commit d0308d4b6b02597f39fc31a9bddf7bb3faad5622 upstream.
If the hub_configure() fails after setting the hdev->maxchild
the hub->ports might be NULL or point to uninitialized kzallocated
memory causing NULL pointer dereference in hub_quiesce() during cleanup.
Now after such error the hdev->maxchild is set to 0 to avoid cleanup
of uninitialized ports.
Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 82fee4d67ab86d6fe5eb0f9a9e988ca9d654d765 upstream.
This patch clears pci_dev->state_saved at the beginning of suspending.
PCI config state may be saved long before that. Some drivers call
pci_save_state() from the ->probe() callback to get snapshot of sane
configuration space to use in the ->slot_reset() callback.
[wangyj: adjust context]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> # add comment
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
commit 418df63adac56841ef6b0f1fcf435bc64d4ed177 upstream.
Commit 455bd4c430b0 ("ARM: 7668/1: fix memset-related crashes caused by
recent GCC (4.7.2) optimizations") attempted to fix a compliance issue
with the memset return value. However the memset itself became broken
by that patch for misaligned pointers.
This fixes the above by branching over the entry code from the
misaligned fixup code to avoid reloading the original pointer.
Also, because the function entry alignment is wrong in the Thumb mode
compilation, that fixup code is moved to the end.
While at it, the entry instructions are slightly reworked to help dual
issue pipelines.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Alexander Holler <holler@ahsoftware.de>
Cc: Eric Bénard <eric@eukrea.com>
optimizations
commit 455bd4c430b0c0a361f38e8658a0d6cb469942b5 upstream.
Recent GCC versions (e.g. GCC-4.7.2) perform optimizations based on
assumptions about the implementation of memset and similar functions.
The current ARM optimized memset code does not return the value of
its first argument, as is usually expected from standard implementations.
For instance in the following function:
void debug_mutex_lock_common(struct mutex *lock, struct mutex_waiter *waiter)
memset(waiter, MUTEX_DEBUG_INIT, sizeof(*waiter));
waiter->magic = waiter;
INIT_LIST_HEAD(&waiter->list);
compiled as:
800554d0 <debug_mutex_lock_common>:
800554d0: e92d4008 push {r3, lr}
800554d4: e1a00001 mov r0, r1
800554d8: e3a02010 mov r2, #16 ; 0x10
800554dc: e3a01011 mov r1, #17 ; 0x11
800554e0: eb04426e bl 80165ea0 <memset>
800554e4: e1a03000 mov r3, r0
800554e8: e583000c str r0, [r3, #12]
800554ec: e5830000 str r0, [r3]
800554f0: e5830004 str r0, [r3, #4]
800554f4: e8bd8008 pop {r3, pc}
GCC assumes memset returns the value of pointer 'waiter' in register r0; causing
register/memory corruptions.
This patch fixes the return value of the assembly version of memset.
It adds a 'mov' instruction and merges an additional load+store into
existing load/store instructions.
For ease of review, here is a breakdown of the patch into 4 simple steps:
Step 1
Perform the following substitutions:
ip -> r8, then
r0 -> ip,
and insert 'mov ip, r0' as the first statement of the function.
At this point, we have a memset() implementation returning the proper result,
but corrupting r8 on some paths (the ones that were using ip).
Step 2
Make sure r8 is saved and restored when (! CALGN(1)+0) == 1:
save r8:
- str lr, [sp, #-4]!
+ stmfd sp!, {r8, lr}
and restore r8 on both exit paths:
- ldmeqfd sp!, {pc} @ Now <64 bytes to go.
+ ldmeqfd sp!, {r8, pc} @ Now <64 bytes to go.
tst r2, #16
stmneia ip!, {r1, r3, r8, lr}
- ldr lr, [sp], #4
+ ldmfd sp!, {r8, lr}
Step 3
Make sure r8 is saved and restored when (! CALGN(1)+0) == 0:
save r8:
- stmfd sp!, {r4-r7, lr}
+ stmfd sp!, {r4-r8, lr}
bgt 3b
- ldmeqfd sp!, {r4-r7, pc}
+ ldmeqfd sp!, {r4-r8, pc}
tst r2, #16
stmneia ip!, {r4-r7}
- ldmfd sp!, {r4-r7, lr}
+ ldmfd sp!, {r4-r8, lr}
Step 4
Rewrite register list "r4-r7, r8" as "r4-r8".
