commit 17d0774f80681020eccc9638d925a23f1fc4f671 upstream.
Attributes declared with __ATTR_PREALLOC use sysfs_kf_read() which returns
zero bytes for non-zero offset. This breaks script checkarray in mdadm tool
in debian where /bin/sh is 'dash' because its builtin 'read' reads only one
byte at a time. Script gets 'i' instead of 'idle' when reads current action
from /sys/block/$dev/md/sync_action and as a result does nothing.
This patch adds trivial implementation of partial read: generate whole
string and move required part into buffer head.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: 4ef67a8c95f3 ("sysfs/kernfs: make read requests on pre-alloc files use the buffer.")
Link: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=787950
Acked-by: Tejun Heo <tj@kernel.org>
commit 5d17d3b4bbf3becb89fd48b74340a50a39736f6d upstream.
The "name" variable's memory is now freed when the device is destructed
thanks to devm function.
Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Fixes: e0f8a24e0edfd ("staging:iio::hwmon interface client driver.")
Fixes: 61bb53bcbdd86 ("hwmon: (iio_hwmon) Add support for humidity sensors")
commit b027d11263836a0cd335520175257dcb99b43757 upstream.
The commit 02fc76f6a changed base of the sysfs attributes from device to card.
The "show" callbacks dereferenced wrong objects because of this.
Fixes: 02fc76f6a7db ('ALSA: line6: Create sysfs via snd_card_add_dev_attr()')
Reviewed-by: Stefan Hajnoczi <stefanha@gmail.com>
Signed-off-by: Andrej Krutak <dev@andree.sk>
commit adc8a43a6d6688272ebffa81789fa857e603dec6 upstream.
Done, because line6_stream_stop() locks and calls line6_unlink_audio_urbs(),
which in turn invokes audio_out_callback(), which tries to lock 2nd time.
Fixes:
[ INFO: possible recursive locking detected ]
4.4.15+ #15 Not tainted
mplayer/3591 is trying to acquire lock:
(&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa27655>] audio_out_callback+0x70/0x110 [snd_usb_line6]
but task is already holding lock:
(&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa26aad>] line6_stream_stop+0x24/0x5c [snd_usb_line6]
Possible unsafe locking scenario:
CPU0
lock(&(&line6pcm->out.lock)->rlock);
*** DEADLOCK ***
May be due to missing lock nesting notation
3 locks held by mplayer/3591:
#0: (snd_pcm_link_rwlock){.-.-..}, at: [<bf8d49a7>] snd_pcm_stream_lock+0x1e/0x40 [snd_pcm]
#1: (&(&substream->self_group.lock)->rlock){-.-...}, at: [<bf8d49af>] snd_pcm_stream_lock+0x26/0x40 [snd_pcm]
#2: (&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa26aad>] line6_stream_stop+0x24/0x5c [snd_usb_line6]
stack backtrace:
CPU: 0 PID: 3591 Comm: mplayer Not tainted 4.4.15+ #15
Hardware name: Generic AM33XX (Flattened Device Tree)
[<c0015d85>] (unwind_backtrace) from [<c001253d>] (show_stack+0x11/0x14)
[<c001253d>] (show_stack) from [<c02f1bdf>] (dump_stack+0x8b/0xac)
[<c02f1bdf>] (dump_stack) from [<c0076f43>] (__lock_acquire+0xc8b/0x1780)
[<c0076f43>] (__lock_acquire) from [<c007810d>] (lock_acquire+0x99/0x1c0)
[<c007810d>] (lock_acquire) from [<c06171e7>] (_raw_spin_lock_irqsave+0x3f/0x4c)
[<c06171e7>] (_raw_spin_lock_irqsave) from [<bfa27655>] (audio_out_callback+0x70/0x110 [snd_usb_line6])
[<bfa27655>] (audio_out_callback [snd_usb_line6]) from [<c04294db>] (__usb_hcd_giveback_urb+0x53/0xd0)
[<c04294db>] (__usb_hcd_giveback_urb) from [<c046388d>] (musb_giveback+0x3d/0x98)
[<c046388d>] (musb_giveback) from [<c04647f5>] (musb_urb_dequeue+0x6d/0x114)
[<c04647f5>] (musb_urb_dequeue) from [<c042ac11>] (usb_hcd_unlink_urb+0x39/0x98)
[<c042ac11>] (usb_hcd_unlink_urb) from [<bfa26a87>] (line6_unlink_audio_urbs+0x6a/0x6c [snd_usb_line6])
[<bfa26a87>] (line6_unlink_audio_urbs [snd_usb_line6]) from [<bfa26acb>] (line6_stream_stop+0x42/0x5c [snd_usb_line6])
[<bfa26acb>] (line6_stream_stop [snd_usb_line6]) from [<bfa26fe7>] (snd_line6_trigger+0xb6/0xf4 [snd_usb_line6])
[<bfa26fe7>] (snd_line6_trigger [snd_usb_line6]) from [<bf8d47b7>] (snd_pcm_do_stop+0x36/0x38 [snd_pcm])
[<bf8d47b7>] (snd_pcm_do_stop [snd_pcm]) from [<bf8d462f>] (snd_pcm_action_single+0x22/0x40 [snd_pcm])
[<bf8d462f>] (snd_pcm_action_single [snd_pcm]) from [<bf8d46f9>] (snd_pcm_action+0xac/0xb0 [snd_pcm])
[<bf8d46f9>] (snd_pcm_action [snd_pcm]) from [<bf8d4b61>] (snd_pcm_drop+0x38/0x64 [snd_pcm])
[<bf8d4b61>] (snd_pcm_drop [snd_pcm]) from [<bf8d6233>] (snd_pcm_common_ioctl1+0x7fe/0xbe8 [snd_pcm])
[<bf8d6233>] (snd_pcm_common_ioctl1 [snd_pcm]) from [<bf8d6779>] (snd_pcm_playback_ioctl1+0x15c/0x51c [snd_pcm])
[<bf8d6779>] (snd_pcm_playback_ioctl1 [snd_pcm]) from [<bf8d6b59>] (snd_pcm_playback_ioctl+0x20/0x28 [snd_pcm])
[<bf8d6b59>] (snd_pcm_playback_ioctl [snd_pcm]) from [<c016714b>] (do_vfs_ioctl+0x3af/0x5c8)
Fixes: 63e20df1e5b2 ('ALSA: line6: Reorganize PCM stream handling')
commit 7e4379eae0e31994ea645db1d13006ea8e5ce539 upstream.
