[ Upstream commit e0165f20447c8ca1d367725ee94d8ec9f38ca275 ]
Clear the VendorVersion in the PLOGI/PLOGI ACC payload
Vendor version info may have been set on fabric login. Before sending
PLOGI payloads, ensure that it's cleared.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <james.smart@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
[ Upstream commit e6c6acc0e0223ddaf867628d420ee196349c6fae ]
Correct issue leading to oops during link reset. Missing vport pointer.
[mkp: fixed typo]
[ Upstream commit 6c9231f604c2575be24c96d38deb70f145172f92 ]
Correct host name in symbolic_name field of nameserver registrations
[ Upstream commit 104450eb08ca662e6b1d02da11aca9598e978f3e ]
FCoE VPort enable-disable does not bring up the VPort.
VPI structure needed to be initialized before being re-registered.
[ Upstream commit 6b3b3bdb83b4ad51252d21bb13596db879e51850 ]
On loosely ordered memory systems (PPC for example), the WQE elements
were being updated in memory, but not necessarily flushed before the
separate doorbell was written to hw which would cause hw to dma the
WQE element. Thus, the hardware occasionally received partially
updated WQE data.
Add the memory barrier after updating the WQE memory.
[ Upstream commit 401579c22ccbcb54244494069973e64b1fe980d2 ]
Several lifecycle events in the rtl8188eu driver are logged using the
DBG_88E_LEVEL macro from rtw_debug.h, which is tagged as ERROR
regardless of the actual level. Below are dmesg excerpts after loading
and unloading the module, the messages are misleading as there was no
error.
[517434.916239] usbcore: registered new interface driver r8188eu
[517435.680653] R8188EU: ERROR indicate disassoc
[517437.122606] R8188EU: ERROR assoc success
[517797.735611] usbcore: deregistering interface driver r8188eu
[517797.736069] R8188EU: ERROR indicate disassoc
Remove the ERROR prefix from the logs. After the patch, logs are:
[517949.873976] usbcore: registered new interface driver r8188eu
[517950.592845] R8188EU: indicate disassoc
[517951.993973] R8188EU: assoc success
[521778.784448] usbcore: deregistering interface driver r8188eu
[521778.784838] R8188EU: indicate disassoc
Signed-off-by: Galo Navarro <anglorvaroa@gmail.com>
[ Upstream commit 4e768e7645ec4ffa92ee163643777b261ae97142 ]
UFS device requires to perform bkops (back ground operations) periodically
but host can control (via auto-bkops parameter of device) when device can
perform bkops based on its performance requirements. In general, host
would like to enable the device's auto-bkops only when it's not doing any
regular data transfer but sometimes device may not behave properly if host
keeps the auto-bkops disabled. This change adds the capability to let the
device auto-bkops always enabled except suspend.
Reviewed-by: Sahitya Tummala <stummala@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
[ Upstream commit ab3dabb3e8cf077850f20610f73a0def1fed10cb ]
If the driver is built as a module, autoload won't work because the module
alias information is not filled. So user-space can't match the registered
device with the corresponding module.
Export the module alias information using the MODULE_DEVICE_TABLE() macro.
Before this patch:
$ modinfo drivers/scsi/ufs/ufs-qcom.ko | grep alias
After this patch:
alias: of:N*T*Cqcom,ufshcC*
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
[ Upstream commit 76ed5a8f47476e4984cc8c0c1bc4cee62650f7fd ]
Fix an if statement with hw_dbg lines where the logic was inverted with
regards to the corresponding return value used in the if statement.
Signed-off-by: Hannu Lounento <hannu.lounento@ge.com>
Signed-off-by: Peter Senna Tschudin <peter.senna@collabora.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
[ Upstream commit 9474933caf21a4cb5147223dca1551f527aaac36 ]
Similar to ixgbe, when an interface is part of a namespace it is
possible that igb_close() may be called while __igb_shutdown() is
running which ends up in a double free WARN and/or a BUG in
free_msi_irqs().
Extend the rtnl_lock() to protect the call to netif_device_detach() and
igb_clear_interrupt_scheme() in __igb_shutdown() and check for
netif_device_present() to avoid calling igb_clear_interrupt_scheme() a
second time in igb_close().
Also extend the rtnl lock in igb_resume() to netif_device_attach().
Signed-off-by: Todd Fujinaka <todd.fujinaka@intel.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 182785335447957409282ca745aa5bc3968facee ]
Several people have reported firmware leaving the I210/I211 PHY's page
select register set to something other than the default of zero. This
causes the first accesses, PHY_IDx register reads, to access something
else, resulting in device probe failure:
igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
igb: Copyright (c) 2007-2014 Intel Corporation.
igb: probe of 0000:01:00.0 failed with error -2
This problem began for them after a previous patch I submitted was
applied:
commit 2a3cdead8b408351fa1e3079b220fa331480ffbc
Author: Aaron Sierra <asierra@xes-inc.com>
Date: Tue Nov 3 12:37:09 2015 -0600
igb: Remove GS40G specific defines/functions
I personally experienced this problem after attempting to PXE boot from
I210 devices using this firmware:
Intel(R) Boot Agent GE v1.5.78
Copyright (C) 1997-2014, Intel Corporation
Resetting the PHY before reading from it, ensures the page select
register is in its default state and doesn't make assumptions about
the PHY's register set before the PHY has been probed.
