commit 9bb5d40cd93c9dd4be74834b1dcb1ba03629716b upstream.
Vince's fuzzer once again found holes. This time it spotted a leak in
the locked page accounting.
When an event had redirected output and its close() was the last
reference to the buffer we didn't have a vm context to undo accounting.
Change the code to destroy the buffer on the last munmap() and detach
all redirected events at that time. This provides us the right context
to undo the vm accounting.
[Backporting for 3.4-stable.
VM_RESERVED flag was replaced with pair 'VM_DONTEXPAND | VM_DONTDUMP' in
314e51b9 since 3.7.0-rc1, and 314e51b9 comes from a big patchset, we didn't
backport the patchset, so I restored 'VM_DNOTEXPAND | VM_DONTDUMP' as before:
- vma->vm_flags |= VM_DONTCOPY | VM_DONTEXPAND | VM_DONTDUMP;
+ vma->vm_flags |= VM_DONTCOPY | VM_RESERVED;
-- zliu]
Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net
Cc: <stable@kernel.org>
Signed-off-by: Zhouping Liu <zliu@redhat.com>
commit 26cb63ad11e04047a64309362674bcbbd6a6f246 upstream.
Vince reported a problem found by his perf specific trinity
fuzzer.
Al noticed 2 problems with perf's mmap():
- it has issues against fork() since we use vma->vm_mm for accounting.
- it has an rb refcount leak on double mmap().
We fix the issues against fork() by using VM_DONTCOPY; I don't
think there's code out there that uses this; we didn't hear
about weird accounting problems/crashes. If we do need this to
work, the previously proposed VM_PINNED could make this work.
Aside from the rb reference leak spotted by Al, Vince's example
prog was indeed doing a double mmap() through the use of
perf_event_set_output().
This exposes another problem, since we now have 2 events with
one buffer, the accounting gets screwy because we account per
event. Fix this by making the buffer responsible for its own
accounting.
-- zliu]
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net
commit 384e301e3519599b000c1a2ecd938b533fc15d85 upstream.
When we use pch_uart as system console like 'console=ttyPCH0,115200',
then 'send break' to it. We'll encounter the deadlock on a cpu/core,
with interrupts disabled on the core. When we happen to have all irqs
affinity to cpu0 then the deadlock on cpu0 actually deadlock whole
system.
In pch_uart_interrupt, we have spin_lock_irqsave(&priv->lock, flags)
then call pch_uart_err_ir when break is received. Then the call to
dev_err would actually call to pch_console_write then we'll run into
another spin_lock(&priv->lock), with interrupts disabled.
So in the call sequence lead by pch_uart_interrupt, we should be
carefully to call functions that will 'print message to console' only
in case the uart port is not being used as serial console.
Signed-off-by: Liang Li <liang.li@windriver.com>
Cc: Yijing Wang <wangyijing@huawei.com>
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream.
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no
mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are
in the middle of 'ubifs_readdir()'.
This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses
it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage,
but this may corrupt memory and lead to all kinds of problems like crashes an
security holes.
This patch fixes the problem by using the 'file->f_version' field, which
'->llseek()' always unconditionally sets to zero. We set it to 1 in
'ubifs_readdir()' and whenever we detect that it became 0, we know there was a
seek and it is time to clear the state saved in 'file->private_data'.
I tested this patch by writing a user-space program which runds readdir and
seek in parallell. I could easily crash the kernel without these patches, but
could not crash it with these patches.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream.
First of all, this means that 'file->private_data' can be freed while
'ubifs_readdir()' uses it. But this particular patch does not fix the problem.
This patch is only a preparation, and the fix will follow next.
In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly,
because 'file->f_pos' can be changed by '->llseek()' at any point. This may
lead 'ubifs_readdir()' to returning inconsistent data: directory entry names
may correspond to incorrect file positions.
So here we introduce a local variable 'pos', read 'file->f_pose' once at very
the beginning, and then stick to 'pos'. The result of this is that when
'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of
'ubifs_readdir()', the latter "wins".
commit 2976b10f05bd7f6dab9f9e7524451ddfed656a89 upstream.
There was a a bug in setup_new_exec(), whereby
the test to disabled perf monitoring was not
correct because the new credentials for the
process were not yet committed and therefore
the get_dumpable() test was never firing.
The patch fixes the problem by moving the
perf_event test until after the credentials
are committed.
Signed-off-by: Stephane Eranian <eranian@google.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 578a1310f2592ba90c5674bca21c1dbd1adf3f0a upstream.
We triggered an oops while running trinity with 3.4 kernel:
BUG: unable to handle kernel paging request at 0000000100000d07
IP: [<ffffffffa0109738>] dlci_ioctl+0xd8/0x2d4 [dlci]
PGD 640c0d067 PUD 0
Oops: 0000 [#1] PREEMPT SMP
CPU 3
Pid: 7302, comm: trinity-child3 Not tainted 3.4.24.09+ 40 Huawei Technologies Co., Ltd. Tecal RH2285 /BC11BTSA
RIP: 0010:[<ffffffffa0109738>] [<ffffffffa0109738>] dlci_ioctl+0xd8/0x2d4 [dlci]
Call Trace:
[<ffffffff8137c5c3>] sock_ioctl+0x153/0x280
[<ffffffff81195494>] do_vfs_ioctl+0xa4/0x5e0
[<ffffffff8118354a>] ? fget_light+0x3ea/0x490
[<ffffffff81195a1f>] sys_ioctl+0x4f/0x80
[<ffffffff81478b69>] system_call_fastpath+0x16/0x1b
It's because the net device is not a dlci device.
