commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 6ac1dc736b323011a55ecd1fc5897c24c4f77cbd upstream.
Setting si_code to 0 is the same a setting si_code to SI_USER which is definitely
not correct. With si_code set to SI_USER si_pid and si_uid will be copied to
userspace instead of si_addr. Which is very wrong.
So fix this by using a sensible si_code (SEGV_MAPERR) for this failure.
Fixes: b920de1b77b7 ("mn10300: add the MN10300/AM33 architecture to the kernel")
Cc: Masakazu Urade <urade.masakazu@jp.panasonic.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
commit d796e77f1dd541fe34481af2eee6454688d13982 upstream.
As a writable mount, it is not expected for overlayfs to return
EINVAL/EROFS for fsync, even if dir/file is not changed.
This commit fixes the case of fsync of directory, which is easier to
address, because overlayfs already implements fsync file operation for
directories.
The problem reported by Raphael is that new PostgreSQL 10.0 with a
database in overlayfs where lower layer in squashfs fails to start.
The failure is due to fsync error, when PostgreSQL does fsync on all
existing db directories on startup and a specific directory exists
lower layer with no changes.
Reported-by: Raphael Hertzog <raphael@ouaza.com>
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Tested-by: Raphaël Hertzog <hertzog@debian.org>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 43cdd1b716b26f6af16da4e145b6578f98798bf6 upstream.
There's no need to be printing a raw kernel pointer to the kernel log at
every boot. So just remove it, and change the whole message to use the
correct dev_info() call at the same time.
Reported-by: Wang Qize <wang_qize@venustech.com.cn>
commit 5bae7f73d378a986 upstream
Upstream is a near rewrite of the async nvme probe that ultimately didn't
even cleanly merge in 4.5. This patch is a much smaller change targeted
to the regression introduced in 4.4.
If a controller is in a degraded mode that needs admin assistence to
recover, we need to leave the controller running. We just want to disable
namespace access without shuting the controller down.
Fixes: 3cf519b5a8d4("nvme: merge nvme_dev_start, nvme_dev_resume and nvme_async_probe")
Signed-off-by: Keith Busch <keith.busch@intel.com>
commit f3038ee3a3f1017a1cbe9907e31fa12d366c5dcb upstream.
This function was introduced by 247e743cbe6e ("Btrfs: Use async helpers
to deal with pages that have been improperly dirtied") and it didn't do
any error handling then. This function might very well fail in ENOMEM
situation, yet it's not handled, this could lead to inconsistent state.
So let's handle the failure by setting the mapping error bit.
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Reviewed-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 5a0ec388ef0f6e33841aeb810d7fa23f049ec4cd upstream.
Commit 523e1d399ce0 ("block: make gendisk hold a reference to its queue")
modified add_disk() and disk_release() but did not update any of the
error paths that trigger a put_disk() call after disk->queue has been
assigned. That introduced the following behavior in the pktcdvd driver
if pkt_new_dev() fails:
Kernel BUG at 00000000e98fd882 [verbose debug info unavailable]
Since disk_release() calls blk_put_queue() anyway if disk->queue != NULL,
fix this by removing the blk_cleanup_queue() call from the pkt_setup_dev()
error path.
Fixes: commit 523e1d399ce0 ("block: make gendisk hold a reference to its queue")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
commit 544e92581a2ac44607d7cc602c6b54d18656f56d upstream.
Fix an uninitialized variable warning in the Octeon EDAC driver, as seen
in MIPS cavium_octeon_defconfig builds since v4.14 with Codescape GNU
Tools 2016.05-03:
drivers/edac/octeon_edac-lmc.c In function ‘octeon_lmc_edac_poll_o2’:
drivers/edac/octeon_edac-lmc.c:87:24: warning: ‘((long unsigned int*)&int_reg)[1]’ may \
be used uninitialized in this function [-Wmaybe-uninitialized]
if (int_reg.s.sec_err || int_reg.s.ded_err) {
Iinitialise the whole int_reg variable to zero before the conditional
assignments in the error injection case.