Signed-off-by: Ivan Djelic <ivan.djelic@parrot.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
commit 057db8488b53d5e4faa0cedb2f39d4ae75dfbdbb upstream.
Andrey reported the following report:
ERROR: AddressSanitizer: heap-buffer-overflow on address ffff8800359c99f3
ffff8800359c99f3 is located 0 bytes to the right of 243-byte region [ffff8800359c9900, ffff8800359c99f3)
Accessed by thread T13003:
#0 ffffffff810dd2da (asan_report_error+0x32a/0x440)
#1 ffffffff810dc6b0 (asan_check_region+0x30/0x40)
#2 ffffffff810dd4d3 (__tsan_write1+0x13/0x20)
#3 ffffffff811cd19e (ftrace_regex_release+0x1be/0x260)
#4 ffffffff812a1065 (__fput+0x155/0x360)
#5 ffffffff812a12de (____fput+0x1e/0x30)
#6 ffffffff8111708d (task_work_run+0x10d/0x140)
#7 ffffffff810ea043 (do_exit+0x433/0x11f0)
#8 ffffffff810eaee4 (do_group_exit+0x84/0x130)
#9 ffffffff810eafb1 (SyS_exit_group+0x21/0x30)
#10 ffffffff81928782 (system_call_fastpath+0x16/0x1b)
Allocated by thread T5167:
#0 ffffffff810dc778 (asan_slab_alloc+0x48/0xc0)
#1 ffffffff8128337c (__kmalloc+0xbc/0x500)
#2 ffffffff811d9d54 (trace_parser_get_init+0x34/0x90)
#3 ffffffff811cd7b3 (ftrace_regex_open+0x83/0x2e0)
#4 ffffffff811cda7d (ftrace_filter_open+0x2d/0x40)
#5 ffffffff8129b4ff (do_dentry_open+0x32f/0x430)
#6 ffffffff8129b668 (finish_open+0x68/0xa0)
#7 ffffffff812b66ac (do_last+0xb8c/0x1710)
#8 ffffffff812b7350 (path_openat+0x120/0xb50)
#9 ffffffff812b8884 (do_filp_open+0x54/0xb0)
#10 ffffffff8129d36c (do_sys_open+0x1ac/0x2c0)
#11 ffffffff8129d4b7 (SyS_open+0x37/0x50)
#12 ffffffff81928782 (system_call_fastpath+0x16/0x1b)
Shadow bytes around the buggy address:
ffff8800359c9700: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
ffff8800359c9780: fd fd fd fd fd fd fd fd fa fa fa fa fa fa fa fa
ffff8800359c9800: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9880: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
=>ffff8800359c9980: 00 00 00 00 00 00 00 00 00 00 00 00 00 00[03]fb
ffff8800359c9a00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9a80: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9b00: fa fa fa fa fa fa fa fa 00 00 00 00 00 00 00 00
ffff8800359c9b80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8800359c9c00: 00 00 00 00 00 00 00 00 fa fa fa fa fa fa fa fa
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap redzone: fa
Heap kmalloc redzone: fb
Freed heap region: fd
Shadow gap: fe
The out-of-bounds access happens on 'parser->buffer[parser->idx] = 0;'
Although the crash happened in ftrace_regex_open() the real bug
occurred in trace_get_user() where there's an incrementation to
parser->idx without a check against the size. The way it is triggered
is if userspace sends in 128 characters (EVENT_BUF_SIZE + 1), the loop
that reads the last character stores it and then breaks out because
there is no more characters. Then the last character is read to determine
what to do next, and the index is incremented without checking size.
Then the caller of trace_get_user() usually nulls out the last character
with a zero, but since the index is equal to the size, it writes a nul
character after the allocated space, which can corrupt memory.
Luckily, only root user has write access to this file.
Link: http://lkml.kernel.org/r/20131009222323.04fd1a0d@gandalf.local.home
Reported-by: Andrey Konovalov <andreyknvl@google.com>
packet
commit 3a7b21eaf4fb3c971bdb47a98f570550ddfe4471 upstream.
Some Cisco phones create huge messages that are spread over multiple packets.
After calculating the offset of the SIP body, it is validated to be within
the packet and the packet is dropped otherwise. This breaks operation of
these phones. Since connection tracking is supposed to be passive, just let
those packets pass unmodified and untracked.
Cc: William Roberts <bill.c.roberts@gmail.com>
commit 8b8d654b55648561287bd8baca0f75f964a17038 upstream.
