commit b09a61cc0bc2a7151f4ab652489e85253d5d0175 upstream.
This patch (as1653) fixes a bug in ehci-hcd. Unlike iTD entries, an
siTD entry in the periodic schedule may not complete until the frame
after the one it belongs to. Consequently, when scanning the periodic
schedule it is necessary to start with the frame _preceding_ the one
where the previous scan ended.
Not doing this properly can result in memory leaks and failures to
complete isochronous URBs.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Andy Leiserson <andy@leiserson.org>
commit 58b2939b4d5a030eaec469d29812ab8477ee7e76 upstream.
When the xHCI driver is not available, actively switch the ports to EHCI
mode since some BIOSes leave them in xHCI mode where they would
otherwise appear dead. This was discovered on a Dell Optiplex 7010,
but it's possible other systems could be affected.
This should be backported to kernels as old as 3.0, that contain the
commit 69e848c2090aebba5698a1620604c7dccb448684 "Intel xhci: Support
EHCI/xHCI port switching."
Signed-off-by: David Moore <david.moore@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 48c3375c5f69b1c2ef3d1051a0009cb9bce0ce24 upstream.
This patch (as1640) fixes a memory leak in xhci-hcd. The urb_priv
data structure isn't always deallocated in the handle_tx_event()
routine for non-control transfers. The patch adds a kfree() call so
that all paths end up freeing the memory properly.
This patch should be backported to kernels as old as 2.6.36, that
contain the commit 8e51adccd4c4b9ffcd509d7f2afce0a906139f75 "USB: xHCI:
Introduce urb_priv structure"
Reported-and-tested-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz>
commit f18f8ed2a9adc41c2d9294b85b6af115829d2af1 upstream.
To calculate the TD size for a particular TRB in an isoc TD, we need
know the endpoint's max packet size. Isochronous endpoints also encode
the number of additional service opportunities in their wMaxPacketSize
field. The TD size calculation did not mask off those bits before using
the field. This resulted in incorrect TD size information for
isochronous TRBs when an URB frame buffer crossed a 64KB boundary.
For example:
- an isoc endpoint has 2 additional service opportunites and
a max packet size of 1020 bytes
- a frame transfer buffer contains 3060 bytes
- one frame buffer crosses a 64KB boundary, and must be split into
one 1276 byte TRB, and one 1784 byte TRB.
The TD size is is the number of packets that remain to be transferred
for a TD after processing all the max packet sized packets in the
current TRB and all previous TRBs.
For this TD, the number of packets to be transferred is (3060 / 1020),
or 3. The first TRB contains 1276 bytes, which means it contains one
full packet, and a 256 byte remainder. After processing all the max
packet-sized packets in the first TRB, the host will have 2 packets left
to transfer.
The old code would calculate the TD size for the first TRB as:
total packet count = DIV_ROUND_UP (TD length / endpoint wMaxPacketSize)
total packet count - (first TRB length / endpoint wMaxPacketSize)
The math should have been:
total packet count = DIV_ROUND_UP (3060 / 1020) = 3
3 - (1276 / 1020) = 2
Since the old code didn't mask off the additional service interval bits
from the wMaxPacketSize field, the math ended up as
total packet count = DIV_ROUND_UP (3060 / 5116) = 1
1 - (1276 / 5116) = 1
Fix this by masking off the number of additional service opportunities
in the wMaxPacketSize field.
This patch should be backported to stable kernels as old as 3.0, that
contain the commit 4da6e6f247a2601ab9f1e63424e4d944ed4124f3 "xhci 1.0:
Update TD size field format." It may not apply well to kernels older
than 3.2 because of commit 29cc88979a8818cd8c5019426e945aed118b400e
"USB: use usb_endpoint_maxp() instead of le16_to_cpu()".
commit 760973d2a74b93eb1697981f7448f0e62767cfc4 upstream.
An isochronous TD is comprised of one isochronous TRB chained to zero or
more normal TRBs. Only the isoc TRB has the TBC and TLBPC fields. The
normal TRBs must set those fields to zeroes. The code was setting the
TBC and TLBPC fields for both isoc and normal TRBs. Fix this.
This should be backported to stable kernels as old as 3.0, that contain
the commit b61d378f2da41c748aba6ca19d77e1e1c02bcea5 " xhci 1.0: Set
transfer burst last packet count field."
commit ba7b5c22d33136a5612ca5ef8d31564dcc501126 upstream.
