2012-12-05Linux 3.4.22v3.4.22Greg Kroah-Hartman
2012-12-05x86-32: Export kernel_stack_pointer() for modulesH. Peter Anvin
commit cb57a2b4cff7edf2a4e32c0163200e9434807e0a upstream. Modules, in particular oprofile (and possibly other similar tools) need kernel_stack_pointer(), so export it using EXPORT_SYMBOL_GPL(). Cc: Yang Wei <wei.yang@windriver.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Jun Zhang <jun.zhang@intel.com> Link: http://lkml.kernel.org/r/20120912135059.GZ8285@erda.amd.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Robert Richter <rric@kernel.org> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Philip Müller <philm@manjaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03Linux 3.4.21v3.4.21Greg Kroah-Hartman
2012-12-03iwlwifi: fix 6000 series channel switch commandJohannes Berg
commit 8f7b8db6e0557c8437adf9371e020cd89a7e85dc upstream. The channel switch command for 6000 series devices is larger than the maximum inline command size of 320 bytes. The command is therefore refused with a warning. Fix this by allocating the command and using the NOCOPY mechanism. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03net/wireless: ipw2200: Fix panic occurring in ipw_handle_promiscuous_tx()Stanislav Yakovlev
commit bf11315eeda510ea4fc1a2bf972d8155d31d89b4 upstream. The driver does not count space of radiotap fields when allocating skb for radiotap packet. This leads to kernel panic with the following call trace: ... [67607.676067] [<c152f90f>] error_code+0x67/0x6c [67607.676067] [<c142f831>] ? skb_put+0x91/0xa0 [67607.676067] [<f8cf5e5b>] ? ipw_handle_promiscuous_tx+0x16b/0x2d0 [ipw2200] [67607.676067] [<f8cf5e5b>] ipw_handle_promiscuous_tx+0x16b/0x2d0 [ipw2200] [67607.676067] [<f8cf899b>] ipw_net_hard_start_xmit+0x8b/0x90 [ipw2200] [67607.676067] [<f8741c5a>] libipw_xmit+0x55a/0x980 [libipw] [67607.676067] [<c143d3e8>] dev_hard_start_xmit+0x218/0x4d0 ... This bug was found by VittGam. https://bugzilla.kernel.org/show_bug.cgi?id=43255 Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03timekeeping: Cast raw_interval to u64 to avoid shift overflowDan Carpenter
commit 5b3900cd409466c0070b234d941650685ad0c791 upstream. We fixed a bunch of integer overflows in timekeeping code during the 3.6 cycle. I did an audit based on that and found this potential overflow. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: John Stultz <johnstul@us.ibm.com> Link: http://lkml.kernel.org/r/20121009071823.GA19159@elgon.mountain Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ben Hutchings <ben@decadent.org.uk> [ herton: adapt for 3.5, timekeeper instead of tk pointer ] Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ARM: OMAP: counter: add locking to read_persistent_clockColin Cross
commit 9d7d6e363b06934221b81a859d509844c97380df upstream. read_persistent_clock uses a global variable, use a spinlock to ensure non-atomic updates to the variable don't overlap and cause time to move backwards. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03mmc: sdhci-s3c: fix the wrong number of max bus clocksJaehoon Chung
commit 5feb54a1ab91a237e247c013b8c4fb100ea347b1 upstream. We can use up to four bus-clocks; but on module remove, we didn't disable the fourth bus clock. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03powerpc/eeh: Lock module while handling EEH eventGavin Shan
commit feadf7c0a1a7c08c74bebb4a13b755f8c40e3bbc upstream. The EEH core is talking with the PCI device driver to determine the action (purely reset, or PCI device removal). During the period, the driver might be unloaded and in turn causes kernel crash as follows: EEH: Detected PCI bus error on PHB#4-PE#10000 EEH: This PCI device has failed 3 times in the last hour lpfc 0004:01:00.0: 0:2710 PCI channel disable preparing for reset Unable to handle kernel paging request for data at address 0x00000490 Faulting instruction address: 0xd00000000e682c90 cpu 0x1: Vector: 300 (Data Access) at [c000000fc75ffa20] pc: d00000000e682c90: .lpfc_io_error_detected+0x30/0x240 [lpfc] lr: d00000000e682c8c: .lpfc_io_error_detected+0x2c/0x240 [lpfc] sp: c000000fc75ffca0 msr: 8000000000009032 dar: 490 dsisr: 40000000 current = 0xc000000fc79b88b0 paca = 