Cc: Matwey V. Kornilov <matwey@sai.msu.ru>
Cc: Chris Arges <carges@vectranetworks.com>
Cc: Jochen Henneberg <jh@henneberg-systemdesign.com>
Signed-off-by: Aaron Sierra <asierra@xes-inc.com>
Tested-by: Matwey V. Kornilov <matwey@sai.msu.ru>
Tested-by: Chris J Arges <christopherarges@gmail.com>
[ Upstream commit 1ae0d5af347df224a6e76334683f13a96d915a44 ]
Here, If devm_ioremap_nocache will fail. It will return NULL.
Kernel can run into a NULL-pointer dereference. This error check
will avoid NULL pointer dereference.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Acked-by: Vincent Abriou <vincent.abriou@st.com>
[ Upstream commit 62989cebd367a1aae1e009e1a5b1ec046a4c8fdc ]
If NO_DMA=y:
ERROR: "dma_pool_alloc" [drivers/ata/sata_mv.ko] undefined!
ERROR: "dmam_pool_create" [drivers/ata/sata_mv.ko] undefined!
ERROR: "dma_pool_free" [drivers/ata/sata_mv.ko] undefined!
Add a dependency on HAS_DMA to fix this.
[ Upstream commit 2a736e0585e585c2566b5119af8381910a170e44 ]
If NO_DMA=y:
ERROR: "bad_dma_ops" [drivers/ata/sata_highbank.ko] undefined!
[ Upstream commit 7bc7ab1e63dfe004931502f90ce7020e375623da ]
If NO_DMA=y:
ERROR: "dmam_alloc_coherent" [drivers/ata/libata.ko] undefined!
[ Upstream commit d97556c8012015901a3ce77f46960078139cd79d ]
We need to also have OFFPULLUDENABLE bit set to use the off mode pull values.
Otherwise the line is pulled down internally if no external pull exists.
This is has some documentation at:
http://processors.wiki.ti.com/index.php/Optimizing_OMAP35x_and_AM/DM37x_OFF_mode_PAD_configuration
Note that the value is still glitchy during off mode transitions as documented
in spz319f.pdf "Advisory 1.45". It's best to use external pulls instead of
relying on the internal ones for off mode and even then anything pulled up
will get driven down momentarily on off mode restore for GPIO banks other
than bank1.
[ Upstream commit 6e613ebf4405fc09e2a8c16ed193b47f80a3cbed ]
It's possible that there are multiple quirks that need to be initialized
for the same SoC. Fix the issue by not returning on the first match.
[ Upstream commit 1aa09df0854efe16b7a80358a18f0a0bebafd246 ]
Without these changes children of the scn syscon
won't probe.
[ Upstream commit f62280efe8934a1275fd148ef302d1afec8cd3df ]
When using 8250_omap driver, we need to specify the right
compatible value for the UART to work on dm814x and dm816x.
[ Upstream commit 2f3fc1e6200309ccf87f61dea56e57e563c4f800 ]
Multiple IES API resets can cause a race condition where the mailbox
interrupt request bits can be cleared before being handled. This can
leave certain mailbox messages from the PF to be untreated and the PF
will enter in some inactive state. If this situation occurs, the IES API
will initiate a mailbox version reset which, then, trigger a mailbox
state change. Once this mailbox transition occurs (from OPEN to CONNECT
state), a request for reset will be returned.
This ensures that PF will undergo a reset whenever IES API encounters an
unknown global mailbox interrupt event or whenever the IES API
terminates.
Signed-off-by: Ngai-Mint Kwan <ngai-mint.kwan@intel.com>
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Krishneil Singh <krishneil.k.singh@intel.com>
[ Upstream commit 9fe172b9be532acc23e35ba693700383ab775e66 ]
extcon-palmas must be child of palmas and expects parent's
drvdata to be valid. Check for non NULL parent drvdata and
fail if it is NULL. Not doing so will result in a NULL
pointer dereference later in the probe() parent drvdata
is NULL (e.g. misplaced extcon-palmas node in device tree).
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
commit a9df21e34b422f79d9a9fa5c3eff8c2a53491be6 upstream.
Commit adfa543e7314 ("dmatest: don't use set_freezable_with_signal()")
introduced a bug (that is in fact documented by the patch commit text)
that leaves behind a dangling pointer. Since the done_wait structure is
allocated on the stack, future invocations to the DMATEST can produce
undesirable results (e.g., corrupted spinlocks). Ideally, this would be
cleaned up in the thread handler, but at the very least, the kernel
is left in a very precarious scenario that can lead to some long debug
sessions when the crash comes later.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=197605
Signed-off-by: Adam Wallis <awallis@codeaurora.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit fd865802c66bc451dc515ed89360f84376ce1a56 upstream.
There's been numerous reported instances where BTUSB_QCA_ROME
bluetooth controllers stop functioning upon resume from suspend. These
devices seem to be losing power during suspend. Patch will detect a status
change on resume and perform a reset.
Signed-off-by: Leif Liddy <leif.linux@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Kai Heng Feng <kai.heng.feng@canonical.com>
[ Not upstream because this is a minimal fix for a bug where arm32
kernels can use a much slower implementation of AES than is actually
available, potentially forcing vendors to disable encryption on their
devices.]
All the aes-bs (bit-sliced) and aes-ce (cryptographic extensions)
algorithms had a priority of 300. This is undesirable because it means
an aes-bs algorithm may be used when an aes-ce algorithm is available.
