commit 7cf321d118a825c1541b43ca45294126fd474efa upstream.
This fixes a regression in all these drivers since the cache
mode tracking was fixed for mixed mappings. It uses the new
arch API to add the VRAM range to the PAT mapping tracking
tables.
Fixes: 87744ab3832 (mm: fix cache mode tracking in vm_insert_mixed())
Reviewed-by: Christian König <christian.koenig@amd.com>.
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 8ef4227615e158faa4ee85a1d6466782f7e22f2f upstream.
A recent change to the mm code in:
87744ab3832b mm: fix cache mode tracking in vm_insert_mixed()
started enforcing checking the memory type against the registered list for
amixed pfn insertion mappings. It happens that the drm drivers for a number
of gpus relied on this being broken. Currently the driver only inserted
VRAM mappings into the tracking table when they came from the kernel,
and userspace mappings never landed in the table. This led to a regression
where all the mapping end up as UC instead of WC now.
I've considered a number of solutions but since this needs to be fixed
in fixes and not next, and some of the solutions were going to introduce
overhead that hadn't been there before I didn't consider them viable at
this stage. These mainly concerned hooking into the TTM io reserve APIs,
but these API have a bunch of fast paths I didn't want to unwind to add
this to.
The solution I've decided on is to add a new API like the arch_phys_wc
APIs (these would have worked but wc_del didn't take a range), and
use them from the drivers to add a WC compatible mapping to the table
for all VRAM on those GPUs. This means we can then create userspace
mapping that won't get degraded to UC.
v1.1: use CONFIG_X86_PAT + add some comments in io.h
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: x86@kernel.org
Cc: mcgrof@suse.com
Cc: Dan Williams <dan.j.williams@intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit 7b6924d94a60c6b8c1279ca003e8744e6cd9e8b1 upstream.
'type' is user-controlled, so sanitize it after the bounds check to
avoid using it in speculative execution. This covers the following
potential gadgets detected with the help of smatch:
* fs/ext4/super.c:5741 ext4_quota_read() warn: potential spectre issue
'sb_dqopt(sb)->files' [r]
* fs/ext4/super.c:5778 ext4_quota_write() warn: potential spectre issue
* fs/f2fs/super.c:1552 f2fs_quota_read() warn: potential spectre issue
* fs/f2fs/super.c:1608 f2fs_quota_write() warn: potential spectre issue
* fs/quota/dquot.c:412 mark_info_dirty() warn: potential spectre issue
'sb_dqopt(sb)->info' [w]
* fs/quota/dquot.c:933 dqinit_needed() warn: potential spectre issue
'dquots' [r]
* fs/quota/dquot.c:2112 dquot_commit_info() warn: potential spectre
issue 'dqopt->ops' [r]
* fs/quota/dquot.c:2362 vfs_load_quota_inode() warn: potential spectre
issue 'dqopt->files' [w] (local cap)
* fs/quota/dquot.c:2369 vfs_load_quota_inode() warn: potential spectre
issue 'dqopt->ops' [w] (local cap)
* fs/quota/dquot.c:2370 vfs_load_quota_inode() warn: potential spectre
issue 'dqopt->info' [w] (local cap)
* fs/quota/quota.c:110 quota_getfmt() warn: potential spectre issue
'sb_dqopt(sb)->info' [r]
* fs/quota/quota_v2.c:84 v2_check_quota_file() warn: potential spectre
issue 'quota_magics' [w]
* fs/quota/quota_v2.c:85 v2_check_quota_file() warn: potential spectre
issue 'quota_versions' [w]
* fs/quota/quota_v2.c:96 v2_read_file_info() warn: potential spectre
issue 'dqopt->info' [r]
* fs/quota/quota_v2.c:172 v2_write_file_info() warn: potential spectre
Additionally, a quick inspection indicates there are array accesses with
'type' in quota_on() and quota_off() functions which are also addressed
by this.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Jeremy Cline <jcline@redhat.com>
commit 99cbbe56eb8bede625f410ab62ba34673ffa7d21 upstream.
When the number of queues grows beyond 32, the array of queues is
resized but not all members were being copied. Fix by also copying
'tid', 'cpu' and 'set'.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Fixes: e502789302a6e ("perf auxtrace: Add helpers for queuing AUX area tracing data")
Link: http://lkml.kernel.org/r/20180814084608.6563-1-adrian.hunter@intel.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 3943b040f11ed0cc6d4585fd286a623ca8634547 upstream.
The writeback thread would exit with a lock held when the cache device
is detached via sysfs interface, fix it by releasing the held lock
before exiting the while-loop.
