2015-03-15Linux 4.0-rc4v4.0-rc4Linus Torvalds
2015-03-15Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fix from Dave Airlie: "An oops snuck in in an -rc3 patch, this fixes it" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: [PATCH] drm/mm: Fix support 4 GiB and larger ranges
2015-03-15Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clock framework fixes from Michael Turquette: "The clk fixes for 4.0-rc4 comprise three themes. First are the usual driver fixes for new regressions since v3.19. Second are fixes to the common clock divider type caused by recent changes to how we round clock rates. This affects many clock drivers that use this common code. Finally there are fixes for drivers that improperly compared struct clk pointers (drivers must not deref these pointers). While some of these drivers have done this for a long time, this did not cause a problem until we started generating unique struct clk pointers for every consumer. A new function, clk_is_match was introduced to get these drivers working again and they are fixed up to no longer deref the pointers themselves" * tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: ASoC: kirkwood: fix struct clk pointer comparing ASoC: fsl_spdif: fix struct clk pointer comparing ARM: imx: fix struct clk pointer comparing clk: introduce clk_is_match clk: don't export static symbol clk: divider: fix calculation of initial best divider when rounding to closest clk: divider: fix selection of divider when rounding to closest clk: divider: fix calculation of maximal parent rate for a given divider clk: divider: return real rate instead of divider value clk: qcom: fix platform_no_drv_owner.cocci warnings clk: qcom: fix platform_no_drv_owner.cocci warnings clk: qcom: Add PLL4 vote clock clk: qcom: lcc-msm8960: Fix PLL rate detection clk: qcom: Fix slimbus n and m val offsets clk: ti: Fix FAPLL parent enable bit handling
2015-03-16[PATCH] drm/mm: Fix support 4 GiB and larger rangesKrzysztof Kolasa
bad argument if(tmp)... in check_free_hole fix oops: kernel BUG at drivers/gpu/drm/drm_mm.c:305! [airlied: excellent, this was my task for today]. Signed-off-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Reviewed-by: Chris wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-03-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "This is a rather unpleasantly large set of bug fixes for arm-soc, Most of them because of cross-tree dependencies for Exynos where we should have figured out the right path to merge things before the merge window, and then the maintainer being unable to sort things out in time during a business trip. The other changes contained here are the usual collection: MAINTAINERS file updates - Gregory Clement is now a co-maintainer for the legacy Marvell EBU platforms - A MAINTAINERS entry for the Freescale Vybrid platform that was added last year - Matt Porter no longer works as a maintainer on Broadcom SoCs Build-time issues - A compile-time error for at91 - Several minor DT fixes on at91, imx, exynos, socfpga, and omap - The new digicolor platform was not correctly enabled at all Configuration issues - Two defconfig fix for regressions using USB on versatile express and on OMAP3 - Enabling all 8 CPUs on Allwinner/SUNxi - Enabling the new STiH410 platform to be usable Bug fixes in platform code - A missing barrier for socfpga - Fixing LPDDR1 self-refresh mode on at91 - Fixing RTC interrupt numbers on Exynos3250 - Fixing a cache-coherency issues in CPU power-down on Exynos5 - Multiple small OMAP power management fixes" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (69 commits) MAINTAINERS: Add myself as co-maintainer to the legacy support of the mvebu SoCs ARM: at91: pm_slowclock: fix the compilation error ARM: at91/dt: fix USB high-speed clock to select UTMI ARM: at91/dt: fix at91 udc compatible strings ARM: at91/dt: declare matrix node as a syscon device ARM: vexpress: update CONFIG_USB_ISP1760 option ARM: digicolor: add the machine directory to Makefile ARM: STi: Add STiH410 SoC support MAINTAINERS: add Freescale Vybrid SoC MAINTAINERS: Remove self as ARM mach-bcm co-maintainer ARM: imx6sl-evk: set swbst_reg as vbus's parent reg ARM: imx6qdl-sabresd: set swbst_reg as vbus's parent reg ARM: at91/dt: at91sam9261: fix clocks and clock-names in udc definition ARM: OMAP2+: Fix wl12xx on dm3730-evm with mainline u-boot ARM: OMAP: enable TWL4030_USB in omap2plus_defconfig ARM: dts: dra7x-evm: avoid possible contention while muxing on CAN lines ARM: dts: dra7x-evm: Don't use dcan1_rx.gpio1_15 in DCAN pinctrl ARM: dts: am43xx: fix SLEWCTRL_FAST pinctrl binding ARM: dts: am33xx: fix SLEWCTRL_FAST pinctrl binding ARM: dts: OMAP5: fix polling intervals for thermal zones ...
