commit fd3ba42c76d3d4b776120c2b24c1791e7bb3deb1 upstream.
wchar_t is currently 16bit so converting a utf8 encoded characters not
in plane 0 (>= 0x10000) to wchar_t (that is calling char2uni) lead to a
-EINVAL return. This patch detect utf8 in cifs_strtoUTF16 and add special
code calling utf8s_to_utf16s.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 72bd481f860f0125c810bb43d878ce5f9c060c58 upstream.
Apparently this was lost when we converted to the standard option
parser in 8830d7e07a5e38bc47650a7554b7c1cfd49902bf
Reported-by: Gregory Lee Bartholomew <gregory.lee.bartholomew@gmail.com>
Cc: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 74d83beaa229aac7d126ac1ed9414658ff1a89d2 upstream.
JFFS2 was designed without thought for OOB bitflips, it seems, but they
can occur and will be reported to JFFS2 via mtd_read_oob()[1]. We don't
want to fail on these transactions, since the data was corrected.
[1] Few drivers report bitflips for OOB-only transactions. With such
drivers, this patch should have no effect.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit a445f784ae5558a3da680aa6b39ed53c95a551c1 upstream.
This patch fixes regression introduced by
"8bdc81c jffs2: get rid of jffs2_sync_super". We submit a delayed work in order
to make sure the write-buffer is synchronized at some point. But we do not
flush it when we unmount, which causes an oops when we unmount the file-system
and then the delayed work is executed.
This patch fixes the issue by adding a "cancel_delayed_work_sync()" infocation
in the '->sync_fs()' handler. This will make sure the delayed work is canceled
on sync, unmount and re-mount. And because VFS always callse 'sync_fs()' before
unmounting or remounting, this fixes the issue.
Reported-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 8464dd52d3198dd05cafb005371d76e5339eb842 upstream.
On some systems, e.g., kzm9g, MMCIF interfaces can produce spurious
interrupts without any active request. To prevent the Oops, that results
in such cases, don't dereference the mmc request pointer until we make
sure, that we are indeed processing such a request.
Reported-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit c4c8eeb4df00aabb641553d6fbcd46f458e56cd9 upstream.
In some cases mmc_suspend_host() is not able to claim the
host and proceed with the suspend process. The core returns
-EBUSY to the host controller driver. Unfortunately, the
host controller driver does not pass on this information
to the PM core and hence the system suspend process continues.
ret = mmc_suspend_host(host->mmc);
if (ret) {
host->suspended = 0;
if (host->pdata->resume) {
ret = host->pdata->resume(dev, host->slot_id);
The return status from mmc_suspend_host() is overwritten by return
status from host->pdata->resume. So the original return status is lost.
In these cases the MMC core gets to an unexpected state
during resume and multiple issues related to MMC crop up.
1. Host controller driver starts accessing the device registers
before the clocks are enabled which leads to a prefetch abort.
2. A file copy thread which was launched before suspend gets
stuck due to the host not being reclaimed during resume.
To avoid such problems pass on the -EBUSY status to the PM core
from the host controller driver. With this change, MMC core
suspend might still fail but it does not end up making the
system unusable. Suspend gets aborted and the user can try
suspending the system again.
Signed-off-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
Acked-by: Venkatraman S <svenkatr@ti.com>
commit 4d3d688da8e7016f15483e9319b41311e1db9515 upstream.
Unloading the omap2 nand driver missed to release the memory region which will
result in not being able to request it again if one want to load the driver
later on.
This patch fixes following error when loading omap2 module after unloading:
---8<---
~ $ rmmod omap2
~ $ modprobe omap2
[ 37.420928] omap2-nand: probe of omap2-nand.0 failed with error -16
--->8---
This error was introduced in 67ce04bf2746f8a1f8c2a104b313d20c63f68378 which
was the first commit of this driver.
Signed-off-by: Andreas Bießmann <andreas@biessmann.de>
commit 7d9b110269253b1d5858cfa57d68dfc7bf50dd77 upstream.