Signed-off-by: James Hogan <jhogan@kernel.org>
Acked-by: David Daney <david.daney@cavium.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: linux-mips@linux-mips.org
Fixes: 1bc021e81565 ("EDAC: Octeon: Add error injection support")
Link: http://lkml.kernel.org/r/20171113161206.20990-1-james.hogan@mips.com
commit ca47480921587ae30417dd234a9f79af188e3666 upstream.
Return 0 if the operation was successful, not the userspace memory
value. Check that userspace value equals passed oldval, not itself.
Don't update *uval if the value wasn't read from userspace memory.
This fixes process hang due to infinite loop in futex_lock_pi.
It also fixes a bunch of glibc tests nptl/tst-mutexpi*.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 55fc633c41a08ce9244ff5f528f420b16b1e04d6 upstream.
We need to define NEED_SRM_SAVE_RESTORE on the Avanti, otherwise we get
machine check exception when attempting to reboot the machine.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
commit 21ffceda1c8b3807615c40d440d7815e0c85d366 upstream.
On alpha, a process will crash if it attempts to start a thread and a
signal is delivered at the same time. The crash can be reproduced with
this program: https://cygwin.com/ml/cygwin/2014-11/msg00473.html
The reason for the crash is this:
* we call the clone syscall
* we go to the function copy_process
* copy process calls copy_thread_tls, it is a wrapper around copy_thread
* copy_thread sets the tls pointer: childti->pcb.unique = regs->r20
* copy_thread sets regs->r20 to zero
* we go back to copy_process
* copy process checks "if (signal_pending(current))" and returns
-ERESTARTNOINTR
* the clone syscall is restarted, but this time, regs->r20 is zero, so
the new thread is created with zero tls pointer
* the new thread crashes in start_thread when attempting to access tls
The comment in the code says that setting the register r20 is some
compatibility with OSF/1. But OSF/1 doesn't use the CLONE_SETTLS flag, so
we don't have to zero r20 if CLONE_SETTLS is set. This patch fixes the bug
by zeroing regs->r20 only if CLONE_SETTLS is not set.
commit 0e88bb002a9b2ee8cc3cc9478ce2dc126f849696 upstream.
Set si_signo.
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: linux-sh@vger.kernel.org
Fixes: 0983b31849bb ("sh: Wire up division and address error exceptions on SH-2A.")
commit 500d58300571b6602341b041f97c082a461ef994 upstream.
While reviewing the signal sending on openrisc the do_unaligned_access
function stood out because it is obviously wrong. A comment about an
si_code set above when actually si_code is never set. Leading to a
random si_code being sent to userspace in the event of an unaligned
access.
Looking further SIGBUS BUS_ADRALN is the proper pair of signal and
si_code to send for an unaligned access. That is what other
architectures do and what is required by posix.
Given that do_unaligned_access is broken in a way that no one can be
relying on it on openrisc fix the code to just do the right thing.
Fixes: 769a8a96229e ("OpenRISC: Traps")
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Stafford Horne <shorne@gmail.com>
Cc: openrisc@lists.librecores.org
Acked-by: Stafford Horne <shorne@gmail.com>
commit 61f5acea8737d9b717fcc22bb6679924f3c82b98 upstream.
Commit 7d06d5895c15 ("Revert "Bluetooth: btusb: fix QCA...suspend/resume"")
removed the setting of the BTUSB_RESET_RESUME quirk for QCA Rome devices,
instead favoring adding USB_QUIRK_RESET_RESUME quirks in usb/core/quirks.c.
This was done because the DIY BTUSB_RESET_RESUME reset-resume handling
has several issues (see the original commit message). An added advantage
of moving over to the USB-core reset-resume handling is that it also
disables autosuspend for these devices, which is similarly broken on these.
But there are 2 issues with this approach:
1) It leaves the broken DIY BTUSB_RESET_RESUME code in place for Realtek
devices.
