2012-05-21Linux 3.3.7v3.3.7Greg Kroah-Hartman
2012-05-21Avoid reading past buffer when calling GETACLSachin Prabhu
commit 5a00689930ab975fdd1b37b034475017e460cf2a upstream. Bug noticed in commit bf118a342f10dafe44b14451a1392c3254629a1f When calling GETACL, if the size of the bitmap array, the length attribute and the acl returned by the server is greater than the allocated buffer(args.acl_len), we can Oops with a General Protection fault at _copy_from_pages() when we attempt to read past the pages allocated. This patch allocates an extra PAGE for the bitmap and checks to see that the bitmap + attribute_length + ACLs don't exceed the buffer space allocated to it. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reported-by: Jian Li <jiali@redhat.com> [Trond: Fixed a size_t vs unsigned int printk() warning] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21Avoid beyond bounds copy while caching ACLSachin Prabhu
commit 5794d21ef4639f0e33440927bb903f9598c21e92 upstream. When attempting to cache ACLs returned from the server, if the bitmap size + the ACL size is greater than a PAGE_SIZE but the ACL size itself is smaller than a PAGE_SIZE, we can read past the buffer page boundary. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reported-by: Jian Li <jiali@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21spi-topcliff-pch: add recovery processing in case wait-event timeoutTomoya MORINAGA
commit 0f57e168aa109775430c76cc663fb64909813d84 upstream. Currently, pch_spi_start_transfer failure is not anticipated. This patch adds the processing. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21spi-topcliff-pch: supports a spi mode setup and bit order setup by IO controlTomoya MORINAGA
commit f258b44e22e07f5e98ac2260c70acff5784791b6 upstream. This patch supports a spi mode setup and bit order setup by IO control. spi mode: mode 0 to mode 3 bit order: LSB first, MSB first Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21spi-topcliff-pch: Fix issue for transmitting over 4KByteTomoya MORINAGA
commit 7d05b3e868ee0f9231baf40cb77be3df5dd1f18c upstream. Currently, when spi-topcliff-pch receives transmit request over 4KByte, this driver can't process correctly. This driver needs to divide the data into 4Kbyte unit. This patch fixes the issue. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21spi-topcliff-pch: Modify pci-bus number dynamically to get DMA device infoTomoya MORINAGA
commit ee2ece5261a639b89f194d141444b03b4c923179 upstream. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21i2c-eg20t: change timeout value 50msec to 1000msecTomoya MORINAGA
commit 8a52f9f347da721b199b7f9dcc0168bbe7d0baae upstream. Currently, during i2c works alone, wait-event timeout is not occurred. However, as CPU load increases, timeout occurs frequently. So, I modified like this patch. Modifying like this patch, I've never seen the timeout event with high load test. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21OMAPDSS: VENC: fix NULL pointer dereference in DSS2 VENC sysfs debug attr on ↵Danny Kukawka
OMAP4 commit cc1d3e032df53d83d0ca4d537d8eb67eb5b3e808 upstream. Commit ba02fa37de80bea10d706f39f076dd848348320a disabled the venc driver registration on OMAP4. Since the driver never gets probed/initialised your get a dereferenceed NULL pointer if you try to get info from /sys/kernel/debug/omapdss/venc Return info message about disabled venc if venc_dump_regs() gets called. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21dl2k: Clean up rio_ioctlJeff Mahoney
commit 1bb57e940e1958e40d51f2078f50c3a96a9b2d75 upstream. The dl2k driver's rio_ioctl call has a few issues: - No permissions checking - Implements SIOCGMIIREG and SIOCGMIIREG using the SIOCDEVPRIVATE numbers - Has a few ioctls that may have been used for debugging at one point but have no place in the kernel proper. This patch removes all but the MII ioctls, renumbers them to use the standard ones, and adds the proper permission check for SIOCSMIIREG. We can also get rid of the dl2k-specific struct mii_data in favor of the generic struct mii_ioctl_data. Since we have the phyid on hand, we can add the SIOCGMIIPHY ioctl too. Most of the MII code for the driver could probably be converted to use the generic MII library but I don't have a device to test the results. Reported-by: Stephan Mueller <stephan.mueller@atsec.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21compat: Fix RT signal mask corruption via sigprocmaskJan Kiszka