0xc00000000edb0380 softe: 0 irq_happened: 0x00 pid = 3386, comm = eehd enter ? for help [c000000fc75ffca0] c000000fc75ffd30 (unreliable) [c000000fc75ffd30] c00000000004fd3c .eeh_report_error+0x7c/0xf0 [c000000fc75ffdc0] c00000000004ee00 .eeh_pe_dev_traverse+0xa0/0x180 [c000000fc75ffe70] c00000000004ffd8 .eeh_handle_event+0x68/0x300 [c000000fc75fff00] c0000000000503a0 .eeh_event_handler+0x130/0x1a0 [c000000fc75fff90] c000000000020138 .kernel_thread+0x54/0x70 1:mon> The patch increases the reference of the corresponding driver modules while EEH core does the negotiation with PCI device driver so that the corresponding driver modules can't be unloaded during the period and we're safe to refer the callbacks. Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [ herton: backported for 3.5, adjusted driver assignments, return 0 instead of NULL, assume dev is not NULL ] Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03MPI: Fix compilation on MIPS with GCC 4.4 and newerManuel Lauss
commit a3cea9894157c20a5b1ec08b7e0b5f2019740c10 upstream. Since 4.4 GCC on MIPS no longer recognizes the "h" constraint, leading to this build failure: CC lib/mpi/generic_mpih-mul1.o lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1': lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm' This patch updates MPI with the latest umul_ppm implementations for MIPS. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: James Morris <jmorris@namei.org> Patchwork: https://patchwork.linux-mips.org/patch/4612/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03watchdog: using u64 in get_sample_period()Chuansheng Liu
commit 8ffeb9b0e6369135bf03a073514f571ef10606b9 upstream. In get_sample_period(), unsigned long is not enough: watchdog_thresh * 2 * (NSEC_PER_SEC / 5) case1: watchdog_thresh is 10 by default, the sample value will be: 0xEE6B2800 case2: set watchdog_thresh is 20, the sample value will be: 0x1 DCD6 5000 In case2, we need use u64 to express the sample period. Otherwise, changing the threshold thru proc often can not be successful. Signed-off-by: liu chuansheng <chuansheng.liu@intel.com> Acked-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03USB: mct_u232: fix broken closeJohan Hovold
commit 5260e458f5eff269a43e4f1e9c47186c57b88ddb upstream. Make sure generic close is called at close. The driver relies on the generic write implementation but did not call generic close. Note that the call to kill the read urb is not redundant, as mct_u232 uses an interrupt urb from the second port as the read urb and that generic close therefore fails to kill it. Compile-only tested. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-03NFC: Fix nfc_llcp_local chained list insertionThierry Escande
commit 16a78e9fed5e8baa8480ae3413f4328c4537c599 upstream. list_add was called with swapped parameters Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03NFC: pn533: Fix mem leak in pn533_in_dep_link_upWaldemar Rymarkiewicz
commit 70418e6efcf4f8652cc08e3f2ab8ae35f0948fd9 upstream. cmd is allocated in pn533_dep_link_up and passed as an arg to pn533_send_cmd_frame_async together with a complete cb. arg is passed to the cb and must be kfreed there. Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03NFC: pn533: Fix use after freeSzymon Janc
commit 770f750bc2b8312489c8e45306f551d08a319d3c upstream. cmd was freed in pn533_dep_link_up regardless of pn533_send_cmd_frame_async return code. Cmd is passed as argument to pn533_in_dep_link_up_complete callback and should be freed there. Signed-off-by: Szymon Janc <szymon.janc@tieto.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03get_dvb_firmware: fix download site for tda10046 firmwareMauro Carvalho Chehab
commit 25ec43d3e6306978cf66060ed18c4160ce8fc302 upstream. The previous website doesn't exist anymore. Update it to one site that actually exists. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03sata_svw: check DMA start bit before resetDavid Milburn
