2012-04-02Linux 3.3.1v3.3.1Greg Kroah-Hartman
2012-04-02ASPM: Fix pcie devices with non-pcie childrenMatthew Garrett
commit c9651e70ad0aa499814817cbf3cc1d0b806ed3a1 upstream. Since 3.2.12 and 3.3, some systems are failing to boot with a BUG_ON. Some other systems using the pata_jmicron driver fail to boot because no disks are detected. Passing pcie_aspm=force on the kernel command line works around it. The cause: commit 4949be16822e ("PCI: ignore pre-1.1 ASPM quirking when ASPM is disabled") changed the behaviour of pcie_aspm_sanity_check() to always return 0 if aspm is disabled, in order to avoid cases where we changed ASPM state on pre-PCIe 1.1 devices. This skipped the secondary function of pcie_aspm_sanity_check which was to avoid us enabling ASPM on devices that had non-PCIe children, causing trouble later on. Move the aspm_disabled check so we continue to honour that scenario. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=42979 and http://bugs.debian.org/665420 Reported-by: Romain Francoise <romain@orebokech.com> # kernel panic Reported-by: Chris Holland <bandidoirlandes@gmail.com> # disk detection trouble Signed-off-by: Matthew Garrett <mjg@redhat.com> Tested-by: Hatem Masmoudi <hatem.masmoudi@gmail.com> # Dell Latitude E5520 Tested-by: janek <jan0x6c@gmail.com> # pata_jmicron with JMB362/JMB363 [jn: with more symptoms in log message] Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02serial: sh-sci: fix a race of DMA submit_tx on transferYoshii Takashi
commit 49d4bcaddca977fffdea8b0b71f6e5da96dac78e upstream. When DMA is enabled, sh-sci transfer begins with uart_start() sci_start_tx() if (cookie_tx < 0) schedule_work() Then, starts DMA when wq scheduled, -- (A) process_one_work() work_fn_rx() cookie_tx = desc->submit_tx() And finishes when DMA transfer ends, -- (B) sci_dma_tx_complete() async_tx_ack() cookie_tx = -EINVAL (possible another schedule_work()) This A to B sequence is not reentrant, since controlling variables (for example, cookie_tx above) are not queues nor lists. So, they must be invoked as A B A B..., otherwise results in kernel crash. To ensure the sequence, sci_start_tx() seems to test if cookie_tx < 0 (represents "not used") to call schedule_work(). But cookie_tx will not be set (to a cookie, also means "used") until in the middle of work queue scheduled function work_fn_tx(). This gap between the test and set allows the breakage of the sequence under the very frequently call of uart_start(). Another gap between async_tx_ack() and another schedule_work() results in the same issue, too. This patch introduces a new condition "cookie_tx == 0" just to mark it is "busy" and assign it within spin-locked region to fill the gaps. Signed-off-by: Takashi Yoshii <takashi.yoshii.zj@renesas.com> Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ARM: tegra: Fix device tree AUXDATA for USB/EHCIStephen Warren
commit 8c3ec84102d171a24f050a086bfc546e9de93f9f upstream. Commit 4a53f4e "USB: ehci-tegra: add probing through device tree" added AUXDATA for Tegra's USB/EHCI controller. However, it pointed the platform data at a location containing the address of the intended platform data, rather than the platform data itself. This change fixes that. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02nfsd: don't allow zero length strings in cache_parse()Dan Carpenter
commit 6d8d17499810479eabd10731179c04b2ca22152f upstream. There is no point in passing a zero length string here and quite a few of that cache_parse() implementations will Oops if count is zero. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02rtc: Provide flag for rtc devices that don't support UIEJohn Stultz
commit 4a649903f91232d02284d53724b0a45728111767 upstream. Richard Weinberger noticed that on some RTC hardware that doesn't support UIE mode, due to coarse granular alarms (like 1minute resolution), the current virtualized RTC support doesn't properly error out when UIE is enabled. Instead the current code queues an alarm for the next second, but it won't fire until up to a miniute later. This patch provides a generic way to flag this sort of hardware and fixes the issue on the mpc5121 where Richard noticed the problem. Reported-by: Richard Weinberger <richard@nod.at> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02compat: use sys_sendfile64() implementation for sendfile syscallChris Metcalf
commit 1631fcea8399da5e80a80084b3b8c5bfd99d21e7 upstream. <asm-generic/unistd.h> was set up to use sys_sendfile() for the 32-bit compat API instead of sys_sendfile64(), but in fact the right thing to do is to use sys_sendfile64() in all cases. The 32-bit sendfile64() API in glibc uses the sendfile64 syscall, so it has to be capable of doing full 64-bit operations. But the sys_sendfile() kernel implementation has a MAX_NON_LFS test in it which explicitly limits the offset to 2^32. So, we need to use the sys_sendfile64() implementation in the kernel for this case. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02x86, tls: Off by one limit checkDan Carpenter