2015-03-15Merge tag 'irqchip-fixes-4.0' of git://git.infradead.org/users/jcooper/linuxLinus Torvalds
Pull irqchip fixes from Jason Cooper: "armada-370-xp: - Chained per-cpu interrupts gic{,-v3,v3-its}" - Various fixes for safer operation" * tag 'irqchip-fixes-4.0' of git://git.infradead.org/users/jcooper/linux: irqchip: gicv3-its: Support safe initialization irqchip: gicv3-its: Define macros for GITS_CTLR fields irqchip: gicv3-its: Add limitation to page order irqchip: gicv3-its: Use 64KB page as default granule irqchip: gicv3-its: Zero itt before handling to hardware irqchip: gic-v3: Fix out of bounds access to cpu_logical_map irqchip: gic: Fix unsafe locking reported by lockdep irqchip: gicv3-its: Fix unsafe locking reported by lockdep irqchip: gicv3-its: Iterate over PCI aliases to generate ITS configuration irqchip: gicv3-its: Allocate enough memory for the full range of DeviceID irqchip: gicv3-its: Fix ITS CPU init irqchip: armada-370-xp: Fix chained per-cpu interrupts
2015-03-15Merge branch 'irqchip/urgent-gic' into irqchip/urgentJason Cooper
2015-03-14Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Misc i915, vmwgfx and radeon fixes along with a fix for one of those recursive sleep mutex debug cases in the mst code" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/vmwgfx: Fix an issue with the device losing its irq line on module unload drm/vmwgfx: Correctly NULLify dma buffer pointer on failure drm/vmwgfx: Reorder device takedown somewhat drm/vmwgfx: Fix a couple of lock dependency violations drm/radeon: drop setting UPLL to sleep mode drm/radeon: fix wait to actually occur after the signaling callback drm/i915: Prevent TLB error on first execution on SNB drm/i915: Do both mt and gen6 style forcewake reset on ivb probe drm/i915: Make WAIT_IOCTL negative timeouts be indefinite again drm/i915: use in_interrupt() not in_irq() to check context drm/mst: fix recursive sleep warning on qlock drm: Don't assign fbs for universal cursor support to files
2015-03-14Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fix from James Bottomley: "This is a simple fix for a domain revalidation crash which has recently turned up in the libsas code (applies to mvsas, isc and aic94xx)" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: libsas: Fix Kernel Crash in smp_execute_task
2015-03-14Merge tag 'locks-v4.0-4' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking bugfix from Jeff Layton: "Just a small fix for a potential problem in one of the lease tracepoints" * tag 'locks-v4.0-4' of git://git.samba.org/jlayton/linux: locks: fix generic_delete_lease tracepoint to use victim pointer
2015-03-14Merge tag 'vfio-v4.0-rc4' of git://github.com/awilliam/linux-vfioLinus Torvalds
Pull VFIO fix from Alex Williamson: "Add missing break to avoid clobbering ioctl (Alexey Kardashevskiy)" * tag 'vfio-v4.0-rc4' of git://github.com/awilliam/linux-vfio: vfio-pci: Add missing break to enable VFIO_PCI_ERR_IRQ_INDEX
2015-03-14Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - add TLB invalidation for page table tear-down which was missed when support for CONFIG_HAVE_RCU_TABLE_FREE was added (assuming page table freeing was always deferred) - use UEFI for system and reset poweroff if available - fix asm label placement in relation to the alignment statement * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: put __boot_cpu_mode label after alignment instead of before efi/arm64: use UEFI for system reset and poweroff arm64: Invalidate the TLB corresponding to intermediate page table levels
2015-03-14Merge tag 'linux-kselftest-4.0-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull Kselftest fix from Shuah Khan: "selftests/exec: Check if the syscall exists and bail if not" * tag 'linux-kselftest-4.0-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests/exec: Check if the syscall exists and bail if not
2015-03-14locks: fix generic_delete_lease tracepoint to use victim pointerJeff Layton
It's possible that "fl" won't point at a valid lock at this point, so use "victim" instead which is either a valid lock or NULL. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
2015-03-14arm64: put __boot_cpu_mode label after alignment instead of beforeArd Biesheuvel
