slowpath_null+0x1d/0x20
[18332.809706] [<ffffffffa025d90f>] ib_dealloc_pd+0xff/0x120 [ib_core]
[18332.814384] [<ffffffffa04f3d7c>] ipoib_transport_dev_cleanup+0xfc/0x1d0 [ib_ipoib]
[18332.820031] [<ffffffffa04ed648>] ipoib_ib_dev_cleanup+0x98/0x110 [ib_ipoib]
[18332.825220] [<ffffffffa04e62c8>] ipoib_dev_cleanup+0x2d8/0x550 [ib_ipoib]
[18332.830290] [<ffffffffa04e656f>] ipoib_uninit+0x2f/0x40 [ib_ipoib]
[18332.834911] [<ffffffff81772a8a>] rollback_registered_many+0x1aa/0x2c0
[18332.839741] [<ffffffff81772bd1>] rollback_registered+0x31/0x40
[18332.844091] [<ffffffff81773b18>] unregister_netdevice_queue+0x48/0x80
[18332.848880] [<ffffffffa04f489b>] ipoib_vlan_delete+0x1fb/0x290 [ib_ipoib]
[18332.853848] [<ffffffffa04df1cd>] delete_child+0x7d/0xf0 [ib_ipoib]
[18332.858474] [<ffffffff81520c08>] dev_attr_store+0x18/0x30
[18332.862510] [<ffffffff8127fe4a>] sysfs_kf_write+0x3a/0x50
[18332.866349] [<ffffffff8127f4e0>] kernfs_fop_write+0x120/0x170
[18332.870471] [<ffffffff81207198>] __vfs_write+0x28/0xe0
[18332.874152] [<ffffffff810e09bf>] ? percpu_down_read+0x1f/0x50
[18332.878274] [<ffffffff81208062>] vfs_write+0xa2/0x1a0
[18332.881896] [<ffffffff812093a6>] SyS_write+0x46/0xa0
[18332.885632] [<ffffffff810039b7>] do_syscall_64+0x57/0xb0
[18332.889709] [<ffffffff81883321>] entry_SYSCALL64_slow_path+0x25/0x25
[18332.894727] ---[ end trace 09ebbe31f831ef17 ]---
Fixes: ee1e2c82c245 ("IPoIB: Refresh paths instead of flushing them on SM change events")
commit 68c6bcdd8bd00394c234b915ab9b97c74104130c upstream.
The function send_leave sets the member: group->query_id
(group->query_id = ret) after calling the sa_query, but leave_handler
can be executed before the setting and it might delete the group object,
and will get a memory corruption.
Additionally, this patch gets rid of group->query_id variable which is
not used.
Fixes: faec2f7b96b5 ('IB/sa: Track multicast join/leave requests')
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
commit 546481c2816ea3c061ee9d5658eb48070f69212e upstream.
When a new CM connection is being requested, ipoib driver copies data
from the path pointer in the CM/tx object, the path object might be
invalid at the point and memory corruption will happened later when now
the CM driver will try using that data.
The next scenario demonstrates it:
neigh_add_path --> ipoib_cm_create_tx -->
queue_work (pointer to path is in the cm/tx struct)
#while the work is still in the queue,
#the port goes down and causes the ipoib_flush_paths:
ipoib_flush_paths --> path_free --> kfree(path)
#at this point the work scheduled starts.
ipoib_cm_tx_start --> copy from the (invalid)path pointer:
(memcpy(&pathrec, &p->path->pathrec, sizeof pathrec);)
-> memory corruption.
To fix that the driver now starts the CM/tx connection only if that
specific path exists in the general paths database.
This check is protected with the relevant locks, and uses the gid from
the neigh member in the CM/tx object which is valid according to the ref
count that was taken by the CM/tx.
Fixes: 839fcaba35 ('IPoIB: Connected mode experimental support')
commit dccbfcf52cebb8963246eba5b177b77f26b34da0 upstream.
If vmcs12 does not intercept APIC_BASE writes, then KVM will handle the
write with vmcs02 as the current VMCS.
This will incorrectly apply modifications intended for vmcs01 to vmcs02
and L2 can use it to gain access to L0's x2APIC registers by disabling
virtualized x2APIC while using msr bitmap that assumes enabled.