commit 8f0750f19789cf352d7e24a6cc50f2ab1b4f1372 upstream. These are used as offsets into an array of GDT_ENTRY_TLS_ENTRIES members so GDT_ENTRY_TLS_ENTRIES is one past the end of the array. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Link: http://lkml.kernel.org/r/20120324075250.GA28258@elgon.mountain Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02x86, tsc: Skip refined tsc calibration on systems with reliable TSCAlok Kataria
commit 57779dc2b3b75bee05ef5d1ada47f615f7a13932 upstream. While running the latest Linux as guest under VMware in highly over-committed situations, we have seen cases when the refined TSC algorithm fails to get a valid tsc_start value in tsc_refine_calibration_work from multiple attempts. As a result the kernel keeps on scheduling the tsc_irqwork task for later. Subsequently after several attempts when it gets a valid start value it goes through the refined calibration and either bails out or uses the new results. Given that the kernel originally read the TSC frequency from the platform, which is the best it can get, I don't think there is much value in refining it. So for systems which get the TSC frequency from the platform we should skip the refined tsc algorithm. We can use the TSC_RELIABLE cpu cap flag to detect this, right now it is set only on VMware and for Moorestown Penwell both of which have there own TSC calibration methods. Signed-off-by: Alok N Kataria <akataria@vmware.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Dirk Brandewie <dirk.brandewie@gmail.com> Cc: Alan Cox <alan@linux.intel.com> [jstultz: Reworked to simply not schedule the refining work, rather then scheduling the work and bombing out later] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02lockd: fix arg parsing for grace_period and timeout.NeilBrown
commit de5b8e8e047534aac6bc9803f96e7257436aef9c upstream. If you try to set grace_period or timeout via a module parameter to lockd, and do this on a big-endian machine where sizeof(int) != sizeof(unsigned long) it won't work. This number given will be effectively shifted right by the difference in those two sizes. So cast kp->arg properly to get correct result. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02net: fix a potential rcu_read_lock() imbalance in rt6_fill_node()Eric Dumazet
[ Upstream commit 94f826b8076e2cb92242061e92f21b5baa3eccc2 ] Commit f2c31e32b378 (net: fix NULL dereferences in check_peer_redir() ) added a regression in rt6_fill_node(), leading to rcu_read_lock() imbalance. Thats because NLA_PUT() can make a jump to nla_put_failure label. Fix this by using nla_put() Many thanks to Ben Greear for his help Reported-by: Ben Greear <greearb@candelatech.com> Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02xfrm: Access the replay notify functions via the registered callbacksSteffen Klassert
[ Upstream commit 1265fd616782ef03b98fd19f65c2b47fcd4ea11f ] We call the wrong replay notify function when we use ESN replay handling. This leads to the fact that we don't send notifications if we use ESN. Fix this by calling the registered callbacks instead of xfrm_replay_notify(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02sky2: override for PCI legacy power managementstephen hemminger
[ Upstream commit 5676cc7bfe1e388e87843f71daa229610385b41e ] Some BIOS's don't setup power management correctly (what else is new) and don't allow use of PCI Express power control. Add a special exception module parameter to allow working around this issue. Based on slightly different patch by Knut Petersen. Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02net: fix napi_reuse_skb() skb reserveEric Dumazet
[ Upstream commit 2a2a459eeeff48640dc557548ce576d666ab06ed ] napi->skb is allocated in napi_get_frags() using netdev_alloc_skb_ip_align(), with a reserve of NET_SKB_PAD + NET_IP_ALIGN bytes. However, when such skb is recycled in napi_reuse_skb(), it ends with a reserve of NET_IP_ALIGN which is suboptimal. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02Fix pppol2tp getsockname()Benjamin LaHaise
[ Upstream commit bbdb32cb5b73597386913d052165423b9d736145 ] While testing L2TP functionality, I came across a bug in getsockname(). The IP address returned within the pppol2tp_addr's addr memember was not being set to the IP address in use. This bug is caused by using inet_sk() on the wrong socket (the L2TP socket rather than the underlying UDP socket), and was likely introduced during the addition of L2TPv3 support. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02Remove printk from rds_sendmsgDave Jones
[ Upstream commit a6506e1486181975d318344143aca722b2b91621 ] no socket layer outputs a message for this error and neither should rds. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ipv6: fix incorrent ipv6 ipsec packet fragmentGao feng
