2012-08-15Linux 3.4.9v3.4.9Greg Kroah-Hartman
2012-08-15rt61pci: fix NULL pointer dereference in config_lna_gainStanislaw Gruszka
commit deee0214def5d8a32b8112f11d9c2b1696e9c0cb upstream. We can not pass NULL libconf->conf->channel to rt61pci_config() as it is dereferenced unconditionally in rt61pci_config_lna_gain() subroutine. Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=44361 Reported-and-tested-by: <dolohow@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15Input: wacom - Bamboo One 1024 pressure fixChris Bagwell
commit 6dc463511d4a690f01a9248df3b384db717e0b1c upstream. Bamboo One's with ID of 0x6a and 0x6b were added with correct indication of 1024 pressure levels but the Graphire packet routine was only looking at 9 bits. Increased to 10 bits. This bug caused these devices to roll over to zero pressure at half way mark. The other devices using this routine only support 256 or 512 range and look to fix unused bits at zero. Signed-off-by: Chris Bagwell <chris@cnpbagwell.com> Reported-by: Tushant Mirchandani <tushantin@gmail.com> Reviewed-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15Input: eeti_ts: pass gpio value instead of IRQArnd Bergmann
commit 4eef6cbfcc03b294d9d334368a851b35b496ce53 upstream. The EETI touchscreen asserts its IRQ line as soon as it has data in its internal buffers. The line is automatically deasserted once all data has been read via I2C. Hence, the driver has to monitor the GPIO line and cannot simply rely on the interrupt handler reception. In the current implementation of the driver, irq_to_gpio() is used to determine the GPIO number from the i2c_client's IRQ value. As irq_to_gpio() is not available on all platforms, this patch changes this and makes the driver ignore the passed in IRQ. Instead, a GPIO is added to the platform_data struct and gpio_to_irq is used to derive the IRQ from that GPIO. If this fails, bail out. The driver is only able to work in environments where the touchscreen GPIO can be mapped to an IRQ. Without this patch, building raumfeld_defconfig results in: drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active': drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration] Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Sven Neumann <s.neumann@raumfeld.com> Cc: linux-input@vger.kernel.org Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15e1000e: NIC goes up and immediately goes downTushar Dave
commit b7ec70be01a87f2c85df3ae11046e74f9b67e323 upstream. Found that commit d478eb44 was a bad commit. If the link partner is transmitting codeword (even if NULL codeword), then the RXCW.C bit will be set so check for RXCW.CW is unnecessary. Ref: RH BZ 840642 Reported-by: Fabio Futigami <ffutigam@redhat.com> Signed-off-by: Tushar Dave <tushar.n.dave@intel.com> CC: Marcelo Ricardo Leitner <mleitner@redhat.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15iwlwifi: disable greenfield transmissions as a workaroundJohannes Berg
commit 50e2a30cf6fcaeb2d27360ba614dd169a10041c5 upstream. There's a bug that causes the rate scaling to get stuck when it has to use single-stream rates with a peer that can do GF and SGI; the two are incompatible so we can't use them together, but that causes the algorithm to not work at all, it always rejects updates. Disable greenfield for now to prevent that problem. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Tested-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15tun: don't zeroize sock->file on detachStanislav Kinsbursky
commit 66d1b9263a371abd15806c53f486f0645ef31a8f upstream. This is a fix for bug, introduced in 3.4 kernel by commit 1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d ("tun: don't hold network namespace by tun sockets"), which, among other things, replaced simple sock_put() by sk_release_kernel(). Below is sequence, which leads to oops for non-persistent devices: tun_chr_close() tun_detach() <== tun->socket.file = NULL tun_free_netdev() sk_release_sock() sock_release(sock->file == NULL) iput(SOCK_INODE(sock)) <== dereference on NULL pointer This patch just removes zeroing of socket's file from __tun_detach(). sock_release() will do this. Reported-by: Ruan Zhijie <ruanzhijie@hotmail.com> Tested-by: Ruan Zhijie <ruanzhijie@hotmail.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15cfg80211: fix interface combinations check for ADHOC(IBSS)Liang Li