commit b03e66a6be91f8389fcd902ab6c1563db1c9c06b upstream. If kdump is triggered with pending IO, controller may not respond causing kdump to fail. http://marc.info/?l=linux-ide&m=133032255424658&w=2 During error recovery ata_do_dev_read_id never completes due hang in mmio_insw. ata_do_dev_read_id ata_sff_data_xfer ioread16_rep mmio_insw if DMA start bit is cleared before reset, PIO command is successful and kdump succeeds. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ixgbe: add support for X540-AT1joshua.a.hay@intel.com
commit df376f0de167754da9b3ece4afdb5bb8bf3fbf3e upstream. This patch adds device support for Ethernet Controller X540-AT1. Signed-off-by: Josh Hay <joshua.a.hay@intel.com> Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Abdallah Chatila <Abdallah.Chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03KVM: x86: invalid opcode oops on SET_SREGS with OSXSAVE bit set (CVE-2012-4461)Petr Matousek
commit 6d1068b3a98519247d8ba4ec85cd40ac136dbdf9 upstream. On hosts without the XSAVE support unprivileged local user can trigger oops similar to the one below by setting X86_CR4_OSXSAVE bit in guest cr4 register using KVM_SET_SREGS ioctl and later issuing KVM_RUN ioctl. invalid opcode: 0000 [#2] SMP Modules linked in: tun ip6table_filter ip6_tables ebtable_nat ebtables ... Pid: 24935, comm: zoog_kvm_monito Tainted: G D 3.2.0-3-686-pae EIP: 0060:[<f8b9550c>] EFLAGS: 00210246 CPU: 0 EIP is at kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] EAX: 00000001 EBX: 000f387e ECX: 00000000 EDX: 00000000 ESI: 00000000 EDI: 00000000 EBP: ef5a0060 ESP: d7c63e70 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process zoog_kvm_monito (pid: 24935, ti=d7c62000 task=ed84a0c0 task.ti=d7c62000) Stack: 00000001 f70a1200 f8b940a9 ef5a0060 00000000 00200202 f8769009 00000000 ef5a0060 000f387e eda5c020 8722f9c8 00015bae 00000000 ed84a0c0 ed84a0c0 c12bf02d 0000ae80 ef7f8740 fffffffb f359b740 ef5a0060 f8b85dc1 0000ae80 Call Trace: [<f8b940a9>] ? kvm_arch_vcpu_ioctl_set_sregs+0x2fe/0x308 [kvm] ... [<c12bfb44>] ? syscall_call+0x7/0xb Code: 89 e8 e8 14 ee ff ff ba 00 00 04 00 89 e8 e8 98 48 ff ff 85 c0 74 1e 83 7d 48 00 75 18 8b 85 08 07 00 00 31 c9 8b 95 0c 07 00 00 <0f> 01 d1 c7 45 48 01 00 00 00 c7 45 1c 01 00 00 00 0f ae f0 89 EIP: [<f8b9550c>] kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] SS:ESP 0068:d7c63e70 QEMU first retrieves the supported features via KVM_GET_SUPPORTED_CPUID and then sets them later. So guest's X86_FEATURE_XSAVE should be masked out on hosts without X86_FEATURE_XSAVE, making kvm_set_cr4 with X86_CR4_OSXSAVE fail. Userspaces that allow specifying guest cpuid with X86_FEATURE_XSAVE even on hosts that do not support it, might be susceptible to this attack from inside the guest as well. Allow setting X86_CR4_OSXSAVE bit only if host has XSAVE support. Signed-off-by: Petr Matousek <pmatouse@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03scsi: Silence unnecessary warnings about ioctl to partitionJan Kara
commit 6d9359280753d2955f86d6411047516a9431eb51 upstream. Sometimes, warnings about ioctls to partition happen often enough that they form majority of the warnings in the kernel log and users complain. In some cases warnings are about ioctls such as SG_IO so it's not good to get rid of the warnings completely as they can ease debugging of userspace problems when ioctl is refused. Since I have seen warnings from lots of commands, including some proprietary userspace applications, I don't think disallowing the ioctls for processes with CAP_SYS_RAWIO will happen in the near future if ever. So lets just stop warning for processes with CAP_SYS_RAWIO for which ioctl is allowed. Acked-by: Paolo Bonzini <pbonzini@redhat.com> CC: Paolo Bonzini <pbonzini@redhat.com> CC: James Bottomley <JBottomley@parallels.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: satoru takeuchi <satoru.takeuchi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03bas_gigaset: fix pre_reset handlingTilman Schmidt
commit c6fdd8e5d0c65bb8821dc6da26ee1a2ddd58b3cc upstream. The delayed work function int_in_work() may call usb_reset_device() and thus, indirectly, the driver's pre_reset method. Trying to cancel the work synchronously in that situation would deadlock. Fix by avoiding cancel_work_sync() in the pre_reset method. If the reset was NOT initiated by int_in_work() this might cause int_in_work() to run after the post_reset method, with urb_int_in already resubmitted, so handle that case gracefully. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Add support for Realtek ALC292David Henningsson
