2012-04-15Merge commit 'v3.4-rc3' into rt-3.4-rc3-rt4v3.4-rc3-rt4Clark Williams
2012-04-15Linux 3.4-rc3v3.4-rc3Linus Torvalds
2012-04-15Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Nothing too disasterous, the biggest thing being the removal of the regulator support for vcore in the AMBA driver; only one SoC was using this and it got broken during the last merge window, which then started causing problems for other people. Mutual agreement was reached for it to be removed." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7386/1: jump_label: fixup for rename to static_key ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEE ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMU ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus ARM: 7383/1: nommu: populate vectors page from paging_init ARM: 7381/1: nommu: fix typo in mm/Kconfig ARM: 7380/1: DT: do not add a zero-sized memory property ARM: 7379/1: DT: fix atags_to_fdt() second call site ARM: 7366/3: amba: Remove AMBA level regulator support ARM: 7377/1: vic: re-read status register before dispatching each IRQ handler ARM: 7368/1: fault.c: correct how the tsk->[maj|min]_flt gets incremented
2012-04-15x86-32: fix up strncpy_from_user() sign errorLinus Torvalds
The 'max' range needs to be unsigned, since the size of the user address space is bigger than 2GB. We know that 'count' is positive in 'long' (that is checked in the caller), so we will truncate 'max' down to something that fits in a signed long, but before we actually do that, that comparison needs to be done in unsigned. Bug introduced in commit 92ae03f2ef99 ("x86: merge 32/64-bit versions of 'strncpy_from_user()' and speed it up"). On x86-64 you can't trigger this, since the user address space is much smaller than 63 bits, and on x86-32 it works in practice, since you would seldom hit the strncpy limits anyway. I had actually tested the corner-cases, I had only tested them on x86-64. Besides, I had only worried about the case of a pointer *close* to the end of the address space, rather than really far away from it ;) This also changes the "we hit the user-specified maximum" to return 'res', for the trivial reason that gcc seems to generate better code that way. 'res' and 'count' are the same in that case, so it really doesn't matter which one we return. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-15ARM: 7386/1: jump_label: fixup for rename to static_keyRabin Vincent
c5905afb0 ("static keys: Introduce 'struct static_key'...") renamed struct jump_label_key to struct static_key. Fixup ARM for this to eliminate these build warnings: include/linux/jump_label.h:113:2: warning: passing argument 1 of 'arch_static_branch' from incompatible pointer type include/asm/jump_label.h:17:82: note: expected 'struct jump_label_key *' but argument is of type 'struct static_key *' Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-15ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEEJonathan Austin
Currently when ThumbEE is not enabled (!CONFIG_ARM_THUMBEE) the ThumbEE register states are not saved/restored at context switch. The default state of the ThumbEE Ctrl register (TEECR) allows userspace accesses to the ThumbEE Base Handler register (TEEHBR). This can cause unexpected behaviour when people use ThumbEE on !CONFIG_ARM_THUMBEE kernels, as well as allowing covert communication - eg between userspace tasks running inside chroot jails. This patch sets up TEECR in order to prevent user-space access to TEEHBR when !CONFIG_ARM_THUMBEE. In this case, tasks are sent SIGILL if they try to access TEEHBR. Cc: stable@vger.kernel.org Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Jonathan Austin <jonathan.austin@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-15ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMUWill Deacon
If a bank of memory spanning the 4GB boundary is added on a !CONFIG_LPAE kernel then we will hang early during boot since the memory bank will have wrapped around to zero. This patch truncates memory banks for !LPAE configurations when the end address is not representable in 32 bits. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-15ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpusLinus Walleij
During booting of cpu1, there is a short window where cpu1 is online, but not active where cpu1 is occupied by waiting to become active. If cpu0 then decides to schedule something on cpu1 and wait for it to complete, before cpu0 has set cpu1 active, we have a deadlock. Typically it's this CPU frequency transition that happens at this time, so let's just not wait for it to happen, it will happen whenever the CPU eventually comes online instead. Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@kernel.org Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Reviewed-by: Rickard Andersson <rickard.andersson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-15PCI: Fix regression in pci_restore_state(), v3Rafael J. Wysocki
