2018-06-16Linux 4.4.138v4.4.138Greg Kroah-Hartman
2018-06-16crypto: vmx - Remove overly verbose printk from AES init routinesMichael Ellerman
commit 1411b5218adbcf1d45ddb260db5553c52e8d917c upstream. In the vmx AES init routines we do a printk(KERN_INFO ...) to report the fallback implementation we're using. However with a slow console this can significantly affect the speed of crypto operations. Using 'cryptsetup benchmark' the removal of the printk() leads to a ~5x speedup for aes-cbc decryption. So remove them. Fixes: 8676590a1593 ("crypto: vmx - Adding AES routines for VMX module") Fixes: 8c755ace357c ("crypto: vmx - Adding CBC routines for VMX module") Fixes: 4f7f60d312b3 ("crypto: vmx - Adding CTR routines for VMX module") Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module") Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16Input: elan_i2c - add ELAN0612 (Lenovo v330 14IKB) ACPI IDJohannes Wienke
commit e6e7e9cd8eed0e18217c899843bffbe8c7dae564 upstream. Add ELAN0612 to the list of supported touchpads; this ID is used in Lenovo v330 14IKB devices. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199253 Signed-off-by: Johannes Wienke <languitar@semipol.de> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16Input: goodix - add new ACPI id for GPD Win 2 touch screenEthan Lee
commit 5ca4d1ae9bad0f59bd6f851c39b19f5366953666 upstream. GPD Win 2 Website: http://www.gpd.hk/gpdwin2.asp Tested on a unit from the first production run sent to Indiegogo backers Signed-off-by: Ethan Lee <flibitijibibo@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16kvm: x86: use correct privilege level for sgdt/sidt/fxsave/fxrstor accessPaolo Bonzini
commit 3c9fa24ca7c9c47605672916491f79e8ccacb9e6 upstream. The functions that were used in the emulation of fxrstor, fxsave, sgdt and sidt were originally meant for task switching, and as such they did not check privilege levels. This is very bad when the same functions are used in the emulation of unprivileged instructions. This is CVE-2018-10853. The obvious fix is to add a new argument to ops->read_std and ops->write_std, which decides whether the access is a "system" access or should use the processor's CPL. Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12) Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16vmw_balloon: fixing double free when batching mode is offGil Kupfer
commit b23220fe054e92f616b82450fae8cd3ab176cc60 upstream. The balloon.page field is used for two different purposes if batching is on or off. If batching is on, the field point to the page which is used to communicate with with the hypervisor. If it is off, balloon.page points to the page that is about to be (un)locked. Unfortunately, this dual-purpose of the field introduced a bug: when the balloon is popped (e.g., when the machine is reset or the balloon driver is explicitly removed), the balloon driver frees, unconditionally, the page that is held in balloon.page. As a result, if batching is disabled, this leads to double freeing the last page that is sent to the hypervisor. The following error occurs during rmmod when kernel checkers are on, and the balloon is not empty: [ 42.307653] ------------[ cut here ]------------ [ 42.307657] Kernel BUG at ffffffffba1e4b28 [verbose debug info unavailable] [ 42.307720] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC [ 42.312512] Modules linked in: vmw_vsock_vmci_transport vsock ppdev joydev vmw_balloon(-) input_leds serio_raw vmw_vmci parport_pc shpchp parport i2c_piix4 nfit mac_hid autofs4 vmwgfx drm_kms_helper hid_generic syscopyarea sysfillrect usbhid sysimgblt fb_sys_fops hid ttm mptspi scsi_transport_spi ahci mptscsih drm psmouse vmxnet3 libahci mptbase pata_acpi [ 42.312766] CPU: 10 PID: 1527 Comm: rmmod Not tainted 4.12.0+ #5 [ 42.312803] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 09/30/2016 [ 42.313042] task: ffff9bf9680f8000 task.stack: ffffbfefc1638000 [ 42.313290] RIP: 0010:__free_pages+0x38/0x40 [ 42.313510] RSP: 0018:ffffbfefc163be98 EFLAGS: 00010246 [ 42.313731] RAX: 000000000000003e RBX: ffffffffc02b9720 RCX: 0000000000000006 [ 42.313972] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff9bf97e08e0a0 [ 42.314201] RBP: ffffbfefc163be98 R08: 0000000000000000 R09: 0000000000000000 [ 42.314435] R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffc02b97e4 [ 42.314505] R13: ffffffffc02b9748 R14: ffffffffc02b9728 R15: 0000000000000200 [ 42.314550] FS: 00007f3af5fec700(0000) GS:ffff9bf97e080000(0000) knlGS:0000000000000000 [ 42.314599] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 42.314635] CR2: 00007f44f6f4ab24 CR3: 00000003a7d12000 CR4: 00000000000006e0 [ 42.314864] Call Trace: [ 42.315774] vmballoon_pop+0x102/0x130 [vmw_balloon] [ 42.315816] vmballoon_exit+0x42/0xd64 [vmw_balloon] [ 42.315853] SyS_delete_module+0x1e2/0x250 [ 42.315891] entry_SYSCALL_64_fastpath+0x23/0xc2 [ 42.315924] RIP: 0033:0x7f3af5b0e8e7 [ 42.315949] RSP: 002b:00007fffe6ce0148 EFLAGS: 00000206 ORIG_RAX: 00000000000000b0 [ 42.315996] RAX: ffffffffffffffda RBX: 000055be676401e0 RCX: 00007f3af5b0e8e7 [ 42.316951] RDX: 000000000000000a RSI: 0000000000000800 RDI: 000055be67640248 [ 42.317887] RBP: 0000000000000003 R08: 0000000000000000 R09: 1999999999999999 [ 42.318845] R10: 0000000000000883 R11: 0000000000000206 R12: 00007fffe6cdf130 [ 42.319755] R13: 0000000000000000 R14: 0000000000000000 R15: 000055be676401e0 [ 42.320606] Code: c0 74 1c f0 ff 4f 1c 74 02 5d c3 85 f6 74 07 e8 0f d8 ff ff 5d c3 31 f6 e8 c6 fb ff ff 5d c3 48 c7 c6 c8 0f c5 ba e8 58 be 02 00 <0f> 0b 66 0f 1f 44 00 00 66 66 66 66 90 48 85 ff 75 01 c3 55 48 [ 42.323462] RIP: __free_pages+0x38/0x40 RSP: ffffbfefc163be98 [ 42.325735] ---[ end trace 872e008e33f81508 ]--- To solve the bug, we eliminate the dual purpose of balloon.page. Fixes: f220a80f0c2e ("VMware balloon: add batching to the vmw_balloon.") Cc: stable@vger.kernel.org Reported-by: Oleksandr Natalenko <onatalen@redhat.com> Signed-off-by: Gil Kupfer <gilkup@gmail.com> Signed-off-by: Nadav Amit <namit@vmware.com> Reviewed-by: Xavier Deguillard <xdeguillard@vmware.com> Tested-by: Oleksandr Natalenko <oleksandr@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16serial: samsung: fix maxburst parameter for DMA transactionsMarek Szyprowski
commit aa2f80e752c75e593b3820f42c416ed9458fa73e upstream. The best granularity of residue that DMA engine can report is in the BURST units, so the serial driver must use MAXBURST = 1 and DMA_SLAVE_BUSWIDTH_1_BYTE if it relies on exact number of bytes transferred by DMA engine. Fixes: 62c37eedb74c ("serial: samsung: add dma reqest/release functions") Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16KVM: x86: pass kvm_vcpu to kvm_read_guest_virt and kvm_write_guest_virt_systemPaolo Bonzini
commit ce14e868a54edeb2e30cb7a7b104a2fc4b9d76ca upstream. Int the next patch the emulator's .read_std and .write_std callbacks will grow another argument, which is not needed in kvm_read_guest_virt and kvm_write_guest_virt_system's callers. Since we have to make separate functions, let's give the currently existing names a nicer interface, too. Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12) Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16KVM: x86: introduce linear_{read,write}_systemPaolo Bonzini
commit 79367a65743975e5cac8d24d08eccc7fdae832b0 upstream. Wrap the common invocation of ctxt->ops->read_std and ctxt->ops->write_std, so as to have a smaller patch when the functions grow another argument. Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12) Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16Clarify (and fix) MAX_LFS_FILESIZE macrosLinus Torvalds
