2016-05-11Linux 4.4.10v4.4.10Greg Kroah-Hartman
2016-05-11drm/i915/skl: Fix DMC load on Skylake J0 and K0Mat Martineau
commit a41c8882592fb80458959b10e37632ce030b68ca upstream. The driver does not load firmware for unknown steppings, so these new steppings must be added to the list. Cc: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Mat Martineau <mathew.j.martineau@linux.intel.com> Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1454023163-25469-1-git-send-email-mathew.j.martineau@linux.intel.com Cc: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11lib/test-string_helpers.c: fix and improve string_get_size() testsVitaly Kuznetsov
commit 72676bb53f33fd0ef3a1484fc1ecfd306dc6ff40 upstream. Recently added commit 564b026fbd0d ("string_helpers: fix precision loss for some inputs") fixed precision issues for string_get_size() and broke tests. Fix and improve them: test both STRING_UNITS_2 and STRING_UNITS_10 at a time, better failure reporting, test small an huge values. Fixes: 564b026fbd0d28e9 ("string_helpers: fix precision loss for some inputs") Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: James Bottomley <JBottomley@Odin.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ACPI / processor: Request native thermal interrupt handling via _OSCSrinivas Pandruvada
commit a21211672c9a1d730a39aa65d4a5b3414700adfb upstream. There are several reports of freeze on enabling HWP (Hardware PStates) feature on Skylake-based systems by the Intel P-states driver. The root cause is identified as the HWP interrupts causing BIOS code to freeze. HWP interrupts use the thermal LVT which can be handled by Linux natively, but on the affected Skylake-based systems SMM will respond to it by default. This is a problem for several reasons: - On the affected systems the SMM thermal LVT handler is broken (it will crash when invoked) and a BIOS update is necessary to fix it. - With thermal interrupt handled in SMM we lose all of the reporting features of the arch/x86/kernel/cpu/mcheck/therm_throt driver. - Some thermal drivers like x86-package-temp depend on the thermal threshold interrupts signaled via the thermal LVT. - The HWP interrupts are useful for debugging and tuning performance (if the kernel can handle them). The native handling of thermal interrupts needs to be enabled because of that. This requires some way to tell SMM that the OS can handle thermal interrupts. That can be done by using _OSC/_PDC in processor scope very early during ACPI initialization. The meaning of _OSC/_PDC bit 12 in processor scope is whether or not the OS supports native handling of interrupts for Collaborative Processor Performance Control (CPPC) notifications. Since on HWP-capable systems CPPC is a firmware interface to HWP, setting this bit effectively tells the firmware that the OS will handle thermal interrupts natively going forward. For details on _OSC/_PDC refer to: http://www.intel.com/content/www/us/en/standards/processor-vendor-specific-acpi-specification.html To implement the _OSC/_PDC handshake as described, introduce a new function, acpi_early_processor_osc(), that walks the ACPI namespace looking for ACPI processor objects and invokes _OSC for them with bit 12 in the capabilities buffer set and terminates the namespace walk on the first success. Also modify intel_thermal_interrupt() to clear HWP status bits in the HWP_STATUS MSR to acknowledge HWP interrupts (which prevents them from firing continuously). Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> [ rjw: Subject & changelog, function rename ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/i915: Fake HDMI live statusShashank Sharma
commit 60b3143c7cac7e8d2ca65c0b347466c5776395d1 upstream. This patch does the following: - Fakes live status of HDMI as connected (even if that's not). While testing certain (monitor + cable) combinations with various intel platforms, it seems that live status register doesn't work reliably on some older devices. So limit the live_status check for HDMI detection, only for platforms from gen7 onwards. V2: restrict faking live_status to certain platforms V3: (Ville) - keep the debug message for !live_status case - fix indentation of comment - remove "warning" from the debug message (Jani) - Change format of fix details in the commit message Fixes: 237ed86c693d ("drm/i915: Check live status before reading edid") Suggested-by: Ville Syrjala <ville.syrjala@linux.intel.com> Signed-off-by: Shashank Sharma <shashank.sharma@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1461237606-16491-1-git-send-email-shashank.sharma@intel.com Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> (cherry picked from commit 4f4a8185011773f7520d9916c6857db946e7f9d1) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/i915: Make RPS EI/thresholds multiple of 25 on SNB-BDWVille Syrjälä