Postpone execution of vmx_set_virtual_x2apic_mode until vmcs01 is the
current VMCS. An alternative solution would temporarily make vmcs01 the
current VMCS, but it requires more care.
Fixes: 8d14695f9542 ("x86, apicv: add virtual x2apic support")
Reported-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 6a8b0c6b18f62a277ffb2139d0c0253fe35d7feb upstream.
free_irq() expects the same device identity that was passed to
corresponding request_irq(), otherwise the IRQ is not freed.
Fixes: e1f7c9eee707 ("dmaengine: at_xdmac: creation of the atmel eXtended DMA Controller driver")
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 735f2770a770156100f534646158cb58cb8b2939 upstream.
Commit fec1d0115240 ("[PATCH] Disable CLONE_CHILD_CLEARTID for abnormal
exit") has caused a subtle regression in nscd which uses
CLONE_CHILD_CLEARTID to clear the nscd_certainly_running flag in the
shared databases, so that the clients are notified when nscd is
restarted. Now, when nscd uses a non-persistent database, clients that
have it mapped keep thinking the database is being updated by nscd, when
in fact nscd has created a new (anonymous) one (for non-persistent
databases it uses an unlinked file as backend).
The original proposal for the CLONE_CHILD_CLEARTID change claimed
(https://lkml.org/lkml/2006/10/25/233):
: The NPTL library uses the CLONE_CHILD_CLEARTID flag on clone() syscalls
: on behalf of pthread_create() library calls. This feature is used to
: request that the kernel clear the thread-id in user space (at an address
: provided in the syscall) when the thread disassociates itself from the
: address space, which is done in mm_release().
: Unfortunately, when a multi-threaded process incurs a core dump (such as
: from a SIGSEGV), the core-dumping thread sends SIGKILL signals to all of
: the other threads, which then proceed to clear their user-space tids
: before synchronizing in exit_mm() with the start of core dumping. This
: misrepresents the state of process's address space at the time of the
: SIGSEGV and makes it more difficult for someone to debug NPTL and glibc
: problems (misleading him/her to conclude that the threads had gone away
: before the fault).
: The fix below is to simply avoid the CLONE_CHILD_CLEARTID action if a
: core dump has been initiated.
The resulting patch from Roland (https://lkml.org/lkml/2006/10/26/269)
seems to have a larger scope than the original patch asked for. It
seems that limitting the scope of the check to core dumping should work
for SIGSEGV issue describe above.
[Changelog partly based on Andreas' description]
Fixes: fec1d0115240 ("[PATCH] Disable CLONE_CHILD_CLEARTID for abnormal exit")
Link: http://lkml.kernel.org/r/1471968749-26173-1-git-send-email-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Tested-by: William Preston <wpreston@suse.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Roland McGrath <roland@hack.frob.com>
Cc: Andreas Schwab <schwab@suse.com>
commit a8719670687c46ed2e904c0d05fa4cd7e4950cd1 upstream.
Fixes: ddd17531ad908 ("ASoC: omap-mcpdm: Clean up with devm_* function")
Managed irq request will not doing any good in ASoC probe level as it is
not going to free up the irq when the driver is unbound from the sound
card.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reported-by: Russell King <linux@armlinux.org.uk>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit e7d316a02f683864a12389f8808570e37fb90aa3 upstream.
We have scripts which write to certain fields on 3.18 kernels but this
seems to be failing on 4.4 kernels. An entry which we write to here is
xfrm_aevent_rseqth which is u32.
echo 4294967295 > /proc/sys/net/core/xfrm_aevent_rseqth
Commit 230633d109e3 ("kernel/sysctl.c: detect overflows when converting
to int") prevented writing to sysctl entries when integer overflow
occurs. However, this does not apply to unsigned integers.
Heinrich suggested that we introduce a new option to handle 64 bit
limits and set min as 0 and max as UINT_MAX. This might not work as it
leads to issues similar to __do_proc_doulongvec_minmax. Alternatively,
we would need to change the datatype of the entry to 64 bit.
static int __do_proc_doulongvec_minmax(void *data, struct ctl_table
i = (unsigned long *) data; //This cast is causing to read beyond the size of data (u32)
vleft = table->maxlen / sizeof(unsigned long); //vleft is 0 because maxlen is sizeof(u32) which is lesser than sizeof(unsigned long) on x86_64.