commit 0cc3b0ec23ce4c69e1e890ed2b8d2fa932b14aad upstream. We have a MAX_LFS_FILESIZE macro that is meant to be filled in by filesystems (and other IO targets) that know they are 64-bit clean and don't have any 32-bit limits in their IO path. It turns out that our 32-bit value for that limit was bogus. On 32-bit, the VM layer is limited by the page cache to only 32-bit index values, but our logic for that was confusing and actually wrong. We used to define that value to (((loff_t)PAGE_SIZE << (BITS_PER_LONG-1))-1) which is actually odd in several ways: it limits the index to 31 bits, and then it limits files so that they can't have data in that last byte of a page that has the highest 31-bit index (ie page index 0x7fffffff). Neither of those limitations make sense. The index is actually the full 32 bit unsigned value, and we can use that whole full page. So the maximum size of the file would logically be "PAGE_SIZE << BITS_PER_LONG". However, we do wan tto avoid the maximum index, because we have code that iterates over the page indexes, and we don't want that code to overflow. So the maximum size of a file on a 32-bit host should actually be one page less than the full 32-bit index. So the actual limit is ULONG_MAX << PAGE_SHIFT. That means that we will not actually be using the page of that last index (ULONG_MAX), but we can grow a file up to that limit. The wrong value of MAX_LFS_FILESIZE actually caused problems for Doug Nazar, who was still using a 32-bit host, but with a 9.7TB 2 x RAID5 volume. It turns out that our old MAX_LFS_FILESIZE was 8TiB (well, one byte less), but the actual true VM limit is one page less than 16TiB. This was invisible until commit c2a9737f45e2 ("vfs,mm: fix a dead loop in truncate_inode_pages_range()"), which started applying that MAX_LFS_FILESIZE limit to block devices too. NOTE! On 64-bit, the page index isn't a limiter at all, and the limit is actually just the offset type itself (loff_t), which is signed. But for clarity, on 64-bit, just use the maximum signed value, and don't make people have to count the number of 'f' characters in the hex constant. So just use LLONG_MAX for the 64-bit case. That was what the value had been before too, just written out as a hex constant. Fixes: c2a9737f45e2 ("vfs,mm: fix a dead loop in truncate_inode_pages_range()") Reported-and-tested-by: Doug Nazar <nazard@nazar.ca> Cc: Andreas Dilger <adilger@dilger.ca> Cc: Mark Fasheh <mfasheh@versity.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rafael Tinoco <rafael.tinoco@linaro.org> [backported to 4.4.y due to requests of failed LTP tests - gregkh] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16gpio: No NULL ownerLinus Walleij
commit 7d18f0a14aa6a0d6bad39111c1fb655f07f71d59 upstream. Sometimes a GPIO is fetched with NULL as parent device, and that is just fine. So under these circumstances, avoid using dev_name() to provide a name for the GPIO line. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Daniel Rosenberg <drosen@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/crypto, x86/fpu: Remove X86_FEATURE_EAGER_FPU #ifdef from the crc32c codeAndy Lutomirski
commit 02f39b2379fb81557ae864ec8f85421c0250c954 upstream. The crypto code was checking both use_eager_fpu() and defined(X86_FEATURE_EAGER_FPU). The latter was nonsensical, so remove it. This will avoid breakage when we remove X86_FEATURE_EAGER_FPU. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: pbonzini@redhat.com Link: http://lkml.kernel.org/r/1475627678-20788-2-git-send-email-riel@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16af_key: Always verify length of provided sadb_keyKevin Easton
commit 4b66af2d6356a00e94bcdea3e7fea324e8b5c6f4 upstream. Key extensions (struct sadb_key) include a user-specified number of key bits. The kernel uses that number to determine how much key data to copy out of the message in pfkey_msg2xfrm_state(). The length of the sadb_key message must be verified to be long enough, even in the case of SADB_X_AALG_NULL. Furthermore, the sadb_key_len value must be long enough to include both the key data and the struct sadb_key itself. Introduce a helper function verify_key_len(), and call it from parse_exthdrs() where other exthdr types are similarly checked for correctness. Signed-off-by: Kevin Easton <kevin@guarana.org> Reported-by: syzbot+5022a34ca5a3d49b84223653fab632dfb7b4cf37@syzkaller.appspotmail.com Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Cc: Zubin Mithra <zsm@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Fix math emulation in eager fpu modeAndy Lutomirski
commit 4ecd16ec7059390b430af34bd8bc3ca2b5dcef9a upstream. Systems without an FPU are generally old and therefore use lazy FPU switching. Unsurprisingly, math emulation in eager FPU mode is a bit buggy. Fix it. There were two bugs involving kernel code trying to use the FPU registers in eager mode even if they didn't exist and one BUG_ON() that was incorrect. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Rik van Riel <riel@redhat.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/b4b8d112436bd6fab866e1b4011131507e8d7fbe.1453675014.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Fix FNSAVE usage in eagerfpu modeAndy Lutomirski
commit 5ed73f40735c68d8a656b46d09b1885d3b8740ae upstream. In eager fpu mode, having deactivated FPU without immediately reloading some other context is illegal. Therefore, to recover from FNSAVE, we can't just deactivate the state -- we need to reload it if we're not actively context switching. We had this wrong in fpu__save() and fpu__copy(). Fix both. __kernel_fpu_begin() was fine -- add a comment. This fixes a warning triggerable with nofxsr eagerfpu=on. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Rik van Riel <riel@redhat.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/60662444e13c76f06e23c15c5dcdba31b4ac3d67.1453675014.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Hard-disable lazy FPU modeAndy Lutomirski
commit ca6938a1cd8a1c5e861a99b67f84ac166fc2b9e7 upstream. Since commit: 58122bf1d856 ("x86/fpu: Default eagerfpu=on on all CPUs") ... in Linux 4.6, eager FPU mode has been the default on all x86 systems, and no one has reported any regressions. This patch removes the ability to enable lazy mode: use_eager_fpu() becomes "return true" and all of the FPU mode selection machinery is removed. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: pbonzini@redhat.com Link: http://lkml.kernel.org/r/1475627678-20788-3-git-send-email-riel@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Fix eager-FPU handling on legacy FPU machinesBorislav Petkov
commit 6e6867093de35141f0a76b66ac13f9f2e2c8e77a upstream. i486 derived cores like Intel Quark support only the very old, legacy x87 FPU (FSAVE/FRSTOR, CPUID bit FXSR is not set), and our FPU code wasn't handling the saving and restoring there properly in the 'eagerfpu' case. So after we made eagerfpu the default for all CPU types: 58122bf1d856 x86/fpu: Default eagerfpu=on on all CPUs these old FPU designs broke. First, Andy Shevchenko reported a splat: WARNING: CPU: 0 PID: 823 at arch/x86/include/asm/fpu/internal.h:163 fpu__clear+0x8c/0x160 which was us trying to execute FXRSTOR on those machines even though they don't support it. After taking care of that, Bryan O'Donoghue reported that a simple FPU test still failed because we weren't initializing the FPU state properly on those machines. Take care of all that. Reported-and-tested-by: Bryan O'Donoghue <pure.logic@nexus-software.ie> Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20160311113206.GD4312@pd.tnic Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Revert ("x86/fpu: Disable AVX when eagerfpu is off")Yu-cheng Yu
