commit 1d0a0b2f6df2bf2643fadc990eb143361eca6ada upstream.
ACPICA commit b60612373a4ef63b64a57c124576d7ddb6d8efb6
For physical addresses, since the address may exceed 32-bit address range
after calculation, we should use 0x%8.8X%8.8X instead of ACPI_PRINTF_UINT
and ACPI_FORMAT_UINT64() instead of
ACPI_FORMAT_NATIVE_UINT()/ACPI_FORMAT_TO_UINT().
This patch also removes above replaced macros as there are no users.
This is a preparation to switch acpi_physical_address to 64-bit on 32-bit
kernel builds.
Link: https://github.com/acpica/acpica/commit/b6061237
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Signed-off-by: George G. Davis <george_davis@mentor.com>
commit cc2080b0e5a7c6c33ef5e9ffccbc2b8f6f861393 upstream.
ACPICA commit 7f06739db43a85083a70371c14141008f20b2198
after calculation, we should use %8.8X%8.8X (see ACPI_FORMAT_UINT64()) to
convert the %p formats.
kernel builds.
Link: https://github.com/acpica/acpica/commit/7f06739d
ACPI_PHYSADDR_TO_PTR()/ACPI_PTR_TO_PHYSADDR().
commit 6d3fd3cc33d50e4c0d0c0bd172de02caaec3127c upstream.
ACPICA commit 154f6d074dd38d6ebc0467ad454454e6c5c9ecdf
There are code pieces converting pointers using "(acpi_physical_address) x"
or "ACPI_CAST_PTR (t, x)" formats, this patch cleans up them.
Known issues:
1. Cleanup of "(ACPI_PHYSICAL_ADDRRESS) x" for a table field
For the conversions around the table fields, it is better to fix it with
alignment also fixed. So this patch doesn't modify such code. There
should be no functional problem by leaving them unchanged.
Link: https://github.com/acpica/acpica/commit/154f6d07
commit f254e3c57b9d952e987502aefa0804c177dd2503 upstream.
ACPICA commit 7d9fd64397d7c38899d3dc497525f6e6b044e0e3
OSPMs like Linux expect an acpi_physical_address returning value from
acpi_find_root_pointer(). This triggers warnings if sizeof (acpi_size) doesn't
equal to sizeof (acpi_physical_address):
drivers/acpi/osl.c:275:3: warning: passing argument 1 of 'acpi_find_root_pointer' from incompatible pointer type [enabled by default]
In file included from include/acpi/acpi.h:64:0,
from include/linux/acpi.h:36,
from drivers/acpi/osl.c:41:
include/acpi/acpixf.h:433:1: note: expected 'acpi_size *' but argument is of type 'acpi_physical_address *'
This patch corrects acpi_find_root_pointer().
Link: https://github.com/acpica/acpica/commit/7d9fd643
commit 86cc05840a0da1afcb6b8151b53f3b606457c91b upstream.
commit bc26d4d06e337ade069f33d3f4377593b24e6e36 upstream.
A deadlock can be initiated by userspace via ioctl(SNDCTL_SEQ_OUTOFBAND)
on /dev/sequencer with TMR_ECHO midi event.
In this case the control flow is:
sound_ioctl()
-> case SND_DEV_SEQ:
case SND_DEV_SEQ2:
sequencer_ioctl()
-> case SNDCTL_SEQ_OUTOFBAND:
spin_lock_irqsave(&lock,flags);
play_event();
-> case EV_TIMING:
seq_timing_event()
-> case TMR_ECHO:
seq_copy_to_input()
-> spin_lock_irqsave(&lock,flags);
It seems that spin_lock_irqsave() around play_event() is not necessary,
because the only other call location in seq_startplay() makes the call
without acquiring spinlock.
So, the patch just removes spinlocks around play_event().
By the way, it removes unreachable code in seq_timing_event(),
since (seq_mode == SEQ_2) case is handled in the beginning.