Fixes: fadd94e05c02 (bcache: quit dc->writeback_thread when BCACHE_DEV_DETACHING is set)
Signed-off-by: Shan Hai <shan.hai@oracle.com>
Signed-off-by: Coly Li <colyli@suse.de>
Tested-by: Shenghui Wang <shhuiw@foxmail.com>
Cc: stable@vger.kernel.org #4.17+
commit 82c9a927bc5df6e06b72d206d24a9d10cced4eb5 upstream.
When running in a container with a user namespace, if you call getxattr
with name = "system.posix_acl_access" and size % 8 != 4, then getxattr
silently skips the user namespace fixup that it normally does resulting in
un-fixed-up data being returned.
This is caused by posix_acl_fix_xattr_to_user() being passed the total
buffer size and not the actual size of the xattr as returned by
vfs_getxattr().
This commit passes the actual length of the xattr as returned by
vfs_getxattr() down.
A reproducer for the issue is:
touch acl_posix
setfacl -m user:0:rwx acl_posix
and the compile:
#define _GNU_SOURCE
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <unistd.h>
#include <attr/xattr.h>
/* Run in user namespace with nsuid 0 mapped to uid != 0 on the host. */
int main(int argc, void **argv)
ssize_t ret1, ret2;
char buf1[128], buf2[132];
int fret = EXIT_SUCCESS;
char *file;
if (argc < 2) {
fprintf(stderr,
"Please specify a file with "
"\"system.posix_acl_access\" permissions set\n");
_exit(EXIT_FAILURE);
file = argv[1];
ret1 = getxattr(file, "system.posix_acl_access",
buf1, sizeof(buf1));
if (ret1 < 0) {
fprintf(stderr, "%s - Failed to retrieve "
"\"system.posix_acl_access\" "
"from \"%s\"\n", strerror(errno), file);
ret2 = getxattr(file, "system.posix_acl_access",
buf2, sizeof(buf2));
if (ret2 < 0) {
if (ret1 != ret2) {
fprintf(stderr, "The value of \"system.posix_acl_"
"access\" for file \"%s\" changed "
"between two successive calls\n", file);
for (ssize_t i = 0; i < ret2; i++) {
if (buf1[i] == buf2[i])
continue;
fprintf(stderr,
"Unexpected different in byte %zd: "
"%02x != %02x\n", i, buf1[i], buf2[i]);
fret = EXIT_FAILURE;
if (fret == EXIT_SUCCESS)
fprintf(stderr, "Test passed\n");
else
fprintf(stderr, "Test failed\n");
_exit(fret);
and run:
./tester acl_posix
On a non-fixed up kernel this should return something like:
root@c1:/# ./t
Unexpected different in byte 16: ffffffa0 != 00
Unexpected different in byte 17: ffffff86 != 00
Unexpected different in byte 18: 01 != 00
and on a fixed kernel:
root@c1:~# ./t
Test passed
Fixes: 2f6f0654ab61 ("userns: Convert vfs posix_acl support to use kuids and kgids")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199945
Reported-by: Colin Watson <cjwatson@ubuntu.com>
Signed-off-by: Christian Brauner <christian@brauner.io>
Acked-by: Serge Hallyn <serge@hallyn.com>
commit bb24153a3f13dd0dbc1f8055ad97fe346d598f66 upstream.
The default delay 5 jiffies is too much when the kernel is compiled with
HZ=100 - it results in jumpy cursor in Xwindow.
In order to find out the optimal delay, I benchmarked the driver on
1280x720x30fps video. I found out that with HZ=1000, 10ms is acceptable,
but with HZ=250 or HZ=300, we need 4ms, so that the video is played
without any frame skips.
This patch changes the delay to this value.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 8c5b044299951acd91e830a688dd920477ea1eda upstream.
I have a USB display adapter using the udlfb driver and I use it on an ARM
board that doesn't have any graphics card. When I plug the adapter in, the
console is properly displayed, however when I unplug and re-plug the
adapter, the console is not displayed and I can't access it until I reboot
the board.
The reason is this:
When the adapter is unplugged, dlfb_usb_disconnect calls
unlink_framebuffer, then it waits until the reference count drops to zero
and then it deallocates the framebuffer. However, the console that is
attached to the framebuffer device keeps the reference count non-zero, so
the framebuffer device is never destroyed. When the USB adapter is plugged
again, it creates a new device /dev/fb1 and the console is not attached to
it.
This patch fixes the bug by unbinding the console from unlink_framebuffer.
The code to unbind the console is moved from do_unregister_framebuffer to
a function unbind_console. When the console is unbound, the reference
count drops to zero and the udlfb driver frees the framebuffer. When the
adapter is plugged back, a new framebuffer is created and the console is
attached to it.