commit b7dafa0ef3145c31d7753be0a08b3cbda51f0209 upstream. compat_sys_sigprocmask reads a smaller signal mask from userspace than sigprogmask accepts for setting. So the high word of blocked.sig[0] will be cleared, releasing any potentially blocked RT signal. This was discovered via userspace code that relies on get/setcontext. glibc's i386 versions of those functions use sigprogmask instead of rt_sigprogmask to save/restore signal mask and caused RT signal unblocking this way. As suggested by Linus, this replaces the sys_sigprocmask based compat version with one that open-codes the required logic, including the merge of the existing blocked set with the new one provided on SIG_SETMASK. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21cifs: fix revalidation test in cifs_llseek()Dan Carpenter
commit 48a5730e5b71201e226ff06e245bf308feba5f10 upstream. This test is always true so it means we revalidate the length every time, which generates more network traffic. When it is SEEK_SET or SEEK_CUR, then we don't need to revalidate. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21memcg: free spare array to avoid memory leakSha Zhengju
commit 8c7577637ca31385e92769a77e2ab5b428e8b99c upstream. When the last event is unregistered, there is no need to keep the spare array anymore. So free it to avoid memory leak. Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ext4: avoid deadlock on sync-mounted FS w/o journalEric Sandeen
commit c1bb05a657fb3d8c6179a4ef7980261fae4521d7 upstream. Processes hang forever on a sync-mounted ext2 file system that is mounted with the ext4 module (default in Fedora 16). I can reproduce this reliably by mounting an ext2 partition with "-o sync" and opening a new file an that partition with vim. vim will hang in "D" state forever. The same happens on ext4 without a journal. I am attaching a small patch here that solves this issue for me. In the sync mounted case without a journal, ext4_handle_dirty_metadata() may call sync_dirty_buffer(), which can't be called with buffer lock held. Also move mb_cache_entry_release inside lock to avoid race fixed previously by 8a2bfdcb ext[34]: EA block reference count racing fix Note too that ext2 fixed this same problem in 2006 with b2f49033 [PATCH] fix deadlock in ext2 Signed-off-by: Martin.Wilck@ts.fujitsu.com [sandeen@redhat.com: move mb_cache_entry_release before unlock, edit commit msg] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21init: don't try mounting device as nfs root unless type fully matchesSasha Levin
commit 377485f6244af255b04d662cf19cddbbc4ae4310 upstream. Currently, we'll try mounting any device who's major device number is UNNAMED_MAJOR as NFS root. This would happen for non-NFS devices as well (such as 9p devices) but it wouldn't cause any issues since mounting the device as NFS would fail quickly and the code proceeded to doing the proper mount: [ 101.522716] VFS: Unable to mount root fs via NFS, trying floppy. [ 101.534499] VFS: Mounted root (9p filesystem) on device 0:18. Commit 6829a048102a ("NFS: Retry mounting NFSROOT") introduced retries when mounting NFS root, which means that now we don't immediately fail and instead it takes an additional 90+ seconds until we stop retrying, which has revealed the issue this patch fixes. This meant that it would take an additional 90 seconds to boot when we're not using a device type which gets detected in order before NFS. This patch modifies the NFS type check to require device type to be 'Root_NFS' instead of requiring the device to have an UNNAMED_MAJOR major. This makes boot process cleaner since we now won't go through the NFS mounting code at all when the device isn't an NFS root ("/dev/nfs"). Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21tcp: do_tcp_sendpages() must try to push data out on oom conditionsWilly Tarreau
commit bad115cfe5b509043b684d3a007ab54b80090aa1 upstream. Since recent changes on TCP splicing (starting with commits 2f533844 "tcp: allow splice() to build full TSO packets" and 35f9c09f "tcp: tcp_sendpages() should call tcp_push() once"), I started seeing massive stalls when forwarding traffic between two sockets using splice() when pipe buffers were larger than socket buffers. Latest changes (net: netdev_alloc_skb() use build_skb()) made the problem even more apparent. The reason seems to be that if do_tcp_sendpages() fails on out of memory condition without being able to send at least one byte, tcp_push() is not called and the buffers cannot be flushed. After applying the attached patch, I cannot reproduce the stalls at all and the data rate it perfectly stable and steady under any condition which previously caused the problem to be permanent. The issue seems to have been there since before the kernel migrated to git, which makes me think that the stalls I occasionally experienced with tux during stress-tests years ago were probably related to the same issue. This issue was first encountered on 3.0.31 and 3.2.17, so please backport to -stable. Signed-off-by: Willy Tarreau <w@1wt.eu> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21MD: Add del_timer_sync to mddev_suspend (fix nasty panic)Jonathan Brassow