2) Sofar only 2 of the 10 QCA devices known to the btusb code have been
added to usb/core/quirks.c and if we fix the Realtek case the same way
we need to add an additional 14 entries. So in essence we need to
duplicate a large part of the usb_device_id table in btusb.c in
usb/core/quirks.c and manually keep them in sync.
This commit instead restores setting a reset-resume quirk for QCA devices
in the btusb.c code, avoiding the duplicate usb_device_id table problem.
This commit avoids the problems with the original DIY BTUSB_RESET_RESUME
code by simply setting the USB_QUIRK_RESET_RESUME quirk directly on the
usb_device.
This commit also moves the BTUSB_REALTEK case over to directly setting the
USB_QUIRK_RESET_RESUME on the usb_device and removes the now unused
BTUSB_RESET_RESUME code.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1514836
Fixes: 7d06d5895c15 ("Revert "Bluetooth: btusb: fix QCA...suspend/resume"")
Cc: Leif Liddy <leif.linux@gmail.com>
Cc: Matthias Kaehlcke <mka@chromium.org>
Cc: Brian Norris <briannorris@chromium.org>
Cc: Daniel Drake <drake@endlessm.com>
Cc: Kai-Heng Feng <kai.heng.feng@canonical.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 7d06d5895c159f64c46560dc258e553ad8670fe0 upstream.
This reverts commit fd865802c66bc451dc515ed89360f84376ce1a56.
This commit causes a regression on some QCA ROME chips. The USB device
reset happens in btusb_open(), hence firmware loading gets interrupted.
Furthermore, this commit stops working after commit
("a0085f2510e8976614ad8f766b209448b385492f Bluetooth: btusb: driver to
enable the usb-wakeup feature"). Reset-resume quirk only gets enabled in
btusb_suspend() when it's not a wakeup source.
If we really want to reset the USB device, we need to do it before
btusb_open(). Let's handle it in drivers/usb/core/quirks.c.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
Tested-by: Brian Norris <briannorris@chromium.org>
commit b4cdaba274247c9c841c6a682c08fa91fb3aa549 upstream.
BCM43341 devices soldered onto the PCB (non-removable) always (AFAICT)
use an UART connection for bluetooth. But they also advertise btsdio
support on their 3th sdio function, this causes 2 problems:
1) A non functioning BT HCI getting registered
2) Since the btsdio driver does not have suspend/resume callbacks,
mmc_sdio_pre_suspend will return -ENOSYS, causing mmc_pm_notify()
to react as if the SDIO-card is removed and since the slot is
marked as non-removable it will never get detected as inserted again.
Which results in wifi no longer working after a suspend/resume.
This commit fixes both by making btsdio ignore BCM43341 devices
when connected to a slot which is marked non-removable.
commit edfc3722cfef4217c7fe92b272cbe0288ba1ff57 upstream.
The Toshiba Click Mini uses an i2c attached keyboard/touchpad combo
(single i2c_hid device for both) which has a vid:pid of 04F3:0401,
which is also used by a bunch of Elan touchpads which are handled by the
drivers/input/mouse/elan_i2c driver, but that driver deals with pure
touchpads and does not work for a combo device such as the one on the
Toshiba Click Mini.
The combo on the Mini has an ACPI id of ELAN0800, which is not claimed
by the elan_i2c driver, so check for that and if it is found do not ignore
the device. This fixes the keyboard/touchpad combo on the Mini not working
(although with the touchpad in mouse emulation mode).
commit 4f7e988e63e336827f4150de48163bed05d653bd upstream.
This reverts commit 92266d6ef60c ("async: simplify lowest_in_progress()")
which was simply wrong: In the case where domain is NULL, we now use the
wrong offsetof() in the list_first_entry macro, so we don't actually
fetch the ->cookie value, but rather the eight bytes located
sizeof(struct list_head) further into the struct async_entry.
On 64 bit, that's the data member, while on 32 bit, that's a u64 built
from func and data in some order.