commit a65050c6f17e52442716138d48d0a47301a8344b upstream. Leonid Shatz noticed that the SDM interpretation of the following recent commit: 394db20ca240741 ("x86/fpu: Disable AVX when eagerfpu is off") ... is incorrect and that the original behavior of the FPU code was correct. Because AVX is not stated in CR0 TS bit description, it was mistakenly believed to be not supported for lazy context switch. This turns out to be false: Intel Software Developer's Manual Vol. 3A, Sec. 2.5 Control Registers: 'TS Task Switched bit (bit 3 of CR0) -- Allows the saving of the x87 FPU/ MMX/SSE/SSE2/SSE3/SSSE3/SSE4 context on a task switch to be delayed until an x87 FPU/MMX/SSE/SSE2/SSE3/SSSE3/SSE4 instruction is actually executed by the new task.' Intel Software Developer's Manual Vol. 2A, Sec. 2.4 Instruction Exception Specification: 'AVX instructions refer to exceptions by classes that include #NM "Device Not Available" exception for lazy context switch.' So revert the commit. Reported-by: Leonid Shatz <leonid.shatz@ravellosystems.com> Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ravi V. Shankar <ravi.v.shankar@intel.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1457569734-3785-1-git-send-email-yu-cheng.yu@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Fix 'no387' regressionAndy Lutomirski
commit f363938c70a04e6bc99023a5e0c44ef7879b903f upstream. After fixing FPU option parsing, we now parse the 'no387' boot option too early: no387 clears X86_FEATURE_FPU before it's even probed, so the boot CPU promptly re-enables it. I suspect it gets even more confused on SMP. Fix the probing code to leave X86_FEATURE_FPU off if it's been disabled by setup_clear_cpu_cap(). Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Fixes: 4f81cbafcce2 ("x86/fpu: Fix early FPU command-line parsing") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Default eagerfpu=on on all CPUsAndy Lutomirski
commit 58122bf1d856a4ea9581d62a07c557d997d46a19 upstream. We have eager and lazy FPU modes, introduced in: 304bceda6a18 ("x86, fpu: use non-lazy fpu restore for processors supporting xsave") The result is rather messy. There are two code paths in almost all of the FPU code, and only one of them (the eager case) is tested frequently, since most kernel developers have new enough hardware that we use eagerfpu. It seems that, on any remotely recent hardware, eagerfpu is a win: glibc uses SSE2, so laziness is probably overoptimistic, and, in any case, manipulating TS is far slower that saving and restoring the full state. (Stores to CR0.TS are serializing and are poorly optimized.) To try to shake out any latent issues on old hardware, this changes the default to eager on all CPUs. If no performance or functionality problems show up, a subsequent patch could remove lazy mode entirely. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Rik van Riel <riel@redhat.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/ac290de61bf08d9cfc2664a4f5080257ffc1075a.1453675014.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Disable AVX when eagerfpu is offyu-cheng yu
commit 394db20ca240741a08d472173db13d6f6a6e5a28 upstream. When "eagerfpu=off" is given as a command-line input, the kernel should disable AVX support. The Task Switched bit used for lazy context switching does not support AVX. If AVX is enabled without eagerfpu context switching, one task's AVX state could become corrupted or leak to other tasks. This is a bug and has bad security implications. This only affects systems that have AVX/AVX2/AVX512 and this issue will be found only when one actually uses AVX/AVX2/AVX512 _AND_ does eagerfpu=off. Reference: Intel Software Developer's Manual Vol. 3A Sec. 2.5 Control Registers: TS Task Switched bit (bit 3 of CR0) -- Allows the saving of the x87 FPU/ MMX/SSE/SSE2/SSE3/SSSE3/SSE4 context on a task switch to be delayed until an x87 FPU/MMX/SSE/SSE2/SSE3/SSSE3/SSE4 instruction is actually executed by the new task. Sec. 13.4.1 Using the TS Flag to Control the Saving of the X87 FPU and SSE State When the TS flag is set, the processor monitors the instruction stream for x87 FPU, MMX, SSE instructions. When the processor detects one of these instructions, it raises a device-not-available exeception (#NM) prior to executing the instruction. Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Ravi V. Shankar <ravi.v.shankar@intel.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/1452119094-7252-5-git-send-email-yu-cheng.yu@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Disable MPX when eagerfpu is offyu-cheng yu
commit a5fe93a549c54838063d2952dd9643b0b18aa67f upstream. This issue is a fallout from the command-line parsing move. When "eagerfpu=off" is given as a command-line input, the kernel should disable MPX support. The decision for turning off MPX was made in fpu__init_system_ctx_switch(), which is after the selection of the XSAVE format. This patch fixes it by getting that decision done earlier in fpu__init_system_xstate(). Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Ravi V. Shankar <ravi.v.shankar@intel.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/1452119094-7252-4-git-send-email-yu-cheng.yu@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/cpufeature: Remove unused and seldomly used cpu_has_xx macrosBorislav Petkov
commit 362f924b64ba0f4be2ee0cb697690c33d40be721 upstream. Those are stupid and code should use static_cpu_has_safe() or boot_cpu_has() instead. Kill the least used and unused ones. The remaining ones need more careful inspection before a conversion can happen. On the TODO. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1449481182-27541-4-git-send-email-bp@alien8.de Cc: David Sterba <dsterba@suse.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Matt Mackall <mpm@selenic.com> Cc: Chris Mason <clm@fb.com> Cc: Josef Bacik <jbacik@fb.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86: Remove unused function cpu_has_ht_siblings()Juergen Gross
commit ed29210cd6a67425026e78aa298fa434e11a74e3 upstream. It is used nowhere. Signed-off-by: Juergen Gross <jgross@suse.com> Link: http://lkml.kernel.org/r/1447761943-770-1-git-send-email-jgross@suse.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-16x86/fpu: Fix early FPU command-line parsingyu-cheng yu
commit 4f81cbafcce2c603db7865e9d0e461f7947d77d4 upstream. The function fpu__init_system() is executed before parse_early_param(). This causes wrong FPU configuration. This patch fixes this issue by parsing boot_command_line in the beginning of fpu__init_system(). With all four patches in this series, each parameter disables features as the following: eagerfpu=off: eagerfpu, avx, avx2, avx512, mpx no387: fpu nofxsr: fxsr, fxsropt, xmm noxsave: xsave, xsaveopt, xsaves, xsavec, avx, avx2, avx512, mpx, xgetbv1 noxsaveopt: xsaveopt noxsaves: xsaves Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Ravi V. Shankar <ravi.v.shankar@intel.com> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: yu-cheng yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/1452119094-7252-2-git-send-email-yu-cheng.yu@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13Linux 4.4.137v4.4.137Greg Kroah-Hartman
2018-06-13net: metrics: add proper netlink validationEric Dumazet