Introduce a new proc handler proc_douintvec. Individual proc entries
will need to be updated to use the new handler.
Fixes: 230633d109e3 ("kernel/sysctl.c:detect overflows when converting to int")
Link: http://lkml.kernel.org/r/1471479806-5252-1-git-send-email-subashab@codeaurora.org
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
client-architecture-support
commit 66443efa83dc73775100b7442962ce2cb0d4472e upstream.
When booting from an OpenFirmware which supports it, we use the
"ibm,client-architecture-support" firmware call to communicate
our capabilities to firmware.
The format of the structure we pass to firmware is specified in
PAPR (Power Architecture Platform Requirements), or the public version
LoPAPR (Linux on Power Architecture Platform Reference).
Referring to table 244 in LoPAPR v1.1, option vector 5 contains a 4 byte
field at bytes 17-20 for the "Platform Facilities Enable". This is
followed by a 1 byte field at byte 21 for "Sub-Processor Represenation
Level".
Comparing to the code, there we have the Platform Facilities
options (OV5_PFO_*) at byte 17, but we fail to pad that field out to its
full width of 4 bytes. This means the OV5_SUB_PROCESSORS option is
incorrectly placed at byte 18.
Fix it by adding zero bytes for bytes 18, 19, 20, and comment the bytes
to hopefully make it clearer in future.
As far as I'm aware nothing actually consumes this value at this time,
so the effect of this bug is nil in practice.
It does mean we've been incorrectly setting bit 15 of the "Platform
Facilities Enable" option for the past ~3 1/2 years, so we should avoid
allocating that bit to anything else in future.
Fixes: df77c7992029 ("powerpc/pseries: Update ibm,architecture.vec for PAPR 2.7/POWER8")
commit f823a2aa8f4674c095a5413b9e3ba12d82df06f2 upstream.
wlc_phy_txpower_get_current() does a logical OR of power->flags, which
presumes that power.flags was initiliazed earlier by the caller,
unfortunately, this is not the case, so make sure we zero out the struct
tx_power before calling into wlc_phy_txpower_get_current().
Reported-by: coverity (CID 146011)
Fixes: 5b435de0d7868 ("net: wireless: add brcm80211 drivers")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 5c5fa1f464ac954982df1d96b9f9a5103d21aedd upstream.
In case dma_mapping_error() returns an error in dma_rxfill, we would be
leaking a packet that we allocated with brcmu_pkt_buf_get_skb().
Reported-by: coverity (CID 1081819)
Fixes: 67d0cf50bd32 ("brcmsmac: Fix WARNING caused by lack of calls to dma_mapping_error()")
Acked-by: Arend van Spriel <arend@broadcom.com>
commit 3bdae810721b33061d2e541bd78a70f86ca42af3 upstream.
In case brcmf_sdiod_recv_chain() cannot complete a succeful call to
brcmf_sdiod_buffrw, we would be leaking glom_skb and not free it as we
should, fix this.
Reported-by: coverity (CID 1164856)
Fixes: a413e39a38573 ("brcmfmac: fix brcmf_sdcard_recv_chain() for host without sg support")
commit 979cf59acc9d634cc140aadd0d2915947ab303cc upstream.
Fix to return error code -ENODEV from the error handling
case instead of 0, as done elsewhere in this function.
Fixes: 87b2bdf02278 ("ASoC: Intel: Skylake: Initialize NHLT table")
Acked-By: Vinod Koul <vinod.kou@intel.com>
commit c001c87a63aa2f35358e33eb05e45e4cbcb34f54 upstream.
We should always do a layoutcommit after commit to DS, except if
the layout segment we're using has set FF_FLAGS_NO_LAYOUTCOMMIT.
Fixes: d67ae825a59d ("pnfs/flexfiles: Add the FlexFile Layout Driver")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 73e6c5d854d3f7f75e8b46d3e54aeb5d83fe6b1f upstream.
According to the errata
https://www.rfc-editor.org/errata_search.php?rfc=5661&eid=2751
we should always send layout commit after a commit to DS.
Fixes: bc7d4b8fd091 ("nfs/filelayout: set layoutcommit...")
commit a4e187d83d88eeaba6252aac0a2ffe5eaa73a818 upstream.