[ Upstream commit 1f85851e17b64cabd089a8a8839dddebc627948c ] Since commit 299b0767(ipv6: Fix IPsec slowpath fragmentation problem) In func ip6_append_data,after call skb_put(skb, fraglen + dst_exthdrlen) the skb->len contains dst_exthdrlen,and we don't reduce dst_exthdrlen at last This will make fraggap>0 in next "while cycle",and cause the size of skb incorrent Fix this by reserve headroom for dst_exthdrlen. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02net: bpf_jit: fix BPF_S_LDX_B_MSH compilationEric Dumazet
[ Upstream commit dc72d99dabb870ca5bd6d9fff674be853bb4a88d ] Matt Evans spotted that x86 bpf_jit was incorrectly handling negative constant offsets in BPF_S_LDX_B_MSH instruction. We need to abort JIT compilation like we do in common_load so that filter uses the interpreter code and can call __load_pointer() Reference: http://lists.openwall.net/netdev/2011/07/19/11 Thanks to Indan Zupancic to bring back this issue. Reported-by: Matt Evans <matt@ozlabs.org> Reported-by: Indan Zupancic <indan@nul.nu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02drm/i915: suspend fbdev device around suspend/hibernateDave Airlie
commit 3fa016a0b5c5237e9c387fc3249592b2cb5391c6 upstream. Looking at hibernate overwriting I though it looked like a cursor, so I tracked down this missing piece to stop the cursor blink timer. I've no idea if this is sufficient to fix the hibernate problems people are seeing, but please test it. Both radeon and nouveau have done this for a long time. I've run this personally all night hib/resume cycles with no fails. Reviewed-by: Keith Packard <keithp@keithp.com> Reported-by: Petr Tesarik <kernel@tesarici.cz> Reported-by: Stanislaw Gruszka <sgruszka@redhat.com> Reported-by: Lots of misc segfaults after hibernate across the world. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=37142 Tested-by: Dave Airlie <airlied@redhat.com> Tested-by: Bojan Smojver <bojan@rexursive.com> Tested-by: Andreas Hartmann <andihartmann@01019freenet.de> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02module: Remove module size limitSasha Levin
commit f946eeb9313ff1470758e171a60fe7438a2ded3f upstream. Module size was limited to 64MB, this was legacy limitation due to vmalloc() which was removed a while ago. Limiting module size to 64MB is both pointless and affects real world use cases. Cc: Tim Abbott <tim.abbott@oracle.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02NFSv4.1: Fix layoutcommit error handlingTrond Myklebust
commit e59d27e05a6435f8c04d5ad843f37fa795f2eaaa upstream. Firstly, task->tk_status will always return negative error values, so the current tests for 'NFS4ERR_DELEG_REVOKED' etc. are all being ignored. Secondly, clean up the code so that we only need to test task->tk_status once! Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02NFSv4: Fix two infinite loops in the mount codeTrond Myklebust
commit 05e9cfb408b24debb3a85fd98edbfd09dd148881 upstream. We can currently loop forever in nfs4_lookup_root() and in nfs41_proc_secinfo_no_name(), if the first iteration returns a NFS4ERR_DELAY or something else that causes exception.retry to get set. Reported-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02slub: Do not hold slub_lock when calling sysfs_slab_add()Christoph Lameter
commit 66c4c35c6bc5a1a452b024cf0364635b28fd94e4 upstream. sysfs_slab_add() calls various sysfs functions that actually may end up in userspace doing all sorts of things. Release the slub_lock after adding the kmem_cache structure to the list. At that point the address of the kmem_cache is not known so we are guaranteed exlusive access to the following modifications to the kmem_cache structure. If the sysfs_slab_add fails then reacquire the slub_lock to remove the kmem_cache structure from the list. Reported-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02xfs: Fix oops on IO error during xlog_recover_process_iunlinks()Jan Kara
commit d97d32edcd732110758799ae60af725e5110b3dc upstream. When an IO error happens during inode deletion run from xlog_recover_process_iunlinks() filesystem gets shutdown. Thus any subsequent attempt to read buffers fails. Code in xlog_recover_process_iunlinks() does not count with the fact that read of a buffer which was read a while ago can really fail which results in the oops on agi = XFS_BUF_TO_AGI(agibp); Fix the problem by cleaning up the buffer handling in xlog_recover_process_iunlinks() as suggested by Dave Chinner. We release buffer lock but keep buffer reference to AG buffer. That is enough for buffer to stay pinned in memory and we don't have to call xfs_read_agi() all the time. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02backlight: fix typo in tosa_lcd.cMasanari Iida