Compile tested only.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: Willy Tarreau <w@1wt.eu>
commit c097877319ab61dd045b6497953b4e3df8f2bb44 upstream.
arm64 builds with GCC 5 have caused the __asmeq assertions in the PSCI
calling code to fire, so move the ARM PSCI calls out of line into their
own assembly file for consistency and to safeguard against the same
issue occuring with the 32-bit toolchain.
[will: brought into line with arm64 implementation]
Reported-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit bad4371d87d1d1ed1aecd9c9cc21c41ac3f289c8 upstream.
f9fd54f22e ("mmc: sh_mmcif: Use msecs_to_jiffies() for host->timeout")
changed the timeout value from 1000 jiffies to 1s. In the case where
HZ is 1000 the values are the same. However, for smaller HZ values the
timeout is now smaller, 1s instead of 10s in the case of HZ=100.
Since the timeout occurs in spite of a normal data transfer a timeout of
10s seems more appropriate. This restores the previous timeout in the
case where HZ=100 and results in an increase over the previous timeout
for larger values of HZ.
Fixes: f9fd54f22e ("mmc: sh_mmcif: Use msecs_to_jiffies() for host->timeout")
Signed-off-by: Takeshi Kihara <takeshi.kihara.df@renesas.com>
[horms: rewrote changelog to refer to HZ]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Yoshihiro Kaneko <ykaneko0929@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 184af16b09360d6273fd6160e6ff7f8e2482ef23 upstream.
The PM_RESTORE_PREPARE is not handled now in mmc_pm_notify(),
as result mmc_rescan() could be scheduled and executed at
late hibernation restore stages when MMC device is suspended
already - which, in turn, will lead to system crash on TI dra7-evm board:
WARNING: CPU: 0 PID: 3188 at drivers/bus/omap_l3_noc.c:148 l3_interrupt_handler+0x258/0x374()
44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Idle): Data Access in User mode during Functional access
Hence, add missed PM_RESTORE_PREPARE PM event in mmc_pm_notify().
Fixes: 4c2ef25fe0b8 (mmc: fix all hangs related to mmc/sd card...)
Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org>
commit 4e93b9a6abc0d028daf3c8a00cb77b679d8a4df4 upstream.
During kernel boot, it will try to read some logical sectors
of each block device node for the possible partition table.
But since RPMB partition is special and can not be accessed
by normal eMMC read / write CMDs, it will cause below error
messages during kernel boot:
mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
mmcblk0rpmb: error -110 transferring data, sector 0, nr 32, cmd response 0x900, card status 0xb00
mmcblk0rpmb: retrying using single block read
mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900
end_request: I/O error, dev mmcblk0rpmb, sector 0
Buffer I/O error on device mmcblk0rpmb, logical block 0
end_request: I/O error, dev mmcblk0rpmb, sector 8
Buffer I/O error on device mmcblk0rpmb, logical block 1
end_request: I/O error, dev mmcblk0rpmb, sector 16
Buffer I/O error on device mmcblk0rpmb, logical block 2
end_request: I/O error, dev mmcblk0rpmb, sector 24
Buffer I/O error on device mmcblk0rpmb, logical block 3
This patch will discard the access request in eMMC queue if
it is RPMB partition access request. By this way, it avoids
trigger above error messages.
Fixes: 090d25fe224c ("mmc: core: Expose access to RPMB partition")
Signed-off-by: Yunpeng Gao <yunpeng.gao@intel.com>
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Tested-by: Michael Shigorin <mike@altlinux.org>
commit c5272a28566b00cce79127ad382406e0a8650690 upstream.
Way back, when the world was a simpler place and there was no war, no
evil, and no kernel bugs, there was just a single pinctrl lock. That
was how the world was when (57291ce pinctrl: core device tree mapping
table parsing support) was written. In that case, there were
instances where the pinctrl mutex was already held when
pinctrl_register_map() was called, hence a "locked" parameter was
passed to the function to indicate that the mutex was already locked
(so we shouldn't lock it again).
A few years ago in (42fed7b pinctrl: move subsystem mutex to
pinctrl_dev struct), we switched to a separate pinctrl_maps_mutex.