The aes-ce algorithms have much better performance (up to 10x faster).
Fix it by decreasing the priority of the aes-bs algorithms to 250.
This was fixed upstream by commit cc477bf64573 ("crypto: arm/aes -
replace bit-sliced OpenSSL NEON code"), but it was just a small part of
a complete rewrite. This patch just fixes the priority bug for older
kernels.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 7fd078337201cf7468f53c3d9ef81ff78cb6df3b upstream.
A CDC Ethernet functional descriptor with wMaxSegmentSize = 0 will
cause a divide error in usbnet_probe:
divide error: 0000 [#1] PREEMPT SMP KASAN
Modules linked in:
CPU: 0 PID: 24 Comm: kworker/0:1 Not tainted 4.14.0-rc8-44453-g1fdc1a82c34f #56
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: usb_hub_wq hub_event
task: ffff88006bef5c00 task.stack: ffff88006bf60000
RIP: 0010:usbnet_update_max_qlen+0x24d/0x390 drivers/net/usb/usbnet.c:355
RSP: 0018:ffff88006bf67508 EFLAGS: 00010246
RAX: 00000000000163c8 RBX: ffff8800621fce40 RCX: ffff8800621fcf34
RDX: 0000000000000000 RSI: ffffffff837ecb7a RDI: ffff8800621fcf34
RBP: ffff88006bf67520 R08: ffff88006bef5c00 R09: ffffed000c43f881
R10: ffffed000c43f880 R11: ffff8800621fc406 R12: 0000000000000003
R13: ffffffff85c71de0 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88006ca00000(0000) knlGS:0000000000000000
CR2: 00007ffe9c0d6dac CR3: 00000000614f4000 CR4: 00000000000006f0
Call Trace:
usbnet_probe+0x18b5/0x2790 drivers/net/usb/usbnet.c:1783
qmi_wwan_probe+0x133/0x220 drivers/net/usb/qmi_wwan.c:1338
usb_probe_interface+0x324/0x940 drivers/usb/core/driver.c:361
really_probe drivers/base/dd.c:413
driver_probe_device+0x522/0x740 drivers/base/dd.c:557
Fix by simply ignoring the bogus descriptor, as it is optional
for QMI devices anyway.
Fixes: 423ce8caab7e ("net: usb: qmi_wwan: New driver for Huawei QMI based WWAN devices")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2cb80187ba065d7decad7c6614e35e07aec8a974 upstream.
Setting dev->hard_mtu to 0 will cause a divide error in
usbnet_probe. Protect against devices with bogus CDC Ethernet
functional descriptors by ignoring a zero wMaxSegmentSize.
Acked-by: Oliver Neukum <oneukum@suse.com>
commit df80cd9b28b9ebaa284a41df611dbf3a2d05ca74 upstream.
Now when peeling off an association to the sock in another netns, all
transports in this assoc are not to be rehashed and keep use the old
key in hashtable.
As a transport uses sk->net as the hash key to insert into hashtable,
it would miss removing these transports from hashtable due to the new
netns when closing the sock and all transports are being freeed, then
later an use-after-free issue could be caused when looking up an asoc
and dereferencing those transports.
This is a very old issue since very beginning, ChunYu found it with
syzkaller fuzz testing with this series:
socket$inet6_sctp()
bind$inet6()
sendto$inet6()
unshare(0x40000000)
getsockopt$inet_sctp6_SCTP_GET_ASSOC_ID_LIST()
getsockopt$inet_sctp6_SCTP_SOCKOPT_PEELOFF()
This patch is to block this call when peeling one assoc off from one
netns to another one, so that the netns of all transport would not
go out-sync with the key in hashtable.
Note that this patch didn't fix it by rehashing transports, as it's
difficult to handle the situation when the tuple is already in use
in the new netns. Besides, no one would like to peel off one assoc
to another netns, considering ipaddrs, ifaces, etc. are usually
different.
Reported-by: ChunYu Wang <chunwang@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
commit 089bc0143f489bd3a4578bdff5f4ca68fb26f341 upstream.
Rather than constructing a local structure instance on the stack, fill
the fields directly on the shared ring, just like other backends do.
Build on the fact that all response structure flavors are actually
identical (the old code did make this assumption too).
This is XSA-216.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[bwh: Backported to 4.4: adjust context]
commit 0d0e57697f162da4aa218b5feafe614fb666db07 upstream.
The patch fixes two things at once:
1) It checks the env->allow_ptr_leaks and only prints the map address to
the log if we have the privileges to do so, otherwise it just dumps 0
as we would when kptr_restrict is enabled on %pK. Given the latter is
off by default and not every distro sets it, I don't want to rely on
this, hence the 0 by default for unprivileged.
2) Printing of ldimm64 in the verifier log is currently broken in that
we don't print the full immediate, but only the 32 bit part of the
first insn part for ldimm64. Thus, fix this up as well; it's okay to
access, since we verified all ldimm64 earlier already (including just
constants) through replace_map_fd_with_map_ptr().
Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs")
Fixes: cbd357008604 ("bpf: verifier (add ability to receive verification log)")
Reported-by: Jann Horn <jannh@google.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[bwh: Backported to 4.4: s/bpf_verifier_env/verifier_env/]
commit c8401dda2f0a00cd25c0af6a95ed50e478d25de4 upstream.
