2018-09-19Linux 4.4.157v4.4.157Greg Kroah-Hartman
2018-09-19mm: get rid of vmacache_flush_all() entirelyLinus Torvalds
commit 7a9cdebdcc17e426fb5287e4a82db1dfe86339b2 upstream. Jann Horn points out that the vmacache_flush_all() function is not only potentially expensive, it's buggy too. It also happens to be entirely unnecessary, because the sequence number overflow case can be avoided by simply making the sequence number be 64-bit. That doesn't even grow the data structures in question, because the other adjacent fields are already 64-bit. So simplify the whole thing by just making the sequence number overflow case go away entirely, which gets rid of all the complications and makes the code faster too. Win-win. [ Oleg Nesterov points out that the VMACACHE_FULL_FLUSHES statistics also just goes away entirely with this ] Reported-by: Jann Horn <jannh@google.com> Suggested-by: Will Deacon <will.deacon@arm.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19x86/speculation/l1tf: Increase l1tf memory limit for Nehalem+Andi Kleen
[upstream cc51e5428ea54f575d49cfcede1d4cb3a72b4ec4 for 4.4. Note there might be still a trivial conflict with the backport for b0a182f875689647b014bc01d36b340217792852, but should be easy to resolve] On Nehalem and newer core CPUs the CPU cache internally uses 44 bits physical address space. The L1TF workaround is limited by this internal cache address width, and needs to have one bit free there for the mitigation to work. Older client systems report only 36bit physical address space so the range check decides that L1TF is not mitigated for a 36bit phys/32GB system with some memory holes. But since these actually have the larger internal cache width this warning is bogus because it would only really be needed if the system had more than 43bits of memory. Add a new internal x86_cache_bits field. Normally it is the same as the physical bits field reported by CPUID, but for Nehalem and newerforce it to be at least 44bits. Change the L1TF memory size warning to use the new cache_bits field to avoid bogus warnings and remove the bogus comment about memory size. Fixes: 17dbca119312 ("x86/speculation/l1tf: Add sysfs reporting for l1tf") Reported-by: George Anchev <studio@anchev.net> Reported-by: Christopher Snowhill <kode54@gmail.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: x86@kernel.org Cc: linux-kernel@vger.kernel.org Cc: Michael Hocko <mhocko@suse.com> Cc: vbabka@suse.cz Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180824170351.34874-1-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19autofs: fix autofs_sbi() does not check super block typeIan Kent
commit 0633da48f0793aeba27f82d30605624416723a91 upstream. autofs_sbi() does not check the superblock magic number to verify it has been given an autofs super block. Backport Note: autofs4 has been renamed to autofs upstream. As a result the upstream patch does not apply cleanly onto 4.14.y. Link: http://lkml.kernel.org/r/153475422934.17131.7563724552005298277.stgit@pluto.themaw.net Reported-by: <syzbot+87c3c541582e56943277@syzkaller.appspotmail.com> Signed-off-by: Ian Kent <raven@themaw.net> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Zubin Mithra <zsm@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19mtd: ubi: wl: Fix error return code in ubi_wl_init()Wei Yongjun
commit 7233982ade15eeac05c6f351e8d347406e6bcd2f upstream. Fix to return error code -ENOMEM from the kmem_cache_alloc() error handling case instead of 0, as done elsewhere in this function. Fixes: f78e5623f45b ("ubi: fastmap: Erase outdated anchor PEBs during attach") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Richard Weinberger <richard@nod.at> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19crypto: vmx - Fix sleep-in-atomic bugsOndrej Mosnacek
commit 0522236d4f9c5ab2e79889cb020d1acbe5da416e upstream. This patch fixes sleep-in-atomic bugs in AES-CBC and AES-XTS VMX implementations. The problem is that the blkcipher_* functions should not be called in atomic context. The bugs can be reproduced via the AF_ALG interface by trying to encrypt/decrypt sufficiently large buffers (at least 64 KiB) using the VMX implementations of 'cbc(aes)' or 'xts(aes)'. Such operations then trigger BUG in crypto_yield(): [ 891.863680] BUG: sleeping function called from invalid context at include/crypto/algapi.h:424 [ 891.864622] in_atomic(): 1, irqs_disabled(): 0, pid: 12347, name: kcapi-enc [ 891.864739] 1 lock held by kcapi-enc/12347: [ 891.864811] #0: 00000000f5d42c46 (sk_lock-AF_ALG){+.+.}, at: skcipher_recvmsg+0x50/0x530 [ 891.865076] CPU: 5 PID: 12347 Comm: kcapi-enc Not tainted 4.19.0-0.rc0.git3.1.fc30.ppc64le #1 [ 891.865251] Call Trace: [ 891.865340] [c0000003387578c0] [c000000000d67ea4] dump_stack+0xe8/0x164 (unreliable) [ 891.865511] [c000000338757910] [c000000000172a58] ___might_sleep+0x2f8/0x310 [ 891.865679] [c000000338757990] [c0000000006bff74] blkcipher_walk_done+0x374/0x4a0 [ 891.865825] [c0000003387579e0] [d000000007e73e70] p8_aes_cbc_encrypt+0x1c8/0x260 [vmx_crypto] [ 891.865993] [c000000338757ad0] [c0000000006c0ee0] skcipher_encrypt_blkcipher+0x60/0x80 [ 891.866128] [c000000338757b10] [c0000000006ec504] skcipher_recvmsg+0x424/0x530 [ 891.866283] [c000000338757bd0] [c000000000b00654] sock_recvmsg+0x74/0xa0 [ 891.866403] [c000000338757c10] [c000000000b00f64] ___sys_recvmsg+0xf4/0x2f0 [ 891.866515] [c000000338757d90] [c000000000b02bb8] __sys_recvmsg+0x68/0xe0 [ 891.866631] [c000000338757e30] [c00000000000bbe4] system_call+0x5c/0x70 Fixes: 8c755ace357c ("crypto: vmx - Adding CBC routines for VMX module") Fixes: c07f5d3da643 ("crypto: vmx - Adding support for XTS") Cc: stable@vger.kernel.org Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19ethernet: ti: davinci_emac: add missing of_node_put after calling ↵Peter Chen
of_parse_phandle commit 5817f977527e5cdbea9ca56d2b95824f59c8747d upstream. of_node_put needs to be called when the device node which is got from of_parse_phandle has finished using. Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19net: ethernet: ti: cpsw: fix mdio device reference leakJohan Hovold