Fix incorrect bit test that originally showed up in
4ee823b83bc9851743fab756c76b27d6a1e2472b "USB/xHCI: Support
device-initiated USB 3.0 resume."
Use '&' instead of '&&'.
This should be backported to kernels as old as 3.4.
Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu>
new switch command
commit 200e0d994d9d1919b28c87f1a5fb99a8e13b8a0f upstream.
1. Optimize the match rules with new macro for Huawei USB storage devices,
to avoid to load USB storage driver for the modem interface
with Huawei devices.
2. Add to support new switch command for new Huawei USB dongles.
Signed-off-by: fangxiaozhi <huananhu@huawei.com>
commit 07c7be3d87e5cdaf5f94c271c516456364ef286c upstream.
1. Define a new macro for USB storage match rules:
matching with Vendor ID and interface descriptors.
commit 54a3ac0c9e5b7213daa358ce74d154352657353a upstream.
Usb3.0 device defines function remote wakeup which is only for interface
recipient rather than device recipient. This is different with usb2.0 device's
remote wakeup feature which is defined for device recipient. According usb3.0
spec 9.4.5, the function remote wakeup can be modified by the SetFeature()
requests using the FUNCTION_SUSPEND feature selector. This patch is to use
correct way to disable usb3.0 device's function remote wakeup after suspend
error and resuming.
This should be backported to kernels as old as 3.4, that contain the
commit 623bef9e03a60adc623b09673297ca7a1cdfb367 "USB/xhci: Enable remote
wakeup for USB3 devices."
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d upstream.
This patch (as1654) fixes a very old bug in ehci-hcd, connected with
scheduling of periodic split transfers. The calculations for
full/low-speed bus usage are all carried out after the correction for
bit-stuffing has been applied, but the values in the max_tt_usecs
array assume it hasn't been. The array should allow for allocation of
up to 90% of the bus capacity, which is 900 us, not 780 us.
The symptom caused by this bug is that any isochronous transfer to a
full-speed device with a maxpacket size larger than about 980 bytes is
always rejected with a -ENOSPC error.
commit ee74290b7853db9d5fd64db70e5c175241c59fba upstream.
This patch (as1652) fixes a long-standing bug in ehci-hcd. The driver
relies on status polls to know when to stop port-resume signalling.
It uses the root-hub status timer to schedule these status polls. But
when the driver for the root hub is resumed, the timer is rescheduled
to go off immediately -- before the port is ready. When this happens
the timer does not get re-enabled, which prevents the port resume from
finishing until some other event occurs.
The symptom is that when a new device is plugged in, it doesn't get
recognized or enumerated until lsusb is run or something else happens.
The solution is to re-enable the root-hub status timer after every
status poll while a port resume is in progress.
This bug hasn't surfaced before now because we never used to try to
suspend the root hub in the middle of a port resume (except by
coincidence).
Reported-and-tested-by: Norbert Preining <preining@logic.at>
Tested-by: Ming Lei <ming.lei@canonical.com>
commit 6e0c3339a6f19d748f16091d0a05adeb1e1f822b upstream.
This patch (as1648) fixes a regression affecting nVidia EHCI
controllers. Evidently they don't like to have more than one async QH
unlinked at a time. I can't imagine how they manage to mess it up,
but at least one of them does.
The patch changes the async unlink logic in two ways:
Each time an IAA cycle is started, only the first QH on the
async unlink list is handled (rather than all of them).
Async QHs do not all get unlinked as soon as they have been
empty for long enough. Instead, only the last one (i.e., the
one that has been on the schedule the longest) is unlinked,
and then only if no other unlinks are in progress at the time.
This means that when multiple QHs are empty, they won't be unlinked as
quickly as before. That's okay; it won't affect correct operation of
the driver or add an excessive load. Multiple unlinks tend to be
relatively rare in any case.
Reported-and-tested-by: Piergiorgio Sartor <piergiorgio.sartor@nexgo.de>
commit 55bcdce8a8228223ec4d17d8ded8134ed265d2c5 upstream.
This patch (as1647) attempts to work around a problem that seems to
affect some nVidia EHCI controllers. They sometimes take a very long
time to turn off their async or periodic schedules. I don't know if
this is a result of other problems, but in any case it seems wise not
to depend on schedule enables or disables taking effect in any
specific length of time.
