2013-07-28Linux 3.4.55v3.4.55Greg Kroah-Hartman
2013-07-28ALSA: usb-audio: 6fire: return correct XRUN indicationEldad Zack
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream. Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer function of 6fire, as expected by snd_pcm_update_hw_ptr0(). Caught by sparse. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28hrtimers: Move SMP function call to thread contextThomas Gleixner
commit 5ec2481b7b47a4005bb446d176e5d0257400c77d upstream. smp_call_function_* must not be called from softirq context. But clock_was_set() which calls on_each_cpu() is called from softirq context to implement a delayed clock_was_set() for the timer interrupt handler. Though that almost never gets invoked. A recent change in the resume code uses the softirq based delayed clock_was_set to support Xens resume mechanism. linux-next contains a new warning which warns if smp_call_function_* is called from softirq context which gets triggered by that Xen change. Fix this by moving the delayed clock_was_set() call to a work context. Reported-and-tested-by: Artem Savkov <artem.savkov@gmail.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Konrad Wilk <konrad.wilk@oracle.com> Cc: John Stultz <john.stultz@linaro.org> Cc: xen-devel@lists.xen.org Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28tracing: Fix irqs-off tag display in syscall tracingzhangwei(Jovi)
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream. All syscall tracing irqs-off tags are wrong, the syscall enter entry doesn't disable irqs. [root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event [root@jovi tracing]# cat trace # tracer: nop # # entries-in-buffer/entries-written: 13/13 #P:2 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | irqbalance-513 [000] d... 56115.496766: sys_open(filename: 804e1a6, flags: 0, mode: 1b6) irqbalance-513 [000] d... 56115.497008: sys_open(filename: 804e1bb, flags: 0, mode: 1b6) sendmail-771 [000] d... 56115.827982: sys_open(filename: b770e6d1, flags: 0, mode: 1b6) The reason is syscall tracing doesn't record irq_flags into buffer. The proper display is: [root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event [root@jovi tracing]# cat trace # tracer: nop # # entries-in-buffer/entries-written: 14/14 #P:2 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | irqbalance-514 [001] .... 46.213921: sys_open(filename: 804e1a6, flags: 0, mode: 1b6) irqbalance-514 [001] .... 46.214160: sys_open(filename: 804e1bb, flags: 0, mode: 1b6) <...>-920 [001] .... 47.307260: sys_open(filename: 4e82a0c5, flags: 80000, mode: 0) Link: http://lkml.kernel.org/r/1365564393-10972-3-git-send-email-jovi.zhangwei@huawei.com Cc: stable@vger.kernel.org # 2.6.35 Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28lockd: protect nlm_blocked access in nlmsvc_retry_blockedDavid Jeffery
commit 1c327d962fc420aea046c16215a552710bde8231 upstream. In nlmsvc_retry_blocked, the check that the list is non-empty and acquiring the pointer of the first entry is unprotected by any lock. This allows a rare race condition when there is only one entry on the list. A function such as nlmsvc_grant_callback() can be called, which will temporarily remove the entry from the list. Between the list_empty() and list_entry(),the list may become empty, causing an invalid pointer to be used as an nlm_block, leading to a possible crash. This patch adds the nlm_block_lock around these calls to prevent concurrent use of the nlm_blocked list. This was a regression introduced by f904be9cc77f361d37d71468b13ff3d1a1823dea "lockd: Mostly remove BKL from the server". Signed-off-by: David Jeffery <djeffery@redhat.com> Cc: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: cp210x support SEL C662 Vendor/DeviceBarry Grussling
commit b579fa52f6be0b4157ca9cc5e94d44a2c89a7e95 upstream. This patch adds support for the Schweitzer Engineering Laboratories C662 USB cable based off the CP210x driver. Signed-off-by: Barry Grussling <barry@grussling.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28USB: cp210x: add MMB and PI ZigBee USB Device SupportSami Rahman
commit 7681156982026ebf7eafd7301eb0374d7648d068 upstream. Added support for MMB Networks and Planet Innovation Ingeni ZigBee USB devices using customized Silicon Labs' CP210x.c USB to UART bridge drivers with PIDs: 88A4, 88A5. Signed-off-by: Sami Rahman <sami.rahman@mmbresearch.com> Tested-by: Sami Rahman <sami.rahman@mmbresearch.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: serial: cp210x: Add USB ID for Netgear Switches embedded serial adapterLuiz Angelo Daros de Luca
commit 90625070c4253377025878c4e82feed8b35c7116 upstream. This adds NetGear Managed Switch M4100 series, M5300 series, M7100 series USB ID (0846:0110) to the cp210x driver. Without this, the serial adapter is not recognized in Linux. Description was obtained from an Netgear Eng. Signed-off-by: Luiz Angelo Daros de Luca <luizluca@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: serial: option: Add ONYX 3G device supportEnrico Mioso
commit 63b5df963f52ccbab6fabedf05b7ac6b465789a4 upstream. This patch adds support for the ONYX 3G device (version 1) from ALFA NETWORK. Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28USB: option: add D-Link DWM-152/C1 and DWM-156/C1Alexandr \\\"Sky\\\" Ivanov
commit ca24763588844b14f019ffc45c7df6d9e8f932c5 upstream. Adding support for D-Link DWM-152/C1 and DWM-156/C1 devices. DWM-152/C1: T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 6 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=07d1 ProdID=3e01 Rev= 0.00 S: Product=USB Configuration S: SerialNumber=1234567890ABCDEF C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms DWM-156/C1: T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 8 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=07d1 ProdID=3e02 Rev= 0.00 S: Product=DataCard Device S: SerialNumber=1234567890ABCDEF C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms Signed-off-by: Alexandr Ivanov <alexandr.sky@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28USB: option: append Petatel NP10T device to GSM modems listDaniil Bolsun
commit c38e83b6cc2adf80e3f091fd92cfbeacc9748347 upstream. This patch was tested on 3.10.1 kernel. Same models of Petatel NP10T modems have different device IDs. Unfortunately they have no additional revision information on a board which may treat them as different devices. Currently I've seen only two NP10T devices with various IDs. Possibly Petatel NP10T list will be appended upon devices with new IDs will appear. Signed-off-by: Daniil Bolsun <dan.bolsun@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: serial: option.c: remove ONDA MT825UP product ID fromdriverEnrico Mioso