Do not kfree() the mtd_info; it is handled in the mtd subsystem and
already freed by nand_release(). Instead kfree() the struct
omap_nand_info allocated in omap_nand_probe which was not freed before.
This patch fixes following error when unloading the omap2 module:
---8<---
~ $ rmmod omap2
kernel BUG at mm/slab.c:3126!
Internal error: Oops - BUG: 0 [#1] PREEMPT ARM
Modules linked in: omap2(-)
CPU: 0 Not tainted (3.6.0-rc3-00230-g155e36d-dirty #3)
PC is at cache_free_debugcheck+0x2d4/0x36c
LR is at kfree+0xc8/0x2ac
pc : [<c01125a0>] lr : [<c0112efc>] psr: 200d0193
sp : c521fe08 ip : c0e8ef90 fp : c521fe5c
r10: bf0001fc r9 : c521e000 r8 : c0d99c8c
r7 : c661ebc0 r6 : c065d5a4 r5 : c65c4060 r4 : c78005c0
r3 : 00000000 r2 : 00001000 r1 : c65c4000 r0 : 00000001
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 86694019 DAC: 00000015
Process rmmod (pid: 549, stack limit = 0xc521e2f0)
Stack: (0xc521fe08 to 0xc5220000)
fe00: c008a874 c00bf44c c515c6d0 200d0193 c65c4860 c515c240
fe20: c521fe3c c521fe30 c008a9c0 c008a854 c521fe5c c65c4860 c78005c0 bf0001fc
fe40: c780ff40 a00d0113 c521e000 00000000 c521fe84 c521fe60 c0112efc c01122d8
fe60: c65c4860 c0673778 c06737ac 00000000 00070013 00000000 c521fe9c c521fe88
fe80: bf0001fc c0112e40 c0673778 bf001ca8 c521feac c521fea0 c02ca11c bf0001ac
fea0: c521fec4 c521feb0 c02c82c4 c02ca100 c0673778 bf001ca8 c521fee4 c521fec8
fec0: c02c8dd8 c02c8250 00000000 bf001ca8 bf001ca8 c0804ee0 c521ff04 c521fee8
fee0: c02c804c c02c8d20 bf001924 00000000 bf001ca8 c521e000 c521ff1c c521ff08
ff00: c02c950c c02c7fbc bf001d48 00000000 c521ff2c c521ff20 c02ca3a4 c02c94b8
ff20: c521ff3c c521ff30 bf001938 c02ca394 c521ffa4 c521ff40 c009beb4 bf001930
ff40: c521ff6c 70616d6f b6fe0032 c0014f84 70616d6f b6fe0032 00000081 60070010
ff60: c521ff84 c521ff70 c008e1f4 c00bf328 0001a004 70616d6f c521ff94 0021ff88
ff80: c008e368 0001a004 70616d6f b6fe0032 00000081 c0015028 00000000 c521ffa8
ffa0: c0014dc0 c009bcd0 0001a004 70616d6f bec2ab38 00000880 bec2ab38 00000880
ffc0: 0001a004 70616d6f b6fe0032 00000081 00000319 00000000 b6fe1000 00000000
ffe0: bec2ab30 bec2ab20 00019f00 b6f539c0 60070010 bec2ab38 aaaaaaaa aaaaaaaa
Backtrace:
[<c01122cc>] (cache_free_debugcheck+0x0/0x36c) from [<c0112efc>] (kfree+0xc8/0x2ac)
[<c0112e34>] (kfree+0x0/0x2ac) from [<bf0001fc>] (omap_nand_remove+0x5c/0x64 [omap2])
[<bf0001a0>] (omap_nand_remove+0x0/0x64 [omap2]) from [<c02ca11c>] (platform_drv_remove+0x28/0x2c)
r5:bf001ca8 r4:c0673778
[<c02ca0f4>] (platform_drv_remove+0x0/0x2c) from [<c02c82c4>] (__device_release_driver+0x80/0xdc)
[<c02c8244>] (__device_release_driver+0x0/0xdc) from [<c02c8dd8>] (driver_detach+0xc4/0xc8)
[<c02c8d14>] (driver_detach+0x0/0xc8) from [<c02c804c>] (bus_remove_driver+0x9c/0x104)
r6:c0804ee0 r5:bf001ca8 r4:bf001ca8 r3:00000000
[<c02c7fb0>] (bus_remove_driver+0x0/0x104) from [<c02c950c>] (driver_unregister+0x60/0x80)
r6:c521e000 r5:bf001ca8 r4:00000000 r3:bf001924
[<c02c94ac>] (driver_unregister+0x0/0x80) from [<c02ca3a4>] (platform_driver_unregister+0x1c/0x20)
r5:00000000 r4:bf001d48