TF is handled a bit differently for syscall and sysret, compared
to the other instructions: TF is checked after the instruction completes,
so that the OS can disable #DB at a syscall by adding TF to FMASK.
When the sysret is executed the #DB is taken "as if" the syscall insn
just completed.
KVM emulates syscall so that it can trap 32-bit syscall on Intel processors.
Fix the behavior, otherwise you could get #DB on a user stack which is not
nice. This does not affect Linux guests, as they use an IST or task gate
for #DB.
This fixes CVE-2017-7518.
Reported-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
- kvm_vcpu_check_singlestep() sets some flags differently
- Drop changes to kvm_skip_emulated_instruction()]
commit 06bd3c36a733ac27962fea7d6f47168841376824 upstream.
Huang has reported that in his powerfail testing he is seeing stale
block contents in some of recently allocated blocks although he mounts
ext4 in data=ordered mode. After some investigation I have found out
that indeed when delayed allocation is used, we don't add inode to
transaction's list of inodes needing flushing before commit. Originally
we were doing that but commit f3b59291a69d removed the logic with a
flawed argument that it is not needed.
The problem is that although for delayed allocated blocks we write their
contents immediately after allocating them, there is no guarantee that
the IO scheduler or device doesn't reorder things and thus transaction
allocating blocks and attaching them to inode can reach stable storage
before actual block contents. Actually whenever we attach freshly
allocated blocks to inode using a written extent, we should add inode to
transaction's ordered inode list to make sure we properly wait for block
contents to be written before committing the transaction. So that is
what we do in this patch. This also handles other cases where stale data
exposure was possible - like filling hole via mmap in
data=ordered,nodelalloc mode.
The only exception to the above rule are extending direct IO writes where
blkdev_direct_IO() waits for IO to complete before increasing i_size and
thus stale data exposure is not possible. For now we don't complicate
the code with optimizing this special case since the overhead is pretty
low. In case this is observed to be a performance problem we can always
handle it using a special flag to ext4_map_blocks().
Fixes: f3b59291a69d0b734be1fc8be489fef2dd846d3d
Reported-by: "HUANG Weller (CM/ESW12-CN)" <Weller.Huang@cn.bosch.com>
Tested-by: "HUANG Weller (CM/ESW12-CN)" <Weller.Huang@cn.bosch.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
- Drop check for EXT4_GET_BLOCKS_ZERO flag
- Adjust context]
commit eb0c19942288569e0ae492476534d5a485fb8ab4 upstream.
dvb_detach(arg) calls symbol_put_addr(arg), where arg should be a pointer
to a function. Right now a pointer to state->dib7000p_ops is passed to
dvb_detach(), which causes a BUG() in symbol_put_addr() as discovered by
syzkaller. Pass state->dib7000p_ops.set_wbd_ref instead.
kernel BUG at kernel/module.c:1081!
invalid opcode: 0000 [#1] PREEMPT SMP KASAN
Modules linked in:
CPU: 1 PID: 1151 Comm: kworker/1:1 Tainted: G W
4.14.0-rc1-42251-gebb2c2437d80 #224
task: ffff88006a336300 task.stack: ffff88006a7c8000
RIP: 0010:symbol_put_addr+0x54/0x60 kernel/module.c:1083
RSP: 0018:ffff88006a7ce210 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880062a8d190 RCX: 0000000000000000
RDX: dffffc0000000020 RSI: ffffffff85876d60 RDI: ffff880062a8d190
RBP: ffff88006a7ce218 R08: 1ffff1000d4f9c12 R09: 1ffff1000d4f9ae4
R10: 1ffff1000d4f9bed R11: 0000000000000000 R12: ffff880062a8d180
R13: 00000000ffffffed R14: ffff880062a8d190 R15: ffff88006947c000
FS: 0000000000000000(0000) GS:ffff88006c900000(0000) knlGS:0000000000000000
CR2: 00007f6416532000 CR3: 00000000632f5000 CR4: 00000000000006e0
Call Trace:
stk7070p_frontend_attach+0x515/0x610
drivers/media/usb/dvb-usb/dib0700_devices.c:1013
dvb_usb_adapter_frontend_init+0x32b/0x660
drivers/media/usb/dvb-usb/dvb-usb-dvb.c:286
dvb_usb_adapter_init drivers/media/usb/dvb-usb/dvb-usb-init.c:86
dvb_usb_init drivers/media/usb/dvb-usb/dvb-usb-init.c:162
dvb_usb_device_init+0xf70/0x17f0 drivers/media/usb/dvb-usb/dvb-usb-init.c:277
dib0700_probe+0x171/0x5a0 drivers/media/usb/dvb-usb/dib0700_core.c:886
usb_probe_interface+0x35d/0x8e0 drivers/usb/core/driver.c:361
driver_probe_device+0x610/0xa00 drivers/base/dd.c:557
__device_attach_driver+0x230/0x290 drivers/base/dd.c:653
bus_for_each_drv+0x161/0x210 drivers/base/bus.c:463
__device_attach+0x26e/0x3d0 drivers/base/dd.c:710
device_initial_probe+0x1f/0x30 drivers/base/dd.c:757
bus_probe_device+0x1eb/0x290 drivers/base/bus.c:523
device_add+0xd0b/0x1660 drivers/base/core.c:1835
usb_set_configuration+0x104e/0x1870 drivers/usb/core/message.c:1932
generic_probe+0x73/0xe0 drivers/usb/core/generic.c:174
usb_probe_device+0xaf/0xe0 drivers/usb/core/driver.c:266
usb_new_device+0x7b8/0x1020 drivers/usb/core/hub.c:2457
hub_port_connect drivers/usb/core/hub.c:4903
hub_port_connect_change drivers/usb/core/hub.c:5009
port_event drivers/usb/core/hub.c:5115
hub_event+0x194d/0x3740 drivers/usb/core/hub.c:5195
process_one_work+0xc7f/0x1db0 kernel/workqueue.c:2119
worker_thread+0x221/0x1850 kernel/workqueue.c:2253
kthread+0x3a1/0x470 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:431
Code: ff ff 48 85 c0 74 24 48 89 c7 e8 48 ea ff ff bf 01 00 00 00 e8
de 20 e3 ff 65 8b 05 b7 2f c2 7e 85 c0 75 c9 e8 f9 0b c1 ff eb c2 <0f>
0b 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 b8 00 00
RIP: symbol_put_addr+0x54/0x60 RSP: ffff88006a7ce210
---[ end trace b75b357739e7e116 ]---
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 58fd55e838276a0c13d1dc7c387f90f25063cbf3 upstream.
