2013-05-24Linux 3.9.4v3.9.4Greg Kroah-Hartman
2013-05-24x86, vm86: fix VM86 syscalls: use SYSCALL_DEFINEx(...)Alexander van Heukelum
commit 5522ddb3fc0dfd4a503c8278eafd88c9f2d3fada upstream. Commit 49cb25e9290 x86: 'get rid of pt_regs argument in vm86/vm86old' got rid of the pt_regs stub for sys_vm86old and sys_vm86. The functions were, however, not changed to use the calling convention for syscalls. [AV: killed asmlinkage_protect() - it's done automatically now] Backported-by: Satoru Takeuchi <satoru.takeuchi@gmail.com> Reported-and-tested-by: Hans de Bruin <jmdebruin@xmsnet.nl> Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: Multiple NTB client fixJon Mason
commit 8b19d450ad188d402a183ff4a4d40f31c3916fbf upstream. Fix issue with adding multiple ntb client devices to the ntb virtual bus. Previously, multiple devices would be added with the same name, resulting in crashes. To get around this issue, add a unique number to the device when it is added. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24ntb_netdev: remove from list on exitJon Mason
commit 904435cf76a9bdd5eb41b1c4e049d5a64f3a8400 upstream. The ntb_netdev device is not removed from the global list of devices upon device removal. If the device is re-added, the removal code would find the first instance and try to remove an already removed device. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: memcpy lockup workaroundJon Mason
commit c336acd3331dcc191a97dbc66a557d47741657c7 upstream. The system will appear to lockup for long periods of time due to the NTB driver spending too much time in memcpy. Avoid this by reducing the number of packets that can be serviced on a given interrupt. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: Correctly handle receive buffers of the minimal sizeJon Mason
commit c9d534c8cbaedbb522a1d2cb037c6c394f610317 upstream. The ring logic of the NTB receive buffer/transmit memory window requires there to be at least 2 payload sized allotments. For the minimal size case, split the buffer into two and set the transport_mtu to the appropriate size. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: reset tx_index on link toggleJon Mason
commit 90f9e934647e652a69396e18c779215a493271cf upstream. If the NTB link toggles, the driver could stop receiving due to the tx_index not being set to 0 on the transmitting size on a link-up event. This is due to the driver expecting the incoming data to start at the beginning of the receive buffer and not at a random place. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: Link toggle memory leakJon Mason
commit b77b2637b39ecc380bb08992380d7d48452b0872 upstream. Each link-up will allocate a new NTB receive buffer when the NTB properties are negotiated with the remote system. These allocations did not check for existing buffers and thus did not free them. Now, the driver will check for an existing buffer and free it if not of the correct size, before trying to alloc a new one. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: Handle 64bit BAR sizesJon Mason
commit 113fc505b83b2d16e820ca74fa07f99a34877b1d upstream. 64bit BAR sizes are permissible with an NTB device. To support them various modifications and clean-ups were required, most significantly using 2 32bit scratch pad registers for each BAR. Also, modify the driver to allow more than 2 Memory Windows. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: fix pointer math issuesDan Carpenter
commit cc0f868d8adef7bdc12cda132654870086d766bc upstream. ->remote_rx_info and ->rx_info are struct ntb_rx_info pointers. If we add sizeof(struct ntb_rx_info) then it goes too far. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24ntb: off by one sanity checksDan Carpenter
commit ad3e2751e7c546ae678be1f8d86e898506b42cef upstream. These tests are off by one. If "mw" is equal to NTB_NUM_MW then we would go beyond the end of the ndev->mw[] array. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24NTB: variable dereferenced before checkJon Mason
commit 186f27ff9f9ec5c110739ced88ce9f8fca053882 upstream. Correct instances of variable dereferencing before checking its value on the functions exported to the client drivers. Also, add sanity checks for all exported functions. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24virtio_console: fix uapi headerMichael S. Tsirkin
