2012-03-03Linux 3.3-rc6v3.3-rc6Linus Torvalds
2012-03-03Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6 SCSI fixes from James Bottomley: "There's just a single fix in here: the osd max device number fix." * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] osd_uld: Bump MAX_OSD_DEVICES from 64 to 1,048,576
2012-03-03Merge tag 'parisc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 PARISC fixes from James Bottomley: "This is a set of build fixes to get the cross compiled architecture testbeds building again" * tag 'parisc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] don't unconditionally override CROSS_COMPILE for 64 bit. [PARISC] include <linux/prefetch.h> in drivers/parisc/iommu-helpers.h [PARISC] fix compile break caused by iomap: make IOPORT/PCI mapping functions conditional
2012-03-03Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/kvm: Fix Host-Only/Guest-Only counting with SVM disabled
2012-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull from Herbert Xu: "This push fixes a bug in mv_cesa that causes all hash operations that supply data on a final operation to fail." * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: mv_cesa - fix final callback not ignoring input data
2012-03-02vfs: export full_name_hash() function to modulesLinus Torvalds
Commit 5707c87f "vfs: uninline full_name_hash()" broke the modular build, because it needs exporting now that it isn't inlined any more. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging hhwmon fixes for 3.3-rc6 from Guenter Roeck: These patches are necessary for correct operation and management of F75387. * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (f75375s) Catch some attempts to write to r/o registers hwmon: (f75375s) Properly map the F75387 automatic modes to pwm_enable hwmon: (f75375s) Make pwm*_mode writable for the F75387 hwmon: (f75375s) Fix writes to the pwm* attribute for the F75387
2012-03-02Merge tag 'fbdev-fixes-for-3.3-2' of git://github.com/schandinat/linux-2.6Linus Torvalds
fbdev fixes for 3.3 from Florian Tobias Schandinat It includes: - two fixes for OMAP HDMI - one fix to make new OMAP functions behave as they are supposed to - one Kconfig dependency fix - two fixes for viafb for modesetting on VX900 hardware * tag 'fbdev-fixes-for-3.3-2' of git://github.com/schandinat/linux-2.6: OMAPDSS: APPLY: make ovl_enable/disable synchronous OMAPDSS: panel-dvi: Add Kconfig dependency on I2C viafb: fix IGA1 modesetting on VX900 viafb: select HW scaling on VX900 for IGA2 OMAPDSS: HDMI: hot plug detect fix OMAPDSS: HACK: Ensure DSS clock domain gets out of idle when HDMI is enabled
2012-03-02Merge tag 'sound-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound sound fixes for 3.3-rc6 from Takashi Iwai This contains again regression fixes for various HD-audio and ASoC regarding SSI and dapm shutdown path. In addition, a minor azt3328 fix and the correction of the new jack-notification strings in HD-audio. * tag 'sound-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Kill hyphenated names ALSA: hda - Add a fake mute feature ALSA: hda - Always set HP pin in unsol handler for STAC/IDT codecs ALSA: azt3328 - Fix NULL ptr dereference on cards without OPL3 ALSA: hda/realtek - Fix resume of multiple input sources ASoC: i.MX SSI: Fix DSP_A format. ASoC: dapm: Check for bias level when powering down
2012-03-02vfs: split up name hashing in link_path_walk() into helper functionLinus Torvalds
The code in link_path_walk() that finds out the length and the hash of the next path component is some of the hottest code in the kernel. And I have a version of it that does things at the full width of the CPU wordsize at a time, but that means that we *really* want to split it up into a separate helper function. So this re-organizes the code a bit and splits the hashing part into a helper function called "hash_name()". It returns the length of the pathname component, while at the same time computing and writing the hash to the appropriate location. The code generation is slightly changed by this patch, but generally for the better - and the added abstraction actually makes the code easier to read too. And the new interface is well suited for replacing just the "hash_name()" function with alternative implementations. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02vfs: clarify and clean up dentry_cmp()Linus Torvalds