The patch removes the existing 20-ms timeout for enabling and
disabling the schedules. The driver will now continue to poll the
schedule state at 1-ms intervals until the controller finally decides
to obey the most recent command issued by the driver. Just in case
this hides a problem, a debugging message will be logged if the
controller takes longer than 20 polls.
I don't know if this will actually fix anything, but it can't hurt.
Tested-by: Piergiorgio Sartor <piergiorgio.sartor@nexgo.de>
commit 78796ae17eacedcdcaaeb03ba73d2e532a4c8f83 upstream.
Add VID and PID for Telit Gobi QDL device
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
commit d4fa681541aa7bf8570d03426dd7ba663a71c467 upstream.
New device with 3 serial interfaces:
If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend) Sub=ff Prot=ff
If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff
If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff
If#= 3 Alt= 0 #EPs= 2 Cls=08(stor) Sub=06 Prot=50
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 03eb466f276ceef9dcf023dc5474db02af68aad9 upstream.
Add PID and special handling for Telit LE920
commit c249f911406efcc7456cb4af79396726bf7b8c57 upstream.
Add PID/VID entries for ELV WS 300 PC II weather station
Signed-off-by: Sven Killig <sven@killig.de>
commit 0ba3b2ccc72b3df5c305d61f59d93ab0f0e87991 upstream.
Add support for Zolix Omni 1509 monochromator custom USB-RS232 converter.
Signed-off-by: Petr Kubánek <petr@kubanek.net>
commit e7e034e18a0ab6bafb2425c3242cac311164f4d6 upstream.
The RTC control register should be enabled in the process of
initializing.
Without this patch, I failed to enable RTC in Hisilicon Hi3620 SoC. The
register mapping section in RTC is always read as zero. So I doubt that
ST guys may already enable this register in bootloader. So they won't
meet this issue.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
commit 72fca4a4b32dc778b5b885c3498700e42b610d49 upstream.
Previously the alarm event was not propagated into the RTC subsystem.
By adding a call to rtc_update_irq, this fixes a timeout problem with
the hwclock utility.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
remove_migration_pte
commit be7517d6ab9722f0abad6ba5ffd39cfced95549c upstream.
When setting a huge PTE, besides calling pte_mkhuge(), we also need to
call arch_make_huge_pte(), which we indeed do in make_huge_pte(), but we
forget to do in hugetlb_change_protection() and remove_migration_pte().
Signed-off-by: Zhigang Lu <zlu@tilera.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Hillf Danton <dhillf@gmail.com>
commit a9bae189542e71f91e61a4428adf6e5a7dfe8063 upstream.
There exists a situation when GC can work in background alone without
any other filesystem activity during significant time.
The nilfs_clean_segments() method calls nilfs_segctor_construct() that
updates superblocks in the case of NILFS_SC_SUPER_ROOT and
THE_NILFS_DISCONTINUED flags are set. But when GC is working alone the
nilfs_clean_segments() is called with unset THE_NILFS_DISCONTINUED flag.
As a result, the update of superblocks doesn't occurred all this time
and in the case of SPOR superblocks keep very old values of last super
root placement.
SYMPTOMS:
Trying to mount a NILFS2 volume after SPOR in such environment ends with
very long mounting time (it can achieve about several hours in some
cases).
REPRODUCING PATH:
1. It needs to use external USB HDD, disable automount and doesn't
make any additional filesystem activity on the NILFS2 volume.
2. Generate temporary file with size about 100 - 500 GB (for example,
dd if=/dev/zero of=<file_name> bs=1073741824 count=200). The size of
file defines duration of GC working.
3. Then it needs to delete file.
4. Start GC manually by means of command "nilfs-clean -p 0". When you
start GC by means of such way then, at the end, superblocks is updated
by once. So, for simulation of SPOR, it needs to wait sometime (15 -
40 minutes) and simply switch off USB HDD manually.
5. Switch on USB HDD again and try to mount NILFS2 volume. As a
result, NILFS2 volume will mount during very long time.
REPRODUCIBILITY: 100%
FIX:
This patch adds checking that superblocks need to update and set
THE_NILFS_DISCONTINUED flag before nilfs_clean_segments() call.
Reported-by: Sergey Alexandrov <splavgm@gmail.com>
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Tested-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 7a9c83888761a9a26049b439dc0b09e7ea8a854b upstream.