Cc: Dave Airlie <airlied@redhat.com>
Cc: Bernie Thompson <bernie@plugable.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
[b.zolnierkie: preserve old behavior for do_unregister_framebuffer()]
commit 38dabd91ff0bde33352ca3cc65ef515599b77a05 upstream.
pwm-tiehrpwm driver disables PWM output by putting it in low output
state via active AQCSFRC register in ehrpwm_pwm_disable(). But, the
AQCSFRC shadow register is not updated. Therefore, when shadow AQCSFRC
register is re-enabled in ehrpwm_pwm_enable() (say to enable second PWM
output), previous settings are lost as shadow register value is loaded
into active register. This results in things like PWMA getting enabled
automatically, when PWMB is enabled and vice versa. Fix this by
updating AQCSFRC shadow register as well during ehrpwm_pwm_disable().
Fixes: 19891b20e7c2 ("pwm: pwm-tiehrpwm: PWM driver support for EHRPWM")
Signed-off-by: Vignesh R <vigneshr@ti.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
commit 59965593205fa4044850d35ee3557cf0b7edcd14 upstream.
In ubifs_jnl_update() we sync parent and child inodes to the flash,
in case of xattrs, the parent inode (AKA host inode) has a non-zero
data_len. Therefore we need to adjust synced_i_size too.
This issue was reported by ubifs self tests unter a xattr related work
load.
UBIFS error (ubi0:0 pid 1896): dbg_check_synced_i_size: ui_size is 4, synced_i_size is 0, but inode is clean
UBIFS error (ubi0:0 pid 1896): dbg_check_synced_i_size: i_ino 65, i_mode 0x81a4, i_size 4
Cc: <stable@vger.kernel.org>
Fixes: 1e51764a3c2a ("UBIFS: add new flash file system")
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 95a22d2084d72ea067d8323cc85677dba5d97cae upstream.
Check whether the size is within bounds before using it.
If the size is not correct, abort and dump the bad data node.
Cc: Silvio Cesare <silvio.cesare@gmail.com>
Fixes: 1e51764a3c2ac ("UBIFS: add new flash file system")
Reported-by: Silvio Cesare <silvio.cesare@gmail.com>
commit 08acbdd6fd736b90f8d725da5a0de4de2dd6de62 upstream.
This reverts commit 353748a359f1821ee934afc579cf04572406b420.
It bypassed the linux-mtd review process and fixes the issue not as it
should.
commit eef19816ada3abd56d9f20c88794cc2fea83ebb2 upstream.
Allocate the buffer after we return early.
Otherwise memory is being leaked.
commit 5820f140edef111a9ea2ef414ab2428b8cb805b1 upstream.
The old code would hold the userns_state_mutex indefinitely if
memdup_user_nul stalled due to e.g. a userfault region. Prevent that by
moving the memdup_user_nul in front of the mutex_lock().
Note: This changes the error precedence of invalid buf/count/*ppos vs
map already written / capabilities missing.
Fixes: 22d917d80e84 ("userns: Rework the user_namespace adding uid/gid...")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Christian Brauner <christian@brauner.io>
commit 42a0cc3478584d4d63f68f2f5af021ddbea771fa upstream.
Holding uts_sem as a writer while accessing userspace memory allows a
namespace admin to stall all processes that attempt to take uts_sem.
Instead, move data through stack buffers and don't access userspace memory
while uts_sem is held.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit 9ba3eb5103cf56f0daaf07de4507df76e7813ed7 upstream.
commit 1c48db44924298ad0cb5a6386b88017539be8822 upstream.
PFSID should be used in the invalidation descriptor for flushing
device IOTLBs on SRIOV VFs.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: "Ashok Raj" <ashok.raj@intel.com>
Cc: "Lu Baolu" <baolu.lu@linux.intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 0f725561e168485eff7277d683405c05b192f537 upstream.
When SRIOV VF device IOTLB is invalidated, we need to provide
the PF source ID such that IOMMU hardware can gauge the depth
of invalidation queue which is shared among VFs. This is needed
when device invalidation throttle (DIT) capability is supported.
This patch adds bit definitions for checking and tracking PFSID.
commit a6f572084fbee8b30f91465f4a085d7a90901c57 upstream.
Will noted that only checking mm_users is incorrect; we should also
check mm_count in order to cover CPUs that have a lazy reference to
this mm (and could do speculative TLB operations).
If removing this turns out to be a performance issue, we can
re-instate a more complete check, but in tlb_table_flush() eliding the
call_rcu_sched().
Fixes: 267239116987 ("mm, powerpc: move the RCU page-table freeing into generic code")
Reported-by: Will Deacon <will.deacon@arm.com>
Acked-by: Rik van Riel <riel@surriel.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: stable@kernel.org
commit 6e1811900b6fe6f2b4665dba6bd6ed32c6b98575 upstream.