Another one for the big head.S spring cleaning: the label should be after the .align or it may point to the padding. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-03-14efi/arm64: use UEFI for system reset and poweroffArd Biesheuvel
If UEFI Runtime Services are available, they are preferred over direct PSCI calls or other methods to reset the system. For the reset case, we need to hook into machine_restart(), as the arm_pm_restart function pointer may be overwritten by modules. Tested-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-03-14arm64: Invalidate the TLB corresponding to intermediate page table levelsCatalin Marinas
The ARM architecture allows the caching of intermediate page table levels and page table freeing requires a sequence like: pmd_clear() TLB invalidation pte page freeing With commit 5e5f6dc10546 (arm64: mm: enable HAVE_RCU_TABLE_FREE logic), the page table freeing batching was moved from tlb_remove_page() to tlb_remove_table(). The former takes care of TLB invalidation as this is also shared with pte clearing and page cache page freeing. The latter, however, does not invalidate the TLBs for intermediate page table levels as it probably relies on the architecture code to do it if required. When the mm->mm_users < 2, tlb_remove_table() does not do any batching and page table pages are freed before tlb_finish_mmu() which performs the actual TLB invalidation. This patch introduces __tlb_flush_pgtable() for arm64 and calls it from the {pte,pmd,pud}_free_tlb() directly without relying on deferred page table freeing. Fixes: 5e5f6dc10546 arm64: mm: enable HAVE_RCU_TABLE_FREE logic Reported-by: Jon Masters <jcm@redhat.com> Tested-by: Jon Masters <jcm@redhat.com> Tested-by: Steve Capper <steve.capper@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-03-13Merge tag 'pm+acpi-4.0-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "Just two fixes, one for an ACPI LPSS driver issue introduced during the 3.17 cycle and one revert of a recent commit that sort of broke the cpupower tool. Specifics: - Fix an ACPI LPSS (Low-Power Subsystem) driver issue causing the 8250_dw driver to confuse an LPSS clock with another one it is supposed to handle due to the lack of identification allowing it to tell those clocks apart (Heikki Krogerus). - Revert a recent commit that was supposed to improve the usability of the cpupower tool, but clearly did the opposite (Josh Boyer)" * tag 'pm+acpi-4.0-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: Revert "cpupower Makefile change to help run the tool without 'make install'" ACPI / LPSS: provide con_id for the clkdev
2015-03-13MAINTAINERS: Add myself as co-maintainer to the legacy support of the mvebu SoCsGregory CLEMENT
I will also take care of the legacy support(not fully converted to DT) of the mvebu SoCs. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-03-13Merge branch 'pm-tools'Rafael J. Wysocki
* pm-tools: Revert "cpupower Makefile change to help run the tool without 'make install'"
2015-03-13Merge tag 'stable/for-linus-4.0-rc3-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen bug fixes from David Vrabel: - fix a PV regression in 3.19. - fix a dom0 crash on hosts with large numbers of PIRQs. - prevent pcifront from disabling memory or I/O port access, which may trigger host crashes. * tag 'stable/for-linus-4.0-rc3-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen-pciback: limit guest control of command register xen/events: avoid NULL pointer dereference in dom0 on large machines xen: Remove trailing semicolon from xenbus_register_frontend() definition x86/xen: correct bug in p2m list initialization
2015-03-13Merge tag 'sound-4.0-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This is a round of HD-audio fixes: there are a long-standing regression fix and a few more device/codec-specific quirks. In addition, a couple of FireWire regression fixes, a USB-audio quirk for Roland UA-22 and a sanity check in API for user-defined control elements" * tag 'sound-4.0-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Don't access stereo amps for mono channel widgets ALSA: hda - Add workaround for MacBook Air 5,2 built-in mic ALSA: hda - Set single_adc_amp flag for CS420x codecs ALSA: snd-usb: add quirks for Roland UA-22 ALSA: control: Add sanity checks for user ctl id name string ALSA: hda - Fix built-in mic on Compaq Presario CQ60 ALSA: firewire-lib: leave unit reference counting completely Revert "ALSA: dice: fix wrong offsets for Dice interface" ALSA: hda - Fix regression of HD-audio controller fallback modes