commit 6407d75afd08545f2252bb39806ffd3f10c7faac upstream. uapi should use __u32 not u32. Fix a macro in virtio_console.h which uses u32. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24drm/radeon: Fix VRAM size calculation for VRAM >= 4GBNiels Ole Salscheider
commit fc986034540102cd090237bf3f70262e1ae80d9c upstream. Add ULL prefix to avoid overflow. Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24drm/nouveau/bios: fix thinko in ZM_MASK_ADD opcodeBen Skeggs
commit 46b47b8a7d9223b12ddcabf1f3fc6e753e2d84a1 upstream. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24x86: Fix bit corruption at CPU resume timeLinus Torvalds
commit 5e427ec2d066b48a5c27b3a5a3315f7e4e729077 upstream. In commit 78d77df71510 ("x86-64, init: Do not set NX bits on non-NX capable hardware") we added the early_pmd_flags that gets the NX bit set when a CPU supports NX. However, the new variable was marked __initdata, because the main _use_ of this is in an __init routine. However, the bit setting happens from secondary_startup_64(), which is called not only at bootup, but on every secondary CPU start. Including resuming from STR and at CPU hotplug time. So the value cannot be __initdata. Reported-bisected-and-tested-by: Michal Hocko <mhocko@suse.cz> Acked-by: Peter Anvin <hpa@linux.intel.com> Cc: Fernando Luis Vázquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24i2c: designware: always clear interrupts before enabling themMika Westerberg
commit 2a2d95e9d6d29e726cc294b65391917ed2e32bf4 upstream. If the I2C bus is put to a low power state by an ACPI method it might pull the SDA line low (as its power is removed). Once the bus is put to full power state again, the SDA line is pulled back to high. This transition looks like a STOP condition from the controller point-of-view which sets STOP detected bit in its status register causing the driver to fail subsequent transfers. Fix this by always clearing all interrupts before we start a transfer. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24i2c: designware: fix RX FIFO overrunJosef Ahmad
commit e6f34cea56f5b95498070eaa9f4aa3ba4a9e4f62 upstream. i2c_dw_xfer_msg() pushes a number of bytes to transmit/receive to/from the bus into the TX FIFO. For master-rx transactions, the maximum amount of data that can be received is calculated depending solely on TX and RX FIFO load. This is racy - TX FIFO may contain master-rx data yet to be processed, which will eventually land into the RX FIFO. This data is not taken into account and the function may request more data than the controller is actually capable of storing. This patch ensures the driver takes into account the outstanding master-rx data in TX FIFO to prevent RX FIFO overrun. Signed-off-by: Josef Ahmad <josef.ahmad@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24hwmon: fix error return code in abituguru_probe()Wei Yongjun
commit ecacb0b17c08fae89f65468727f0e4b8e91da4e1 upstream. Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24btrfs: don't stop searching after encountering the wrong itemGabriel de Perthuis
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream. The search ioctl skips items that are too large for a result buffer, but inline items of a certain size occuring before any search result is found would trigger an overflow and stop the search entirely. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641 Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24arm64: mm: Fix operands of clz in __flush_dcache_allSukanto Ghosh
commit b4fed0796841b5293b9c9427a5391b7bb20ef2d9 upstream. The format of the lower 32-bits of the 64-bit operand to 'dc cisw' is unchanged from ARMv7 architecture and the upper bits are RES0. This implies that the 'way' field of the operand of 'dc cisw' occupies the bit-positions [31 .. (32-A)]. Due to the use of 64-bit extended operands to 'clz', the existing implementation of __flush_dcache_all is incorrectly placing the 'way' field in the bit-positions [63 .. (64-A)]. Signed-off-by: Sukanto Ghosh <sghosh@apm.com> Tested-by: Anup Patel <anup.patel@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24arm64: debug: clear mdscr_el1 instead of taking the OS lockWill Deacon