[<c02ca388>] (platform_driver_unregister+0x0/0x20) from [<bf001938>] (omap_nand_driver_exit+0x14/0x1c [omap2])
[<bf001924>] (omap_nand_driver_exit+0x0/0x1c [omap2]) from [<c009beb4>] (sys_delete_module+0x1f0/0x2ec)
[<c009bcc4>] (sys_delete_module+0x0/0x2ec) from [<c0014dc0>] (ret_fast_syscall+0x0/0x48)
r8:c0015028 r7:00000081 r6:b6fe0032 r5:70616d6f r4:0001a004
Code: e1a00005 eb0d9172 e7f001f2 e7f001f2 (e7f001f2)
---[ end trace 6a30b24d8c0cc2ee ]---
Segmentation fault
--->8---
commit 7bb9c75436212813b38700c34df4bbb6eb82debe upstream.
The code responsible for reading the version of the mirror bbt was
incorrectly using the descriptor of the main bbt.
Pass the mirror bbt descriptor to 'scan_read_raw' when reading the
version of the mirror bbt.
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit bb0a13a13411c4ce24c48c8ff3cdf7b48d237240 upstream.
If override size is too big, the module was actually loaded instead of
failing, because retval was not set.
This lead to memory corruption with the use of the freed structs nandsim
and nand_chip.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
commit d1f55c680e5d021e7066f4461dd678d42af18898 upstream.
Update driver autcpu12-nvram.c so it compiles; map_read32/map_write32
no longer exist in the kernel so the driver is totally broken.
Additionally, map_info name passed to simple_map_init is incorrect.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
commit c51803ddba10d80d9f246066802c6e359cf1d44c upstream.
We may cause a memory leak when the @types has more then one parser.
Take the `default_mtd_part_types` for example. The default_mtd_part_types has
two parsers now: `cmdlinepart` and `ofpart`.
Assume the following case:
The kernel command line sets the partitions like:
#gpmi-nand:20m(boot),20m(kernel),1g(rootfs),-(user)
But the devicetree file(such as arch/arm/boot/dts/imx28-evk.dts) also sets
the same partitions as the kernel command line does.
In the current code, the partitions parsed out by the `ofpart` will
overwrite the @pparts which has already set by the `cmdlinepart` parser,
and the the partitions parsed out by the `cmdlinepart` is missed.
A memory leak occurs.
So we should break the code as soon as we parse out the partitions,
In actually, this patch makes a priority order between the parsers.
If one parser has already parsed out the partitions successfully,
it's no need to use another parser anymore.
Signed-off-by: Huang Shijie <shijie8@gmail.com>
This reverts 622ecb9ace2ec006b58f6779732961945ea303ca which is
commit 0d8957c8a90bbb5d34fab9a304459448a5131e06 upstream.
We may only start to set up the new register values after having
confirmed that the ring is truely off. Otherwise the hw might lose the
newly written register values. This is caught later on in the init
sequence, when we check whether the register writes have stuck.
Reported-by: Andreas Sturmlechner <andreas.sturmlechner@gmail.com>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: Yang Guang <guang.a.yang@intel.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
commit d35be8bab9b0ce44bed4b9453f86ebf64062721e upstream.