partial of commit 8e8b41f9d8c8e63fc92f899ace8da91a490ac573 upstream. As part of commit 463454b5dbd8 ("cfg80211: fix interface combinations check"), this extra check was introduced: if ((all_iftypes & used_iftypes) != used_iftypes) goto cont; However, most wireless NIC drivers did not advertise ADHOC in wiphy.iface_combinations[i].limits[] and hence we'll get -EBUSY when we bring up a ADHOC wlan with commands similar to: # iwconfig wlan0 mode ad-hoc && ifconfig wlan0 up In commit 8e8b41f9d8c8e ("cfg80211: enforce lack of interface combinations"), the change below fixes the issue: if (total == 1) return 0; But it also introduces other dependencies for stable. For example, a full cherry pick of 8e8b41f9d8c8e would introduce additional regressions unless we also start cherry picking driver specific fixes like the following: 9b4760e ath5k: add possible wiphy interface combinations 1ae2fc2 mac80211_hwsim: advertise interface combinations 20c8e8d ath9k: add possible wiphy interface combinations And the purpose of the 'if (total == 1)' is to cover the specific use case (IBSS, adhoc) that was mentioned above. So we just pick the specific part out from 8e8b41f9d8c8e here. Doing so gives stable kernels a way to fix the change introduced by 463454b5dbd8, without having to make cherry picks specific to various NIC drivers. Signed-off-by: Liang Li <liang.li@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15cfg80211: process pending events when unregistering net deviceDaniel Drake
commit 1f6fc43e621167492ed4b7f3b4269c584c3d6ccc upstream. libertas currently calls cfg80211_disconnected() when it is being brought down. This causes an event to be allocated, but since the wdev is already removed from the rdev by the time that the event processing work executes, the event is never processed or freed. http://article.gmane.org/gmane.linux.kernel.wireless.general/95666 Fix this leak, and other possible situations, by processing the event queue when a device is being unregistered. Thanks to Johannes Berg for the suggestion. Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ARM: pxa: remove irq_to_gpio from ezx-pcap driverArnd Bergmann
commit 59ee93a528b94ef4e81a08db252b0326feff171f upstream. The irq_to_gpio function was removed from the pxa platform in linux-3.2, and this driver has been broken since. There is actually no in-tree user of this driver that adds this platform device, but the driver can and does get enabled on some platforms. Without this patch, building ezx_defconfig results in: drivers/mfd/ezx-pcap.c: In function 'pcap_isr_work': drivers/mfd/ezx-pcap.c:205:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ARM: dts: imx53-ard: add regulators for lan9220Shawn Guo
commit 1eec0c569523782392b5e6245effddb626213b8c upstream. Since commit c7e963f (net/smsc911x: Add regulator support), the lan9220 device tree probe fails on imx53-ard board, because the commit makes VDD33A and VDDVARIO supplies mandatory for the driver. Add a fixed dummy 3V3 supplying lan9220 to fix the regression. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ARM: mxs: Remove MMAP_MIN_ADDR setting from mxs_defconfigMarek Vasut
commit 3bed491c8d28329e34f8a31e3fe64d03f3a350f1 upstream. The CONFIG_DEFAULT_MMAP_MIN_ADDR was set to 65536 in mxs_defconfig, this caused severe breakage of userland applications since the upper limit for ARM is 32768. By default CONFIG_DEFAULT_MMAP_MIN_ADDR is set to 4096 and can also be changed via /proc/sys/vm/mmap_min_addr if needed. Quoting Russell King [1]: "4096 is also fine for ARM too. There's not much point in having defconfigs change it - that would just be pure noise in the config files." the CONFIG_DEFAULT_MMAP_MIN_ADDR can be removed from the defconfig altogether. This problem was introduced by commit cde7c41 (ARM: configs: add defconfig for mach-mxs). [1] http://marc.info/?l=linux-arm-kernel&m=134401593807820&w=2 Signed-off-by: Marek Vasut <marex@denx.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15target: Check number of unmap descriptors against our limitRoland Dreier
commit 7409a6657aebf8be74c21d0eded80709b27275cb upstream. Fail UNMAP commands that have more than our reported limit on unmap descriptors. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> [bwh: Backported to 3.2: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15target: Fix possible integer underflow in UNMAP emulationRoland Dreier
commit b7fc7f3777582dea85156a821d78a522a0c083aa upstream. It's possible for an initiator to send us an UNMAP command with a descriptor that is less than 8 bytes; in that case it's really bad for us to set an unsigned int to that value, subtract 8 from it, and then use that as a limit for our loop (since the value will wrap around to a huge positive value). Fix this by making size be signed and only looping if size >= 16 (ie if we have at least a full descriptor available). Also remove offset as an obfuscated name for the constant 8. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> [bwh: Backported to 3.2: adjust filename, context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15target: Fix reading of data length fields for UNMAP commandsRoland Dreier