commit 4ea3959018d09edfa36a9e7b5ccdbd4ec4b99e49 upstream. Somehow my SNB GT1 (Dell XPS 8300) gets very unhappy around GPU hangs if the RPS EI/thresholds aren't suitably aligned. It seems like scheduling/timer interupts stop working somehow and things get stuck eg. in usleep_range(). I bisected the problem down to commit 8a5864377b12 ("drm/i915/skl: Restructured the gen6_set_rps_thresholds function") I observed that before all the values were at least multiples of 25, but afterwards they are not. And rounding things up to the next multiple of 25 does seem to help, so lets' do that. I also tried roundup(..., 5) but that wasn't sufficient. Also I have no idea if we might need this sort of thing on gen9+ as well. These are the original EI/thresholds: LOW_POWER GEN6_RP_UP_EI 12500 GEN6_RP_UP_THRESHOLD 11800 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 21250 BETWEEN GEN6_RP_UP_EI 10250 GEN6_RP_UP_THRESHOLD 9225 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 18750 HIGH_POWER GEN6_RP_UP_EI 8000 GEN6_RP_UP_THRESHOLD 6800 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 15000 These are after 8a5864377b12: LOW_POWER GEN6_RP_UP_EI 12500 GEN6_RP_UP_THRESHOLD 11875 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 21250 BETWEEN GEN6_RP_UP_EI 10156 GEN6_RP_UP_THRESHOLD 9140 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 18750 HIGH_POWER GEN6_RP_UP_EI 7812 GEN6_RP_UP_THRESHOLD 6640 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 15000 And these are what we have after this patch: LOW_POWER GEN6_RP_UP_EI 12500 GEN6_RP_UP_THRESHOLD 11875 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 21250 BETWEEN GEN6_RP_UP_EI 10175 GEN6_RP_UP_THRESHOLD 9150 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 18750 HIGH_POWER GEN6_RP_UP_EI 7825 GEN6_RP_UP_THRESHOLD 6650 GEN6_RP_DOWN_EI 25000 GEN6_RP_DOWN_THRESHOLD 15000 Cc: Akash Goel <akash.goel@intel.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Testcase: igt/kms_pipe_crc_basic/hang-read-crc-pipe-B Fixes: 8a5864377b12 ("drm/i915/skl: Restructured the gen6_set_rps_thresholds function") Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1461159836-9108-1-git-send-email-ville.syrjala@linux.intel.com Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Patrik Jakobsson <patrik.jakobsson@linux.intel.com> (cherry picked from commit 8a292d016d1cc4938ff14b4df25328230b08a408) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/i915: Fix eDP low vswing for BroadwellMika Kahola
commit 992e7a41f9fcc7bcd10e7d346aee5ed7a2c241cb upstream. It was noticed on bug #94087 that module parameter i915.edp_vswing=2 that should override the VBT setting to use default voltage swing (400 mV) was not applied for Broadwell. This patch provides a fix for this by checking if default i.e. higher voltage swing is requested to be used and applies the DDI translations table for DP instead of eDP (low vswing) table. v2: Combine two if statements into one (Jani) v3: Change dev_priv->edp_low_vswing to use dev_priv->vbt.edp.low_vswing Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=94087 Signed-off-by: Mika Kahola <mika.kahola@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1461155942-7749-1-git-send-email-mika.kahola@intel.com Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> (cherry picked from commit 00983519214b61c1b9371ec2ed55a4dde773e384) [Jani: s/dev_priv->vbt.edp.low_vswing/dev_priv->edp_low_vswing/ to backport] Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/i915/ddi: Fix eDP VDD handling during booting and suspend/resumeImre Deak
commit 5eaa60c7109b40f17ac81090bc8b90482da76cd1 upstream. The driver's VDD on/off logic assumes that whenever the VDD is on we also hold an AUX power domain reference. Since BIOS can leave the VDD on during booting and resuming and on DDI platforms we won't take a corresponding power reference, the above assumption won't hold on those platforms and an eventual delayed VDD off work will do an extraneous AUX power domain put resulting in a refcount underflow. Fix this the same way we did this for non-DDI DP encoders: commit 6d93c0c41760c0 ("drm/i915: fix VDD state tracking after system resume") At the same time call the DP encoder suspend handler the same way as the non-DDI DP encoders do to flush any pending VDD off work. Leaving the work running may cause a HW access where we don't expect this (at a point where power domains are suspended already). While at it remove an unnecessary function call indirection. This fixed for me AUX refcount underflow problems on BXT during suspend/resume. CC: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1460963062-13211-4-git-send-email-imre.deak@intel.com (cherry picked from commit bf93ba67e9c05882f05b7ca2d773cfc8bf462c2a) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/radeon: make sure vertical front porch is at least 1Alex Deucher
commit 3104b8128d4d646a574ed9d5b17c7d10752cd70b upstream. hw doesn't like a 0 value. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11iio: ak8975: fix maybe-uninitialized warningRichard Leitner
commit 05be8d4101d960bad271d32b4f6096af1ccb1534 upstream. If i2c_device_id *id is NULL and acpi_match_device returns NULL too, then chipset may be unitialized when accessing &ak_def_array[chipset] in ak8975_probe. Therefore initialize chipset to AK_MAX_TYPE, which will return an error when not changed. This patch fixes the following maybe-uninitialized warning: drivers/iio/magnetometer/ak8975.c: In function ‘ak8975_probe’: drivers/iio/magnetometer/ak8975.c:788:14: warning: ‘chipset’ may be used uninitialized in this function [-Wmaybe-uninitialized] data->def = &ak_def_array[chipset]; Signed-off-by: Richard Leitner <dev@g0hl1n.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11iio: ak8975: Fix NULL pointer exception on early interruptKrzysztof Kozlowski