In the event of CPU hotplug, the kernel modifies the cpusets' cpus_allowed
masks as and when necessary to ensure that the tasks belonging to the cpusets
have some place (online CPUs) to run on. And regular CPU hotplug is
destructive in the sense that the kernel doesn't remember the original cpuset
configurations set by the user, across hotplug operations.
However, suspend/resume (which uses CPU hotplug) is a special case in which
the kernel has the responsibility to restore the system (during resume), to
exactly the same state it was in before suspend.
In order to achieve that, do the following:
1. Don't modify cpusets during suspend/resume. At all.
In particular, don't move the tasks from one cpuset to another, and
don't modify any cpuset's cpus_allowed mask. So, simply ignore cpusets
during the CPU hotplug operations that are carried out in the
suspend/resume path.
2. However, cpusets and sched domains are related. We just want to avoid
altering cpusets alone. So, to keep the sched domains updated, build
a single sched domain (containing all active cpus) during each of the
CPU hotplug operations carried out in s/r path, effectively ignoring
the cpusets' cpus_allowed masks.
(Since userspace is frozen while doing all this, it will go unnoticed.)
3. During the last CPU online operation during resume, build the sched
domains by looking up the (unaltered) cpusets' cpus_allowed masks.
That will bring back the system to the same original state as it was in
before suspend.
Ultimately, this will not only solve the cpuset problem related to suspend
resume (ie., restores the cpusets to exactly what it was before suspend, by
not touching it at all) but also speeds up suspend/resume because we avoid
running cpuset update code for every CPU being offlined/onlined.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20120524141611.3692.20155.stgit@srivatsabhat.in.ibm.com
Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
query_variable_info/update_capsule workable
commit d6cf86d8f23253225fe2a763d627ecf7dfee9dae upstream.
A value of efi.runtime_version is checked before calling
update_capsule()/query_variable_info() as follows.
But it isn't initialized anywhere.
<snip>
static efi_status_t virt_efi_query_variable_info(u32 attr,
u64 *storage_space,
u64 *remaining_space,
u64 *max_variable_size)
if (efi.runtime_version < EFI_2_00_SYSTEM_TABLE_REVISION)
return EFI_UNSUPPORTED;
<snip>
This patch initializes a value of efi.runtime_version at boot time.
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Acked-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Signed-off-by: Ivan Hu <ivan.hu@canonical.com>
commit 9dead5bbb825d7c25c0400e61de83075046322d0 upstream.
We can't assume the presence of the red zone while we're still in a boot
services environment, so we should build with -fno-red-zone to avoid
problems. Change the size of wchar at the same time to make string handling
simpler.
Acked-by: Josh Boyer <jwboyer@redhat.com>
This reverts commit b398aa3174cd. It
causes a regression with some versions of ipxe. 3.6 has other fixes
that cannot be backported to 3.5, so it is better to live with the
minor problem that b398aa3174cd fixes.
https://bugzilla.redhat.com/show_bug.cgi?id=854983
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 00442ad04a5eac08a98255697c510e708f6082e2 upstream.
Commit cc9a6c877661 ("cpuset: mm: reduce large amounts of memory barrier
related damage v3") introduced a potential memory corruption.
shmem_alloc_page() uses a pseudo vma and it has one significant unique
combination, vma->vm_ops=NULL and vma->policy->flags & MPOL_F_SHARED.
get_vma_policy() does NOT increase a policy ref when vma->vm_ops=NULL
and mpol_cond_put() DOES decrease a policy ref when a policy has
MPOL_F_SHARED. Therefore, when a cpuset update race occurs,
alloc_pages_vma() falls in 'goto retry_cpuset' path, decrements the
reference count and frees the policy prematurely.
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Josh Boyer <jwboyer@gmail.com>
commit 63f74ca21f1fad36d075e063f06dcc6d39fe86b2 upstream.
When shared_policy_replace() fails to allocate new->policy is not freed
correctly by mpol_set_shared_policy(). The problem is that shared
mempolicy code directly call kmem_cache_free() in multiple places where
it is easy to make a mistake.
This patch creates an sp_free wrapper function and uses it. The bug was
introduced pre-git age (IOW, before 2.6.12-rc2).