It did some odd things for unclear reasons. As this is one of the functions that gets changed when doing word-at-a-time compares, this is yet another of the "don't change any semantics, but clean things up so that subsequent patches don't get obscured by the cleanups". Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02vfs: uninline full_name_hash()Linus Torvalds
.. and also use it in lookup_one_len() rather than open-coding it. There aren't any performance-critical users, so inlining it is silly. But it wouldn't matter if it wasn't for the fact that the word-at-a-time dentry name patches want to conditionally replace the function, and uninlining it sets the stage for that. So again, this is a preparatory patch that doesn't change any semantics, and only prepares for a much cleaner and testable word-at-a-time dentry name accessor patch. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02vfs: trivial __d_lookup_rcu() cleanupsLinus Torvalds
These don't change any semantics, but they clean up the code a bit and mark some arguments appropriately 'const'. They came up as I was doing the word-at-a-time dcache name accessor code, and cleaning this up now allows me to send out a smaller relevant interesting patch for the experimental stuff. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02hwmon: (f75375s) Catch some attempts to write to r/o registersNikolaus Schulz
It makes no sense to attempt to manually configure the fan in auto mode, or set the duty cycle directly in closed loop mode. The corresponding registers are then read-only. If the user tries it nonetheless, error out with EINVAL instead of silently doing nothing. Signed-off-by: Nikolaus Schulz <mail@microschulz.de> [guenter.roeck@ericsson.com: Minor formatting cleanup] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-03-02hwmon: (f75375s) Properly map the F75387 automatic modes to pwm_enableNikolaus Schulz
The F75387 supports automatic fan control using either PWM duty cycle or RPM speed values. Make the driver detect the latter mode, and expose the different modes in sysfs as per pwm_enable, so that the user can switch between them. The interpretation of the pwm_enable attribute for the F75387 is adjusted to be a superset of those values used for similar Fintek chips which do not support automatic duty mode, with 2 mapping to automatic speed mode, and moving automatic duty mode to the new value 4. Toggling the duty mode via pwm_enable is currently denied for the F75387, as the chip then simply reinterprets the fan configuration register values according to the new mode, switching between RPM and PWM units, which makes this a dangerous operation. This patch introduces a new pwm mode into the driver. This is necessary because the new mode (automatic pwm mode, 4) may already be enabled by the BIOS, and the driver should not break existing functionality. This was seen on at least one board. Signed-off-by: Nikolaus Schulz <mail@microschulz.de> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-03-02Merge branches 'core-urgent-for-linus', 'perf-urgent-for-linus' and ↵Linus Torvalds
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pulling latest branches from Ingo: * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: memblock: Fix size aligning of memblock_alloc_base_nid() * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Ensure offset provided is not greater than function length without DWARF info too perf tools: Ensure comm string is properly terminated perf probe: Ensure offset provided is not greater than function length perf evlist: Return first evsel for non-sample event on old kernel perf/hwbp: Fix a possible memory leak * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: CPU hotplug, cpusets, suspend: Don't touch cpusets during suspend/resume
2012-03-02regset: Return -EFAULT, not -EIO, on host-side memory faultH. Peter Anvin
There is only one error code to return for a bad user-space buffer pointer passed to a system call in the same address space as the system call is executed, and that is EFAULT. Furthermore, the low-level access routines, which catch most of the faults, return EFAULT already. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: <stable@vger.kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02regset: Prevent null pointer reference on readonly regsetsH. Peter Anvin