[ Upstream commit 5b5e7a0de2bbf2a1afcd9f49e940010e9fb80d53 ] Before using nla_get_u32(), better make sure the attribute is of the proper size. Code recently was changed, but bug has been there from beginning of git. BUG: KMSAN: uninit-value in rtnetlink_put_metrics+0x553/0x960 net/core/rtnetlink.c:746 CPU: 1 PID: 14139 Comm: syz-executor6 Not tainted 4.17.0-rc5+ #103 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x185/0x1d0 lib/dump_stack.c:113 kmsan_report+0x149/0x260 mm/kmsan/kmsan.c:1084 __msan_warning_32+0x6e/0xc0 mm/kmsan/kmsan_instr.c:686 rtnetlink_put_metrics+0x553/0x960 net/core/rtnetlink.c:746 fib_dump_info+0xc42/0x2190 net/ipv4/fib_semantics.c:1361 rtmsg_fib+0x65f/0x8c0 net/ipv4/fib_semantics.c:419 fib_table_insert+0x2314/0x2b50 net/ipv4/fib_trie.c:1287 inet_rtm_newroute+0x210/0x340 net/ipv4/fib_frontend.c:779 rtnetlink_rcv_msg+0xa32/0x1560 net/core/rtnetlink.c:4646 netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2448 rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:4664 netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline] netlink_unicast+0x1678/0x1750 net/netlink/af_netlink.c:1336 netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg net/socket.c:639 [inline] ___sys_sendmsg+0xec0/0x1310 net/socket.c:2117 __sys_sendmsg net/socket.c:2155 [inline] __do_sys_sendmsg net/socket.c:2164 [inline] __se_sys_sendmsg net/socket.c:2162 [inline] __x64_sys_sendmsg+0x331/0x460 net/socket.c:2162 do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x44/0xa9 RIP: 0033:0x455a09 RSP: 002b:00007faae5fd8c68 EFLAGS: 00000246 ORIG_RAX: 000000000000002e RAX: ffffffffffffffda RBX: 00007faae5fd96d4 RCX: 0000000000455a09 RDX: 0000000000000000 RSI: 0000000020000000 RDI: 0000000000000013 RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff R13: 00000000000005d0 R14: 00000000006fdc20 R15: 0000000000000000 Uninit was stored to memory at: kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline] kmsan_save_stack mm/kmsan/kmsan.c:294 [inline] kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:685 __msan_chain_origin+0x69/0xc0 mm/kmsan/kmsan_instr.c:529 fib_convert_metrics net/ipv4/fib_semantics.c:1056 [inline] fib_create_info+0x2d46/0x9dc0 net/ipv4/fib_semantics.c:1150 fib_table_insert+0x3e4/0x2b50 net/ipv4/fib_trie.c:1146 inet_rtm_newroute+0x210/0x340 net/ipv4/fib_frontend.c:779 rtnetlink_rcv_msg+0xa32/0x1560 net/core/rtnetlink.c:4646 netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2448 rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:4664 netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline] netlink_unicast+0x1678/0x1750 net/netlink/af_netlink.c:1336 netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg net/socket.c:639 [inline] ___sys_sendmsg+0xec0/0x1310 net/socket.c:2117 __sys_sendmsg net/socket.c:2155 [inline] __do_sys_sendmsg net/socket.c:2164 [inline] __se_sys_sendmsg net/socket.c:2162 [inline] __x64_sys_sendmsg+0x331/0x460 net/socket.c:2162 do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Uninit was created at: kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline] kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:189 kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:315 kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan.c:322 slab_post_alloc_hook mm/slab.h:446 [inline] slab_alloc_node mm/slub.c:2753 [inline] __kmalloc_node_track_caller+0xb32/0x11b0 mm/slub.c:4395 __kmalloc_reserve net/core/skbuff.c:138 [inline] __alloc_skb+0x2cb/0x9e0 net/core/skbuff.c:206 alloc_skb include/linux/skbuff.h:988 [inline] netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline] netlink_sendmsg+0x76e/0x1350 net/netlink/af_netlink.c:1876 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg net/socket.c:639 [inline] ___sys_sendmsg+0xec0/0x1310 net/socket.c:2117 __sys_sendmsg net/socket.c:2155 [inline] __do_sys_sendmsg net/socket.c:2164 [inline] __se_sys_sendmsg net/socket.c:2162 [inline] __x64_sys_sendmsg+0x331/0x460 net/socket.c:2162 do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Fixes: a919525ad832 ("net: Move fib_convert_metrics to metrics file") Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Cc: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13net: phy: broadcom: Fix bcm_write_exp()Florian Fainelli
[ Upstream commit 79fb218d97980d4fee9a64f4c8ff05289364ba25 ] On newer PHYs, we need to select the expansion register to write with setting bits [11:8] to 0xf. This was done correctly by bcm7xxx.c prior to being migrated to generic code under bcm-phy-lib.c which unfortunately used the older implementation from the BCM54xx days. Fix this by creating an inline stub: bcm_write_exp_sel() which adds the correct value (MII_BCM54XX_EXP_SEL_ER) and update both the Cygnus PHY and BCM7xxx PHY drivers which require setting these bits. broadcom.c is unchanged because some PHYs even use a different selector method, so let them specify it directly (e.g: SerDes secondary selector). Fixes: a1cba5613edf ("net: phy: Add Broadcom phy library for common interfaces") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13rtnetlink: validate attributes in do_setlink()Eric Dumazet
[ Upstream commit 644c7eebbfd59e72982d11ec6cc7d39af12450ae ] It seems that rtnl_group_changelink() can call do_setlink while a prior call to validate_linkmsg(dev = NULL, ...) could not validate IFLA_ADDRESS / IFLA_BROADCAST Make sure do_setlink() calls validate_linkmsg() instead of letting its callers having this responsibility. With help from Dmitry Vyukov, thanks a lot ! BUG: KMSAN: uninit-value in is_valid_ether_addr include/linux/etherdevice.h:199 [inline] BUG: KMSAN: uninit-value in eth_prepare_mac_addr_change net/ethernet/eth.c:275 [inline] BUG: KMSAN: uninit-value in eth_mac_addr+0x203/0x2b0 net/ethernet/eth.c:308 CPU: 1 PID: 8695 Comm: syz-executor3 Not tainted 4.17.0-rc5+ #103 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x185/0x1d0 lib/dump_stack.c:113 kmsan_report+0x149/0x260 mm/kmsan/kmsan.c:1084 __msan_warning_32+0x6e/0xc0 mm/kmsan/kmsan_instr.c:686 is_valid_ether_addr include/linux/etherdevice.h:199 [inline] eth_prepare_mac_addr_change net/ethernet/eth.c:275 [inline] eth_mac_addr+0x203/0x2b0 net/ethernet/eth.c:308 dev_set_mac_address+0x261/0x530 net/core/dev.c:7157 do_setlink+0xbc3/0x5fc0 net/core/rtnetlink.c:2317 rtnl_group_changelink net/core/rtnetlink.c:2824 [inline] rtnl_newlink+0x1fe9/0x37a0 net/core/rtnetlink.c:2976 rtnetlink_rcv_msg+0xa32/0x1560 net/core/rtnetlink.c:4646 netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2448 rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:4664 netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline] netlink_unicast+0x1678/0x1750 net/netlink/af_netlink.c:1336 netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg net/socket.c:639 [inline] ___sys_sendmsg+0xec0/0x1310 net/socket.c:2117 __sys_sendmsg net/socket.c:2155 [inline] __do_sys_sendmsg net/socket.c:2164 [inline] __se_sys_sendmsg net/socket.c:2162 [inline] __x64_sys_sendmsg+0x331/0x460 net/socket.c:2162 do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x44/0xa9 RIP: 0033:0x455a09 RSP: 002b:00007fc07480ec68 EFLAGS: 00000246 ORIG_RAX: 000000000000002e RAX: ffffffffffffffda RBX: 00007fc07480f6d4 RCX: 0000000000455a09 RDX: 0000000000000000 RSI: 00000000200003c0 RDI: 0000000000000014 RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff R13: 00000000000005d0 R14: 00000000006fdc20 R15: 0000000000000000 Uninit was stored to memory at: kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline] kmsan_save_stack mm/kmsan/kmsan.c:294 [inline] kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:685 kmsan_memcpy_origins+0x11d/0x170 mm/kmsan/kmsan.c:527 __msan_memcpy+0x109/0x160 mm/kmsan/kmsan_instr.c:478 do_setlink+0xb84/0x5fc0 net/core/rtnetlink.c:2315 rtnl_group_changelink net/core/rtnetlink.c:2824 [inline] rtnl_newlink+0x1fe9/0x37a0 net/core/rtnetlink.c:2976 rtnetlink_rcv_msg+0xa32/0x1560 net/core/rtnetlink.c:4646 netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2448 rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:4664 netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline] netlink_unicast+0x1678/0x1750 net/netlink/af_netlink.c:1336 netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg net/socket.c:639 [inline] ___sys_sendmsg+0xec0/0x1310 net/socket.c:2117 __sys_sendmsg net/socket.c:2155 [inline] __do_sys_sendmsg net/socket.c:2164 [inline] __se_sys_sendmsg net/socket.c:2162 [inline] __x64_sys_sendmsg+0x331/0x460 net/socket.c:2162 do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Uninit was created at: kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline] kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:189 kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:315 kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan.c:322 slab_post_alloc_hook mm/slab.h:446 [inline] slab_alloc_node mm/slub.c:2753 [inline] __kmalloc_node_track_caller+0xb32/0x11b0 mm/slub.c:4395 __kmalloc_reserve net/core/skbuff.c:138 [inline] __alloc_skb+0x2cb/0x9e0 net/core/skbuff.c:206 alloc_skb include/linux/skbuff.h:988 [inline] netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline] netlink_sendmsg+0x76e/0x1350 net/netlink/af_netlink.c:1876 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg net/socket.c:639 [inline] ___sys_sendmsg+0xec0/0x1310 net/socket.c:2117 __sys_sendmsg net/socket.c:2155 [inline] __do_sys_sendmsg net/socket.c:2164 [inline] __se_sys_sendmsg net/socket.c:2162 [inline] __x64_sys_sendmsg+0x331/0x460 net/socket.c:2162 do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Fixes: e7ed828f10bd ("netlink: support setting devgroup parameters") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Cc: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13team: use netdev_features_t instead of u32Dan Carpenter
[ Upstream commit 25ea66544bfd1d9df1b7e1502f8717e85fa1e6e6 ] This code was introduced in 2011 around the same time that we made netdev_features_t a u64 type. These days a u32 is not big enough to hold all the potential features. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13net/mlx4: Fix irq-unsafe spinlock usageJack Morgenstein
[ Upstream commit d546b67cda015fb92bfee93d5dc0ceadb91deaee ] spin_lock/unlock was used instead of spin_un/lock_irq in a procedure used in process space, on a spinlock which can be grabbed in an interrupt. This caused the stack trace below to be displayed (on kernel 4.17.0-rc1 compiled with Lock Debugging enabled): [ 154.661474] WARNING: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected [ 154.668909] 4.17.0-rc1-rdma_rc_mlx+ #3 Tainted: G I [ 154.675856] ----------------------------------------------------- [ 154.682706] modprobe/10159 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire: [ 154.690254] 00000000f3b0e495 (&(&qp_table->lock)->rlock){+.+.}, at: mlx4_qp_remove+0x20/0x50 [mlx4_core] [ 154.700927] and this task is already holding: [ 154.707461] 0000000094373b5d (&(&cq->lock)->rlock/1){....}, at: destroy_qp_common+0x111/0x560 [mlx4_ib] [ 154.718028] which would create a new lock dependency: [ 154.723705] (&(&cq->lock)->rlock/1){....} -> (&(&qp_table->lock)->rlock){+.+.} [ 154.731922] but this new dependency connects a SOFTIRQ-irq-safe lock: [ 154.740798] (&(&cq->lock)->rlock){..-.} [ 154.740800] ... which became SOFTIRQ-irq-safe at: [ 154.752163] _raw_spin_lock_irqsave+0x3e/0x50 [ 154.757163] mlx4_ib_poll_cq+0x36/0x900 [mlx4_ib] [ 154.762554] ipoib_tx_poll+0x4a/0xf0 [ib_ipoib] ... to a SOFTIRQ-irq-unsafe lock: [ 154.815603] (&(&qp_table->lock)->rlock){+.+.} [ 154.815604] ... which became SOFTIRQ-irq-unsafe at: [ 154.827718] ... [ 154.827720] _raw_spin_lock+0x35/0x50 [ 154.833912] mlx4_qp_lookup+0x1e/0x50 [mlx4_core] [ 154.839302] mlx4_flow_attach+0x3f/0x3d0 [mlx4_core] Since mlx4_qp_lookup() is called only in process space, we can simply replace the spin_un/lock calls with spin_un/lock_irq calls. Fixes: 6dc06c08bef1 ("net/mlx4: Fix the check in attaching steering rules") Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Tariq Toukan <tariqt@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13qed: Fix mask for physical address in ILT entryShahed Shaikh
[ Upstream commit fdd13dd350dda1826579eb5c333d76b14513b812 ] ILT entry requires 12 bit right shifted physical address. Existing mask for ILT entry of physical address i.e. ILT_ENTRY_PHY_ADDR_MASK is not sufficient to handle 64bit address because upper 8 bits of 64 bit address were getting masked which resulted in completer abort error on PCIe bus due to invalid address. Fix that mask to handle 64bit physical address. Fixes: fe56b9e6a8d9 ("qed: Add module with basic common support") Signed-off-by: Shahed Shaikh <shahed.shaikh@cavium.com> Signed-off-by: Ariel Elior <ariel.elior@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13packet: fix reserve calculationWillem de Bruijn
[ Upstream commit 9aad13b087ab0a588cd68259de618f100053360e ] Commit b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation") ensures that packet_snd always starts writing the link layer header in reserved headroom allocated for this purpose. This is needed because packets may be shorter than hard_header_len, in which case the space up to hard_header_len may be zeroed. But that necessary padding is not accounted for in skb->len. The fix, however, is buggy. It calls skb_push, which grows skb->len when moving skb->data back. But in this case packet length should not change. Instead, call skb_reserve, which moves both skb->data and skb->tail back, without changing length. Fixes: b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation") Reported-by: Tariq Toukan <tariqt@mellanox.com> Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Soheil Hassas Yeganeh <soheil@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13net: usb: cdc_mbim: add flag FLAG_SEND_ZLPDaniele Palmas
[ Upstream commit 9f7c728332e8966084242fcd951aa46583bc308c ] Testing Telit LM940 with ICMP packets > 14552 bytes revealed that the modem needs FLAG_SEND_ZLP to properly work, otherwise the cdc mbim data interface won't be anymore responsive. Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Acked-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13net/packet: refine check for priv area sizeEric Dumazet
[ Upstream commit eb73190f4fbeedf762394e92d6a4ec9ace684c88 ] syzbot was able to trick af_packet again [1] Various commits tried to address the problem in the past, but failed to take into account V3 header size. [1] tpacket_rcv: packet too big, clamped from 72 to 4294967224. macoff=96 BUG: KASAN: use-after-free in prb_run_all_ft_ops net/packet/af_packet.c:1016 [inline] BUG: KASAN: use-after-free in prb_fill_curr_block.isra.59+0x4e5/0x5c0 net/packet/af_packet.c:1039 Write of size 2 at addr ffff8801cb62000e by task kworker/1:2/2106 CPU: 1 PID: 2106 Comm: kworker/1:2 Not tainted 4.17.0-rc7+ #77 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Workqueue: ipv6_addrconf addrconf_dad_work Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1b9/0x294 lib/dump_stack.c:113 print_address_description+0x6c/0x20b mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412 __asan_report_store2_noabort+0x17/0x20 mm/kasan/report.c:436 prb_run_all_ft_ops net/packet/af_packet.c:1016 [inline] prb_fill_curr_block.isra.59+0x4e5/0x5c0 net/packet/af_packet.c:1039 __packet_lookup_frame_in_block net/packet/af_packet.c:1094 [inline] packet_current_rx_frame net/packet/af_packet.c:1117 [inline] tpacket_rcv+0x1866/0x3340 net/packet/af_packet.c:2282 dev_queue_xmit_nit+0x891/0xb90 net/core/dev.c:2018 xmit_one net/core/dev.c:3049 [inline] dev_hard_start_xmit+0x16b/0xc10 net/core/dev.c:3069 __dev_queue_xmit+0x2724/0x34c0 