[mgorman@suse.de: Editted changelog]
commit b22d127a39ddd10d93deee3d96e643657ad53a49 upstream.
shared_policy_replace() use of sp_alloc() is unsafe. 1) sp_node cannot
be dereferenced if sp->lock is not held and 2) another thread can modify
sp_node between spin_unlock for allocating a new sp node and next
spin_lock. The bug was introduced before 2.6.12-rc2.
Kosaki's original patch for this problem was to allocate an sp node and
policy within shared_policy_replace and initialise it when the lock is
reacquired. I was not keen on this approach because it partially
duplicates sp_alloc(). As the paths were sp->lock is taken are not that
performance critical this patch converts sp->lock to sp->mutex so it can
sleep when calling sp_alloc().
[kosaki.motohiro@jp.fujitsu.com: Original patch]
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 869833f2c5c6e4dd09a5378cfc665ffb4615e5d2 upstream.
Dave Jones' system call fuzz testing tool "trinity" triggered the
following bug error with slab debugging enabled
BUG numa_policy (Not tainted): Poison overwritten
INFO: 0xffff880146498250-0xffff880146498250. First byte 0x6a instead of 0x6b
INFO: Allocated in mpol_new+0xa3/0x140 age=46310 cpu=6 pid=32154
__slab_alloc+0x3d3/0x445
kmem_cache_alloc+0x29d/0x2b0
mpol_new+0xa3/0x140
sys_mbind+0x142/0x620
system_call_fastpath+0x16/0x1b
INFO: Freed in __mpol_put+0x27/0x30 age=46268 cpu=6 pid=32154
__slab_free+0x2e/0x1de
kmem_cache_free+0x25a/0x260
remove_vma+0x68/0x90
exit_mmap+0x118/0x140
mmput+0x73/0x110
exit_mm+0x108/0x130
do_exit+0x162/0xb90
do_group_exit+0x4f/0xc0
sys_exit_group+0x17/0x20
INFO: Slab 0xffffea0005192600 objects=27 used=27 fp=0x (null) flags=0x20000000004080
INFO: Object 0xffff880146498250 @offset=592 fp=0xffff88014649b9d0
The problem is that the structure is being prematurely freed due to a
reference count imbalance. In the following case mbind(addr, len) should
replace the memory policies of both vma1 and vma2 and thus they will
become to share the same mempolicy and the new mempolicy will have the
MPOL_F_SHARED flag.
| vma1 | vma2(shmem) |
addr addr+len
alloc_pages_vma() uses get_vma_policy() and mpol_cond_put() pair for
maintaining the mempolicy reference count. The current rule is that
get_vma_policy() only increments refcount for shmem VMA and
mpol_conf_put() only decrements refcount if the policy has
MPOL_F_SHARED.
In above case, vma1 is not shmem vma and vma->policy has MPOL_F_SHARED!
The reference count will be decreased even though was not increased
whenever alloc_page_vma() is called. This has been broken since commit
[52cd3b07: mempolicy: rework mempolicy Reference Counting] in 2008.
There is another serious bug with the sharing of memory policies.
Currently, mempolicy rebind logic (it is called from cpuset rebinding)
ignores a refcount of mempolicy and override it forcibly. Thus, any
mempolicy sharing may cause mempolicy corruption. The bug was
introduced by commit [68860ec1: cpusets: automatic numa mempolicy
rebinding].
Ideally, the shared policy handling would be rewritten to either
properly handle COW of the policy structures or at least reference count
MPOL_F_SHARED based exclusively on information within the policy.
However, this patch takes the easier approach of disabling any policy
sharing between VMAs. Each new range allocated with sp_alloc will
allocate a new policy, set the reference count to 1 and drop the
reference count of the old policy. This increases the memory footprint
but is not expected to be a major problem as mbind() is unlikely to be
used for fine-grained ranges. It is also inefficient because it means
we allocate a new policy even in cases where mbind_range() could use the
new_policy passed to it. However, it is more straight-forward and the
change should be invisible to the user.