The codes to initialize work struct or create a proc interface should
be called only once and never although it's called many times through
the init callback. Move that stuff into patch_generic_hdmi() so that
it's called only once.
BugLink: https://bugs.launchpad.net/bugs/1212160
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 0636fc507a976cdc40f21bdbcce6f0b98ff1dfe9 upstream.
Signed-off-by: Rui li <li.rui27@zte.com.cn>
Cc: stable <stable@vger.kernel.org>
commit d6776e6d5c2f8db0252f447b09736075e1bbe387 upstream.
_pci_assign_resource() took an int "size" argument, which meant that
sizes larger than 4GB were truncated. Change type to resource_size_t.
[bhelgaas: changelog]
Signed-off-by: Nikhil P Rao <nikhil.rao@intel.com>
Cc: Jiri Slaby <jslaby@suse.cz>
[ Upstream commit 6f092343855a71e03b8d209815d8c45bf3a27fcd ]
We don't validate iph->ihl which may lead a dead loop if we meet a IPIP
skb whose iph->ihl is zero. Fix this by failing immediately when iph->ihl
is evil (less than 5).
This issue were introduced by commit ec5efe7946280d1e84603389a1030ccec0a767ae
(rps: support IPIP encapsulation).
Signed-off-by: Jason Wang <jasowang@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 059dfa6a93b779516321e5112db9d7621b1367ba ]
time_after_eq() only works if the delta is < MAX_ULONG/2.
For a 32bit Dom0, if netfront sends packets at a very low rate, the time
between subsequent calls to tx_credit_exceeded() may exceed MAX_ULONG/2
and the test for timer_after_eq() will be incorrect. Credit will not be
replenished and the guest may become unable to send packets (e.g., if
prior to the long gap, all credit was exhausted).
Use jiffies_64 variant to mitigate this problem for 32bit Dom0.
Suggested-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Jason Luan <jianhai.luan@oracle.com>
commit c23632d4e57c0dd20bf50eca08fa0eb8ad3ff680 upstream.
Some rs780 asics seem to be affected as well.
See:
http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=91f3a6aaf280294b07c05dfe606e6c27b7ba3c72
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=60791
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit b062672e305ce071f21eb9e18b102c2a430e0999 upstream.
Apply the protections from
commit 1b2f1489633888d4a06028315dc19d65768a1c05
Author: Dave Airlie <airlied@redhat.com>
Date: Sat Aug 14 20:20:34 2010 +1000
drm: block userspace under allocating buffer and having drivers overwrite it (v2)
to the core ioctl structs as well, for we found one instance where there
is a 32-/64-bit size mismatch and were guilty of writing beyond the end
of the user's buffer.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Dave Airlie <airlied@redhat.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: dri-devel@lists.freedesktop.org
commit 7cb2ef56e6a8b7b368b2e883a0a47d02fed66911 upstream.
I am working with a tool that simulates oracle database I/O workload.
This tool (orion to be specific -
<http://docs.oracle.com/cd/E11882_01/server.112/e16638/iodesign.htm#autoId24>)
allocates hugetlbfs pages using shmget() with SHM_HUGETLB flag. It then
does aio into these pages from flash disks using various common block
sizes used by database. I am looking at performance with two of the most
common block sizes - 1M and 64K. aio performance with these two block
sizes plunged after Transparent HugePages was introduced in the kernel.
Here are performance numbers:
pre-THP 2.6.39 3.11-rc5
1M read 8384 MB/s 5629 MB/s 6501 MB/s
64K read 7867 MB/s 4576 MB/s 4251 MB/s
I have narrowed the performance impact down to the overheads introduced by
THP in __get_page_tail() and put_compound_page() routines. perf top shows
>40% of cycles being spent in these two routines. Every time direct I/O
to hugetlbfs pages starts, kernel calls get_page() to grab a reference to
the pages and calls put_page() when I/O completes to put the reference
away. THP introduced significant amount of locking overhead to get_page()
and put_page() when dealing with compound pages because hugepages can be
split underneath get_page() and put_page(). It added this overhead
irrespective of whether it is dealing with hugetlbfs pages or transparent
hugepages. This resulted in 20%-45% drop in aio performance when using
hugetlbfs pages.