commit 86e1d5adcef961eb383ce4eacbe0ef22f06e2045 upstream. Make sure to drop the reference taken by of_find_device_by_node() when looking up an mdio device from a phy_id property during probe. Fixes: 549985ee9c72 ("cpsw: simplify the setup of the register pointers") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19drivers: net: cpsw: fix parsing of phy-handle DT property in dual_emac configDavid Rivshin
commit 552165bcf7060b998b4a9b5b86110b6a5e04dfd9 upstream. Commit 9e42f715264ff158478fa30eaed847f6e131366b ("drivers: net: cpsw: add phy-handle parsing") saved the "phy-handle" phandle into a new cpsw_priv field. However, phy connections are per-slave, so the phy_node field should be in cpsw_slave_data rather than cpsw_priv. This would go unnoticed in a single emac configuration. But in dual_emac mode, the last "phy-handle" property parsed for either slave would be used by both of them, causing them both to refer to the same phy_device. Fixes: 9e42f715264f ("drivers: net: cpsw: add phy-handle parsing") Signed-off-by: David Rivshin <drivshin@allworx.com> Tested-by: Nicolas Chauvet <kwizart@gmail.com> Tested-by: Andrew Goodbody <andrew.goodbody@cambrionix.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19netfilter: x_tables: avoid stack-out-of-bounds read in ↵Eric Dumazet
xt_copy_counters_from_user commit e466af75c074e76107ae1cd5a2823e9c61894ffb upstream. syzkaller reports an out of bound read in strlcpy(), triggered by xt_copy_counters_from_user() Fix this by using memcpy(), then forcing a zero byte at the last position of the destination, as Florian did for the non COMPAT code. Fixes: d7591f0c41ce ("netfilter: x_tables: introduce and use xt_copy_counters_from_user") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19vmw_balloon: include asm/io.hNadav Amit
Fix a build error due to missing virt_to_phys() Reported-by: kbuild test robot <lkp@intel.com> Fixes: f0a1bf29d821b ("vmw_balloon: fix inflation with batching") Cc: stable@vger.kernel.org Cc: Xavier Deguillard <xdeguillard@vmware.com> Signed-off-by: Nadav Amit <namit@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19xhci: Fix use-after-free in xhci_free_virt_deviceMathias Nyman
commit 44a182b9d17765514fa2b1cc911e4e65134eef93 upstream. KASAN found a use-after-free in xhci_free_virt_device+0x33b/0x38e where xhci_free_virt_device() sets slot id to 0 if udev exists: if (dev->udev && dev->udev->slot_id) dev->udev->slot_id = 0; dev->udev will be true even if udev is freed because dev->udev is not set to NULL. set dev->udev pointer to NULL in xhci_free_dev() The original patch went to stable so this fix needs to be applied there as well. Fixes: a400efe455f7 ("xhci: zero usb device slot_id member when disabling and freeing a xhci slot") Cc: <stable@vger.kernel.org> Reported-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19RDMA/cma: Do not ignore net namespace for unbound cm_idParav Pandit
[ Upstream commit 643d213a9a034fa04f5575a40dfc8548e33ce04f ] Currently if the cm_id is not bound to any netdevice, than for such cm_id, net namespace is ignored; which is incorrect. Regardless of cm_id bound to a netdevice or not, net namespace must match. When a cm_id is bound to a netdevice, in such case net namespace and netdevice both must match. Fixes: 4c21b5bcef73 ("IB/cma: Add net_dev and private data checks to RDMA CM") Signed-off-by: Parav Pandit <parav@mellanox.com> Reviewed-by: Daniel Jurgens <danielj@mellanox.com> Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19MIPS: WARN_ON invalid DMA cache maintenance, not BUG_ONPaul Burton
[ Upstream commit d4da0e97baea8768b3d66ccef3967bebd50dfc3b ] If a driver causes DMA cache maintenance with a zero length then we currently BUG and kill the kernel. As this is a scenario that we may well be able to recover from, WARN & return in the condition instead. Signed-off-by: Paul Burton <paul.burton@mips.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/14623/ Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19f2fs: fix to do sanity check with {sit,nat}_ver_bitmap_bytesizeChao Yu
[ Upstream commit c77ec61ca0a49544ca81881cc5d5529858f7e196 ] This patch adds to do sanity check with {sit,nat}_ver_bitmap_bytesize during mount, in order to avoid accessing across cache boundary with this abnormal bitmap size. - Overview buffer overrun in build_sit_info() when mounting a crafted f2fs image - Reproduce - Kernel message [ 548.580867] F2FS-fs (loop0): Invalid log blocks per segment (8201) [ 548.580877] F2FS-fs (loop0): Can't find valid F2FS filesystem in 1th superblock [ 548.584979] ================================================================== [ 548.586568] BUG: KASAN: use-after-free in kmemdup+0x36/0x50 [ 548.587715] Read of size 64 at addr ffff8801e9c265ff by task mount/1295 [ 548.589428] CPU: 1 PID: 1295 Comm: mount Not tainted 4.18.0-rc1+ #4 [ 548.589432] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014 [ 548.589438] Call Trace: [ 548.589474] dump_stack+0x7b/0xb5 [ 548.589487] print_address_description+0x70/0x290 [ 548.589492] kasan_report+0x291/0x390 [ 548.589496] ? kmemdup+0x36/0x50 [ 548.589509] check_memory_region+0x139/0x190 [ 548.589514] memcpy+0x23/0x50 [ 548.589518] kmemdup+0x36/0x50 [ 548.589545] f2fs_build_segment_manager+0x8fa/0x3410 [ 548.589551] ? __asan_loadN+0xf/0x20 [ 548.589560] ? f2fs_sanity_check_ckpt+0x1be/0x240 [ 548.589566] ? f2fs_flush_sit_entries+0x10c0/0x10c0 [ 548.589587] ? __put_user_ns+0x40/0x40 [ 548.589604] ? find_next_bit+0x57/0x90 [ 548.589610] f2fs_fill_super+0x194b/0x2b40 [ 548.589617] ? f2fs_commit_super+0x1b0/0x1b0 [ 548.589637] ? set_blocksize+0x90/0x140 [ 548.589651] mount_bdev+0x1c5/0x210 [ 548.589655] ? f2fs_commit_super+0x1b0/0x1b0 [ 548.589667] f2fs_mount+0x15/0x20 [ 548.589672] mount_fs+0x60/0x1a0 [ 548.589683] ? alloc_vfsmnt+0x309/0x360 [ 548.589688] vfs_kern_mount+0x6b/0x1a0 [ 548.589699] do_mount+0x34a/0x18c0 [ 548.589710] ? lockref_put_or_lock+0xcf/0x160 [ 