The regset common infrastructure assumed that regsets would always have .get and .set methods, but not necessarily .active methods. Unfortunately people have since written regsets without .set methods. Rather than putting in stub functions everywhere, handle regsets with null .get or .set methods explicitly. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: <stable@vger.kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-02perf/x86/kvm: Fix Host-Only/Guest-Only counting with SVM disabledJoerg Roedel
It turned out that a performance counter on AMD does not count at all when the GO or HO bit is set in the control register and SVM is disabled in EFER. This patch works around this issue by masking out the HO bit in the performance counter control register when SVM is not enabled. The GO bit is not touched because it is only set when the user wants to count in guest-mode only. So when SVM is disabled the counter should not run at all and the not-counting is the intended behaviour. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Avi Kivity <avi@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Robert Richter <robert.richter@amd.com> Cc: stable@vger.kernel.org # v3.2 Link: http://lkml.kernel.org/r/1330523852-19566-1-git-send-email-joerg.roedel@amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-02ALSA: hda - Kill hyphenated namesTakashi Iwai
Kill hyphens from "Line-Out" name strings, as suggested by Mark Brown. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-02Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Various smaller perf/urgent fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Watchdog updates from Wim Van Sebroeck: * git://www.linux-watchdog.org/linux-watchdog: watchdog: fix GETTIMEOUT ioctl in booke_wdt watchdog: update maintainers git entry watchdog: Fix typo in pnx4008_wdt.c watchdog: Fix typo in Kconfig watchdog: fix error in probe() of s3c2410_wdt (reset at booting) watchdog: hpwdt: clean up set_memory_x call for 32 bit
2012-03-01Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull from Mark Brown: "A simple, driver specific fix. This device isn't widely used outside of Marvell reference boards most of which are probably used with their BSPs rather than with mainline so low risk." * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: fix the ldo configure according to 88pm860x spec
2012-03-01Merge branch 'i2c-embedded/for-3.3' of ↵Linus Torvalds
git://git.pengutronix.de/git/wsa/linux-2.6 i2c bugfix from Wolfram Sang: "This patch fixes a wrong assumption in the mxs-i2c-driver about a command queue being done. Without it, we have seen races when the bus was under load." * 'i2c-embedded/for-3.3' of git://git.pengutronix.de/git/wsa/linux-2.6: i2c: mxs: only flag completion when queue is completely done
2012-03-01Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
DRM fixes from Dave Airlie: intel: fixes for output regression on 965GM, an oops and a machine hang radeon: uninitialised var (that gcc didn't warn about for some reason) + a couple of correctness fixes. exynos: fixes for various things, drop some chunks of unused code. * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon/kms/vm: fix possible bug in radeon_vm_bo_rmv() drm/radeon: fix uninitialized variable drm/radeon/kms: fix radeon_dp_get_modes for LVDS bridges (v2) drm/i915: Remove use of the autoreported ringbuffer HEAD position drm/i915: Prevent a machine hang by checking crtc->active before loading lut drm/i915: fix operator precedence when enabling RC6p drm/i915: fix a sprite watermark computation to avoid divide by zero if xpos<0 drm/i915: fix mode set on load pipe. (v2) drm/exynos: exynos_drm.h header file fixes drm/exynos: added panel physical size. drm/exynos: added postclose to release resource. drm/exynos: removed exynos_drm_fbdev_recreate function. drm/exynos: fixed page flip issue. drm/exynos: added possible_clones setup function. drm/exynos: removed pageflip_event_list init code when closed. drm/exynos: changed priority of mixer layers. drm/exynos: Fix typo in exynos_mixer.c
2012-03-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: [S390] memory hotplug: prevent memory zone interleave [S390] crash_dump: remove duplicate include [S390] KEYS: Enable the compat keyctl wrapper on s390x
2012-03-01Merge tag 'asoc-3.3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus A small fix for the SSI driver and a fix for system shutdown with modern devices. Most of the modern devices will never get shut down normally with a visible kernel log as the systems they're in tend not to shut down often and when they do it's usually in form factors that don't have a user visible console.