On all versions of Tegra30 Cardhu, the reset signal to the NXP PCA9546
I2C mux is connected to the Tegra GPIO BB0. Currently, this pin on the
Tegra is not configured as a GPIO but as a special-function IO (SFIO)
that is multiplexing the pin to an I2S controller. On exiting system
suspend, I2C commands sent to the PCA9546 are failing because there is
no ACK. Although it is not possible to see exactly what is happening
to the reset during suspend, by ensuring it is configured as a GPIO
and driven high, to de-assert the reset, the failures are no longer
seen.
Please note that this GPIO is also used to drive the reset signal
going to the camera connector on the board. However, given that there
is no camera support currently for Cardhu, this should not have any
impact.
Fixes: 40431d16ff11 ("ARM: tegra: enable PCA9546 on Cardhu")
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 0914bb965e38a055e9245637aed117efbe976e91 upstream.
"dev->nr_children" is the number of children which were parsed
successfully in bl_parse_stripe(). It could be all of them and then, in
that case, it is equal to v->stripe.volumes_count. Either way, the >
should be >= so that we don't go beyond the end of what we're supposed
to.
Fixes: 5c83746a0cf2 ("pnfs/blocklayout: in-kernel GETDEVICEINFO XDR parsing")
Cc: stable@vger.kernel.org # 3.17+
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 3df6f61fff49632492490fb6e42646b803a9958a upstream.
Commit ea0212f40c6 (power: auto select CONFIG_SRCU) made the code in
drivers/base/power/wakeup.c use SRCU instead of RCU, but it forgot to
select CONFIG_SRCU in Kconfig, which leads to the following build
error if CONFIG_SRCU is not selected somewhere else:
drivers/built-in.o: In function `wakeup_source_remove':
(.text+0x3c6fc): undefined reference to `synchronize_srcu'
drivers/built-in.o: In function `pm_print_active_wakeup_sources':
(.text+0x3c7a8): undefined reference to `__srcu_read_lock'
(.text+0x3c84c): undefined reference to `__srcu_read_unlock'
drivers/built-in.o: In function `device_wakeup_arm_wake_irqs':
(.text+0x3d1d8): undefined reference to `__srcu_read_lock'
(.text+0x3d228): undefined reference to `__srcu_read_unlock'
drivers/built-in.o: In function `device_wakeup_disarm_wake_irqs':
(.text+0x3d24c): undefined reference to `__srcu_read_lock'
(.text+0x3d29c): undefined reference to `__srcu_read_unlock'
drivers/built-in.o:(.data+0x4158): undefined reference to `process_srcu'
Fix this error by selecting CONFIG_SRCU when PM_SLEEP is enabled.
Fixes: ea0212f40c6 (power: auto select CONFIG_SRCU)
Cc: 4.2+ <stable@vger.kernel.org> # 4.2+
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
[ rjw: Minor subject/changelog fixups ]
commit 10aa14527f458e9867cf3d2cc6b8cb0f6704448b upstream.
Added checks to prevent GPFs from raising.
Link: http://lkml.kernel.org/r/20180727110558.5479-1-tomasbortoli@gmail.com
Signed-off-by: Tomas Bortoli <tomasbortoli@gmail.com>
Reported-by: syzbot+1a262da37d3bead15c39@syzkaller.appspotmail.com
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
commit 016f8ffc48cb01d1e7701649c728c5d2e737d295 upstream.
While debugging another bug, I was looking at all the synchronize*()
functions being used in kernel/trace, and noticed that trace_uprobes was
using synchronize_sched(), with a comment to synchronize with
{u,ret}_probe_trace_func(). When looking at those functions, the data is
protected with "rcu_read_lock()" and not with "rcu_read_lock_sched()". This
is using the wrong synchronize_*() function.
Link: http://lkml.kernel.org/r/20180809160553.469e1e32@gandalf.local.home
Fixes: 70ed91c6ec7f8 ("tracing/uprobes: Support ftrace_event_file base multibuffer")
Acked-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 3e536e222f2930534c252c1cc7ae799c725c5ff9 upstream.
There is a window for racing when printing directly to task->comm,
allowing other threads to see a non-terminated string. The vsnprintf
function fills the buffer, counts the truncated chars, then finally
writes the \0 at the end.