548.589716] ? copy_mount_string+0x20/0x20 [ 548.589728] ? memcg_kmem_put_cache+0x1b/0xa0 [ 548.589734] ? kasan_check_write+0x14/0x20 [ 548.589740] ? _copy_from_user+0x6a/0x90 [ 548.589744] ? memdup_user+0x42/0x60 [ 548.589750] ksys_mount+0x83/0xd0 [ 548.589755] __x64_sys_mount+0x67/0x80 [ 548.589781] do_syscall_64+0x78/0x170 [ 548.589797] entry_SYSCALL_64_after_hwframe+0x44/0xa9 [ 548.589820] RIP: 0033:0x7f76fc331b9a [ 548.589821] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48 [ 548.589880] RSP: 002b:00007ffd4f0a0e48 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5 [ 548.589890] RAX: ffffffffffffffda RBX: 000000000146c030 RCX: 00007f76fc331b9a [ 548.589892] RDX: 000000000146c210 RSI: 000000000146df30 RDI: 0000000001474ec0 [ 548.589895] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013 [ 548.589897] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 0000000001474ec0 [ 548.589900] R13: 000000000146c210 R14: 0000000000000000 R15: 0000000000000003 [ 548.590242] The buggy address belongs to the page: [ 548.591243] page:ffffea0007a70980 count:0 mapcount:0 mapping:0000000000000000 index:0x0 [ 548.592886] flags: 0x2ffff0000000000() [ 548.593665] raw: 02ffff0000000000 dead000000000100 dead000000000200 0000000000000000 [ 548.595258] raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000 [ 548.603713] page dumped because: kasan: bad access detected [ 548.605203] Memory state around the buggy address: [ 548.606198] ffff8801e9c26480: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [ 548.607676] ffff8801e9c26500: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [ 548.609157] >ffff8801e9c26580: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [ 548.610629] ^ [ 548.612088] ffff8801e9c26600: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [ 548.613674] ffff8801e9c26680: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [ 548.615141] ================================================================== [ 548.616613] Disabling lock debugging due to kernel taint [ 548.622871] WARNING: CPU: 1 PID: 1295 at mm/page_alloc.c:4065 __alloc_pages_slowpath+0xe4a/0x1420 [ 548.622878] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy [ 548.623217] CPU: 1 PID: 1295 Comm: mount Tainted: G B 4.18.0-rc1+ #4 [ 548.623219] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014 [ 548.623226] RIP: 0010:__alloc_pages_slowpath+0xe4a/0x1420 [ 548.623227] Code: ff ff 01 89 85 c8 fe ff ff e9 91 fc ff ff 41 89 c5 e9 5c fc ff ff 0f 0b 89 f8 25 ff ff f7 ff 89 85 8c fe ff ff e9 d5 f2 ff ff <0f> 0b e9 65 f2 ff ff 65 8b 05 38 81 d2 47 f6 c4 01 74 1c 65 48 8b [ 548.623281] RSP: 0018:ffff8801f28c7678 EFLAGS: 00010246 [ 548.623284] RAX: 0000000000000000 RBX: 00000000006040c0 RCX: ffffffffb82f73b7 [ 548.623287] RDX: 1ffff1003e518eeb RSI: 000000000000000c RDI: 0000000000000000 [ 548.623290] RBP: ffff8801f28c7880 R08: 0000000000000000 R09: ffffed0047fff2c5 [ 548.623292] R10: 0000000000000001 R11: ffffed0047fff2c4 R12: ffff8801e88de040 [ 548.623295] R13: 00000000006040c0 R14: 000000000000000c R15: ffff8801f28c7938 [ 548.623299] FS: 00007f76fca51840(0000) GS:ffff8801f6f00000(0000) knlGS:0000000000000000 [ 548.623302] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 548.623304] CR2: 00007f19b9171760 CR3: 00000001ed952000 CR4: 00000000000006e0 [ 548.623317] Call Trace: [ 548.623325] ? kasan_check_read+0x11/0x20 [ 548.623330] ? __zone_watermark_ok+0x92/0x240 [ 548.623336] ? get_page_from_freelist+0x1c3/0x1d90 [ 548.623347] ? _raw_spin_lock_irqsave+0x2a/0x60 [ 548.623353] ? warn_alloc+0x250/0x250 [ 548.623358] ? save_stack+0x46/0xd0 [ 548.623361] ? kasan_kmalloc+0xad/0xe0 [ 548.623366] ? __isolate_free_page+0x2a0/0x2a0 [ 548.623370] ? mount_fs+0x60/0x1a0 [ 548.623374] ? vfs_kern_mount+0x6b/0x1a0 [ 548.623378] ? do_mount+0x34a/0x18c0 [ 548.623383] ? ksys_mount+0x83/0xd0 [ 548.623387] ? __x64_sys_mount+0x67/0x80 [ 548.623391] ? do_syscall_64+0x78/0x170 [ 548.623396] ? entry_SYSCALL_64_after_hwframe+0x44/0xa9 [ 548.623401] __alloc_pages_nodemask+0x3c5/0x400 [ 548.623407] ? __alloc_pages_slowpath+0x1420/0x1420 [ 548.623412] ? __mutex_lock_slowpath+0x20/0x20 [ 548.623417] ? kvmalloc_node+0x31/0x80 [ 548.623424] alloc_pages_current+0x75/0x110 [ 548.623436] kmalloc_order+0x24/0x60 [ 548.623442] kmalloc_order_trace+0x24/0xb0 [ 548.623448] __kmalloc_track_caller+0x207/0x220 [ 548.623455] ? f2fs_build_node_manager+0x399/0xbb0 [ 548.623460] kmemdup+0x20/0x50 [ 548.623465] f2fs_build_node_manager+0x399/0xbb0 [ 548.623470] f2fs_fill_super+0x195e/0x2b40 [ 548.623477] ? f2fs_commit_super+0x1b0/0x1b0 [ 548.623481] ? set_blocksize+0x90/0x140 [ 548.623486] mount_bdev+0x1c5/0x210 [ 548.623489] ? f2fs_commit_super+0x1b0/0x1b0 [ 548.623495] f2fs_mount+0x15/0x20 [ 548.623498] mount_fs+0x60/0x1a0 [ 548.623503] ? alloc_vfsmnt+0x309/0x360 [ 548.623508] vfs_kern_mount+0x6b/0x1a0 [ 548.623513] do_mount+0x34a/0x18c0 [ 548.623518] ? lockref_put_or_lock+0xcf/0x160 [ 548.623523] ? copy_mount_string+0x20/0x20 [ 548.623528] ? memcg_kmem_put_cache+0x1b/0xa0 [ 548.623533] ? kasan_check_write+0x14/0x20 [ 548.623537] ? _copy_from_user+0x6a/0x90 [ 548.623542] ? memdup_user+0x42/0x60 [ 548.623547] ksys_mount+0x83/0xd0 [ 548.623552] __x64_sys_mount+0x67/0x80 [ 548.623557] do_syscall_64+0x78/0x170 [ 548.623562] entry_SYSCALL_64_after_hwframe+0x44/0xa9 [ 548.623566] RIP: 0033:0x7f76fc331b9a [ 548.623567] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48 [ 548.623632] RSP: 002b:00007ffd4f0a0e48 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5 [ 548.623636] RAX: ffffffffffffffda RBX: 000000000146c030 RCX: 00007f76fc331b9a [ 548.623639] RDX: 000000000146c210 RSI: 000000000146df30 RDI: 0000000001474ec0 [ 548.623641] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013 [ 548.623643] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 0000000001474ec0 [ 548.623646] R13: 000000000146c210 R14: 0000000000000000 R15: 0000000000000003 [ 548.623650] ---[ end trace 4ce02f25ff7d3df5 ]--- [ 548.623656] F2FS-fs (loop0): Failed to initialize F2FS node manager [ 548.627936] F2FS-fs (loop0): Invalid log blocks per segment (8201) [ 548.627940] F2FS-fs (loop0): Can't find valid F2FS filesystem in 1th superblock [ 548.635835] F2FS-fs (loop0): Failed to initialize F2FS node manager - Location https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/segment.c#L3578 sit_i->sit_bitmap = kmemdup(src_bitmap, bitmap_size, GFP_KERNEL); Buffer overrun happens when doing memcpy. I suspect there is missing (inconsistent) checks on bitmap_size. Reported by Wen Xu (wen.xu@gatech.edu) from SSLab, Gatech. Reported-by: Wen Xu <wen.xu@gatech.edu> Signed-off-by: Chao Yu <yuchao0@huawei.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19mfd: ti_am335x_tscadc: Fix struct clk memory leakZumeng Chen