...but (oops) we forgot to re-think about the whole "locked" parameter
for pinctrl_register_map(). Basically the "locked" parameter appears
to still refer to whether the bigger pinctrl_dev mutex is locked, but
we're using it to skip locks of our (now separate) pinctrl_maps_mutex.
That's kind of a bad thing(TM). Probably nobody noticed because most
of the calls to pinctrl_register_map happen at boot time and we've got
synchronous device probing. ...and even cases where we're
asynchronous don't end up actually hitting the race too often. ...but
after banging my head against the wall for a bug that reproduced 1 out
of 1000 reboots and lots of looking through kgdb, I finally noticed
this.
Anyway, we can now safely remove the "locked" parameter and go back to
a war-free, evil-free, and kernel-bug-free world.
Fixes: 42fed7ba44e4 ("pinctrl: move subsystem mutex to pinctrl_dev struct")
Signed-off-by: Doug Anderson <dianders@chromium.org>
commit d52cdfa4a0c6406bbfb33206341eaf1fb1555994 upstream.
MPEG 2/4 are only supported since UVD3.
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit a1b403da70e038ca6c6c6fe434d1d873546873a3 upstream.
Invalid messages can crash the hw otherwise.
commit 29c63fe22a17c64e54016040cd882481bd45ee5a upstream.
Invalid handles can crash the hw.
commit db12973cd581d4e79f4aadd0960948f268d15af7 upstream.
Fixing a memory leak with userptrs.
v2: clean up the loop, use an iterator instead
v3: remove unused variable
Signed-off-by: monk.liu <monk.liu@amd.com>
commit d73a824acc705571c0f47596326d7967fba9a1d9 upstream.
bug: https://bugzilla.kernel.org/show_bug.cgi?id=97701
Reported-by: Mikael Pettersson <mikpelinux@gmail.com>
Tested-by: Mikael Pettersson <mikpelinux@gmail.com>
commit 013ead48a843442e63b9426e3bd5df18ca5d054a upstream.
Hardware doesn't seem to work correctly, just block userspace in this case.
v2: add missing defines
Bugs: https://bugs.freedesktop.org/show_bug.cgi?id=85320
commit 79b066bd76d501cfe8328142153da301f5ca11d1 upstream.
This patch fixes a bug where sdma vm wasn't initialized when
an sdma queue was created in HWS mode.
This caused GPUVM faults to appear on dmesg and it is one of the
causes that SDMA queues are not working.
Signed-off-by: Xihan Zhang <xihan.zhang@amd.com>
Reviewed-by: Ben Goz <ben.goz@amd.comt>
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 1e5ec956a057585adaa1365615c82810b2f5356f upstream.
Sometimes we might unregister process that have queues, because we couldn't
preempt the queues. Until now we blocked it with BUG_ON but instead just
print it as debug.
Reviewed-by: Ben Goz <ben.goz@amd.com>
commit 9fcb1704d1d51b12e2f03c78bca013d0cbbb7c98 upstream.
The eDP port A register on PCH split platforms has a slightly different
register layout from the other ports, with bit 6 being either alternate
scrambler reset or reserved, depending on the generation. Our
misinterpretation of the bit as audio has lead to warning.
Fix this by not enabling audio on port A, since none of our platforms
support audio on port A anyway.
v2: DDI doesn't have audio on port A either (Sivakumar Thulasimani)
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=89958
Reported-and-tested-by: Chris Bainbridge <chris.bainbridge@gmail.com>
Reviewed-by: Sivakumar Thulasimani <sivakumar.thulasimani@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 3916e3fd81021fb795bfbdb17f375b6b3685bced upstream.
Single channel LVDS maxes out at 112 MHz. The 15" pre-retina models
shipped with 1440x900 (106 MHz) by default or 1680x1050 (119 MHz)
as a BTO option, both versions used dual channel LVDS even though
the smaller one would have fit into a single channel.