If there's an error, pcm is released in line6_pcm_acquire already.
Fixes: 247d95ee6dd2 ('ALSA: line6: Handle error from line6_pcm_acquire()')
commit 702b07fcc9b264c9afd372676bbdd50a762dcde0 upstream.
SRAT maps APIC ID to proximity domains ids (PXM). Mapping from PXM to
NUMA node ids is based on order of entries in SRAT table.
SRAT table has just LAPIC entires or mix of LAPIC and X2APIC entries.
As long as there are only LAPIC entires, mapping from proximity domain
id to NUMA node id is as assumed by BIOS. However, once APIC entries are
mixed, X2APIC entries would be first mapped which causes unexpected NUMA
node mapping.
To fix that, change parsing to check each entry against both LAPIC and
X2APIC so mapping is in the SRAT/PXM order.
This is supplemental change to the fix made by commit d81056b5278
(Handle apic/x2apic entries in MADT in correct order) and using the
mechanism introduced by 9b3fedd (ACPI / tables: Add acpi_subtable_proc
to ACPI table parsers).
Fixes: d81056b5278 (Handle apic/x2apic entries in MADT in correct order)
Signed-off-by: Lukasz Anaczkowski <lukasz.anaczkowski@intel.com>
[ rjw : Subject & changelog ]
commit f18ebc211e259d4f591e39e74b2aa2de226c9a1d upstream.
The problem with ornamental, do-nothing gotos is that they lead to
"forgot to set the error code" bugs. We should be returning -EINVAL
here but we don't. It leads to an uninitalized variable in
counter_show():
drivers/acpi/sysfs.c:603 counter_show()
error: uninitialized symbol 'status'.
Fixes: 1c8fce27e275 (ACPI: introduce drivers/acpi/sysfs.c)
commit 5331d9cab32ef640b4cd38a43b0858874fbb7168 upstream.
Commit e647b532275b ("ACPI: Add early device probing infrastructure")
introduced code that allows inserting driver specific
struct acpi_probe_entry probe entries into ACPI linker sections
(one per-subsystem, eg irqchip, clocksource) that are then walked
to retrieve the data and function hooks required to probe the
respective kernel components.
Probing for all entries in a section is triggered through
the __acpi_probe_device_table() function, that in turn, according
to the table ID a given probe entry reports parses the table
with the function retrieved from the respective section structures
(ie struct acpi_probe_entry). Owing to the current ACPI table
parsing implementation, the __acpi_probe_device_table() function
has to share global variables with the acpi_match_madt() function, so
in order to guarantee mutual exclusion locking is required
between the two functions.
Current kernel code implements the locking through the acpi_probe_lock
spinlock; this has the side effect of requiring all code called
within the lock (ie struct acpi_probe_entry.probe_{table/subtbl} hooks)
not to sleep.
However, kernel subsystems that make use of the early probing
infrastructure are relying on kernel APIs that may sleep (eg
irq_domain_alloc_fwnode(), among others) in the function calls
pointed at by struct acpi_probe_entry.{probe_table/subtbl} entries
(eg gic_v2_acpi_init()), which is a bug.
Since __acpi_probe_device_table() is called from context
that is allowed to sleep the acpi_probe_lock spinlock can be replaced
with a mutex; this fixes the issue whilst still guaranteeing
mutual exclusion.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Fixes: e647b532275b (ACPI: Add early device probing infrastructure)
commit 3feab13c919f99b0a17d0ca22ae00cf90f5d3fd1 upstream.
When the ACPI_DECLARE_PROBE_ENTRY macro was added in
commit e647b532275b ("ACPI: Add early device probing infrastructure"),
a stub macro adding an unused entry was added for the !CONFIG_ACPI
Kconfig option case to make sure kernel code making use of the
macro did not require to be guarded within CONFIG_ACPI in order to
be compiled.
The stub macro was never used since all kernel code that defines
ACPI_DECLARE_PROBE_ENTRY entries is currently guarded within
CONFIG_ACPI; it contains a typo that should be nonetheless fixed.
Fix the typo in the stub (ie !CONFIG_ACPI) ACPI_DECLARE_PROBE_ENTRY()
macro so that it can actually be used if needed.
commit 5ca05345c56cb979e1a25ab6146437002f95cac8 upstream.