commit 878c69aae986ae97084458c0183a8c0a059865b1 upstream. Some (very few) early devices like mine, where not exposting a proper CDC descriptor. This was fixed with an immediate firmware update from the vendor, and pre-installed on newer devices. So actual devices can be driven by cdc_acm.c + cdc_ether.c. Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: serial: option: add Olivetti Olicard 200Dan Williams
commit 4cf76df06ecc852633ed927d91e01c83c33bc331 upstream. Speaks AT on interfaces 5 (command & PPP) and 3 (secondary), other interface protocols are unknown. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: option: add TP-LINK MA260Bjørn Mork
commit 94190301ffa059c2d127b3a67ec5d161d5c62681 upstream. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28usb: serial: option: blacklist ONDA MT689DC QMI interfaceEnrico Mioso
commit 3d1a69e726406ab662ab88fa30a3a05ed404334d upstream. Prevent the option driver from binding itself to the QMI/WWAN interface, making it unusable by the proper driver. Signed-off-by: enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28zfcp: block queue limits with data routerSteffen Maier
commit 5fea4291deacd80188b996d2f555fc6a1940e5d4 upstream. Commit 86a9668a8d29ea711613e1cb37efa68e7c4db564 "[SCSI] zfcp: support for hardware data router" reduced the initial block queue limits in the scsi_host_template to the absolute minimum and adjusted them later on. However, the adjustment was too late for the BSG devices of Scsi_Host and fc_host. Therefore, ioctl(..., SG_IO, ...) with request or response size > 4kB to a BSG device of an fc_host or a Scsi_Host fails with EINVAL. As a result, users of such ioctl such as HBA_SendCTPassThru() in libzfcphbaapi return with error HBA_STATUS_ERROR. Initialize the block queue limits in zfcp_scsi_host_template to the greatest common denominator (GCD). While we cannot exploit the slightly enlarged maximum request size with data router, this should be neglectible. Doing so also avoids running into trouble after live guest relocation (LGR) / migration from a data router FCP device to an FCP device that does not support data router. In that case, zfcp would figure out the new limits on adapter recovery, but the fc_host and Scsi_Host (plus in fact all sdevs) still exist with the old and now too large queue limits. It should also OK, not to use half the size as in the DIX case, because fc_host and Scsi_Host do not transport FCP requests including SCSI commands using protection data. [Backported for 3.4-stable. commit a53c8fa since v3.6-rc1 unified copyright messages, e.g: revise such messages 'Copyright IBM Corporation' as 'Copyright IBM Corp', so updated the messages as a53c8fa did. - zliu] Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Reviewed-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Zhouping Liu <zliu@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28SCSI: Fix incorrect memset in bnx2fc_parse_fcp_rspAndi Kleen
commit 16da05b1158d1bcb31656e636a8736a663b1cf1f upstream. gcc 4.8 warns because the memset only clears sizeof(char *) bytes, not the whole buffer. Use the correct buffer size and clear the whole sense buffer. /backup/lsrc/git/linux-lto-2.6/drivers/scsi/bnx2fc/bnx2fc_io.c: In function 'bnx2fc_parse_fcp_rsp': /backup/lsrc/git/linux-lto-2.6/drivers/scsi/bnx2fc/bnx2fc_io.c:1810:41: warning: argument to 'sizeof' in 'memset' call is the same expression as the destination; did you mean to provide an explicit length? [-Wsizeof-pointer-memaccess] memset(sc_cmd->sense_buffer, 0, sizeof(sc_cmd->sense_buffer)); ^ Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28SCSI: megaraid_sas: fix memory leak if SGL has zero length entriesBjørn Mork
commit 7a6a731bd00ca90d0e250867c3b9c05b5ff0fa49 upstream. commit 98cb7e44 ([SCSI] megaraid_sas: Sanity check user supplied length before passing it to dma_alloc_coherent()) introduced a memory leak. Memory allocated for entries following zero length SGL entries will not be freed. Reference: http://bugs.debian.org/688198 Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28writeback: Fix periodic writeback after fs mountJan Kara
commit a5faeaf9109578e65e1a32e2a3e76c8b47e7dcb6 upstream. Code in blkdev.c moves a device inode to default_backing_dev_info when the last reference to the device is put and moves the device inode back to its bdi when the first reference is acquired. This includes moving to wb.b_dirty list if the device inode is dirty. The code however doesn't setup timer to wake corresponding flusher thread and while wb.b_dirty list is non-empty __mark_inode_dirty() will not set it up either. Thus periodic writeback is effectively disabled until a sync(2) call which can lead to unexpected data loss in case of crash or power failure. Fix the problem by setting up a timer for periodic writeback in case we add the first dirty inode to wb.b_dirty list in bdev_inode_switch_bdi(). Reported-by: Bert De Jonghe <Bert.DeJonghe@amplidata.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28vlan: fix a race in egress prio managementEric Dumazet
[ Upstream commit 3e3aac497513c669e1c62c71e1d552ea85c1d974 ] egress_priority_map[] hash table updates are protected by rtnl, and we never remove elements until device is dismantled. We have to make sure that before inserting an new element in hash table, all its fields are committed to memory or else another cpu could find corrupt values and crash. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28atl1e: unmap partially mapped skb on dma error and free skbNeil Horman
[ Upstream commit 584ec4355355ffac43571b02a314d43eb2f7fcbf ] Ben Hutchings pointed out that my recent update to atl1e in commit 352900b583b2852152a1e05ea0e8b579292e731e ("atl1e: fix dma mapping warnings") was missing a bit of code. Specifically it reset the hardware tx ring to its origional state when we hit a dma error, but didn't unmap any exiting mappings from the operation. This patch fixes that up. It also remembers to free the skb in the event that an error occurs, so we don't leak. Untested, as I don't have hardware. I think its pretty straightforward, but please review closely. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Ben Hutchings <bhutchings@solarflare.com> CC: Jay Cliburn <jcliburn@gmail.com> CC: Chris Snook <chris.snook@gmail.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28atl1e: fix dma mapping warningsNeil Horman