Notes:
Bug report showing that the MacBookPro8,2 with 1440x900 uses dual
channel LVDS (this lead to it being hardcoded in intel_lvds.c by
Daniel Vetter with commit 618563e3945b9d0864154bab3c607865b557cecc):
https://bugzilla.kernel.org/show_bug.cgi?id=42842
If i915.lvds_channel_mode=2 is missing even though the machine needs
it, every other vertical line is white and consequently, only the left
half of the screen is visible (verified by myself on a MacBookPro9,1).
Forum posting concerning a MacBookPro6,2 with 1440x900, author is
using i915.lvds_channel_mode=2 on the kernel command line, proving
that the machine uses dual channels:
https://bbs.archlinux.org/viewtopic.php?id=185770
Chi Mei N154C6-L04 with 1440x900 is a replacement panel for all
MacBook Pro "A1286" models, and that model number encompasses the
MacBookPro6,2 / 8,2 / 9,1. Page 17 of the panel's datasheet shows it's
driven with dual channel LVDS:
http://www.ebay.com/itm/-/400690878560
http://www.everymac.com/ultimate-mac-lookup/?search_keywords=A1286
http://www.taopanel.com/chimei/datasheet/N154C6-L04.pdf
Those three 15" models, MacBookPro6,2 / 8,2 / 9,1, are the only ones
with i915 graphics and dual channel LVDS, so that list should be
complete. And the 8,2 is already in intel_lvds.c.
Possible motivation to use dual channel LVDS even on the 1440x900
models: Reduce the number of different parts, i.e. use identical logic
boards and display cabling on both versions and the only differing
component is the panel.
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Jani Nikula <jani.nikula@intel.com>
[Jani: included notes in the commit message for posterity]
commit 6f317cfe42c9d8a7c9c1a327d2f1bcc517a3cd91 upstream.
Single channel LVDS maxes out at 112 MHz, anything above must be dual
channel. This avoids the need to specify i915.lvds_channel_mode=2 on
all 17" MacBook Pro models with i915 graphics since they had 1920x1200
(193 MHz), plus those 15" pre-retina models which had a resolution
of 1680x1050 (119 MHz) as a BTO option.
Source for 112 MHz limit of single channel LVDS is section 2.3 of:
https://01.org/linuxgraphics/sites/default/files/documentation/ivb_ihd_os_vol3_part4.pdf
v2: Avoid hardcoding 17" models by assuming dual channel LVDS if the
resolution necessitates it, suggested by Jani Nikula.
v3: Fix typo, thanks Joonas Lahtinen.
v4: Split commit in two, suggested by Ville Syrjälä.
Tested-by: Lukas Wunner <lukas@wunner.de>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
[Jani: included spec reference into the commit message]
commit fdb68e09bbb1c981f24608d7022c7d93cc47b326 upstream.
Since commit 844b03f27739135fe1fed2fef06da0ffc4c7a081 we make
sure that after vblank irq off, we return the last valid
(vblank count, vblank timestamp) pair to clients, e.g., during
modesets, which is good.
An overlooked side effect of that commit for kms drivers without
support for precise vblank timestamping is that at vblank irq
enable, when we update the vblank counter from the hw counter, we
can't update the corresponding vblank timestamp, so now we have a
totally mismatched timestamp for the new count to confuse clients.
Restore old client visible behaviour from before Linux 3.17, but
zero out the timestamp at vblank counter update (instead of disable
as in original implementation) if we can't generate a meaningful
timestamp immediately for the new vblank counter. This will fix
this regression, so callers know they need to retry again later
if they need a valid timestamp, but at the same time preserves
the improvements made in the commit mentioned above.
Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
Cc: <stable@vger.kernel.org> #v3.17+
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Daniel Vetter <daniel@ffwll.ch>
commit 11133db7a836b0cb411faa048f07a38e994d1382 upstream.
Fixes: c94a4ab7af3f ("ARM: ux500: Disable the MMCI gpio-regulator by default")
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
commit f9a8c3914ba85f19c3360b19612d77c47adb8942 upstream.
commit 53d2669844263fd5fdc70f0eb6a2eb8a21086d8e upstream.