Commit cdeadd712f52b16a9285386d61ee26fd14eb4085 (mtd: nand: davinci: add OF
support for davinci nand controller) has never been really build tested with
the driver as a module. When the driver is built-in, the missing semicolon
after structure initializer is "compensated" by MODULE_DEVICE_TABLE() macro
being empty and so the initializer using the trailing semicolon on the next
line; when the driver is built as a module, compilation error ensues, and as
the 'davinci_all_defconfig' has the NAND driver modular, this error prevents
DaVinci family kernel from building...
commit aa7f67304d1a03180f463258aa6f15a8b434e77d upstream.
When the system has multiple domains do_sched_rt_period_timer()
can run on any CPU and may iterate over all rt_rq in
cpu_online_mask. This means when balance_runtime() is run for a
given rt_rq that rt_rq may be in a different rd than the current
processor. Thus if we use smp_processor_id() to get rd in
do_balance_runtime() we may borrow runtime from a rt_rq that is
not part of our rd.
This changes do_balance_runtime to get the rd from the passed in
rt_rq ensuring that we borrow runtime only from the correct rd
for the given rt_rq.
This fixes a BUG at kernel/sched/rt.c:687! in __disable_runtime
when we try reclaim runtime lent to other rt_rq but runtime has
been lent to a rt_rq in another rd.
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Mike Galbraith <bitbucket@online.de>
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/1358186131-29494-1-git-send-email-sbohrer@rgmadvisors.com
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream.
For some reason they didn't get replaced so far by their
paravirt equivalents, resulting in code to be run with
interrupts disabled that doesn't expect so (causing, in the
observed case, a BUG_ON() to trigger) when syscall auditing is
enabled.
David (Cc-ed) came up with an identical fix, so likely this can
be taken to count as an ack from him.
Reported-by: Peter Moody <pmoody@google.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com
Tested-by: Peter Moody <pmoody@google.com>
commit f2d68cf4daa4de97d400d94836b907e35228e54f upstream.
When kzalloc() failed in radeon_user_framebuffer_create(), need to
call object_unreference() to match the object_reference().
Signed-off-by: liu chuansheng <chuansheng.liu@intel.com>
Signed-off-by: xueminsu <xuemin.su@intel.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit fd5d93a0015ce1a7db881382022b2fcdfdc61760 upstream.
If the requested number of DWs on the ring is larger than
the size of the ring itself, return an error.
In testing with large VM updates, we've seen crashes when we
try and allocate more space on the ring than the total size
of the ring without checking.
This prevents the crash but for large VM updates or bo moves
of very large buffers, we will need to break the transaction
down into multiple batches. I have patches to use IBs for
the next kernel.
commit f689e3acbd2e48cc4101e0af454193f81af4baaf upstream.
Make sure at least one RB is enabled in
r6xx_remap_render_backend() to avoid an division by
zero in some corner cases.
See:
https://bugzilla.redhat.com/show_bug.cgi?id=892233
commit f7eb97300832f4fe5fe916c5d84cd2e25169330e upstream.
Need to adjust the backend map depending on which
RB is enabled.
Fixes:
Reported-by: Mikko Tiihonen <mikko.tiihonen@iki.fi>
commit bb588820ef421c6098dca1fec29c3b347f1c8c19 upstream.
Force the crtc mem requests on/off immediately rather
than waiting for the double buffered updates to kick in.
Seems we miss the update in certain conditions. Also
handle the DCE6 case.
Signed-off-by: Christopher Staite <chris@yourdreamnet.co.uk>
commit 9200ee4941a6e5d1ec5df88982243686882dff3f upstream.
vbios says external TMDS while the board is actually
internal TMDS.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=60037
commit 674a16f2b4724880d07389abbb95abf320b924aa upstream.
Newer versions of mesa emit this.
commit ed39fadd6df01095378e499fac3674883f16b853 upstream.
Some chips seem to need a little delay after blacking out
the MC before the requests actually stop.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=56139
https://bugs.freedesktop.org/show_bug.cgi?id=57567
commit 7810cc1e7721220f1ed2a23ca95113d6434f6dcd upstream.
digsig_verify_rsa() does not free kmalloc'ed buffer returned by
mpi_get_buffer().
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit eda8eebdd153c48a4e2a3a3ac3cd9e2e31f5c6b3 upstream.
The ASM version of hash computation function was truncating the upper bit.
Make the ASM version similar to hpt_hash function. Remove masking vsid bits.