[ Upstream commit 352900b583b2852152a1e05ea0e8b579292e731e ] Recently had this backtrace reported: WARNING: at lib/dma-debug.c:937 check_unmap+0x47d/0x930() Hardware name: System Product Name ATL1E 0000:02:00.0: DMA-API: device driver failed to check map error[device address=0x00000000cbfd1000] [size=90 bytes] [mapped as single] Modules linked in: xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables snd_hda_codec_hdmi snd_hda_codec_realtek iTCO_wdt iTCO_vendor_support snd_hda_intel acpi_cpufreq mperf coretemp btrfs zlib_deflate snd_hda_codec snd_hwdep microcode raid6_pq libcrc32c snd_seq usblp serio_raw xor snd_seq_device joydev snd_pcm snd_page_alloc snd_timer snd lpc_ich i2c_i801 soundcore mfd_core atl1e asus_atk0110 ata_generic pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm i2c_core pata_marvell uinput Pid: 314, comm: systemd-journal Not tainted 3.9.0-0.rc6.git2.3.fc19.x86_64 #1 Call Trace: <IRQ> [<ffffffff81069106>] warn_slowpath_common+0x66/0x80 [<ffffffff8106916c>] warn_slowpath_fmt+0x4c/0x50 [<ffffffff8138151d>] check_unmap+0x47d/0x930 [<ffffffff810ad048>] ? sched_clock_cpu+0xa8/0x100 [<ffffffff81381a2f>] debug_dma_unmap_page+0x5f/0x70 [<ffffffff8137ce30>] ? unmap_single+0x20/0x30 [<ffffffffa01569a1>] atl1e_intr+0x3a1/0x5b0 [atl1e] [<ffffffff810d53fd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff81119636>] handle_irq_event_percpu+0x56/0x390 [<ffffffff811199ad>] handle_irq_event+0x3d/0x60 [<ffffffff8111cb6a>] handle_fasteoi_irq+0x5a/0x100 [<ffffffff8101c36f>] handle_irq+0xbf/0x150 [<ffffffff811dcb2f>] ? file_sb_list_del+0x3f/0x50 [<ffffffff81073b10>] ? irq_enter+0x50/0xa0 [<ffffffff8172738d>] do_IRQ+0x4d/0xc0 [<ffffffff811dcb2f>] ? file_sb_list_del+0x3f/0x50 [<ffffffff8171c6b2>] common_interrupt+0x72/0x72 <EOI> [<ffffffff810db5b2>] ? lock_release+0xc2/0x310 [<ffffffff8109ea04>] lg_local_unlock_cpu+0x24/0x50 [<ffffffff811dcb2f>] file_sb_list_del+0x3f/0x50 [<ffffffff811dcb6d>] fput+0x2d/0xc0 [<ffffffff811d8ea1>] filp_close+0x61/0x90 [<ffffffff811fae4d>] __close_fd+0x8d/0x150 [<ffffffff811d8ef0>] sys_close+0x20/0x50 [<ffffffff81725699>] system_call_fastpath+0x16/0x1b The usual straighforward failure to check for dma_mapping_error after a map operation is completed. This patch should fix it, the reporter wandered off after filing this bz: https://bugzilla.redhat.com/show_bug.cgi?id=954170 and I don't have hardware to test, but the fix is pretty straightforward, so I figured I'd post it for review. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Jay Cliburn <jcliburn@gmail.com> CC: Chris Snook <chris.snook@gmail.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ifb: fix oops when loading the ifb faileddingtianhong
[ Upstream commit f2966cd5691058b8674a20766525bedeaea9cbcf ] If __rtnl_link_register() return faild when loading the ifb, it will take the wrong path and get oops, so fix it just like dummy. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28dummy: fix oops when loading the dummy faileddingtianhong
[ Upstream commit 2c8a01894a12665d8059fad8f0a293c98a264121 ] We rename the dummy in modprobe.conf like this: install dummy0 /sbin/modprobe -o dummy0 --ignore-install dummy install dummy1 /sbin/modprobe -o dummy1 --ignore-install dummy We got oops when we run the command: modprobe dummy0 modprobe dummy1 ------------[ cut here ]------------ [ 3302.187584] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 [ 3302.195411] IP: [<ffffffff813fe62a>] __rtnl_link_unregister+0x9a/0xd0 [ 3302.201844] PGD 85c94a067 PUD 8517bd067 PMD 0 [ 3302.206305] Oops: 0002 [#1] SMP [ 3302.299737] task: ffff88105ccea300 ti: ffff880eba4a0000 task.ti: ffff880eba4a0000 [ 3302.307186] RIP: 0010:[<ffffffff813fe62a>] [<ffffffff813fe62a>] __rtnl_link_unregister+0x9a/0xd0 [ 3302.316044] RSP: 0018:ffff880eba4a1dd8 EFLAGS: 00010246 [ 3302.321332] RAX: 0000000000000000 RBX: ffffffff81a9d738 RCX: 0000000000000002 [ 3302.328436] RDX: 0000000000000000 RSI: ffffffffa04d602c RDI: ffff880eba4a1dd8 [ 3302.335541] RBP: ffff880eba4a1e18 R08: dead000000200200 R09: dead000000100100 [ 3302.342644] R10: 0000000000000080 R11: 0000000000000003 R12: ffffffff81a9d788 [ 3302.349748] R13: ffffffffa04d7020 R14: ffffffff81a9d670 R15: ffff880eba4a1dd8 [ 3302.364910] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 3302.370630] CR2: 0000000000000008 CR3: 000000085e15e000 CR4: 00000000000427e0 [ 3302.377734] DR0: 0000000000000003 DR1: 00000000000000b0 DR2: 0000000000000001 [ 3302.384838] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 3302.391940] Stack: [ 3302.393944] ffff880eba4a1dd8 ffff880eba4a1dd8 ffff880eba4a1e18 ffffffffa04d70c0 [ 3302.401350] 00000000ffffffef ffffffffa01a8000 0000000000000000 ffffffff816111c8 [ 3302.408758] ffff880eba4a1e48 ffffffffa01a80be ffff880eba4a1e48 ffffffffa04d70c0 [ 3302.416164] Call Trace: [ 3302.418605] [<ffffffffa01a8000>] ? 0xffffffffa01a7fff [ 3302.423727] [<ffffffffa01a80be>] dummy_init_module+0xbe/0x1000 [dummy0] [ 3302.430405] [<ffffffffa01a8000>] ? 0xffffffffa01a7fff [ 3302.435535] [<ffffffff81000322>] do_one_initcall+0x152/0x1b0 [ 3302.441263] [<ffffffff810ab24b>] do_init_module+0x7b/0x200 [ 3302.446824] [<ffffffff810ad3d2>] load_module+0x4e2/0x530 [ 3302.452215] [<ffffffff8127ae40>] ? ddebug_dyndbg_boot_param_cb+0x60/0x60 [ 3302.458979] [<ffffffff810ad5f1>] SyS_init_module+0xd1/0x130 [ 3302.464627] [<ffffffff814b9652>] system_call_fastpath+0x16/0x1b [ 3302.490090] RIP [<ffffffff813fe62a>] __rtnl_link_unregister+0x9a/0xd0 [ 3302.496607] RSP <ffff880eba4a1dd8> [ 3302.500084] CR2: 0000000000000008 [ 3302.503466] ---[ end trace 8342d49cd49f78ed ]--- The reason is that when loading dummy, if __rtnl_link_register() return failed, the init_module should return and avoid take the wrong path. Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-289p: fix off by one causing access violations and memory corruptionSasha Levin
[ Upstream commit 110ecd69a9feea82a152bbf9b12aba57e6396883 ] p9_release_pages() would attempt to dereference one value past the end of pages[]. This would cause the following crashes: [ 6293.171817] BUG: unable to handle kernel paging request at ffff8807c96f3000 [ 6293.174146] IP: [<ffffffff8412793b>] p9_release_pages+0x3b/0x60 [ 6293.176447] PGD 79c5067 PUD 82c1e3067 PMD 82c197067 PTE 80000007c96f3060 [ 6293.180060] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC [ 6293.180060] Modules linked in: [ 6293.180060] CPU: 62 PID: 174043 Comm: modprobe Tainted: G W 3.10.0-next-20130710-sasha #3954 [ 6293.180060] task: ffff8807b803b000 ti: ffff880787dde000 task.ti: ffff880787dde000 [ 6293.180060] RIP: 0010:[<ffffffff8412793b>] [<ffffffff8412793b>] p9_release_pages+0x3b/0x60 [ 6293.214316] RSP: 0000:ffff880787ddfc28 EFLAGS: 00010202 [ 6293.214316] RAX: 0000000000000001 RBX: ffff8807c96f2ff8 RCX: 0000000000000000 [ 6293.222017] RDX: ffff8807b803b000 RSI: 0000000000000001 RDI: ffffea001c7e3d40 [ 