Since hugetlbfs pages can not be split, there is no reason to go through
all the locking overhead for these pages from what I can see. I added
code to __get_page_tail() and put_compound_page() to bypass all the
locking code when working with hugetlbfs pages. This improved performance
significantly. Performance numbers with this patch:
pre-THP 3.11-rc5 3.11-rc5 + Patch
1M read 8384 MB/s 6501 MB/s 8371 MB/s
64K read 7867 MB/s 4251 MB/s 6510 MB/s
Performance with 64K read is still lower than what it was before THP, but
still a 53% improvement. It does mean there is more work to be done but I
will take a 53% improvement for now.
Please take a look at the following patch and let me know if it looks
reasonable.
[akpm@linux-foundation.org: tweak comments]
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin B Shelar <pshelar@nicira.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Minchan Kim <minchan@kernel.org>
commit f856567b930dfcdbc3323261bf77240ccdde01f5 upstream.
In commit d496f94d22d1 ('[SCSI] aacraid: fix security weakness') we
added a check on CAP_SYS_RAWIO to the ioctl. The compat ioctls need the
check as well.
commit 3d77b50c5874b7e923be946ba793644f82336b75 upstream.
Commit b1adaf65ba03 ("[SCSI] block: add sg buffer copy helper
functions") introduces two sg buffer copy helpers, and calls
flush_kernel_dcache_page() on pages in SG list after these pages are
written to.
Unfortunately, the commit may introduce a potential bug:
- Before sending some SCSI commands, kmalloc() buffer may be passed to
block layper, so flush_kernel_dcache_page() can see a slab page
finally
- According to cachetlb.txt, flush_kernel_dcache_page() is only called
on "a user page", which surely can't be a slab page.
- ARCH's implementation of flush_kernel_dcache_page() may use page
mapping information to do optimization so page_mapping() will see the
slab page, then VM_BUG_ON() is triggered.
Aaro Koskinen reported the bug on ARM/kirkwood when DEBUG_VM is enabled,
and this patch fixes the bug by adding test of '!PageSlab(miter->page)'
before calling flush_kernel_dcache_page().
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Simon Baatz <gmbnomis@gmail.com>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Tejun Heo <tj@kernel.org>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
commit cba9a90053e3b7973eff4f1946f33032e98eeed5 upstream.
According to create_thread(3): "The new thread does not inherit the creating
thread's alternate signal stack". Since commit f9a3879a (Fix sigaltstack
corruption among cloned threads), current->sas_ss_size is set to 0 for cloned
processes sharing VM with their parent. Don't use the (nonexistent) alternate
signal stack in this case. This has been broken since commit 29c4dfd9 ([XTENSA]
Remove non-rt signal handling).
Fixes the SA_ONSTACK part of the nptl/tst-cancel20 test from uClibc.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Chris Zankel <chris@zankel.net>
commit 201f99f170df14ba52ea4c52847779042b7a623b upstream.
We don't cap the size of buffer from the user so we could write past the
end of the array here. Only root can write to this file.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
commit 8d1e72250c847fa96498ec029891de4dc638a5ba upstream.
The DevInfo.u32Reserved[] array isn't initialized so it leaks kernel
information to user space.
commit c2c65cd2e14ada6de44cb527e7f1990bede24e15 upstream.
We need to check "count" so we don't overflow the ei->data buffer.
commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream.
... due to a copy & paste error.
Spotted by coverity CID 710923.
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 268ff14525edba31da29a12a9dd693cdd6a7872e upstream.
Spotted by coverity CID 115170.
commit a4461f41b94cb52e0141af717dcf4ef6558c8e2e upstream.
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = d5300000
[00000008] *pgd=0d265831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT ARM
CPU: 0 PID: 2295 Comm: vlc Not tainted 3.11.0+ #755
task: dee74800 ti: e213c000 task.ti: e213c000
PC is at snd_pcm_info+0xc8/0xd8
LR is at 0x30232065
pc : [<c031b52c>] lr : [<30232065>] psr: a0070013
sp : e213dea8 ip : d81cb0d0 fp : c05f7678
r10: c05f7770 r9 : fffffdfd r8 : 00000000
r7 : d8a968a8 r6 : d8a96800 r5 : d8a96200 r4 : d81cb000
r3 : 00000000 r2 : d81cb000 r1 : 00000001 r0 : d8a96200
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 15300019 DAC: 00000015
Process vlc (pid: 2295, stack limit = 0xe213c248)
[<c031b52c>] (snd_pcm_info) from [<c031b570>] (snd_pcm_info_user+0x34/0x9c)
[<c031b570>] (snd_pcm_info_user) from [<c03164a4>] (snd_pcm_control_ioctl+0x274/0x280)
[<c03164a4>] (snd_pcm_control_ioctl) from [<c0311458>] (snd_ctl_ioctl+0xc0/0x55c)
[<c0311458>] (snd_ctl_ioctl) from [<c00eca84>] (do_vfs_ioctl+0x80/0x31c)
[<c00eca84>] (do_vfs_ioctl) from [<c00ecd5c>] (SyS_ioctl+0x3c/0x60)
[<c00ecd5c>] (SyS_ioctl) from [<c000e500>] (ret_fast_syscall+0x0/0x48)
Code: e1a00005 e59530dc e3a01001 e1a02004 (e5933008)
---[ end trace cb3d9bdb8dfefb3c ]---
This is provoked when the ASoC front end is open along with its backend,
(which causes the backend to have a runtime assigned to it) and then the
SNDRV_CTL_IOCTL_PCM_INFO is requested for the (visible) backend device.