creator other
vsnprintf:
fill (not terminated)
count the rest trace_sched_waking(p):
... memcpy(comm, p->comm, TASK_COMM_LEN)
write \0
The consequences depend on how 'other' uses the string. In our case,
it was copied into the tracing system's saved cmdlines, a buffer of
adjacent TASK_COMM_LEN-byte buffers (note the 'n' where 0 should be):
crash-arm64> x/1024s savedcmd->saved_cmdlines | grep 'evenk'
0xffffffd5b3818640: "irq/497-pwr_evenkworker/u16:12"
...and a strcpy out of there would cause stack corruption:
[224761.522292] Kernel panic - not syncing: stack-protector:
Kernel stack is corrupted in: ffffff9bf9783c78
crash-arm64> kbt | grep 'comm\|trace_print_context'
#6 0xffffff9bf9783c78 in trace_print_context+0x18c(+396)
comm (char [16]) = "irq/497-pwr_even"
crash-arm64> rd 0xffffffd4d0e17d14 8
ffffffd4d0e17d14: 2f71726900000000 5f7277702d373934 ....irq/497-pwr_
ffffffd4d0e17d24: 726f776b6e657665 3a3631752f72656b evenkworker/u16:
ffffffd4d0e17d34: f9780248ff003231 cede60e0ffffff9b 12..H.x......`..
ffffffd4d0e17d44: cede60c8ffffffd4 00000fffffffffd4 .....`..........
The workaround in e09e28671 (use strlcpy in __trace_find_cmdline) was
likely needed because of this same bug.
Solved by vsnprintf:ing to a local buffer, then using set_task_comm().
This way, there won't be a window where comm is not terminated.
Link: http://lkml.kernel.org/r/20180726071539.188015-1-snild@sony.com
Fixes: bc0c38d139ec7 ("ftrace: latency tracer infrastructure")
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Snild Dolkow <snild@sony.com>
[backported to 3.18 / 4.4 by Snild]
commit 757d9140072054528b13bbe291583d9823cde195 upstream.
Masami Hiramatsu reported:
Current trace-enable attribute in sysfs returns an error
if user writes the same setting value as current one,
e.g.
# cat /sys/block/sda/trace/enable
0
# echo 0 > /sys/block/sda/trace/enable
bash: echo: write error: Invalid argument
# echo 1 > /sys/block/sda/trace/enable
bash: echo: write error: Device or resource busy
But this is not a preferred behavior, it should ignore
if new setting is same as current one. This fixes the
problem as below.
0
Link: http://lkml.kernel.org/r/20180816103802.08678002@gandalf.local.home
Cc: linux-block@vger.kernel.org
Fixes: cd649b8bb830d ("blktrace: remove sysfs_blk_trace_enable_show/store()")
Reported-by: Masami Hiramatsu <mhiramat@kernel.org>
Tested-by: Masami Hiramatsu <mhiramat@kernel.org>
commit f143641bfef9a4a60c57af30de26c63057e7e695 upstream.
Currently, when one echo's in 1 into tracing_on, the current tracer's
"start()" function is executed, even if tracing_on was already one. This can
lead to strange side effects. One being that if the hwlat tracer is enabled,
and someone does "echo 1 > tracing_on" into tracing_on, the hwlat tracer's
start() function is called again which will recreate another kernel thread,
and make it unable to remove the old one.
Link: http://lkml.kernel.org/r/1533120354-22923-1-git-send-email-erica.bugden@linutronix.de
Fixes: 2df8f8a6a897e ("tracing: Fix regression with irqsoff tracer and tracing_on file")
Reported-by: Erica Bugden <erica.bugden@linutronix.de>
commit c3cc1b0fc27508da53fe955a3b23d03964410682 upstream.
Currently, when all modules, including VMCI and VMware balloon are built
into the kernel, the initialization of the balloon happens before the
VMCI is probed. As a result, the balloon fails to initialize the VMCI
doorbell, which it uses to get asynchronous requests for balloon size
changes.
The problem can be seen in the logs, in the form of the following
message:
"vmw_balloon: failed to initialize vmci doorbell"
The driver would work correctly but slightly less efficiently, probing
for requests periodically. This patch changes the balloon to be
initialized using late_initcall() instead of module_init() to address
this issue. It does not address a situation in which VMCI is built as a
module and the balloon is built into the kernel.
Fixes: 48e3d668b790 ("VMware balloon: Enable notification via VMCI")
Reviewed-by: Xavier Deguillard <xdeguillard@vmware.com>
Signed-off-by: Nadav Amit <namit@vmware.com>
commit ce664331b2487a5d244a51cbdd8cb54f866fbe5d upstream.
When vmballoon_vmci_init() sets a doorbell using VMCI_DOORBELL_SET, for
some reason it does not consider the status and looks at the result.
However, the hypervisor does not update the result - it updates the
status. This might cause VMCI doorbell not to be enabled, resulting in
degraded performance.
commit 5081efd112560d3febb328e627176235b250d59d upstream.
If the hypervisor sets 2MB batching is on, while batching is cleared,
the balloon code breaks. In this case the legacy mechanism is used with
2MB page. The VM would report a 2MB page is ballooned, and the
hypervisor would only take the first 4KB.
While the hypervisor should not report such settings, make the code more
robust by not enabling 2MB support without batching.