2015-03-13Merge tag 'devicetree-fixes-for-4.0' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: - fix for stdout-path option parsing with added unittest - fix for stdout-path interaction with earlycon - several DT unittest fixes - fix Sparc allmodconfig build error on of_platform_register_reconfig_notifier - several DT overlay kconfig and build warning fixes - several DT binding documentation updates * tag 'devicetree-fixes-for-4.0' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: of/platform: Fix sparc:allmodconfig build of: unittest: Add options string testcase variants of: fix handling of '/' in options for of_find_node_by_path() of/unittest: Fix the wrong expected value in of_selftest_property_string of/unittest: remove the duplicate of_changeset_init dt: submitting-patches: clarify that DT maintainers are to be cced on bindings of: unittest: fix I2C dependency of/overlay: Remove unused variable Documentation: DT: Renamed of-serial.txt to 8250.txt of: Fix premature bootconsole disable with 'stdout-path' serial: add device tree binding documentation for ETRAX FS UART of/overlay: Directly include idr.h of: Drop superfluous dependance for OF_OVERLAY of: Add vendor prefix for Arasan of: Add prompt for OF_OVERLAY config
2015-03-13Merge branch 'gadget' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfsLinus Torvalds
Pull gadgetfs fixes from Al Viro: "Assorted fixes around AIO on gadgetfs: leaks, use-after-free, troubles caused by ->f_op flipping" * 'gadget' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: gadgetfs: really get rid of switching ->f_op gadgetfs: get rid of flipping ->f_op in ep_config() gadget: switch ep_io_operations to ->read_iter/->write_iter gadgetfs: use-after-free in ->aio_read() gadget/function/f_fs.c: switch to ->{read,write}_iter() gadget/function/f_fs.c: use put iov_iter into io_data gadget/function/f_fs.c: close leaks move iov_iter.c from mm/ to lib/ new helper: dup_iter()
2015-03-13of/platform: Fix sparc:allmodconfig buildGuenter Roeck
sparc:allmodconfig fails to build with: drivers/built-in.o: In function `platform_bus_init': (.init.text+0x3684): undefined reference to `of_platform_register_reconfig_notifier' of_platform_register_reconfig_notifier is only declared if both OF_ADDRESS and OF_DYNAMIC are configured. Yet, the include file only declares a dummy function if OF_DYNAMIC is not configured. The sparc architecture does not configure OF_ADDRESS, but does configure OF_DYNAMIC, causing above error. Fixes: 801d728c10db ("of/reconfig: Add OF_DYNAMIC notifier for platform_bus_type") Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Rob Herring <robh@kernel.org>
2015-03-13ALSA: hda - Don't access stereo amps for mono channel widgetsTakashi Iwai
The current HDA generic parser initializes / modifies the amp values always in stereo, but this seems causing the problem on ALC3229 codec that has a few mono channel widgets: namely, these mono widgets react to actions for both channels equally. In the driver code, we do care the mono channel and create a control only for the left channel (as defined in HD-audio spec) for such a node. When the control is updated, only the left channel value is changed. However, in the resume, the right channel value is also restored from the initial value we took as stereo, and this overwrites the left channel value. This ends up being the silent output as the right channel has been never touched and remains muted. This patch covers the places where unconditional stereo amp accesses are done and converts to the conditional accesses. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94581 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-03-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "13 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: memcg: disable hierarchy support if bound to the legacy cgroup hierarchy mm: reorder can_do_mlock to fix audit denial kasan, module: move MODULE_ALIGN macro into <linux/moduleloader.h> kasan, module, vmalloc: rework shadow allocation for modules fanotify: fix event filtering with FAN_ONDIR set mm/nommu.c: export symbol max_mapnr arch/c6x/include/asm/pgtable.h: define dummy pgprot_writecombine for !MMU nilfs2: fix deadlock of segment constructor during recovery mm: cma: fix CMA aligned offset calculation mm, hugetlb: close race when setting PageTail for gigantic pages mm, oom: do not fail __GFP_NOFAIL allocation if oom killer is disabled drivers/rtc/rtc-s3c.c: add .needs_src_clk to s3c6410 RTC data ocfs2: make append_dio an incompat feature
2015-03-12memcg: disable hierarchy support if bound to the legacy cgroup hierarchyVladimir Davydov
If the memory cgroup controller is initially mounted in the scope of the default cgroup hierarchy and then remounted to a legacy hierarchy, it will still have hierarchy support enabled, which is incorrect. We should disable hierarchy support if bound to the legacy cgroup hierarchy. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: reorder can_do_mlock to fix audit denialJeff Vander Stoep
A userspace call to mmap(MAP_LOCKED) may result in the successful locking of memory while also producing a confusing audit log denial. can_do_mlock checks capable and rlimit. If either of these return positive can_do_mlock returns true. The capable check leads to an LSM hook used by apparmour and selinux which produce the audit denial. Reordering so rlimit is checked first eliminates the denial on success, only recording a denial when the lock is unsuccessful as a result of the denial. Signed-off-by: Jeff Vander Stoep <jeffv@google.com> Acked-by: Nick Kralevich <nnk@google.com> Cc: Jeff Vander Stoep <jeffv@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Paul Cassella <cassella@cray.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12kasan, module: move MODULE_ALIGN macro into <linux/moduleloader.h>Andrey Ryabinin
include/linux/moduleloader.h is more suitable place for this macro. Also change alignment to PAGE_SIZE for CONFIG_KASAN=n as such alignment already assumed in several places. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12kasan, module, vmalloc: rework shadow allocation for modulesAndrey Ryabinin
Current approach in handling shadow memory for modules is broken. Shadow memory could be freed only after memory shadow corresponds it is no longer used. vfree() called from interrupt context could use memory its freeing to store 'struct llist_node' in it: void vfree(const void *addr) { ... if (unlikely(in_interrupt())) { struct vfree_deferred *p = this_cpu_ptr(&vfree_deferred); if (llist_add((struct llist_node *)addr, &p->list)) schedule_work(&p->wq); Later this list node used in free_work() which actually frees memory. Currently module_memfree() called in interrupt context will free shadow before freeing module's memory which could provoke kernel crash. So shadow memory should be freed after module's memory. However, such deallocation order could race with kasan_module_alloc() in module_alloc(). Free shadow right before releasing vm area. At this point vfree()'d memory is not used anymore and yet not available for other allocations. New VM_KASAN flag used to indicate that vm area has dynamically allocated shadow memory so kasan frees shadow only if it was previously allocated. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12fanotify: fix event filtering with FAN_ONDIR setSuzuki K. Poulose
With FAN_ONDIR set, the user can end up getting events, which it hasn't marked. This was revealed with fanotify04 testcase failure on Linux-4.0-rc1, and is a regression from 3.19, revealed with 66ba93c0d7fe6 ("fanotify: don't set FAN_ONDIR implicitly on a marks ignored mask"). # /opt/ltp/testcases/bin/fanotify04 [ ... ] fanotify04 7 TPASS : event generated properly for type 100000 fanotify04 8 TFAIL : fanotify04.c:147: got unexpected event 30 fanotify04 9 TPASS : No event as expected The testcase sets the adds the following marks : FAN_OPEN | FAN_ONDIR for a fanotify on a dir. Then does an open(), followed by close() of the directory and expects to see an event FAN_OPEN(0x20). However, the fanotify returns (FAN_OPEN|FAN_CLOSE_NOWRITE(0x10)). This happens due to the flaw in the check for event_mask in fanotify_should_send_event() which does: if (event_mask & marks_mask & ~marks_ignored_mask) return true; where, event_mask == (FAN_ONDIR | FAN_CLOSE_NOWRITE), marks_mask == (FAN_ONDIR | FAN_OPEN), marks_ignored_mask == 0 Fix this by masking the outgoing events to the user, as we already take care of FAN_ONDIR and FAN_EVENT_ON_CHILD. Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Tested-by: Lino Sanfilippo <LinoSanfilippo@gmx.de> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Eric Paris <eparis@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm/nommu.c: export symbol max_mapnrgchen gchen
Several modules may need max_mapnr, so export, the related error with allmodconfig under c6x: MODPOST 3327 modules ERROR: "max_mapnr" [fs/pstore/ramoops.ko] undefined! ERROR: "max_mapnr" [drivers/media/v4l2-core/videobuf2-dma-contig.ko] undefined! Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12arch/c6x/include/asm/pgtable.h: define dummy pgprot_writecombine for !MMUChen Gang
When !MMU, asm-generic will not define default pgprot_writecombine, so c6x needs to define it by itself. The related error: CC [M] fs/pstore/ram_core.o fs/pstore/ram_core.c: In function 'persistent_ram_vmap': fs/pstore/ram_core.c:399:10: error: implicit declaration of function 'pgprot_writecombine' [-Werror=implicit-function-declaration] prot = pgprot_writecombine(PAGE_KERNEL); ^ fs/pstore/ram_core.c:399:8: error: incompatible types when assigning to type 'pgprot_t {aka struct <anonymous>}' from type 'int' prot = pgprot_writecombine(PAGE_KERNEL); ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12nilfs2: fix deadlock of segment constructor during recoveryRyusuke Konishi
According to a report from Yuxuan Shui, nilfs2 in kernel 3.19 got stuck during recovery at mount time. The code path that caused the deadlock was as follows: nilfs_fill_super() load_nilfs() nilfs_salvage_orphan_logs() * Do roll-forwarding, attach segment constructor for recovery, and kick it. nilfs_segctor_thread() nilfs_segctor_thread_construct() * A lock is held with nilfs_transaction_lock() nilfs_segctor_do_construct() nilfs_segctor_drop_written_files() iput() iput_final() write_inode_now() writeback_single_inode() __writeback_single_inode() do_writepages() nilfs_writepage() nilfs_construct_dsync_segment() nilfs_transaction_lock() --> deadlock This can happen if commit 7ef3ff2fea8b ("nilfs2: fix deadlock of segment constructor over I_SYNC flag") is applied and roll-forward recovery was performed at mount time. The roll-forward recovery can happen if datasync write is done and the file system crashes immediately after that. For instance, we can reproduce the issue with the following steps: < nilfs2 is mounted on /nilfs (device: /dev/sdb1) > # dd if=/dev/zero of=/nilfs/test bs=4k count=1 && sync # dd if=/dev/zero of=/nilfs/test conv=notrunc oflag=dsync bs=4k count=1 && reboot -nfh < the system will immediately reboot > # mount -t nilfs2 /dev/sdb1 /nilfs The deadlock occurs because iput() can run segment constructor through writeback_single_inode() if MS_ACTIVE flag is not set on sb->s_flags. The above commit changed segment constructor so that it calls iput() asynchronously for inodes with i_nlink == 0, but that change was imperfect. This fixes the another deadlock by deferring iput() in segment constructor even for the case that mount is not finished, that is, for the case that MS_ACTIVE flag is not set. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reported-by: Yuxuan Shui <yshuiv7@gmail.com> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: cma: fix CMA aligned offset calculationDanesh Petigara