Resolve this by ensuring that ASoC internal backend devices are not
visible to userspace, just as the commentry for snd_pcm_new_internal()
says it should be.
Acked-by: Mark Brown <broonie@linaro.org>
commit 6fc16e58adf50c0f1e4478538983fb5ff6f453d4 upstream.
ASUS N76VZ needs the same fixup as N56VZ for supporting the boost
speaker.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=846529
commit 54e181e073fc1415e41917d725ebdbd7de956455 upstream.
Since the beginning of the parisc-linux port, sometimes 64bit SMP kernels were
not able to bring up other CPUs than the monarch CPU and instead crashed the
kernel. The reason was unclear, esp. since it involved various machines (e.g.
J5600, J6750 and SuperDome). Testing showed, that those crashes didn't happened
when less than 4GB were installed, or if a 32bit Linux kernel was booted.
In the end, the fix for those SMP problems is trivial:
During the early phase of the initialization of the CPUs, including the monarch
CPU, the PDC_PSW firmware function to enable WIDE (=64bit) mode is called.
It's documented that this firmware function may clobber various registers, and
one one of those possibly clobbered registers is %cr30 which holds the task
thread info pointer.
Now, if %cr30 would always have been clobbered, then this bug would have been
detected much earlier. But lots of testing finally showed, that - at least for
%cr30 - on some machines only the upper 32bits of the 64bit register suddenly
turned zero after the firmware call.
So, after finding the root cause, the explanation for the various crashes
became clear:
- On 32bit SMP Linux kernels all upper 32bit were zero, so we didn't faced this
problem.
- Monarch CPUs in 64bit mode always booted sucessfully, because the inital task
thread info pointer was below 4GB.
- Secondary CPUs booted sucessfully on machines with less than 4GB RAM because
the upper 32bit were zero anyay.
- Secondary CPus failed to boot if we had more than 4GB RAM and the task thread
info pointer was located above the 4GB boundary.
Finally, the patch to fix this problem is trivial by saving the %cr30 register
before the firmware call and restoring it afterwards.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: John David Anglin <dave.anglin@bell.net>
commit 97b9410643475d6557d2517c2aff9fd2221141a9 upstream.
Marc Kleine-Budde pointed out, that commit 77cc982 "clocksource: use
clockevents_config_and_register() where possible" caused a regression
for some of the converted subarchs.
The reason is, that the clockevents core code converts the minimal
hardware tick delta to a nanosecond value for core internal
usage. This conversion is affected by integer math rounding loss, so
the backwards conversion to hardware ticks will likely result in a
value which is less than the configured hardware limitation. The
affected subarchs used their own workaround (SIGH!) which got lost in
the conversion.
The solution for the issue at hand is simple: adding evt->mult - 1 to
the shifted value before the integer divison in the core conversion
function takes care of it. But this only works for the case where for
the scaled math mult/shift pair "mult <= 1 << shift" is true. For the
case where "mult > 1 << shift" we can apply the rounding add only for
the minimum delta value to make sure that the backward conversion is
not less than the given hardware limit. For the upper bound we need to
omit the rounding add, because the backwards conversion is always
larger than the original latch value. That would violate the upper
bound of the hardware device.