2012-03-01memblock: Fix size aligning of memblock_alloc_base_nid()Tejun Heo
memblock allocator aligns @size to @align to reduce the amount of fragmentation. Commit: 7bd0b0f0da ("memblock: Reimplement memblock allocation using reverse free area iterator") Broke it by incorrectly relocating @size aligning to memblock_find_in_range_node(). As the aligned size is not propagated back to memblock_alloc_base_nid(), the actually reserved size isn't aligned. While this increases memory use for memblock reserved array, this shouldn't cause any critical failure; however, it seems that the size aligning was hiding a use-beyond-allocation bug in sparc64 and losing the aligning causes boot failure. The underlying problem is currently being debugged but this is a proper fix in itself, it's already pretty late in -rc cycle for boot failures and reverting the change for debugging isn't difficult. Restore the size aligning moving it to memblock_alloc_base_nid(). Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20120228205621.GC3252@dhcp-172-17-108-109.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <alpine.SOC.1.00.1202130942030.1488@math.ut.ee>
2012-02-29Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Merge virtio pull request from Rusty Russell. * tag 'for-linus' of git://github.com/rustyrussell/linux: virtio: balloon: leak / fill balloon across S4
2012-03-01virtio: balloon: leak / fill balloon across S4Amit Shah
commit e562966dbaf49e7804097cd991e5d3a8934fc148 added support for S4 to the balloon driver. The freeze function did nothing to free the pages, since reclaiming the pages from the host to immediately give them back (if S4 was successful) seemed wasteful. Also, if S4 wasn't successful, the guest would have to re-fill the balloon. On restore, the pages were supposed to be marked freed and the free page counters were incremented to reflect the balloon was totally deflated. However, this wasn't done right. The pages that were earlier taken away from the guest during a balloon inflation operation were just shown as used pages after a successful restore from S4. Just a fancy way of leaking lots of memory. Instead of trying that, just leak the balloon on freeze and fill it on restore/thaw paths. This works properly now. The optimisation to not leak can be added later on after a bit of refactoring of the code. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-02-29OMAPDSS: APPLY: make ovl_enable/disable synchronousTomi Valkeinen
ovl->enable/disable are meant to be synchronous so that they can handle the configuration of fifo sizes. The current kernel doesn't configure fifo sizes yet, and so the code doesn't need to block to function (from omapdss driver's perspective). However, for the users of omapdss a non-blocking ovl->disable is confusing, because they don't know when the memory area is not used any more. Furthermore, when the fifo size configuration is added in the next merge window, the change from non-blocking to blocking could cause side effects to the users of omapdss. So by making the functions block already will keep them behaving in the same manner. And, while not the main purpose of this patch, this will also remove the compile warning: drivers/video/omap2/dss/apply.c:350: warning: 'wait_pending_extra_info_updates' defined but not used Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-02-29OMAPDSS: panel-dvi: Add Kconfig dependency on I2CTomi Valkeinen
panel-dvi uses i2c, but the Kconfig didn't have dependency on I2C. Add it. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-02-29perf probe: Ensure offset provided is not greater than function length ↵Prashanth Nageshappa
without DWARF info too The 'perf probe' command allows kprobe to be inserted at any offset from a function start, which results in adding kprobes to unintended location. (example: perf probe do_fork+10000 is allowed even though size of do_fork is ~904). My previous patch https://lkml.org/lkml/2012/2/24/42 addressed the case where DWARF info was available for the kernel. This patch fixes the case where perf probe is used on a kernel without debuginfo available. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/4F4C544D.1010909@linux.vnet.ibm.com Signed-off-by: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-29perf tools: Ensure comm string is properly terminatedDavid Ahern