commit 07d2390e36ee5b3265e9cc8305f2a106c8721e16 upstream. In certain probe conditions the interrupt came right after registering the handler causing a NULL pointer exception because of uninitialized waitqueue: $ udevadm trigger i2c-gpio i2c-gpio-1: using pins 143 (SDA) and 144 (SCL) i2c-gpio i2c-gpio-3: using pins 53 (SDA) and 52 (SCL) Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = e8b38000 [00000000] *pgd=00000000 Internal error: Oops: 5 [#1] SMP ARM Modules linked in: snd_soc_i2s(+) i2c_gpio(+) snd_soc_idma snd_soc_s3c_dma snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore ac97_bus spi_s3c64xx pwm_samsung dwc2 exynos_adc phy_exynos_usb2 exynosdrm exynos_rng rng_core rtc_s3c CPU: 0 PID: 717 Comm: data-provider-m Not tainted 4.6.0-rc1-next-20160401-00011-g1b8d87473b9e-dirty #101 Hardware name: SAMSUNG EXYNOS (Flattened Device Tree) (...) (__wake_up_common) from [<c0379624>] (__wake_up+0x38/0x4c) (__wake_up) from [<c0a41d30>] (ak8975_irq_handler+0x28/0x30) (ak8975_irq_handler) from [<c0386720>] (handle_irq_event_percpu+0x88/0x140) (handle_irq_event_percpu) from [<c038681c>] (handle_irq_event+0x44/0x68) (handle_irq_event) from [<c0389c40>] (handle_edge_irq+0xf0/0x19c) (handle_edge_irq) from [<c0385e04>] (generic_handle_irq+0x24/0x34) (generic_handle_irq) from [<c05ee360>] (exynos_eint_gpio_irq+0x50/0x68) (exynos_eint_gpio_irq) from [<c0386720>] (handle_irq_event_percpu+0x88/0x140) (handle_irq_event_percpu) from [<c038681c>] (handle_irq_event+0x44/0x68) (handle_irq_event) from [<c0389a70>] (handle_fasteoi_irq+0xb4/0x194) (handle_fasteoi_irq) from [<c0385e04>] (generic_handle_irq+0x24/0x34) (generic_handle_irq) from [<c03860b4>] (__handle_domain_irq+0x5c/0xb4) (__handle_domain_irq) from [<c0301774>] (gic_handle_irq+0x54/0x94) (gic_handle_irq) from [<c030c910>] (__irq_usr+0x50/0x80) The bug was reproduced on exynos4412-trats2 (with a max77693 device also using i2c-gpio) after building max77693 as a module. Fixes: 94a6d5cf7caa ("iio:ak8975 Implement data ready interrupt handling") Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Tested-by: Gregor Boirie <gregor.boirie@parrot.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/amdgpu: set metadata pointer to NULL after freeing.Dave Airlie
commit 0092d3edcb23fcdb8cbe4159ba94a534290ff982 upstream. Without this there was a double free of the metadata, which ended up freeing the fd table for me here, and taking out the machine more often than not. I reproduced with X.org + modesetting DDX + latest llvm/mesa, also required using dri3. Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11drm/amdgpu: make sure vertical front porch is at least 1Alex Deucher
commit 0126d4b9a516256f2432ca0dc78ab293a8255378 upstream. hw doesn't like a 0 value. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11gpu: ipu-v3: Fix imx-ipuv3-crtc module autoloadingPhilipp Zabel
commit 503fe87bd0a8346ba9d8b7f49115dcd0a4185226 upstream. If of_node is set before calling platform_device_add, the driver core will try to use of: modalias matching, which fails because the device tree nodes don't have a compatible property set. This patch fixes imx-ipuv3-crtc module autoloading by setting the of_node property only after the platform modalias is set. Fixes: 304e6be652e2 ("gpu: ipu-v3: Assign of_node of child platform devices to corresponding ports") Reported-by: Dennis Gilmore <dennis@ausil.us> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Tested-By: Dennis Gilmore <dennis@ausil.us> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11nvmem: mxs-ocotp: fix buffer overflow in readStanislav Meduna
commit d1306eb675ad7a9a760b6b8e8e189824b8db89e7 upstream. This patch fixes the issue where the mxs_ocotp_read is reading the ocotp in reg_size steps but decrements the remaining size by 1. The number of iterations is thus four times higher, overwriting the area behind the output buffer. Fixes: c01e9a11ab6f ("nvmem: add driver for ocotp in i.MX23 and i.MX28") Tested-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Stanislav Meduna <stano@meduna.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11USB: serial: cp210x: add Straizona Focusers device idsJasem Mutlaq
commit 613ac23a46e10d4d4339febdd534fafadd68e059 upstream. Adding VID:PID for Straizona Focusers to cp210x driver. Signed-off-by: Jasem Mutlaq <mutlaqja@ikarustech.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11USB: serial: cp210x: add ID for Link ECUMike Manning
commit 1d377f4d690637a0121eac8701f84a0aa1e69a69 upstream. The Link ECU is an aftermarket ECU computer for vehicles that provides full tuning abilities as well as datalogging and displaying capabilities via the USB to Serial adapter built into the device. Signed-off-by: Mike Manning <michael@bsch.com.au> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ata: ahci-platform: Add ports-implemented DT bindings.Srinivas Kandagatla
commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 upstream. On some SOCs PORTS_IMPL register value is never programmed by the firmware and left at zero value. Which means that no sata ports are available for software. AHCI driver used to cope up with this by fabricating the port_map if the PORTS_IMPL register is read zero, but recent patch broke this workaround as zero value was valid for NVMe disks. This patch adds ports-implemented DT bindings as workaround for this issue in a way that DT can can override the PORTS_IMPL register in cases where the firmware did not program it already. Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3") Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11libahci: save port map for forced port mapSrinivas Kandagatla
commit 2fd0f46cb1b82587c7ae4a616d69057fb9bd0af7 upstream. In usecases where force_port_map is used saved_port_map is never set, resulting in not programming the PORTS_IMPL register as part of initial config. This patch fixes this by setting it to port_map even in case where force_port_map is used, making it more inline with other parts of the code. Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3") Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11powerpc: Fix bad inline asm constraint in create_zero_mask()Anton Blanchard