commit af02dde8a609d8d071c4b31a82df811a55690a4a upstream. We found a new codec ID 292, and that just a simple quirk would enable sound output/input on this ALC292 chip. BugLink: https://bugs.launchpad.net/bugs/1081466 Tested-by: Acelan Kao <acelan.kao@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Fix missing beep on ASUS X43U notebookDuncan Roe
commit 7110005e8d5c3cd418fc4b64f9f124f004422a9a upstream. Signed-off-by: Duncan Roe <duncan_roe@acslink.net.au> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Add new codec ALC283 ALC290 supportKailang Yang
commit 7ff34ad80b7080fafaac8efa9ef0061708eddd51 upstream. These are compatible with standard ALC269 parser. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03PM / QoS: fix wrong error-checking conditionGuennadi Liakhovetski
commit a7227a0faa117d0bc532aea546ae5ac5f89e8ed7 upstream. dev_pm_qos_add_request() can return 0, 1, or a negative error code, therefore the correct error test is "if (error < 0)." Checking just for non-zero return code leads to erroneous setting of the req->dev pointer to NULL, which then leads to a repeated call to dev_pm_qos_add_ancestor_request() in st1232_ts_irq_handler(). This in turn leads to an Oops, when the I2C host adapter is unloaded and reloaded again because of the inconsistent state of its QoS request list. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03sparc64: not any error from do_sigaltstack() should fail rt_sigreturn()Al Viro
commit fae2ae2a900a5c7bb385fe4075f343e7e2d5daa2 upstream. If a signal handler is executed on altstack and another signal comes, we will end up with rt_sigreturn() on return from the second handler getting -EPERM from do_sigaltstack(). It's perfectly OK, since we are not asking to change the settings; in fact, they couldn't have been changed during the second handler execution exactly because we'd been on altstack all along. 64bit sigreturn on sparc treats any error from do_sigaltstack() as "SIGSEGV now"; we need to switch to the same semantics we are using on other architectures. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03jbd: Fix lock ordering bug in journal_unmap_buffer()Jan Kara
commit 25389bb207987b5774182f763b9fb65ff08761c8 upstream. Commit 09e05d48 introduced a wait for transaction commit into journal_unmap_buffer() in the case we are truncating a buffer undergoing commit in the page stradding i_size on a filesystem with blocksize < pagesize. Sadly we forgot to drop buffer lock before waiting for transaction commit and thus deadlock is possible when kjournald wants to lock the buffer. Fix the problem by dropping the buffer lock before waiting for transaction commit. Since we are still holding page lock (and that is OK), buffer cannot disappear under us. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03can: bcm: initialize ifindex for timeouts without previous frame receptionOliver Hartkopp
commit 81b401100c01d2357031e874689f89bd788d13cd upstream. Set in the rx_ifindex to pass the correct interface index in the case of a message timeout detection. Usually the rx_ifindex value is set at receive time. But when no CAN frame has been received the RX_TIMEOUT notification did not contain a valid value. Reported-by: Andre Naujoks <nautsch2@googlemail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03can: peak_usb: fix hwtstamp assignmentOliver Hartkopp
commit c9faaa09e2a1335678f09c70a0d0eda095564bab upstream. The skb->tstamp is set to the hardware timestamp when available in the USB urb message. This leads to user visible timestamps which contain the 'uptime' of the USB adapter - and not the usual system generated timestamp. Fix this wrong assignment by applying the available hardware timestamp to the skb_shared_hwtstamps data structure - which is intended for this purpose. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03radeon: add AGPMode 1 quirk for RV250Paul Bolle