Reported-by: Li Jinyue <lijinyue@huawei.com>
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 11eb2645cbf38a08ae491bf6c602eea900ec0bb5 upstream.
Otherwise the net device returned can be freed at anytime.
commit c790b0ad23f427c7522ffed264706238c57c007e upstream.
fetch_bp_busy_slots() and toggle_bp_slot() use
for_each_online_cpu(), this is obviously wrong wrt cpu_up() or
cpu_down(), we can over/under account the per-cpu numbers.
For example:
# echo 0 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10 -p 1 &
# echo 1 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10 -C1 -a &
# taskset -p 0x2 1
triggers the same WARN_ONCE("Can't find any breakpoint slot") in
arch_install_hw_breakpoint().
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/20130620155009.GA6327@redhat.com
commit 300b962e5244a1ea010df7e88595faa0085b461d upstream.
If a too small MTU value is set with ioctl(HCISETACLMTU) or by a bogus
controller, memory corruption happens due to a memcpy() call with
negative length.
Fix this crash on either incoming or outgoing connections with a MTU
smaller than L2CAP_HDR_SIZE + L2CAP_CMD_HDR_SIZE:
[ 46.885433] BUG: unable to handle kernel paging request at f56ad000
[ 46.888037] IP: [<c03d94cd>] memcpy+0x1d/0x40
[ 46.888037] *pdpt = 0000000000ac3001 *pde = 00000000373f8067 *pte = 80000000356ad060
[ 46.888037] Oops: 0002 [#1] SMP DEBUG_PAGEALLOC
[ 46.888037] Modules linked in: hci_vhci bluetooth virtio_balloon i2c_piix4 uhci_hcd usbcore usb_common
[ 46.888037] CPU: 0 PID: 1044 Comm: kworker/u3:0 Not tainted 3.10.0-rc1+ #12
[ 46.888037] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 46.888037] Workqueue: hci0 hci_rx_work [bluetooth]
[ 46.888037] task: f59b15b0 ti: f55c4000 task.ti: f55c4000
[ 46.888037] EIP: 0060:[<c03d94cd>] EFLAGS: 00010212 CPU: 0
[ 46.888037] EIP is at memcpy+0x1d/0x40
[ 46.888037] EAX: f56ac1c0 EBX: fffffff8 ECX: 3ffffc6e EDX: f55c5cf2
[ 46.888037] ESI: f55c6b32 EDI: f56ad000 EBP: f55c5c68 ESP: f55c5c5c
[ 46.888037] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 46.888037] CR0: 8005003b CR2: f56ad000 CR3: 3557d000 CR4: 000006f0
[ 46.888037] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 46.888037] DR6: ffff0ff0 DR7: 00000400
[ 46.888037] Stack:
[ 46.888037] fffffff8 00000010 00000003 f55c5cac f8c6a54c ffffffff f8c69eb2 00000000
[ 46.888037] f4783cdc f57f0070 f759c590 1001c580 00000003 0200000a 00000000 f5a88560
[ 46.888037] f5ba2600 f5a88560 00000041 00000000 f55c5d90 f8c6f4c7 00000008 f55c5cf2
[ 46.888037] Call Trace:
[ 46.888037] [<f8c6a54c>] l2cap_send_cmd+0x1cc/0x230 [bluetooth]
[ 46.888037] [<f8c69eb2>] ? l2cap_global_chan_by_psm+0x152/0x1a0 [bluetooth]
[ 46.888037] [<f8c6f4c7>] l2cap_connect+0x3f7/0x540 [bluetooth]
[ 46.888037] [<c019b37b>] ? trace_hardirqs_off+0xb/0x10
[ 46.888037] [<c01a0ff8>] ? mark_held_locks+0x68/0x110
[ 46.888037] [<c064ad20>] ? mutex_lock_nested+0x280/0x360
[ 46.888037] [<c064b9d9>] ? __mutex_unlock_slowpath+0xa9/0x150
[ 46.888037] [<c01a118c>] ? trace_hardirqs_on_caller+0xec/0x1b0
[ 46.888037] [<c064ad08>] ? mutex_lock_nested+0x268/0x360
[ 46.888037] [<c01a125b>] ? trace_hardirqs_on+0xb/0x10
[ 46.888037] [<f8c72f8d>] l2cap_recv_frame+0xb2d/0x1d30 [bluetooth]
[ 46.888037] [<f8c754f1>] l2cap_recv_acldata+0x2a1/0x320 [bluetooth]
[ 46.888037] [<f8c491d8>] hci_rx_work+0x518/0x810 [bluetooth]
[ 46.888037] [<f8c48df2>] ? hci_rx_work+0x132/0x810 [bluetooth]
[ 46.888037] [<c0158979>] process_one_work+0x1a9/0x600
[ 46.888037] [<c01588fb>] ? process_one_work+0x12b/0x600
[ 46.888037] [<c015922e>] ? worker_thread+0x19e/0x320
[ 46.888037] [<c0159187>] worker_thread+0xf7/0x320
[ 46.888037] [<c0159090>] ? rescuer_thread+0x290/0x290
[ 46.888037] [<c01602f8>] kthread+0xa8/0xb0
[ 46.888037] [<c0656777>] ret_from_kernel_thread+0x1b/0x28
[ 46.888037] [<c0160250>] ? flush_kthread_worker+0x120/0x120
[ 46.888037] Code: c3 90 8d 74 26 00 e8 63 fc ff ff eb e8 90 55 89 e5 83 ec 0c 89 5d f4 89 75 f8 89 7d fc 3e 8d 74 26 00 89 cb 89 c7 c1 e9 02 89 d6 <f3> a5 89 d9 83 e1 03 74 02 f3 a4 8b 5d f4 8b 75 f8 8b 7d fc 89
[ 46.888037] EIP: [<c03d94cd>] memcpy+0x1d/0x40 SS:ESP 0068:f55c5c5c
[ 46.888037] CR2: 00000000f56ad000
[ 46.888037] ---[ end trace 0217c1f4d78714a9 ]---
Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 63384fd0b1509acf522a8a8fcede09087eedb7df upstream.