commit b4c112114aab9aff5ed4568ca5e662bb02cdfe74 upstream. In create_zero_mask() we have: addi %1,%2,-1 andc %1,%1,%2 popcntd %0,%1 using the "r" constraint for %2. r0 is a valid register in the "r" set, but addi X,r0,X turns it into an li: li r7,-1 andc r7,r7,r0 popcntd r4,r7 Fix this by using the "b" constraint, for which r0 is not a valid register. This was found with a kernel build using gcc trunk, narrowed down to when -frename-registers was enabled at -O2. It is just luck however that we aren't seeing this on older toolchains. Thanks to Segher for working with me to find this issue. Fixes: d0cebfa650a0 ("powerpc: word-at-a-time optimization for 64-bit Little Endian") Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ACPICA: Dispatcher: Update thread ID for recursive method callsPrarit Bhargava
commit 93d68841a23a5779cef6fb9aa0ef32e7c5bd00da upstream. ACPICA commit 7a3bd2d962f221809f25ddb826c9e551b916eb25 Set the mutex owner thread ID. Original patch from: Prarit Bhargava <prarit@redhat.com> Link: https://bugzilla.kernel.org/show_bug.cgi?id=115121 Link: https://github.com/acpica/acpica/commit/7a3bd2d9 Signed-off-by: Prarit Bhargava <prarit@redhat.com> Tested-by: Andy Lutomirski <luto@kernel.org> # On a Dell XPS 13 9350 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11x86/sysfb_efi: Fix valid BAR address range checkWang YanQing
commit c10fcb14c7afd6688c7b197a814358fecf244222 upstream. The code for checking whether a BAR address range is valid will break out of the loop when a start address of 0x0 is encountered. This behaviour is wrong since by breaking out of the loop we may miss the BAR that describes the EFI frame buffer in a later iteration. Because of this bug I can't use video=efifb: boot parameter to get efifb on my new ThinkPad E550 for my old linux system hard disk with 3.10 kernel. In 3.10, efifb is the only choice due to DRM/I915 not supporting the GPU. This patch also add a trivial optimization to break out after we find the frame buffer address range without testing later BARs. Signed-off-by: Wang YanQing <udknight@gmail.com> [ Rewrote changelog. ] Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Reviewed-by: Peter Jones <pjones@redhat.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/1462454061-21561-2-git-send-email-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ARC: Add missing io barriers to io{read,write}{16,32}be()Vineet Gupta
commit e5bc0478ab6cf565619224536d75ecb2aedca43b upstream. While reviewing a different change to asm-generic/io.h Arnd spotted that ARC ioread32 and ioread32be both of which come from asm-generic versions are not symmetrical in terms of calling the io barriers. generic ioread32 -> ARC readl() [ has barriers] generic ioread32be -> __be32_to_cpu(__raw_readl()) [ lacks barriers] While generic ioread32be is being remediated to call readl(), that involves a swab32(), causing double swaps on ioread32be() on Big Endian systems. So provide our versions of big endian IO accessors to ensure io barrier calls while also keeping them optimal Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ARM: cpuidle: Pass on arm_cpuidle_suspend()'s return valueJames Morse
commit 625fe4f8ffc1b915248558481bb94249f6bd411c upstream. arm_cpuidle_suspend() may return -EOPNOTSUPP, or any value returned by the cpu_ops/cpuidle_ops suspend call. arm_enter_idle_state() doesn't update 'ret' with this value, meaning we always signal success to cpuidle_enter_state(), causing it to update the usage counters as if we succeeded. Fixes: 191de17aa3c1 ("ARM64: cpuidle: Replace cpu_suspend by the common ARM/ARM64 function") Signed-off-by: James Morse <james.morse@arm.com> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11propogate_mnt: Handle the first propogated copy being a slaveEric W. Biederman
commit 5ec0811d30378ae104f250bfc9b3640242d81e3f upstream. When the first propgated copy was a slave the following oops would result: > BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 > IP: [<ffffffff811fba4e>] propagate_one+0xbe/0x1c0 > PGD bacd4067 PUD bac66067 PMD 0 > Oops: 0000 [#1] SMP > Modules linked in: > CPU: 1 PID: 824 Comm: mount Not tainted 4.6.0-rc5userns+ #1523 > Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 > task: ffff8800bb0a8000 ti: ffff8800bac3c000 task.ti: ffff8800bac3c000 > RIP: 0010:[<ffffffff811fba4e>] [<ffffffff811fba4e>] propagate_one+0xbe/0x1c0 > RSP: 0018:ffff8800bac3fd38 EFLAGS: 00010283 > RAX: 0000000000000000 RBX: ffff8800bb77ec00 RCX: 0000000000000010 > RDX: 0000000000000000 RSI: ffff8800bb58c000 RDI: ffff8800bb58c480 > RBP: ffff8800bac3fd48 R08: 0000000000000001 R09: 0000000000000000 > R10: 0000000000001ca1 R11: 0000000000001c9d R12: 0000000000000000 > R13: ffff8800ba713800 R14: ffff8800bac3fda0 R15: ffff8800bb77ec00 > FS: 00007f3c0cd9b7e0(0000) GS:ffff8800bfb00000(0000) knlGS:0000000000000000 > CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 > CR2: 0000000000000010 CR3: 00000000bb79d000 CR4: 00000000000006e0 > Stack: > ffff8800bb77ec00 0000000000000000 ffff8800bac3fd88 ffffffff811fbf85 > ffff8800bac3fd98 ffff8800bb77f080 ffff8800ba713800 ffff8800bb262b40 > 0000000000000000 0000000000000000 ffff8800bac3fdd8 ffffffff811f1da0 > Call Trace: > [<ffffffff811fbf85>] propagate_mnt+0x105/0x140 > [<ffffffff811f1da0>] attach_recursive_mnt+0x120/0x1e0 > [<ffffffff811f1ec3>] graft_tree+0x63/0x70 > [<ffffffff811f1f6b>] do_add_mount+0x9b/0x100 > [<ffffffff811f2c1a>] do_mount+0x2aa/0xdf0 > [<ffffffff8117efbe>] ? strndup_user+0x4e/0x70 > [<ffffffff811f3a45>] SyS_mount+0x75/0xc0 > [<ffffffff8100242b>] do_syscall_64+0x4b/0xa0 > [<ffffffff81988f3c>] entry_SYSCALL64_slow_path+0x25/0x25 > Code: 00 00 75 ec 48 89 0d 02 22 22 01 8b 89 10 01 00 00 48 89 05 fd 21 22 01 39 8e 10 01 00 00 0f 84 e0 00 00 00 48 8b 80 d8 00 00 00 <48> 8b 50 10 48 89 05 df 21 22 01 48 89 15 d0 21 22 01 8b 53 30 > RIP [<ffffffff811fba4e>] propagate_one+0xbe/0x1c0 > RSP <ffff8800bac3fd38> > CR2: 0000000000000010 > ---[ end trace 2725ecd95164f217 ]--- This oops happens with the namespace_sem held and can be triggered by non-root users. An all around not pleasant experience. To avoid this scenario when finding the appropriate source mount to copy stop the walk up the mnt_master chain when the first source mount is encountered. Further rewrite the walk up the last_source mnt_master chain so that it is clear what is going on. The reason why the first source mount is special is that it it's mnt_parent is not a mount in the dest_mnt propagation tree, and as such termination conditions based up on the dest_mnt mount propgation tree do not make sense. To avoid other kinds of confusion last_dest is not changed when computing last_source. last_dest is only used once in propagate_one and that is above the point of the code being modified, so changing the global variable is meaningless and confusing. fixes: f2ebb3a921c1ca1e2ddd9242e95a1989a50c4c68 ("smarter propagate_mnt()") Reported-by: Tycho Andersen <tycho.andersen@canonical.com> Reviewed-by: Seth Forshee <seth.forshee@canonical.com> Tested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11fs/pnode.c: treat zero mnt_group_id-s as unequalMaxim Patlasov
commit 7ae8fd0351f912b075149a1e03a017be8b903b9a upstream. propagate_one(m) calculates "type" argument for copy_tree() like this: > if (m->mnt_group_id == last_dest->mnt_group_id) { > type = CL_MAKE_SHARED; > } else { > type = CL_SLAVE; > if (IS_MNT_SHARED(m)) > type |= CL_MAKE_SHARED; > } The "type" argument then governs clone_mnt() behavior with respect to flags and mnt_master of new mount. When we iterate through a slave group, it is possible that both current "m" and "last_dest" are not shared (although, both are slaves, i.e. have non-NULL mnt_master-s). Then the comparison above erroneously makes new mount shared and sets its mnt_master to last_source->mnt_master. The patch fixes the problem by handling zero mnt_group_id-s as though they are unequal. The similar problem exists in the implementation of "else" clause above when we have to ascend upward in the master/slave tree by calling: > last_source = last_source->mnt_master; > last_dest = last_source->mnt_parent; proper number of times. The last step is governed by "n->mnt_group_id != last_dest->mnt_group_id" condition that may lie if both are zero. The patch fixes this case in the same way as the former one. [AV: don't open-code an obvious helper...] Signed-off-by: Maxim Patlasov <mpatlasov@virtuozzo.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11x86/tsc: Read all ratio bits from MSR_PLATFORM_INFOChen Yu
commit 886123fb3a8656699dff40afa0573df359abeb18 upstream. Currently we read the tsc radio: ratio = (MSR_PLATFORM_INFO >> 8) & 0x1f; Thus we get bit 8-12 of MSR_PLATFORM_INFO, however according to the SDM (35.5), the ratio bits are bit 8-15. Ignoring the upper bits can result in an incorrect tsc ratio, which causes the TSC calibration and the Local APIC timer frequency to be incorrect. Fix this problem by masking 0xff instead. [ tglx: Massaged changelog ] Fixes: 7da7c1561366 "x86, tsc: Add static (MSR) TSC calibration on Intel Atom SoCs" Signed-off-by: Chen Yu <yu.c.chen@intel.com> Cc: "Rafael J. Wysocki" <rafael@kernel.org> Cc: Bin Gao <bin.gao@intel.com> Cc: Len Brown <lenb@kernel.org> Link: http://lkml.kernel.org/r/1462505619-5516-1-git-send-email-yu.c.chen@intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11MAINTAINERS: Remove asterisk from EFI directory namesMatt Fleming
commit e8dfe6d8f6762d515fcd4f30577f7bfcf7659887 upstream. Mark reported that having asterisks on the end of directory names confuses get_maintainer.pl when it encounters subdirectories, and that my name does not appear when run on drivers/firmware/efi/libstub. Reported-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/1462303781-8686-2-git-send-email-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11writeback: Fix performance regression in wb_over_bg_thresh()Howard Cochran
commit 74d369443325063a5f0260e63971decb950fd8fa upstream. Commit 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use wb_domain aware operations") unintentionally changed this function's meaning from "are there more dirty pages than the background writeback threshold" to "are there more dirty pages than the writeback threshold". The background writeback threshold is typically half of the writeback threshold, so this had the effect of raising the number of dirty pages required to cause a writeback worker to perform background writeout. This can cause a very severe performance regression when a BDI uses BDI_CAP_STRICTLIMIT because balance_dirty_pages() and the writeback worker can now disagree on whether writeback should be initiated. For example, in a system having 1GB of RAM, a single spinning disk, and a "pass-through" FUSE filesystem mounted over the disk, application code mmapped a 128MB file on the disk and was randomly dirtying pages in that mapping. Because FUSE uses strictlimit and has a default max_ratio of only 1%, in balance_dirty_pages, thresh is ~200, bg_thresh is ~100, and the dirty_freerun_ceiling is the average of those, ~150. So, it pauses the dirtying processes when we have 151 dirty pages and wakes up a background writeback worker. But the worker tests the wrong threshold (200 instead of 100), so it does not initiate writeback and just returns. Thus, balance_dirty_pages keeps looping, sleeping and then waking up the worker who will do nothing. It remains stuck in this state until the few dirty pages that we have finally expire and we write them back for that reason. Then the whole process repeats, resulting in near-zero throughput through the FUSE BDI. The fix is to call the parameterized variant of wb_calc_thresh, so that the worker will do writeback if the bg_thresh is exceeded which was the behavior before the referenced commit. Fixes: 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use wb_domain aware operations") Signed-off-by: Howard Cochran <hcochran@kernelspring.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Tested-by Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: Reduce refcnt of removed router when updating routeSven Eckelmann