commit 45171002b01b2e2ec4f991eca81ffd8430fd0aec upstream. The Intel 82855PM host bridge / Mobility FireGL 9000 RV250 combination in an (outdated) ThinkPad T41 needs AGPMode 1 for suspend/resume (under KMS, that is). So add a quirk for it. (Change R250 to RV250 in comment for preceding quirk too.) Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03mac80211: deinitialize ibss-internals after emptiness checkSimon Wunderlich
commit b78a4932f5fb11fadf41e69c606a33fa6787574c upstream. The check whether the IBSS is active and can be removed should be performed before deinitializing the fields used for the check/search. Otherwise, the configured BSS will not be found and removed properly. To make it more clear for the future, rename sdata->u.ibss to the local pointer ifibss which is used within the checks. This behaviour was introduced by f3209bea110cade12e2b133da8b8499689cb0e2e ("mac80211: fix IBSS teardown race") Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Cc: Ignacy Gawedzki <i@lri.fr> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03futex: avoid wake_futex() for a PI futex_qDarren Hart
commit aa10990e028cac3d5e255711fb9fb47e00700e35 upstream. Dave Jones reported a bug with futex_lock_pi() that his trinity test exposed. Sometime between queue_me() and taking the q.lock_ptr, the lock_ptr became NULL, resulting in a crash. While futex_wake() is careful to not call wake_futex() on futex_q's with a pi_state or an rt_waiter (which are either waiting for a futex_unlock_pi() or a PI futex_requeue()), futex_wake_op() and futex_requeue() do not perform the same test. Update futex_wake_op() and futex_requeue() to test for q.pi_state and q.rt_waiter and abort with -EINVAL if detected. To ensure any future breakage is caught, add a WARN() to wake_futex() if the same condition is true. This fix has seen 3 hours of testing with "trinity -c futex" on an x86_64 VM with 4 CPUS. [akpm@linux-foundation.org: tidy up the WARN()] Signed-off-by: Darren Hart <dvhart@linux.intel.com> Reported-by: Dave Jones <davej@redat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: John Kacur <jkacur@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03dm: fix deadlock with request based dm and queue request_fn recursionJens Axboe
commit a8c32a5c98943d370ea606a2e7dc04717eb92206 upstream. Request based dm attempts to re-run the request queue off the request completion path. If used with a driver that potentially does end_io from its request_fn, we could deadlock trying to recurse back into request dispatch. Fix this by punting the request queue run to kblockd. Tested to fix a quickly reproducible deadlock in such a scenario. Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03md/raid10: decrement correct pending counter when writing to replacement.NeilBrown
commit 884162df2aadd7414bef4935e1a54976fd4e3988 upstream. When a write to a replacement device completes, we carefully and correctly found the rdev that the write actually went to and the blithely called rdev_dec_pending on the primary rdev, even if this write was to the replacement. This means that any writes to an array while a replacement was ongoing would cause the nr_pending count for the primary device to go negative, so it could never be removed. This bug has been present since replacement was introduced in 3.3, so it is suitable for any -stable kernel since then. Reported-by: "George Spelvin" <linux@horizon.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03md: Avoid write invalid address if read_seqretry returned true.majianpeng
commit 35f9ac2dcec8f79d7059ce174fd7b7ee3290d620 upstream. If read_seqretry returned true and bbp was changed, it will write invalid address which can cause some serious problem. This bug was introduced by commit v3.0-rc7-130-g2699b67. So fix is suitable for 3.0.y thru 3.6.y. Reported-by: zhuwenfeng@kedacom.com Tested-by: zhuwenfeng@kedacom.com Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03md: Reassigned the parameters if read_seqretry returned true in func ↵majianpeng
md_is_badblock. commit ab05613a0646dcc11049692d54bae76ca9ffa910 upstream. This bug was introduced by commit(v3.0-rc7-126-g2230dfe). So fix is suitable for 3.0.y thru 3.6.y. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03jffs2: Fix lock acquisition order bug in jffs2_write_beginThomas Betker