commit 8da00edc1069f01c34510fa405dc15d96c090a3f upstream. Fix typo in drivers/video/backlight/tosa_lcd.c "tosa_lcd_reume" should be "tosa_lcd_resume". Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02dm thin: fix stacked bi_next usageJoe Thornber
commit 6f94a4c45a6f744383f9f695dde019998db3df55 upstream. Avoid using the bi_next field for the holder of a cell when deferring bios because a stacked device below might change it. Store the holder in a new field in struct cell instead. When a cell is created, the bio that triggered creation (the holder) was added to the same bio list as subsequent bios. In some cases we pass this holder bio directly to devices underneath. If those devices use the bi_next field there will be trouble... This also simplifies some code that had to work out which bio was the holder. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02dm persistent data: fix btree rebalancing after removeJoe Thornber
commit b0988900bae9ecf968a8a8d086a9eec671a9517a upstream. When we remove an entry from a node we sometimes rebalance with it's two neighbours. This wasn't being done correctly; in some cases entries have to move all the way from the right neighbour to the left neighbour, or vice versa. This patch pretty much re-writes the balancing code to fix it. This code is barely used currently; only when you delete a thin device, and then only if you have hundreds of them in the same pool. Once we have discard support, which removes mappings, this will be used much more heavily. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02dm exception store: fix init error pathAndrei Warkentin
commit aadbe266f2f89ccc68b52f4effc7b3a8b29521ef upstream. Call the correct exit function on failure in dm_exception_store_init. Signed-off-by: Andrei Warkentin <andrey.warkentin@gmail.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02dm crypt: add missing error handlingMikulas Patocka
commit 72c6e7afc43e19f68a31dea204fc366624d6eee9 upstream. Always set io->error to -EIO when an error is detected in dm-crypt. There were cases where an error code would be set only if we finish processing the last sector. If there were other encryption operations in flight, the error would be ignored and bio would be returned with success as if no error happened. This bug is present in kcryptd_crypt_write_convert, kcryptd_crypt_read_convert and kcryptd_async_done. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02dm crypt: fix mempool deadlockMikulas Patocka
commit aeb2deae2660a1773c83d3c6e9e6575daa3855d6 upstream. This patch fixes a possible deadlock in dm-crypt's mempool use. Currently, dm-crypt reserves a mempool of MIN_BIO_PAGES reserved pages. It allocates first MIN_BIO_PAGES with non-failing allocation (the allocation cannot fail and waits until the mempool is refilled). Further pages are allocated with different gfp flags that allow failing. Because allocations may be done in parallel, this code can deadlock. Example: There are two processes, each tries to allocate MIN_BIO_PAGES and the processes run simultaneously. It may end up in a situation where each process allocates (MIN_BIO_PAGES / 2) pages. The mempool is exhausted. Each process waits for more pages to be freed to the mempool, which never happens. To avoid this deadlock scenario, this patch changes the code so that only the first page is allocated with non-failing gfp mask. Allocation of further pages may fail. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02drm/radeon/kms/atom: force bpc to 8 for nowAlex Deucher
commit 017d213f649c6775e4a4349e50a5631a4e4c7308 upstream. Using the bpc (bits per color) specified by the monitor can cause problems in some cases. Until we get a better handle on how to deal with those cases, just use a bpc of 8. Reported-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02mfd: Test for jack detection when deciding if wm8994 should suspendMark Brown
commit d2cb87c23e8514ca49c85adc5924999927bb9494 upstream. The jack detection on WM1811 is often required during system suspend, add it as another check when deciding if we should suspend. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02gpio/davinci: fix enabling unbanked GPIO IRQsSekhar Nori
commit 81b279d80a63628e580c71a31d30a8c3b3047ad4 upstream. Unbanked GPIO IRQ handling code made a copy of just the irq_chip structure for GPIO IRQ lines which caused problems after the generic IRQ chip conversion because there was no valid irq_chip_type structure with the right "regs" populated. irq_gc_mask_set_bit() was therefore accessing random addresses. Fix it by making a copy of irq_chip_type structure instead. This will ensure sane register offsets. Reported-by: Jon Povey <Jon.Povey@racelogic.co.uk> Tested-by: Jon Povey <Jon.Povey@racelogic.co.uk> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02gpio/davinci: fix oops on unbanked gpio irq requestSekhar Nori