6293.222017] RBP: ffff880787ddfc48 R08: 0000000000000000 R09: 0000000000000000 [ 6293.222017] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001 [ 6293.222017] R13: 0000000000000001 R14: ffff8807cc50c070 R15: ffff8807cc50c070 [ 6293.222017] FS: 00007f572641d700(0000) GS:ffff8807f3600000(0000) knlGS:0000000000000000 [ 6293.256784] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 6293.256784] CR2: ffff8807c96f3000 CR3: 00000007c8e81000 CR4: 00000000000006e0 [ 6293.256784] Stack: [ 6293.256784] ffff880787ddfcc8 ffff880787ddfcc8 0000000000000000 ffff880787ddfcc8 [ 6293.256784] ffff880787ddfd48 ffffffff84128be8 ffff880700000002 0000000000000001 [ 6293.256784] ffff8807b803b000 ffff880787ddfce0 0000100000000000 0000000000000000 [ 6293.256784] Call Trace: [ 6293.256784] [<ffffffff84128be8>] p9_virtio_zc_request+0x598/0x630 [ 6293.256784] [<ffffffff8115c610>] ? wake_up_bit+0x40/0x40 [ 6293.256784] [<ffffffff841209b1>] p9_client_zc_rpc+0x111/0x3a0 [ 6293.256784] [<ffffffff81174b78>] ? sched_clock_cpu+0x108/0x120 [ 6293.256784] [<ffffffff84122a21>] p9_client_read+0xe1/0x2c0 [ 6293.256784] [<ffffffff81708a90>] v9fs_file_read+0x90/0xc0 [ 6293.256784] [<ffffffff812bd073>] vfs_read+0xc3/0x130 [ 6293.256784] [<ffffffff811a78bd>] ? trace_hardirqs_on+0xd/0x10 [ 6293.256784] [<ffffffff812bd5a2>] SyS_read+0x62/0xa0 [ 6293.256784] [<ffffffff841a1a00>] tracesys+0xdd/0xe2 [ 6293.256784] Code: 66 90 48 89 fb 41 89 f5 48 8b 3f 48 85 ff 74 29 85 f6 74 25 45 31 e4 66 0f 1f 84 00 00 00 00 00 e8 eb 14 12 fd 41 ff c4 49 63 c4 <48> 8b 3c c3 48 85 ff 74 05 45 39 e5 75 e7 48 83 c4 08 5b 41 5c [ 6293.256784] RIP [<ffffffff8412793b>] p9_release_pages+0x3b/0x60 [ 6293.256784] RSP <ffff880787ddfc28> [ 6293.256784] CR2: ffff8807c96f3000 [ 6293.256784] ---[ end trace 50822ee72cd360fc ]--- Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv6: in case of link failure remove route directly instead of letting it expireHannes Frederic Sowa
[ Upstream commit 1eb4f758286884e7566627164bca4c4a16952a83 ] We could end up expiring a route which is part of an ecmp route set. Doing so would invalidate the rt->rt6i_nsiblings calculations and could provoke the following panic: [ 80.144667] ------------[ cut here ]------------ [ 80.145172] kernel BUG at net/ipv6/ip6_fib.c:733! [ 80.145172] invalid opcode: 0000 [#1] SMP [ 80.145172] Modules linked in: 8021q nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables +snd_hda_intel snd_hda_codec snd_hwdep snd_seq snd_seq_device snd_pcm snd_page_alloc snd_timer virtio_balloon snd soundcore i2c_piix4 i2c_core virtio_net virtio_blk [ 80.145172] CPU: 1 PID: 786 Comm: ping6 Not tainted 3.10.0+ #118 [ 80.145172] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 80.145172] task: ffff880117fa0000 ti: ffff880118770000 task.ti: ffff880118770000 [ 80.145172] RIP: 0010:[<ffffffff815f3b5d>] [<ffffffff815f3b5d>] fib6_add+0x75d/0x830 [ 80.145172] RSP: 0018:ffff880118771798 EFLAGS: 00010202 [ 80.145172] RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88011350e480 [ 80.145172] RDX: ffff88011350e238 RSI: 0000000000000004 RDI: ffff88011350f738 [ 80.145172] RBP: ffff880118771848 R08: ffff880117903280 R09: 0000000000000001 [ 80.145172] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88011350f680 [ 80.145172] R13: ffff880117903280 R14: ffff880118771890 R15: ffff88011350ef90 [ 80.145172] FS: 00007f02b5127740(0000) GS:ffff88011fd00000(0000) knlGS:0000000000000000 [ 80.145172] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 80.145172] CR2: 00007f981322a000 CR3: 00000001181b1000 CR4: 00000000000006e0 [ 80.145172] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 80.145172] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 80.145172] Stack: [ 80.145172] 0000000000000001 ffff880100000000 ffff880100000000 ffff880117903280 [ 80.145172] 0000000000000000 ffff880119a4cf00 0000000000000400 00000000000007fa [ 80.145172] 0000000000000000 0000000000000000 0000000000000000 ffff88011350f680 [ 80.145172] Call Trace: [ 80.145172] [<ffffffff815eeceb>] ? rt6_bind_peer+0x4b/0x90 [ 80.145172] [<ffffffff815ed985>] __ip6_ins_rt+0x45/0x70 [ 80.145172] [<ffffffff815eee35>] ip6_ins_rt+0x35/0x40 [ 80.145172] [<ffffffff815ef1e4>] ip6_pol_route.isra.44+0x3a4/0x4b0 [ 80.145172] [<ffffffff815ef34a>] ip6_pol_route_output+0x2a/0x30 [ 80.145172] [<ffffffff81616077>] fib6_rule_action+0xd7/0x210 [ 80.145172] [<ffffffff815ef320>] ? ip6_pol_route_input+0x30/0x30 [ 80.145172] [<ffffffff81553026>] fib_rules_lookup+0xc6/0x140 [ 80.145172] [<ffffffff81616374>] fib6_rule_lookup+0x44/0x80 [ 80.145172] [<ffffffff815ef320>] ? ip6_pol_route_input+0x30/0x30 [ 80.145172] [<ffffffff815edea3>] ip6_route_output+0x73/0xb0 [ 80.145172] [<ffffffff815dfdf3>] ip6_dst_lookup_tail+0x2c3/0x2e0 [ 80.145172] [<ffffffff813007b1>] ? list_del+0x11/0x40 [ 80.145172] [<ffffffff81082a4c>] ? remove_wait_queue+0x3c/0x50 [ 80.145172] [<ffffffff815dfe4d>] ip6_dst_lookup_flow+0x3d/0xa0 [ 80.145172] [<ffffffff815fda77>] rawv6_sendmsg+0x267/0xc20 [ 80.145172] [<ffffffff815a8a83>] inet_sendmsg+0x63/0xb0 [ 80.145172] [<ffffffff8128eb93>] ? selinux_socket_sendmsg+0x23/0x30 [ 80.145172] [<ffffffff815218d6>] sock_sendmsg+0xa6/0xd0 [ 80.145172] [<ffffffff81524a68>] SYSC_sendto+0x128/0x180 [ 80.145172] [<ffffffff8109825c>] ? update_curr+0xec/0x170 [ 80.145172] [<ffffffff81041d09>] ? kvm_clock_get_cycles+0x9/0x10 [ 80.145172] [<ffffffff810afd1e>] ? __getnstimeofday+0x3e/0xd0 [ 80.145172] [<ffffffff8152509e>] SyS_sendto+0xe/0x10 [ 80.145172] [<ffffffff8164efd9>] system_call_fastpath+0x16/0x1b [ 80.145172] Code: fe ff ff 41 f6 45 2a 06 0f 85 ca fe ff ff 49 8b 7e 08 4c 89 ee e8 94 ef ff ff e9 b9 fe ff ff 48 8b 82 28 05 00 00 e9 01 ff ff ff <0f> 0b 49 8b 54 24 30 0d 00 00 40 00 89 83 14 01 00 00 48 89 53 [ 80.145172] RIP [<ffffffff815f3b5d>] fib6_add+0x75d/0x830 [ 80.145172] RSP <ffff880118771798> [ 80.387413] ---[ end trace 02f20b7a8b81ed95 ]--- [ 80.390154] Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28macvtap: correctly linearize skb when zerocopy is usedJason Wang
[ Upstream commit 61d46bf979d5cd7c164709a80ad5676a35494aae ] Userspace may produce vectors greater than MAX_SKB_FRAGS. When we try to linearize parts of the skb to let the rest of iov to be fit in the frags, we need count copylen into linear when calling macvtap_alloc_skb() instead of partly counting it into data_len. Since this breaks zerocopy_sg_from_iovec() since its inner counter assumes nr_frags should be zero at beginning. This cause nr_frags to be increased wrongly without setting the correct frags. This bug were introduced from b92946e2919134ebe2a4083e4302236295ea2a73 (macvtap: zerocopy: validate vectors before building skb). Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ifb: fix rcu_sched self-detected stallsdingtianhong