commit 9c413e25d95fd3c0abe23eadad66191b22baa549 upstream. During boot, we take the debug OS lock before interrupts are enabled. This is required to prevent clearing of PSTATE.D on the interrupt entry path, which could result in spurious debug exceptions before we've got round to resetting things like the hardware breakpoints registers to a sane state. A problem with this approach is that taking the OS lock prevents an external JTAG debugger from debugging the system, which is especially irritating during boot, where JTAG debugging can be most useful. This patch clears mdscr_el1 rather than taking the lock, clearing the MDE and KDE bits and preventing self-hosted hardware debug exceptions from occurring. Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19Linux 3.9.3v3.9.3Greg Kroah-Hartman
2013-05-19target: Use FD_MAX_SECTORS/FD_BLOCKSIZE for blockdevs using fileioAndy Grover
commit e3e84cda321703b123f36488f50700f371bc7230 upstream. We can still see the error reported in https://patchwork.kernel.org/patch/2338981/ when using fileio backed by a block device. I'm assuming this will get us past that error (from sbc_parse_cdb), and also assuming it's OK to have our max_sectors be larger than the block's queue max hw sectors? Reported-by: Eric Harney <eharney@redhat.com> Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19audit: Make testing for a valid loginuid explicit.Eric W. Biederman
commit 780a7654cee8d61819512385e778e4827db4bfbc upstream. audit rule additions containing "-F auid!=4294967295" were failing with EINVAL because of a regression caused by e1760bd. Apparently some userland audit rule sets want to know if loginuid uid has been set and are using a test for auid != 4294967295 to determine that. In practice that is a horrible way to ask if a value has been set, because it relies on subtle implementation details and will break every time the uid implementation in the kernel changes. So add a clean way to test if the audit loginuid has been set, and silently convert the old idiom to the cleaner and more comprehensible new idiom. RGB notes: In upstream, audit_rule_to_entry has been refactored out. This is patch is already upstream in functionally the same form in commit 780a7654cee8d61819512385e778e4827db4bfbc . The decimal constant was cast to unsigned to quiet GCC 4.6 32-bit architecture warnings. Reported-By: Steve Grubb <sgrubb@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Tested-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Backported-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19parisc: make default cross compiler search more robust (v3)Helge Deller
commit 6880b0150a7c25fd75c5ece80abc49ebf53c38c1 upstream. People/distros vary how they prefix the toolchain name for 64bit builds. Rather than enforce one convention over another, add a for loop which does a search for all the general prefixes. For 64bit builds, we now search for (in order): hppa64-unknown-linux-gnu hppa64-linux-gnu hppa64-linux For 32bit builds, we look for: hppa-unknown-linux-gnu hppa-linux-gnu hppa-linux hppa2.0-unknown-linux-gnu hppa2.0-linux-gnu hppa2.0-linux hppa1.1-unknown-linux-gnu hppa1.1-linux-gnu hppa1.1-linux This patch was initiated by Mike Frysinger, with feedback from Jeroen Roovers, John David Anglin and Helge Deller. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jeroen Roovers <jer@gentoo.org> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19parisc: fix NATIVE set up in buildMike Frysinger
commit 93782eba49e23c3f311a6b05a19ba15927ec4e8b upstream. The ifeq operator does not accept globs, so this little bit of code will never match (unless uname literally prints out "parsic*"). Rewrite to use a pattern matching operator so that NATIVE is set to 1 on parisc. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19parisc: use long branch in fork_like macroJohn David Anglin
commit bbbfde782084b4f0d85ddffb88f1cf4650ff40e4 upstream. The "b" branch instruction used in the fork_like macro only can handle 17-bit pc-relative offsets. This fails with an out of range offset with some .config files. Rewrite to use the "be" instruction which can branch to any address in a space. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19parisc: fix SMP races when updating PTE and TLB entries in entry.SJohn David Anglin