[mgorman@suse.de: Edited changelog]
Reported-by: Dave Jones <davej@redhat.com>,
Cc: Christoph Lameter <cl@linux.com>,
linkages"
commit 8d34694c1abf29df1f3c7317936b7e3e2e308d9b upstream.
Commit 05f144a0d5c2 ("mm: mempolicy: Let vma_merge and vma_split handle
vma->vm_policy linkages") removed vma->vm_policy updates code but it is
the purpose of mbind_range(). Now, mbind_range() is virtually a no-op
and while it does not allow memory corruption it is not the right fix.
This patch is a revert.
commit a10d206ef1a83121ab7430cb196e0376a7145b22 upstream.
Each grace period is supposed to have at least one callback waiting
for that grace period to complete. However, if CONFIG_NO_HZ=n, an
extra callback-free grace period is no big problem -- it will chew up
a tiny bit of CPU time, but it will complete normally. In contrast,
CONFIG_NO_HZ=y kernels have the potential for all the CPUs to go to
sleep indefinitely, in turn indefinitely delaying completion of the
callback-free grace period. Given that nothing is waiting on this grace
period, this is also not a problem.
That is, unless RCU CPU stall warnings are also enabled, as they are
in recent kernels. In this case, if a CPU wakes up after at least one
minute of inactivity, an RCU CPU stall warning will result. The reason
that no one noticed until quite recently is that most systems have enough
OS noise that they will never remain absolutely idle for a full minute.
But there are some embedded systems with cut-down userspace configurations
that consistently get into this situation.
All this begs the question of exactly how a callback-free grace period
gets started in the first place. This can happen due to the fact that
CPUs do not necessarily agree on which grace period is in progress.
If a CPU still believes that the grace period that just completed is
still ongoing, it will believe that it has callbacks that need to wait for
another grace period, never mind the fact that the grace period that they
were waiting for just completed. This CPU can therefore erroneously
decide to start a new grace period. Note that this can happen in
TREE_RCU and TREE_PREEMPT_RCU even on a single-CPU system: Deadlock
considerations mean that the CPU that detected the end of the grace
period is not necessarily officially informed of this fact for some time.
Once this CPU notices that the earlier grace period completed, it will
invoke its callbacks. It then won't have any callbacks left. If no
other CPU has any callbacks, we now have a callback-free grace period.
This commit therefore makes CPUs check more carefully before starting a
new grace period. This new check relies on an array of tail pointers
into each CPU's list of callbacks. If the CPU is up to date on which
grace periods have completed, it checks to see if any callbacks follow
the RCU_DONE_TAIL segment, otherwise it checks to see if any callbacks
follow the RCU_WAIT_TAIL segment. The reason that this works is that
the RCU_WAIT_TAIL segment will be promoted to the RCU_DONE_TAIL segment
as soon as the CPU is officially notified that the old grace period
has ended.
This change is to cpu_needs_another_gp(), which is called in a number
of places. The only one that really matters is in rcu_start_gp(), where
the root rcu_node structure's ->lock is held, which prevents any
other CPU from starting or completing a grace period, so that the
comparison that determines whether the CPU is missing the completion
of a grace period is stable.
Reported-by: Becky Bruce <bgillbruce@gmail.com>
Reported-by: Subodh Nijsure <snijsure@grid-net.com>
Reported-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Tested-by: Paul Walmsley <paul@pwsan.com> # OMAP3730, OMAP4430
commit 0ee23fda59740767324b4340247ca41a2f498ca6 upstream.
In the old times, the whole idle task was considered
as an RCU quiescent state. But as RCU became more and
more successful overtime, some RCU read side critical
section have been added even in the code of some
architectures idle tasks, for tracing for example.
So nowadays, rcu_idle_enter() and rcu_idle_exit() must
be called by the architecture to tell RCU about the part
in the idle loop that doesn't make use of rcu read side
critical sections, typically the part that puts the CPU
in low power mode.
This is necessary for RCU to find the quiescent states in
idle in order to complete grace periods.