Without this patch, we observed hang during bootup due to not satisfying page
fault request correctly. The fault handler used wrong hash values to update
the HPTE. Hence we kept looping with page fault.
hash_page(ea=000001003e260008, access=203, trap=300 ip=3fff91787134 dsisr 42000000
The computed value of hash 000000000f22f390
update: avpnv=4003e46054003e00, hash=000000000722f390, f=80000006, psize: 2 ...
BenH: The over-masking has been there for ever but only hurts with the
new 64T support introduced in 3.7
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
commit 4610476d89d53714ca94aae081fa035908bc137a upstream.
net/netfilter/xt_CT.c: In function ‘xt_ct_tg_check_v1’:
net/netfilter/xt_CT.c:250:6: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized]
net/netfilter/xt_CT.c: In function ‘xt_ct_tg_check_v0’:
net/netfilter/xt_CT.c:112:6: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized]
Reported-by: Borislav Petkov <bp@alien8.de>
Acked-by: Borislav Petkov <bp@alien8.de>
This is for stable-3.7.y only and this problem has already been solved
in mainline through some slab/slub re-work which isn't suitable to
backport here. See create_kmalloc_cache() in mm/slab_common.c there.
commit cce89f4f6911286500cf7be0363f46c9b0a12ce0('Move kmem_cache
refcounting to common code') moves some refcount manipulation code to
common code. Unfortunately, it also removed refcount assignment for
kmalloc_caches. So, kmalloc_caches's refcount is initially 0.
This makes erroneous situation.
Paul Hargrove report that when he create a 8-byte kmem_cache and
destory it, he encounter below message.
'Objects remaining in kmalloc-8 on kmem_cache_close()'
8-byte kmem_cache merge with 8-byte kmalloc cache and refcount is
increased by one. So, resulting refcount is 1. When destroy it, it hit
refcount = 0, then kmem_cache_close() is executed and error message is
printed.
This patch assign initial refcount 1 to kmalloc_caches, so fix this
Reported-by: Paul Hargrove <phhargrove@lbl.gov>
Cc: Christoph Lameter <cl@linux.com>
Signed-off-by: Joonsoo Kim <js1304@gmail.com>
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit b514407547890686572606c9dfa4b7f832db9958 upstream.
We stopped reading FORCEWAKE for posting reads in
commit 8dee3eea3ccd3b6c00a8d3a08dd715d6adf737dd
Author: Ben Widawsky <ben@bwidawsk.net>
Date: Sat Sep 1 22:59:50 2012 -0700
drm/i915: Never read FORCEWAKE
and started using something from the same cacheline instead. On the
bug reporter's machine this broke entering rc6 states after a
suspend/resume cycle. It turns out reading ECOBUS as posting read
worked fine, while GTFIFODBG did not, preventing RC6 states after
suspend/resume per the bug report referenced below. It's not entirely
clear why, but clearly GTFIFODBG was nowhere near the same cacheline
or address range as FORCEWAKE.
Trying out various registers for posting reads showed that all tested
registers for which NEEDS_FORCE_WAKE() (in i915_drv.c) returns true
work. Conversely, most (but not quite all) registers for which
NEEDS_FORCE_WAKE() returns false do not work. Details in the referenced
bug.
Based on the above, add posting reads on ECOBUS where GTFIFODBG was
previously relied on.
In true cargo cult spirit, add posting reads for FORCEWAKE_VLV writes as
well, but instead of ECOBUS, use FORCEWAKE_ACK_VLV which is in the same
address range as FORCEWAKE_VLV.
v2: Add more details to the commit message. No functional changes.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=52411
Reported-and-tested-by: Alexander Bersenev <bay@hackerdom.ru>
CC: Ben Widawsky <ben@bwidawsk.net>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: stable@vger.kernel.org
[danvet: add cc: stable and make the commit message a bit clearer that
this is a regression fix and what exactly broke.]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 1310b955c804975651dca6c674ebfd1cb2b4c7ff upstream.
This patch fixes a leak in one of the error paths of
ctnetlink_create_expect if no helper and no timeout is specified.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
commit 5b76c4948fe6977bead2359c2054f3e6a2dcf3d0 upstream.
arptables 0.0.4 (released on 10th Jan 2013) supports calling the
CLASSIFY target, but on adding a rule to the wrong chain, the
diagnostic is as follows:
# arptables -A INPUT -j CLASSIFY --set-class 0:0
arptables: Invalid argument
# dmesg | tail -n1
x_tables: arp_tables: CLASSIFY target: used from hooks
PREROUTING, but only usable from INPUT/FORWARD
This is incorrect, since xt_CLASSIFY.c does specify
(1 << NF_ARP_OUT) | (1 << NF_ARP_FORWARD).