[ Upstream commit c2b1509c77a99a0dcea0a9051ca743cb88385f50 ] Use devm_elk_get() to let Linux manage struct clk memory to avoid the following memory leakage report: unreferenced object 0xdd75efc0 (size 64): comm "systemd-udevd", pid 186, jiffies 4294945126 (age 1195.750s) hex dump (first 32 bytes): 61 64 63 5f 74 73 63 5f 66 63 6b 00 00 00 00 00 adc_tsc_fck..... 00 00 00 00 92 03 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<c0a15260>] kmemleak_alloc+0x40/0x74 [<c0287a10>] __kmalloc_track_caller+0x198/0x388 [<c0255610>] kstrdup+0x40/0x5c [<c025565c>] kstrdup_const+0x30/0x3c [<c0636630>] __clk_create_clk+0x60/0xac [<c0630918>] clk_get_sys+0x74/0x144 [<c0630cdc>] clk_get+0x5c/0x68 [<bf0ac540>] ti_tscadc_probe+0x260/0x468 [ti_am335x_tscadc] [<c06f3c0c>] platform_drv_probe+0x60/0xac [<c06f1abc>] driver_probe_device+0x214/0x2dc [<c06f1c18>] __driver_attach+0x94/0xc0 [<c06efe2c>] bus_for_each_dev+0x90/0xa0 [<c06f1470>] driver_attach+0x28/0x30 [<c06f1030>] bus_add_driver+0x184/0x1ec [<c06f2b74>] driver_register+0xb0/0xf0 [<c06f3b4c>] __platform_driver_register+0x40/0x54 Signed-off-by: Zumeng Chen <zumeng.chen@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19iommu/ipmmu-vmsa: Fix allocation in atomic contextGeert Uytterhoeven
[ Upstream commit 46583e8c48c5a094ba28060615b3a7c8c576690f ] When attaching a device to an IOMMU group with CONFIG_DEBUG_ATOMIC_SLEEP=y: BUG: sleeping function called from invalid context at mm/slab.h:421 in_atomic(): 1, irqs_disabled(): 128, pid: 61, name: kworker/1:1 ... Call trace: ... arm_lpae_alloc_pgtable+0x114/0x184 arm_64_lpae_alloc_pgtable_s1+0x2c/0x128 arm_32_lpae_alloc_pgtable_s1+0x40/0x6c alloc_io_pgtable_ops+0x60/0x88 ipmmu_attach_device+0x140/0x334 ipmmu_attach_device() takes a spinlock, while arm_lpae_alloc_pgtable() allocates memory using GFP_KERNEL. Originally, the ipmmu-vmsa driver had its own custom page table allocation implementation using GFP_ATOMIC, hence the spinlock was fine. Fix this by replacing the spinlock by a mutex, like the arm-smmu driver does. Fixes: f20ed39f53145e45 ("iommu/ipmmu-vmsa: Use the ARM LPAE page table allocator") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19partitions/aix: fix usage of uninitialized lv_info and lvname structuresMauricio Faria de Oliveira
[ Upstream commit 14cb2c8a6c5dae57ee3e2da10fa3db2b9087e39e ] The if-block that sets a successful return value in aix_partition() uses 'lvip[].pps_per_lv' and 'n[].name' potentially uninitialized. For example, if 'numlvs' is zero or alloc_lvn() fails, neither is initialized, but are used anyway if alloc_pvd() succeeds after it. So, make the alloc_pvd() call conditional on their initialization. This has been hit when attaching an apparently corrupted/stressed AIX LUN, misleading the kernel to pr_warn() invalid data and hang. [...] partition (null) (11 pp's found) is not contiguous [...] partition (null) (2 pp's found) is not contiguous [...] partition (null) (3 pp's found) is not contiguous [...] partition (null) (64 pp's found) is not contiguous Fixes: 6ceea22bbbc8 ("partitions: add aix lvm partition support files") Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19partitions/aix: append null character to print data from diskMauricio Faria de Oliveira
[ Upstream commit d43fdae7bac2def8c4314b5a49822cb7f08a45f1 ] Even if properly initialized, the lvname array (i.e., strings) is read from disk, and might contain corrupt data (e.g., lack the null terminating character for strings). So, make sure the partition name string used in pr_warn() has the null terminating character. Fixes: 6ceea22bbbc8 ("partitions: add aix lvm partition support files") Suggested-by: Daniel J. Axtens <daniel.axtens@canonical.com> Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19Input: atmel_mxt_ts - only use first T9 instanceNick Dyer
[ Upstream commit 36f5d9ef26e52edff046b4b097855db89bf0cd4a ] The driver only registers one input device, which uses the screen parameters from the first T9 instance. The first T63 instance also uses those parameters. It is incorrect to send input reports from the second instances of these objects if they are enabled: the input scaling will be wrong and the positions will be mashed together. This also causes problems on Android if the number of slots exceeds 32. In the future, this could be handled by looking for enabled touch object instances and creating an input device for each one. Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk> Acked-by: Benson Leung <bleung@chromium.org> Acked-by: Yufeng Shen <miletus@chromium.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19net: dcb: For wild-card lookups, use priority -1, not 0Petr Machata
[ Upstream commit 08193d1a893c802c4b807e4d522865061f4e9f4f ] The function dcb_app_lookup walks the list of specified DCB APP entries, looking for one that matches a given criteria: ifindex, selector, protocol ID and optionally also priority. The "don't care" value for priority is set to 0, because that priority has not been allowed under CEE regime, which predates the IEEE standardization. Under IEEE, 0 is a valid priority number. But because dcb_app_lookup considers zero a wild card, attempts to add an APP entry with priority 0 fail when other entries exist for a given ifindex / selector / PID triplet. Fix by changing the wild-card value to -1. Signed-off-by: Petr Machata <petrm@mellanox.com> Signed-off-by: Ido Schimmel <idosch@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19MIPS: Octeon: add missing of_node_put()Nicholas Mc Guire