For counter subdevices, the `s->insn_write` handler is being set to the
wrong function, `ni_tio_insn_read()`. It should be
`ni_tio_insn_write()`.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Reported-by: Éric Piel <piel@delmic.com>
Fixes: 10f74377eec3 ("staging: comedi: ni_tio: make ni_tio_winsn() a
proper comedi (*insn_write)"
commit f0f4b0cc3a8cffd983f5940d46cd0227f3f5710a upstream.
Commit ebb657babfa9 ("staging: comedi: ni_mio_common: clarify the
cmd->start_arg validation and use") introduced a backwards compatibility
issue in the use of asynchronous commands on the AO subdevice when
`start_src` is `TRIG_EXT`. Valid values for `start_src` are `TRIG_INT`
(for internal, software trigger), and `TRIG_EXT` (for external trigger).
When set to `TRIG_EXT`. In both cases, the driver relies on an
internal, software trigger to set things up (allowing the user
application to write sufficient samples to the data buffer before the
trigger), so it acts as a software "pre-trigger" in the `TRIG_EXT` case.
The software trigger is handled by `ni_ao_inttrig()`.
Prior to the above change, when `start_src` was `TRIG_INT`, `start_arg`
was required to be 0, and `ni_ao_inttrig()` checked that the software
trigger number was also 0. After the above change, when `start_src` was
`TRIG_INT`, any value was allowed for `start_arg`, and `ni_ao_inttrig()`
checked that the software trigger number matched this `start_arg` value.
The backwards compatibility issue is that the internal trigger number
now has to match `start_arg` when `start_src` is `TRIG_EXT` when it
previously had to be 0.
Fix the backwards compatibility issue in `ni_ao_inttrig()` by always
allowing software trigger number 0 when `start_src` is something other
than `TRIG_INT`.
Thanks to Spencer Olson for reporting the issue.
Reported-by: Spencer Olson <olsonse@umich.edu>
Fixes: ebb657babfa9 ("staging: comedi: ni_mio_common: clarify the cmd->start_arg validation and use")
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
commit 403fe7f34e3327ddac2e06a15e76a293d613381e upstream.
Commit 73e0e4dfed4c ("staging: comedi: comedi_test: fix timer lock-up")
fixed a lock-up in the timer routine `waveform_ai_timer()` (which was
called `waveform_ai_interrupt()` at the time) caused by
commit 240512474424 ("staging: comedi: comedi_test: use
comedi_handle_events()"). However, it introduced a race condition that
can result in the timer routine misbehaving, such as accessing freed
memory or dereferencing a NULL pointer.
73e0... changed the timer routine to do nothing unless a
`WAVEFORM_AI_RUNNING` flag was set, and changed `waveform_ai_cancel()`
to clear the flag and replace a call to `del_timer_sync()` with a call
to `del_timer()`. `waveform_ai_cancel()` may be called from the timer
routine itself (via `comedi_handle_events()`), or from `do_cancel()`.
(`do_cancel()` is called as a result of a file operation (usually a
`COMEDI_CANCEL` ioctl command, or a release), or during device removal.)
When called from `do_cancel()`, the call to `waveform_ai_cancel()` is
followed by a call to `do_become_nonbusy()`, which frees up stuff for
the current asynchronous command under the assumption that it is now
safe to do so. The race condition occurs when the timer routine
`waveform_ai_timer()` checks the `WAVEFORM_AI_RUNNING` flag just before
it is cleared by `waveform_ai_cancel()`, and is still running during the
call to `do_become_nonbusy()`. In particular, it can lead to a NULL
pointer dereference:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffffc0c63add>] waveform_ai_timer+0x17d/0x290 [comedi_test]
That corresponds to this line in `waveform_ai_timer()`:
unsigned int chanspec = cmd->chanlist[async->cur_chan];
but `do_become_nonbusy()` frees `cmd->chanlist` and sets it to `NULL`.
Fix the race by calling `del_timer_sync()` instead of `del_timer()` in
`waveform_ai_cancel()` when not in an interrupt context. The only time
`waveform_ai_cancel()` is called in an interrupt context is when it is
called from the timer routine itself, via `comedi_handle_events()`.
There is no longer any need for the `WAVEFORM_AI_RUNNING` flag, so get
rid of it.
The bug was copied from the AI subdevice to the AO when support for
commands on the AO subdevice was added by commit 0cf55bbef2f9 ("staging:
comedi: comedi_test: implement commands on AO subdevice"). That
involves the timer routine `waveform_ao_timer()`, the comedi "cancel"
routine `waveform_ao_cancel()`, and the flag `WAVEFORM_AO_RUNNING`. Fix
it in the same way as for the AI subdevice.
Fixes: 73e0e4dfed4c ("staging: comedi: comedi_test: fix timer lock-up")
Fixes: 0cf55bbef2f9 ("staging: comedi: comedi_test: implement commands
on AO subdevice")
Cc: Éric Piel <piel@delmic.com>
commit 80e162ee9b31d77d851b10f8c5299132be1e120f upstream.
`daqboard2000_find_boardinfo()` is supposed to check if the
DaqBoard/2000 series model is supported, based on the PCI subvendor and
subdevice ID. The current code is wrong as it is comparing the PCI
device's subdevice ID to an expected, fixed value for the subvendor ID.