Commit 1bc3974 (ARM: 7755/1: handle user space mapped pages in
flush_kernel_dcache_page) moved the implementation of
flush_kernel_dcache_page() into mm/flush.c but did not implement it
on noMMU ARM.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Acked-by: Kevin Hilman <khilman@linaro.org>
commit 1bc39742aab09248169ef9d3727c9def3528b3f3 upstream.
Commit f8b63c1 made flush_kernel_dcache_page a no-op assuming that
the pages it needs to handle are kernel mapped only. However, for
example when doing direct I/O, pages with user space mappings may
occur.
Thus, continue to do lazy flushing if there are no user space
mappings. Otherwise, flush the kernel cache lines directly.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
commit 04df32fa10ab9a6f0643db2949d42efc966bc844 upstream.
When we run the crackerjack testsuite, the inotify_add_watch test is
stalled.
This is caused by the invalid mask 0 - the task is waiting for the event
but it never comes. inotify_add_watch() should return -EINVAL as it did
before commit 676a0675cf92 ("inotify: remove broken mask checks causing
unmount to be EINVAL"). That commit removes the invalid mask check, but
that check is needed.
Check the mask's ALL_INOTIFY_BITS before the inotify_arg_to_mask() call.
If none are set, just return -EINVAL.
Because IN_UNMOUNT is in ALL_INOTIFY_BITS, this change will not trigger
the problem that above commit fixed.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Eric Paris <eparis@parisplace.org>
commit 574780fd5e6ec52bd43e0bdb777a19e4c4c6aa9c upstream.
Here is a fun one. Bug seems to have been introduced by commit 140854cb,
almost two years ago. I have no idea why we only started seeing it now,
but we did.
Rough callgraph:
core_tpg_set_initiator_node_queue_depth()
`-> spin_lock_irqsave(&tpg->session_lock, flags);
`-> lio_tpg_shutdown_session()
`-> iscsit_stop_time2retain_timer()
`-> spin_unlock_bh(&se_tpg->session_lock);
`-> spin_lock_bh(&se_tpg->session_lock);
`-> spin_unlock_irqrestore(&tpg->session_lock, flags);
core_tpg_set_initiator_node_queue_depth() used to call spin_lock_bh(),
but 140854cb changed that to spin_lock_irqsave(). However,
lio_tpg_shutdown_session() still claims to be called with spin_lock_bh()
held, as does iscsit_stop_time2retain_timer():
* Called with spin_lock_bh(&struct se_portal_group->session_lock) held
Stale documentation is mostly annoying, but in this case the dropping
the lock with the _bh variant is plain wrong. It is also wrong to drop
locks two functions below the lock-holder, but I will ignore that bit
for now.
After some more locking and unlocking we eventually hit this backtrace:
WARNING: at kernel/softirq.c:159 local_bh_enable_ip+0xe8/0x100()
Pid: 24645, comm: lio_helper.py Tainted: G O 3.6.11+
Call Trace:
[<ffffffff8103e5ff>] warn_slowpath_common+0x7f/0xc0
[<ffffffffa040ae37>] ? iscsit_inc_conn_usage_count+0x37/0x50 [iscsi_target_mod]
[<ffffffff8103e65a>] warn_slowpath_null+0x1a/0x20
[<ffffffff810472f8>] local_bh_enable_ip+0xe8/0x100
[<ffffffff815b8365>] _raw_spin_unlock_bh+0x15/0x20
[<ffffffffa040ae37>] iscsit_inc_conn_usage_count+0x37/0x50 [iscsi_target_mod]
[<ffffffffa041149a>] iscsit_stop_session+0xfa/0x1c0 [iscsi_target_mod]
[<ffffffffa0417fab>] lio_tpg_shutdown_session+0x7b/0x90 [iscsi_target_mod]
[<ffffffffa033ede4>] core_tpg_set_initiator_node_queue_depth+0xe4/0x290 [target_core_mod]
[<ffffffffa0409032>] iscsit_tpg_set_initiator_node_queue_depth+0x12/0x20 [iscsi_target_mod]
[<ffffffffa0415c29>] lio_target_nacl_store_cmdsn_depth+0xa9/0x180 [iscsi_target_mod]
[<ffffffffa0331b49>] target_fabric_nacl_base_attr_store+0x39/0x40 [target_core_mod]
[<ffffffff811b857d>] configfs_write_file+0xbd/0x120
[<ffffffff81148f36>] vfs_write+0xc6/0x180
[<ffffffff81149251>] sys_write+0x51/0x90
[<ffffffff815c0969>] system_call_fastpath+0x16/0x1b
---[ end trace 3747632b9b164652 ]---
As a pure band-aid, this patch drops the _bh.