Add this missing pair of calls in scores's idle loop.
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit 48ae077cfce72591b8fc80e1dcc87806f86fed7f upstream.
in low power mode.
Add this missing pair of calls in the m32r's idle loop.
Cc: Hirokazu Takata <takata@linux-m32r.org>
commit c633f9e788928e91ad11f44df29b47bbbe9550b0 upstream.
in low power mode.
Add this missing pair of calls in the Cris's idle loop.
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Cris <linux-cris-kernel@axis.com>
commit 4c94cada48f7c660eca582be6032427a5e367117 upstream.
in low power mode.
Add this missing pair of calls in the Alpha's idle loop.
Tested-by: Michael Cree <mcree@orcon.net.nz>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: alpha <linux-alpha@vger.kernel.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 5b57ba37e82a15f345a6a2eb8c01a2b2d94c5eeb upstream.
in low power mode.
Add this missing pair of calls in the m68k's idle loop.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: m68k <linux-m68k@lists.linux-m68k.org>
commit 5b0753a90b7a98bc613c3767e9263a1a76d4f900 upstream.
in low power mode.
Add this missing pair of calls in the mn10300's idle loop.
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
commit 41d8fe5bb3cf91ce2716ac8f43e4b40d802a99c8 upstream.
in low power mode.
Add this missing pair of calls in the Frv's idle loop.
commit 11ad47a0edbd62bfc0547cfcdf227a911433f207 upstream.
in low power mode.
Add this missing pair of calls in the xtensa's idle loop.
Cc: Chris Zankel <chris@zankel.net>
commit fbe752188d5589e7fcbb8e79824e560f77dccc92 upstream.
in low power mode.
Add this missing pair of calls in the parisc's idle loop.
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Parisc <linux-parisc@vger.kernel.org>
commit b2fe1430d4115c74d007c825cb9dc3317f28bb16 upstream.
in low power mode.
Add this missing pair of calls in the h8300's idle loop.
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
commit 93482f4ef1093f5961a63359a34612183d6beea0 upstream.
Traditionally, the entire idle task served as an RCU quiescent state.
But when RCU read side critical sections started appearing within the
idle loop, this traditional strategy became untenable. The fix was to
create new RCU APIs named rcu_idle_enter() and rcu_idle_exit(), which
must be called by each architecture's idle loop so that RCU can tell
when it is safe to ignore a given idle CPU.
Unfortunately, this fix was never applied to ia64, a shortcoming remedied
by this commit.
Reported by: Tony Luck <tony.luck@intel.com>
Tested by: Tony Luck <tony.luck@intel.com>
commit f8f2ac9a76b0f80a6763ca316116a7bab8486997 upstream.
I can't even find how I figured this might be needed anymore. But sure
enough, the value I'm reading back on platforms doesn't match what the
docs recommends.
It seemed to fix Chris' GT1 in limited testing as well.
Tested-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 74d44445afb9f50126eba052adeb89827cee88f3 upstream.
... since finish_page_flip needs the vblank timestamp generated
in drm_handle_vblank. Somehow all the gmch platforms get it right,
but all the pch platform irq handlers get is wrong. Hooray for copy&
pasting!
Currently this gets papered over by a gross hack in finish_page_flip.
A second patch will remove that.
Note that without this, the new timestamp sanity checks in flip_test
occasionally get tripped up, hence the cc: stable tag.
Reviewed-by: mario.kleiner@tuebingen.mpg.de
Tested-by: Imre Deak <imre.deak@intel.com>
commit 5bb61643f6a70d48de9cfe91ad0fee0d618b6816 upstream.
This was meant to be the purpose of the
intel_crtc_wait_for_pending_flips() function which is called whilst
preparing the CRTC for a modeset or before disabling. However, as Ville
Syrjala pointed out, we set the pending flip notification on the old
framebuffer that is no longer attached to the CRTC by the time we come
to flush the pending operations. Instead, we can simply wait on the
pending unpin work to be finished on this CRTC, knowning that the
hardware has therefore finished modifying the registers, before proceeding
with our direct access.