It should be comparing the PCI device's subvendor ID to this fixed
value. Correct it.
Fixes: 7e8401b23e7f ("staging: comedi: daqboard2000: add back subsystem_device check")
commit 40d9c32525cba79130612650b1abc47c0c0f19a8 upstream.
These product IDs are listed in Windows driver.
0x6803 corresponds to WeTelecom WM-D300.
0x6802 name is unknown.
Signed-off-by: Aleksandr Makarov <aleksandr.o.makarov@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 6695593e4a7659db49ac6eca98c164f7b5589f72 upstream.
Add support for WeTelecom WM-D200.
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=22de ProdID=6801 Rev=00.00
S: Manufacturer=WeTelecom Incorporated
S: Product=WeTelecom Mobile Products
C: #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
commit 3b7c7e52efda0d4640060de747768360ba70a7c0 upstream.
There is an allocation with GFP_KERNEL flag in mos7840_write(),
while it may be called from interrupt context.
Follow-up for commit 191252837626 ("USB: kobil_sct: fix non-atomic
allocation in write path")
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
commit 5a5a1d614287a647b36dff3f40c2b0ceabbc83ec upstream.
There is an allocation with GFP_KERNEL flag in mos7720_write(),
commit 6c73358c83ce870c0cf32413e5cadb3b9a39c606 upstream.
The maximum value allowed for wMaxPacketSize of a high-speed interrupt
endpoint is 1024 bytes, not 1023.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Fixes: aed9d65ac327 ("USB: validate wMaxPacketValue entries in endpoint descriptors")
commit c4e94174983a86c935be1537a73e496b778b0287 upstream.
When the controller is configured to be dual role and it's in host mode,
if bind udc and gadgt driver, those gadget operations will do gadget
disconnect and finally pull down DP line, which will break host function.
Signed-off-by: Li Jun <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit 53e5f36fbd2453ad69a3369a1db62dc06c30a4aa upstream.
UBSAN complains about a left shift by -1 in proc_do_submiturb(). This
can occur when an URB is submitted for a bulk or control endpoint on
a high-speed device, since the code doesn't bother to check the
endpoint type; normally only interrupt or isochronous endpoints have
a nonzero bInterval value.
Aside from the fact that the operation is illegal, it shouldn't matter
because the result isn't used. Still, in theory it could cause a
hardware exception or other problem, so we should work around it.
This patch avoids doing the left shift unless the shift amount is >= 0.
The same piece of code has another problem. When checking the device
speed (the exponential encoding for interrupt endpoints is used only
by high-speed or faster devices), we need to look for speed >=
USB_SPEED_SUPER as well as speed == USB_SPEED HIGH. The patch adds
this check.
Reported-by: Vittorio Zecca <zeccav@gmail.com>
Tested-by: Vittorio Zecca <zeccav@gmail.com>
Suggested-by: Bjørn Mork <bjorn@mork.no>
commit 626d2f07de89bf6be3d7301524d0ab3375b81b9c upstream.
The USB-DMAC's interruption happens even if the CHCR.DE is not set to 1
because CHCR.NULLE is set to 1. So, this driver should call
usb_dmac_isr_transfer_end() if the DE bit is set to 1 only. Otherwise,
the desc is possible to be NULL in the usb_dmac_isr_transfer_end().
Fixes: 0c1c8ff32fa2 ("dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver)
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 10bb087ce381c812cd81a65ffd5e6f83e6399291 upstream.
Increase value of supported key sizes for qat_aes_xts.
aes-xts keys consists of keys of equal size concatenated.
Fixes: def14bfaf30d ("crypto: qat - add support for ctr(aes) and xts(aes)")
Reported-by: Wenqian Yu <wenqian.yu@intel.com>
Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com>
commit e514cc0a492a3f39ef71b31590a7ef67537ee04b upstream.
The props->ap[] array is defined like this:
struct alg_props ap[NX_MAX_FC][NX_MAX_MODE][3];
So we can see that if msc->fc and msc->mode are == to NX_MAX_FC or
NX_MAX_MODE then we're off by one.
Fixes: ae0222b7289d ('powerpc/crypto: nx driver code supporting nx encryption')
commit 47af45d684b5f3ae000ad448db02ce4f13f73273 upstream.
The commit 4097461897df ("Input: i8042 - break load dependency ...")
correctly set up ps2_cmd_mutex pointer for the KBD port but forgot to do
the same for AUX port(s), which results in communication on KBD and AUX
ports to clash with each other.
Fixes: 4097461897df ("Input: i8042 - break load dependency ...")
Reported-by: Bruno Wolff III <bruno@wolff.to>
Tested-by: Bruno Wolff III <bruno@wolff.to>
commit 4097461897df91041382ff6fcd2bfa7ee6b2448c upstream.
As explained in 1407814240-4275-1-git-send-email-decui@microsoft.com we
have a hard load dependency between i8042 and atkbd which prevents
keyboard from working on Gen2 Hyper-V VMs.
> hyperv_keyboard invokes serio_interrupt(), which needs a valid serio
> driver like atkbd.c. atkbd.c depends on libps2.c because it invokes
> ps2_command(). libps2.c depends on i8042.c because it invokes
> i8042_check_port_owner(). As a result, hyperv_keyboard actually
> depends on i8042.c.