commit 1a5fa4576ec8a462313c7516b31d7453481ddbe8 upstream. The UNMAP DATA LENGTH and UNMAP BLOCK DESCRIPTOR DATA LENGTH fields are in the unmap descriptor (the payload transferred to our data out buffer), not in the CDB itself. Read them from the correct place in target_emulated_unmap. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> [bwh: Backported to 3.2: adjust filename, context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15target: Add range checking to UNMAP emulationRoland Dreier
commit 2594e29865c291db162313187612cd9f14538f33 upstream. When processing an UNMAP command, we need to make sure that the number of blocks we're asked to UNMAP does not exceed our reported maximum number of blocks per UNMAP, and that the range of blocks we're unmapping doesn't go past the end of the device. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> [bwh: Backported to 3.2: adjust filename, context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: hugetlbfs: close race during teardown of hugetlbfs shared page tablesMel Gorman
commit d833352a4338dc31295ed832a30c9ccff5c7a183 upstream. If a process creates a large hugetlbfs mapping that is eligible for page table sharing and forks heavily with children some of whom fault and others which destroy the mapping then it is possible for page tables to get corrupted. Some teardowns of the mapping encounter a "bad pmd" and output a message to the kernel log. The final teardown will trigger a BUG_ON in mm/filemap.c. This was reproduced in 3.4 but is known to have existed for a long time and goes back at least as far as 2.6.37. It was probably was introduced in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages look like this; [ ..........] Lots of bad pmd messages followed by this [ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7). [ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7). [ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7). [ 127.186778] ------------[ cut here ]------------ [ 127.186781] kernel BUG at mm/filemap.c:134! [ 127.186782] invalid opcode: 0000 [#1] SMP [ 127.186783] CPU 7 [ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod [ 127.186801] [ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR [ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160 [ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002 [ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0 [ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00 [ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003 [ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8 [ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8 [ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000 [ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0 [ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0) [ 127.186821] Stack: [ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b [ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98 [ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000 [ 127.186827] Call Trace: [ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80 [ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220 [ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30 [ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0 [ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0 [ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50 [ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130 [ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0 [ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230 [ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150 [ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30 [ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80 [ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360 [ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170 [ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b [ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0 [ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160 [ 127.186870] RSP <ffff8804144b5c08> [ 127.186871] ---[ end trace 7cbac5d1db69f426 ]--- The bug is a race and not always easy to reproduce. To reproduce it I was doing the following on a single socket I7-based machine with 16G of RAM. $ hugeadm --pool-pages-max DEFAULT:13G $ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax $ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall $ for i in `seq 1 9000`; do ./hugetlbfs-test; done On my particular machine, it usually triggers within 10 minutes but enabling debug options can change the timing such that it never hits. Once the bug is triggered, the machine is in trouble and needs to be rebooted. The machine will respond but processes accessing proc like "ps aux" will hang due to the BUG_ON. shutdown will also hang and needs a hard reset or a sysrq-b. The basic problem is a race between page table sharing and teardown. For the most part page table sharing depends on i_mmap_mutex. In some cases, it is also taking the mm->page_table_lock for the PTE updates but with shared page tables, it is the i_mmap_mutex that is more important. Unfortunately it appears to be also insufficient. Consider the following situation Process A Process B --------- --------- hugetlb_fault shmdt LockWrite(mmap_sem) do_munmap unmap_region unmap_vmas unmap_single_vma unmap_hugepage_range Lock(i_mmap_mutex) Lock(mm->page_table_lock) huge_pmd_unshare/unmap tables <--- (1) Unlock(mm->page_table_lock) Unlock(i_mmap_mutex) huge_pte_alloc ... Lock(i_mmap_mutex) ... vma_prio_walk, find svma, spte ... Lock(mm->page_table_lock) ... share spte ... Unlock(mm->page_table_lock) ... Unlock(i_mmap_mutex) ... hugetlb_no_page <--- (2) free_pgtables unlink_file_vma hugetlb_free_pgd_range remove_vma_list In this scenario, it is possible for Process A to share page tables with Process B that is trying to tear them down. The i_mmap_mutex on its own does not prevent Process A walking Process B's page tables. At (1) above, the page tables are not shared yet so it unmaps the PMDs. Process A sets up page table sharing and at (2) faults a new entry. Process B then trips up on it in free_pgtables. This patch fixes the problem by adding a new function __unmap_hugepage_range_final that is only called when the VMA is about to be destroyed. This function clears VM_MAYSHARE during unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA ineligible for sharing and avoids the race. Superficially this looks like it would then be vunerable to truncate and madvise issues but hugetlbfs has its own truncate handlers so does not use unmap_mapping_range() and does not support madvise(DONTNEED). This should be treated as a -stable candidate if it is merged. Test program is as follows. The test case was mostly written by Michal Hocko with a few minor changes to reproduce this bug. ==== CUT HERE ==== static size_t huge_page_size = (2UL << 20); static size_t nr_huge_page_A = 512; static size_t nr_huge_page_B = 5632; unsigned int get_random(unsigned int max) { struct timeval tv; gettimeofday(&tv, NULL); srandom(tv.tv_usec); return random() % max; } static void play(void *addr, size_t size) { unsigned char *start = addr, *end = start + size, *a; start += get_random(size/2); /* we could itterate on huge pages but let's give it more time. */ for (a = start; a < end; a += 4096) *a = 0; } int main(int argc, char **argv) { key_t key = IPC_PRIVATE; size_t sizeA = nr_huge_page_A * huge_page_size; size_t sizeB = nr_huge_page_B * huge_page_size; int shmidA, shmidB; void *addrA = NULL, *addrB = NULL; int nr_children = 300, n = 0; if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) { perror("shmget:"); return 1; } if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) { perror("shmat"); return 1; } if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) { perror("shmget:"); return 1; } if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) { perror("shmat"); return 1; } fork_child: switch(fork()) { case 0: switch (n%3) { case 0: play(addrA, sizeA); break; case 1: play(addrB, sizeB); break; case 2: break; } break; case -1: perror("fork:"); break; default: if (++n < nr_children) goto fork_child; play(addrA, sizeA); break; } shmdt(addrA); shmdt(addrB); do { wait(NULL); } while (--n > 0); shmctl(shmidA, IPC_RMID, NULL); shmctl(shmidB, IPC_RMID, NULL); return 0; } [akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build] Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15x86, microcode: Sanitize per-cpu microcode reloading interfaceBorislav Petkov