commit 0d9f4f135eb6dea06bdcb7065b1e4ff78274a5e9 upstream. Use del_timer_sync to remove timer before mddev_suspend finishes. We don't want a timer going off after an mddev_suspend is called. This is especially true with device-mapper, since it can call the destructor function immediately following a suspend. This results in the removal (kfree) of the structures upon which the timer depends - resulting in a very ugly panic. Therefore, we add a del_timer_sync to mddev_suspend to prevent this. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21e1000: Prevent reset task killing itself.Tushar Dave
commit 8ce6909f77ba1b7bcdea65cc2388fd1742b6d669 upstream. Killing reset task while adapter is resetting causes deadlock. Only kill reset task if adapter is not resetting. Ref bug #43132 on bugzilla.kernel.org Signed-off-by: Tushar Dave <tushar.n.dave@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21dm mpath: check if scsi_dh module already loaded before trying to loadMike Snitzer
commit 510193a2d3d2e03ae53b95c0ae4f33cdff02cbf8 upstream. If the requested scsi_dh module is already loaded then skip request_module(). Multipath table loads can hang in an unnecessary __request_module. Reported-by: Ben Marzinski <bmarzins@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21virtio: console: tell host of open ports after resume from s3/s4Amit Shah
commit fa8b66ccd2d200b64496cfedcce90bf54fe7d6e9 upstream. If a port was open before going into one of the sleep states, the port can continue normal operation after restore. However, the host has to be told that the guest side of the connection is open to restore pre-suspend state. This wasn't noticed so far due to a bug in qemu that was fixed recently (which marked the guest-side connection as always open). Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21target: Fix bug in handling of FILEIO + block_device resize opsNicholas Bellinger
commit cd9323fd68aee3c1c6b5b21e5746c9d1b586fb58 upstream. This patch fixes a bug in the handling of FILEIO w/ underlying block_device resize operations where the original fd_dev->fd_dev_size was incorrectly being used in fd_get_blocks() for READ_CAPACITY response payloads. This patch avoids using fd_dev->fd_dev_size for FILEIO devices with an underlying block_device, and instead changes fd_get_blocks() to get the sector count directly from i_size_read() as recommended by hch. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21target: Fix SPC-2 RELEASE bug for multi-session iSCSI client setupsBernhard Kohl
commit edc318d9fea6854df752ec8c645b960b0d5a1d23 upstream. This patch addresses a bug in a special case for target core SPC-2 RELEASE logic where the same physical client (eg: iSCSI InitiatorName) with differing iSCSI session identifiers (ISID) is allowed to incorrectly release the same client's SPC-2 reservation from the non reservation holding path. Note this bug is specific to iscsi-target w/ SPC-2 reservations, and with the default enforce_pr_isids=1 device attr setting in target-core controls if a InitiatorName + different ISID reservations are handled the same as a single iSCSI client entity. Signed-off-by: Bernhard Kohl <bernhard.kohl@gmx.net> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21target: Drop incorrect se_lun_acl release for dynamic -> explict ACL conversionNicholas Bellinger
commit cfebf8f42f47327fa54cf05c19b98f4bd5236a26 upstream. This patch removes some potentially problematic legacy code within core_clear_initiator_node_from_tpg() that was originally intended to release left over se_lun_acl setup during dynamic NodeACL+MappedLUN generate when running with TPG demo-mode operation. Since we now only ever expect to allocate and release se_lun_acl from within target_core_fabric_configfs.c:target_fabric_make_mappedlun() and target_fabric_drop_mappedlun() context respectively, this code for demo-mode release is incorrect and needs to be removed. Cc: Christoph Hellwig <hch@lst.de> Cc: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21crypto: mv_cesa requires on CRYPTO_HASH to buildAlexander Clouter