Fixes: 365bd7ef7ec8e ("VMware balloon: Support 2m page ballooning.")
Signed-off-by: Nadav Amit <nadav.amit@gmail.com>
commit 09755690c6b7c1eabdc4651eb3b276f8feb1e447 upstream.
When balloon batching is not supported by the hypervisor, the guest
frame number (GFN) must fit in 32-bit. However, due to a bug, this check
was mistakenly ignored. In practice, when total RAM is greater than
16TB, the balloon does not work currently, making this bug unlikely to
happen.
Fixes: ef0f8f112984 ("VMware balloon: partially inline vmballoon_reserve_page.")
commit 9a5094ca29ea9b1da301b31fd377c0c0c4c23034 upstream.
A sysfs write callback function needs to either return the number of
consumed characters or an error.
The ad952x_store() function currently returns 0 if the input value was "0",
this will signal that no characters have been consumed and the function
will be called repeatedly in a loop indefinitely. Fix this by returning
number of supplied characters to indicate that the whole input string has
been consumed.
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Fixes: cd1678f96329 ("iio: frequency: New driver for AD9523 SPI Low Jitter Clock Generator")
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 5a4e33c1c53ae7d4425f7d94e60e4458a37b349e upstream.
Fix the displayed phase for the ad9523 driver. Currently the most
significant decimal place is dropped and all other digits are shifted one
to the left. This is due to a multiplication by 10, which is not necessary,
so remove it.
Fixes: cd1678f9632 ("iio: frequency: New driver for AD9523 SPI Low Jitter Clock Generator")
commit fd2fa95416188a767a63979296fa3e169a9ef5ec upstream.
policy_hint_size starts as 0 during __write_initial_superblock(). It
isn't until the policy is loaded that policy_hint_size is set in-core
(cmd->policy_hint_size). But it never got recorded in the on-disk
superblock because __commit_transaction() didn't deal with transfering
the in-core cmd->policy_hint_size to the on-disk superblock.
The in-core cmd->policy_hint_size gets initialized by metadata_open()'s
__begin_transaction_flags() which re-reads all superblock fields.
Because the superblock's policy_hint_size was never properly stored, when
the cache was created, hints_array_available() would always return false
when re-activating a previously created cache. This means
__load_mappings() always considered the hints invalid and never made use
of the hints (these hints served to optimize).
Another detremental side-effect of this oversight is the cache_check
utility would fail with: "invalid hint width: 0"
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Mostly recycling the commit log from adaba23ccd7d which fixed
populate_pmd, but did not fix populate_pud. The same problem exists
there.
Stable trees reverted the following patch:
Revert "x86/mm/pat: Ensure cpa->pfn only contains page frame numbers"
This reverts commit 87e2bd898d3a79a8c609f183180adac47879a2a4 which is
commit edc3b9129cecd0f0857112136f5b8b1bc1d45918 upstream.
but the L1TF patch 02ff2769edbc backported here
x86/mm/pat: Make set_memory_np() L1TF safe
commit 958f79b9ee55dfaf00c8106ed1c22a2919e0028b upstream
set_memory_np() is used to mark kernel mappings not present, but it has
it's own open coded mechanism which does not have the L1TF protection of
inverting the address bits.
assumed that cpa->pfn contains a PFN. With the above patch reverted
it does not, which causes the PUD to be set to an incorrect address
shifted by 12 bits, which can cause various failures.
Convert the address to a PFN before passing it to pud_pfn().
This is a 4.4 stable only patch to fix the L1TF patches backport there.
Cc: stable@vger.kernel.org # 4.4-only
commit 430ac66eb4c5b5c4eb846b78ebf65747510b30f1 upstream.
The patch adds the flush in p9_mux_poll_stop() as it the function used by
p9_conn_destroy(), in turn called by p9_fd_close() to stop the async
polling associated with the data regarding the connection.
Link: http://lkml.kernel.org/r/20180720092730.27104-1-tomasbortoli@gmail.com
Reported-by: syzbot+39749ed7d9ef6dfb23f6@syzkaller.appspotmail.com
To: Eric Van Hensbergen <ericvh@gmail.com>
To: Ron Minnich <rminnich@sandia.gov>
To: Latchesar Ionkov <lucho@ionkov.net>
Cc: Yiwen Jiang <jiangyiwen@huwei.com>
commit 7913690dcc5e18e235769fd87c34143072f5dbea upstream.
The p9_client_version() does not initialize the version pointer. If the
call to p9pdu_readf() returns an error and version has not been allocated
in p9pdu_readf(), then the program will jump to the "error" label and will
try to free the version pointer. If version is not initialized, free()
will be called with uninitialized, garbage data and will provoke a crash.