commit 5ffd3412ae5536a4c57469cb8ea31887121dcb2e upstream. jffs2_write_begin() first acquires the page lock, then f->sem. This causes an AB-BA deadlock with jffs2_garbage_collect_live(), which first acquires f->sem, then the page lock: jffs2_garbage_collect_live mutex_lock(&f->sem) (A) jffs2_garbage_collect_dnode jffs2_gc_fetch_page read_cache_page_async do_read_cache_page lock_page(page) (B) jffs2_write_begin grab_cache_page_write_begin find_lock_page lock_page(page) (B) mutex_lock(&f->sem) (A) We fix this by restructuring jffs2_write_begin() to take f->sem before the page lock. However, we make sure that f->sem is not held when calling jffs2_reserve_space(), as this is not permitted by the locking rules. The deadlock above was observed multiple times on an SoC with a dual ARMv7 (Cortex-A9), running the long-term 3.4.11 kernel; it occurred when using scp to copy files from a host system to the ARM target system. The fix was heavily tested on the same target system. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03mtd: ofpart: Fix incorrect NULL check in parse_ofoldpart_partitions()Sachin Kamat
commit 5a6ea4af0907f995dc06df21a9c9ef764c7cd3bc upstream. The pointer returned by kzalloc should be tested for NULL to avoid potential NULL pointer dereference later. Incorrect pointer was being tested for NULL. Bug introduced by commit fbcf62a3 (mtd: physmap_of: move parse_obsolete_partitions to become separate parser). This patch fixes this bug. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Artem Bityutskiy <artem.bityutskiy@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03mtd: slram: invalid checking of absolute end addressJiri Engelthaler
commit c36a7ff4578ab6294885aef5ef241aeec4cdb1f0 upstream. Fixed parsing end absolute address. Signed-off-by: Jiri Engelthaler <engycz@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03PARISC: fix user-triggerable panic on pariscAl Viro
commit 441a179dafc0f99fc8b3a8268eef66958621082e upstream. int sys32_rt_sigprocmask(int how, compat_sigset_t __user *set, compat_sigset_t __user *oset, unsigned int sigsetsize) { sigset_t old_set, new_set; int ret; if (set && get_sigset32(set, &new_set, sigsetsize)) ... static int get_sigset32(compat_sigset_t __user *up, sigset_t *set, size_t sz) { compat_sigset_t s; int r; if (sz != sizeof *set) panic("put_sigset32()"); In other words, rt_sigprocmask(69, (void *)69, 69) done by 32bit process will promptly panic the box. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03PARISC: fix virtual aliasing issue in get_shared_area()James Bottomley
commit 949a05d03490e39e773e8652ccab9157e6f595b4 upstream. On Thu, 2012-11-01 at 16:45 -0700, Michel Lespinasse wrote: > Looking at the arch/parisc/kernel/sys_parisc.c implementation of > get_shared_area(), I do have a concern though. The function basically > ignores the pgoff argument, so that if one creates a shared mapping of > pages 0-N of a file, and then a separate shared mapping of pages 1-N > of that same file, both will have the same cache offset for their > starting address. > > This looks like this would create obvious aliasing issues. Am I > misreading this ? I can't understand how this could work good enough > to be undetected, so there must be something I'm missing here ??? This turns out to be correct and we need to pay attention to the pgoff as well as the address when creating the virtual address for the area. Fortunately, the bug is rarely triggered as most applications which use pgoff tend to use large values (git being the primary one, and it uses pgoff in multiples of 16MB) which are larger than our cache coherency modulus, so the problem isn't often seen in practise. Reported-by: Michel Lespinasse <walken@google.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Cirrus: Correctly clear line_out_pins when moving to speakerDavid Henningsson
commit 34c3d1926bdaf45d3a891dd577482abcdd9faa34 upstream. If this array is not cleared, the jack related code later might fail to create "Internal Speaker Phantom Jack" on Dell Inspiron 3420 and Dell Vostro 2420. BugLink: https://bugs.launchpad.net/bugs/1076840 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: ua101, usx2y: fix broken MIDI outputClemens Ladisch