Before commit 778be232a207 ("NFS do not find client in NFSv4
pg_authenticate"), the Linux callback server replied with
RPC_AUTH_ERROR / RPC_AUTH_BADCRED, instead of dropping the CB
request. Let's restore that behavior so the server has a chance to
do something useful about it, and provide a warning that helps
admins correct the problem.
Fixes: 778be232a207 ("NFS do not find client in NFSv4 ...")
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 0533b13072f4bf35738290d2cf9e299c7bc6c42a upstream.
If an RPC program does not set vs_dispatch and pc_func() returns
rpc_drop_reply, the server sends a reply anyway containing a single
word containing the value RPC_DROP_REPLY (in network byte-order, of
course). This is a nonsense RPC message.
Fixes: 9e701c610923 ("svcrpc: simpler request dropping")
commit 3935e08768ff777da6496521b1fc36f72823672c upstream.
mbr_ds is an integer, don't use %pad to print it.
Fixes: commit 268914f4e7a0 ("dmaengine: at_xdmac: use %pad format string for dma_addr_t")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit dd7328e4c53649c1c7ec36bc1cf5b229b8662047 upstream.
pci_dma_mapping_error() returns true on error and false on success.
Fixes: fd6ddfa4c1dd ('fnic: check pci_map_single() return value')
commit 55f1cf83d5cf885c75267269729805852039c834 upstream.
The pio_dev[] array has MAX_NR_PIO_DEVICES elements so the > should be
Fixes: 5f97f7f9400d ('[PATCH] avr32 architecture')
commit aaab50fcea78ae3414c3afc25aae8d0603df34d0 upstream.
The function ar9003_hw_apply_minccapwr_thresh takes as second parameter not
a pointer to the channel but a boolean value describing whether the channel
is 2.4GHz or not. This broke (according to the origin commit) the ETSI
regulatory compliance on 5GHz channels.
Fixes: 3533bf6b15a0 ("ath9k: Fix regulatory compliance")
Cc: Simon Wunderlich <sw@simonwunderlich.de>
Cc: Sujith Manoharan <c_manoha@qca.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit d7e92e15e92fc987640772bf110586898b5f15aa upstream.
When CONFIG_INPUT is disabled, multiple gspca backend drivers
print compile-time warnings about unused variables:
media/usb/gspca/cpia1.c: In function 'sd_stopN':
media/usb/gspca/cpia1.c:1627:13: error: unused variable 'sd' [-Werror=unused-variable]
media/usb/gspca/konica.c: In function 'sd_stopN':
media/usb/gspca/konica.c:246:13: error: unused variable 'sd' [-Werror=unused-variable]
This annotates the variables as __maybe_unused, to let the compiler
know that they are declared intentionally.
Fixes: ee186fd96a5f ("[media] gscpa_t613: Add support for the camera button")
Fixes: c2f644aeeba3 ("[media] gspca_cpia1: Add support for button")
Fixes: b517af722860 ("V4L/DVB: gspca_konica: New gspca subdriver for konica chipset using cams")
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit e44c153b30c9a0580fc2b5a93f3c6d593def2278 upstream.
The code is checking for negative returns but it should be checking for
zero.
Fixes: aab3125c43d8 ('[media] em28xx: add support for registering multiple i2c buses')
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit fa1ce54ea38f7f83473fce62e64fefbd7ebd170e upstream.
drivers/nfc/fdp/fdp.c: In function ‘fdp_nci_patch_otp’:
drivers/nfc/fdp/fdp.c:373: warning: comparison is always false due to limited range of data type
drivers/nfc/fdp/fdp.c: In function ‘fdp_nci_patch_ram’:
drivers/nfc/fdp/fdp.c:444: warning: comparison is always false due to limited range of data type
fdp_nci_create_conn() may return a negative error code, which is
silently ignored by assigning it to a u8.
Change conn_id from u8 to int to fix this.
Fixes: a06347c04c13e380 ("NFC: Add Intel Fields Peak NFC solution driver")
commit 849a9627299100ae3f0ce573fc87d2b476f3bb59 upstream.
Currently the state sent in SF configuration is always
FULL_ON.
This commit sets the correct state (e.g. INIT_OFF
when station is not associated).