commit c9fc3f778a6a215ace14ee556067c73982b6d40f upstream. Microcode reloading in a per-core manner is a very bad idea for both major x86 vendors. And the thing is, we have such interface with which we can end up with different microcode versions applied on different cores of an otherwise homogeneous wrt (family,model,stepping) system. So turn off the possibility of doing that per core and allow it only system-wide. This is a minimal fix which we'd like to see in stable too thus the more-or-less arbitrary decision to allow system-wide reloading only on the BSP: $ echo 1 > /sys/devices/system/cpu/cpu0/microcode/reload ... and disable the interface on the other cores: $ echo 1 > /sys/devices/system/cpu/cpu23/microcode/reload -bash: echo: write error: Invalid argument Also, allowing the reload only from one CPU (the BSP in that case) doesn't allow the reload procedure to degenerate into an O(n^2) deal when triggering reloads from all /sys/devices/system/cpu/cpuX/microcode/reload sysfs nodes simultaneously. A more generic fix will follow. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1340280437-7718-2-git-send-email-bp@amd64.org Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15x86, microcode: microcode_core.c simple_strtoul cleanupShuah Khan
commit e826abd523913f63eb03b59746ffb16153c53dc4 upstream. Change reload_for_cpu() in kernel/microcode_core.c to call kstrtoul() instead of calling obsoleted simple_strtoul(). Signed-off-by: Shuah Khan <shuahkhan@gmail.com> Reviewed-by: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/1336324264.2897.9.camel@lorien2 Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15HID: add ASUS AIO keyboard model AK1DCyrus Lien
commit 2d8767bb421574dfcf48e4be0751ce7d8f73d5d7 upstream. Add Asus All-In-One PC keyboard model AK1D. BugLink: https://bugs.launchpad.net/bugs/1027789 Signed-off-by: Cyrus Lien <cyrus.lien@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15HID: add support for Cypress barcode scanner 04B4:ED81Lionel Vaux
commit 76c9d8fe2c7fc34ffc387d8022c5828d6ff9df48 upstream. Add yet another device to the list of Cypress barcode scanners needing the CP_RDESC_SWAPPED_MIN_MAX quirk. Signed-off-by: Lionel Vaux (iouri) <lionel.vaux@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15HID: multitouch: add support for Novatek touchscreenAustin Hendrix
commit 4db703ead4535792ea54dba7275fdd1527848e74 upstream. Add support for a Novatek touchscreen panel as a generic HID multitouch panel. Signed-off-by: Austin Hendrix <ahendrix@willowgarage.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: mix in architectural randomness in extract_buf()H. Peter Anvin
commit d2e7c96af1e54b507ae2a6a7dd2baf588417a7e5 upstream. Mix in any architectural randomness in extract_buf() instead of xfer_secondary_buf(). This allows us to mix in more architectural randomness, and it also makes xfer_secondary_buf() faster, moving a tiny bit of additional CPU overhead to process which is extracting the randomness. [ Commit description modified by tytso to remove an extended advertisement for the RDRAND instruction. ] Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: DJ Johnston <dj.johnston@intel.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15dmi: Feed DMI table to /dev/random driverTony Luck
commit d114a33387472555188f142ed8e98acdb8181c6d upstream. Send the entire DMI (SMBIOS) table to the /dev/random driver to help seed its pools. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: Add comment to random_initialize()Tony Luck
commit cbc96b7594b5691d61eba2db8b2ea723645be9ca upstream. Many platforms have per-machine instance data (serial numbers, asset tags, etc.) squirreled away in areas that are accessed during early system bringup. Mixing this data into the random pools has a very high value in providing better random data, so we should allow (and even encourage) architecture code to call add_device_randomness() from the setup_arch() paths. However, this limits our options for internal structure of the random driver since random_initialize() is not called until long after setup_arch(). Add a big fat comment to rand_initialize() spelling out this requirement. Suggested-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: remove rand_initialize_irq()Theodore Ts'o
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream. With the new interrupt sampling system, we are no longer using the timer_rand_state structure in the irq descriptor, so we can stop initializing it now. [ Merged in fixes from Sedat to find some last missing references to rand_initialize_irq() ] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mfd: wm831x: Feed the device UUID into device_add_randomness()Mark Brown
commit 27130f0cc3ab97560384da437e4621fc4e94f21c upstream. wm831x devices contain a unique ID value. Feed this into the newly added device_add_randomness() to add some per device seed data to the pool. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15rtc: wm831x: Feed the write counter into device_add_randomness()Mark Brown