I think the bug happens to be harmless in practice: It obviously only
affects callers which pass a NULL domain, and AFAICT the only such
caller is
async_synchronize_full() ->
async_synchronize_full_domain(NULL) ->
async_synchronize_cookie_domain(ASYNC_COOKIE_MAX, NULL)
and the ASYNC_COOKIE_MAX means that in practice we end up waiting for
the async_global_pending list to be empty - but it would break if
somebody happened to pass (void*)-1 as the data element to
async_schedule, and of course also if somebody ever does a
async_synchronize_cookie_domain(, NULL) with a "finite" cookie value.
Maybe the "harmless in practice" means this isn't -stable material. But
I'm not completely confident my quick git grep'ing is enough, and there
might be affected code in one of the earlier kernels that has since been
removed, so I'll leave the decision to the stable guys.
Link: http://lkml.kernel.org/r/20171128104938.3921-1-linux@rasmusvillemoes.dk
Fixes: 92266d6ef60c "async: simplify lowest_in_progress()"
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Adam Wallis <awallis@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 9893b905e743ded332575ca04486bd586c0772f7 upstream.
The XC2028_I2C_FLUSH only needs to be implemented on a few
devices. Others can safely ignore it.
That prevents filling the dmesg with lots of messages like:
dib0700: stk7700ph_xc3028_callback: unknown command 2, arg 0
Fixes: 4d37ece757a8 ("[media] tuner/xc2028: Add I2C flush callback")
Reported-by: Enrico Mioso <mrkiko.rs@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 81742be14b6a90c9fd0ff6eb4218bdf696ad8e46 upstream.
Before this patch, when compiled for arm32, the signal strength
were reported as:
Lock (0x1f) Signal= 4294908.66dBm C/N= 12.79dB
Because of a 32 bit integer overflow. After it, it is properly
reported as:
Lock (0x1f) Signal= -58.64dBm C/N= 12.79dB
Fixes: 0f91c9d6bab9 ("[media] TS2020: Calculate tuner gain correctly")
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 0be267255cef64e1c58475baa7b25568355a3816 upstream.
When the watchdog device is suspended, its timeout is set to the maximum
value. During resume, the previously set timeout should be restored.
This does not work at the moment.
The suspend function calls
imx2_wdt_set_timeout(wdog, IMX2_WDT_MAX_TIME);
and resume reverts this by calling
imx2_wdt_set_timeout(wdog, wdog->timeout);
However, imx2_wdt_set_timeout() updates wdog->timeout. Therefore,
wdog->timeout is set to IMX2_WDT_MAX_TIME when we enter the resume
function.
Fix this by adding a new function __imx2_wdt_set_timeout() which
only updates the hardware settings. imx2_wdt_set_timeout() now calls
__imx2_wdt_set_timeout() and then saves the new timeout to
wdog->timeout.
During suspend, we call __imx2_wdt_set_timeout() directly so that
wdog->timeout won't be updated and we can restore the previous value
during resume. This approach makes wdog->timeout different from the
actual setting in the hardware which is usually not a good thing.
However, the two differ only while we're suspended and no kernel code is
running, so it should be ok in this case.
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 6b6977117f50d60455ace86b2d256f6fb4f3de05 upstream.
Consider the following scenario:
1. CPU A calls vmx_deliver_nested_posted_interrupt() to send an IPI
to CPU B via virtual posted-interrupt mechanism.
2. CPU B is currently executing L2 guest.
3. vmx_deliver_nested_posted_interrupt() calls
kvm_vcpu_trigger_posted_interrupt() which will note that
vcpu->mode == IN_GUEST_MODE.
4. Assume that before CPU A sends the physical POSTED_INTR_NESTED_VECTOR
IPI, CPU B exits from L2 to L0 during event-delivery
(valid IDT-vectoring-info).
5. CPU A now sends the physical IPI. The IPI is received in host and
it's handler (smp_kvm_posted_intr_nested_ipi()) does nothing.