[ Upstream commit 440d57bc5ff55ec1efb3efc9cbe9420b4bbdfefa ] According to the commit 16b0dc29c1af9df341428f4c49ada4f626258082 (dummy: fix rcu_sched self-detected stalls) Eric Dumazet fix the problem in dummy, but the ifb will occur the same problem like the dummy modules. Trying to "modprobe ifb numifbs=30000" triggers : INFO: rcu_sched self-detected stall on CPU After this splat, RTNL is locked and reboot is needed. We must call cond_resched() to avoid this, even holding RTNL. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sunvnet: vnet_port_remove must call unregister_netdevDave Kleikamp
[ Upstream commit aabb9875d02559ab9b928cd6f259a5cc4c21a589 ] The missing call to unregister_netdev() leaves the interface active after the driver is unloaded by rmmod. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv6: ip6_append_data_mtu did not care about pmtudisc and frag_sizeHannes Frederic Sowa
[ Upstream commit 75a493e60ac4bbe2e977e7129d6d8cbb0dd236be ] If the socket had an IPV6_MTU value set, ip6_append_data_mtu lost track of this when appending the second frame on a corked socket. This results in the following splat: [37598.993962] ------------[ cut here ]------------ [37598.994008] kernel BUG at net/core/skbuff.c:2064! [37598.994008] invalid opcode: 0000 [#1] SMP [37598.994008] Modules linked in: tcp_lp uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_core videodev media vfat fat usb_storage fuse ebtable_nat xt_CHECKSUM bridge stp llc ipt_MASQUERADE nf_conntrack_netbios_ns nf_conntrack_broadcast ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat +nf_nat_ipv4 nf_nat iptable_mangle nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i cxgb3 mdio libcxgbi ib_iser rdma_cm ib_addr iw_cm ib_cm ib_sa ib_mad ib_core iscsi_tcp libiscsi_tcp libiscsi +scsi_transport_iscsi rfcomm bnep iTCO_wdt iTCO_vendor_support snd_hda_codec_conexant arc4 iwldvm mac80211 snd_hda_intel acpi_cpufreq mperf coretemp snd_hda_codec microcode cdc_wdm cdc_acm [37598.994008] snd_hwdep cdc_ether snd_seq snd_seq_device usbnet mii joydev btusb snd_pcm bluetooth i2c_i801 e1000e lpc_ich mfd_core ptp iwlwifi pps_core snd_page_alloc mei cfg80211 snd_timer thinkpad_acpi snd tpm_tis soundcore rfkill tpm tpm_bios vhost_net tun macvtap macvlan kvm_intel kvm uinput binfmt_misc +dm_crypt i915 i2c_algo_bit drm_kms_helper drm i2c_core wmi video [37598.994008] CPU 0 [37598.994008] Pid: 27320, comm: t2 Not tainted 3.9.6-200.fc18.x86_64 #1 LENOVO 27744PG/27744PG [37598.994008] RIP: 0010:[<ffffffff815443a5>] [<ffffffff815443a5>] skb_copy_and_csum_bits+0x325/0x330 [37598.994008] RSP: 0018:ffff88003670da18 EFLAGS: 00010202 [37598.994008] RAX: ffff88018105c018 RBX: 0000000000000004 RCX: 00000000000006c0 [37598.994008] RDX: ffff88018105a6c0 RSI: ffff88018105a000 RDI: ffff8801e1b0aa00 [37598.994008] RBP: ffff88003670da78 R08: 0000000000000000 R09: ffff88018105c040 [37598.994008] R10: ffff8801e1b0aa00 R11: 0000000000000000 R12: 000000000000fff8 [37598.994008] R13: 00000000000004fc R14: 00000000ffff0504 R15: 0000000000000000 [37598.994008] FS: 00007f28eea59740(0000) GS:ffff88023bc00000(0000) knlGS:0000000000000000 [37598.994008] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [37598.994008] CR2: 0000003d935789e0 CR3: 00000000365cb000 CR4: 00000000000407f0 [37598.994008] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [37598.994008] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [37598.994008] Process t2 (pid: 27320, threadinfo ffff88003670c000, task ffff88022c162ee0) [37598.994008] Stack: [37598.994008] ffff88022e098a00 ffff88020f973fc0 0000000000000008 00000000000004c8 [37598.994008] ffff88020f973fc0 00000000000004c4 ffff88003670da78 ffff8801e1b0a200 [37598.994008] 0000000000000018 00000000000004c8 ffff88020f973fc0 00000000000004c4 [37598.994008] Call Trace: [37598.994008] [<ffffffff815fc21f>] ip6_append_data+0xccf/0xfe0 [37598.994008] [<ffffffff8158d9f0>] ? ip_copy_metadata+0x1a0/0x1a0 [37598.994008] [<ffffffff81661f66>] ? _raw_spin_lock_bh+0x16/0x40 [37598.994008] [<ffffffff8161548d>] udpv6_sendmsg+0x1ed/0xc10 [37598.994008] [<ffffffff812a2845>] ? sock_has_perm+0x75/0x90 [37598.994008] [<ffffffff815c3693>] inet_sendmsg+0x63/0xb0 [37598.994008] [<ffffffff812a2973>] ? selinux_socket_sendmsg+0x23/0x30 [37598.994008] [<ffffffff8153a450>] sock_sendmsg+0xb0/0xe0 [37598.994008] [<ffffffff810135d1>] ? __switch_to+0x181/0x4a0 [37598.994008] [<ffffffff8153d97d>] sys_sendto+0x12d/0x180 [37598.994008] [<ffffffff810dfb64>] ? __audit_syscall_entry+0x94/0xf0 [37598.994008] [<ffffffff81020ed1>] ? syscall_trace_enter+0x231/0x240 [37598.994008] [<ffffffff8166a7e7>] tracesys+0xdd/0xe2 [37598.994008] Code: fe 07 00 00 48 c7 c7 04 28 a6 81 89 45 a0 4c 89 4d b8 44 89 5d a8 e8 1b ac b1 ff 44 8b 5d a8 4c 8b 4d b8 8b 45 a0 e9 cf fe ff ff <0f> 0b 66 0f 1f 84 00 00 00 00 00 66 66 66 66 90 55 48 89 e5 48 [37598.994008] RIP [<ffffffff815443a5>] skb_copy_and_csum_bits+0x325/0x330 [37598.994008] RSP <ffff88003670da18> [37599.007323] ---[ end trace d69f6a17f8ac8eee ]--- While there, also check if path mtu discovery is activated for this socket. The logic was adapted from ip6_append_data when first writing on the corked socket. This bug was introduced with commit 0c1833797a5a6ec23ea9261d979aa18078720b74 ("ipv6: fix incorrect ipsec fragment"). v2: a) Replace IPV6_PMTU_DISC_DO with IPV6_PMTUDISC_PROBE. b) Don't pass ipv6_pinfo to ip6_append_data_mtu (suggestion by Gao feng, thanks!). c) Change mtu to unsigned int, else we get a warning about non-matching types because of the min()-macro type-check. Acked-by: Gao feng <gaofeng@cn.fujitsu.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv6: call udp_push_pending_frames when uncorking a socket with AF_INET ↵Hannes Frederic Sowa