commit d1a65f1741bfd9c69f9e4e2ad447a89b6810427d upstream. _batadv_update_route rcu_derefences orig_ifinfo->router outside of a spinlock protected region to print some information messages to the debug log. But this pointer is not checked again when the new pointer is assigned in the spinlock protected region. Thus is can happen that the value of orig_ifinfo->router changed in the meantime and thus the reference counter of the wrong router gets reduced after the spinlock protected region. Just rcu_dereferencing the value of orig_ifinfo->router inside the spinlock protected region (which also set the new pointer) is enough to get the correct old router object. Fixes: e1a5382f978b ("batman-adv: Make orig_node->router an rcu protected pointer") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: Fix broadcast/ogm queue limit on a removed interfaceLinus Lüssing
commit c4fdb6cff2aa0ae740c5f19b6f745cbbe786d42f upstream. When removing a single interface while a broadcast or ogm packet is still pending then we will free the forward packet without releasing the queue slots again. This patch is supposed to fix this issue. Fixes: 6d5808d4ae1b ("batman-adv: Add missing hardif_free_ref in forw_packet_free") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> [sven@narfation.org: fix conflicts with current version] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: Check skb size before using encapsulated ETH+VLAN headerSven Eckelmann
commit c78296665c3d81f040117432ab9e1cb125521b0c upstream. The encapsulated ethernet and VLAN header may be outside the received ethernet frame. Thus the skb buffer size has to be checked before it can be parsed to find out if it encapsulates another batman-adv packet. Fixes: 420193573f11 ("batman-adv: softif bridge loop avoidance") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: fix DAT candidate selection (must use vid)Antonio Quartulli
commit 2871734e85e920503d49b3a8bc0afbe0773b6036 upstream. Now that DAT is VLAN aware, it must use the VID when computing the DHT address of the candidate nodes where an entry is going to be stored/retrieved. Fixes: be1db4f6615b ("batman-adv: make the Distributed ARP Table vlan aware") Signed-off-by: Antonio Quartulli <a@unstable.cc> [sven@narfation.org: fix conflicts with current version] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11mm: update min_free_kbytes from khugepaged after core initializationJason Baron
commit bc22af74f271ef76b2e6f72f3941f91f0da3f5f8 upstream. Khugepaged attempts to raise min_free_kbytes if its set too low. However, on boot khugepaged sets min_free_kbytes first from subsys_initcall(), and then the mm 'core' over-rides min_free_kbytes after from init_per_zone_wmark_min(), via a module_init() call. Khugepaged used to use a late_initcall() to set min_free_kbytes (such that it occurred after the core initialization), however this was removed when the initialization of min_free_kbytes was integrated into the starting of the khugepaged thread. The fix here is simply to invoke the core initialization using a core_initcall() instead of module_init(), such that the previous initialization ordering is restored. I didn't restore the late_initcall() since start_stop_khugepaged() already sets min_free_kbytes via set_recommended_min_free_kbytes(). This was noticed when we had a number of page allocation failures when moving a workload to a kernel with this new initialization ordering. On an 8GB system this restores min_free_kbytes back to 67584 from 11365 when CONFIG_TRANSPARENT_HUGEPAGE=y is set and either CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y or CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y. Fixes: 79553da293d3 ("thp: cleanup khugepaged startup") Signed-off-by: Jason Baron <jbaron@akamai.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11proc: prevent accessing /proc/<PID>/environ until it's readyMathias Krause
commit 8148a73c9901a8794a50f950083c00ccf97d43b3 upstream. If /proc/<PID>/environ gets read before the envp[] array is fully set up in create_{aout,elf,elf_fdpic,flat}_tables(), we might end up trying to read more bytes than are actually written, as env_start will already be set but env_end will still be zero, making the range calculation underflow, allowing to read beyond the end of what has been written. Fix this as it is done for /proc/<PID>/cmdline by testing env_end for zero. It is, apparently, intentionally set last in create_*_tables(). This bug was found by the PaX size_overflow plugin that detected the arithmetic underflow of 'this_len = env_end - (env_start + src)' when env_end is still zero. The expected consequence is that userland trying to access /proc/<PID>/environ of a not yet fully set up process may get inconsistent data as we're in the middle of copying in the environment variables. Fixes: https://forums.grsecurity.net/viewtopic.php?f=3&t=4363 Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=116461 Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Emese Revfy <re.emese@gmail.com> Cc: Pax Team <pageexec@freemail.hu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Mateusz Guzik <mguzik@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jarod Wilson <jarod@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11Input: zforce_ts - fix dual touch recognitionKnut Wohlrab