commit 1ebfefcf37a6e308266a8d786e8cfea0a454058c upstream. Without CRYPTO_HASH being selected, mv_cesa has a lot of hooks into undefined exports. ---- MODPOST 81 modules Kernel: arch/arm/boot/Image is ready AS arch/arm/boot/compressed/head.o GZIP arch/arm/boot/compressed/piggy.gzip CC arch/arm/boot/compressed/misc.o CC arch/arm/boot/compressed/decompress.o ERROR: "crypto_ahash_type" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_final" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_register_ahash" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_unregister_ahash" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_update" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_digest" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_setkey" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_alloc_shash" [drivers/crypto/mv_cesa.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 make: *** Waiting for unfinished jobs.... ---- Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21arch/tile: apply commit 74fca9da0 to the compat signal handling as wellChris Metcalf
commit a134d228298c6aa9007205c6b81cae0cac0acb5d upstream. This passes siginfo and mcontext to tilegx32 signal handlers that don't have SA_SIGINFO set just as we have been doing for tilegx64. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21jffs2: Fix lock acquisition order bug in gc pathJosh Cartwright
commit 226bb7df3d22bcf4a1c0fe8206c80cc427498eae upstream. The locking policy is such that the erase_complete_block spinlock is nested within the alloc_sem mutex. This fixes a case in which the acquisition order was erroneously reversed. This issue was caught by the following lockdep splat: ======================================================= [ INFO: possible circular locking dependency detected ] 3.0.5 #1 ------------------------------------------------------- jffs2_gcd_mtd6/299 is trying to acquire lock: (&c->alloc_sem){+.+.+.}, at: [<c01f7714>] jffs2_garbage_collect_pass+0x314/0x890 but task is already holding lock: (&(&c->erase_completion_lock)->rlock){+.+...}, at: [<c01f7708>] jffs2_garbage_collect_pass+0x308/0x890 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&(&c->erase_completion_lock)->rlock){+.+...}: [<c008bec4>] validate_chain+0xe6c/0x10bc [<c008c660>] __lock_acquire+0x54c/0xba4 [<c008d240>] lock_acquire+0xa4/0x114 [<c046780c>] _raw_spin_lock+0x3c/0x4c [<c01f744c>] jffs2_garbage_collect_pass+0x4c/0x890 [<c01f937c>] jffs2_garbage_collect_thread+0x1b4/0x1cc [<c0071a68>] kthread+0x98/0xa0 [<c000f264>] kernel_thread_exit+0x0/0x8 -> #0 (&c->alloc_sem){+.+.+.}: [<c008ad2c>] print_circular_bug+0x70/0x2c4 [<c008c08c>] validate_chain+0x1034/0x10bc [<c008c660>] __lock_acquire+0x54c/0xba4 [<c008d240>] lock_acquire+0xa4/0x114 [<c0466628>] mutex_lock_nested+0x74/0x33c [<c01f7714>] jffs2_garbage_collect_pass+0x314/0x890 [<c01f937c>] jffs2_garbage_collect_thread+0x1b4/0x1cc [<c0071a68>] kthread+0x98/0xa0 [<c000f264>] kernel_thread_exit+0x0/0x8 other info that might help us debug this: Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(&(&c->erase_completion_lock)->rlock); lock(&c->alloc_sem); lock(&(&c->erase_completion_lock)->rlock); lock(&c->alloc_sem); *** DEADLOCK *** 1 lock held by jffs2_gcd_mtd6/299: #0: (&(&c->erase_completion_lock)->rlock){+.+...}, at: [<c01f7708>] jffs2_garbage_collect_pass+0x308/0x890 stack backtrace: [<c00155dc>] (unwind_backtrace+0x0/0x100) from [<c0463dc0>] (dump_stack+0x20/0x24) [<c0463dc0>] (dump_stack+0x20/0x24) from [<c008ae84>] (print_circular_bug+0x1c8/0x2c4) [<c008ae84>] (print_circular_bug+0x1c8/0x2c4) from [<c008c08c>] (validate_chain+0x1034/0x10bc) [<c008c08c>] (validate_chain+0x1034/0x10bc) from [<c008c660>] (__lock_acquire+0x54c/0xba4) [<c008c660>] (__lock_acquire+0x54c/0xba4) from [<c008d240>] (lock_acquire+0xa4/0x114) [<c008d240>] (lock_acquire+0xa4/0x114) from [<c0466628>] (mutex_lock_nested+0x74/0x33c) [<c0466628>] (mutex_lock_nested+0x74/0x33c) from [<c01f7714>] (jffs2_garbage_collect_pass+0x314/0x890) [<c01f7714>] (jffs2_garbage_collect_pass+0x314/0x890) from [<c01f937c>] (jffs2_garbage_collect_thread+0x1b4/0x1cc) [<c01f937c>] (jffs2_garbage_collect_thread+0x1b4/0x1cc) from [<c0071a68>] (kthread+0x98/0xa0) [<c0071a68>] (kthread+0x98/0xa0) from [<c000f264>] (kernel_thread_exit+0x0/0x8) This was introduce in '81cfc9f jffs2: Fix serious write stall due to erase'. Signed-off-by: Josh Cartwright <joshc@linux.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21mm: nobootmem: fix sign extend problem in __free_pages_memory()Russ Anderson