Fixes i-g-t/flip_test on non-pch platforms. pch platforms simply
schedule the flip immediately when the pipe is disabled, leading
to other funny issues.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
[danvet: Added i-g-t note and cc: stable]
commit fb6ca6d154cdcd53e7f27f8dbba513830372699b upstream.
There are so many quirks, lets just try and force
this for all RS690s. See:
https://bugs.freedesktop.org/show_bug.cgi?id=37679
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 3a6d59df80897cc87812b6826d70085905bed013 upstream.
Fixes another system on:
commit 2e3b3b105ab3bb5b6a37198da4f193cd13781d13 upstream.
SI asics store voltage information differently so we
don't have a way to deal with it properly yet.
commit 3184009c36da413724f283e3c7ac9cc60c623bc4 upstream.
As during the plane cleanup, we wish to disable the hardware and
so may modify state on the associated CRTC, that CRTC must continue to
exist until we are finished.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=54101
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Tested-by: lu hua <huax.lu@intel.com>
commit d6ba6d215a538a58f0f0026f0961b0b9125e8042 upstream.
Fixes some unfortunate races on resume. The G84 version of the code doesn't
need this as "gpuobj"s are automagically suspended/resumed by the core code
whereas pinned buffer objects are not.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit c05fce586d4da2dfe0309bef3795a8586e967bc3 upstream.
Added support for Xbox Communicator to USB quirks.
Signed-off-by: Marko Friedemann <mfr@bmx-chemnitz.de>
commit c10514394ef9e8de93a4ad8c8904d71dcd82c122 upstream.
While going through Ubuntu bugs, I discovered this patch being
posted and a confirmation that the patch works as expected.
Finding out how the hw volume really works would be preferrable
to just disabling the broken one, but this would be better than
nothing.
Credit: sndfnsdfin (qawsnews)
BugLink: https://bugs.launchpad.net/bugs/559939
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 4b527b6516ab1f0af8aaedd02dbf71ee2c1180f4 upstream.
When the input gain for the internal mic is set to its maximum level,
the background noise becomes so high - and any relevant signal clipped -
that the setting becomes unusable. It is better to limit the amplification.
BugLink: https://bugs.launchpad.net/bugs/1052460
commit 9f720bb9409ea5923361fbd3fdbc505ca36cf012 upstream.
In commit af741c1 ("ALSA: hda/realtek - Call alc_auto_parse_customize_define()
always after fixup"), alc_auto_parse_customize_define was moved after
detection of ALC271X.
The problem is that detection of ALC271X relies on spec->cdefine.platform_type,
and it's set on alc_auto_parse_customize_define.
Move the alc_auto_parse_customize_define and its required fixup setup
before the block doing the ALC271X and other codec setup.
BugLink: https://bugs.launchpad.net/bugs/1006690
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Reviewed-by: David Henningsson <david.henningsson@canonical.com>
commit d4f1e48bd11e3df6a26811f7a1f06c4225d92f7d upstream.
When the loopback timer handler is running, calling del_timer() (for STOP
trigger) will not wait for the handler to complete before deactivating the
timer. The timer gets rescheduled in the handler as usual. Then a subsequent
START trigger will try to start the timer using add_timer() with a timer pending
leading to a kernel panic.
Serialize the calls to add_timer() and del_timer() using a spin lock to avoid
this.
Signed-off-by: Omair Mohammed Abdullah <omair.m.abdullah@linux.intel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
commit e4db0952e542090c605fd41d31d761f1b4624f4a upstream.
The Lenovo IdeaPad U310 has an internal mic where the right channel
is phase inverted.
Signed-off-by: Felix Kaechele <felix@fetzig.org>
commit ab3951eb74e7c33a2f5b7b64d72e82f1eea61571 upstream.
We should not hit this under any sane conditions, but still, this does not
looks right.
Reported-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
CC: Chris Wilson <chris@chris-wilson.co.uk>
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Chris Wlison <chris@chris-wilson.co.uk>
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