commit f0a18819e261afc5fdbd8c5c6f9943123c5461ba upstream. Currently, race conditions exist in the handling of TLB interruptions in entry.S. In particular, dirty bit updates can be lost if an accessed interruption occurs just after the dirty bit interruption on a different cpu. Lost dirty bit updates result in user pages not being flushed and general system instability. This change adds lock and unlock macros to synchronize all PTE and TLB updates done in entry.S. As a result, userspace stability is significantly improved. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19parisc: only re-enable interrupts if we need to schedule or deliver signals ↵John David Anglin
when returning to userspace commit c207a76bf155cb5cf24cf849c08f6555e9180594 upstream. Helge and I have found that we have a kernel stack overflow problem which causes a variety of random failures. Currently, we re-enable interrupts when returning from an external interrupt incase we need to schedule or delivery signals. As a result, a potentially unlimited number of interrupts can occur while we are running on the kernel stack. It is very limited in space (currently, 16k). This change defers enabling interrupts until we have actually decided to schedule or delivery signals. This only occurs when we about to return to userspace. This limits the number of interrupts on the kernel stack to one. In other cases, interrupts remain disabled until the final return from interrupt (rfi). Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19usermodehelper: check subprocess_info->path != NULLOleg Nesterov
commit 264b83c07a84223f0efd0d1db9ccc66d6f88288f upstream. argv_split(empty_or_all_spaces) happily succeeds, it simply returns argc == 0 and argv[0] == NULL. Change call_usermodehelper_exec() to check sub_info->path != NULL to avoid the crash. This is the minimal fix, todo: - perhaps we should change argv_split() to return NULL or change the callers. - kill or justify ->path[0] check - narrow the scope of helper_lock() Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-By: Lucas De Marchi <lucas.demarchi@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drm/radeon: restore nomodeset operation (v2)Dave Airlie
commit e9ced8e040ebe40e9953db90acbe7d0b58702ebb upstream. When UMS was deprecated it removed support for nomodeset commandline we really want this in distro land so we can debug stuff, everyone should fallback to vesa correctly. v2: oops -1 isn't used anymore, restore original behaviour -1 is default, so we can boot with nomodeset on the command line, then use radeon.modeset=1 to override it for debugging later. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drm/radeon: check incoming cliprects pointerKees Cook
commit fefaedcfb82d2e57c2320acf60604ab03b750cc0 upstream. The "boxes" parameter points into userspace memory. It should be verified like any other operation against user memory. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ASoC: da7213: Fix setting dmic_samplephase and dmic_clk_rateAxel Lin
commit 61559af111e41761f5f4f20ce0897345eb59076e upstream. When set dmic_samplephase and dmic_clk_rate bits for dmic_cfg, current code checks pdata->dmic_data_sel which is wrong. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ipmi: ipmi_devintf: compat_ioctl method fails to take ipmi_mutexBenjamin LaHaise
commit 6368087e851e697679af059b4247aca33a69cef3 upstream. When a 32 bit version of ipmitool is used on a 64 bit kernel, the ipmi_devintf code fails to correctly acquire ipmi_mutex. This results in incomplete data being retrieved in some cases, or other possible failures. Add a wrapper around compat_ipmi_ioctl() to take ipmi_mutex to fix this. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drivers/char/ipmi: memcpy, need additional 2 bytes to avoid memory overflowChen Gang
commit a5f2b3d6a738e7d4180012fe7b541172f8c8dcea upstream. When calling memcpy, read_data and write_data need additional 2 bytes. write_data: for checking: "if (size > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(bt->write_data + 3, data + 1, size - 1)" read_data: for checking: "if (msg_len < 3 || msg_len > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(data + 2, bt->read_data + 4, msg_len - 2)" Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ACPI / EC: Restart transaction even when the IBF flag setLan Tianyu