commit e99ddfde6ae0dd2662bb40435696002b590e4057 upstream. Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added autosuspend code to all files making up the snd-usb-audio driver. However, midi.c is part of snd-usb-lib and is also used by other drivers, not all of which support autosuspend. Thus, calls to usb_autopm_get_interface() could fail, and this unexpected error would result in the MIDI output being completely unusable. Make it work by ignoring the error that is expected with drivers that do not support autosuspend. Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com> Reported-by: Devin Venable <venable.devin@gmail.com> Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk> Reported-by: Jannis Achstetter <jannis_achstetter@web.de> Reported-by: Rui Nuno Capela <rncbc@rncbc.org> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03drm/radeon: add new SI pci idAlex Deucher
commit 0181bd5dea2ed0696f84591a92da0b6a1f1a2e62 upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03SCSI: isci: copy fis 0x34 response into proper bufferMaciej Patelczyk
commit 49bd665c5407a453736d3232ee58f2906b42e83c upstream. SATA MICROCODE DOWNALOAD fails on isci driver. After receiving Register Device to Host (FIS 0x34) frame Initiator resets phy. In the frame handler routine response (FIS 0x34) was copied into wrong buffer and upper layer did not receive any answer which resulted in timeout and reset. This patch corrects this bug. Signed-off-by: Maciej Patelczyk <maciej.patelczyk@intel.com> Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03mwifiex: fix system hang issue in cmd timeout error caseBing Zhao
commit b1a47aa5e1e159e2cb06d7dfcc17ef5149b09299 upstream. Reported by Tim Shepard: I was seeing sporadic failures (wedgeups), and the majority of those failures I saw printed the printouts in mwifiex_cmd_timeout_func with cmd = 0xe5 which is CMD_802_11_HS_CFG_ENH. When this happens, two minutes later I get notified that the rtcwake thread is blocked, like this: INFO: task rtcwake:3495 blocked for more than 120 seconds. To get the hung thread unblocked we wake up the cmd wait queue and cancel the ioctl. Reported-by: Tim Shepard <shep@laptop.org> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03mwifiex: report error to MMC core if we cannot suspendBing Zhao
commit dd321acddc3be1371263b8c9e6c6f2af89f63d57 upstream. When host_sleep_config command fails we should return error to MMC core to indicate the failure for our device. The misspelled variable is also removed as it's redundant. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03rtlwifi: rtl8192cu: Add new USB IDAlbert Pool
commit a485e827f07bfdd0762059386e6e787bed6e81ee upstream. This is an ISY IWL 2000. Probably a clone of Belkin F7D1102 050d:1102. Its FCC ID is the same. Signed-off-by: Albert Pool <albertpool@solcon.nl> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03x86, microcode, AMD: Add support for family 16h processorsBoris Ostrovsky
commit 36c46ca4f322a7bf89aad5462a3a1f61713edce7 upstream. Add valid patch size for family 16h processors. [ hpa: promoting to urgent/stable since it is hw enabling and trivial ] Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com> Acked-by: Andreas Herrmann <herrmann.der.user@googlemail.com> Link: http://lkml.kernel.org/r/1353004910-2204-1-git-send-email-boris.ostrovsky@amd.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03x86, efi: Fix processor-specific memcpy() build errorMatt Fleming
commit 0f905a43ce955b638139bd84486194770a6a2c08 upstream. Building for Athlon/Duron/K7 results in the following build error, arch/x86/boot/compressed/eboot.o: In function `__constant_memcpy3d': eboot.c:(.text+0x385): undefined reference to `_mmx_memcpy' arch/x86/boot/compressed/eboot.o: In function `efi_main': eboot.c:(.text+0x1a22): undefined reference to `_mmx_memcpy' because the boot stub code doesn't link with the kernel proper, and therefore doesn't have access to the 3DNow version of memcpy. So, follow the example of misc.c and #undef memcpy so that we use the version provided by misc.c. See https://bugzilla.kernel.org/show_bug.cgi?id=50391 Reported-by: Al Viro <viro@zeniv.linux.org.uk> Reported-by: Ryan Underwood <nemesis@icequake.net> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