Link: http://lkml.kernel.org/r/20180709222943.19503-1-tomasbortoli@gmail.com
Reported-by: syzbot+65c6b72f284a39d416b4@syzkaller.appspotmail.com
Reviewed-by: Jun Piao <piaojun@huawei.com>
Reviewed-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
commit 23cba9cbde0bba05d772b335fe5f66aa82b9ad19 upstream.
Because the value of limit is VIRTQUEUE_NUM, if index is equal to
limit, it will cause sg array out of bounds, so correct the judgement
of BUG_ON.
Link: http://lkml.kernel.org/r/5B63D5F6.6080109@huawei.com
Signed-off-by: Yiwen Jiang <jiangyiwen@huawei.com>
Reported-By: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Jun Piao <piaojun@huawei.com>
commit 3111784bee81591ea2815011688d28b65df03627 upstream.
In my testing, v9fs_fid_xattr_set will return successfully even if the
backend ext4 filesystem has no space to store xattr key-value. That will
cause inconsistent behavior between front end and back end. The reason is
that lsetxattr will be triggered by p9_client_clunk, and unfortunately we
did not catch the error. This patch will catch the error to notify upper
caller.
p9_client_clunk (in 9p)
p9_client_rpc(clnt, P9_TCLUNK, "d", fid->fid);
v9fs_clunk (in qemu)
put_fid
free_fid
v9fs_xattr_fid_clunk
v9fs_co_lsetxattr
s->ops->lsetxattr
ext4_xattr_user_set (in host ext4 filesystem)
Link: http://lkml.kernel.org/r/5B57EACC.2060900@huawei.com
Signed-off-by: Jun Piao <piaojun@huawei.com>
commit cd813e1cd7122f2c261dce5b54d1e0c97f80e1a5 upstream.
During Machine Check interrupt on pseries platform, register r3 points
RTAS extended event log passed by hypervisor. Since hypervisor uses r3
to pass pointer to rtas log, it stores the original r3 value at the
start of the memory (first 8 bytes) pointed by r3. Since hypervisor
stores this info and rtas log is in BE format, linux should make
sure to restore r3 value in correct endian format.
Without this patch when MCE handler, after recovery, returns to code that
that caused the MCE may end up with Data SLB access interrupt for invalid
address followed by kernel panic or hang.
Severe Machine check interrupt [Recovered]
NIP [d00000000ca301b8]: init_module+0x1b8/0x338 [bork_kernel]
Initiator: CPU
Error type: SLB [Multihit]
Effective address: d00000000ca70000
cpu 0xa: Vector: 380 (Data SLB Access) at [c0000000fc7775b0]
pc: c0000000009694c0: vsnprintf+0x80/0x480
lr: c0000000009698e0: vscnprintf+0x20/0x60
sp: c0000000fc777830
msr: 8000000002009033
dar: a803a30c000000d0
current = 0xc00000000bc9ef00
paca = 0xc00000001eca5c00 softe: 3 irq_happened: 0x01
pid = 8860, comm = insmod
vprintk_emit+0xb4/0x4b0
vprintk_func+0x5c/0xd0
printk+0x38/0x4c
init_module+0x1c0/0x338 [bork_kernel]
do_one_initcall+0x54/0x230
do_init_module+0x8c/0x248
load_module+0x12b8/0x15b0
sys_finit_module+0xa8/0x110
system_call+0x58/0x6c
--- Exception: c00 (System Call) at 00007fff8bda0644
SP (7fffdfbfe980) is in userspace
This patch fixes this issue.
Fixes: a08a53ea4c97 ("powerpc/le: Enable RTAS events support")
Cc: stable@vger.kernel.org # v3.15+
Reviewed-by: Nicholas Piggin <npiggin@gmail.com>
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 1bd6a1c4b80a28d975287630644e6b47d0f977a5 upstream.
Crash memory ranges is an array of memory ranges of the crashing kernel
to be exported as a dump via /proc/vmcore file. The size of the array
is set based on INIT_MEMBLOCK_REGIONS, which works alright in most cases
where memblock memory regions count is less than INIT_MEMBLOCK_REGIONS
value. But this count can grow beyond INIT_MEMBLOCK_REGIONS value since
commit 142b45a72e22 ("memblock: Add array resizing support").