The CMA aligned offset calculation is incorrect for non-zero order_per_bit values. For example, if cma->order_per_bit=1, cma->base_pfn= 0x2f800000 and align_order=12, the function returns a value of 0x17c00 instead of 0x400. This patch fixes the CMA aligned offset calculation. The previous calculation was wrong and would return too-large values for the offset, so that when cma_alloc looks for free pages in the bitmap with the requested alignment > order_per_bit, it starts too far into the bitmap and so CMA allocations will fail despite there actually being plenty of free pages remaining. It will also probably have the wrong alignment. With this change, we will get the correct offset into the bitmap. One affected user is powerpc KVM, which has kvm_cma->order_per_bit set to KVM_CMA_CHUNK_ORDER - PAGE_SHIFT, or 18 - 12 = 6. [gregory.0xf0@gmail.com: changelog additions] Signed-off-by: Danesh Petigara <dpetigara@broadcom.com> Reviewed-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm, hugetlb: close race when setting PageTail for gigantic pagesDavid Rientjes
Now that gigantic pages are dynamically allocatable, care must be taken to ensure that p->first_page is valid before setting PageTail. If this isn't done, then it is possible to race and have compound_head() return NULL. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm, oom: do not fail __GFP_NOFAIL allocation if oom killer is disabledMichal Hocko
Tetsuo Handa has pointed out that __GFP_NOFAIL allocations might fail after OOM killer is disabled if the allocation is performed by a kernel thread. This behavior was introduced from the very beginning by 7f33d49a2ed5 ("mm, PM/Freezer: Disable OOM killer when tasks are frozen"). This means that the basic contract for the allocation request is broken and the context requesting such an allocation might blow up unexpectedly. There are basically two ways forward. 1) move oom_killer_disable after kernel threads are frozen. This has a risk that the OOM victim wouldn't be able to finish because it would depend on an already frozen kernel thread. This would be really tricky to debug. 2) do not fail GFP_NOFAIL allocation no matter what and risk a potential Freezable kernel threads will loop and fail the suspend. Incidental allocations after kernel threads are frozen will at least dump a warning - if we are lucky and the serial console is still active of course... This patch implements the later option because it is safer. We would see warning rather than allocation failures for the kernel threads which would blow up otherwise and have a higher chances to identify __GFP_NOFAIL users from deeper pm code. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@gooogle.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12drivers/rtc/rtc-s3c.c: add .needs_src_clk to s3c6410 RTC dataJavier Martinez Canillas
Commit df9e26d093d3 ("rtc: s3c: add support for RTC of Exynos3250 SoC") added an "rtc_src" DT property to specify the clock used as a source to the S3C real-time clock. Not all SoCs needs this so commit eaf3a659086e ("drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock") changed to check the struct s3c_rtc_data .needs_src_clk to conditionally grab the clock. But that commit didn't update the data for each IP version so the RTC broke on the boards that needs a source clock. This is the case of at least Exynos5250 and Exynos5440 which uses the s3c6410 RTC IP block. This commit fixes the S3C rtc on the Exynos5250 Snow and Exynos5420 Peach Pit and Pi Chromebooks. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Chanwoo Choi <cw00.choi@samsung.com> Cc: Doug Anderson <dianders@chromium.org> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Cc: Tyler Baker <tyler.baker@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12ocfs2: make append_dio an incompat featureMark Fasheh
It turns out that making this feature ro_compat isn't quite enough to prevent accidental corruption on mount from older kernels. Ocfs2 (like other file systems) will process orphaned inodes even when the user mounts in 'ro' mode. So for the case of a filesystem not knowing the append_dio feature, mounting the filesystem could result in orphaned-for-dio files being deleted, which we clearly don't want. So instead, turn this into an incompat flag. Btw, this is kind of my fault - initially I asked that we add a flag to cover the feature and even suggested that we use an ro flag. It wasn't until I was looking through our commits for v4.0-rc1 that I realized we actually want this to be incompat. Signed-off-by: Mark Fasheh <mfasheh@suse.de> Cc: Joseph Qi <joseph.qi@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-13Merge branch 'drm-fixes-4.0' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes Some additional radeon fixes for 4.0 * 'drm-fixes-4.0' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: drop setting UPLL to sleep mode drm/radeon: fix wait to actually occur after the signaling callback