The GPIO regulator for the SD-card isn't a ux500 SOC configuration, but
instead it's specific to the board. Move the definition of it, into the
board DTSs.
commit 19fc99d0c6ba7d9b65456496b5bb2169d5f74cd0 upstream.
In that case, emit_udiv() will be called with rn == ARM_R0 (r_scratch)
and loading rm first into ARM_R0 will result in jit_udiv() function
being called the same dividend and divisor. Fix that by loading rn
first into ARM_R1 and then rm into ARM_R0.
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
Fixes: aee636c4809f (bpf: do not use reciprocal divide)
Acked-by: Mircea Gherzan <mgherzan@gmail.com>
commit 102bcb6ed2d1c3ffcc7269afc957c2df11942085 upstream.
If we use a combination of VMODE and I2C4 for retention modes,
eventually the off idle power consumption will creep up by about
23mW, even during off mode with I2C4 always staying enabled.
Turns out this is because of erratum i531 "Extra Power Consumed
When Repeated Start Operation Mode Is Enabled on I2C Interface
Dedicated for Smart Reflex (I2C4)" as pointed out by Nishanth
Menon <nm@ti.com>.
Let's fix the issue by adding i2c_cfg_clear_mask for the bits
to clear when initializing the I2C4 adapter so we can clear
SREN bit that drives the I2C4 lines low otherwise when there
is no traffic.
Fixes: 3b8c4ebb7630 ("ARM: OMAP3: Fix idle mode signaling for
sys_clkreq and sys_off_mode")
Cc: Kevin Hilman <khilman@kernel.org>
Cc: Tero Kristo <t-kristo@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
commit 750e30d4076ae5e02ad13a376e96c95a2627742c upstream.
There is no crystal connected to the internal RTC on the Open Block
AX3. So let's disable it in order to prevent the kernel probing the
driver uselessly. Eventually this patches removes the following
warning message from the boot log:
"rtc-mv d0010300.rtc: internal RTC not ticking"
Acked-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit cfe8c59762244251fd9a5e281d48808095ff4090 upstream.
On imx23-olinuxino the LED turns on when level logic high is aplied to
GPIO2_1.
Fix the gpios property accordingly.
Fixes: b34aa1850244 ("ARM: dts: imx23-olinuxino: Remove unneeded "default-on"")
Reported-by: Stefan Wahren <stefan.wahren@i2se.com>
Tested-by: Stefan Wahren <stefan.wahren@i2se.com>
commit 0fdebe1a2f4d3a8fc03754022fabf8ba95e131a3 upstream.
The dr_mode of usb0 on imx233-olinuxino is left to default "otg".
Since the green LED (GPIO2_1) on imx233-olinuxino is connected to the
same pin as USB_OTG_ID it's possible to disable USB host by LED toggling:
echo 0 > /sys/class/leds/green/brightness
[ 1068.890000] ci_hdrc ci_hdrc.0: remove, state 1
[ 1068.890000] usb usb1: USB disconnect, device number 1
[ 1068.920000] usb 1-1: USB disconnect, device number 2
[ 1068.920000] usb 1-1.1: USB disconnect, device number 3
[ 1069.070000] usb 1-1.2: USB disconnect, device number 4
[ 1069.450000] ci_hdrc ci_hdrc.0: USB bus 1 deregistered
[ 1074.460000] ci_hdrc ci_hdrc.0: timeout waiting for 00000800 in 11
This patch fixes the issue by setting dr_mode to "host" in the dts file.
Reported-by: Harald Geyer <harald@ccbib.org>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
Fixes: b49312948285 ("ARM: dts: imx23-olinuxino: Add USB host support")
commit 4ada77e37a773168fea484899201e272ab44ba8b upstream.
Fix a typo in the TX DMA interrupt name for AUART4.
This patch makes AUART4 operational again.
Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma")
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
commit 7f8d49dcc66a3dd3a8fc3078330b8fb9e616ad3f upstream.