It seems that the return value of usb_ifnum_to_if() can be NULL and
needs to be checked.
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Sean Young <sean@mess.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 93dc1774d2a4c7a298d5cdf78cc8acdcb7b1428d upstream.
Commit f4757af ("staging: panel: Fix single-open policy race condition")
introduced in 3.19-rc1 attempted to fix a race condition on the open, but
failed to properly do it and used to exit without restoring the semaphore.
This results in -EBUSY being returned after the first open error until
the module is reloaded or the system restarted (ie: consecutive to a
dual open resulting in -EBUSY or to a permission error).
Fixes: f4757af85 # 3.19-rc1
Cc: Mariusz Gorski <marius.gorski@gmail.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
[wt: driver is in staging/panel in 4.4]
commit 6f48655facfd7f7ccfe6d252ac0fe319ab02e4dd upstream.
This patch fixes a generate_node_acls = 1 + cache_dynamic_acls = 0
regression, that was introduced by
commit 01d4d673558985d9a118e1e05026633c3e2ade9b
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Wed Dec 7 12:55:54 2016 -0800
which originally had the proper list_del_init() usage, but was
dropped during list review as it was thought unnecessary by HCH.
However, list_del_init() usage is required during the special
generate_node_acls = 1 + cache_dynamic_acls = 0 case when
transport_free_session() does a list_del(&se_nacl->acl_list),
followed by target_complete_nacl() doing the same thing.
This was manifesting as a general protection fault as reported
by Justin:
kernel: general protection fault: 0000 [#1] SMP
kernel: Modules linked in:
kernel: CPU: 0 PID: 11047 Comm: iscsi_ttx Not tainted 4.13.0-rc2.x86_64.1+ #20
kernel: Hardware name: Intel Corporation S5500BC/S5500BC, BIOS S5500.86B.01.00.0064.050520141428 05/05/2014
kernel: task: ffff88026939e800 task.stack: ffffc90007884000
kernel: RIP: 0010:target_put_nacl+0x49/0xb0
kernel: RSP: 0018:ffffc90007887d70 EFLAGS: 00010246
kernel: RAX: dead000000000200 RBX: ffff8802556ca000 RCX: 0000000000000000
kernel: RDX: dead000000000100 RSI: 0000000000000246 RDI: ffff8802556ce028
kernel: RBP: ffffc90007887d88 R08: 0000000000000001 R09: 0000000000000000
kernel: R10: ffffc90007887df8 R11: ffffea0009986900 R12: ffff8802556ce020
kernel: R13: ffff8802556ce028 R14: ffff8802556ce028 R15: ffffffff88d85540
kernel: FS: 0000000000000000(0000) GS:ffff88027fc00000(0000) knlGS:0000000000000000
kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
kernel: CR2: 00007fffe36f5f94 CR3: 0000000009209000 CR4: 00000000003406f0
kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
kernel: DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
kernel: Call Trace:
kernel: transport_free_session+0x67/0x140
kernel: transport_deregister_session+0x7a/0xc0
kernel: iscsit_close_session+0x92/0x210
kernel: iscsit_close_connection+0x5f9/0x840
kernel: iscsit_take_action_for_connection_exit+0xfe/0x110
kernel: iscsi_target_tx_thread+0x140/0x1e0
kernel: ? wait_woken+0x90/0x90
kernel: kthread+0x124/0x160
kernel: ? iscsit_thread_get_cpumask+0x90/0x90
kernel: ? kthread_create_on_node+0x40/0x40
kernel: ret_from_fork+0x22/0x30
kernel: Code: 00 48 89 fb 4c 8b a7 48 01 00 00 74 68 4d 8d 6c 24 08 4c
89 ef e8 e8 28 43 00 48 8b 93 20 04 00 00 48 8b 83 28 04 00 00 4c 89
ef <48> 89 42 08 48 89 10 48 b8 00 01 00 00 00 00 ad de 48 89 83 20
kernel: RIP: target_put_nacl+0x49/0xb0 RSP: ffffc90007887d70
kernel: ---[ end trace f12821adbfd46fed ]---
To address this, go ahead and use proper list_del_list() for all
cases of se_nacl->acl_list deletion.