[ Upstream commit b1259519e618d479ede8a0db5474b3aff99f5056 ] The call to of_find_node_by_name returns a node pointer with refcount incremented thus it must be explicitly decremented here after the last usage. Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Signed-off-by: Paul Burton <paul.burton@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/19558/ Cc: Ralf Baechle <ralf@linux-mips.org> Cc: James Hogan <jhogan@kernel.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19net: mvneta: fix mtu change on port without linkYelena Krivosheev
[ Upstream commit 8466baf788ec3e18836bd9c91ba0b1a07af25878 ] It is incorrect to enable TX/RX queues (call by mvneta_port_up()) for port without link. Indeed MTU change for interface without link causes TX queues to stuck. Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit") Signed-off-by: Yelena Krivosheev <yelena@marvell.com> [gregory.clement: adding Fixes tags and rewording commit log] Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19gpio: ml-ioh: Fix buffer underwrite on probe error pathAnton Vasilyev
[ Upstream commit 4bf4eed44bfe288f459496eaf38089502ef91a79 ] If ioh_gpio_probe() fails on devm_irq_alloc_descs() then chip may point to any element of chip_save array, so reverse iteration from pointer chip may become chip_save[-1] and gpiochip_remove() will operate with wrong memory. The patch fix the error path of ioh_gpio_probe() to correctly bypass chip_save array. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19x86/mm: Remove in_nmi() warning from vmalloc_fault()Joerg Roedel
[ Upstream commit 6863ea0cda8725072522cd78bda332d9a0b73150 ] It is perfectly okay to take page-faults, especially on the vmalloc area while executing an NMI handler. Remove the warning. Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: David H. Gutteridge <dhgutteridge@sympatico.ca> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: linux-mm@kvack.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Brian Gerst <brgerst@gmail.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Waiman Long <llong@redhat.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: joro@8bytes.org Link: https://lkml.kernel.org/r/1532533683-5988-2-git-send-email-joro@8bytes.org Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19Bluetooth: hidp: Fix handling of strncpy for hid->name informationMarcel Holtmann
[ Upstream commit b3cadaa485f0c20add1644a5c877b0765b285c0c ] This fixes two issues with setting hid->name information. CC net/bluetooth/hidp/core.o In function ‘hidp_setup_hid’, inlined from ‘hidp_session_dev_init’ at net/bluetooth/hidp/core.c:815:9, inlined from ‘hidp_session_new’ at net/bluetooth/hidp/core.c:953:8, inlined from ‘hidp_connection_add’ at net/bluetooth/hidp/core.c:1366:8: net/bluetooth/hidp/core.c:778:2: warning: ‘strncpy’ output may be truncated copying 127 bytes from a string of length 127 [-Wstringop-truncation] strncpy(hid->name, req->name, sizeof(req->name) - 1); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC net/bluetooth/hidp/core.o net/bluetooth/hidp/core.c: In function ‘hidp_setup_hid’: net/bluetooth/hidp/core.c:778:38: warning: argument to ‘sizeof’ in ‘strncpy’ call is the same expression as the source; did you mean to use the size of the destination? [-Wsizeof-pointer-memaccess] strncpy(hid->name, req->name, sizeof(req->name)); ^ Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19ath10k: disable bundle mgmt tx completion event supportSurabhi Vishnoi
[ Upstream commit 673bc519c55843c68c3aecff71a4101e79d28d2b ] The tx completion of multiple mgmt frames can be bundled in a single event and sent by the firmware to host, if this capability is not disabled explicitly by the host. If the host cannot handle the bundled mgmt tx completion, this capability support needs to be disabled in the wmi init cmd, sent to the firmware. Add the host capability indication flag in the wmi ready command, to let firmware know the features supported by the host driver. This field is ignored if it is not supported by firmware. Set the host capability indication flag(i.e. host_capab) to zero, for disabling the support of bundle mgmt tx completion. This will indicate the firmware to send completion event for every mgmt tx completion, instead of bundling them together and sending in a single event. Tested HW: WCN3990 Tested FW: WLAN.HL.2.0-01188-QCAHLSWMTPLZ-1 Signed-off-by: Surabhi Vishnoi <svishnoi@codeaurora.org> Signed-off-by: Rakesh Pillai <pillair@codeaurora.org> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19scsi: 3ware: fix return 0 on the error path of probeAnton Vasilyev
[ Upstream commit 4dc98c1995482262e70e83ef029135247fafe0f2 ] tw_probe() returns 0 in case of fail of tw_initialize_device_extension(), pci_resource_start() or tw_reset_sequence() and releases resources. twl_probe() returns 0 in case of fail of twl_initialize_device_extension(), pci_iomap() and twl_reset_sequence(). twa_probe() returns 0 in case of fail of tw_initialize_device_extension(), ioremap() and twa_reset_sequence(). The patch adds retval initialization for these cases. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19ata: libahci: Correct setting of DEVSLP registerSrinivas Pandruvada
[ Upstream commit 2dbb3ec29a6c069035857a2fc4c24e80e5dfe3cc ] We have seen that on some platforms, SATA device never show any DEVSLP residency. This prevent power gating of SATA IP, which prevent system to transition to low power mode in systems with SLP_S0 aka modern standby systems. The PHY logic is off only in DEVSLP not in slumber. Reference: https://www.intel.com/content/dam/www/public/us/en/documents/datasheets /332995-skylake-i-o-platform-datasheet-volume-1.pdf Section 28.7.6.1 Here driver is trying to do read-modify-write the devslp register. But not resetting the bits for which this driver will modify values (DITO, MDAT and DETO). So simply reset those bits before updating to new values. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19MIPS: Fix ISA virt/bus conversion for non-zero PHYS_OFFSETPaul Burton