commit 28fe5c825f8e15744d04c7c1b8df197950923ecd upstream. The EC driver works abnormally with IBF flag always set. IBF means "The host has written a byte of data to the command or data port, but the embedded controller has not yet read it". If IBF is set in the EC status and not cleared, this will cause all subsequent EC requests to fail with a timeout error. Change the EC driver so that it doesn't refuse to restart a transaction if IBF is set in the status. Also increase the number of transaction restarts to 5, as it turns out that 2 is not sufficient in some cases. This bug happens on several different machines (Asus V1S, Dell Latitude E6530, Samsung R719, Acer Aspire 5930G, Sony Vaio SR19VN and others). [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=14733 References: https://bugzilla.kernel.org/show_bug.cgi?id=15560 References: https://bugzilla.kernel.org/show_bug.cgi?id=15946 References: https://bugzilla.kernel.org/show_bug.cgi?id=42945 References: https://bugzilla.kernel.org/show_bug.cgi?id=48221 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19target/iblock: Fix WCE=1 + DPOFUA=1 backend WRITE regressionNicholas Bellinger
commit d2bdbee0d91a5d3ba2e439ce889e20bfe6fd4f1b upstream. This patch fixes a regression bug introduced in v3.9-rc1 where if the underlying struct block_device for a IBLOCK backend is configured with WCE=1 + DPOFUA=1 settings, the rw = WRITE assignment no longer occurs in iblock_execute_rw(), and rw = 0 is passed to iblock_submit_bios() in effect causing a READ bio operation to occur. The offending commit is: commit d0c8b259f8970d39354c1966853363345d401330 Author: Nicholas Bellinger <nab@linux-iscsi.org> Date: Tue Jan 29 22:10:06 2013 -0800 target/iblock: Use backend REQ_FLUSH hint for WriteCacheEnabled status Note the WCE=1 + DPOFUA=0, WCE=0 + DPOFUA=1, and WCE=0 + DPOFUA=0 cases are not affected by this regression bug. Reported-by: Chris Boot <bootc@bootc.net> Tested-by: Chris Boot <bootc@bootc.net> Reported-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19target: close target_put_sess_cmd() vs. core_tmr_abort_task() raceJoern Engel
commit ccf5ae83a6cf3d9cfe9a7038bfe7cd38ab03d5e1 upstream. It is possible for one thread to to take se_sess->sess_cmd_lock in core_tmr_abort_task() before taking a reference count on se_cmd->cmd_kref, while another thread in target_put_sess_cmd() drops se_cmd->cmd_kref before taking se_sess->sess_cmd_lock. This introduces kref_put_spinlock_irqsave() and uses it in target_put_sess_cmd() to close the race window. Signed-off-by: Joern Engel <joern@logfs.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19iscsi-target: Fix processing of OOO commandsShlomo Pongratz
commit 3eccfdb01da58fbd0f789ae6ca61cee3769e26de upstream. Fix two issues in OOO commands processing done at iscsit_attach_ooo_cmdsn. Handle command serial numbers wrap around by using iscsi_sna_lt and not regular comparisson. The routine iterates until it finds an entry whose serial number is greater than the serial number of the new one, thus the new entry should be inserted before that entry and not after. Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19cpufreq / intel_pstate: fix ffmpeg regressionDirk Brandewie
commit ca182aee389f8026401510f4c63841cb02c820e8 upstream. The ffmpeg benchmark in the phoronix test suite has threads on multiple cores that rely on the progress on of threads on other cores and ping pong back and forth fast enough to make the core appear less busy than it "should" be. If the core has been at minimum p-state for a while bump the pstate up to kick the core to see if it is in this ping pong state. If the core is truly idle the p-state will be reduced at the next sample time. If the core makes more progress it will send more work to the thread bringing both threads out of the ping pong scenario and the p-state will be selected normally. This fixes a performance regression of approximately 30% Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19cpufreq / intel_pstate: use lowest requested max performanceDirk Brandewie