Signed-off-by: Joern Engel <joern@logfs.org>
commit 35a2fbc941accd0e9f1bfadd669311786118d874 upstream.
Add product id for Abbott strip port cable for Precision meter which
uses the TI 3410 chip.
Signed-off-by: Anders Hammarquist <iko@iko.pp.se>
commit d2983cdb480157f637df07723f28aaa657b1080d upstream.
memcpy param is wrong because of offset in bl_cmd, this may corrupt the
stack which may cause a crash.
Tested-by: Ferruh Yigit <fery@cypress.com> on TMA300-DVK
Signed-off-by: Ferruh Yigit <fery@cypress.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
[ Upstream commit 567b871e503316b0927e54a3d7c86d50b722d955 ]
Do not modify or load balance ARP packets passing through balance-alb
mode (wherein the ARP did not originate locally, and arrived via a bridge).
Modifying pass-through ARP replies causes an incorrect MAC address
to be placed into the ARP packet, rendering peers unable to communicate
with the actual destination from which the ARP reply originated.
Load balancing pass-through ARP requests causes an entry to be
created for the peer in the rlb table, and bond_alb_monitor will
occasionally issue ARP updates to all peers in the table instrucing them
as to which MAC address they should communicate with; this occurs when
some event sets rx_ntt. In the bridged case, however, the MAC address
used for the update would be the MAC of the slave, not the actual source
MAC of the originating destination. This would render peers unable to
communicate with the destinations beyond the bridge.
Signed-off-by: Zheng Li <zheng.x.li@oracle.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Signed-off-by: Matthew O'Connor <liquidhorse@gmail.com>
[ Upstream commit a6f79d0f26704214b5b702bbac525cb72997f984 ]
PPPoL2TP sockets should comply with the standard send*() return values
(i.e. return number of bytes sent instead of 0 upon success).
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 55b92b7a11690bc377b5d373872a6b650ae88e64 ]
Copy user data after PPP framing header. This prevents erasure of the
added PPP header and avoids leaking two bytes of uninitialised memory
at the end of skb's data buffer.
[ Upstream commit 2dc85bf323515e59e15dfa858d1472bb25cad0fe ]
uaddr->sa_data is exactly of size 14, which is hard-coded here and
passed as a size argument to strncpy(). A device name can be of size
IFNAMSIZ (== 16), meaning we might leave the destination string
unterminated. Thus, use strlcpy() and also sizeof() while we're
at it. We need to memset the data area beforehand, since strlcpy
does not padd the remaining buffer with zeroes for user space, so
that we do not possibly leak anything.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 76c455decbbad31de21c727edb184a963f42b40b ]
team_get_port_by_index_rcu() might return NULL due to race between port
removal and skb tx path. Panic is easily triggeable when txing packets
and adding/removing port in a loop.
introduced by commit 3d249d4ca "net: introduce ethernet teaming device"
and commit 753f993911b "team: introduce random mode" (for random mode)
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 1abd165ed757db1afdefaac0a4bc8a70f97d258c ]
While stress testing sctp sockets, I hit the following panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
PGD 7cead067 PUD 7ce76067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: sctp(F) libcrc32c(F) [...]
CPU: 7 PID: 2950 Comm: acc Tainted: GF 3.10.0-rc2+ #1
Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
task: ffff88007ce0e0c0 ti: ffff88007b568000 task.ti: ffff88007b568000
RIP: 0010:[<ffffffffa0490c4e>] [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP: 0018:ffff88007b569e08 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff88007db78a00 RCX: dead000000200200
RDX: ffffffffa049fdb0 RSI: ffff8800379baf38 RDI: 0000000000000000
RBP: ffff88007b569e18 R08: ffff88007c230da0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880077990d00 R14: 0000000000000084 R15: ffff88007db78a00
FS: 00007fc18ab61700(0000) GS:ffff88007fc60000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 000000007cf9d000 CR4: 00000000000007e0
Stack:
ffff88007b569e38 ffff88007db78a00 ffff88007b569e38 ffffffffa049fded
ffffffff81abf0c0 ffff88007db78a00 ffff88007b569e58 ffffffff8145b60e
0000000000000000 0000000000000000 ffff88007b569eb8 ffffffff814df36e
Call Trace:
[<ffffffffa049fded>] sctp_destroy_sock+0x3d/0x80 [sctp]
[<ffffffff8145b60e>] sk_common_release+0x1e/0xf0
[<ffffffff814df36e>] inet_create+0x2ae/0x350
[<ffffffff81455a6f>] __sock_create+0x11f/0x240
[<ffffffff81455bf0>] sock_create+0x30/0x40
[<ffffffff8145696c>] SyS_socket+0x4c/0xc0
[<ffffffff815403be>] ? do_page_fault+0xe/0x10
[<ffffffff8153cb32>] ? page_fault+0x22/0x30
[<ffffffff81544e02>] system_call_fastpath+0x16/0x1b
Code: 0c c9 c3 66 2e 0f 1f 84 00 00 00 00 00 e8 fb fe ff ff c9 c3 66 0f
1f 84 00 00 00 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 <48>
8b 47 20 48 89 fb c6 47 1c 01 c6 40 12 07 e8 9e 68 01 00 48
RIP [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP <ffff88007b569e08>
---[ end trace e0d71ec1108c1dd9 ]---
I did not hit this with the lksctp-tools functional tests, but with a
small, multi-threaded test program, that heavily allocates, binds,
listens and waits in accept on sctp sockets, and then randomly kills
some of them (no need for an actual client in this case to hit this).