[ Upstream commit 0494d7ffdcebc6935410ea0719b24ab626675351 ] isa_virt_to_bus() & isa_bus_to_virt() claim to treat ISA bus addresses as being identical to physical addresses, but they fail to do so in the presence of a non-zero PHYS_OFFSET. Correct this by having them use virt_to_phys() & phys_to_virt(), which consolidates the calculations to one place & ensures that ISA bus addresses do indeed match physical addresses. Signed-off-by: Paul Burton <paul.burton@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/20047/ Cc: James Hogan <jhogan@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Vladimir Kondratiev <vladimir.kondratiev@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19ath10k: prevent active scans on potential unusable channelsSven Eckelmann
[ Upstream commit 3f259111583801013cb605bb4414aa529adccf1c ] The QCA4019 hw1.0 firmware 10.4-3.2.1-00050 and 10.4-3.5.3-00053 (and most likely all other) seem to ignore the WMI_CHAN_FLAG_DFS flag during the scan. This results in transmission (probe requests) on channels which are not "available" for transmissions. Since the firmware is closed source and nothing can be done from our side to fix the problem in it, the driver has to work around this problem. The WMI_CHAN_FLAG_PASSIVE seems to be interpreted by the firmware to not scan actively on a channel unless an AP was detected on it. Simple probe requests will then be transmitted by the STA on the channel. ath10k must therefore also use this flag when it queues a radar channel for scanning. This should reduce the chance of an active scan when the channel might be "unusable" for transmissions. Fixes: e8a50f8ba44b ("ath10k: introduce DFS implementation") Signed-off-by: Sven Eckelmann <sven.eckelmann@openmesh.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19macintosh/via-pmu: Add missing mmio accessorsFinn Thain
[ Upstream commit 576d5290d678a651b9f36050fc1717e0573aca13 ] Add missing in_8() accessors to init_pmu() and pmu_sr_intr(). This fixes several sparse warnings: drivers/macintosh/via-pmu.c:536:29: warning: dereference of noderef expression drivers/macintosh/via-pmu.c:537:33: warning: dereference of noderef expression drivers/macintosh/via-pmu.c:1455:17: warning: dereference of noderef expression drivers/macintosh/via-pmu.c:1456:69: warning: dereference of noderef expression Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19NFSv4.0 fix client reference leak in callbackOlga Kornievskaia
[ Upstream commit 32cd3ee511f4e07ca25d71163b50e704808d22f4 ] If there is an error during processing of a callback message, it leads to refrence leak on the client structure and eventually an unclean superblock. Signed-off-by: Olga Kornievskaia <kolga@netapp.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19perf tools: Allow overriding MAX_NR_CPUS at compile timeChristophe Leroy
[ Upstream commit 21b8732eb4479b579bda9ee38e62b2c312c2a0e5 ] After update of kernel, the perf tool doesn't run anymore on my 32MB RAM powerpc board, but still runs on a 128MB RAM board: ~# strace perf execve("/usr/sbin/perf", ["perf"], [/* 12 vars */]) = -1 ENOMEM (Cannot allocate memory) --- SIGSEGV {si_signo=SIGSEGV, si_code=SI_KERNEL, si_addr=0} --- +++ killed by SIGSEGV +++ Segmentation fault objdump -x shows that .bss section has a huge size of 24Mbytes: 27 .bss 016baca8 101cebb8 101cebb8 001cd988 2**3 With especially the following objects having quite big size: 10205f80 l O .bss 00140000 runtime_cycles_stats 10345f80 l O .bss 00140000 runtime_stalled_cycles_front_stats 10485f80 l O .bss 00140000 runtime_stalled_cycles_back_stats 105c5f80 l O .bss 00140000 runtime_branches_stats 10705f80 l O .bss 00140000 runtime_cacherefs_stats 10845f80 l O .bss 00140000 runtime_l1_dcache_stats 10985f80 l O .bss 00140000 runtime_l1_icache_stats 10ac5f80 l O .bss 00140000 runtime_ll_cache_stats 10c05f80 l O .bss 00140000 runtime_itlb_cache_stats 10d45f80 l O .bss 00140000 runtime_dtlb_cache_stats 10e85f80 l O .bss 00140000 runtime_cycles_in_tx_stats 10fc5f80 l O .bss 00140000 runtime_transaction_stats 11105f80 l O .bss 00140000 runtime_elision_stats 11245f80 l O .bss 00140000 runtime_topdown_total_slots 11385f80 l O .bss 00140000 runtime_topdown_slots_retired 114c5f80 l O .bss 00140000 runtime_topdown_slots_issued 11605f80 l O .bss 00140000 runtime_topdown_fetch_bubbles 11745f80 l O .bss 00140000 runtime_topdown_recovery_bubbles This is due to commit 4d255766d28b1 ("perf: Bump max number of cpus to 1024"), because many tables are sized with MAX_NR_CPUS This patch gives the opportunity to redefine MAX_NR_CPUS via $ make EXTRA_CFLAGS=-DMAX_NR_CPUS=1 Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20170922112043.8349468C57@po15668-vm-win7.idsi0.si.c-s.fr Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19f2fs: do not set free of current sectionYunlong Song
[ Upstream commit 3611ce9911267cb93d364bd71ddea6821278d11f ] For the case when sbi->segs_per_sec > 1, take section:segment = 5 for example, if segment 1 is just used and allocate new segment 2, and the blocks of segment 1 is invalidated, at this time, the previous code will use __set_test_and_free to free the free_secmap and free_sections++, this is not correct since it is still a current section, so fix it. Signed-off-by: Yunlong Song <yunlong.song@huawei.com> Reviewed-by: Chao Yu <yuchao0@huawei.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19tty: rocket: Fix possible buffer overwrite on register_PCIAnton Vasilyev
[ Upstream commit 0419056ec8fd01ddf5460d2dba0491aad22657dd ] If number of isa and pci boards exceed NUM_BOARDS on the path rp_init()->init_PCI()->register_PCI() then buffer overwrite occurs in register_PCI() on assign rcktpt_io_addr[i]. The patch adds check on upper bound for index of registered board in register_PCI. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19uio: potential double frees if __uio_register_device() failsDan Carpenter