6. Assume that before CPU A sets pi_pending=true and KVM_REQ_EVENT,
CPU B continues to run in L0 and reach vcpu_enter_guest(). As
KVM_REQ_EVENT is not set yet, vcpu_enter_guest() will continue and resume
L2 guest.
7. At this point, CPU A sets pi_pending=true and KVM_REQ_EVENT but
it's too late! CPU B already entered L2 and KVM_REQ_EVENT will only be
consumed at next L2 entry!
Another scenario to consider:
2. Assume that before CPU A calls kvm_vcpu_trigger_posted_interrupt(),
CPU B is at L0 and is about to resume into L2. Further assume that it is
in vcpu_enter_guest() after check for KVM_REQ_EVENT.
3. At this point, CPU A calls kvm_vcpu_trigger_posted_interrupt() which
will note that vcpu->mode != IN_GUEST_MODE. Therefore, do nothing and
return false. Then, will set pi_pending=true and KVM_REQ_EVENT.
4. Now CPU B continue and resumes into L2 guest without processing
the posted-interrupt until next L2 entry!
To fix both issues, we just need to change
vmx_deliver_nested_posted_interrupt() to set pi_pending=true and
KVM_REQ_EVENT before calling kvm_vcpu_trigger_posted_interrupt().
It will fix the first scenario by chaging step (6) to note that
KVM_REQ_EVENT and pi_pending=true and therefore process
nested posted-interrupt.
It will fix the second scenario by two possible ways:
1. If kvm_vcpu_trigger_posted_interrupt() is called while CPU B has changed
vcpu->mode to IN_GUEST_MODE, physical IPI will be sent and will be received
when CPU resumes into L2.
2. If kvm_vcpu_trigger_posted_interrupt() is called while CPU B hasn't yet
changed vcpu->mode to IN_GUEST_MODE, then after CPU B will change
vcpu->mode it will call kvm_request_pending() which will return true and
therefore force another round of vcpu_enter_guest() which will note that
KVM_REQ_EVENT and pi_pending=true and therefore process nested
posted-interrupt.
Fixes: 705699a13994 ("KVM: nVMX: Enable nested posted interrupt processing")
Signed-off-by: Liran Alon <liran.alon@oracle.com>
Reviewed-by: Nikita Leshenko <nikita.leshchenko@oracle.com>
Reviewed-by: Krish Sadhukhan <krish.sadhukhan@oracle.com>
[Add kvm_vcpu_kick to also handle the case where L1 doesn't intercept L2 HLT
and L2 executes HLT instruction. - Paolo]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 20e8175d246e9f9deb377f2784b3e7dfb2ad3e86 upstream.
KVM doesn't follow the SMCCC when it comes to unimplemented calls,
and inject an UNDEF instead of returning an error. Since firmware
calls are now used for security mitigation, they are becoming more
common, and the undef is counter productive.
Instead, let's follow the SMCCC which states that -1 must be returned
to the caller when getting an unknown function number.
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 225ece3e7dad4cfc44cca38ce7a3a80f255ea8f1 upstream.
In case DECO0 cannot be acquired - i.e. run_descriptor_deco0() fails
with -ENODEV, caam_probe() enters an endless loop:
ret -ENODEV
-> instantiate_rng
-ENODEV, overwritten by -EAGAIN
ret -EAGAIN
-> caam_probe
-EAGAIN results in endless loop
It turns out the error path in instantiate_rng() is incorrect,
the checks are done in the wrong order.
Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles")
Reported-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Suggested-by: Auer Lukas <lukas.auer@aisec.fraunhofer.de>
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit a1dfb4c48cc1e64eeb7800a27c66a6f7e88d075a upstream.
The 32-bit compat v4l2 ioctl handling is implemented based on its 64-bit
equivalent. It converts 32-bit data structures into its 64-bit
equivalents and needs to provide the data to the 64-bit ioctl in user
space memory which is commonly allocated using
compat_alloc_user_space().
However, due to how that function is implemented, it can only be called
a single time for every syscall invocation.