The fixed-regulator bindings require a separate property enable-active-high,
the standard gpio phandle property polarity setting is ignored.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Fixes: 4fe69a934b1f ("ARM: dts: Add Phytec pfla02 with i.MX6 DualLite/Solo")
commit f90d3f0d0a11fa77918fd5497cb616dd2faa8431 upstream.
The property '#pwm-cells' is currently missing. It is not possible to
use pwm4 without this property.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Fixes: 5658a68fb578 ("ARM i.MX25: Add devicetree")
commit 1819e3034ee26ffadc71880064ed8b8e7d74f52c upstream.
N900 audio recording needs that codec provides bias voltage for integrated
digital microphone and headset microphone depending which one is used.
Digital microphone uses 2 V bias and it comes from the codec A part. Codec
B part drives the headset microphone bias and that is set to 2.5 V.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
[Jarkko: Headset mic bias changed to 2 (2.5 V) as it was before commit
e2e8bfdf6157 ("ASoC: tlv320aic3x: Convert mic bias to a supply widget")]
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
commit 2a34c0872adf252f23a6fef2d051a169ac796cef upstream.
hctx->tags has to be set as NULL in case that it is to be unmapped
no matter if set->tags[hctx->queue_num] is NULL or not in blk_mq_map_swqueue()
because shared tags can be freed already from another request queue.
The same situation has to be considered during handling CPU online too.
Unmapped hw queue can be remapped after CPU topo is changed, so we need
to allocate tags for the hw queue in blk_mq_map_swqueue(). Then tags
allocation for hw queue can be removed in hctx cpu online notifier, and it
is reasonable to do that after mapping is updated.
Reported-by: Dongsu Park <dongsu.park@profitbricks.com>
Tested-by: Dongsu Park <dongsu.park@profitbricks.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit f054b56c951bf1731ba7314a4c7f1cc0b2977cc9 upstream.
Firstly during CPU hotplug, even queue is freezed, timeout
handler still may come and access hctx->tags, which may cause
use after free, so this patch deactivates timeout handler
inside CPU hotplug notifier.
Secondly, tags can be shared by more than one queues, so we
have to check if the hctx has been unmapped, otherwise
still use-after-free on tags can be triggered.
commit 6cd18e711dd8075da9d78cfc1239f912ff28968a upstream.
Because of the peculiar way that md devices are created (automatically
when the device node is opened), a new device can be created and
registered immediately after the
blk_unregister_region(disk_devt(disk), disk->minors);
call in del_gendisk().
Therefore it is important that all visible artifacts of the previous
device are removed before this call. In particular, the 'bdi'.
Since:
commit c4db59d31e39ea067c32163ac961e9c80198fd37
Author: Christoph Hellwig <hch@lst.de>
fs: don't reassign dirty inodes to default_backing_dev_info
moved the
device_unregister(bdi->dev);
call from bdi_unregister() to bdi_destroy() it has been quite easy to
lose a race and have a new (e.g.) "md127" be created after the
blk_unregister_region() call and before bdi_destroy() is ultimately
called by the final 'put_disk', which must come after del_gendisk().
The new device finds that the bdi name is already registered in sysfs
and complains
> [ 9627.630029] WARNING: CPU: 18 PID: 3330 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x5a/0x70()
> [ 9627.630032] sysfs: cannot create duplicate filename '/devices/virtual/bdi/9:127'
We can fix this by moving the bdi_destroy() call out of
blk_release_queue() (which can happen very late when a refcount
reaches zero) and into blk_cleanup_queue() - which happens exactly when the md
device driver calls it.
Then it is only necessary for md to call blk_cleanup_queue() before
del_gendisk(). As loop.c devices are also created on demand by
opening the device node, we make the same change there.
Fixes: c4db59d31e39ea067c32163ac961e9c80198fd37
Reported-by: Azat Khuzhin <a3at.mail@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit c0403ec0bb5a8c5b267fb7e16021bec0b17e4964 upstream.
This reverts Linux 4.1-rc1 commit 0618764cb25f6fa9fb31152995de42a8a0496475.