> For a Generation 2 Hyper-V VM (meaning no i8042 device emulated), if a
> Linux VM (like Arch Linux) happens to configure CONFIG_SERIO_I8042=m
> rather than =y, atkbd.ko can't load because i8042.ko can't load(due to
> no i8042 device emulated) and finally hyperv_keyboard can't work and
> the user can't input: https://bugs.archlinux.org/task/39820
> (Ubuntu/RHEL/SUSE aren't affected since they use CONFIG_SERIO_I8042=y)
To break the dependency we move away from using i8042_check_port_owner()
and instead allow serio port owner specify a mutex that clients should use
to serialize PS/2 command stream.
Reported-by: Mark Laws <mdl@60hz.org>
Tested-by: Mark Laws <mdl@60hz.org>
commit fae16989be77b09bab86c79233e4b511ea769cea upstream.
Commit fe6b0dfaba68 ("Input: tegra-kbc - use reset framework")
accidentally converted _deassert to _assert, so there is no code
to wake up this hardware.
Fixes: fe6b0dfaba68 ("Input: tegra-kbc - use reset framework")
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
commit d2c609b834d62f1e91f1635a27dca29f7806d3d6 upstream.
The qgroup_flags field is overloaded such that it reflects the on-disk
status of qgroups and the runtime state. The BTRFS_QGROUP_STATUS_FLAG_RESCAN
flag is used to indicate that a rescan operation is in progress, but if
the file system is unmounted while a rescan is running, the rescan
operation is paused. If the file system is then mounted read-only,
the flag will still be present but the rescan operation will not have
been resumed. When we go to umount, btrfs_qgroup_wait_for_completion
will see the flag and interpret it to mean that the rescan worker is
still running and will wait for a completion that will never come.
This patch uses a separate flag to indicate when the worker is
running. The locking and state surrounding the qgroup rescan worker
needs a lot of attention beyond this patch but this is enough to
avoid a hung umount.
Signed-off-by; Jeff Mahoney <jeffm@suse.com>
Reviewed-by: Qu Wenruo <quwenruo@cn.fujitsu.com>
Signed-off-by: David Sterba <dsterba@suse.com>
Signed-off-by: Chris Mason <clm@fb.com>
commit d06f23d6a947c9abae41dc46be69a56baf36f436 upstream.
We wait on qgroup rescan completion in three places: file system
shutdown, the quota disable ioctl, and the rescan wait ioctl. If the
user sends a signal while we're waiting, we continue happily along. This
is expected behavior for the rescan wait ioctl. It's racy in the shutdown
path but mostly works due to other unrelated synchronization points.
In the quota disable path, it Oopses the kernel pretty much immediately.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
commit 088bf2ff5d12e2e32ee52a4024fec26e582f44d3 upstream.
seq_read() is a nasty piece of work, not to mention buggy.
It has (I think) an old bug which allows unprivileged userspace to read
beyond the end of m->buf.
I was getting these:
BUG: KASAN: slab-out-of-bounds in seq_read+0xcd2/0x1480 at addr ffff880116889880
Read of size 2713 by task trinity-c2/1329
CPU: 2 PID: 1329 Comm: trinity-c2 Not tainted 4.8.0-rc1+ #96
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
Call Trace:
kasan_object_err+0x1c/0x80
kasan_report_error+0x2cb/0x7e0
kasan_report+0x4e/0x80
check_memory_region+0x13e/0x1a0
kasan_check_read+0x11/0x20
proc_reg_read+0x10b/0x260
do_loop_readv_writev.part.5+0x140/0x2c0
do_readv_writev+0x589/0x860
vfs_readv+0x7b/0xd0
do_readv+0xd8/0x2c0
SyS_readv+0xb/0x10
do_syscall_64+0x1b3/0x4b0
entry_SYSCALL64_slow_path+0x25/0x25
Object at ffff880116889100, in cache kmalloc-4096 size: 4096
Allocated:
PID = 1329
save_stack_trace+0x26/0x80
save_stack+0x46/0xd0
kasan_kmalloc+0xad/0xe0
__kmalloc+0x1aa/0x4a0
seq_buf_alloc+0x35/0x40
seq_read+0x7d8/0x1480
vfs_readv+0x7b/0xd0
do_readv+0xd8/0x2c0
SyS_readv+0xb/0x10
return_from_SYSCALL_64+0x0/0x6a
Freed:
PID = 0
(stack is not available)
Memory state around the buggy address:
ffff88011688a000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff88011688a080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff88011688a100: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88011688a180: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88011688a200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Disabling lock debugging due to kernel taint
This seems to be the same thing that Dave Jones was seeing here:
https://lkml.org/lkml/2016/8/12/334
There are multiple issues here:
1) If we enter the function with a non-empty buffer, there is an attempt
to flush it. But it was not clearing m->from after doing so, which
means that if we try to do this flush twice in a row without any call
to traverse() in between, we are going to be reading from the wrong
place -- the splat above, fixed by this patch.
2) If there's a short write to userspace because of page faults, the
buffer may already contain multiple lines (i.e. pos has advanced by
more than 1), but we don't save the progress that was made so the
next call will output what we've already returned previously. Since
that is a much less serious issue (and I have a headache after
staring at seq_read() for the past 8 hours), I'll leave that for now.
Link: http://lkml.kernel.org/r/1471447270-32093-1-git-send-email-vegard.nossum@oracle.com
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Reported-by: Dave Jones <davej@codemonkey.org.uk>
commit 2527ecc9195e9c66252af24c4689e8a67cd4ccb9 upstream.