commit ab2dde9924dd1ddb791fa8b14aa52e1df681e20c upstream. Unbanked GPIO irq setup code was overwriting chip_data leading to the following oops on request_irq() Unable to handle kernel paging request at virtual address febfffff pgd = c22dc000 [febfffff] *pgd=00000000 Internal error: Oops: 801 [#1] PREEMPT Modules linked in: mcu(+) edmak irqk cmemk CPU: 0 Not tainted (3.0.0-rc7+ #93) PC is at irq_gc_mask_set_bit+0x68/0x7c LR is at vprintk+0x22c/0x484 pc : [<c0080c0c>] lr : [<c00457e0>] psr: 60000093 sp : c33e3ba0 ip : c33e3af0 fp : c33e3bc4 r10: c04555bc r9 : c33d4340 r8 : 60000013 r7 : 0000002d r6 : c04555bc r5 : fec67010 r4 : 00000000 r3 : c04734c8 r2 : fec00000 r1 : ffffffff r0 : 00000026 Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user Control: 0005317f Table: 822dc000 DAC: 00000015 Process modprobe (pid: 526, stack limit = 0xc33e2270) Stack: (0xc33e3ba0 to 0xc33e4000) 3ba0: 00000000 c007d3d4 c33e3bcc c04555bc c04555bc c33d4340 c33e3bdc c33e3bc8 3bc0: c007f5f8 c0080bb4 00000000 c04555bc c33e3bf4 c33e3be0 c007f654 c007f5c0 3be0: 00000000 c04555bc c33e3c24 c33e3bf8 c007e6e8 c007f618 c01f2284 c0350af8 3c00: c0405214 bf016c98 00000001 00000000 c33dc008 0000002d c33e3c54 c33e3c28 3c20: c007e888 c007e408 00000001 c23ef880 c33dc000 00000000 c33dc080 c25caa00 3c40: c0487498 bf017078 c33e3c94 c33e3c58 bf016b44 c007e7d4 bf017078 c33dc008 3c60: c25caa08 c33dc008 c33e3c84 bf017484 c25caa00 c25caa00 c01f5f48 c25caa08 3c80: c0496d60 bf017484 c33e3ca4 c33e3c98 c022a698 bf01692c c33e3cd4 c33e3ca8 3ca0: c01f5d88 c022a688 00000000 bf017484 c25caa00 c25caa00 c01f5f48 c25caa08 3cc0: c0496d60 00000000 c33e3cec c33e3cd8 c01f5f8c c01f5d10 00000000 c33e3cf0 3ce0: c33e3d14 c33e3cf0 c01f5210 c01f5f58 c303cb48 c25ecf94 c25caa00 c25caa00 3d00: c25caa34 c33e3dd8 c33e3d34 c33e3d18 c01f6044 c01f51b8 c0496d3c c25caa00 3d20: c044e918 c33e3dd8 c33e3d44 c33e3d38 c01f4ff4 c01f5fcc c33e3d94 c33e3d48 3d40: c01f3d10 c01f4fd8 00000000 c044e918 00000000 00000000 c01f52c0 c034d570 3d60: c33e3d84 c33e3d70 c022bf84 c25caa00 00000000 c044e918 c33e3dd8 c25c2e00 3d80: c0496d60 bf01763c c33e3db4 c33e3d98 c022b1a0 c01f384c c25caa00 c33e3dd8 3da0: 00000000 c33e3dd8 c33e3dd4 c33e3db8 c022b27c c022b0e8 00000000 bf01763c 3dc0: c0451c80 c33e3dd8 c33e3e34 c33e3dd8 bf016f60 c022b210 5f75636d 746e6f63 3de0: 006c6f72 00000000 00000000 00000000 00000000 00000000 00000000 bf0174bc 3e00: 00000000 00989680 00000000 00000020 c0451c80 c0451c80 bf0174dc c01f5eb0 3e20: c33f0f00 bf0174dc c33e3e44 c33e3e38 c01f72f4 bf016e2c c33e3e74 c33e3e48 3e40: c01f5d88 c01f72e4 00000000 c0451c80 c0451cb4 bf0174dc c01f5eb0 c33f0f00 3e60: c0473100 00000000 c33e3e94 c33e3e78 c01f5f44 c01f5d10 00000000 c33e3e98 3e80: bf0174dc c01f5eb0 c33e3ebc c33e3e98 c01f5534 c01f5ec0 c303c038 c3061c30 3ea0: 00003cd8 00098258 bf0174dc c0462ac8 c33e3ecc c33e3ec0 c01f5bec c01f54dc 3ec0: c33e3efc c33e3ed0 c01f4d30 c01f5bdc bf0173a0 c33e2000 00003cd8 00098258 3ee0: bf0174dc c33e2000 c00301a4 bf019000 c33e3f1c c33e3f00 c01f6588 c01f4c8c 3f00: 00003cd8 00098258 00000000 c33e2000 c33e3f2c c33e3f20 c01f777c c01f6524 3f20: c33e3f3c c33e3f30 bf019014 c01f7740 c33e3f7c c33e3f40 c002f3ec bf019010 3f40: 00000000 00003cd8 00098258 bf017518 00000000 00003cd8 00098258 bf017518 3f60: 00000000 c00301a4 c33e2000 00000000 c33e3fa4 c33e3f80 c007b934 c002f3c4 3f80: c00b307c c00b2f48 00003cd8 00000000 00000003 00000080 00000000 c33e3fa8 3fa0: c0030020 c007b8b8 00003cd8 00000000 00098288 00003cd8 00098258 00098240 3fc0: 00003cd8 00000000 00000003 00000080 00098008 00098028 00098288 00000001 3fe0: be892998 be892988 00013d7c 40178740 60000010 00098288 09089041 00200845 Backtrace: [<c0080ba4>] (irq_gc_mask_set_bit+0x0/0x7c) from [<c007f5f8>] (irq_enable+0x48/0x58) r6:c33d4340 r5:c04555bc r4:c04555bc [<c007f5b0>] (irq_enable+0x0/0x58) from [<c007f654>] (irq_startup+0x4c/0x54) r5:c04555bc r4:00000000 [<c007f608>] (irq_startup+0x0/0x54) from [<c007e6e8>] (__setup_irq+0x2f0/0x3cc) r5:c04555bc r4:00000000 [<c007e3f8>] (__setup_irq+0x0/0x3cc) from [<c007e888>] (request_threaded_irq+0xc4/0x110) r8:0000002d r7:c33dc008 r6:00000000 r5:00000001 r4:bf016c98 [<c007e7c4>] (request_threaded_irq+0x0/0x110) from [<bf016b44>] (mcu_spi_probe+0x228/0x37c [mcu]) [<bf01691c>] (mcu_spi_probe+0x0/0x37c [mcu]) from [<c022a698>] (spi_drv_probe+0x20/0x24) [<c022a678>] (spi_drv_probe+0x0/0x24) from [<c01f5d88>] (driver_probe_device+0x88/0x1b0) [<c01f5d00>] (driver_probe_device+0x0/0x1b0) from [<c01f5f8c>] (__device_attach+0x44/0x48) [<c01f5f48>] (__device_attach+0x0/0x48) from [<c01f5210>] (bus_for_each_drv+0x68/0x94) r5:c33e3cf0 r4:00000000 [<c01f51a8>] (bus_for_each_drv+0x0/0x94) from [<c01f6044>] (device_attach+0x88/0xa0) r7:c33e3dd8 r6:c25caa34 r5:c25caa00 r4:c25caa00 [<c01f5fbc>] (device_attach+0x0/0xa0) from [<c01f4ff4>] (bus_probe_device+0x2c/0x4c) r7:c33e3dd8 r6:c044e918 r5:c25caa00 r4:c0496d3c [<c01f4fc8>] (bus_probe_device+0x0/0x4c) from [<c01f3d10>] (device_add+0x4d4/0x648) [<c01f383c>] (device_add+0x0/0x648) from [<c022b1a0>] (spi_add_device+0xc8/0x128) [<c022b0d8>] (spi_add_device+0x0/0x128) from [<c022b27c>] (spi_new_device+0x7c/0xb4) r7:c33e3dd8 r6:00000000 r5:c33e3dd8 r4:c25caa00 [<c022b200>] (spi_new_device+0x0/0xb4) from [<bf016f60>] (mcu_probe+0x144/0x224 [mcu]) r7:c33e3dd8 r6:c0451c80 r5:bf01763c r4:00000000 [<bf016e1c>] (mcu_probe+0x0/0x224 [mcu]) from [<c01f72f4>] (platform_drv_probe+0x20/0x24) [<c01f72d4>] (platform_drv_probe+0x0/0x24) from [<c01f5d88>] (driver_probe_device+0x88/0x1b0) [<c01f5d00>] (driver_probe_device+0x0/0x1b0) from [<c01f5f44>] (__driver_attach+0x94/0x98) [<c01f5eb0>] (__driver_attach+0x0/0x98) from [<c01f5534>] (bus_for_each_dev+0x68/0x94) r7:c01f5eb0 r6:bf0174dc r5:c33e3e98 r4:00000000 [<c01f54cc>] (bus_for_each_dev+0x0/0x94) from [<c01f5bec>] (driver_attach+0x20/0x28) r7:c0462ac8 r6:bf0174dc r5:00098258 r4:00003cd8 [<c01f5bcc>] (driver_attach+0x0/0x28) from [<c01f4d30>] (bus_add_driver+0xb4/0x258) [<c01f4c7c>] (bus_add_driver+0x0/0x258) from [<c01f6588>] (driver_register+0x74/0x158) [<c01f6514>] (driver_register+0x0/0x158) from [<c01f777c>] (platform_driver_register+0x4c/0x60) r7:c33e2000 r6:00000000 r5:00098258 r4:00003cd8 [<c01f7730>] (platform_driver_register+0x0/0x60) from [<bf019014>] (mcu_init+0x14/0x20 [mcu]) [<bf019000>] (mcu_init+0x0/0x20 [mcu]) from [<c002f3ec>] (do_one_initcall+0x38/0x170) [<c002f3b4>] (do_one_initcall+0x0/0x170) from [<c007b934>] (sys_init_module+0x8c/0x1a4) [<c007b8a8>] (sys_init_module+0x0/0x1a4) from [<c0030020>] (ret_fast_syscall+0x0/0x2c) r7:00000080 r6:00000003 r5:00000000 r4:00003cd8 Code: e1844003 e585400c e596300c e5932064 (e7814002) Fix the issue. Reported-by: Jon Povey <Jon.Povey@racelogic.co.uk> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02gpio/omap: fix _set_gpio_irqenable implementationTarun Kanti DebBarma
commit 8276536cec38bc6bde30d0aa67716f22b9b9705a upstream. This function should be capable of both enabling and disabling interrupts based upon the *enable* parameter. Right now the function only enables the interrupt and *enable* is not used at all. So add the interrupt disable capability also using the parameter. Signed-off-by: Tarun Kanti DebBarma <tarun.kanti@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ARM: tegra: select required CPU and L2 errata optionsStephen Warren
commit f35b431dde39fb40944d1024f08d88fbf04a3193 upstream. The ARM IP revisions in Tegra are: Tegra20: CPU r1p1, PL310 r2p0 Tegra30: CPU A01=r2p7/>=A02=r2p9, NEON r2p3-50, PL310 r3p1-50 Based on work by Olof Johansson, although the actual list of errata is somewhat different here, since I added a bunch more and removed one PL310 erratum that doesn't seem applicable. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02vfs: fix d_ancestor() case in d_materialize_uniqueMichel Lespinasse
commit b18dafc86bb879d2f38a1743985d7ceb283c2f4d upstream. In d_materialise_unique() there are 3 subcases to the 'aliased dentry' case; in two subcases the inode i_lock is properly released but this does not occur in the -ELOOP subcase. This seems to have been introduced by commit 1836750115f2 ("fix loop checks in d_materialise_unique()"). Signed-off-by: Michel Lespinasse <walken@google.com> [ Added a comment, and moved the unlock to where we generate the -ELOOP, which seems to be more natural. You probably can't actually trigger this without a buggy network file server - d_materialize_unique() is for finding aliases on non-local filesystems, and the d_ancestor() case is for a hardlinked directory loop. But we should be robust in the case of such buggy servers anyway. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ext4: check for zero length extentTheodore Ts'o
commit 31d4f3a2f3c73f279ff96a7135d7202ef6833f12 upstream. Explicitly test for an extent whose length is zero, and flag that as a corrupted extent. This avoids a kernel BUG_ON assertion failure. Tested: Without this patch, the file system image found in tests/f_ext_zero_len/image.gz in the latest e2fsprogs sources causes a kernel panic. With this patch, an ext4 file system error is noted instead, and the file system is marked as being corrupted. https://bugzilla.kernel.org/show_bug.cgi?id=42859 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ext4: fix race between sync and completed io workJeff Moyer