[ Upstream commit f019f07ecf6a6b8bd6d7853bce70925d90af02d1 ] The uio_unregister_device() function assumes that if "info->uio_dev" is non-NULL that means "info" is fully allocated. Setting info->uio_de has to be the last thing in the function. In the current code, if request_threaded_irq() fails then we return with info->uio_dev set to non-NULL but info is not fully allocated and it can lead to double frees. Fixes: beafc54c4e2f ("UIO: Add the User IO core code") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19misc: ti-st: Fix memory leak in the error path of probe()Anton Vasilyev
[ Upstream commit 81ae962d7f180c0092859440c82996cccb254976 ] Free resources instead of direct return of the error code if kim_probe fails. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19md/raid5: fix data corruption of replacements after originals droppedBingJing Chang
[ Upstream commit d63e2fc804c46e50eee825c5d3a7228e07048b47 ] During raid5 replacement, the stripes can be marked with R5_NeedReplace flag. Data can be read from being-replaced devices and written to replacing spares without reading all other devices. (It's 'replace' mode. s.replacing = 1) If a being-replaced device is dropped, the replacement progress will be interrupted and resumed with pure recovery mode. However, existing stripes before being interrupted cannot read from the dropped device anymore. It prints lots of WARN_ON messages. And it results in data corruption because existing stripes write problematic data into its replacement device and update the progress. \# Erase disks (1MB + 2GB) dd if=/dev/zero of=/dev/sda bs=1MB count=2049 dd if=/dev/zero of=/dev/sdb bs=1MB count=2049 dd if=/dev/zero of=/dev/sdc bs=1MB count=2049 dd if=/dev/zero of=/dev/sdd bs=1MB count=2049 mdadm -C /dev/md0 -amd -R -l5 -n3 -x0 /dev/sd[abc] -z 2097152 \# Ensure array stores non-zero data dd if=/root/data_4GB.iso of=/dev/md0 bs=1MB \# Start replacement mdadm /dev/md0 -a /dev/sdd mdadm /dev/md0 --replace /dev/sda Then, Hot-plug out /dev/sda during recovery, and wait for recovery done. echo check > /sys/block/md0/md/sync_action cat /sys/block/md0/md/mismatch_cnt # it will be greater than 0. Soon after you hot-plug out /dev/sda, you will see many WARN_ON messages. The replacement recovery will be interrupted shortly. After the recovery finishes, it will result in data corruption. Actually, it's just an unhandled case of replacement. In commit <f94c0b6658c7> (md/raid5: fix interaction of 'replace' and 'recovery'.), if a NeedReplace device is not UPTODATE then that is an error, the commit just simply print WARN_ON but also mark these corrupted stripes with R5_WantReplace. (it means it's ready for writes.) To fix this case, we can leverage 'sync and replace' mode mentioned in commit <9a3e1101b827> (md/raid5: detect and handle replacements during recovery.). We can add logics to detect and use 'sync and replace' mode for these stripes. Reported-by: Alex Chen <alexchen@synology.com> Reviewed-by: Alex Wu <alexwu@synology.com> Reviewed-by: Chung-Chiang Cheng <cccheng@synology.com> Signed-off-by: BingJing Chang <bingjingc@synology.com> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19scsi: target: fix __transport_register_session lockingMike Christie
[ Upstream commit 6a64f6e1591322beb8ce16e952a53582caf2a15c ] When __transport_register_session is called from transport_register_session irqs will already have been disabled, so we do not want the unlock irq call to enable them until the higher level has done the final spin_unlock_irqrestore/ spin_unlock_irq. This has __transport_register_session use the save/restore call. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19gpio: tegra: Move driver registration to subsys_init levelDmitry Osipenko
[ Upstream commit 40b25bce0adbe641a744d1291bc0e51fb7f3c3d8 ] There is a bug in regards to deferred probing within the drivers core that causes GPIO-driver to suspend after its users. The bug appears if GPIO-driver probe is getting deferred, which happens after introducing dependency on PINCTRL-driver for the GPIO-driver by defining "gpio-ranges" property in device-tree. The bug in the drivers core is old (more than 4 years now) and is well known, unfortunately there is no easy fix for it. The good news is that we can workaround the deferred probe issue by changing GPIO / PINCTRL drivers registration order and hence by moving PINCTRL driver registration to the arch_init level and GPIO to the subsys_init. Signed-off-by: Dmitry Osipenko <digetx@gmail.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19Bluetooth: h5: Fix missing dependency on BT_HCIUART_SERDEVJohan Hedberg
[ Upstream commit 6c3711ec64fd23a9abc8aaf59a9429569a6282df ] This driver was recently updated to use serdev, so add the appropriate dependency. Without this one can get compiler warnings like this if CONFIG_SERIAL_DEV_BUS is not enabled: CC [M] drivers/bluetooth/hci_h5.o drivers/bluetooth/hci_h5.c:934:36: warning: ‘h5_serdev_driver’ defined but not used [-Wunused-variable] static struct serdev_device_driver h5_serdev_driver = { ^~~~~~~~~~~~~~~~ Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19ethtool: Remove trailing semicolon for static inlineFlorian Fainelli
[ Upstream commit d89d41556141a527030a15233135ba622ba3350d ] Android's header sanitization tool chokes on static inline functions having a trailing semicolon, leading to an incorrectly parsed header file. While the tool should obviously be fixed, also fix the header files for the two affected functions: ethtool_get_flow_spec_ring() and ethtool_get_flow_spec_ring_vf(). Fixes: 8cf6f497de40 ("ethtool: Add helper routines to pass vf to rx_flow_spec") Reporetd-by: Blair Prescott <blair.prescott@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19misc: mic: SCIF Fix scif_get_new_port() error handlingDan Carpenter