commit 6984ab1ab35f422292b7781c65284038bcc0f6a6 upstream. A wrong decoding of the touch coordinate message causes a wrong touch ID. Touch ID for dual touch must be 0 or 1. According to the actual Neonode nine byte touch coordinate coding, the state is transported in the lower nibble and the touch ID in the higher nibble of payload byte five. Signed-off-by: Knut Wohlrab <Knut.Wohlrab@de.bosch.com> Signed-off-by: Oleksij Rempel <linux@rempel-privat.de> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11HID: Fix boot delay for Creative SB Omni Surround 5.1 with quirkNazar Mokrynskyi
commit 567a44ecb44eb2584ddb93e962cfb133ce77e0bb upstream. Needed for v2 of the device firmware, otherwise kernel will stuck for few seconds and throw "usb_submit_urb(ctrl) failed: -1" early on system boot. Signed-off-by: Nazar Mokrynskyi <nazar@mokrynskyi.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11HID: wacom: Add support for DTK-1651Ping Cheng
commit e1123fe975852cc0970b4e53ea65ca917e54c923 upstream. DTK-1651 is a display pen-only tablet Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11xen/evtchn: fix ring resize when binding new eventsJan Beulich
commit 27e0e6385377c4dc68a4ddaf1a35a2dfa951f3c5 upstream. The copying of ring data was wrong for two cases: For a full ring nothing got copied at all (as in that case the canonicalized producer and consumer indexes are identical). And in case one or both of the canonicalized (after the resize) indexes would point into the second half of the buffer, the copied data ended up in the wrong (free) part of the new buffer. In both cases uninitialized data would get passed back to the caller. Fix this by simply copying the old ring contents twice: Once to the low half of the new buffer, and a second time to the high half. This addresses the inability to boot a HVM guest with 64 or more vCPUs. This regression was caused by 8620015499101090 (xen/evtchn: dynamically grow pending event channel ring). Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11xen/balloon: Fix crash when ballooning on x86 32 bit PAERoss Lagerwall
commit dfd74a1edfaba5864276a2859190a8d242d18952 upstream. Commit 55b3da98a40dbb3776f7454daf0d95dde25c33d2 (xen/balloon: find non-conflicting regions to place hotplugged memory) caused a regression in 4.4. When ballooning on an x86 32 bit PAE system with close to 64 GiB of memory, the address returned by allocate_resource may be above 64 GiB. When using CONFIG_SPARSEMEM, this setup is limited to using physical addresses < 64 GiB. When adding memory at this address, it runs off the end of the mem_section array and causes a crash. Instead, fail the ballooning request. Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11xen: Fix page <-> pfn conversion on 32 bit systemsRoss Lagerwall
commit 60901df3aed230d4565dca003f11b6a95fbf30d9 upstream. Commit 1084b1988d22dc165c9dbbc2b0e057f9248ac4db (xen: Add Xen specific page definition) caused a regression in 4.4. The xen functions to convert between pages and pfns fail due to an overflow on systems where a physical address may not fit in an unsigned long (e.g. x86 32 bit PAE systems). Rework the conversion to avoid overflow. This should also result in simpler object code. This bug manifested itself as disk corruption with Linux 4.4 when using blkfront in a Xen HVM x86 32 bit guest with more than 4 GiB of memory. Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ARM: SoCFPGA: Fix secondary CPU startup in thumb2 kernelSascha Hauer
commit 5616f36713ea77f57ae908bf2fef641364403c9f upstream. The secondary CPU starts up in ARM mode. When the kernel is compiled in thumb2 mode we have to explicitly compile the secondary startup trampoline in ARM mode, otherwise the CPU will go to Nirvana. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reported-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Signed-off-by: Kevin Hilman <khilman@baylibre.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ARM: EXYNOS: Properly skip unitialized parent clock in power domain onKrzysztof Kozlowski
commit a0a966b83873f33778710a4fc59240244b0734a5 upstream. We want to skip reparenting a clock on turning on power domain, if we do not have the parent yet. The parent is obtained when turning the domain off. However due to a typo, the loop is continued on IS_ERR() of clock being reparented, not on the IS_ERR() of the parent. Theoretically this could lead to OOPS on first turn on of a power domain, if there was no turn off before. Practically that should never happen because all power domains are turned on by default (reset value, bootloader does not turn off them usually) so the first action will be always turn off. Fixes: 29e5eea06bc1 ("ARM: EXYNOS: Get current parent clock for power domain on/off") Reported-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11mm/zswap: provide unique zpool nameDan Streetman