The UserMode (UM) Linux build was failing in gpiolib-of as it requires
ioremap()/iounmap() to exist, which is absent from UM. The non-existence
of IO memory is negatively defined as CONFIG_NO_IOMEM which means we
need to depend on HAS_IOMEM.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
commit 3295235fd70ed6d594aadee8c892a14f6a4b2d2e upstream.
In case of error, the function usb_get_phy() returns ERR_PTR() and never
returns NULL. The NULL test in the return value check should be replaced
with IS_ERR().
Fixes: b5a2875605ca ("usb: renesas_usbhs: Allow an OTG PHY driver to
provide VBUS")
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit e7f851684efb3377e9c93aca7fae6e76212e5680 upstream.
Found one megaraid_sas HBA probe fails,
[ 187.235190] scsi host2: Avago SAS based MegaRAID driver
[ 191.112365] megaraid_sas 0000:89:00.0: BAR 0: can't reserve [io 0x0000-0x00ff]
[ 191.120548] megaraid_sas 0000:89:00.0: IO memory region busy!
and the card has resource like,
[ 125.097714] pci 0000:89:00.0: [1000:005d] type 00 class 0x010400
[ 125.104446] pci 0000:89:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 125.110686] pci 0000:89:00.0: reg 0x14: [mem 0xce400000-0xce40ffff 64bit]
[ 125.118286] pci 0000:89:00.0: reg 0x1c: [mem 0xce300000-0xce3fffff 64bit]
[ 125.125891] pci 0000:89:00.0: reg 0x30: [mem 0xce200000-0xce2fffff pref]
that does not io port resource allocated from BIOS, and kernel can not
assign one as io port shortage.
The driver is only looking for MEM, and should not fail.
It turns out megasas_init_fw() etc are using bar index as mask. index 1
is used as mask 1, so that pci_request_selected_regions() is trying to
request BAR0 instead of BAR1.
Fix all related reference.
Fixes: b6d5d8808b4c ("megaraid_sas: Use lowest memory bar for SR-IOV VF support")
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Kashyap Desai <kashyap.desai@broadcom.com>
commit ce7c6c9e1d997a2670aead3a7b87f4df32c11118 upstream.
mpt3sas crashes on resume after suspend with WarpDrive flash cards. The
reply_post_host_index array is not set back up after the resume, and we
deference a stale pointer in _base_interrupt().
[ 47.309711] BUG: unable to handle kernel paging request at ffffc90001f8006c
[ 47.318289] IP: [<ffffffffc00863ef>] _base_interrupt+0x49f/0xa30 [mpt3sas]
[ 47.326749] PGD 41ccaa067 PUD 41ccab067 PMD 3466c067 PTE 0
[ 47.333848] Oops: 0002 [#1] SMP
[ 47.452708] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.7.0 #6
[ 47.460506] Hardware name: Dell Inc. OptiPlex 990/06D7TR, BIOS A18 09/24/2013
[ 47.469629] task: ffffffff81c0d500 ti: ffffffff81c00000 task.ti: ffffffff81c00000
[ 47.479112] RIP: 0010:[<ffffffffc00863ef>] [<ffffffffc00863ef>] _base_interrupt+0x49f/0xa30 [mpt3sas]
[ 47.490466] RSP: 0018:ffff88041d203e30 EFLAGS: 00010002
[ 47.497801] RAX: 0000000000000001 RBX: ffff880033f4c000 RCX: 0000000000000001
[ 47.506973] RDX: ffffc90001f8006c RSI: 0000000000000082 RDI: 0000000000000082
[ 47.516141] RBP: ffff88041d203eb0 R08: ffff8804118e2820 R09: 0000000000000001
[ 47.525300] R10: 0000000000000001 R11: 00000000100c0000 R12: 0000000000000000
[ 47.534457] R13: ffff880412c487e0 R14: ffff88041a8987d8 R15: 0000000000000001
[ 47.543632] FS: 0000000000000000(0000) GS:ffff88041d200000(0000) knlGS:0000000000000000
[ 47.553796] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 47.561632] CR2: ffffc90001f8006c CR3: 0000000001c06000 CR4: 00000000000406f0
[ 47.570883] Stack:
[ 47.575015] 000000001d211228 ffff88041d2100c0 ffff8800c47d8130 0000000000000100
[ 47.584625] ffff8804100c0000 100c000000000000 ffff88041a8992a0 ffff88041a8987f8
[ 47.594230] ffff88041d203e00 ffffffff81111e55 000000000000038c ffff880414ad4280
[ 47.603862] Call Trace:
[ 47.608474] <IRQ>
[ 47.610413] [<ffffffff81111e55>] ? call_timer_fn+0x35/0x120
[ 47.620539] [<ffffffff81100a1f>] handle_irq_event_percpu+0x7f/0x1c0
[ 47.629061] [<ffffffff81100b8c>] handle_irq_event+0x2c/0x50
[ 47.636859] [<ffffffff81103fff>] handle_edge_irq+0x6f/0x130
[ 47.644654] [<ffffffff8102fbf3>] handle_irq+0x73/0x120
[ 47.652011] [<ffffffff810c6ada>] ? atomic_notifier_call_chain+0x1a/0x20
[ 47.660854] [<ffffffff817e374b>] do_IRQ+0x4b/0xd0
[ 47.667777] [<ffffffff817e160c>] common_interrupt+0x8c/0x8c
[ 47.675635] <EOI>
Move the reply_post_host_index array setup into
mpt3sas_base_map_resources(), which is also in the resume path.