commit 491caa43639abcffaa645fbab372a7ef4ce2975c upstream. The following command line will leave the aio-stress process unkillable on an ext4 file system (in my case, mounted on /mnt/test): aio-stress -t 20 -s 10 -O -S -o 2 -I 1000 /mnt/test/aiostress.3561.4 /mnt/test/aiostress.3561.4.20 /mnt/test/aiostress.3561.4.19 /mnt/test/aiostress.3561.4.18 /mnt/test/aiostress.3561.4.17 /mnt/test/aiostress.3561.4.16 /mnt/test/aiostress.3561.4.15 /mnt/test/aiostress.3561.4.14 /mnt/test/aiostress.3561.4.13 /mnt/test/aiostress.3561.4.12 /mnt/test/aiostress.3561.4.11 /mnt/test/aiostress.3561.4.10 /mnt/test/aiostress.3561.4.9 /mnt/test/aiostress.3561.4.8 /mnt/test/aiostress.3561.4.7 /mnt/test/aiostress.3561.4.6 /mnt/test/aiostress.3561.4.5 /mnt/test/aiostress.3561.4.4 /mnt/test/aiostress.3561.4.3 /mnt/test/aiostress.3561.4.2 This is using the aio-stress program from the xfstests test suite. That particular command line tells aio-stress to do random writes to 20 files from 20 threads (one thread per file). The files are NOT preallocated, so you will get writes to random offsets within the file, thus creating holes and extending i_size. It also opens the file with O_DIRECT and O_SYNC. On to the problem. When an I/O requires unwritten extent conversion, it is queued onto the completed_io_list for the ext4 inode. Two code paths will pull work items from this list. The first is the ext4_end_io_work routine, and the second is ext4_flush_completed_IO, which is called via the fsync path (and O_SYNC handling, as well). There are two issues I've found in these code paths. First, if the fsync path beats the work routine to a particular I/O, the work routine will free the io_end structure! It does not take into account the fact that the io_end may still be in use by the fsync path. I've fixed this issue by adding yet another IO_END flag, indicating that the io_end is being processed by the fsync path. The second problem is that the work routine will make an assignment to io->flag outside of the lock. I have witnessed this result in a hang at umount. Moving the flag setting inside the lock resolved that problem. The problem was introduced by commit b82e384c7b ("ext4: optimize locking for end_io extent conversion"), which first appeared in 3.2. As such, the fix should be backported to that release (probably along with the unwritten extent conversion race fix). Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ext4: fix race between unwritten extent conversion and truncateJeff Moyer
commit 266991b13890049ee1a6bb95b9817f06339ee3d7 upstream. The following comment in ext4_end_io_dio caught my attention: /* XXX: probably should move into the real I/O completion handler */ inode_dio_done(inode); The truncate code takes i_mutex, then calls inode_dio_wait. Because the ext4 code path above will end up dropping the mutex before it is reacquired by the worker thread that does the extent conversion, it seems to me that the truncate can happen out of order. Jan Kara mentioned that this might result in error messages in the system logs, but that should be the extent of the "damage." The fix is pretty straight-forward: don't call inode_dio_done until the extent conversion is complete. Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ext4: ignore EXT4_INODE_JOURNAL_DATA flag with delallocLukas Czerner
commit 3d2b158262826e8b75bbbfb7b97010838dd92ac7 upstream. Ext4 does not support data journalling with delayed allocation enabled. We even do not allow to mount the file system with delayed allocation and data journalling enabled, however it can be set via FS_IOC_SETFLAGS so we can hit the inode with EXT4_INODE_JOURNAL_DATA set even on file system mounted with delayed allocation (default) and that's where problem arises. The easies way to reproduce this problem is with the following set of commands: mkfs.ext4 /dev/sdd mount /dev/sdd /mnt/test1 dd if=/dev/zero of=/mnt/test1/file bs=1M count=4 chattr +j /mnt/test1/file dd if=/dev/zero of=/mnt/test1/file bs=1M count=4 conv=notrunc chattr -j /mnt/test1/file Additionally it can be reproduced quite reliably with xfstests 272 and 269. In fact the above reproducer is a part of test 272. To fix this we should ignore the EXT4_INODE_JOURNAL_DATA inode flag if the file system is mounted with delayed allocation. This can be easily done by fixing ext4_should_*_data() functions do ignore data journal flag when delalloc is set (suggested by Ted). We also have to set the appropriate address space operations for the inode (again, ignoring data journal flag if delalloc enabled). Additionally this commit introduces ext4_inode_journal_mode() function because ext4_should_*_data() has already had a lot of common code and this change is putting it all into one function so it is easier to read. Successfully tested with xfstests in following configurations: delalloc + data=ordered delalloc + data=writeback data=journal nodelalloc + data=ordered nodelalloc + data=writeback nodelalloc + data=journal Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02jbd2: clear BH_Delay & BH_Unwritten in journal_unmap_bufferEric Sandeen