Supposedly to avoid this limitation, the existing code uses a mix of
memory from the kernel stack and memory allocated through
Under normal circumstances, this would not work, because the 64-bit
ioctl expects all pointers to point to user space memory. As a
workaround, set_fs(KERNEL_DS) is called to temporarily disable this
extra safety check and allow kernel pointers. However, this might
introduce a security vulnerability: The result of the 32-bit to 64-bit
conversion is writeable by user space because the output buffer has been
allocated via compat_alloc_user_space(). A malicious user space process
could then manipulate pointers inside this output buffer, and due to the
previous set_fs(KERNEL_DS) call, functions like get_user() or put_user()
no longer prevent kernel memory access.
The new approach is to pre-calculate the total amount of user space
memory that is needed, allocate it using compat_alloc_user_space() and
then divide up the allocated memory to accommodate all data structures
that need to be converted.
An alternative approach would have been to retain the union type karg
that they allocated on the kernel stack in do_video_ioctl(), copy all
data from user space into karg and then back to user space. However, we
decided against this approach because it does not align with other
compat syscall implementations. Instead, we tried to replicate the
get_user/put_user pairs as found in other places in the kernel:
if (get_user(clipcount, &up->clipcount) ||
put_user(clipcount, &kp->clipcount)) return -EFAULT;
Notes from hans.verkuil@cisco.com:
This patch was taken from:
https://github.com/LineageOS/android_kernel_samsung_apq8084/commit/97b733953c06e4f0398ade18850f0817778255f7
Clearly nobody could be bothered to upstream this patch or at minimum
tell us :-( We only heard about this a week ago.
This patch was rebased and cleaned up. Compared to the original I
also swapped the order of the convert_in_user arguments so that they
matched copy_in_user. It was hard to review otherwise. I also replaced
the ALLOC_USER_SPACE/ALLOC_AND_GET by a normal function.
Fixes: 6b5a9492ca ("v4l: introduce string control support.")
Signed-off-by: Daniel Mentz <danielmentz@google.com>
Co-developed-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit d83a8243aaefe62ace433e4384a4f077bed86acb upstream.
Some ioctls need to copy back the result even if the ioctl returned
an error. However, don't do this for the error code -ENOTTY.
It makes no sense in that cases.
commit 169f24ca68bf0f247d111aef07af00dd3a02ae88 upstream.
There is nothing wrong with using an unknown buffer type. So
stop spamming the kernel log whenever this happens. The kernel
will just return -EINVAL to signal this.
commit a751be5b142ef6bcbbb96d9899516f4d9c8d0ef4 upstream.
put_v4l2_window32() didn't copy back the clip list to userspace.
Drivers can update the clip rectangles, so this should be done.
commit 025a26fa14f8fd55d50ab284a30c016a5be953d0 upstream.
Commit b2787845fb91 ("V4L/DVB (5289): Add support for video output
overlays.") added the field global_alpha to struct v4l2_window but did
not update the compat layer accordingly. This change adds global_alpha
to struct v4l2_window32 and copies the value for global_alpha back and
forth.
commit 273caa260035c03d89ad63d72d8cd3d9e5c5e3f1 upstream.
If the device is of type VFL_TYPE_SUBDEV then vdev->ioctl_ops
is NULL so the 'if (!ops->vidioc_query_ext_ctrl)' check would crash.
Add a test for !ops to the condition.
All sub-devices that have controls will use the control framework,
so they do not have an equivalent to ops->vidioc_query_ext_ctrl.
Returning false if ops is NULL is the correct thing to do here.
Fixes: b8c601e8af ("v4l2-compat-ioctl32.c: fix ctrl_is_pointer")
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit b8c601e8af2d08f733d74defa8465303391bb930 upstream.
ctrl_is_pointer just hardcoded two known string controls, but that
caused problems when using e.g. custom controls that use a pointer
for the payload.
Reimplement this function: it now finds the v4l2_ctrl (if the driver
uses the control framework) or it calls vidioc_query_ext_ctrl (if the
driver implements that directly).