The problem which that commit attempts to fix actually lies in the
Freescale CAAM crypto driver not dm-crypt.
dm-crypt uses CRYPTO_TFM_REQ_MAY_BACKLOG. This means the the crypto
driver should internally backlog requests which arrive when the queue is
full and process them later. Until the crypto hw's queue becomes full,
the driver returns -EINPROGRESS. When the crypto hw's queue if full,
the driver returns -EBUSY, and if CRYPTO_TFM_REQ_MAY_BACKLOG is set, is
expected to backlog the request and process it when the hardware has
queue space. At the point when the driver takes the request from the
backlog and starts processing it, it calls the completion function with
a status of -EINPROGRESS. The completion function is called (for a
second time, in the case of backlogged requests) with a status/err of 0
when a request is done.
Crypto drivers for hardware without hardware queueing use the helpers,
crypto_init_queue(), crypto_enqueue_request(), crypto_dequeue_request()
and crypto_get_backlog() helpers to implement this behaviour correctly,
while others implement this behaviour without these helpers (ccp, for
example).
dm-crypt (before the patch that needs reverting) uses this API
correctly. It queues up as many requests as the hw queues will allow
(i.e. as long as it gets back -EINPROGRESS from the request function).
Then, when it sees at least one backlogged request (gets -EBUSY), it
waits till that backlogged request is handled (completion gets called
with -EINPROGRESS), and then continues. The references to
af_alg_wait_for_completion() and af_alg_complete() in that commit's
commit message are irrelevant because those functions only handle one
request at a time, unlink dm-crypt.
The problem is that the Freescale CAAM driver, which that commit
describes as having being tested with, fails to implement the
backlogging behaviour correctly. In cam_jr_enqueue(), if the hardware
queue is full, it simply returns -EBUSY without backlogging the request.
What the observed deadlock was is not described in the commit message
but it is obviously the wait_for_completion() in crypto_convert() where
dm-crypto would wait for the completion being called with -EINPROGRESS
in the case of backlogged requests. This completion will never be
completed due to the bug in the CAAM driver.
Commit 0618764cb25 incorrectly made dm-crypt wait for every request,
even when the driver/hardware queues are not full, which means that
dm-crypt will never see -EBUSY. This means that that commit will cause
a performance regression on all crypto drivers which implement the API
correctly.
Revert it. Correct backlog handling should be implemented in the CAAM
driver instead.
Cc'ing stable purely because commit 0618764cb25 did. If for some reason
a stable@ kernel did pick up commit 0618764cb25 it should get reverted.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
Reviewed-by: Horia Geanta <horia.geanta@freescale.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 8014bcc86ef112eab9ee1db312dba4e6b608cf89 upstream.
The variable for the 'permissive' module parameter used to be static
but was recently changed to be extern. This puts it in the kernel
global namespace if the driver is built-in, so its name should begin
with a prefix identifying the driver.
Fixes: af6fc858a35b ("xen-pciback: limit guest control of command register")
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
__startup_pirq()
commit 16e6bd5970c88a2ac018b84a5f1dd5c2ff1fdf2c upstream.
.. because bind_evtchn_to_cpu(evtchn, cpu) will map evtchn to
'info' and pass 'info' down to xen_evtchn_port_bind_to_cpu().
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Tested-by: Annie Li <annie.li@oracle.com>
commit b9d934f27c91b878c4b2e64299d6e419a4022f8d upstream.
After a resume the hypervisor/tools may change console event
channel number. We should re-query it.
commit 16f1cf3ba7303228372d3756677bf7d10e79cf9f upstream.
After a resume the hypervisor/tools may change xenbus event
commit 5cec98834989a014a9560b1841649eaca95cf00e upstream.
When a guest is resumed, the hypervisor may change event channel
assignments. If this happens and the guest uses 2-level events it
is possible for the interrupt to be claimed by wrong VCPU since
cpu_evtchn_mask bits may be stale. This can happen even though
evtchn_2l_bind_to_cpu() attempts to clear old bits: irq_info that
is passed in is not necessarily the original one (from pre-migration
times) but instead is freshly allocated during resume and so any
information about which CPU the channel was bound to is lost.