If threads in a multi-threaded process have names shorter than the main thread the comm for the named threads is not properly terminated. E.g., for the process 'namedthreads' where each thread is named noploop%d where %d is the thread number: Before: perf script -f comm,tid,ip,sym,dso noploop:4ads 21616 400a49 noploop (/tmp/namedthreads) The 'ads' in the thread comm bleeds over from the process name. After: perf script -f comm,tid,ip,sym,dso noploop:4 21616 400a49 noploop (/tmp/namedthreads) Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1330111898-68071-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-29perf probe: Ensure offset provided is not greater than function lengthPrashanth Nageshappa
The perf probe command allows kprobe to be inserted at any offset from a function start, which results in adding kprobes to unintended location. Example: perf probe do_fork+10000 is allowed even though size of do_fork is ~904. This patch will ensure probe addition fails when the offset specified is greater than size of the function. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jason Baron <jbaron@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/4F473F33.4060409@linux.vnet.ibm.com Signed-off-by: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-29perf evlist: Return first evsel for non-sample event on old kernelNamhyung Kim
On old kernels that don't support sample_id_all feature, perf_evlist__id2evsel() returns NULL for non-sampling events. This breaks perf top when multiple events are given on command line. Fix it by using first evsel in the evlist. This will also prevent getting the same (potential) problem in such new tool/ old kernel combo. Suggested-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1329702447-25045-1-git-send-email-namhyung.kim@lge.com Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-29Merge tag 'fixes-3.3-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Arnd Bergmann says: "Another set of arm-soc bug fixes on top of v3.3-rc5. The few larger bits are all for devices that still need to get set up in board code. Only three platforms are in this set of fixes: omap2+, pxa and lpc32xx." * tag 'fixes-3.3-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (22 commits) ARM: LPC32xx: serial.c: Fixed loop limit ARM: LPC32xx: serial.c: HW bug workaround ARM: LPC32xx: irq.c: Clear latched event ARM: LPC32xx: Fix interrupt controller init ARM: LPC32xx: Fix irq on GPI_28 ARM: OMAP2: fix mailbox init code ARM: OMAP2+: gpmc-smsc911x: add required smsc911x regulators ARM: OMAP1: Fix out-of-bounds array access for Innovator OMAP3 EVM: remove out-of-bounds array access of gpio_leds ARM: OMAP: Fix build error when mmc_omap is built as module ARM: OMAP: Fix kernel panic with HSMMC when twl4030_gpio is a module pxa/hx4700: add platform device and I2C info for AK4641 codec arch/arm/mach-pxa/: included linux/gpio.h twice arch/arm/mach-mmp/: some files include some headers twice ARM: pxa: fix error handling in pxa2xx_drv_pcmcia_probe ARM: pxa: fix including linux/gpio.h twice ARM: pxa: fix mixed declarations and code in sharpsl_pm ARM: pxa: fix wrong parsing gpio event on spitz ARM: OMAP2+: usb-host: fix compile warning ARM: OMAP4: Move the barrier memboclk_steal() as part of reserve callback ...
2012-02-29Merge tag 'for-3.3' of git://openrisc.net/jonas/linuxLinus Torvalds
Build fixes for 3.3 from Jonas Bonn * tag 'for-3.3' of git://openrisc.net/jonas/linux: openrisc: Fix up audit_syscall_[entry|exit]() usage openrisc: include export.h for EXPORT_SYMBOL
2012-02-29drm/radeon/kms/vm: fix possible bug in radeon_vm_bo_rmv()Sebastian Biemueller
The bo is removed from the list at the top of radeon_vm_bo_rmv(), but then the list is used in radeon_vm_bo_update_pte() to look up the vm. remove the bo_list entry at the end of the function instead. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jerome Glisse <j.glisse@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-29ALSA: hda - Add a fake mute featureTakashi Iwai
Some codecs don't supply the mute amp-capabilities although the lowest volume gives the mute. It'd be handy if the parser provides the mute mixers in such a case. This patch adds an extension amp-cap bit (which is used only in the driver) to represent the min volume = mute state. Also modified the amp cache code to support the fake mute feature when this bit is set but the real mute bit is unset. In addition, conexant cx5051 parser uses this new feature to implement the missing mute controls. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42825 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-29drm/radeon: fix uninitialized variableChristian König