Then, again, allocating, binding, etc, and then killing child processes.
This panic then only occurs when ``echo 1 > /proc/sys/net/sctp/auth_enable''
is set. The cause for that is actually very simple: in sctp_endpoint_init()
we enter the path of sctp_auth_init_hmacs(). There, we try to allocate
our crypto transforms through crypto_alloc_hash(). In our scenario,
it then can happen that crypto_alloc_hash() fails with -EINTR from
crypto_larval_wait(), thus we bail out and release the socket via
sk_common_release(), sctp_destroy_sock() and hit the NULL pointer
dereference as soon as we try to access members in the endpoint during
sctp_endpoint_free(), since endpoint at that time is still NULL. Now,
if we have that case, we do not need to do any cleanup work and just
leave the destruction handler.
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 534c877928a16ae5f9776436a497109639bf67dc ]
Commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
"net IPv6 : Fix broken IPv6 routing table after loopback down-up"
forgot to assign rt6_info to the inet6_ifaddr.
When disable the net device, the rt6_info which allocated
in init_loopback will not be destroied in __ipv6_ifa_notify.
This will trigger the waring message below
[23527.916091] unregister_netdevice: waiting for tap0 to become free. Usage count = 1
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit c87a124a5d5e8cf8e21c4363c3372bcaf53ea190 ]
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading
first item in the rcu protected list, in case the loop was restarted.
This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37
rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is
ptr->field :
In some cases, gcc caches the value or ptr->field in a register.
Use a barrier() to disallow such caching, as documented in
Documentation/atomic_ops.txt line 114
Thanks a lot to Roman for providing analysis and numerous patches.
Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru>
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit a622260254ee481747cceaaa8609985b29a31565 ]
Daniel Petre reported crashes in icmp_dst_unreach() with following call
graph:
Daniel found a similar problem mentioned in
http://lkml.indiana.edu/hypermail/linux/kernel/1007.0/00961.html
And indeed this is the root cause : skb->cb[] contains data fooling IP
stack.
We must clear IPCB in ip_tunnel_xmit() sooner in case dst_link_failure()
is called. Or else skb->cb[] might contain garbage from GSO segmentation
layer.
A similar fix was tested on linux-3.9, but gre code was refactored in
linux-3.10. I'll send patches for stable kernels as well.
Many thanks to Daniel for providing reports, patches and testing !
Reported-by: Daniel Petre <daniel.petre@rcs-rds.ro>
[ Upstream commit 547669d483e5783d722772af1483fa474da7caf9 ]
commit 3853b5841c01a ("xps: Improvements in TX queue selection")
introduced ooo_okay flag, but the condition to set it is slightly wrong.
In our traces, we have seen ACK packets being received out of order,
and RST packets sent in response.
We should test if we have any packets still in host queue.
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 35f079ebbc860dcd1cca70890c9c8d59c1145525 ]
This patch is a fix for a bug triggering newly_acked_sacked < 0
in tcp_ack(.).
The bug is triggered by sacked_out decreasing relative to prior_sacked,
but packets_out remaining the same as pior_packets. This is because the
snapshot of prior_packets is taken after tcp_sacktag_write_queue() while
prior_sacked is captured before tcp_sacktag_write_queue(). The problem
is: tcp_sacktag_write_queue (tcp_match_skb_to_sack() -> tcp_fragment)
adjusts the pcount for packets_out and sacked_out (MSS change or other
reason). As a result, this delta in pcount is reflected in
(prior_sacked - sacked_out) but not in (prior_packets - packets_out).
This patch does the following:
1) initializes prior_packets at the start of tcp_ack() so as to
capture the delta in packets_out created by tcp_fragment.
2) introduces a new "previous_packets_out" variable that snapshots
packets_out right before tcp_clean_rtx_queue, so pkts_acked can be
correctly computed as before.
3) Computes pkts_acked using previous_packets_out, and computes
newly_acked_sacked using prior_packets.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 98962baad72fd6d393bf39dbb7c2076532c363c6 ]
This patch cures transmit timeout's with DHCP observed
while running under KVM. When the transmit ring is cleaned out,
the Byte Queue Limit values need to be reset.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit b423e9ae49d78ea3f53b131c8d5a6087aed16fd6 ]
8168evl offloaded checksums are wrong since commit
e5195c1f31f399289347e043d6abf3ffa80f0005 ("r8169: fix 8168evl frame padding.")
pads small packets to 60 bytes (without ethernet checksum). Typical symptoms
appear as UDP checksums which are wrong by the count of added bytes.
It isn't worth compensating. Let the driver checksum.