Reported-by: Justin Maggard <jmaggard01@gmail.com>
Tested-by: Justin Maggard <jmaggard01@gmail.com>
Cc: Justin Maggard <jmaggard01@gmail.com>
commit 59b6986dbfcdab96a971f9663221849de79a7556 upstream.
Allocate a task management request structure for all task management
requests, including task reassignment. This change avoids that the
se_tmr->response assignment dereferences an uninitialized se_tmr
pointer.
Reported-by: Moshe David <mdavid@infinidat.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Moshe David <mdavid@infinidat.com>
commit 9029679f66d976f8c720eb03c4898274803c9923 upstream.
Upon stopping an AP interface the driver disable INFRA mode effectively
setting the interface in IBSS mode. However, this may affect other
interfaces running in INFRA mode. For instance, if user creates and stops
hostap daemon on virtual interface, then association cannot work on
primary interface because default BSS has been set to IBSS mode in
firmware side. The IBSS mode should be set when cfg80211 changes the
interface.
Reviewed-by: Wright Feng <wright.feng@cypress.com>
Signed-off-by: Chi-hsien Lin <Chi-Hsien.Lin@cypress.com>
[kvalo@codeaurora.org: rephased commit log based on discussion]
Signed-off-by: Wright Feng <wright.feng@cypress.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Cc: Philipp Rosenberger <p.rosenberger@linutronix.de>
commit d01332f1acacc0cb43a61f4244dd2b846d4cd585 upstream.
Changing certain link attributes (link tolerance and link priority)
from the TIPC management tool is supposed to automatically take
effect at both endpoints of the affected link.
Currently the media address is not instantiated for the link and is
used uninstantiated when crafting protocol messages designated for the
peer endpoint. This means that changing a link property currently
results in the property being changed on the local machine but the
protocol message designated for the peer gets lost. Resulting in
property discrepancy between the endpoints.
In this patch we resolve this by using the media address from the
link entry and using the bearer transmit function to send it. Hence,
we can now eliminate the redundant function tipc_link_prot_xmit() and
the redundant field tipc_link::media_addr.
Fixes: 2af5ae372a4b (tipc: clean up unused code and structures)
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Reported-by: Jason Hu <huzhijiang@gmail.com>
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
[backported to 4.4 by Tommi Rantala]
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
commit 47b2c3fff4932e6fc17ce13d51a43c6969714e20 upstream.
CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for
several 64-bit architectures : mips, parisc, tile.
At the moment and for those architectures, calling in 32-bit userspace the
keyctl syscall would return an ENOSYS error.
This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to
make sure the compatibility wrapper is registered by default for any 64-bit
architecture as long as it is configured with CONFIG_COMPAT.
[DH: Modified to remove arm64 compat enablement also as requested by Eric
Biggers]
Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
cc: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Cc: James Cowgill <james.cowgill@mips.com>
[ Upstream commit 06f877d613be3621604c2520ec0351d9fbdca15f ]
In my first attempt to fix the lockdep splat, I forgot we could
enter inet_csk_route_req() with a freshly allocated request socket,
for which refcount has not yet been elevated, due to complex
SLAB_TYPESAFE_BY_RCU rules.
We either are in rcu_read_lock() section _or_ we own a refcount on the
request.
Correct RCU verb to use here is rcu_dereference_check(), although it is
not possible to prove we actually own a reference on a shared
refcount :/
In v2, I added ireq_opt_deref() helper and use in three places, to fix other
possible splats.
[ 49.844590] lockdep_rcu_suspicious+0xea/0xf3
[ 49.846487] inet_csk_route_req+0x53/0x14d
[ 49.848334] tcp_v4_route_req+0xe/0x10
[ 49.850174] tcp_conn_request+0x31c/0x6a0
[ 49.851992] ? __lock_acquire+0x614/0x822
[ 49.854015] tcp_v4_conn_request+0x5a/0x79
[ 49.855957] ? tcp_v4_conn_request+0x5a/0x79
[ 49.858052] tcp_rcv_state_process+0x98/0xdcc
[ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307
[ 49.862085] tcp_v4_do_rcv+0xfc/0x145
[ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145
[ 49.866173] tcp_v4_rcv+0x5ab/0xaf9
[ 49.868029] ip_local_deliver_finish+0x1af/0x2e7
[ 49.870064] ip_local_deliver+0x1b2/0x1c5
[ 49.871775] ? inet_del_offload+0x45/0x45
[ 49.873916] ip_rcv_finish+0x3f7/0x471
[ 49.875476] ip_rcv+0x3f1/0x42f
[ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7
[ 49.878791] __netif_receive_skb_core+0x6d3/0x950
[ 49.880701] ? process_backlog+0x7e/0x216
[ 49.882589] __netif_receive_skb+0x1d/0x5e
[ 49.884122] process_backlog+0x10c/0x216
[ 49.885812] net_rx_action+0x147/0x3df
Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()")
Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races")
Reported-by: kernel test robot <fengguang.wu@intel.com>
Reported-by: Maciej Żenczykowski <maze@google.com>
[ Upstream commit a6ca7abe53633d08eea1c6756cb49c9b2d4c90bf ]
This patch fixes the following lockdep splat in inet_csk_route_req()
inet_csk_route_req
tcp_v4_send_synack
tcp_rtx_synack
inet_rtx_syn_ack
tcp_fastopen_synack_time
tcp_retransmit_timer
tcp_write_timer_handler
tcp_write_timer
call_timer_fn
Thread running inet_csk_route_req() owns a reference on the request
socket, so we have the guarantee ireq->ireq_opt wont be changed or
freed.
lockdep can enforce this invariant for us.