Without this fix the driver randomly treats textures as arrays and I'm really wondering why gcc isn't complaining about it. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-29Merge branch 'exynos-drm-fixes' of ↵Dave Airlie
git://git.infradead.org/users/kmpark/linux-2.6-samsung into HEAD * 'exynos-drm-fixes' of git://git.infradead.org/users/kmpark/linux-2.6-samsung: drm/exynos: exynos_drm.h header file fixes drm/exynos: added panel physical size. drm/exynos: added postclose to release resource. drm/exynos: removed exynos_drm_fbdev_recreate function. drm/exynos: fixed page flip issue. drm/exynos: added possible_clones setup function. drm/exynos: removed pageflip_event_list init code when closed. drm/exynos: changed priority of mixer layers. drm/exynos: Fix typo in exynos_mixer.c
2012-02-29drm/radeon/kms: fix radeon_dp_get_modes for LVDS bridges (v2)Alex Deucher
Need to call ExternalEncoderControl to set up DDC before trying to get an EDID for all DP bridge chips (including DP to LVDS). Also remove redundant encoder assignment. V2: fix typo in commit message. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-29watchdog: fix GETTIMEOUT ioctl in booke_wdtDmitry Artamonow
Commit dcfb748422 ([WATCHDOG] fix book E watchdog to take WDIOC_SETTIMEOUT arg in seconds) fixed SETTIMEOUT ioctl to use seconds as a parameter instead of some hardware-specific "period", but missed to apply similar changes to GETTIMEOUT, so it still returns "period" value. Let's fix it! Also, while at it, make SETTIMEOUT ioctl return real timeout value as it should do according to the documentation. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-02-29ALSA: hda - Always set HP pin in unsol handler for STAC/IDT codecsTakashi Iwai
A bug report with an old Sony laptop showed that we can't rely on BIOS setting the pins of headphones but the driver should set always by itself. Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-28ecryptfs: fix printk format warning for size_tRandy Dunlap
Fix printk format warning (from Linus's suggestion): on i386: fs/ecryptfs/miscdev.c:433:38: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'unsigned int' and on x86_64: fs/ecryptfs/miscdev.c:433:38: warning: format '%u' expects type 'unsigned int', but argument 4 has type 'long unsigned int' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Cc: ecryptfs@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-28hwmon: (f75375s) Make pwm*_mode writable for the F75387Nikolaus Schulz
2012-02-28hwmon: (f75375s) Fix writes to the pwm* attribute for the F75387Nikolaus Schulz
For the F75387, the register holding the current PWM duty cycle value is r/o; changing it requires writing to the fan expect register instead. Signed-off-by: Nikolaus Schulz <mail@microschulz.de> [guenter.roeck@ericsson.com: Simplified function parameters] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-02-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: Read resource groups on mount GFS2: Ensure rindex is uptodate for fallocate GFS2: Read in rindex if necessary during unlink GFS2: Fix race between lru_list and glock ref count
2012-02-28Merge tag 'iommu-fixes-v3.3-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu IOMMU fixes for Linux 3.3-rc5 All the fixes are for the OMAP IOMMU driver. The first patch is the biggest one. It fixes the calls of the function omap_find_iovm_area() in the omap-iommu-debug module which expects a 'struct device' parameter since commit fabdbca instead of an omap_iommu handle. The omap-iommu-debug code still passed the handle to the function which caused a crash. The second patch fixes a NULL pointer dereference in the OMAP code and the third patch makes sure that the omap-iommu is initialized before the omap-isp driver, which relies on the iommu. The last patch is only a workaround until defered probing is implemented. * tag 'iommu-fixes-v3.3-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: ARM: OMAP: make iommu subsys_initcall to fix builtin omap3isp iommu/omap: fix NULL pointer dereference iommu/omap: fix erroneous omap-iommu-debug API calls