commit 9dccf55f4cb011a7552a8a2749a580662f5ed8ed upstream. The tamper evident features of the RTC include the "write counter" which is a pseudo-random number regenerated whenever we set the RTC. Since this value is unpredictable it should provide some useful seeding to the random number generator. Only do this on boot since the goal is to seed the pool rather than add useful entropy. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15MAINTAINERS: Theodore Ts'o is taking over the random driverTheodore Ts'o
commit 330e0a01d54c2b8606c56816f99af6ebc58ec92c upstream. Matt Mackall stepped down as the /dev/random driver maintainer last year, so Theodore Ts'o is taking back the /dev/random driver. Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: add tracepoints for easier debugging and verificationTheodore Ts'o
commit 00ce1db1a634746040ace24c09a4e3a7949a3145 upstream. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: add new get_random_bytes_arch() functionTheodore Ts'o
commit c2557a303ab6712bb6e09447df828c557c710ac9 upstream. Create a new function, get_random_bytes_arch() which will use the architecture-specific hardware random number generator if it is present. Change get_random_bytes() to not use the HW RNG, even if it is avaiable. The reason for this is that the hw random number generator is fast (if it is present), but it requires that we trust the hardware manufacturer to have not put in a back door. (For example, an increasing counter encrypted by an AES key known to the NSA.) It's unlikely that Intel (for example) was paid off by the US Government to do this, but it's impossible for them to prove otherwise --- especially since Bull Mountain is documented to use AES as a whitener. Hence, the output of an evil, trojan-horse version of RDRAND is statistically indistinguishable from an RDRAND implemented to the specifications claimed by Intel. Short of using a tunnelling electronic microscope to reverse engineer an Ivy Bridge chip and disassembling and analyzing the CPU microcode, there's no way for us to tell for sure. Since users of get_random_bytes() in the Linux kernel need to be able to support hardware systems where the HW RNG is not present, most time-sensitive users of this interface have already created their own cryptographic RNG interface which uses get_random_bytes() as a seed. So it's much better to use the HW RNG to improve the existing random number generator, by mixing in any entropy returned by the HW RNG into /dev/random's entropy pool, but to always _use_ /dev/random's entropy pool. This way we get almost of the benefits of the HW RNG without any potential liabilities. The only benefits we forgo is the speed/performance enhancements --- and generic kernel code can't depend on depend on get_random_bytes() having the speed of a HW RNG anyway. For those places that really want access to the arch-specific HW RNG, if it is available, we provide get_random_bytes_arch(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: use the arch-specific rng in xfer_secondary_poolTheodore Ts'o
commit e6d4947b12e8ad947add1032dd754803c6004824 upstream. If the CPU supports a hardware random number generator, use it in xfer_secondary_pool(), where it will significantly improve things and where we can afford it. Also, remove the use of the arch-specific rng in add_timer_randomness(), since the call is significantly slower than get_cycles(), and we're much better off using it in xfer_secondary_pool() anyway. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15net: feed /dev/random with the MAC address when registering a deviceTheodore Ts'o
commit 7bf2357524408b97fec58344caf7397f8140c3fd upstream. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: David Miller <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15usb: feed USB device information to the /dev/random driverTheodore Ts'o
commit b04b3156a20d395a7faa8eed98698d1e17a36000 upstream. Send the USB device's serial, product, and manufacturer strings to the /dev/random driver to help seed its pools. Cc: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: create add_device_randomness() interfaceLinus Torvalds
commit a2080a67abe9e314f9e9c2cc3a4a176e8a8f8793 upstream. Add a new interface, add_device_randomness() for adding data to the random pool that is likely to differ between two devices (or possibly even per boot). This would be things like MAC addresses or serial numbers, or the read-out of the RTC. This does *not* add any actual entropy to the pool, but it initializes the pool to different values for devices that might otherwise be identical and have very little entropy available to them (particularly common in the embedded world). [ Modified by tytso to mix in a timestamp, since there may be some variability caused by the time needed to detect/configure the hardware in question. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: use lockless techniques in the interrupt pathTheodore Ts'o