This patch corrects the x_tables diagnostic message to print the
proper hook names for the NFPROTO_ARP case.
Affects all kernels down to and including v2.6.31.
Signed-off-by: Jan Engelhardt <jengelh@inai.de>
commit 1e47ee8367babe6a5e8adf44a714c7086657b87e upstream.
canqun zhang reported that we're hitting BUG_ON in the
nf_conntrack_destroy path when calling kfree_skb while
rmmod'ing the nf_conntrack module.
Currently, the nf_ct_destroy hook is being set to NULL in the
destroy path of conntrack.init_net. However, this is a problem
since init_net may be destroyed before any other existing netns
(we cannot assume any specific ordering while releasing existing
netns according to what I read in recent emails).
Thanks to Gao feng for initial patch to address this issue.
Reported-by: canqun zhang <canqunzhang@gmail.com>
Acked-by: Gao feng <gaofeng@cn.fujitsu.com>
commit 2727de76041b2064c0b74f00a2a89678fb3efafc upstream.
xt_recent can try high order page allocations and this can fail.
iptables: page allocation failure: order:9, mode:0xc0d0
It also wastes about half the allocated space because of kmalloc()
power-of-two roundups and struct recent_table layout.
Use vmalloc() instead to save space and be less prone to allocation
errors when memory is fragmented.
Reported-by: Miroslav Kratochvil <exa.exa@gmail.com>
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Harald Reindl <h.reindl@thelounge.net>
commit 665e205c16c1f902ac6763b8ce8a0a3a1dcefe59 upstream.
recent_net_exit() is called before recent_mt_destroy() in the
destroy path of network namespaces. Make sure there are no entries
in the parent proc entry xt_recent before removing it.
Signed-off-by: Vitaly E. Lavrov <lve@guap.ru>
commit 09181842b000344b1205801df3aa5b726c03cc62 upstream.
Two packets may race to create the same entry in the hashtable,
double check if this packet lost race. This double checking only
happens in the path of the packet that creates the hashtable for
first time.
Note that, with this patch, no packet drops occur if the race happens.
Reported-by: Feng Gao <gfree.wind@gmail.com>
commit 32263dd1b43378b4f7d7796ed713f77e95f27e8a upstream.
commit 757ae316fb35811cfd8c67de0e0b8680ec4c1f37 upstream.
warning: (NETFILTER_XT_TARGET_NOTRACK) selects NETFILTER_XT_TARGET_CT which has unmet direct
+dependencies (NET && INET && NETFILTER && NETFILTER_XTABLES && NF_CONNTRACK && (IP_NF_RAW ||
+IP6_NF_RAW) && NETFILTER_ADVANCED)
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
commit 10db9069eb5c60195170a4119bdbcbce69a4945f upstream.
Florian Westphal reported that the removal of the NOTRACK target
(9655050 netfilter: remove xt_NOTRACK) is breaking some existing
setups.
That removal was scheduled for removal since long time ago as
described in Documentation/feature-removal-schedule.txt
What: xt_NOTRACK
Files: net/netfilter/xt_NOTRACK.c
When: April 2011
Why: Superseded by xt_CT
Still, people may have not notice / may have decided to stick to an
old iptables version. I agree with him in that some more conservative
approach by spotting some printk to warn users for some time is less
agressive.
Current iptables 1.4.16.3 already contains the aliasing support
that makes it point to the CT target, so upgrading would fix it.
Still, the policy so far has been to avoid pushing our users to
upgrade.
As a solution, this patch recovers the NOTRACK target inside the CT
target and it now spots a warning.
Reported-by: Florian Westphal <fw@strlen.de>
commit e035edd16ee83498cccc9beedfc215e15cab3a07 upstream.
In (0c36b48 netfilter: nfnetlink_log: fix mac address for 6in4 tunnels)
the include file that defines ARPD_SIT was missing. This passed unnoticed
during my tests (I did not hit this problem here).
net/netfilter/nfnetlink_log.c: In function '__build_packet_message':
net/netfilter/nfnetlink_log.c:494:25: error: 'ARPHRD_SIT' undeclared (first use in this function)
net/netfilter/nfnetlink_log.c:494:25: note: each undeclared identifier is reported only once for
+each function it appears in