[ Upstream commit a39284ae9d2ad09975c8ae33f1bd0f05fbfbf6ee ] There are only 2 callers of scif_get_new_port() and both appear to get the error handling wrong. Both treat zero returns as error, but it actually returns negative error codes and >= 0 on success. Fixes: e9089f43c9a7 ("misc: mic: SCIF open close bind and listen APIs") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19ARC: [plat-axs*]: Enable SWAPAlexey Brodkin
commit c83532fb0fe053d2e43e9387354cb1b52ba26427 upstream. SWAP support on ARC was fixed earlier by commit 6e3761145a9b ("ARC: Fix CONFIG_SWAP") so now we may safely enable it on platforms that have external media like USB and SD-card. Note: it was already allowed for HSDK Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: stable@vger.kernel.org # 6e3761145a9b: ARC: Fix CONFIG_SWAP Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19locking/osq_lock: Fix osq_lock queue corruptionPrateek Sood
commit 50972fe78f24f1cd0b9d7bbf1f87d2be9e4f412e upstream. Fix ordering of link creation between node->prev and prev->next in osq_lock(). A case in which the status of optimistic spin queue is CPU6->CPU2 in which CPU6 has acquired the lock. tail v ,-. <- ,-. |6| |2| `-' -> `-' At this point if CPU0 comes in to acquire osq_lock, it will update the tail count. CPU2 CPU0 ---------------------------------- tail v ,-. <- ,-. ,-. |6| |2| |0| `-' -> `-' `-' After tail count update if CPU2 starts to unqueue itself from optimistic spin queue, it will find an updated tail count with CPU0 and update CPU2 node->next to NULL in osq_wait_next(). unqueue-A tail v ,-. <- ,-. ,-. |6| |2| |0| `-' `-' `-' unqueue-B ->tail != curr && !node->next If reordering of following stores happen then prev->next where prev being CPU2 would be updated to point to CPU0 node: tail v ,-. <- ,-. ,-. |6| |2| |0| `-' `-' -> `-' osq_wait_next() node->next <- 0 xchg(node->next, NULL) tail v ,-. <- ,-. ,-. |6| |2| |0| `-' `-' `-' unqueue-C At this point if next instruction WRITE_ONCE(next->prev, prev); in CPU2 path is committed before the update of CPU0 node->prev = prev then CPU0 node->prev will point to CPU6 node. tail v----------. v ,-. <- ,-. ,-. |6| |2| |0| `-' `-' `-' `----------^ At this point if CPU0 path's node->prev = prev is committed resulting in change of CPU0 prev back to CPU2 node. CPU2 node->next is NULL currently, tail v ,-. <- ,-. <- ,-. |6| |2| |0| `-' `-' `-' `----------^ so if CPU0 gets into unqueue path of osq_lock it will keep spinning in infinite loop as condition prev->next == node will never be true. Signed-off-by: Prateek Sood <prsood@codeaurora.org> [ Added pictures, rewrote comments. ] Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: sramana@codeaurora.org Link: http://lkml.kernel.org/r/1500040076-27626-1-git-send-email-prsood@codeaurora.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19selinux: use GFP_NOWAIT in the AVC kmem_cachesMichal Hocko
commit 476accbe2f6ef69caeebe99f52a286e12ac35aee upstream. There is a strange __GFP_NOMEMALLOC usage pattern in SELinux, specifically GFP_ATOMIC | __GFP_NOMEMALLOC which doesn't make much sense. GFP_ATOMIC on its own allows to access memory reserves while __GFP_NOMEMALLOC dictates we cannot use memory reserves. Replace this with the much more sane GFP_NOWAIT in the AVC code as we can tolerate memory allocation failures in that code. Signed-off-by: Michal Hocko <mhocko@kernel.org> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19locking/rwsem-xadd: Fix missed wakeup due to reordering of loadPrateek Sood
commit 9c29c31830a4eca724e137a9339137204bbb31be upstream. If a spinner is present, there is a chance that the load of rwsem_has_spinner() in rwsem_wake() can be reordered with respect to decrement of rwsem count in __up_write() leading to wakeup being missed: spinning writer up_write caller --------------- ----------------------- [S] osq_unlock() [L] osq spin_lock(wait_lock) sem->count=0xFFFFFFFF00000001 +0xFFFFFFFF00000000 count=sem->count MB sem->count=0xFFFFFFFE00000001 -0xFFFFFFFF00000001 spin_trylock(wait_lock) return rwsem_try_write_lock(count) spin_unlock(wait_lock) schedule() Reordering of atomic_long_sub_return_release() in __up_write() and rwsem_has_spinner() in rwsem_wake() can cause missing of wakeup in up_write() context. In spinning writer, sem->count and local variable count is 0XFFFFFFFE00000001. It would result in rwsem_try_write_lock() failing to acquire rwsem and spinning writer going to sleep in rwsem_down_write_failed(). The smp_rmb() will make sure that the spinner state is consulted after sem->count is updated in up_write context. Signed-off-by: Prateek Sood <prsood@codeaurora.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dave@stgolabs.net Cc: longman@redhat.com Cc: parri.andrea@gmail.com Cc: sramana@codeaurora.org Link: http://lkml.kernel.org/r/1504794658-15397-1-git-send-email-prsood@codeaurora.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19block,blkcg: use __GFP_NOWARN for best-effort allocations in blkcgTejun Heo
commit e00f4f4d0ff7e13b9115428a245b49108d625f09 upstream. blkcg allocates some per-cgroup data structures with GFP_NOWAIT and when that fails falls back to operations which aren't specific to the cgroup. Occassional failures are expected under pressure and falling back to non-cgroup operation is the right thing to do. Unfortunately, I forgot to add __GFP_NOWARN to these allocations and these expected failures end up creating a lot of noise. Add __GFP_NOWARN. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Marc MERLIN <marc@merlins.org> Reported-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19staging/rts5208: Fix read overflow in memcpyDaniel Micay
commit 88a5b39b69ab1828fd4130e2baadd184109cea69 upstream. Noticed by FORTIFY_SOURCE, this swaps memcpy() for strncpy() to zero-value fill the end of the buffer instead of over-reading a string from .rodata. Signed-off-by: Daniel Micay <danielmicay@gmail.com> [kees: wrote commit log] Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Wayne Porter <wporter82@gmail.com> Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