commit d8f469e9cff3bc4a6317d923e9506be046aa7bdc upstream. There are two ways that the maximum p-state can be clamped, via a policy change and via the sysfs file. The acpi-thermal driver adjusts the p-state policy in response to thermal events. These changes override the users settings at the moment. Use the lowest of the two requested values this ensures that we will not exceed the requested pstate from either mechanism. Reported-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19cpufreq / intel_pstate: remove idle time and duration from sample and ↵Dirk Brandewie
calculations commit 1abc4b20b85b42e8573957e54b193385cf48b0d6 upstream. Idle time is taken into account in the APERF/MPERF ratio calculation there is no reason for the driver to track it seperately. This reduces the work in the driver and makes the code more readable. Removal of the tracking of sample duration removes the possibility of the divide by zero exception when the duration is sub 1us References: https://bugzilla.kernel.org/show_bug.cgi?id=56691 Reported-by: Mike Lothian <mike@fireburn.co.uk> Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drivers/rtc/rtc-pcf2123.c: fix error return code in pcf2123_probe()Wei Yongjun
commit 35623715818dfa720cccf99cd280dcbb4b78da23 upstream. Fix to return -ENODEV in the chip not found error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ARM: EXYNOS5: Fix kernel dump in AFTR idle modeInderpal Singh
commit 088584618836b159947bc4ab5011a5cf1f081a62 upstream. The kernel crashes while resuming from AFTR idle mode. It happens because L2 cache was not going into retention state. This patch configures the USE_RETENTION bit of ARM_L2_OPTION register so that it does not depend on MANUAL_L2RSTDISABLE_CONTROL of ARM_COMMON_OPTION register for L2RSTDISABLE signal. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Tested-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19VSOCK: Drop bogus __init annotation from vsock_init_tables()Geert Uytterhoeven
commit 22ee3b57c3ff71772b0c4178404b04f5df78d501 upstream. If gcc (e.g. 4.1.2) decides not to inline vsock_init_tables(), this will cause a section mismatch: WARNING: net/vmw_vsock/vsock.o(.text+0x1bc): Section mismatch in reference from the function __vsock_core_init() to the function .init.text:vsock_init_tables() The function __vsock_core_init() references the function __init vsock_init_tables(). This is often because __vsock_core_init lacks a __init annotation or the annotation of vsock_init_tables is wrong. This may cause crashes if VSOCKETS=y and VMWARE_VMCI_VSOCKETS=m. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drbd: fix for deadlock when using automatic split-brain-recoveryPhilipp Reisner
commit 7c689e63a847316c1b2500f86891b0a574ce7e69 upstream. With an automatic after split-brain recovery policy of "after-sb-1pri call-pri-lost-after-sb", when trying to drbd_set_role() to R_SECONDARY, we run into a deadlock. This was first recognized and supposedly fixed by 2009-06-10 "Fixed a deadlock when using automatic split brain recovery when both nodes are" replacing drbd_set_role() with drbd_change_state() in that code-path, but the first hunk of that patch forgets to remove the drbd_set_role(). We apparently only ever tested the "two primaries" case. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drbd: fix memory leakLars Ellenberg
commit 94ad0a101415978be04945b2787be1e8e8a874db upstream. We forgot to free the disk_conf, so for each attach/detach cycle we leaked 336 bytes. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drbd: Fix build error when CONFIG_CRYPTO_HMAC is not setPhilipp Reisner
commit ef57f9e6bb9278720c8a5278728f252ab85d7ac6 upstream. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19watchdog: Fix race condition in registration codeGuenter Roeck
commit 60403f7a4d9368d187f79cba5e4672d01df37574 upstream. A race condition exists when registering the first watchdog device. Sequence of events: - watchdog_register_device calls watchdog_dev_register - watchdog_dev_register creates the watchdog misc device by calling misc_register. At that time, the matching character device (/dev/watchdog0) does not yet exist, and old_wdd is not set either. - Userspace gets an event and opens /dev/watchdog - watchdog_open is called and sets wdd = old_wdd, which is still NULL, and tries to dereference it. This causes the kernel to panic. Seen with systemd trying to open /dev/watchdog immediately after it was created. Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