Commit 26f41062f28d ("PCI: check for pci bar restore completion and retry") attempted to address problems with PCI BAR restoration on systems where FLR had not been completed before pci_restore_state() was called, but it did that in an utterly wrong way. First off, instead of retrying the writes for the BAR registers only, it did that for all of the PCI config space of the device, including the status register (whose value after the write quite obviously need not be the same as the written one). Second, it added arbitrary delay to pci_restore_state() even for systems where the PCI config space restoration was successful at first attempt. Finally, the mdelay(10) it added to every iteration of the writing loop was way too much of a delay for any reasonable device. All of this actually caused resume failures for some devices on Mikko's system. To fix the regression, make pci_restore_state() only retry the writes for BAR registers and only wait if the first read from the register doesn't return the written value. Additionaly, make it wait for 1 ms, instead of 10 ms, after every failing attempt to write into config space. Reported-by: Mikko Vinni <mmvinni@yahoo.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: a few more SoC fixes for 3.4-rc" from Olof Johansson: - A handful of warning and build fixes for Qualcomm MSM - Build/warning and bug fixes for Samsung Exynos - A fix from Rob Herring that removes misplaced interrupt-parent properties from a few device trees - A fix to OMAP dealing with cpufreq build errors, removing some of the offending code since it was redundant anyway * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: OMAP: clock: cleanup CPUfreq leftovers, fix build errors ARM: dts: remove blank interrupt-parent properties ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine files ARM: EXYNOS: Remove broken config values for touchscren for NURI board ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boards ARM: EXYNOS: fix regulator name for NURI board ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LL ARM: msm: Fix section mismatches in proc_comm.c video: msm: Fix section mismatches in mddi.c arm: msm: trout: fix compile failure arm: msm: halibut: remove unneeded fixup ARM: EXYNOS: Add PDMA and MDMA physical base address defines ARM: S5PV210: Fix compiler warning in dma.c file ARM: EXYNOS: Fix compile error in exynos5250-cpufreq.c ARM: EXYNOS: Add missing definition for IRQ_I2S0 ARM: S5PV210: fix unused LDO supply field from wm8994_pdata
2012-04-15Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull another round of sound fixes from Takashi Iwai: "A few regression fixes for Realtek HD-audio codecs, mainly specific to some laptop models." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Fix mem leak (and rid us of trailing whitespace). ALSA: hda/realtek - Add quirk for Mac Pro 5,1 machines ALSA: hda/realtek - Add a fixup entry for Acer Aspire 8940G ALSA: hda/realtek - Fix GPIO1 setup for Acer Aspire 4930 & co ALSA: hda/realtek - Add a few ALC882 model strings back
2012-04-15SCSI: Fix error handling when no ULD is attachedMartin K. Petersen
Commit 18a4d0a22ed6 ("[SCSI] Handle disk devices which can not process medium access commands") introduced a bug in which we would attempt to dereference the scsi driver even when the device had no ULD attached. Ensure that a driver is registered and make the driver accessor function more resilient to errors during device discovery. Reported-by: Elric Fu <elricfu1@gmail.com> Reported-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-14Merge branch 'v3.4-samsung-fixes-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes * 'v3.4-samsung-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine files ARM: EXYNOS: Remove broken config values for touchscren for NURI board ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boards ARM: EXYNOS: fix regulator name for NURI board ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LL ARM: EXYNOS: Add PDMA and MDMA physical base address defines ARM: S5PV210: Fix compiler warning in dma.c file ARM: EXYNOS: Fix compile error in exynos5250-cpufreq.c ARM: EXYNOS: Add missing definition for IRQ_I2S0 ARM: S5PV210: fix unused LDO supply field from wm8994_pdata
2012-04-14ARM: OMAP: clock: cleanup CPUfreq leftovers, fix build errorsKevin Hilman