Signed-off-by: Greg Edwards <gedwards@fireweed.org>
Acked-by: Chaitra P B <chaitra.basappa@broadcom.com>
commit add125054b8727103631dce116361668436ef6a7 upstream.
This fixes the "BOGUS urb xfer" warning logged by usb_submit_urb().
Signed-off-by: Gavin Li <git@thegavinli.com>
Acked-by: Oliver Neukum <oneukum@suse.com>
commit 4d01d88019261d05ec3bff5f1a6013393faa3b9e upstream.
cros_ec_cmd_xfer returns success status if the command transport
completes successfully, but the execution result is incorrectly ignored.
In many cases, the execution result is assumed to be successful, leading
to ignored errors and operating on uninitialized data.
We've recently introduced the cros_ec_cmd_xfer_status() helper to avoid these
problems. Let's use it.
[Regarding the 'Fixes' tag; there is significant refactoring since the driver's
introduction, but the underlying logical error exists throughout I believe]
Fixes: 9d230c9e4f4e ("i2c: ChromeOS EC tunnel driver")
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 9798ac6d32c1a32d6d92d853ff507d2d39c4300c upstream.
So that callers of cros_ec_cmd_xfer() don't have to repeat boilerplate
code when checking for errors from the EC side.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Reviewed-by: Benson Leung <bleung@chromium.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Tested-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
commit fa00c437eef8dc2e7b25f8cd868cfa405fcc2bb3 upstream.
In aacraid's ioctl_send_fib() we do two fetches from userspace, one the
get the fib header's size and one for the fib itself. Later we use the
size field from the second fetch to further process the fib. If for some
reason the size from the second fetch is different than from the first
fix, we may encounter an out-of- bounds access in aac_fib_send(). We
also check the sender size to insure it is not out of bounds. This was
reported in https://bugzilla.kernel.org/show_bug.cgi?id=116751 and was
assigned CVE-2016-6480.
Reported-by: Pengfei Wang <wpengfeinudt@gmail.com>
Fixes: 7c00ffa31 '[SCSI] 2.6 aacraid: Variable FIB size (updated patch)'
Signed-off-by: Dave Carroll <david.carroll@microsemi.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 45c3b08a117e2232fc8d7b9e849ead36386f4f96 upstream.
For resources shared by all cores such as SLC and IOC, only the master
core needs to do any setups / enabling / disabling etc.
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 18b43e89d295cc65151c505c643c98fb2c320e59 upstream.
trace_hardirqs_on_caller() in lockdep.c expects to be called before, not
after interrupts are actually enabled.
The following comment in kernel/locking/lockdep.c substantiates this
claim:
* We're enabling irqs and according to our state above irqs weren't
* already enabled, yet we find the hardware thinks they are in fact
* enabled.. someone messed up their IRQ state tracing.
An example can be found in include/linux/irqflags.h:
do { trace_hardirqs_on(); raw_local_irq_enable(); } while (0)
Without this change, we hit the following DEBUG_LOCKS_WARN_ON.
[ 7.760000] ------------[ cut here ]------------
[ 7.760000] WARNING: CPU: 0 PID: 1 at kernel/locking/lockdep.c:2711 resume_user_mode_begin+0x48/0xf0
[ 7.770000] DEBUG_LOCKS_WARN_ON(!irqs_disabled())
[ 7.780000] Modules linked in:
[ 7.780000] CPU: 0 PID: 1 Comm: init Not tainted 4.7.0-00003-gc668bb9-dirty #366
[ 7.790000]
[ 7.790000] Stack Trace:
[ 7.790000] arc_unwind_core.constprop.1+0xa4/0x118
[ 7.800000] warn_slowpath_fmt+0x72/0x158
[ 7.800000] resume_user_mode_begin+0x48/0xf0
[ 7.810000] ---[ end trace 6f6a7a8fae20d2f0 ]---
Signed-off-by: Daniel Mentz <danielmentz@google.com>
commit 86147e3cfa5e118b61e78f4f0bf29e920dcbd477 upstream.
User mode callee regs are explicitly collected before signal delivery or
breakpoint trap. r25 is special for kernel as it serves as task pointer,
so user mode value is clobbered very early. It is saved in pt_regs where
generally only scratch (aka caller saved) regs are saved.
The code to access the corresponding pt_regs location had a subtle bug as
it was using load/store with scaling of offset, whereas the offset was already
byte wise correct. So fix this by replacing LD.AS with a standard LD
Signed-off-by: Liav Rehana <liavr@mellanox.com>
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
[vgupta: rewrote title and commit log]
commit 20d780374c81cf237834af2202c26df2100ddd69 upstream.
ARC architecture has 2 instruction sets: ARCompact/ARCv2.
While same gcc supports compiling for either (using appropriate toggles),
we can't use the same toolchain to build kernel because libgcc needs
to be unique and the toolchian (uClibc based) is not multilibed.
uClibc toolchain is convenient since it allows all userspace and
kernel to be built with a single install for an ISA.
This however means 2 gnu installs (with same triplet prefix) are needed
for building for 2 ISA and need to be in PATH.