Though looking closer at the details of that function reveals another
bogosity: The upper bounds check is broken as well. Checking for a
resulting "clc" value greater than KTIME_MAX after the conversion is
pointless. The conversion does:
u64 clc = (latch << evt->shift) / evt->mult;
So there is no sanity check for (latch << evt->shift) exceeding the
64bit boundary. The latch argument is "unsigned long", so on a 64bit
arch the handed in argument could easily lead to an unnoticed shift
overflow. With the above rounding fix applied the calculation before
the divison is:
u64 clc = (latch << evt->shift) + evt->mult - 1;
So we need to make sure, that neither the shift nor the rounding add
is overflowing the u64 boundary.
[ukl: move assignment to rnd after eventually changing mult, fix build
issue and correct comment with the right math]
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: nicolas.ferre@atmel.com
Cc: Marc Pignat <marc.pignat@hevs.ch>
Cc: john.stultz@linaro.org
Cc: kernel@pengutronix.de
Cc: Ronald Wahl <ronald.wahl@raritan.com>
Cc: LAK <linux-arm-kernel@lists.infradead.org>
Cc: Ludovic Desroches <ludovic.desroches@atmel.com>
Link: http://lkml.kernel.org/r/1380052223-24139-1-git-send-email-u.kleine-koenig@pengutronix.de
commit 61e4947c99c4494336254ec540c50186d186150b upstream.
Since:
commit 7ceb17e87bde79d285a8b988cfed9eaeebe60b86
md: Allow devices to be re-added to a read-only array.
spares are activated on a read-only array. In case of raid1 and raid10
personalities it causes that not-in-sync devices are marked in-sync
without checking if recovery has been finished.
If a read-only array is degraded and one of its devices is not in-sync
(because the array has been only partially recovered) recovery will be skipped.
This patch adds checking if recovery has been finished before marking a device
in-sync for raid1 and raid10 personalities. In case of raid5 personality
such condition is already present (at raid5.c:6029).
Bug was introduced in 3.10 and causes data corruption.
Signed-off-by: Pawel Baldysiak <pawel.baldysiak@intel.com>
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit f13e220161e738c2710b9904dcb3cf8bb0bcce61 upstream.
libata EH decrements scmd->retries when the command failed for reasons
unrelated to the command itself so that, for example, commands aborted
due to suspend / resume cycle don't get penalized; however,
decrementing scmd->retries isn't enough for ATA passthrough commands.
Without this fix, ATA passthrough commands are not resend to the
drive, and no error is signalled to the caller because:
- allowed retry count is 1
- ata_eh_qc_complete fill the sense data, so result is valid
- sense data is filled with untouched ATA registers.
Signed-off-by: Gwendal Grignou <gwendal@google.com>
abort pending TX
commit d5a7b406c529e4595ce03dc8f6dcf7fa36f106fa upstream.
In patch
0d1862e can: flexcan: fix flexcan_chip_start() on imx6
the loop in flexcan_chip_start() that iterates over all mailboxes after the
soft reset of the CAN core was removed. This loop put all mailboxes (even the
ones marked as reserved 1...7) into EMPTY/INACTIVE mode. On mailboxes 8...63,
this aborts any pending TX messages.
After a cold boot there is random garbage in the mailboxes, which leads to
spontaneous transmit of CAN frames during first activation. Further if the
interface was disabled with a pending message (usually due to an error
condition on the CAN bus), this message is retransmitted after enabling the
interface again.
This patch fixes the regression by:
1) Limiting the maximum number of used mailboxes to 8, 0...7 are used by the RX
FIFO, 8 is used by TX.
2) Marking the TX mailbox as EMPTY/INACTIVE, so that any pending TX of that
mailbox is aborted.
Cc: Lothar Waßmann <LW@KARO-electronics.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 8660998608cfa1077e560034db81885af8e1e885 upstream.
If insert_inode_locked() fails, we shouldn't be calling
unlock_new_inode().
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Tested-by: Michael L. Semon <mlsemon35@gmail.com>
commit 9473ca6e920a3b9ca902753ce52833657f9221cc upstream.
An error in calculating the offset in an skb causes the driver to read
essential device info from the wrong locations. The main effect is that
automatic gain calculations are nonsense.
Signed-off-by: Mark Cave-Ayland <mark.cave-ayland@ilande.co.uk>
commit 0c5b93290b2f3c7a376567c03ae8d385b0e99851 upstream.
When clients are idle for too long, hostapd sends nullfunc frames for
probing. When those are acked by the client, the idle time needs to be
updated.
To make this work (and to avoid unnecessary probing), update sta->last_rx
whenever an ACK was received for a tx packet. Only do this if the flag
IEEE80211_HW_REPORTS_TX_ACK_STATUS is set.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit a754055a1296fcbe6f32de3a5eaca6efb2fd1865 upstream.