commit 6bc2e853c6b46a6041980d58200ad9b0a73a60ff upstream. Systems with 8 TBytes of memory or greater can hit a problem where only the the first 8 TB of memory shows up. This is due to "int i" being smaller than "unsigned long start_aligned", causing the high bits to be dropped. The fix is to change `i' to unsigned long to match start_aligned and end_aligned. Thanks to Jack Steiner for assistance tracking this down. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21hugetlb: prevent BUG_ON in hugetlb_fault() -> hugetlb_cow()Chris Metcalf
commit 4998a6c0edce7fae9c0a5463f6ec3fa585258ee7 upstream. Commit 66aebce747eaf ("hugetlb: fix race condition in hugetlb_fault()") added code to avoid a race condition by elevating the page refcount in hugetlb_fault() while calling hugetlb_cow(). However, one code path in hugetlb_cow() includes an assertion that the page count is 1, whereas it may now also have the value 2 in this path. The consensus is that this BUG_ON has served its purpose, so rather than extending it to cover both cases, we just remove it. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Hillf Danton <dhillf@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21mtd: fix oops in dataflash driverWill Newton
commit 7a84477c4acebf6299b6a8bd6a1d5894eb838ffa upstream. I'm seeing an oops in mtd_dataflash.c with Linux 3.3. What appears to be happening is that otp_select_filemode calls mtd_read_fact_prot_reg with -1 for offset and length and a NULL buffer to test if OTP operations are supported. This finds its way down to otp_read in mtd_dataflash.c and causes an oops when memcpying the returned data into the NULL buf. None of the checks in otp_read catches the negative length and offset. Changing the length of the dummy read to 0 prevents the oops. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21kmemleak: Fix the kmemleak tracking of the percpu areas with !SMPCatalin Marinas
commit 100d13c3b5b9410f604b86f5e0a34da64b8cf659 upstream. Kmemleak tracks the percpu allocations via a specific API and the originally allocated areas must be removed from kmemleak (via kmemleak_free). The code was already doing this for SMP systems. Reported-by: Sami Liedes <sami.liedes@iki.fi> Cc: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21percpu: pcpu_embed_first_chunk() should free unused parts after all allocs ↵Tejun Heo
are complete commit 42b64281453249dac52861f9b97d18552a7ec62b upstream. pcpu_embed_first_chunk() allocates memory for each node, copies percpu data and frees unused portions of it before proceeding to the next group. This assumes that allocations for different nodes doesn't overlap; however, depending on memory topology, the bootmem allocator may end up allocating memory from a different node than the requested one which may overlap with the portion freed from one of the previous percpu areas. This leads to percpu groups for different nodes overlapping which is a serious bug. This patch separates out copy & partial free from the allocation loop such that all allocations are complete before partial frees happen. This also fixes overlapping frees which could happen on allocation failure path - out_free_areas path frees whole groups but the groups could have portions freed at that point. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Pavel V. Panteleev" <pp_84@mail.ru> Tested-by: "Pavel V. Panteleev" <pp_84@mail.ru> LKML-Reference: <E1SNhwY-0007ui-V7.pp_84-mail-ru@f220.mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21cdc_ether: add Novatel USB551L device IDs for FLAG_WWANDan Williams
commit 4e6304b8420aba5311ba21fd68dab2924ae4d91a upstream. Needs to be tagged with FLAG_WWAN, which since it has generic descriptors, won't happen if we don't override the generic driver info. Cc: Oliver Neukum <oliver@neukum.org> Cc: stable@vger.kernel.org Signed-off-by: Dan Williams <dcbw@redhat.com> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21cdc_ether: Ignore bogus union descriptor for RNDIS devicesBjørn Mork
commit 6eddcb4c82883451aec3be1240f17793370fa62f upstream. Some RNDIS devices include a bogus CDC Union descriptor pointing to non-existing interfaces. The RNDIS code is already prepared to handle devices without a CDC Union descriptor by hardwiring the driver to use interfaces 0 and 1, which is correct for the devices with the bogus descriptor as well. So we can reuse the existing workaround. Cc: Markus Kolb <linux-201011@tower-net.de> Cc: Iker Salmón San Millán <shaola@esdebian.org> Cc: Jonathan Nieder <jrnieder@gmail.com> Cc: Oliver Neukum <oliver@neukum.org> Cc: 655387@bugs.debian.org Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ASoC: wm8994: Fix AIF2ADC power downMark Brown