Now that we have OPP layer, and OMAP CPUfreq driver is using it, we no longer need/use the clock framework code for filling up CPUfreq tables. Remove it. Removing this code also eliminates build errors when CPU_FREQ_TABLE support is not enabled. Thanks to Russell King for pointing out the parts I missed under plat-omap in the original version and also pointing out the build errors when CPUFREQ_TABLE support was not enabled. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kevin Hilman <khilman@ti.com> Acked-by: Paul Walmsley <paul@pwsan.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-04-14ARM: dts: remove blank interrupt-parent propertiesRob Herring
These were incorrectly introduced and can cause problems for of_irq_init. The correct way to define a root controller is no interrupt-parent set at all or the interrupt-parent is set to the root controller itself when inherited from a parent node. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Tested-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-04-14Merge branch 'msm-fix' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into fixes From David Brown: "Here are some fixes for msm that fix problems caused by the latest ARM code. The ones from Daniel remove unneeded fixups that now cause compilation failures. Mine fix section mismatches, that were incompletely fixed earlier." * 'msm-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm: ARM: msm: Fix section mismatches in proc_comm.c video: msm: Fix section mismatches in mddi.c arm: msm: trout: fix compile failure arm: msm: halibut: remove unneeded fixup
2012-04-14ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine filesSachin Kamat
Add config dependency for Exynos4 and Exynos5 device tree enabled machine files on config options ARCH_EXYNOS4 and ARCH_EXYNOS5 respectively. Enabling machine support without proper ARCH support enabled is incorrect. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-04-14Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf tool fixes from Ingo Molnar. * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf kvm: Finding struct machine fails for PERF_RECORD_MMAP perf annotate: Validate addr in symbol__inc_addr_samples perf hists browser: Fix NULL deref in hists browsing code perf hists: Catch and handle out-of-date hist entry maps. perf annotate: Fix hist decay perf top: Add intel_idle to the skip list
2012-04-14do not export kernel's NULL #define to userspaceLubos Lunak
GCC's NULL is actually __null, which allows detecting some questionable NULL usage and warn about it. Moreover each platform/compiler should have its own stddef.h anyway (which is different from linux/stddef.h). So there's no good reason to leak kernel's NULL to userspace and override what the compiler provides. Signed-off-by: Luboš Luňák <l.lunak@suse.cz> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-14ARM: EXYNOS: Remove broken config values for touchscren for NURI boardMarek Szyprowski
The atmel_mxt_ts driver has been extended to support more 'configuration objects' in commit 81c88a711 ("Input: atmel_mxt_ts - update object list"), what broke the configuration values for NURI board. These values are optional anyway, so remove them to get the driver working correctly. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-04-14ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boardsMarek Szyprowski
On some versions of NURI and UniversalC210 boards, camera clocks are routed directly to xusbxti clock source. This patch sets the correct value for this clock to let usb and camera sensors to work correctly and avoid division by zero on driver's probe. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-04-14ARM: EXYNOS: fix regulator name for NURI boardMarek Szyprowski
Regulator names should not contain slash to avoid issues with debugfs. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-04-14ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LLMaurus Cuelenaere
When selecting SAMSUNG_PM_DEBUG, it complains about a missing printascii() function if you do not select DEBUG_LL, so make the former select the latter. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-04-13Merge branch 'systemh-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull system.h fixups for less common arch's from Paul Gortmaker: "Here is what is hopefully the last of the system.h related fixups. The fixes for Alpha and ia64 are code relocations consistent with what was done for the more mainstream architectures. Note that the diffstat lines removed vs lines added are not the same since I've fixed some of the whitespace issues in the relocated code blocks. However they are functionally the same. Compile tested locally, plus these two have been in linux-next for a while. There is also a trivial one line system.h related fix for the Tilera arch from Chris Metcalf to fix an implict include.." * 'systemh-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: irq_work: fix compile failure on tile from missing include ia64: populate the cmpxchg header with appropriate code alpha: fix build failures from system.h dismemberment