2015-03-13Merge branch 'vmwgfx-fixes-4.0' of ↵Dave Airlie
git://people.freedesktop.org/~thomash/linux into drm-fixes A couple of fixes for vmwgfx. * 'vmwgfx-fixes-4.0' of git://people.freedesktop.org/~thomash/linux: drm/vmwgfx: Fix an issue with the device losing its irq line on module unload drm/vmwgfx: Correctly NULLify dma buffer pointer on failure drm/vmwgfx: Reorder device takedown somewhat drm/vmwgfx: Fix a couple of lock dependency violations
2015-03-13Merge tag 'drm-intel-fixes-2015-03-12' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes More i915 fixes, three out of four are fixes to old bugs, cc: stable. * tag 'drm-intel-fixes-2015-03-12' of git://anongit.freedesktop.org/drm-intel: drm/i915: Prevent TLB error on first execution on SNB drm/i915: Do both mt and gen6 style forcewake reset on ivb probe drm/i915: Make WAIT_IOCTL negative timeouts be indefinite again drm/i915: use in_interrupt() not in_irq() to check context
2015-03-12mm: thp: Return the correct value for change_huge_pmdMel Gorman
The wrong value is being returned by change_huge_pmd since commit 10c1045f28e8 ("mm: numa: avoid unnecessary TLB flushes when setting NUMA hinting entries") which allows a fallthrough that tries to adjust non-existent PTEs. This patch corrects it. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12ALSA: hda - Add workaround for MacBook Air 5,2 built-in micTakashi Iwai
MacBook Air 5,2 has the same problem as MacBook Pro 8,1 where the built-in mic records only the right channel. Apply the same workaround as MBP8,1 to spread the mono channel via a Cirrus codec vendor-specific COEF setup. Reported-and-tested-by: Vasil Zlatanov <vasil.zlatanov@gmail.com> Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-03-12ALSA: hda - Set single_adc_amp flag for CS420x codecsTakashi Iwai
CS420x codecs seem to deal only the single amps of ADC nodes even though the nodes receive multiple inputs. This leads to the inconsistent amp value after S3/S4 resume, for example. The fix is just to set codec->single_adc_amp flag. Then the driver handles these ADC amps as if single connections. Reported-and-tested-by: Vasil Zlatanov <vasil.zlatanov@gmail.com> Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-03-12Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fix from Wolfram Sang: "An important bugfix for the I2C subsystem core" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: Revert "i2c: core: Dispose OF IRQ mapping at client removal time"
2015-03-12Merge tag 'pci-v4.0-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "Here are a couple updates for v4.0. One fixes a config accessor problem on APM X-Gene that we introduced when switching to generic config accessors, and the other fixes an older read-past-end-of-buffer problem in sysfs. APM X-Gene host bridge driver - Add register offset to config space base address (Feng Kan) Miscellaneous - Don't read past the end of sysfs "driver_override" buffer (Sasha Levin)" * tag 'pci-v4.0-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: xgene: Add register offset to config space base address PCI: Don't read past the end of sysfs "driver_override" buffer
2015-03-12Merge tag 'microblaze-4.0-rc4' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull arch/microblaze fixes from Michal Simek: "Fix syscall error recovery. Two patches - one is just preparation patch for the second which is fixing the problem with syscalls" * tag 'microblaze-4.0-rc4' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Fix syscall error recovery for invalid syscall IDs microblaze: Coding style cleanup
2015-03-12Merge tag 'nios2-fix-4.0-rc4' of git://git.rocketboards.org/linux-socfpga-nextLinus Torvalds
Pull arch/nios2 fix from Ley Foon Tan: "Remove pt_regs from user header and use generic ucontext.h" * tag 'nios2-fix-4.0-rc4' of git://git.rocketboards.org/linux-socfpga-next: nios2: update pt_regs