Due to the skb length changes, TSO code is moved before the Tx descriptor gets
written.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Tested-by: Holger Hoffstätte <holger.hoffstaette@googlemail.com>
[ Upstream commit 6b21e1b77d1a3d58ebfd513264c885695e8a0ba5 ]
The net/netlabel/netlabel_domainhash.c:netlbl_domhsh_add() function
does not properly validate new domain hash entries resulting in
potential problems when an administrator attempts to add an invalid
entry. One such problem, as reported by Vlad Halilov, is a kernel
BUG (found in netlabel_domainhash.c:netlbl_domhsh_audit_add()) when
adding an IPv6 outbound mapping with a CIPSO configuration.
This patch corrects this problem by adding the necessary validation
code to netlbl_domhsh_add() via the newly created
netlbl_domhsh_validate() function.
Ideally this patch should also be pushed to the currently active
-stable trees.
Reported-by: Vlad Halilov <vlad.halilov@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit 284041ef21fdf2e0d216ab6b787bc9072b4eb58a ]
commit 0178b695fd6b4 ("ipv6: Copy cork options in ip6_append_data")
added some code duplication and bad error recovery, leading to potential
crash in ip6_cork_release() as kfree() could be called with garbage.
use kzalloc() to make sure this wont happen.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
[ Upstream commit e5f5e380e0f3bb11f04ca5bc66a551e58e0ad26e ]
Add the missing iounmap() before return from gianfar_ptp_probe()
in the error handling case.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
[ Upstream commit 54d27fcb338bd9c42d1dfc5a39e18f6f9d373c2e ]
TCP md5 communications fail [1] for some devices, because sg/crypto code
assume page offsets are below PAGE_SIZE.
This was discovered using mlx4 driver [2], but I suspect loopback
might trigger the same bug now we use order-3 pages in tcp_sendmsg()
[1] Failure is giving following messages.
huh, entered softirq 3 NET_RX ffffffff806ad230 preempt_count 00000100,
exited with 00000101?
[2] mlx4 driver uses order-2 pages to allocate RX frags
Reported-by: Matt Schnall <mischnal@google.com>
Cc: Bernhard Beck <bbeck@google.com>
commit 764bcbc5a6d7a2f3e75c9f0e4caa984e2926e346 upstream.
__kvm_set_xcr function does the CPL check when set xcr. __kvm_set_xcr is
called in two flows, one is invoked by guest, call stack shown as below,
handle_xsetbv(or xsetbv_interception)
kvm_set_xcr
__kvm_set_xcr
the other one is invoked by host, for example during system reset:
kvm_arch_vcpu_ioctl
kvm_vcpu_ioctl_x86_set_xcrs
__kvm_set_xcr
The former does need the CPL check, but the latter does not.
Signed-off-by: Zhang Haoyu <haoyu.zhang@huawei.com>
[Tweaks to commit message. - Paolo]
commit 3cb3f839d306443f3d1e79b0bde1a2ad2c12b555 upstream.
gcc 4.7.x is emitting calls to __ffsdi2 where previously
it used to inline the appropriate ctz instructions.
While this needs to be fixed in gcc, it's also easy to avoid
having it cause build failures when building with those
compilers by exporting __ffsdi2 to modules.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
commit 72b5322f11ff0abf6a52b3007486656578d2c982 upstream.
The @cn is stay in @clk_notifier_list after it is freed, it cause
memory corruption.
Example, if @clk is registered(first), unregistered(first),
registered(second), unregistered(second).
The freed @cn will be used when @clk is registered(second),
and the bug will be happened when @clk is unregistered(second):
[ 517.040000] clk_notif_dbg clk_notif_dbg.1: clk_notifier_unregister()
[ 517.040000] Unable to handle kernel paging request at virtual address 00df3008
[ 517.050000] pgd = ed858000
[ 517.050000] [00df3008] *pgd=00000000
[ 517.060000] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 517.060000] Modules linked in: clk_notif_dbg(O-) [last unloaded: clk_notif_dbg]
[ 517.060000] CPU: 1 PID: 499 Comm: modprobe Tainted: G O 3.10.0-rc3-00119-ga93cb29-dirty #85
[ 517.060000] task: ee1e0180 ti: ee3e6000 task.ti: ee3e6000
[ 517.060000] PC is at srcu_readers_seq_idx+0x48/0x84
[ 517.060000] LR is at srcu_readers_seq_idx+0x60/0x84
[ 517.060000] pc : [<c0052720>] lr : [<c0052738>] psr: 80070013
[ 517.060000] sp : ee3e7d48 ip : 00000000 fp : ee3e7d6c
[ 517.060000] r10: 00000000 r9 : ee3e6000 r8 : 00000000
[ 517.060000] r7 : ed84fe4c r6 : c068ec90 r5 : c068e430 r4 : 00000000
[ 517.060000] r3 : 00df3000 r2 : 00000000 r1 : 00000002 r0 : 00000000
[ 517.060000] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 517.060000] Control: 18c5387d Table: 2d85804a DAC: 00000015
[ 517.060000] Process modprobe (pid: 499, stack limit = 0xee3e6238)
[ 517.060000] Stack: (0xee3e7d48 to 0xee3e8000)