2012-04-13Merge tag 'fbdev-fixes-for-3.4-1' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev fixes from Florian Tobias Schandinat: - a compile fix for au1*fb - a fix to make kyrofb usable on x86_64 - a fix for uvesafb to prevent an oops due to NX-protection "The fix for kyrofb is a bit large but it's just replacing "unsigned long" by "u32" for 64 bit compatibility." * tag 'fbdev-fixes-for-3.4-1' of git://github.com/schandinat/linux-2.6: video:uvesafb: Fix oops that uvesafb try to execute NX-protected page fbdev: fix au1*fb builds kyrofb: fix on x86_64
2012-04-13Merge branch 'for-linus-min' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull the minimal btrfs branch from Chris Mason: "We have a use-after-free in there, along with errors when mount -o discard is enabled, and a BUG_ON(we should compile with UP more often)." * 'for-linus-min' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use commit root when loading free space cache Btrfs: fix use-after-free in __btrfs_end_transaction Btrfs: check return value of bio_alloc() properly Btrfs: remove lock assert from get_restripe_target() Btrfs: fix eof while discarding extents Btrfs: fix uninit variable in repair_eb_io_failure Revert "Btrfs: increase the global block reserve estimates"
2012-04-13Merge branch 'for-3.4/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver bits from Jens Axboe: - A series of fixes for mtip32xx. Most from Asai at Micron, but also one from Greg, getting rid of the dependency on PCIE_HOTPLUG. - A few bug fixes for xen-blkfront, and blkback. - A virtio-blk fix for Vivek, making resize actually work. - Two fixes from Stephen, making larger transfers possible on cciss. This is needed for tape drive support. * 'for-3.4/drivers' of git://git.kernel.dk/linux-block: block: mtip32xx: remove HOTPLUG_PCI_PCIE dependancy mtip32xx: dump tagmap on failure mtip32xx: fix handling of commands in various scenarios mtip32xx: Shorten macro names mtip32xx: misc changes mtip32xx: Add new sysfs entry 'status' mtip32xx: make setting comp_time as common mtip32xx: Add new bitwise flag 'dd_flag' mtip32xx: fix error handling in mtip_init() virtio-blk: Call revalidate_disk() upon online disk resize xen/blkback: Make optional features be really optional. xen/blkback: Squash the discard support for 'file' and 'phy' type. mtip32xx: fix incorrect value set for drv_cleanup_done, and re-initialize and start port in mtip_restart_port() cciss: Fix scsi tape io with more than 255 scatter gather elements cciss: Initialize scsi host max_sectors for tape drive support xen-blkfront: make blkif_io_lock spinlock per-device xen/blkfront: don't put bdev right after getting it xen-blkfront: use bitmap_set() and bitmap_clear() xen/blkback: Enable blkback on HVM guests xen/blkback: use grant-table.c hypercall wrappers
2012-04-13Merge branch 'for-3.4/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core bits from Jens Axboe: "It's a nice and quiet round this time, since most of the tricky stuff has been pushed to 3.5 to give it more time to mature. After a few hectic block IO core changes for 3.3 and 3.2, I'm quite happy with a slow round. Really minor stuff in here, the only real functional change is making the auto-unplug threshold a per-queue entity. The threshold is set so that it's low enough that we don't hold off IO for too long, but still big enough to get a nice benefit from the batched insert (and hence queue lock cost reduction). For raid configurations, this currently breaks down." * 'for-3.4/core' of git://git.kernel.dk/linux-block: block: make auto block plug flush threshold per-disk based Documentation: Add sysfs ABI change for cfq's target latency. block: Make cfq_target_latency tunable through sysfs. block: use lockdep_assert_held for queue locking block: blk_alloc_queue_node(): use caller's GFP flags instead of GFP_KERNEL
2012-04-13cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUSKevin Hilman
The OMAP driver needs a 'depends on ARCH_OMAP2PLUS' since it only builds for OMAP2+ platforms. This 'depends on' was in the original patch from Russell King, but was erroneously removed by me when making this option user-selectable in commit b09db45c (cpufreq: OMAP driver depends CPUfreq tables.) This patch remedies that. Apologies to Russell King for breaking his originally working patch. Also, thanks to Grazvydas Ignotas for reporting the same problem. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Eliminate obsolete __handle_softirq() function sparc64: Fix bootup crash on sun4v.