commit 32a4e169039927bfb6ee9f0ccbbe3a8aaf13a4bc upstream. Instead of using "zswap" as the name for all zpools created, add an atomic counter and use "zswap%x" with the counter number for each zpool created, to provide a unique name for each new zpool. As zsmalloc, one of the zpool implementations, requires/expects a unique name for each pool created, zswap should provide a unique name. The zsmalloc pool creation does not fail if a new pool with a conflicting name is created, unless CONFIG_ZSMALLOC_STAT is enabled; in that case, zsmalloc pool creation fails with -ENOMEM. Then zswap will be unable to change its compressor parameter if its zpool is zsmalloc; it also will be unable to change its zpool parameter back to zsmalloc, if it has any existing old zpool using zsmalloc with page(s) in it. Attempts to change the parameters will result in failure to create the zpool. This changes zswap to provide a unique name for each zpool creation. Fixes: f1c54846ee45 ("zswap: dynamic pool creation") Signed-off-by: Dan Streetman <ddstreet@ieee.org> Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Dan Streetman <dan.streetman@canonical.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11mm, cma: prevent nr_isolated_* counters from going negativeHugh Dickins
commit 14af4a5e9b26ad251f81c174e8a43f3e179434a5 upstream. /proc/sys/vm/stat_refresh warns nr_isolated_anon and nr_isolated_file go increasingly negative under compaction: which would add delay when should be none, or no delay when should delay. The bug in compaction was due to a recent mmotm patch, but much older instance of the bug was also noticed in isolate_migratepages_range() which is used for CMA and gigantic hugepage allocations. The bug is caused by putback_movable_pages() in an error path decrementing the isolated counters without them being previously incremented by acct_isolated(). Fix isolate_migratepages_range() by removing the error-path putback, thus reaching acct_isolated() with migratepages still isolated, and leaving putback to caller like most other places do. Fixes: edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()") [vbabka@suse.cz: expanded the changelog] Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11Minimal fix-up of bad hashing behavior of hash_64()Linus Torvalds
commit 689de1d6ca95b3b5bd8ee446863bf81a4883ea25 upstream. This is a fairly minimal fixup to the horribly bad behavior of hash_64() with certain input patterns. In particular, because the multiplicative value used for the 64-bit hash was intentionally bit-sparse (so that the multiply could be done with shifts and adds on architectures without hardware multipliers), some bits did not get spread out very much. In particular, certain fairly common bit ranges in the input (roughly bits 12-20: commonly with the most information in them when you hash things like byte offsets in files or memory that have block factors that mean that the low bits are often zero) would not necessarily show up much in the result. There's a bigger patch-series brewing to fix up things more completely, but this is the fairly minimal fix for the 64-bit hashing problem. It simply picks a much better constant multiplier, spreading the bits out a lot better. NOTE! For 32-bit architectures, the bad old hash_64() remains the same for now, since 64-bit multiplies are expensive. The bigger hashing cleanup will replace the 32-bit case with something better. The new constants were picked by George Spelvin who wrote that bigger cleanup series. I just picked out the constants and part of the comment from that series. Cc: George Spelvin <linux@horizon.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11MD: make bio mergeableShaohua Li
commit 9c573de3283af007ea11c17bde1e4568d9417328 upstream. blk_queue_split marks bio unmergeable, which makes sense for normal bio. But if dispatching the bio to underlayer disk, the blk_queue_split checks are invalid, hence it's possible the bio becomes mergeable. In the reported bug, this bug causes trim against raid0 performance slash https://bugzilla.kernel.org/show_bug.cgi?id=117051 Reported-and-tested-by: Park Ju Hyung <qkrwngud825@gmail.com> Fixes: 6ac45aeb6bca(block: avoid to merge splitted bio) Cc: Ming Lei <ming.lei@canonical.com> Cc: Neil Brown <neilb@suse.de> Reviewed-by: Jens Axboe <axboe@fb.com> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11tracing: Don't display trigger file for events that can't be enabledChunyu Hu
commit 854145e0a8e9a05f7366d240e2f99d9c1ca6d6dd upstream. Currently register functions for events will be called through the 'reg' field of event class directly without any check when seting up triggers. Triggers for events that don't support register through debug fs (events under events/ftrace are for trace-cmd to read event format, and most of them don't have a register function except events/ftrace/functionx) can't be enabled at all, and an oops will be hit when setting up trigger for those events, so just not creating them is an easy way to avoid the oops. Link: http://lkml.kernel.org/r/1462275274-3911-1-git-send-email-chuhu@redhat.com Fixes: 85f2b08268c01 ("tracing: Add basic event trigger framework") Signed-off-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11mac80211: fix statistics leak if dev_alloc_name() failsJohannes Berg
commit e6436be21e77e3659b4ff7e357ab5a8342d132d2 upstream. In the case that dev_alloc_name() fails, e.g. because the name was given by the user and already exists, we need to clean up properly and free the per-CPU statistics. Fix that. Fixes: 5a490510ba5f ("mac80211: use per-CPU TX/RX statistics") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ath9k: ar5008_hw_cmn_spur_mitigate: add missing mask_m & mask_p initialisationOleksij Rempel
commit de478a61389cacafe94dc8b035081b681b878f9d upstream. by moving common code to ar5008_hw_cmn_spur_mitigate i forgot to move mask_m & mask_p initialisation. This coused a performance regression on ar9281. Fixes: f911085ffa88 ("ath9k: split ar5008_hw_spur_mitigate and reuse common code in ar9002_hw_spur_mitigate.") Reported-by: Gustav Frederiksen <lkml2017@openmailbox.org> Tested-by: Gustav Frederiksen <lkml2017@openmailbox.org> Signed-off-by: Oleksij Rempel <linux@rempel-privat.de> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