[ 517.060000] [<c0052720>] (srcu_readers_seq_idx+0x48/0x84) from [<c0052790>] (try_check_zero+0x34/0xfc)
[ 517.060000] [<c0052790>] (try_check_zero+0x34/0xfc) from [<c00528b0>] (srcu_advance_batches+0x58/0x114)
[ 517.060000] [<c00528b0>] (srcu_advance_batches+0x58/0x114) from [<c0052c30>] (__synchronize_srcu+0x114/0x1ac)
[ 517.060000] [<c0052c30>] (__synchronize_srcu+0x114/0x1ac) from [<c0052d14>] (synchronize_srcu+0x2c/0x34)
[ 517.060000] [<c0052d14>] (synchronize_srcu+0x2c/0x34) from [<c0053a08>] (srcu_notifier_chain_unregister+0x68/0x74)
[ 517.060000] [<c0053a08>] (srcu_notifier_chain_unregister+0x68/0x74) from [<c0375a78>] (clk_notifier_unregister+0x7c/0xc0)
[ 517.060000] [<c0375a78>] (clk_notifier_unregister+0x7c/0xc0) from [<bf008034>] (clk_notif_dbg_remove+0x34/0x9c [clk_notif_dbg])
[ 517.060000] [<bf008034>] (clk_notif_dbg_remove+0x34/0x9c [clk_notif_dbg]) from [<c02bb974>] (platform_drv_remove+0x24/0x28)
[ 517.060000] [<c02bb974>] (platform_drv_remove+0x24/0x28) from [<c02b9bf8>] (__device_release_driver+0x8c/0xd4)
[ 517.060000] [<c02b9bf8>] (__device_release_driver+0x8c/0xd4) from [<c02ba680>] (driver_detach+0x9c/0xc4)
[ 517.060000] [<c02ba680>] (driver_detach+0x9c/0xc4) from [<c02b99c4>] (bus_remove_driver+0xcc/0xfc)
[ 517.060000] [<c02b99c4>] (bus_remove_driver+0xcc/0xfc) from [<c02bace4>] (driver_unregister+0x54/0x78)
[ 517.060000] [<c02bace4>] (driver_unregister+0x54/0x78) from [<c02bbb44>] (platform_driver_unregister+0x1c/0x20)
[ 517.060000] [<c02bbb44>] (platform_driver_unregister+0x1c/0x20) from [<bf0081f8>] (clk_notif_dbg_driver_exit+0x14/0x1c [clk_notif_dbg])
[ 517.060000] [<bf0081f8>] (clk_notif_dbg_driver_exit+0x14/0x1c [clk_notif_dbg]) from [<c00835e4>] (SyS_delete_module+0x200/0x28c)
[ 517.060000] [<c00835e4>] (SyS_delete_module+0x200/0x28c) from [<c000edc0>] (ret_fast_syscall+0x0/0x48)
[ 517.060000] Code: e5973004 e7911102 e0833001 e2881002 (e7933101)
Reported-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Tested-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
[mturquette@linaro.org: shortened $SUBJECT]
commit 342cda29343a6272c630f94ed56810a76740251b upstream.
When the Android firmware enables the audio interfaces in accessory
mode, it always declares in the control interface's baInterfaceNr array
that interfaces 0 and 1 belong to the audio function. However, the
accessory interface itself, if also enabled, already is at index 0 and
shifts the actual audio interface numbers to 1 and 2, which prevents the
PCM streaming interface from being seen by the host driver.
To get the PCM interface interface to work, detect when the descriptors
point to the (for this driver useless) accessory interface, and redirect
to the correct one.
Reported-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Tested-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 36691e1be6ec551eef4a5225f126a281f8c051c2 upstream.
Just like the previous fix for LogitechHD Webcam c270 in commit
11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the
same workaround for avoiding the kernel warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741
commit 230b3034793247f61e6a0b08c44cf415f6d92981 upstream.
When replaying interrupts (as a result of the interrupt occurring
while soft-disabled), in the case of the decrementer, we are exclusively
testing for a pending timer target. However we also use decrementer
interrupts to trigger the new "irq_work", which in this case would
be missed.
This change the logic to force a replay in both cases of a timer
boundary reached and a decrementer interrupt having actually occurred
while disabled. The former test is still useful to catch cases where
a CPU having been hard-disabled for a long time completely misses the
interrupt due to a decrementer rollover.
Tested-by: Steven Rostedt <rostedt@goodmis.org>
commit 0e37739b1c96d65e6433998454985de994383019 upstream.
It's possible for us to crash when running with ftrace enabled, eg:
Bad kernel stack pointer bffffd12 at c00000000000a454
cpu 0x3: Vector: 300 (Data Access) at [c00000000ffe3d40]
pc: c00000000000a454: resume_kernel+0x34/0x60
lr: c00000000000335c: performance_monitor_common+0x15c/0x180
sp: bffffd12
msr: 8000000000001032
dar: bffffd12
dsisr: 42000000
If we look at current's stack (paca->__current->stack) we see it is
equal to c0000002ecab0000. Our stack is 16K, and comparing to
paca->kstack (c0000002ecab3e30) we can see that we have overflowed our
kernel stack. This leads to us writing over our struct thread_info, and
in this case we have corrupted thread_info->flags and set
_TIF_EMULATE_STACK_STORE.