2012-04-13Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon patches from Guenter Roeck: "Fix build warnings in four drivers" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (pmbus_core) Fix compiler warning hwmon: (smsc47m1) Fix compiler warning hwmon: (acpi_power_meter) Fix compiler warning seen in some configurations hwmon: (smsc47b397) Fix compiler warning
2012-04-13Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO bug fixes from Grant Likely: "Miscellaneous bug fixes to GPIO drivers and for a corner case in the gpio device tree parsing code." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: gpio/exynos: Fix compiler warning in gpio-samsung.c file gpio: Fix range check in of_gpio_simple_xlate() gpio: Fix uninitialized variable bit in adp5588_irq_handler gpio/sodaville: Convert sodaville driver to new irqdomain API
2012-04-13Merge tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull SPI bug fixes from Grant Likely: "Miscellaneous driver bug fixes. No major changes in this branch." * tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: spi/imx: prevent NULL pointer dereference in spi_imx_probe() spi/imx: mark base member in spi_imx_data as __iomem spi/mpc83xx: fix NULL pdata dereference bug spi/davinci: Fix DMA API usage in davinci spi/pL022: include types.h to remove compilation warnings
2012-04-13sparc64: Eliminate obsolete __handle_softirq() functionPaul E. McKenney
The invocation of softirq is now handled by irq_exit(), so there is no need for sparc64 to invoke it on the trap-return path. In fact, doing so is a bug because if the trap occurred in the idle loop, this invocation can result in lockdep-RCU failures. The problem is that RCU ignores idle CPUs, and the sparc64 trap-return path to the softirq handlers fails to tell RCU that the CPU must be considered non-idle while those handlers are executing. This means that RCU is ignoring any RCU read-side critical sections in those handlers, which in turn means that RCU-protected data can be yanked out from under those read-side critical sections. The shiny new lockdep-RCU ability to detect RCU read-side critical sections that RCU is ignoring located this problem. The fix is straightforward: Make sparc64 stop manually invoking the softirq handlers. Reported-by: Meelis Roos <mroos@linux.ee> Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Meelis Roos <mroos@linux.ee> Cc: stable@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13sparc64: Fix bootup crash on sun4v.David S. Miller
The DS driver registers as a subsys_initcall() but this can be too early, in particular this risks registering before we've had a chance to allocate and setup module_kset in kernel/params.c which is performed also as a subsyts_initcall(). Register DS using device_initcall() insteal. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: stable@vger.kernel.org
2012-04-13ARM: msm: Fix section mismatches in proc_comm.cDavid Brown
The change commit 4416e9eb0b4859b3d28016c5fd0a609bdcbc8a2a Author: Gregory Bean <gbean@codeaurora.org> Date: Wed Jul 28 10:22:12 2010 -0700 arm: msm: Fix section mismatch in smd.c. fixes a section mismatch between the board file and the smd driver's probe function, however, it misses the additional mismatches between the probe function and some routines it calls. Fix these up as well. Signed-off-by: David Brown <davidb@codeaurora.org>
2012-04-13video: msm: Fix section mismatches in mddi.cDavid Brown
The change commit 461cbe77d0a4f887c33a3a95ea68a7daf23b4302 Author: Gregory Bean <gbean@codeaurora.org> Date: Wed Jul 28 10:22:13 2010 -0700 video: msm: Fix section mismatch in mddi.c. fixes a section mismatch between the board file and the driver's probe function, however, it misses the additional mismatches between the probe function and some routines it calls. Fix these up as well. Signed-off-by: David Brown <davidb@codeaurora.org>
2012-04-13arm: msm: trout: fix compile failureDaniel Walker
Fixes the following warnings, arch/arm/mach-msm/board-trout.c: In function 'trout_init': arch/arm/mach-msm/board-trout.c:71: error: 'system_rev' undeclared (first use in this function) arch/arm/mach-msm/board-trout.c:71: error: (Each undeclared identifier is reported only once arch/arm/mach-msm/board-trout.c:71: error: for each function it appears in.) and arch/arm/mach-msm/board-trout-panel.c: In function 'trout_init_panel': arch/arm/mach-msm/board-trout-panel.c:267: error: 'system_rev' undeclared (first use in this function) arch/arm/mach-msm/board-trout-panel.c:267: error: (Each undeclared identifier is reported only once arch/arm/mach-msm/board-trout-panel.c:267: error: for each function it appears in.) This came in with the following commit 9f97da78bf018206fb623cd351d454af2f105fe0 which removes asm/system.h Signed-off-by: Daniel Walker <dwalker@fifo99.com> cc: David Howells <dhowells@redhat.com> cc: Bryan Huntsman <bryanh@codeaurora.org> cc: linux-arm-msm@vger.kernel.org cc: linux-arm-kernel@lists.infradead.org Signed-off-by: David Brown <davidb@codeaurora.org>