Fixes: commit f4a3ee493e69 ("iwlwifi: mvm: Always enable the smart FIFO")
Signed-off-by: Shaul Triebitz <shaul.triebitz@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit cdf8b4633075f2171d440d2e37c9c2609019a81a upstream.
AT_VECTOR_SIZE_ARCH should be defined with the maximum number of
NEW_AUX_ENT entries that ARCH_DLINFO can contain, but it wasn't defined
for tile at all even though ARCH_DLINFO will contain one NEW_AUX_ENT for
the VDSO address.
This shouldn't be a problem as AT_VECTOR_SIZE_BASE includes space for
AT_BASE_PLATFORM which tile doesn't use, but lets define it now and add
the comment above ARCH_DLINFO as found in several other architectures to
remind future modifiers of ARCH_DLINFO to keep AT_VECTOR_SIZE_ARCH up to
date.
Fixes: 4a556f4f56da ("tile: implement gettimeofday() via vDSO")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
commit 52d210d961a62a9662e27f14d6505d6741b2fb02 upstream.
In ee1d267423a1 ("pstore: add pstore unregister") I added:
.owner = THIS_MODULE,
in both pstore_fs_type and pstore_file_operations to increase a reference
count when pstore filesystem is mounted and pstore file is opened.
But, it's repetitive. There is no need to increase the opened reference
count. We only need to increase the mounted reference count. When a file
is opened, the filesystem can't be unmounted. Hence the pstore module
can't be unloaded either.
So I drop the opened reference count in this patch.
Fixes: ee1d267423a1 ("pstore: add pstore unregister")
Signed-off-by: Geliang Tang <geliangtang@163.com>
commit 52b9c330c6a8a4b5a1819bdaddf4ec76ab571e81 upstream.
If ->queue_rq() returns BLK_MQ_RQ_QUEUE_OK, we use continue and skip
over the rest of the loop body. However, dptr is assigned later in the
loop body, and the BLK_MQ_RQ_QUEUE_OK case is exactly the case that we'd
want it for.
NVMe isn't actually using BLK_MQ_F_DEFER_ISSUE yet, nor is any other
in-tree driver, but if the code's going to be there, it might as well
work.
Fixes: 74c450521dd8 ("blk-mq: add a 'list' parameter to ->queue_rq()")
Signed-off-by: Omar Sandoval <osandov@fb.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 61dc0a446e5d08f2de8a24b45f69a1e302bb1b1b upstream.
pm_runtime_get_sync does return a error value that must be checked for
error conditions, else, due to various reasons, the device maynot be
enabled and the system will crash due to lack of clock to the hardware
module.
Before:
12.562784] [00000000] *pgd=fe193835
12.562792] Internal error: : 1406 [#1] SMP ARM
12.562864] CPU: 1 PID: 241 Comm: modprobe Not tainted 4.7.0-rc4-next-20160624 #2
12.562867] Hardware name: Generic DRA74X (Flattened Device Tree)
12.562872] task: ed51f140 ti: ed44c000 task.ti: ed44c000
12.562886] PC is at omap4_rng_init+0x20/0x84 [omap_rng]
12.562899] LR is at set_current_rng+0xc0/0x154 [rng_core]
After the proper checks:
[ 94.366705] omap_rng 48090000.rng: _od_fail_runtime_resume: FIXME:
missing hwmod/omap_dev info
[ 94.375767] omap_rng 48090000.rng: Failed to runtime_get device -19
[ 94.382351] omap_rng 48090000.rng: initialization failed.
Fixes: 665d92fa85b5 ("hwrng: OMAP: convert to use runtime PM")
Cc: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
commit 06dfe5cc0cc684e735cb0232fdb756d30780b05d upstream.
SA1111 PCMCIA was broken when PCMCIA switched to using dev_pm_ops for
the PCMCIA socket class. PCMCIA used to handle suspend/resume via the
socket hosting device, which happened at normal device suspend/resume
time.
However, the referenced commit changed this: much of the resume now
happens much earlier, in the noirq resume handler of dev_pm_ops.
However, on SA1111, the PCMCIA device is not accessible as the SA1111
has not been resumed at _noirq time. It's slightly worse than that,
because the SA1111 has already been put to sleep at _noirq time, so
suspend doesn't work properly.
Fix this by converting the core SA1111 code to use dev_pm_ops as well,
and performing its own suspend/resume at noirq time.