Dumping the stack we see:
3:mon> t c0000002ecab0000
[c0000002ecab0000] c00000000002131c .performance_monitor_exception+0x5c/0x70
[c0000002ecab0080] c00000000000335c performance_monitor_common+0x15c/0x180
--- Exception: f01 (Performance Monitor) at c0000000000fb2ec .trace_hardirqs_off+0x1c/0x30
[c0000002ecab0370] c00000000016fdb0 .trace_graph_entry+0xb0/0x280 (unreliable)
[c0000002ecab0410] c00000000003d038 .prepare_ftrace_return+0x98/0x130
[c0000002ecab04b0] c00000000000a920 .ftrace_graph_caller+0x14/0x28
[c0000002ecab0520] c0000000000d6b58 .idle_cpu+0x18/0x90
[c0000002ecab05a0] c00000000000a934 .return_to_handler+0x0/0x34
[c0000002ecab0620] c00000000001e660 .timer_interrupt+0x160/0x300
[c0000002ecab06d0] c0000000000025dc decrementer_common+0x15c/0x180
--- Exception: 901 (Decrementer) at c0000000000104d4 .arch_local_irq_restore+0x74/0xa0
[c0000002ecab09c0] c0000000000fe044 .trace_hardirqs_on+0x14/0x30 (unreliable)
[c0000002ecab0fb0] c00000000016fe3c .trace_graph_entry+0x13c/0x280
[c0000002ecab1050] c00000000003d038 .prepare_ftrace_return+0x98/0x130
[c0000002ecab10f0] c00000000000a920 .ftrace_graph_caller+0x14/0x28
[c0000002ecab1160] c0000000000161f0 .__ppc64_runlatch_on+0x10/0x40
[c0000002ecab11d0] c00000000000a934 .return_to_handler+0x0/0x34
... and so on
__ppc64_runlatch_on() is called from RUNLATCH_ON in the exception entry
path. At that point the irq state is not consistent, ie. interrupts are
hard disabled (by the exception entry), but the paca soft-enabled flag
may be out of sync.
This leads to the local_irq_restore() in trace_graph_entry() actually
enabling interrupts, which we do not want. Because we have not yet
reprogrammed the decrementer we immediately take another decrementer
exception, and recurse.
The fix is twofold. Firstly make sure we call DISABLE_INTS before
calling RUNLATCH_ON. The badly named DISABLE_INTS actually reconciles
the irq state in the paca with the hardware, making it safe again to
call local_irq_save/restore().
Although that should be sufficient to fix the bug, we also mark the
runlatch routines as notrace. They are called very early in the
exception entry and we are asking for trouble tracing them. They are
also fairly uninteresting and tracing them just adds unnecessary
overhead.
[ This regression was introduced by fe1952fc0afb9a2e4c79f103c08aef5d13db1873
"powerpc: Rework runlatch code" by myself --BenH
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
commit 92a49fb0f79f3300e6e50ddf56238e70678e4202 upstream.
Different versions of glibc are broken in different ways, but the short of
it is that for the time being, frsize should == bsize, and be used as the
multiple for the blocks, free, and available fields. This mirrors what is
done for NFS. The previous reporting of the page size for frsize meant
that newer glibc and df would report a very small value for the fs size.
Fixes http://tracker.ceph.com/issues/3793.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Greg Farnum <greg@inktank.com>
commit e9966076cdd952e19f2dd4854cd719be0d7cbebc upstream.
The auth code is called from a variety of contexts, include the mon_client
(protected by the monc's mutex) and the messenger callbacks (currently
protected by nothing). Avoid chaos by protecting all auth state with a
mutex. Nothing is blocking, so this should be simple and lightweight.
Reviewed-by: Alex Elder <elder@inktank.com>
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream.
Use wrapper functions that check whether the auth op exists so that callers
do not need a bunch of conditional checks. Simplifies the external
interface.
commit 0bed9b5c523d577378b6f83eab5835fe30c27208 upstream.
Currently the messenger calls out to a get_authorizer con op, which will
create a new authorizer if it doesn't yet have one. In the meantime, when
we rotate our service keys, the authorizer doesn't get updated. Eventually
it will be rejected by the server on a new connection attempt and get
invalidated, and we will then rebuild a new authorizer, but this is not
ideal.
Instead, if we do have an authorizer, call a new update_authorizer op that
will verify that the current authorizer is using the latest secret. If it
is not, we will build a new one that does. This avoids the transient
failure.
This fixes one of the sorry sequence of events for bug
http://tracker.ceph.com/issues/4282
commit 4b8e8b5d78b8322351d44487c1b76f7e9d3412bc upstream.
We were invalidating the authorizer by removing the ticket handler
entirely. This was effective in inducing us to request a new authorizer,
but in the meantime it mean that any authorizer we generated would get a
new and initialized handler with secret_id=0, which would always be
rejected by the server side with a confusing error message:
auth: could not find secret_id=0
cephx: verify_authorizer could not get service secret for service osd secret_id=0
Instead, simply clear the validity field. This will still induce the auth
code to request a new secret, but will let us continue to use the old
ticket in the meantime. The messenger code will probably continue to fail,
but the exponential backoff will kick in, and eventually the we will get a
new (hopefully more valid) ticket from the mon and be able to continue.
commit 20e55c4cc758e4dccdfd92ae8e9588dd624b2cd7 upstream.
We maintain a counter of failed auth attempts to allow us to retry once
before failing. However, if the second attempt succeeds, the flag isn't
cleared, which makes us think auth failed again later when the connection
resets for other reasons (like a socket error).
This is one part of the sorry sequence of events in bug