commit 15291164b22a357cb211b618adfef4fa82fc0de3 upstream. journal_unmap_buffer()'s zap_buffer: code clears a lot of buffer head state ala discard_buffer(), but does not touch _Delay or _Unwritten as discard_buffer() does. This can be problematic in some areas of the ext4 code which assume that if they have found a buffer marked unwritten or delay, then it's a live one. Perhaps those spots should check whether it is mapped as well, but if jbd2 is going to tear down a buffer, let's really tear it down completely. Without this I get some fsx failures on sub-page-block filesystems up until v3.2, at which point 4e96b2dbbf1d7e81f22047a50f862555a6cb87cb and 189e868fa8fdca702eb9db9d8afc46b5cb9144c9 make the failures go away, because buried within that large change is some more flag clearing. I still think it's worth doing in jbd2, since ->invalidatepage leads here directly, and it's the right place to clear away these flags. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02PM / Hibernate: Enable usermodehelpers in hibernate() error pathSrivatsa S. Bhat
commit 05b4877f6a4f1ba4952d1222213d262bf8c132b7 upstream. If create_basic_memory_bitmaps() fails, usermodehelpers are not re-enabled before returning. Fix this. And while at it, reword the goto labels so that they look more meaningful. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02NFSv4: Rate limit the state manager warning messagesTrond Myklebust
commit 9a3ba432330e504ac61ff0043dbdaba7cea0e35a upstream. Prevent the state manager from filling up system logs when recovery fails on the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02staging: r8712u: Add missing initialization and remove configuration ↵Larry Finger
parameter CONFIG_R8712_AP commit 073863432f7eaa23c7c09733414d4be2eabf5eef upstream. When this driver was upgraded to the vendor 20100831 version in commit 93c55dda092c7 et al,, one listhead initialization was missed. This broke complete operation of the driver whenever AP mode was enabled. This fixes https://bugs.archlinux.org/task/27996. The configuration parameter R8712_AP is misleading as the driver cannot function as an AP without a heavily hacked version of hostapd. Thus, it makes sense to remove the parameter; however the code and data configured for the option is left in. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02rtlwifi: Convert to asynchronous firmware loadLarry Finger
commit b0302aba812bcc39291cdab9ad7e37008f352a91 upstream. This patch addresses a kernel bugzilla report and two recent mail threads. The kernel bugzilla report is https://bugzilla.kernel.org/show_bug.cgi?id=42632, which reports a udev timeout on boot. The first mail thread, which was on LKML (http://lkml.indiana.edu/hypermail/ linux/kernel/1112.3/00965.html) was for a WARNING that occurs after a suspend/resume cycle for rtl8192cu. The scond mail thread (http://marc.info/?l=linux-wireless&m=132655490826766&w=2) concerned changes in udev that break drivers that delay while firmware is loaded on modprobe. This patch converts all rtlwifi-based drivers to use the asynchronous firmware loading mechanism. Drivers rtl8192ce, rtl8192cu and rtl8192de share a common callback routine. Driver rtl8192se needs different handling of the firmware, thus it has its own code. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on()Rafael J. Wysocki
Commit 57d13370cfaf6017c68981e66ff5b3bf20a2705c upstream. Make the MTU2 clocksource driver mark its device as "always on" using pm_genpd_dev_always_on() to protect it from surprise power removals. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02PM / shmobile: Make CMT driver use pm_genpd_dev_always_on()Rafael J. Wysocki
Commit 615a445f7f8a077c145e737864ae59a4d8717882 upstream. Make the CMT clocksource driver mark its device as "always on" using pm_genpd_dev_always_on() to protect it from surprise power removals. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02PM / shmobile: Make TMU driver use pm_genpd_dev_always_on()Rafael J. Wysocki
Commit 2ee619f9487c2acc1efdf2c78e68e2bd51b635fa upstream. Make the TMU clocksource driver mark its device as "always on" using pm_genpd_dev_always_on() to protect it from surprise power removals and make sh7372_add_standard_devices() add TMU devices on sh7372 to the A4R power domain so that their "always on" flags are taken into account as appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02PM / Domains: Introduce "always on" device flagRafael J. Wysocki
This is a backport of mainline commit 1e78a0c7fc92aee076965d516cf54475c39e9894. The TMU device on the Mackerel board belongs to the A4R power domain and loses power when the domain is turned off. Unfortunately, the TMU driver is not prepared to cope with such situations and crashes the system when that happens. To work around this problem introduce a new helper function, pm_genpd_dev_always_on(), allowing a device driver to mark its device as "always on" in case it belongs to a PM domain, which will make the generic PM domains core code avoid powering off the domain containing the device, both at run time and during system suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