On large memory systems with a few DLPAR operations, the memblock memory
regions count could be larger than INIT_MEMBLOCK_REGIONS value. On such
systems, registering fadump results in crash or other system failures
like below:
task: c00007f39a290010 ti: c00000000b738000 task.ti: c00000000b738000
NIP: c000000000047df4 LR: c0000000000f9e58 CTR: c00000000010f180
REGS: c00000000b73b570 TRAP: 0300 Tainted: G L X (4.4.140+)
MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE> CR: 22004484 XER: 20000000
CFAR: c000000000008500 DAR: 000007a450000000 DSISR: 40000000 SOFTE: 0
NIP [c000000000047df4] smp_send_reschedule+0x24/0x80
LR [c0000000000f9e58] resched_curr+0x138/0x160
Call Trace:
resched_curr+0x138/0x160 (unreliable)
check_preempt_curr+0xc8/0xf0
ttwu_do_wakeup+0x38/0x150
try_to_wake_up+0x224/0x4d0
__wake_up_common+0x94/0x100
ep_poll_callback+0xac/0x1c0
__wake_up_sync_key+0x70/0xa0
sock_def_readable+0x58/0xa0
unix_stream_sendmsg+0x2dc/0x4c0
sock_sendmsg+0x68/0xa0
___sys_sendmsg+0x2cc/0x2e0
__sys_sendmsg+0x5c/0xc0
SyS_socketcall+0x36c/0x3f0
system_call+0x3c/0x100
as array index overflow is not checked for while setting up crash memory
ranges causing memory corruption. To resolve this issue, dynamically
allocate memory for crash memory ranges and resize it incrementally,
in units of pagesize, on hitting array size limit.
Fixes: 2df173d9e85d ("fadump: Initialize elfcore header and add PT_LOAD program headers.")
Cc: stable@vger.kernel.org # v3.4+
Signed-off-by: Hari Bathini <hbathini@linux.ibm.com>
Reviewed-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
[mpe: Just use PAGE_SIZE directly, fixup variable placement]
commit c11c7bfd213495784b22ef82a69b6489f8d0092f upstream.
Operating on a zero sized GEM userptr object will lead to explosions.
Fixes: 5cc9ed4b9a7a ("drm/i915: Introduce mapping of user pages into video memory (userptr) ioctl")
Testcase: igt/gem_userptr_blits/input-checking
Signed-off-by: Matthew Auld <matthew.auld@intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://patchwork.freedesktop.org/patch/msgid/20180502195021.30900-1-matthew.auld@intel.com
Cc: Loic <hackurx@opensec.fr>
commit 563a53f3906a6b43692498e5b3ae891fac93a4af upstream.
On non-OF systems spi->controlled_data may be NULL. This causes a NULL
pointer derefence on dm365-evm.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Commit 136f55f66019 ("net: lan78xx: fix rx handling before first
packet is send") was not correctly backported to 4.4. The call to
tasklet_schedule() belongs in lan78xx_link_reset().
Fixes: d1fc12d8475c ("net: lan78xx: fix rx handling before first packet is send")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d28c756caee6e414d9ba367d0b92da24145af2a8 upstream.
The zero-copy optimization when reading or writing large chunks of data
is quite useful. However, the 9p messages created through the zero-copy
write path have an incorrect message size: it should be the size of the
header + size of the data being written but instead it's just the size
of the header.
This only works if the server ignores the size field of the message and
otherwise breaks the framing of the protocol. Fix this by re-writing the
message size field with the correct value.
Tested by running `dd if=/dev/zero of=out bs=4k count=1` inside a
virtio-9p mount.
Link: http://lkml.kernel.org/r/20180717003529.114368-1-chirantan@chromium.org
Signed-off-by: Chirantan Ekbote <chirantan@chromium.org>
Reviewed-by: Greg Kurz <groug@kaod.org>
Tested-by: Greg Kurz <groug@kaod.org>
Cc: Dylan Reid <dgreid@chromium.org>
Cc: Guenter Roeck <groeck@chromium.org>
commit f9c52831133050c6b82aa8b6831c92da2bbf2a0b upstream.
This patch is necessary if case of AF_PACKET or other socket interface
which I am aware of it and didn't allocated the necessary room.
Reported-by: David Palma <david.palma@ntnu.no>
Reported-by: Rabi Narayan Sahoo <rabinarayans0828@gmail.com>
Signed-off-by: Alexander Aring <aring@mojatatu.com>
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
commit ac74f87c789af40936a80131c4759f3e72579c3a upstream.
This patch fixes patch add handling to take care tail and headroom for
single 6lowpan frames. We need to be sure we have a skb with the right
head and tailroom for single frames. This patch do it by using
skb_copy_expand() if head and tailroom is not enough allocated by upper
layer.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195059
commit 8f3fafc9c2f0ece10832c25f7ffcb07c97a32ad4 upstream.
Like d88b6d04: "cdrom: information leak in cdrom_ioctl_media_changed()"
There is another cast from unsigned long to int which causes
a bounds check to fail with specially crafted input. The value is
then used as an index in the slot array in cdrom_slot_status().
Signed-off-by: Scott Bauer <scott.bauer@intel.com>
Signed-off-by: Scott Bauer <sbauer@plzdonthack.me>