[ Upstream commit c92e8c02fe664155ac4234516e32544bec0f113d ]
syzkaller found another bug in DCCP/TCP stacks [1]
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
ireq->opt unless we own the request sock.
Note the opt field is renamed to ireq_opt to ease grep games.
[1]
BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474
Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295
CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135
tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557
__tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072
tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline]
tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071
tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816
tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:249 [inline]
ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:464 [inline]
ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514
netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587
netif_receive_skb+0xae/0x390 net/core/dev.c:4611
tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372
tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766
tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792
call_write_iter include/linux/fs.h:1770 [inline]
new_sync_write fs/read_write.c:468 [inline]
__vfs_write+0x68a/0x970 fs/read_write.c:481
vfs_write+0x18f/0x510 fs/read_write.c:543
SYSC_write fs/read_write.c:588 [inline]
SyS_write+0xef/0x220 fs/read_write.c:580
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x40c341
RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341
RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1
R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000
Allocated by task 3295:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
__do_kmalloc mm/slab.c:3725 [inline]
__kmalloc+0x162/0x760 mm/slab.c:3734
kmalloc include/linux/slab.h:498 [inline]
tcp_v4_save_options include/net/tcp.h:1962 [inline]
tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271
tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283
tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313
tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857
tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482
tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711
Freed by task 3306:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kfree+0xca/0x250 mm/slab.c:3820
inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157
__sk_destruct+0xfd/0x910 net/core/sock.c:1560
sk_destruct+0x47/0x80 net/core/sock.c:1595
__sk_free+0x57/0x230 net/core/sock.c:1603
sk_free+0x2a/0x40 net/core/sock.c:1614
sock_put include/net/sock.h:1652 [inline]
inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959
tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765
tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
[ Upstream commit f3594f0a7ea36661d7fd942facd7f31a64245f1a ]
t->err_count is used to count the link failure on tunnel and an err
will be reported to user socket in tx path if t->err_count is not 0.
udp socket could even return EHOSTUNREACH to users.
Since commit fd58156e456d ("IPIP: Use ip-tunneling code.") removed
the 'switch check' for icmp type in ipip_err(), err_count would be
increased by the icmp packet with ICMP_EXC_FRAGTIME code. an link
failure would be reported out due to this.
In Jianlin's case, when receiving ICMP_EXC_FRAGTIME a icmp packet,
udp netperf failed with the err:
send_data: data send error: No route to host (errno 113)
We expect this error reported from tunnel to socket when receiving
some certain type icmp, but not ICMP_EXC_FRAGTIME, ICMP_SR_FAILED
or ICMP_PARAMETERPROB ones.
This patch is to bring 'switch check' for icmp type back to ipip_err
so that it only reports link failure for the right type icmp, just as
in ipgre_err() and ipip6_err().
Fixes: fd58156e456d ("IPIP: Use ip-tunneling code.")
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit 6151b8b37b119e8e3a8401b080d532520c95faf4 ]
ppp_release() tries to ensure that netdevices are unregistered before
decrementing the unit refcount and running ppp_destroy_interface().
This is all fine as long as the the device is unregistered by
ppp_release(): the unregister_netdevice() call, followed by
rtnl_unlock(), guarantee that the unregistration process completes
before rtnl_unlock() returns.
However, the device may be unregistered by other means (like
ppp_nl_dellink()). If this happens right before ppp_release() calling
rtnl_lock(), then ppp_release() has to wait for the concurrent
unregistration code to release the lock.
But rtnl_unlock() releases the lock before completing the device
unregistration process. This allows ppp_release() to proceed and
eventually call ppp_destroy_interface() before the unregistration
process completes. Calling free_netdev() on this partially unregistered
device will BUG():
kernel BUG at net/core/dev.c:8141!
invalid opcode: 0000 [#1] SMP
CPU: 1 PID: 1557 Comm: pppd Not tainted 4.14.0-rc2+ #4
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1.fc26 04/01/2014
Call Trace:
ppp_destroy_interface+0xd8/0xe0 [ppp_generic]
ppp_disconnect_channel+0xda/0x110 [ppp_generic]
ppp_unregister_channel+0x5e/0x110 [ppp_generic]
pppox_unbind_sock+0x23/0x30 [pppox]
pppoe_connect+0x130/0x440 [pppoe]
SYSC_connect+0x98/0x110
? do_fcntl+0x2c0/0x5d0
SyS_connect+0xe/0x10
entry_SYSCALL_64_fastpath+0x1a/0xa5
RIP: free_netdev+0x107/0x110 RSP: ffffc28a40573d88
---[ end trace ed294ff0cc40eeff ]---
We could set the ->needs_free_netdev flag on PPP devices and move the
ppp_destroy_interface() logic in the ->priv_destructor() callback. But
that'd be quite intrusive as we'd first need to unlink from the other
channels and units that depend on the device (the ones that used the
PPPIOCCONNECT and PPPIOCATTACH ioctls).
Instead, we can just let the netdevice hold a reference on its
ppp_file. This reference is dropped in ->priv_destructor(), at the very
end of the unregistration process, so that neither ppp_release() nor
ppp_disconnect_channel() can call ppp_destroy_interface() in the interim.