net/core/dev.c:3584 dev_queue_xmit+0x17/0x20 net/core/dev.c:3617 neigh_resolve_output+0x679/0xad0 net/core/neighbour.c:1358 neigh_output include/net/neighbour.h:482 [inline] ip6_finish_output2+0xc9c/0x2810 net/ipv6/ip6_output.c:120 ip6_finish_output+0x5fe/0xbc0 net/ipv6/ip6_output.c:154 NF_HOOK_COND include/linux/netfilter.h:277 [inline] ip6_output+0x227/0x9b0 net/ipv6/ip6_output.c:171 dst_output include/net/dst.h:444 [inline] NF_HOOK include/linux/netfilter.h:288 [inline] ndisc_send_skb+0x100d/0x1570 net/ipv6/ndisc.c:491 ndisc_send_ns+0x3c1/0x8d0 net/ipv6/ndisc.c:633 addrconf_dad_work+0xbef/0x1340 net/ipv6/addrconf.c:4033 process_one_work+0xc1e/0x1b50 kernel/workqueue.c:2145 worker_thread+0x1cc/0x1440 kernel/workqueue.c:2279 kthread+0x345/0x410 kernel/kthread.c:240 ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412 The buggy address belongs to the page: page:ffffea00072d8800 count:0 mapcount:-127 mapping:0000000000000000 index:0xffff8801cb620e80 flags: 0x2fffc0000000000() raw: 02fffc0000000000 0000000000000000 ffff8801cb620e80 00000000ffffff80 raw: ffffea00072e3820 ffffea0007132d20 0000000000000002 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8801cb61ff00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ffff8801cb61ff80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 >ffff8801cb620000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ^ ffff8801cb620080: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ffff8801cb620100: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff Fixes: 2b6867c2ce76 ("net/packet: fix overflow in check for priv area size") Fixes: dc808110bb62 ("packet: handle too big packets for PACKET_V3") Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13netdev-FAQ: clarify DaveM's position for stable backportsCong Wang
[ Upstream commit 75d4e704fa8d2cf33ff295e5b441317603d7f9fd ] Per discussion with David at netconf 2018, let's clarify DaveM's position of handling stable backports in netdev-FAQ. This is important for people relying on upstream -stable releases. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13isdn: eicon: fix a missing-check bugWenwen Wang
[ Upstream commit 6009d1fe6ba3bb2dab55921da60465329cc1cd89 ] In divasmain.c, the function divas_write() firstly invokes the function diva_xdi_open_adapter() to open the adapter that matches with the adapter number provided by the user, and then invokes the function diva_xdi_write() to perform the write operation using the matched adapter. The two functions diva_xdi_open_adapter() and diva_xdi_write() are located in diva.c. In diva_xdi_open_adapter(), the user command is copied to the object 'msg' from the userspace pointer 'src' through the function pointer 'cp_fn', which eventually calls copy_from_user() to do the copy. Then, the adapter number 'msg.adapter' is used to find out a matched adapter from the 'adapter_queue'. A matched adapter will be returned if it is found. Otherwise, NULL is returned to indicate the failure of the verification on the adapter number. As mentioned above, if a matched adapter is returned, the function diva_xdi_write() is invoked to perform the write operation. In this function, the user command is copied once again from the userspace pointer 'src', which is the same as the 'src' pointer in diva_xdi_open_adapter() as both of them are from the 'buf' pointer in divas_write(). Similarly, the copy is achieved through the function pointer 'cp_fn', which finally calls copy_from_user(). After the successful copy, the corresponding command processing handler of the matched adapter is invoked to perform the write operation. It is obvious that there are two copies here from userspace, one is in diva_xdi_open_adapter(), and one is in diva_xdi_write(). Plus, both of these two copies share the same source userspace pointer, i.e., the 'buf' pointer in divas_write(). Given that a malicious userspace process can race to change the content pointed by the 'buf' pointer, this can pose potential security issues. For example, in the first copy, the user provides a valid adapter number to pass the verification process and a valid adapter can be found. Then the user can modify the adapter number to an invalid number. This way, the user can bypass the verification process of the adapter number and inject inconsistent data. This patch reuses the data copied in diva_xdi_open_adapter() and passes it to diva_xdi_write(). This way, the above issues can be avoided. Signed-off-by: Wenwen Wang <wang6495@umn.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13ipv4: remove warning in ip_recv_errorWillem de Bruijn
[ Upstream commit 730c54d59403658a62af6517338fa8d4922c1b28 ] A precondition check in ip_recv_error triggered on an otherwise benign race. Remove the warning. The warning triggers when passing an ipv6 socket to this ipv4 error handling function. RaceFuzzer was able to trigger it due to a race in setsockopt IPV6_ADDRFORM. --- CPU0 do_ipv6_setsockopt sk->sk_socket->ops = &inet_dgram_ops; --- CPU1 sk->sk_prot->recvmsg udp_recvmsg ip_recv_error WARN_ON_ONCE(sk->sk_family == AF_INET6); --- CPU0 do_ipv6_setsockopt sk->sk_family = PF_INET; This socket option converts a v6 socket that is connected to a v4 peer to an v4 socket. It updates the socket on the fly, changing fields in sk as well as other structs. This is inherently non-atomic. It races with the lockless udp_recvmsg path. No other code makes an assumption that these fields are updated atomically. It is benign here, too, as ip_recv_error cares only about the protocol of the skbs enqueued on the error queue, for which sk_family is not a precise predictor (thanks to another isue with IPV6_ADDRFORM). Link: http://lkml.kernel.org/r/20180518120826.GA19515@dragonet.kaist.ac.kr Fixes: 7ce875e5ecb8 ("ipv4: warn once on passing AF_INET6 socket to ip_recv_error") Reported-by: DaeRyong Jeong <threeearcat@gmail.com> Suggested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeedsSabrina Dubroca
[ Upstream commit 848235edb5c93ed086700584c8ff64f6d7fc778d ] Currently, raw6_sk(sk)->ip6mr_table is set unconditionally during ip6_mroute_setsockopt(MRT6_TABLE). A subsequent attempt at the same setsockopt will fail with -ENOENT, since we haven't actually created that table. A similar fix for ipv4 was included in commit 5e1859fbcc3c ("ipv4: ipmr: various fixes and cleanups"). Fixes: d1db275dd3f6 ("ipv6: ip6mr: support multiple tables") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13enic: set DMA mask to 47 bitGovindarajulu Varadarajan
[ Upstream commit 322eaa06d55ebc1402a4a8d140945cff536638b4 ] In commit 624dbf55a359b ("driver/net: enic: Try DMA 64 first, then failover to DMA") DMA mask was changed from 40 bits to 64 bits. Hardware actually supports only 47 bits. Fixes: 624dbf55a359b ("driver/net: enic: Try DMA 64 first, then failover to DMA") Signed-off-by: Govindarajulu Varadarajan <gvaradar@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13dccp: don't free ccid2_hc_tx_sock struct in dccp_disconnect()Alexey Kodanev