commit 902c098a3663de3fa18639efbb71b6080f0bcd3c upstream. The real-time Linux folks don't like add_interrupt_randomness() taking a spinlock since it is called in the low-level interrupt routine. This also allows us to reduce the overhead in the fast path, for the random driver, which is the interrupt collection path. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: make 'add_interrupt_randomness()' do something saneTheodore Ts'o
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream. We've been moving away from add_interrupt_randomness() for various reasons: it's too expensive to do on every interrupt, and flooding the CPU with interrupts could theoretically cause bogus floods of entropy from a somewhat externally controllable source. This solves both problems by limiting the actual randomness addition to just once a second or after 64 interrupts, whicever comes first. During that time, the interrupt cycle data is buffered up in a per-cpu pool. Also, we make sure the the nonblocking pool used by urandom is initialized before we start feeding the normal input pool. This assures that /dev/urandom is returning unpredictable data as soon as possible. (Based on an original patch by Linus, but significantly modified by tytso.) Tested-by: Eric Wustrow <ewust@umich.edu> Reported-by: Eric Wustrow <ewust@umich.edu> Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu> Reported-by: Zakir Durumeric <zakir@umich.edu> Reported-by: J. Alex Halderman <jhalderm@umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15x86, nops: Missing break resulting in incorrect selection on IntelAlan Cox
commit d6250a3f12edb3a86db9598ffeca3de8b4a219e9 upstream. The Intel case falls through into the generic case which then changes the values. For cases like the P6 it doesn't do the right thing so this seems to be a screwup. Signed-off-by: Alan Cox <alan@linux.intel.com> Link: http://lkml.kernel.org/n/tip-lww2uirad4skzjlmrm0vru8o@git.kernel.org Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15wireless: reg: restore previous behaviour of chan->max_power calculationsStanislaw Gruszka
commit 5e31fc0815a4e2c72b1b495fe7a0d8f9bfb9e4b4 upstream. commit eccc068e8e84c8fe997115629925e0422a98e4de Author: Hong Wu <Hong.Wu@dspg.com> Date: Wed Jan 11 20:33:39 2012 +0200 wireless: Save original maximum regulatory transmission power for the calucation of the local maximum transmit pow changed the way we calculate chan->max_power as min(chan->max_power, chan->max_reg_power). That broke rt2x00 (and perhaps some other drivers) that do not set chan->max_power. It is not so easy to fix this problem correctly in rt2x00. According to commit eccc068e8 changelog, change claim only to save maximum regulatory power - changing setting of chan->max_power was side effect. This patch restore previous calculations of chan->max_power and do not touch chan->max_reg_power. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ath9k: Add PID/VID support for AR1111Mohammed Shafi Shajakhan
commit d4e5979c0da95791aa717c18e162540c7a596360 upstream. AR1111 is same as AR9485. The h/w difference between them is quite insignificant, Felix suggests only very few baseband features may not be available in AR1111. The h/w code for AR9485 is already present, so AR1111 should work fine with the addition of its PID/VID. Reported-by: Tim Bentley <Tim.Bentley@Gmail.com> Cc: Felix Bitterli <felixb@qca.qualcomm.com> Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Tested-by: Tim Bentley <Tim.Bentley@Gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mac80211: cancel mesh path timerJohannes Berg
commit dd4c9260e7f23f2e951cbfb2726e468c6d30306c upstream. The mesh path timer needs to be canceled when leaving the mesh as otherwise it could fire after the interface has been removed already. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ACPI processor: Fix tick_broadcast_mask online/offline regressionFeng Tang