__ieee80211_scan_completed is called from a worker. This
means that the following flow is possible.
* driver calls ieee80211_scan_completed
* mac80211 cancels the scan (that is already complete)
* __ieee80211_scan_completed runs
When scan_work will finally run, it will see that the scan
hasn't been aborted and might even trigger another scan on
another band. This leads to a situation where cfg80211's
scan is not done and no further scan can be issued.
Fix this by setting a new flag when a HW scan is being
cancelled so that no other scan will be triggered.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit e1466ad5b1aeda303f9282463d55798d2eda218c upstream.
Custom VID/PID for Z3X Box device, popular tool for cellphone flashing.
Signed-off-by: Alexey E. Kramarenko <alexeyk13@yandex.ru>
commit 614ced91fc6fbb5a1cdd12f0f1b6c9197d9f1350 upstream.
The device descriptors are messed up after remote wakeup
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 4294bca7b423d1a5aa24307e3d112a04075e3763 upstream.
The device is not responsive when resumed, unless it is reset.
commit d544db293a44a2a3b09feab7dbd59668b692de71 upstream.
Add new supporting declarations to option.c, to support Huawei new
devices with new bInterfaceSubClass value.
Signed-off-by: fangxiaozhi <huananhu@huawei.com>
commit fd8573f5828873343903215f203f14dc82de397c upstream.
Interface 6 of this device speaks QMI as per tests done by us.
Credits go to Antonella for providing the hardware.
Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com>
Signed-off-by: Antonella Pellizzari <anto.pellizzari83@gmail.com>
Tested-by: Dan Williams <dcbw@redhat.com>
commit f4c19b8e165cff1a6607c21f8809441d61cab7ec upstream.
This patch adds the device id for the Inovia SEW858 device to the option driver.
Reported-by: Pavel Parkhomenko <ra85551@gmail.com>
Tested-by: Pavel Parkhomenko <ra85551@gmail.com>
well.
commit c9d09dc7ad106492c17c587b6eeb99fe3f43e522 upstream.
Without this change, the USB cable for Freestyle Option and compatible
glucometers will not be detected by the driver.
Signed-off-by: Diego Elio Pettenò <flameeyes@flameeyes.eu>
commit f5563318ff1bde15b10e736e97ffce13be08bc1a upstream.
When parsing an invalid radiotap header, the parser can overrun
the buffer that is passed in because it doesn't correctly check
1) the minimum radiotap header size
2) the space for extended bitmaps
The first issue doesn't affect any in-kernel user as they all
check the minimum size before calling the radiotap function.
The second issue could potentially affect the kernel if an skb
is passed in that consists only of the radiotap header with a
lot of extended bitmaps that extend past the SKB. In that case
a read-only buffer overrun by at most 4 bytes is possible.
Fix this by adding the appropriate checks to the parser.
Reported-by: Evan Huus <eapache@gmail.com>
commit e3b6c655b91e01a1dade056cfa358581b47a5351 upstream.
Toralf runs trinity on UML/i386. After some time it hangs and the last
message line is
BUG: soft lockup - CPU#0 stuck for 22s! [trinity-child0:1521]
It's found that pages_dirtied becomes very large. More than 1000000000
pages in this case:
period = HZ * pages_dirtied / task_ratelimit;
BUG_ON(pages_dirtied > 2000000000);
BUG_ON(pages_dirtied > 1000000000); <---------
UML debug printf shows that we got negative pause here:
ick: pause : -984
ick: pages_dirtied : 0
ick: task_ratelimit: 0
pause:
+ if (pause < 0) {
+ extern int printf(char *, ...);
+ printf("ick : pause : %li\n", pause);
+ printf("ick: pages_dirtied : %lu\n", pages_dirtied);
+ printf("ick: task_ratelimit: %lu\n", task_ratelimit);
+ BUG_ON(1);
trace_balance_dirty_pages(bdi,
Since pause is bounded by [min_pause, max_pause] where min_pause is also
bounded by max_pause. It's suspected and demonstrated that the
max_pause calculation goes wrong:
ick: pause : -717
ick: min_pause : -177
ick: max_pause : -717
ick: pages_dirtied : 14
The problem lies in the two "long = unsigned long" assignments in
bdi_max_pause() which might go negative if the highest bit is 1, and the
min_t(long, ...) check failed to protect it falling under 0. Fix all of
them by using "unsigned long" throughout the function.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
Cc: Richard Weinberger <richard@nod.at>
commit e9c6a182649f4259db704ae15a91ac820e63b0ca upstream.