[ Upstream commit 2677d20677314101293e6da0094ede7b5526d2b1 ] Syzbot reported the use-after-free in timer_is_static_object() [1]. This can happen because the structure for the rto timer (ccid2_hc_tx_sock) is removed in dccp_disconnect(), and ccid2_hc_tx_rto_expire() can be called after that. The report [1] is similar to the one in commit 120e9dabaf55 ("dccp: defer ccid_hc_tx_delete() at dismantle time"). And the fix is the same, delay freeing ccid2_hc_tx_sock structure, so that it is freed in dccp_sk_destruct(). [1] ================================================================== BUG: KASAN: use-after-free in timer_is_static_object+0x80/0x90 kernel/time/timer.c:607 Read of size 8 at addr ffff8801bebb5118 by task syz-executor2/25299 CPU: 1 PID: 25299 Comm: syz-executor2 Not tainted 4.17.0-rc5+ #54 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: <IRQ> __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1b9/0x294 lib/dump_stack.c:113 print_address_description+0x6c/0x20b mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412 __asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433 timer_is_static_object+0x80/0x90 kernel/time/timer.c:607 debug_object_activate+0x2d9/0x670 lib/debugobjects.c:508 debug_timer_activate kernel/time/timer.c:709 [inline] debug_activate kernel/time/timer.c:764 [inline] __mod_timer kernel/time/timer.c:1041 [inline] mod_timer+0x4d3/0x13b0 kernel/time/timer.c:1102 sk_reset_timer+0x22/0x60 net/core/sock.c:2742 ccid2_hc_tx_rto_expire+0x587/0x680 net/dccp/ccids/ccid2.c:147 call_timer_fn+0x230/0x940 kernel/time/timer.c:1326 expire_timers kernel/time/timer.c:1363 [inline] __run_timers+0x79e/0xc50 kernel/time/timer.c:1666 run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692 __do_softirq+0x2e0/0xaf5 kernel/softirq.c:285 invoke_softirq kernel/softirq.c:365 [inline] irq_exit+0x1d1/0x200 kernel/softirq.c:405 exiting_irq arch/x86/include/asm/apic.h:525 [inline] smp_apic_timer_interrupt+0x17e/0x710 arch/x86/kernel/apic/apic.c:1052 apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:863 </IRQ> ... Allocated by task 25374: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553 kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490 kmem_cache_alloc+0x12e/0x760 mm/slab.c:3554 ccid_new+0x25b/0x3e0 net/dccp/ccid.c:151 dccp_hdlr_ccid+0x27/0x150 net/dccp/feat.c:44 __dccp_feat_activate+0x184/0x270 net/dccp/feat.c:344 dccp_feat_activate_values+0x3a7/0x819 net/dccp/feat.c:1538 dccp_create_openreq_child+0x472/0x610 net/dccp/minisocks.c:128 dccp_v4_request_recv_sock+0x12c/0xca0 net/dccp/ipv4.c:408 dccp_v6_request_recv_sock+0x125d/0x1f10 net/dccp/ipv6.c:415 dccp_check_req+0x455/0x6a0 net/dccp/minisocks.c:197 dccp_v4_rcv+0x7b8/0x1f3f net/dccp/ipv4.c:841 ip_local_deliver_finish+0x2e3/0xd80 net/ipv4/ip_input.c:215 NF_HOOK include/linux/netfilter.h:288 [inline] ip_local_deliver+0x1e1/0x720 net/ipv4/ip_input.c:256 dst_input include/net/dst.h:450 [inline] ip_rcv_finish+0x81b/0x2200 net/ipv4/ip_input.c:396 NF_HOOK include/linux/netfilter.h:288 [inline] ip_rcv+0xb70/0x143d net/ipv4/ip_input.c:492 __netif_receive_skb_core+0x26f5/0x3630 net/core/dev.c:4592 __netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4657 process_backlog+0x219/0x760 net/core/dev.c:5337 napi_poll net/core/dev.c:5735 [inline] net_rx_action+0x7b7/0x1930 net/core/dev.c:5801 __do_softirq+0x2e0/0xaf5 kernel/softirq.c:285 Freed by task 25374: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] __kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521 kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528 __cache_free mm/slab.c:3498 [inline] kmem_cache_free+0x86/0x2d0 mm/slab.c:3756 ccid_hc_tx_delete+0xc3/0x100 net/dccp/ccid.c:190 dccp_disconnect+0x130/0xc66 net/dccp/proto.c:286 dccp_close+0x3bc/0xe60 net/dccp/proto.c:1045 inet_release+0x104/0x1f0 net/ipv4/af_inet.c:427 inet6_release+0x50/0x70 net/ipv6/af_inet6.c:460 sock_release+0x96/0x1b0 net/socket.c:594 sock_close+0x16/0x20 net/socket.c:1149 __fput+0x34d/0x890 fs/file_table.c:209 ____fput+0x15/0x20 fs/file_table.c:243 task_work_run+0x1e4/0x290 kernel/task_work.c:113 tracehook_notify_resume include/linux/tracehook.h:191 [inline] exit_to_usermode_loop+0x2bd/0x310 arch/x86/entry/common.c:166 prepare_exit_to_usermode arch/x86/entry/common.c:196 [inline] syscall_return_slowpath arch/x86/entry/common.c:265 [inline] do_syscall_64+0x6ac/0x800 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe The buggy address belongs to the object at ffff8801bebb4cc0 which belongs to the cache ccid2_hc_tx_sock of size 1240 The buggy address is located 1112 bytes inside of 1240-byte region [ffff8801bebb4cc0, ffff8801bebb5198) The buggy address belongs to the page: page:ffffea0006faed00 count:1 mapcount:0 mapping:ffff8801bebb41c0 index:0xffff8801bebb5240 compound_mapcount: 0 flags: 0x2fffc0000008100(slab|head) raw: 02fffc0000008100 ffff8801bebb41c0 ffff8801bebb5240 0000000100000003 raw: ffff8801cdba3138 ffffea0007634120 ffff8801cdbaab40 0000000000000000 page dumped because: kasan: bad access detected ... ================================================================== Reported-by: syzbot+5d47e9ec91a6f15dbd6f@syzkaller.appspotmail.com Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13bnx2x: use the right constantJulia Lawall
[ Upstream commit dd612f18a49b63af8b3a5f572d999bdb197385bc ] Nearby code that also tests port suggests that the P0 constant should be used when port is zero. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e,e1; @@ * e ? e1 : e1 // </smpl> Fixes: 6c3218c6f7e5 ("bnx2x: Adjust ETS to 578xx") Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13brcmfmac: Fix check for ISO3166 codeStefan Wahren
commit 9b9322db5c5a1917a66c71fe47c3848a9a31227e upstream. The commit "regulatory: add NUL to request alpha2" increases the length of alpha2 to 3. This causes a regression on brcmfmac, because brcmf_cfg80211_reg_notifier() expect valid ISO3166 codes in the complete array. So fix this accordingly. Fixes: 657308f73e67 ("regulatory: add NUL to request alpha2") Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Acked-by: Franky Lin <franky.lin@broadcom.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> [bwh: Backported to 4.4: adjust filename] Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13drm: set FMODE_UNSIGNED_OFFSET for drm filesDave Airlie
commit 76ef6b28ea4f81c3d511866a9b31392caa833126 upstream. Since we have the ttm and gem vma managers using a subset of the file address space for objects, and these start at 0x100000000 they will overflow the new mmap checks. I've checked all the mmap routines I could see for any bad behaviour but overall most people use GEM/TTM VMA managers even the legacy drivers have a hashtable. Reported-and-Tested-by: Arthur Marsh (amarsh04 on #radeon) Fixes: be83bbf8068 (mmap: introduce sane default mmap limits) Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13xfs: fix incorrect log_flushed on fsyncAmir Goldstein
commit 47c7d0b19502583120c3f396c7559e7a77288a68 upstream. When calling into _xfs_log_force{,_lsn}() with a pointer to log_flushed variable, log_flushed will be set to 1 if: 1. xlog_sync() is called to flush the active log buffer AND/OR 2. xlog_wait() is called to wait on a syncing log buffers xfs_file_fsync() checks the value of log_flushed after _xfs_log_force_lsn() call to optimize away an explicit PREFLUSH request to the data block device after writing out all the file's pages to disk. This optimization is incorrect in the following sequence of events: Task A Task B ------------------------------------------------------- xfs_file_fsync() _xfs_log_force_lsn() xlog_sync() [submit PREFLUSH] xfs_file_fsync() file_write_and_wait_range() [submit WRITE X] [endio WRITE X] _xfs_log_force_lsn() xlog_wait() [endio PREFLUSH] The write X is not guarantied to be on persistent storage when PREFLUSH request in completed, because write A was submitted after the PREFLUSH request, but xfs_file_fsync() of task A will be notified of log_flushed=1 and will skip explicit flush. If the system crashes after fsync of task A, write X may not be present on disk after reboot. This bug was discovered and demonstrated using Josef Bacik's dm-log-writes target, which can be used to record block io operations and then replay a subset of these operations onto the target device. The test goes something like this: - Use fsx to execute ops of a file and record ops on log device - Every now and then fsync the file, store md5 of file and mark the location in the log - Then replay log onto device for each mark, mount fs and compare md5 of file to stored value Cc: Christoph Hellwig <hch@lst.de> Cc: Josef Bacik <jbacik@fb.com> Cc: <stable@vger.kernel.org> Signed-off-by: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13kconfig: Avoid format overflow warning from GCC 8.1Nathan Chancellor