pending data [ Upstream commit 8822b64a0fa64a5dd1dfcf837c5b0be83f8c05d1 ] We accidentally call down to ip6_push_pending_frames when uncorking pending AF_INET data on a ipv6 socket. This results in the following splat (from Dave Jones): skbuff: skb_under_panic: text:ffffffff816765f6 len:48 put:40 head:ffff88013deb6df0 data:ffff88013deb6dec tail:0x2c end:0xc0 dev:<NULL> ------------[ cut here ]------------ kernel BUG at net/core/skbuff.c:126! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: dccp_ipv4 dccp 8021q garp bridge stp dlci mpoa snd_seq_dummy sctp fuse hidp tun bnep nfnetlink scsi_transport_iscsi rfcomm can_raw can_bcm af_802154 appletalk caif_socket can caif ipt_ULOG x25 rose af_key pppoe pppox ipx phonet irda llc2 ppp_generic slhc p8023 psnap p8022 llc crc_ccitt atm bluetooth +netrom ax25 nfc rfkill rds af_rxrpc coretemp hwmon kvm_intel kvm crc32c_intel snd_hda_codec_realtek ghash_clmulni_intel microcode pcspkr snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep usb_debug snd_seq snd_seq_device snd_pcm e1000e snd_page_alloc snd_timer ptp snd pps_core soundcore xfs libcrc32c CPU: 2 PID: 8095 Comm: trinity-child2 Not tainted 3.10.0-rc7+ #37 task: ffff8801f52c2520 ti: ffff8801e6430000 task.ti: ffff8801e6430000 RIP: 0010:[<ffffffff816e759c>] [<ffffffff816e759c>] skb_panic+0x63/0x65 RSP: 0018:ffff8801e6431de8 EFLAGS: 00010282 RAX: 0000000000000086 RBX: ffff8802353d3cc0 RCX: 0000000000000006 RDX: 0000000000003b90 RSI: ffff8801f52c2ca0 RDI: ffff8801f52c2520 RBP: ffff8801e6431e08 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000001 R12: ffff88022ea0c800 R13: ffff88022ea0cdf8 R14: ffff8802353ecb40 R15: ffffffff81cc7800 FS: 00007f5720a10740(0000) GS:ffff880244c00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000005862000 CR3: 000000022843c000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600 Stack: ffff88013deb6dec 000000000000002c 00000000000000c0 ffffffff81a3f6e4 ffff8801e6431e18 ffffffff8159a9aa ffff8801e6431e90 ffffffff816765f6 ffffffff810b756b 0000000700000002 ffff8801e6431e40 0000fea9292aa8c0 Call Trace: [<ffffffff8159a9aa>] skb_push+0x3a/0x40 [<ffffffff816765f6>] ip6_push_pending_frames+0x1f6/0x4d0 [<ffffffff810b756b>] ? mark_held_locks+0xbb/0x140 [<ffffffff81694919>] udp_v6_push_pending_frames+0x2b9/0x3d0 [<ffffffff81694660>] ? udplite_getfrag+0x20/0x20 [<ffffffff8162092a>] udp_lib_setsockopt+0x1aa/0x1f0 [<ffffffff811cc5e7>] ? fget_light+0x387/0x4f0 [<ffffffff816958a4>] udpv6_setsockopt+0x34/0x40 [<ffffffff815949f4>] sock_common_setsockopt+0x14/0x20 [<ffffffff81593c31>] SyS_setsockopt+0x71/0xd0 [<ffffffff816f5d54>] tracesys+0xdd/0xe2 Code: 00 00 48 89 44 24 10 8b 87 d8 00 00 00 48 89 44 24 08 48 8b 87 e8 00 00 00 48 c7 c7 c0 04 aa 81 48 89 04 24 31 c0 e8 e1 7e ff ff <0f> 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 RIP [<ffffffff816e759c>] skb_panic+0x63/0x65 RSP <ffff8801e6431de8> This patch adds a check if the pending data is of address family AF_INET and directly calls udp_push_ending_frames from udp_v6_push_pending_frames if that is the case. This bug was found by Dave Jones with trinity. (Also move the initialization of fl6 below the AF_INET check, even if not strictly necessary.) Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Dave Jones <davej@redhat.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28l2tp: add missing .owner to struct pppox_protoWei Yongjun
[ Upstream commit e1558a93b61962710733dc8c11a2bc765607f1cd ] Add missing .owner of struct pppox_proto. This prevents the module from being removed from underneath its users. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv6,mcast: always hold idev->lock before mca_lockAmerigo Wang
[ Upstream commit 8965779d2c0e6ab246c82a405236b1fb2adae6b2, with some bits from commit b7b1bfce0bb68bd8f6e62a28295922785cc63781 ("ipv6: split duplicate address detection and router solicitation timer") to get the __ipv6_get_lladdr() used by this patch. ] dingtianhong reported the following deadlock detected by lockdep: ====================================================== [ INFO: possible circular locking dependency detected ] 3.4.24.05-0.1-default #1 Not tainted ------------------------------------------------------- ksoftirqd/0/3 is trying to acquire lock: (&ndev->lock){+.+...}, at: [<ffffffff8147f804>] ipv6_get_lladdr+0x74/0x120 but task is already holding lock: (&mc->mca_lock){+.+...}, at: [<ffffffff8149d130>] mld_send_report+0x40/0x150 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&mc->mca_lock){+.+...}: [<ffffffff810a8027>] validate_chain+0x637/0x730 [<ffffffff810a8417>] __lock_acquire+0x2f7/0x500 [<ffffffff810a8734>] lock_acquire+0x114/0x150 [<ffffffff814f691a>] rt_spin_lock+0x4a/0x60 [<ffffffff8149e4bb>] igmp6_group_added+0x3b/0x120 [<ffffffff8149e5d8>] ipv6_mc_up+0x38/0x60 [<ffffffff81480a4d>] ipv6_find_idev+0x3d/0x80 [<ffffffff81483175>] addrconf_notify+0x3d5/0x4b0 [<ffffffff814fae3f>] notifier_call_chain+0x3f/0x80 [<ffffffff81073471>] raw_notifier_call_chain+0x11/0x20 [<ffffffff813d8722>] call_netdevice_notifiers+0x32/0x60 [<ffffffff813d92d4>] __dev_notify_flags+0x34/0x80 [<ffffffff813d9360>] dev_change_flags+0x40/0x70 [<ffffffff813ea627>] do_setlink+0x237/0x8a0 [<ffffffff813ebb6c>] rtnl_newlink+0x3ec/0x600 [<ffffffff813eb4d0>] rtnetlink_rcv_msg+0x160/0x310 [<ffffffff814040b9>] netlink_rcv_skb+0x89/0xb0 [<ffffffff813eb357>] rtnetlink_rcv+0x27/0x40 [<ffffffff81403e20>] netlink_unicast+0x140/0x180 [<ffffffff81404a9e>] netlink_sendmsg+0x33e/0x380 [<ffffffff813c4252>] sock_sendmsg+0x112/0x130 [<ffffffff813c537e>] __sys_sendmsg+0x44e/0x460 [<ffffffff813c5544>] sys_sendmsg+0x44/0x70 [<ffffffff814feab9>] system_call_fastpath+0x16/0x1b -> #0 (&ndev->lock){+.+...}: [<ffffffff810a798e>] check_prev_add+0x3de/0x440 [<ffffffff810a8027>] validate_chain+0x637/0x730 [<ffffffff810a8417>] __lock_acquire+0x2f7/0x500 [<ffffffff810a8734>] lock_acquire+0x114/0x150 [<ffffffff814f6c82>] rt_read_lock+0x42/0x60 [<ffffffff8147f804>] ipv6_get_lladdr+0x74/0x120 [<ffffffff8149b036>] mld_newpack+0xb6/0x160 [<ffffffff8149b18b>] add_grhead+0xab/0xc0 [<ffffffff8149d03b>] add_grec+0x3ab/0x460 [<ffffffff8149d14a>] mld_send_report+0x5a/0x150 [<ffffffff8149f99e>] igmp6_timer_handler+0x4e/0xb0 [<ffffffff8105705a>] call_timer_fn+0xca/0x1d0 [<ffffffff81057b9f>] run_timer_softirq+0x1df/0x2e0 [<ffffffff8104e8c7>] handle_pending_softirqs+0xf7/0x1f0 [<ffffffff8104ea3b>] __do_softirq_common+0x7b/0xf0 [<ffffffff8104f07f>] __thread_do_softirq+0x1af/0x210 [<ffffffff8104f1c1>] run_ksoftirqd+0xe1/0x1f0 [<ffffffff8106c7de>] kthread+0xae/0xc0 [<ffffffff814fff74>] kernel_thread_helper+0x4/0x10 actually we can just hold idev->lock before taking pmc->mca_lock, and avoid taking idev->lock again when iterating idev->addr_list, since the upper callers of mld_newpack() already take read_lock_bh(&idev->lock). Reported-by: dingtianhong <dingtianhong@huawei.com> Cc: dingtianhong <dingtianhong@huawei.com> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: David S. Miller <davem@davemloft.net> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Tested-by: Ding Tianhong <dingtianhong@huawei.com> Tested-by: Chen Weilong <chenweilong@huawei.com> Signed-off-by: Cong Wang <amwang@redhat.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28net: Swap ver and type in pppoe_hdrChangli Gao
[ Upstream commit b1a5a34bd0b8767ea689e68f8ea513e9710b671e ] Ver and type in pppoe_hdr should be swapped as defined by RFC2516 section-4. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28x25: Fix broken locking in ioctl error paths.Dave Jones