2012-04-13arm: msm: halibut: remove unneeded fixupDaniel Walker
This old fixup causes a build failure, so I remove it just like in trout. Signed-off-by: Daniel Walker <dwalker@fifo99.com> Signed-off-by: David Brown <davidb@codeaurora.org>
2012-04-13irq_work: fix compile failure on tile from missing includeChris Metcalf
Building with IRQ_WORK configured results in kernel/irq_work.c: In function ‘irq_work_run’: kernel/irq_work.c:110: error: implicit declaration of function ‘irqs_disabled’ The appropriate header just needs to be included. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-13ia64: populate the cmpxchg header with appropriate codePaul Gortmaker
commit 93f378883cecb9dcb2cf5b51d9d24175906659da "Fix ia64 build errors (fallout from system.h disintegration)" introduced arch/ia64/include/asm/cmpxchg.h as a temporary build fix and stated: "... leave the migration of xchg() and cmpxchg() to this new header file for a future patch." Migrate the appropriate chunks from asm/intrinsics.h and fix the whitespace issues in the migrated chunk. Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-13alpha: fix build failures from system.h dismembermentPaul Gortmaker
commit ec2212088c42ff7d1362629ec26dda4f3e8bdad3 "Disintegrate asm/system.h for Alpha" combined with commit b4816afa3986704d1404fc48e931da5135820472 "Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h" introduced the concept of asm/cmpxchg.h but the alpha arch never got one. Fork the cmpxchg content out of the asm/atomic.h file to create one. Some minor whitespace fixups were done on the block of code that created the new file. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-13kconfig-preempt-rt-full.patchv3.2-rc2-rt4Thomas Gleixner
2012-04-13kconfig-disable-a-few-options-rt.patchThomas Gleixner
Disable stuff which is known to have issues on RT Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13ntp: Make ntp_lock raw.Thomas Gleixner
This needs to be revisited. Not sure whether we can avoid to make this lock raw, but it'd really like to. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13net: Use cpu_chill() instead of cpu_relax()Thomas Gleixner
Retry loops on RT might loop forever when the modifying side was preempted. Use cpu_chill() instead of cpu_relax() to let the system make progress. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable-rt@vger.kernel.org
2012-04-13fs: dcache: Use cpu_chill() in trylock loopsThomas Gleixner
2012-04-13rt: Introduce cpu_chill()Thomas Gleixner
Retry loops on RT might loop forever when the modifying side was preempted. Add cpu_chill() to replace cpu_relax(). cpu_chill() defaults to cpu_relax() for non RT. On RT it puts the looping task to sleep for a tick so the preempted task can make progress. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable-rt@vger.kernel.org
2012-04-13softirq: Check preemption after reenabling interruptsThomas Gleixner
raise_softirq_irqoff() disables interrupts and wakes the softirq daemon, but after reenabling interrupts there is no preemption check, so the execution of the softirq thread might be delayed arbitrarily. In principle we could add that check to local_irq_enable/restore, but that's overkill as the rasie_softirq_irqoff() sections are the only ones which show this behaviour. Reported-by: Carsten Emde <cbe@osadl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable-rt@vger.kernel.org
2012-04-13cpu: Make hotplug.lock a "sleeping" spinlock on RTSteven Rostedt
Tasks can block on hotplug.lock in pin_current_cpu(), but their state might be != RUNNING. So the mutex wakeup will set the state unconditionally to RUNNING. That might cause spurious unexpected wakeups. We could provide a state preserving mutex_lock() function, but this is semantically backwards. So instead we convert the hotplug.lock() to a spinlock for RT, which has the state preserving semantics already. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Carsten Emde <C.Emde@osadl.org> Cc: John Kacur <jkacur@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Clark Williams <clark.williams@gmail.com> Cc: stable-rt@vger.kernel.org Link: http://lkml.kernel.org/r/1330702617.25686.265.camel@gandalf.stny.rr.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