commit 2ae89c7a82ea9d81a19b4fc2df23bef4b112f24e upstream. In file included from scripts/kconfig/zconf.tab.c:2485: scripts/kconfig/confdata.c: In function ‘conf_write’: scripts/kconfig/confdata.c:773:22: warning: ‘%s’ directive writing likely 7 or more bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(newname, "%s%s", dirname, basename); ^~ scripts/kconfig/confdata.c:773:19: note: assuming directive output of 7 bytes sprintf(newname, "%s%s", dirname, basename); ^~~~~~ scripts/kconfig/confdata.c:773:2: note: ‘sprintf’ output 1 or more bytes (assuming 4104) into a destination of size 4097 sprintf(newname, "%s%s", dirname, basename); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ scripts/kconfig/confdata.c:776:23: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~ scripts/kconfig/confdata.c:776:3: note: ‘sprintf’ output between 13 and 4119 bytes into a destination of size 4097 sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Increase the size of tmpname and newname to make GCC happy. Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13mmap: relax file size limit for regular filesLinus Torvalds
commit 423913ad4ae5b3e8fb8983f70969fb522261ba26 upstream. Commit be83bbf80682 ("mmap: introduce sane default mmap limits") was introduced to catch problems in various ad-hoc character device drivers doing mmap and getting the size limits wrong. In the process, it used "known good" limits for the normal cases of mapping regular files and block device drivers. It turns out that the "s_maxbytes" limit was less "known good" than I thought. In particular, /proc doesn't set it, but exposes one regular file to mmap: /proc/vmcore. As a result, that file got limited to the default MAX_INT s_maxbytes value. This went unnoticed for a while, because apparently the only thing that needs it is the s390 kernel zfcpdump, but there might be other tools that use this too. Vasily suggested just changing s_maxbytes for all of /proc, which isn't wrong, but makes me nervous at this stage. So instead, just make the new mmap limit always be MAX_LFS_FILESIZE for regular files, which won't affect anything else. It wasn't the regular file case I was worried about. I'd really prefer for maxsize to have been per-inode, but that is not how things are today. Fixes: be83bbf80682 ("mmap: introduce sane default mmap limits") Reported-by: Vasily Gorbik <gor@linux.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13mmap: introduce sane default mmap limitsLinus Torvalds
commit be83bbf806822b1b89e0a0f23cd87cddc409e429 upstream. The internal VM "mmap()" interfaces are based on the mmap target doing everything using page indexes rather than byte offsets, because traditionally (ie 32-bit) we had the situation that the byte offset didn't fit in a register. So while the mmap virtual address was limited by the word size of the architecture, the backing store was not. So we're basically passing "pgoff" around as a page index, in order to be able to describe backing store locations that are much bigger than the word size (think files larger than 4GB etc). But while this all makes a ton of sense conceptually, we've been dogged by various drivers that don't really understand this, and internally work with byte offsets, and then try to work with the page index by turning it into a byte offset with "pgoff << PAGE_SHIFT". Which obviously can overflow. Adding the size of the mapping to it to get the byte offset of the end of the backing store just exacerbates the problem, and if you then use this overflow-prone value to check various limits of your device driver mmap capability, you're just setting yourself up for problems. The correct thing for drivers to do is to do their limit math in page indices, the way the interface is designed. Because the generic mmap code _does_ test that the index doesn't overflow, since that's what the mmap code really cares about. HOWEVER. Finding and fixing various random drivers is a sisyphean task, so let's just see if we can just make the core mmap() code do the limiting for us. Realistically, the only "big" backing stores we need to care about are regular files and block devices, both of which are known to do this properly, and which have nice well-defined limits for how much data they can access. So let's special-case just those two known cases, and then limit other random mmap users to a backing store that still fits in "unsigned long". Realistically, that's not much of a limit at all on 64-bit, and on 32-bit architectures the only worry might be the GPU drivers, which can have big physical address spaces. To make it possible for drivers like that to say that they are 64-bit clean, this patch does repurpose the "FMODE_UNSIGNED_OFFSET" bit in the file flags to allow drivers to mark their file descriptors as safe in the full 64-bit mmap address space. [ The timing for doing this is less than optimal, and this should really go in a merge window. But realistically, this needs wide testing more than it needs anything else, and being main-line is the only way to do that. So the earlier the better, even if it's outside the proper development cycle - Linus ] Cc: Kees Cook <keescook@chromium.org> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Willy Tarreau <w@1wt.eu> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13tpm: self test failure should not cause suspend to failChris Chiu
commit 0803d7befa15cab5717d667a97a66214d2a4c083 upstream. The Acer Acer Veriton X4110G has a TPM device detected as: tpm_tis 00:0b: 1.2 TPM (device-id 0xFE, rev-id 71) After the first S3 suspend, the following error appears during resume: tpm tpm0: A TPM error(38) occurred continue selftest Any following S3 suspend attempts will now fail with this error: tpm tpm0: Error (38) sending savestate before suspend PM: Device 00:0b failed to suspend: error 38 Error 38 is TPM_ERR_INVALID_POSTINIT which means the TPM is not in the correct state. This indicates that the platform BIOS is not sending the usual TPM_Startup command during S3 resume. >From this point onwards, all TPM commands will fail. The same issue was previously reported on Foxconn 6150BK8MC and Sony Vaio TX3. The platform behaviour seems broken here, but we should not break suspend/resume because of this. When the unexpected TPM state is encountered, set a flag to skip the affected TPM_SaveState command on later suspends. Cc: stable@vger.kernel.org Signed-off-by: Chris Chiu <chiu@endlessm.com> Signed-off-by: Daniel Drake <drake@endlessm.com> Link: http://lkml.kernel.org/r/CAB4CAwfSCvj1cudi+MWaB5g2Z67d9DwY1o475YOZD64ma23UiQ@mail.gmail.com Link: https://lkml.org/lkml/2011/3/28/192 Link: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=591031 Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13tpm: do not suspend/resume if power stays onEnric Balletbo i Serra
commit b5d0ebc99bf5d0801a5ecbe958caa3d68b8eaee8 upstream. The suspend/resume behavior of the TPM can be controlled by setting "powered-while-suspended" in the DTS. This is useful for the cases when hardware does not power-off the TPM. Signed-off-by: Sonny Rao <sonnyrao@chromium.org> Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