This fixes these errors in the kernel log:
pcmcia_socket pcmcia_socket0: time out after reset
pcmcia_socket pcmcia_socket1: time out after reset
and the resulting lack of PCMCIA cards after a S2RAM cycle.
Fixes: d7646f7632549 ("pcmcia: use dev_pm_ops for class pcmcia_socket_class")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit c2f321126e31cd69365e65ecd4a7c774e4fc71d2 upstream.
The current implementation only works if the da9xxx devices are added
before their drivers are registered. Only then it can apply the fixes to
both devices. Otherwise, the driver for the first device gets probed
before the fix for the second device can be applied. This is what
fails when using the IP core switcher or when having the i2c master
driver as a module.
So, we need to disable both da9xxx once we detected one of them. We now
use i2c_transfer with hardcoded i2c_messages and device addresses, so we
don't need the da9xxx client devices to be instantiated. Because the
fixup is used on specific boards only, the addresses are not going to
change.
Fixes: 663fbb52159cca ("ARM: shmobile: R-Car Gen2: Add da9063/da9210 regulator quirk")
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be> (r8a7791/koelsch)
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit da60626e7d02a4f385cae80e450afc8b07035368 upstream.
Clear the current reset status prior to rebooting the platform. This
adds the bit missing from 04fef228fb00 ("[ARM] pxa: introduce
reset_status and clear_reset_status for driver's usage").
Fixes: 04fef228fb00 ("[ARM] pxa: introduce reset_status and clear_reset_status for driver's usage")
commit 02ba38a5b6d6e0bc89c7b74651f1873055028a56 upstream.
pxa_timer wants to be able to call clk_enable() etc on this clock,
but our clk_enable() implementation expects non-NULL enable/disable
operations. Provide these dummy implementations.
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0204000
[00000000] *pgd=00000000
Internal error: Oops: 80000005 [#1] ARM
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 4.8.0-rc2+ #887
Hardware name: Intel-Assabet
task: c0644590 task.stack: c0640000
PC is at 0x0
LR is at clk_enable+0x40/0x58
pc : [<00000000>] lr : [<c021b178>] psr: 600000d3
sp : c0641f60 ip : c0641f4c fp : c0641f74
r10: c1ffc7a0 r9 : 6901b118 r8 : 00000001
r7 : c0639a34 r6 : 0000001b r5 : a00000d3 r4 : c0645d70
r3 : c0645d78 r2 : 00000001 r1 : c0641ef0 r0 : c0645d70
Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment none
Control: c020717f Table: c020717f DAC: 00000053
Process swapper (pid: 0, stack limit = 0xc0640188)
Stack: (0xc0641f60 to 0xc0642000)
1f60: 00384000 c08762e4 c0641f98 c0641f78 c063308c c021b144 00000000 00000000
1f80: 00000000 c0660b20 ffffffff c0641fa8 c0641f9c c06220ec c0633058 c0641fb8
1fa0: c0641fac c061f114 c06220dc c0641ff4 c0641fbc c061bb68 c061f0fc ffffffff
1fc0: ffffffff 00000000 c061b6cc c0639a34 c0660cd4 c0642038 c0639a30 c0645434
1fe0: c0204000 c06380f8 00000000 c0641ff8 c0208048 c061b954 00000000 00000000
Backtrace:
[<c021b138>] (clk_enable) from [<c063308c>] (pxa_timer_nodt_init+0x40/0x120)
r5:c08762e4 r4:00384000
[<c063304c>] (pxa_timer_nodt_init) from [<c06220ec>] (sa1100_timer_init+0x1c/0x20)
r6:ffffffff r5:c0660b20 r4:00000000
[<c06220d0>] (sa1100_timer_init) from [<c061f114>] (time_init+0x24/0x2c)
[<c061f0f0>] (time_init) from [<c061bb68>] (start_kernel+0x220/0x42c)
[<c061b948>] (start_kernel) from [<c0208048>] (0xc0208048)
r10:c06380f8 r8:c0204000 r7:c0645434 r6:c0639a30 r5:c0642038 r4:c0660cd4
Code: bad PC value
---[ end trace 0000000000000000 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
Fixes: ee3a4020f7c9 ("ARM: 8250/1: sa1100: provide OSTIMER0 clock for pxa_timer")
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