commit c7f5f2389377b66028bc129890aa653deafe8d39 upstream. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ASoC: cs42l73: Sync digital mixer kcontrols to allow for 0dBBrian Austin
commit 5807c3bf68eb489032ca8ff70b3d3c833fd8172b upstream. Some of the Digital mixer kcontrol max values were off by 1 not allowing a max of 0dB. Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21media: dvb_frontend: fix a regression with DVB-S zig-zagMauro Carvalho Chehab
commit 910a5f2e9642d5be373beae3d29e1c4a3bc7d83b upstream. Changeset 5bfaadde broke zig-zag for DVB-S drivers that don't implement get_tune_settings() callback. Fix the code, in order to allow it to work as before, otherwise some channels may not be tuned anymore. Fix Fedora Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=814404 Reported-by: Michael Heijenga <database.worker@googlemail.com> Tested-by: Michael Heijenga <database.worker@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21media: rc: Postpone ISR registrationLuis Henriques
commit 9ef449c6b31bb6a8e6dedc24de475a3b8c79be20 upstream. An early registration of an ISR was causing a crash to several users (for example, with the ite-cir driver: http://bugs.launchpad.net/bugs/972723). The reason was that IRQs were being triggered before a driver initialisation was completed. This patch fixes this by moving the invocation to request_irq() and to request_region() to a later stage on the driver probe function. Signed-off-by: Luis Henriques <luis.henriques@canonical.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21media: s5p-fimc: Fix locking in subdev set_crop opSylwester Nawrocki
commit e985dbf7d93e2a3e114b4525413e50f83613e0cb upstream. When setting TRY crop on the sub-device the mutex was erroneously acquired rather than released on exit path. This bug is present in kernels starting from v3.2. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ARM: prevent VM_GROWSDOWN mmaps extending below FIRST_USER_ADDRESSRussell King
commit 9b61a4d1b2064dbd0c9e61754305ac852170509f upstream. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ARM: 7417/1: vfp: ensure preemption is disabled when enabling VFP accessWill Deacon
commit 998de4acb2ba188d20768d1065658377a2e7d29b upstream. The vfp_enable function enables access to the VFP co-processor register space (cp10 and cp11) on the current CPU and must be called with preemption disabled. Unfortunately, the vfp_init late initcall does not disable preemption and can lead to an oops during boot if thread migration occurs at the wrong time and we end up attempting to access the FPSID on a CPU with VFP access disabled. This patch fixes the initcall to call vfp_enable from a non-preemptible context on each CPU and adds a BUG_ON(preemptible) to ensure that any similar problems are easily spotted in the future. Reported-by: Hyungwoo Yang <hwoo.yang@gmail.com> Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21media: marvell-cam: fix an ARM build errorJonathan Corbet
commit 9967232f1be5bab10c7b7a8dcf51ff5c3c1a6d77 upstream. One of the OLPC changes lost a little in its translation to mainline, leading to build errors on the ARM architecture. Remove the offending line, and all will be well. Reported-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21sparc64: Do not clobber %g2 in xcall_fetch_glob_regs().David S. Miller
[ Upstream commit a5a737e090e25981e99d69f01400e3a80356581c ] %g2 is meant to hold the CPUID number throughout this routine, since at the very beginning, and at the very end, we use %g2 to calculate indexes into per-cpu arrays. However we erroneously clobber it in order to hold the %cwp register value mid-stream. Fix this code to use %g3 for the %cwp read and related calulcations instead. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21namespaces, pid_ns: fix leakage on fork() failureMike Galbraith
commit 5e2bf0142231194d36fdc9596b36a261ed2b9fe7 upstream. Fork() failure post namespace creation for a child cloned with CLONE_NEWPID leaks pid_namespace/mnt_cache due to proc being mounted during creation, but not unmounted during cleanup. Call pid_ns_release_proc() during cleanup. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Louis Rilling <louis.rilling@kerlabs.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21usbnet: fix skb traversing races during unlink(v2)Ming Lei
commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa upstream. Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid recursive locking in usbnet_stop()) fixes the recursive locking problem by releasing the skb queue lock before unlink, but may cause skb traversing races: - after URB is unlinked and the queue lock is released, the refered skb and skb->next may be moved to done queue, even be released - in skb_queue_walk_safe, the next skb is still obtained by next pointer of the last skb - so maybe trigger oops or other problems This patch extends the usage of entry->state to describe 'start_unlink' state, so always holding the queue(rx/tx) lock to change the state if the referd skb is in rx or tx queue because we need to know if the refered urb has been started unlinking in unlink_urbs. The other part of this patch is based on Huajun's patch: always traverse from head of the tx/rx queue to get skb which is to be unlinked but not been started unlinking. Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ALSA: hda/idt - Fix power-map for speaker-pins with some HP laptopsTakashi Iwai
commit b0791dda813c179e539b0fc1ecd3f5f30f2571e2 upstream. BIOS on some HP laptops don't set the speaker-pins as fixed but expose as jacks, and this confuses the driver as if these pins are jack-detectable. As a result, the machine doesn't get sounds from speakers because the driver prepares the power-map update via jack unsol events which never come up in reality. The bug was introduced in some time in 3.2 for enabling the power-mapping feature. This patch fixes the problem by replacing the check of the persistent power-map bits with a proper is_jack_detectable() call. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43240 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ALSA: hda/realtek - Add missing CD-input pin for MSI-7350 moboTakashi Iwai
commit bca40138558f0b39357fd1ca477868e4f52f4b1e upstream. Reported-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ALSA: HDA: Lessen CPU usage when waiting for chip to respondDavid Henningsson
commit 32cf4023e689ad5b3a81a749d8cc99d7f184cb99 upstream. When an IRQ for some reason gets lost, we wait up to a second using udelay, which is CPU intensive. This patch improves the situation by waiting about 30 ms in the CPU intensive mode, then stepping down to using msleep(2) instead. In essence, we trade some granularity in exchange for less CPU consumption when the waiting time is a bit longer. As a result, PulseAudio should no longer be killed by the kernel for taking up to much RT-prio CPU time. At least not for *this* reason. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Tested-by: Arun Raghavan <arun.raghavan@collabora.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21ALSA: echoaudio: Remove incorrect part of assertionMark Hills
commit c914f55f7cdfafe9d7d5b248751902c7ab57691e upstream. This assertion seems to imply that chip->dsp_code_to_load is a pointer. It's actually an integer handle on the actual firmware, and 0 has no special meaning. The assertion prevents initialisation of a Darla20 card, but would also affect other models. It seems it was introduced in commit dd7b254d. ALSA sound/pci/echoaudio/echoaudio.c:2061 Echoaudio driver starting... ALSA sound/pci/echoaudio/echoaudio.c:1969 chip=ebe4e000 ALSA sound/pci/echoaudio/echoaudio.c:2007 pci=ed568000 irq=19 subdev=0010 Init hardware... ALSA sound/pci/echoaudio/darla20_dsp.c:36 init_hw() - Darla20 ------------[ cut here ]------------ WARNING: at sound/pci/echoaudio/echoaudio_dsp.c:478 init_hw+0x1d1/0x86c [snd_darla20]() Hardware name: Dell DM051 BUG? (!chip->dsp_code_to_load || !chip->comm_page) Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-12Linux 3.3.6v3.3.6Greg Kroah-Hartman
2012-05-12usb: gadget: udc-core: fix incompatibility with dummy-hcdAlan Stern
commit 320cd1e750f1bf3e47eb41209dcb2be07264cb76 upstream. This patch (as1548) fixes a recently-introduced incompatibility between the UDC core and the dummy-hcd driver. Commit 8ae8090c82eb407267001f75b3d256b3bd4ae691 (usb: gadget: udc-core: fix asymmetric calls in remove_driver) moved the usb_gadget_udc_stop() call in usb_gadget_remove_driver() below the usb_gadget_disconnect() call. As a result, usb_gadget_disconnect() gets called at a time when the gadget driver believes it has been unbound but dummy-hcd believes it has not. A nasty error ensues when dummy-hcd calls the gadget driver's disconnect method a second time. To fix the problem, this patch moves the gadget driver's unbind notification after the usb_gadget_disconnect() call. Now nothing happens between the two unbind notifications, so nothing goes wrong. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