commit b7db60f45d74497c723dc7ae1370cf0b37dfb0d8 upstream. In commit 99b725084 "ACPI processor hotplug: Delay acpi_processor_start() call for hotplugged cores", acpi_processor_hotplug(pr) was wrongly replaced by acpi_processor_cst_has_changed() inside the acpi_cpu_soft_notify(). This patch will restore it back, fixing the tick_broadcast_mask regression: https://lkml.org/lkml/2012/7/30/169 Signed-off-by: Feng Tang <feng.tang@intel.com> Cc: Thomas Renninger <trenn@suse.de> Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ore: Fix out-of-bounds access in _ios_obj()Boaz Harrosh
commit 9e62bb4458ad2cf28bd701aa5fab380b846db326 upstream. _ios_obj() is accessed by group_index not device_table index. The oc->comps array is only a group_full of devices at a time it is not like ore_comp_dev() which is indexed by a global device_table index. This did not BUG until now because exofs only uses a single COMP for all devices. But with other FSs like PanFS this is not true. This bug was only in the write_path, all other users were using it correctly [This is a bug since 3.2 Kernel] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15video/smscufx: fix line counting in fb_writeAlexander Holler
commit 2fe2d9f47cfe1a3e66e7d087368b3d7155b04c15 upstream. Line 0 and 1 were both written to line 0 (on the display) and all subsequent lines had an offset of -1. The result was that the last line on the display was never overwritten by writes to /dev/fbN. The origin of this bug seems to have been udlfb. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15md/raid1: don't abort a resync on the first badblock.NeilBrown
commit b7219ccb33aa0df9949a60c68b5e9f712615e56f upstream. If a resync of a RAID1 array with 2 devices finds a known bad block one device it will neither read from, or write to, that device for this block offset. So there will be one read_target (The other device) and zero write targets. This condition causes md/raid1 to abort the resync assuming that it has finished - without known bad blocks this would be true. When there are no write targets because of the presence of bad blocks we should only skip over the area covered by the bad block. RAID10 already gets this right, raid1 doesn't. Or didn't. As this can cause a 'sync' to abort early and appear to have succeeded it could lead to some data corruption, so it suitable for -stable. Reported-by: Alexander Lyakas <alex.bolshoy@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: mmu_notifier: fix freed page still mapped in secondary MMUXiao Guangrong
commit 3ad3d901bbcfb15a5e4690e55350db0899095a68 upstream. mmu_notifier_release() is called when the process is exiting. It will delete all the mmu notifiers. But at this time the page belonging to the process is still present in page tables and is present on the LRU list, so this race will happen: CPU 0 CPU 1 mmu_notifier_release: try_to_unmap: hlist_del_init_rcu(&mn->hlist); ptep_clear_flush_notify: mmu nofifler not found free page !!!!!! /* * At the point, the page has been * freed, but it is still mapped in * the secondary MMU. */ mn->ops->release(mn, mm); Then the box is not stable and sometimes we can get this bug: [ 738.075923] BUG: Bad page state in process migrate-perf pfn:03bec [ 738.075931] page:ffffea00000efb00 count:0 mapcount:0 mapping: (null) index:0x8076 [ 738.075936] page flags: 0x20000000000014(referenced|dirty) The same issue is present in mmu_notifier_unregister(). We can call ->release before deleting the notifier to ensure the page has been unmapped from the secondary MMU before it is freed. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ALSA: hda - Fix double quirk for Quanta FL1 / Lenovo IdeapadDavid Henningsson
commit 012e7eb1e501d0120e0383b81477f63091f5e365 upstream. The same ID is twice in the quirk table, so the second one is not used. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ALSA: hda - remove quirk for Dell Vostro 1015David Henningsson
commit e9fc83cb2e5877801a255a37ddbc5be996ea8046 upstream. This computer is confirmed working with model=auto on kernel 3.2. Also, parsing fails with hda-emu with the current model. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ALSA: hda - add dock support for Thinkpad X230Felix Kaechele
commit c8415a48fcb7a29889f4405d38c57db351e4b50a upstream. As with the ThinkPad Models X230 Tablet and T530 the X230 needs a qurik to correctly set up the pins for the dock port. Signed-off-by: Felix Kaechele <felix@fetzig.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ALSA: hda - add dock support for Thinkpad T430sPhilipp A. Mohrenweiser
commit 4407be6ba217514b1bc01488f8b56467d309e416 upstream. Add a model/fixup string "lenovo-dock", for Thinkpad T430s, to allow sound in docking station. Tested on Lenovo T430s with ThinkPad Mini Dock Plus Series 3 Signed-off-by: Philipp A. Mohrenweiser <phiamo@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