As developers we keep switching the builds, but would occassionally fail
to update the PATH leading to usage of wrong tools. And this would only
show up at the end of kernel build when linking incompatible libgcc.
So the initial solution was to have gcc define a special preprocessor macro
DEFAULT_CPU_xxx which is unique for default toolchain configuration.
Claudiu proposed using grep for an existing preprocessor macro which is
again uniquely defined per ISA.
Cc: Michal Marek <mmarek@suse.cz>
Suggested-by: Claudiu Zissulescu <claziss@synopsys.com>
commit 3871f42a57efcdc6a9da751a8cb6fa196c212289 upstream.
In i915_ggtt_cleanup_hw we need to remember to free aliasing_ppgtt. This
fixes the following kmemleak message:
unreferenced object 0xffff880213cca000 (size 8192):
comm "modprobe", pid 1298, jiffies 4294745402 (age 703.930s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff817c808e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff8121f9c2>] kmem_cache_alloc_trace+0x142/0x1d0
[<ffffffffa06d11ef>] i915_gem_init_ggtt+0x10f/0x210 [i915]
[<ffffffffa06d71bb>] i915_gem_init+0x5b/0xd0 [i915]
[<ffffffffa069749a>] i915_driver_load+0x97a/0x1460 [i915]
[<ffffffffa06a26ef>] i915_pci_probe+0x4f/0x70 [i915]
[<ffffffff81423015>] local_pci_probe+0x45/0xa0
[<ffffffff81424463>] pci_device_probe+0x103/0x150
[<ffffffff81515e6c>] driver_probe_device+0x22c/0x440
[<ffffffff81516151>] __driver_attach+0xd1/0xf0
[<ffffffff8151379c>] bus_for_each_dev+0x6c/0xc0
[<ffffffff8151555e>] driver_attach+0x1e/0x20
[<ffffffff81514fa3>] bus_add_driver+0x1c3/0x280
[<ffffffff81516aa0>] driver_register+0x60/0xe0
[<ffffffff8142297c>] __pci_register_driver+0x4c/0x50
[<ffffffffa013605b>] 0xffffffffa013605b
Signed-off-by: Matthew Auld <matthew.auld@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Fixes: b18b6bde300e ("drm/i915/bdw: Free PPGTT struct")
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1470420280-21417-1-git-send-email-matthew.auld@intel.com
(cherry picked from commit cb7f27601c81a1e0454e9461e96f65b31fafbea0)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 1f703e6679f373f5bba4efe7093aa82e91af4037 upstream.
Otherwise we may miss errors.
Signed-off-by: Chunming Zhou <David1.Zhou@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 10ea9434065e56fe14287f89258ecf2fb684ed1a upstream.
SDMA could be fail in the thaw() and restore() processes, do software reset
if each SDMA engine is busy.
Signed-off-by: JimQu <Jim.Qu@amd.com>
commit 611a1507fe8569ce1adab3abc982ea58ab559fb9 upstream.
No asics supported by amdgpu support analog TV.
Workaround for bug:
https://bugs.freedesktop.org/show_bug.cgi?id=97460
commit e1718d97aa88ea44a6a8f50ff464253dd0dacf01 upstream.
When looking up the connector type make sure the index
is valid. Avoids a later crash if we read past the end
of the array.
Workaround for bug:
commit 815d27a46f3119f74fe01fe10bf683aa5bc55597 upstream.
This bug seems to be present for a very long time.
Signed-off-by: Christian König <christian.koenig@amd.com>
commit cab0b8d50e9bbef62c04067072c953433a87a9ff upstream.
The GART aperture size can be bigger than 4GB. Therefore the offset
used in amdgpu_gart_bind and amdgpu_gart_unbind must be 64-bit.
Signed-off-by: Felix Kuehling <Felix.Kuehling@amd.com>
commit fcf68f3c0bb2a541aa47a2a38b8939edf84fd529 upstream.
When using CONFIG_DEBUG_ATOMIC_SLEEP, the scheduler nicely points out
that we're calling sleeping primitives within the wait_event loop, which
means we might clobber the task state:
[ 10.831289] do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffc00026b610>]
[ 10.845531] ------------[ cut here ]------------
[ 10.850161] WARNING: at kernel/sched/core.c:7630
[ 12.164333] ---[ end trace 45409966a9a76438 ]---
[ 12.168942] Call trace:
[ 12.171391] [<ffffffc00024ed44>] __might_sleep+0x64/0x90
[ 12.176699] [<ffffffc000954774>] mutex_lock_nested+0x50/0x3fc
[ 12.182440] [<ffffffc0007b9424>] iio_kfifo_buf_data_available+0x28/0x4c
[ 12.189043] [<ffffffc0007b76ac>] iio_buffer_ready+0x60/0xe0
[ 12.194608] [<ffffffc0007b7834>] iio_buffer_read_first_n_outer+0x108/0x1a8
[ 12.201474] [<ffffffc000370d48>] __vfs_read+0x58/0x114
[ 12.206606] [<ffffffc000371740>] vfs_read+0x94/0x118
[ 12.211564] [<ffffffc0003720f8>] SyS_read+0x64/0xb4
[ 12.216436] [<ffffffc000203cb4>] el0_svc_naked+0x24/0x28
To avoid this, we should (a la https://lwn.net/Articles/628628/) use the
wait_woken() function, which avoids the nested sleeping while still
handling races between waiting / wake-events.
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