[ Upstream commit 4ccb93ce7439b63c31bc7597bfffd13567fa483d ] Two of the x25 ioctl cases have error paths that break out of the function without unlocking the socket, leading to this warning: ================================================ [ BUG: lock held when returning to user space! ] 3.10.0-rc7+ #36 Not tainted ------------------------------------------------ trinity-child2/31407 is leaving the kernel with locks still held! 1 lock held by trinity-child2/31407: #0: (sk_lock-AF_X25){+.+.+.}, at: [<ffffffffa024b6da>] x25_ioctl+0x8a/0x740 [x25] Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28neighbour: fix a race in neigh_destroy()Eric Dumazet
[ Upstream commit c9ab4d85de222f3390c67aedc9c18a50e767531e ] There is a race in neighbour code, because neigh_destroy() uses skb_queue_purge(&neigh->arp_queue) without holding neighbour lock, while other parts of the code assume neighbour rwlock is what protects arp_queue Convert all skb_queue_purge() calls to the __skb_queue_purge() variant Use __skb_queue_head_init() instead of skb_queue_head_init() to make clear we do not use arp_queue.lock And hold neigh->lock in neigh_destroy() to close the race. Reported-by: Joe Jin <joe.jin@oracle.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sh_eth: fix unhandled RFE interruptSergei Shtylyov
[ Upstream commit ca8c35852138ee0585eaffe6b9f10a5261ea7771 ] EESR.RFE (receive FIFO overflow) interrupt is enabled by the driver on all SoCs and sh_eth_error() handles it but it's not present in any initializer/assignment of the 'eesr_err_check' field of 'struct sh_eth_cpu_data'. This leads to that interrupt not being handled and cleared, and finally to disabling IRQ and the driver being non-functional. Modify DEFAULT_EESR_ERR_CHECK macro and all explicit initializers of the above mentioned field to contain the EESR.RFE bit. Remove useless backslashes from the initializers, while at it. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28af_key: fix info leaks in notify messagesMathias Krause
[ Upstream commit a5cc68f3d63306d0d288f31edfc2ae6ef8ecd887 ] key_notify_sa_flush() and key_notify_policy_flush() miss to initialize the sadb_msg_reserved member of the broadcasted message and thereby leak 2 bytes of heap memory to listeners. Fix that. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv6: ip6_sk_dst_check() must not assume ipv6 dstEric Dumazet
[ Upstream commit a963a37d384d71ad43b3e9e79d68d42fbe0901f3 ] It's possible to use AF_INET6 sockets and to connect to an IPv4 destination. After this, socket dst cache is a pointer to a rtable, not rt6_info. ip6_sk_dst_check() should check the socket dst cache is IPv6, or else various corruptions/crashes can happen. Dave Jones can reproduce immediate crash with trinity -q -l off -n -c sendmsg -c connect With help from Hannes Frederic Sowa Reported-by: Dave Jones <davej@redhat.com> Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28macvtap: fix recovery from gup errorsMichael S. Tsirkin
[ Upstream commit 4c7ab054ab4f5d63625508ed6f8a607184cae7c2 ] get user pages might fail partially in macvtap zero copy mode. To recover we need to put all pages that we got, but code used a wrong index resulting in double-free errors. Reported-by: Brad Hubbard <bhubbard@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv6: don't call addrconf_dst_alloc again when enable loGao feng
[ Upstream commit a881ae1f625c599b460cc8f8a7fcb1c438f699ad ] If we disable all of the net interfaces, and enable un-lo interface before lo interface, we already allocated the addrconf dst in ipv6_add_addr. So we shouldn't allocate it again when we enable lo interface. Otherwise the message below will be triggered. unregister_netdevice: waiting for sit1 to become free. Usage count = 1 This problem is introduced by commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f "net IPv6 : Fix broken IPv6 routing table after loopback down-up" Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ipv4: Fixed MD5 key lookups when adding/ removing MD5 to/ from TCP sockets.Aydin Arik
[ Upstream commit c0353c7b5da4cbd2ab8227e84bbc9c79890f24ce ] MD5 key lookups on a given TCP socket were being performed incorrectly. This fix alters parameter inputs to the MD5 lookup function tcp_md5_do_lookup, which is called by functions tcp_md5_do_add and tcp_md5_do_del. Specifically, the change now inputs the correct address and address family required to make a proper lookup. Signed-off-by: Aydin Arik <aydin.arik@alliedtelesis.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28bridge: fix switched interval for MLD Query typesLinus Lüssing
[ Upstream commit 32de868cbc6bee010d2cee95b5071b25ecbec8c3 ] General Queries (the one with the Multicast Address field set to zero / '::') are supposed to have a Maximum Response Delay of [Query Response Interval], while for Multicast-Address-Specific Queries it is [Last Listener Query Interval] - not the other way round. (see RFC2710, section 7.3+7.8) Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sparc: tsb must be flushed before tlbDave Kleikamp
Upstream commit 23a01138efe216f8084cfaa74b0b90dd4b097441 This fixes a race where a cpu may re-load a tlb from a stale tsb right after it has been flushed by a remote function call. I still see some instability when stressing the system with parallel kernel builds while creating memory pressure by writing to /proc/sys/vm/nr_hugepages, but this patch improves the stability significantly. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sparc64 address-congruence propertybob picco
Upstream commit 771a37ff4d80b80db3b0df3e7696f14b298c67b7 The Machine Description (MD) property "address-congruence-offset" is optional. According to the MD specification the value is assumed 0UL when not present. This caused early boot failure on T5. Signed-off-by: Bob Picco <bob.picco@oracle.com> CC: sparclinux@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sparc32: vm_area_struct access for old Sun SPARCs.Olivier DANET
Upstream commit 961246b4ed8da3bcf4ee1eb9147f341013553e3c Commit e4c6bfd2d79d063017ab19a18915f0bc759f32d9 ("mm: rearrange vm_area_struct for fewer cache misses") changed the layout of the vm_area_struct structure, it broke several SPARC32 assembly routines which used numerical constants for accessing the vm_mm field. This patch defines the VMA_VM_MM constant to replace the immediate values. Signed-off-by: Olivier DANET <odanet@caramail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28perf: Fix perf_lock_task_context() vs RCUPeter Zijlstra