This patch fixes a particular type of data corruption that has been
encountered when loading a snapshot's metadata from disk.
When we allocate a new chunk in persistent_prepare, we increment
ps->next_free and we make sure that it doesn't point to a metadata area
by further incrementing it if necessary.
When we load metadata from disk on device activation, ps->next_free is
positioned after the last used data chunk. However, if this last used
data chunk is followed by a metadata area, ps->next_free is positioned
erroneously to the metadata area. A newly-allocated chunk is placed at
the same location as the metadata area, resulting in data or metadata
corruption.
This patch changes the code so that ps->next_free skips the metadata
area when metadata are loaded in function read_exceptions.
The patch also moves a piece of code from persistent_prepare_exception
to a separate function skip_metadata to avoid code duplication.
CVE-2013-4299
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit d7dab39b6e16d5eea78ed3c705d2a2d0772b4f06 upstream.
This is based on commit d1f5273e9adb40724a85272f248f210dc4ce919a
ext4: return 32/64-bit dir name hash according to usage type
by Fan Yong <yong.fan@whamcloud.com>
Traditionally ext2/3/4 has returned a 32-bit hash value from llseek()
to appease NFSv2, which can only handle a 32-bit cookie for seekdir()
and telldir(). However, this causes problems if there are 32-bit hash
collisions, since the NFSv2 server can get stuck resending the same
entries from the directory repeatedly.
Allow ext3 to return a full 64-bit hash (both major and minor) for
telldir to decrease the chance of hash collisions.
This patch does implement a new ext3_dir_llseek op, because with 64-bit
hashes, nfs will attempt to seek to a hash "offset" which is much
larger than ext3's s_maxbytes. So for dx dirs, we call
generic_file_llseek_size() with the appropriate max hash value as the
maximum seekable size. Otherwise we just pass through to
generic_file_llseek().
Patch-updated-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Patch-updated-by: Eric Sandeen <sandeen@redhat.com>
(blame us if something is not correct)
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
[ Upstream commit d69e0f7ea95fef8059251325a79c004bac01f018 ]
When IFF_ALLMULTI flag is set on interface and IFF_PROMISC isn't,
emac_dev_mcast_set should only enable RX of multicasts and reset
MACHASH registers.
It does this, but afterwards it either sets up multicast MACs
filtering or disables RX of multicasts and resets MACHASH registers
again, rendering IFF_ALLMULTI flag useless.
This patch fixes emac_dev_mcast_set, so that multicast MACs filtering and
disabling of RX of multicasts are skipped when IFF_ALLMULTI flag is set.
Tested with kernel 2.6.37.
Signed-off-by: Mariusz Ceier <mceier+kernel@gmail.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
[ This is a simplified -stable version of a set of upstream commits. ]
This is a replacement patch only for stable which does fix the problems
handled by the following two commits in -net:
"ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9)
"ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b)
Three frames are written on a corked udp socket for which the output
netdevice has UFO enabled. If the first and third frame are smaller than
the mtu and the second one is bigger, we enqueue the second frame with
skb_append_datato_frags without initializing the gso fields. This leads
to the third frame appended regulary and thus constructing an invalid skb.
This fixes the problem by always using skb_append_datato_frags as soon
as the first frag got enqueued to the skb without marking the packet
as SKB_GSO_UDP.
The problem with only two frames for ipv6 was fixed by "ipv6: udp
packets following an UFO enqueued packet need also be handled by UFO"
(2811ebac2521ceac84f2bdae402455baa6a7fb47).
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit f2e5ddcc0d12f9c4c7b254358ad245c9dddce13b ]
When CONFIG_NETLABEL is disabled, the cipso_v4_validate() function could loop
forever in the main loop if opt[opt_iter +1] == 0, this will causing a kernel
crash in an SMP system, since the CPU executing this function will
stall /not respond to IPIs.
This problem can be reproduced by running the IP Stack Integrity Checker
(http://isic.sourceforge.net) using the following command on a Linux machine
connected to DUT:
"icmpsic -s rand -d <DUT IP address> -r 123456"
wait (1-2 min)
Signed-off-by: Seif Mazareeb <seif@marvell.com>
Acked-by: Paul Moore <paul@paul-moore.com>