Reported-by: Beniamino Galvani <bgalvani@redhat.com>
Fixes: 8cb775bc0a34 ("ppp: fix device unregistration upon netns deletion")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit d04adf1b355181e737b6b1e23d801b07f0b7c4c0 ]
Now when migrating sock to another one in sctp_sock_migrate(), it only
resets owner sk for the data in receive queues, not the chunks on out
queues.
It would cause that data chunks length on the sock is not consistent
with sk sk_wmem_alloc. When closing the sock or freeing these chunks,
the old sk would never be freed, and the new sock may crash due to
the overflow sk_wmem_alloc.
syzbot found this issue with this series:
r0 = socket$inet_sctp()
sendto$inet(r0)
listen(r0)
accept4(r0)
close(r0)
Although listen() should have returned error when one TCP-style socket
is in connecting (I may fix this one in another patch), it could also
be reproduced by peeling off an assoc.
This issue is there since very beginning.
This patch is to reset owner sk for the chunks on out queues so that
sk sk_wmem_alloc has correct value after accept one sock or peeloff
an assoc to one sock.
Note that when resetting owner sk for chunks on outqueue, it has to
sctp_clear_owner_w/skb_orphan chunks before changing assoc->base.sk
first and then sctp_set_owner_w them after changing assoc->base.sk,
due to that sctp_wfree and it's callees are using assoc->base.sk.
[ Upstream commit 5c25f65fd1e42685f7ccd80e0621829c105785d9 ]
If the name argument of dev_get_valid_name() contains "%d", it will try
to assign it a unit number in __dev__alloc_name() and return either the
unit number (>= 0) or an error code (< 0).
Considering positive values as error values prevent tun device creations
relying this mechanism, therefor we should only consider negative values
as errors here.
Signed-off-by: Julien Gomes <julien@arista.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit f8d20b46ce55cf40afb30dcef6d9288f7ef46d9b ]
The similar fix in patch 'ipip: only increase err_count for some
certain type icmp in ipip_err' is needed for ip6gre_err.
In Jianlin's case, udp netperf broke even when receiving a TooBig
icmpv6 packet.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
[ Upstream commit 0f5da659d8f1810f44de14acf2c80cd6499623a0 ]
socket_diag shows information only about sockets from a namespace where
a diag socket lives.
But if we request information about one unix socket, the kernel don't
check that its netns is matched with a diag socket namespace, so any
user can get information about any unix socket in a system. This looks
like a bug.
v2: add a Fixes tag
Fixes: 51d7cccf0723 ("net: make sock diag per-namespace")
Signed-off-by: Andrei Vagin <avagin@openvz.org>
[ Upstream commit 864e2a1f8aac05effac6063ce316b480facb46ff ]
When syzkaller team brought us a C repro for the crash [1] that
had been reported many times in the past, I finally could find
the root cause.
If FlowLabel info is merged by fl6_merge_options(), we leave
part of the opt_space storage provided by udp/raw/l2tp with random value
in opt_space.tot_len, unless a control message was provided at sendmsg()
time.
Then ip6_setup_cork() would use this random value to perform a kzalloc()
call. Undefined behavior and crashes.
Fix is to properly set tot_len in fl6_merge_options()
At the same time, we can also avoid consuming memory and cpu cycles
to clear it, if every option is copied via a kmemdup(). This is the
change in ip6_setup_cork().
[1]
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 6613 Comm: syz-executor0 Not tainted 4.14.0-rc4+ #127
task: ffff8801cb64a100 task.stack: ffff8801cc350000
RIP: 0010:ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168
RSP: 0018:ffff8801cc357550 EFLAGS: 00010203
RAX: dffffc0000000000 RBX: ffff8801cc357748 RCX: 0000000000000010
RDX: 0000000000000002 RSI: ffffffff842bd1d9 RDI: 0000000000000014
RBP: ffff8801cc357620 R08: ffff8801cb17f380 R09: ffff8801cc357b10
R10: ffff8801cb64a100 R11: 0000000000000000 R12: ffff8801cc357ab0
R13: ffff8801cc357b10 R14: 0000000000000000 R15: ffff8801c3bbf0c0
FS: 00007f9c5c459700(0000) GS:ffff8801db200000(0000) knlGS:0000000000000000
CR2: 0000000020324000 CR3: 00000001d1cf2000 CR4: 00000000001406f0
DR0: 0000000020001010 DR1: 0000000000000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000600
Call Trace:
ip6_make_skb+0x282/0x530 net/ipv6/ip6_output.c:1729
udpv6_sendmsg+0x2769/0x3380 net/ipv6/udp.c:1340
inet_sendmsg+0x11f/0x5e0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x358/0x5a0 net/socket.c:1750
SyS_sendto+0x40/0x50 net/socket.c:1718
RIP: 0033:0x4520a9
RSP: 002b:00007f9c5c458c08 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 00000000004520a9
RDX: 0000000000000001 RSI: 0000000020fd1000 RDI: 0000000000000016
RBP: 0000000000000086 R08: 0000000020e0afe4 R09: 000000000000001c
R10: 0000000000000000 R11: 0000000000000216 R12: 00000000004bb1ee
R13: 00000000ffffffff R14: 0000000000000016 R15: 0000000000000029
Code: e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85 ea 0f 00 00 48 8d 79 04 48 b8 00 00 00 00 00 fc ff df 45 8b 74 24 04 48 89 fa 48 c1 ea 03 <0f> b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85
RIP: ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168 RSP: ffff8801cc357550