Thus we should clear the mask during resume.
We also need to make sure that bits for xenstore and console channels
are set when these two subsystems are resumed. While rebind_evtchn_irq()
(which is invoked for both of them on a resume) calls irq_set_affinity(),
the latter will in fact postpone setting affinity until handling the
interrupt. But because cpu_evtchn_mask will have bits for these two
cleared we won't be able to take the interrupt.
With that in mind, we need to bind those two channels explicitly in
rebind_evtchn_irq(). We will keep irq_set_affinity() so that we have a
pass through generic irq affinity code later, in case something needs
to be updated there as well.
(Also replace cpumask_of(0) with cpumask_of(info->cpu) in
rebind_evtchn_irq(): it should be set to zero in preceding
xen_irq_info_evtchn_setup().)
Reported-by: Annie Li <annie.li@oracle.com>
commit db7d4d7f40215843000cb9d441c9149fd42ea36b upstream.
Commit 13060b64b819 ("vfio: Add and use device request op for vfio
bus drivers") incorrectly makes use of an interruptible timeout.
When interrupted, the signal remains pending resulting in subsequent
timeouts occurring instantly. This makes the loop spin at a much
higher rate than intended.
Instead of making this completely non-interruptible, we can change
this into a sort of interruptible-once behavior and use the "once"
to log debug information. The driver API doesn't allow us to abort
and return an error code.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Fixes: 13060b64b819
commit 2a700d8edffdbfb8200332d96c3147e042b337f1 upstream.
Various formats had their byte ordering implemented incorrectly, and
the V4L2_PIX_FMT_UYVY is actually impossible to create, instead you
get V4L2_PIX_FMT_YVYU.
This was working before commit ad6ac452227b7cb93ac79beec092850d178740b1
("add new formats support for marvell-ccic driver"). That commit broke
the original format support and the OLPC XO-1 laptop showed wrong
colors ever since (if you are crazy enough to attempt to run the latest
kernel on it, like I did).
The email addresses of the authors of that patch are no longer valid,
so without a way to reach them and ask them about their test setup
I am going with what I can test on the OLPC laptop.
If this breaks something for someone on their non-OLPC setup, then
contact the linux-media mailinglist. My suspicion however is that
that commit went in untested.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 602498f9aa43d4951eece3fd6ad95a6d0a78d537 upstream.
If multiple soft offline events hit one free page/hugepage concurrently,
soft_offline_page() can handle the free page/hugepage multiple times,
which makes num_poisoned_pages counter increased more than once. This
patch fixes this wrong counting by checking TestSetPageHWPoison for normal
papes and by checking the return value of dequeue_hwpoisoned_huge_page()
for hugepages.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Dean Nelson <dnelson@redhat.com>
commit 464d1387acb94dc43ba772b35242345e3d2ead1b upstream.
mm/page-writeback.c has several places where 1 is added to the divisor
to prevent division by zero exceptions; however, if the original
divisor is equivalent to -1, adding 1 leads to division by zero.
There are three places where +1 is used for this purpose - one in
pos_ratio_polynom() and two in bdi_position_ratio(). The second one
in bdi_position_ratio() actually triggered div-by-zero oops on a
machine running a 3.10 kernel. The divisor is
x_intercept - bdi_setpoint + 1 == span + 1
span is confirmed to be (u32)-1. It isn't clear how it ended up that
but it could be from write bandwidth calculation underflow fixed by
c72efb658f7c ("writeback: fix possible underflow in write bandwidth
calculation").
At any rate, +1 isn't a proper protection against div-by-zero. This
patch converts all +1 protections to |1. Note that
bdi_update_dirty_ratelimit() was already using |1 before this patch.
commit f15133df088ecadd141ea1907f2c96df67c729f0 upstream.
path_openat() jumps to the wrong place after do_tmpfile() - it has
already done path_cleanup() (as part of path_lookupat() called by
do_tmpfile()), so doing that again can lead to double fput().