In both cases it can now check if the control is a pointer control
or not.
commit 8ed5a59dcb47a6f76034ee760b36e089f3e82529 upstream.
The struct v4l2_plane32 should set m.userptr as well. The same
happens in v4l2_buffer32 and v4l2-compliance tests for this.
commit 333b1e9f96ce05f7498b581509bb30cde03018bf upstream.
Instead of doing sizeof(struct foo) use sizeof(*up). There even were
cases where 4 * sizeof(__u32) was used instead of sizeof(kp->reserved),
which is very dangerous when the size of the reserved array changes.
commit 486c521510c44a04cd756a9267e7d1e271c8a4ba upstream.
These helper functions do not really help. Move the code to the
__get/put_v4l2_format32 functions.
commit b7b957d429f601d6d1942122b339474f31191d75 upstream.
The indentation of this source is all over the place. Fix this.
This patch only changes whitespace.
commit 3ee6d040719ae09110e5cdf24d5386abe5d1b776 upstream.
The result of the VIDIOC_PREPARE_BUF ioctl was never copied back
to userspace since it was missing in the switch.
commit 3171cc2b4eb9831ab4df1d80d0410a945b8bc84e upstream.
According to the doc, V4L2_BUF_FLAG_DONE is cleared after DQBUF:
V4L2_BUF_FLAG_DONE 0x00000004 ... After calling the VIDIOC_QBUF or
VIDIOC_DQBUF it is always cleared ...
Unfortunately, it seems that videobuf2 keeps it set after DQBUF. This
can be tested with vivid and dev_debug:
[257604.338082] video1: VIDIOC_DQBUF: 71:33:25.00260479 index=3,
type=vid-cap, flags=0x00002004, field=none, sequence=163,
memory=userptr, bytesused=460800, offset/userptr=0x344b000,
length=460800
This patch forces FLAG_DONE to 0 after calling DQBUF.
Reported-by: Dimitrios Katsaros <patcherwork@gmail.com>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
commit 181a4a2d5a0a7b43cab08a70710d727e7764ccdd upstream.
If the ioctl returned -ENOTTY, then don't bother copying
back the result as there is no point.
commit 073c516ff73557a8f7315066856c04b50383ac34 upstream.
Andrey reported a use-after-free in __ns_get_path():
spin_lock include/linux/spinlock.h:299 [inline]
lockref_get_not_dead+0x19/0x80 lib/lockref.c:179
__ns_get_path+0x197/0x860 fs/nsfs.c:66
open_related_ns+0xda/0x200 fs/nsfs.c:143
sock_ioctl+0x39d/0x440 net/socket.c:1001
vfs_ioctl fs/ioctl.c:45 [inline]
do_vfs_ioctl+0x1bf/0x1780 fs/ioctl.c:685
SYSC_ioctl fs/ioctl.c:700 [inline]
SyS_ioctl+0x8f/0xc0 fs/ioctl.c:691
We are under rcu read lock protection at that point:
rcu_read_lock();
d = atomic_long_read(&ns->stashed);
if (!d)
goto slow;
dentry = (struct dentry *)d;
if (!lockref_get_not_dead(&dentry->d_lockref))
goto slow;
rcu_read_unlock();
but don't use a proper RCU API on the free path, therefore a parallel
__d_free() could free it at the same time. We need to mark the stashed
dentry with DCACHE_RCUACCESS so that __d_free() will be called after all
readers leave RCU.
Fixes: e149ed2b805f ("take the targets of /proc/*/ns/* symlinks to separate fs")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Eric Biggers <ebiggers3@gmail.com>
commit a16e772e664b9a261424107784804cffc8894977 upstream.
Since Poly1305 requires a nonce per invocation, the Linux kernel
implementations of Poly1305 don't use the crypto API's keying mechanism
and instead expect the key and nonce as the first 32 bytes of the data.
But ->setkey() is still defined as a stub returning an error code. This
prevents Poly1305 from being used through AF_ALG and will also break it
completely once we start enforcing that all crypto API users (not just
AF_ALG) call ->setkey() if present.
Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL.
commit 841a3ff329713f796a63356fef6e2f72e4a3f6a3 upstream.
When the cryptd template is used to wrap an unkeyed hash algorithm,
don't install a ->setkey() method to the cryptd instance. This change
is necessary for cryptd to keep working with unkeyed hash algorithms
once we start enforcing that ->setkey() is called when present.
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream.
Templates that use an shash spawn can use crypto_shash_alg_has_setkey()
to determine whether the underlying algorithm requires a key or not.
But there was no corresponding function for ahash spawns. Add it.
Note that the new function actually has to support both shash and ahash
algorithms, since the ahash API can be used with either.
commit f919dde0772a894c693a1eeabc77df69d6a9b937 upstream.
Add Intel Cannon Lake PCH-H PCI ID to the list of supported controllers.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit 998008b779e424bd7513c434d0ab9c1268459009 upstream.
Add PCI ids for Intel Bay Trail, Cherry Trail and Apollo Lake AHCI
SATA controllers. This commit is a preparation patch for allowing a
different default sata link powermanagement policy for mobile chipsets.
commit ca1b4974bd237f2373b0e980b11957aac3499b56 upstream.
Intel uses different SATA PCI ids for the Desktop and Mobile SKUs of their
chipsets. For older models the comment describing which chipset the PCI id
is for, aksi indicates when we're dealing with a mobile SKU. Extend the
comments for recent chipsets to also indicate mobile SKUs.
The information this commit adds comes from Intel's chipset datasheets.
This commit is a preparation patch for allowing a different default
commit ba87977a49913129962af8ac35b0e13e0fa4382d upstream.
Commit b7ce40cff0b9 ("kernfs: cache atomic_write_len in
kernfs_open_file") changes type of local variable 'len' from ssize_t
to size_t. This change caused that the *ppos value is updated also
when the previous write callback failed.
Mentioned snippet:
len = ops->write(...); <- return value can be negative
if (len > 0) <- true here in this case
*ppos += len;
Fixes: b7ce40cff0b9 ("kernfs: cache atomic_write_len in kernfs_open_file")
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
commit 49686cbbb3ebafe42e63868222f269d8053ead00 upstream.
nfs_idmap_legacy_upcall() is supposed to be called with 'aux' pointing
to a 'struct idmap', via the call to request_key_with_auxdata() in
nfs_idmap_request_key().
However it can also be reached via the request_key() system call in
which case 'aux' will be NULL, causing a NULL pointer dereference in
nfs_idmap_prepare_pipe_upcall(), assuming that the key description is
valid enough to get that far.
Fix this by making nfs_idmap_legacy_upcall() negate the key if no
auxdata is provided.
As usual, this bug was found by syzkaller. A simple reproducer using
the command-line keyctl program is:
keyctl request2 id_legacy uid:0 '' @s
Fixes: 57e62324e469 ("NFS: Store the legacy idmapper result in the keyring")
Reported-by: syzbot+5dfdbcf7b3eb5912abbb@syzkaller.appspotmail.com
Signed-off-by: Trond Myklebust <trondmy@gmail.com>
commit 1b8d97b0a837beaf48a8449955b52c650a7114b4 upstream.
If some of the WRITE calls making up an O_DIRECT write syscall fail,
we neglect to commit, even if some of the WRITEs succeed.
We also depend on the commit code to free the reference count on the
nfs_page taken in the "if (request_commit)" case at the end of
nfs_direct_write_completion(). The problem was originally noticed
because ENOSPC's encountered partway through a write would result in a
closed file being sillyrenamed when it should have been unlinked.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 7f1bda447c9bd48b415acedba6b830f61591601f upstream.
The commit list can get very large, and so we need a cond_resched()
in nfs_commit_release_pages() in order to ensure we don't hog the CPU
for excessive periods of time.
Reported-by: Mike Galbraith <efault@gmx.de>