commit 058ebd0eba3aff16b144eabf4510ed9510e1416e upstream. Jiri managed to trigger this warning: [] ====================================================== [] [ INFO: possible circular locking dependency detected ] [] 3.10.0+ #228 Tainted: G W [] ------------------------------------------------------- [] p/6613 is trying to acquire lock: [] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250 [] [] but task is already holding lock: [] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0 [] [] which lock already depends on the new lock. [] [] the existing dependency chain (in reverse order) is: [] [] -> #4 (&ctx->lock){-.-...}: [] -> #3 (&rq->lock){-.-.-.}: [] -> #2 (&p->pi_lock){-.-.-.}: [] -> #1 (&rnp->nocb_gp_wq[1]){......}: [] -> #0 (rcu_node_0){..-...}: Paul was quick to explain that due to preemptible RCU we cannot call rcu_read_unlock() while holding scheduler (or nested) locks when part of the read side critical section was preemptible. Therefore solve it by making the entire RCU read side non-preemptible. Also pull out the retry from under the non-preempt to play nice with RT. Reported-by: Jiri Olsa <jolsa@redhat.com> Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28perf: Remove WARN_ON_ONCE() check in __perf_event_enable() for valid scenarioJiri Olsa
commit 06f417968beac6e6b614e17b37d347aa6a6b1d30 upstream. The '!ctx->is_active' check has a valid scenario, so there's no need for the warning. The reason is that there's a time window between the 'ctx->is_active' check in the perf_event_enable() function and the __perf_event_enable() function having: - IRQs on - ctx->lock unlocked where the task could be killed and 'ctx' deactivated by perf_event_exit_task(), ending up with the warning below. So remove the WARN_ON_ONCE() check and add comments to explain it all. This addresses the following warning reported by Vince Weaver: [ 324.983534] ------------[ cut here ]------------ [ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190() [ 324.984420] Modules linked in: [ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246 [ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010 [ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00 [ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860 [ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a [ 324.984420] Call Trace: [ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b [ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0 [ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20 [ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190 [ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50 [ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130 [ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40 [ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80 [ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70 [ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210 [ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60 [ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40 [ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30 [ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0 [ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620 [ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0 [ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0 [ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe [ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84 [ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80 [ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84 [ 324.984420] ---[ end trace 442ec2f04db3771a ]--- Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28perf: Clone child context from parent context pmuJiri Olsa
commit 734df5ab549ca44f40de0f07af1c8803856dfb18 upstream. Currently when the child context for inherited events is created, it's based on the pmu object of the first event of the parent context. This is wrong for the following scenario: - HW context having HW and SW event - HW event got removed (closed) - SW event stays in HW context as the only event and its pmu is used to clone the child context The issue starts when the cpu context object is touched based on the pmu context object (__get_cpu_context). In this case the HW context will work with SW cpu context ending up with following WARN below. Fixing this by using parent context pmu object to clone from child context. Addresses the following warning reported by Vince Weaver: [ 2716.472065] ------------[ cut here ]------------ [ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x) [ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn [ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2 [ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2 [ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18 [ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad [ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550 [ 2716.476035] Call Trace: [ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70 [ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f [ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194 [ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c [ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394 [ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98 [ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad [ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1 [ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432 [ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141 [ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90 [ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118 [ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c [ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6 [ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d [ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78 [ 2716.476035] ---[ end trace 827178d8a5966c3d ]--- Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28iommu/amd: Only unmap large pages from the first pteAlex Williamson
commit 60d0ca3cfd199b6612bbbbf4999a3470dad38bb1 upstream. If we use a large mapping, the expectation is that only unmaps from the first pte in the superpage are supported. Unmaps from offsets into the superpage should fail (ie. return zero sized unmap). In the current code, unmapping from an offset clears the size of the full mapping starting from an offset. For instance, if we map a 16k physically contiguous range at IOVA 0x0 with a large page, then attempt to unmap 4k at offset 12k, 4 ptes are cleared (12k - 28k) and the unmap returns 16k unmapped. This potentially incorrectly clears valid mappings and confuses drivers like VFIO that use the unmap size to release pinned pages. Fix by refusing to unmap from offsets into the page. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
