2012-01-19Linux 3.3-rc1v3.3-rc1Linus Torvalds
2012-01-19Merge branches 'sched-urgent-for-linus', 'perf-urgent-for-linus' and ↵Linus Torvalds
'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/accounting, proc: Fix /proc/stat interrupts sum * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tracepoints/module: Fix disabling tracepoints with taint CRAP or OOT x86/kprobes: Add arch/x86/tools/insn_sanity to .gitignore x86/kprobes: Fix typo transferred from Intel manual * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, syscall: Need __ARCH_WANT_SYS_IPC for 32 bits x86, tsc: Fix SMI induced variation in quick_pit_calibrate() x86, opcode: ANDN and Group 17 in x86-opcode-map.txt x86/kconfig: Move the ZONE_DMA entry under a menu x86/UV2: Add accounting for BAU strong nacks x86/UV2: Ack BAU interrupt earlier x86/UV2: Remove stale no-resources test for UV2 BAU x86/UV2: Work around BAU bug x86/UV2: Fix BAU destination timeout initialization x86/UV2: Fix new UV2 hardware by using native UV2 broadcast mode x86: Get rid of dubious one-bit signed bitfield
2012-01-19Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
gpio bug fixes for v3.3 * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: gpio: tps65910: Use correct offset for gpio initialization gpio/it8761e: Restrict it8761e gpio driver to x86. gpio-ml-ioh: cleanup __iomem annotation usage gpio-ml-ioh: cleanup NULL pointer checking gpio-pch: cleanup __iomem annotation usage gpio-pch: cleanup NULL pointer checking
2012-01-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: qnx4: don't leak ->BitMap on late failure exits qnx4: reduce the insane nesting in qnx4_checkroot() qnx4: di_fname is an array, for crying out loud... vfs: remove printk from set_nlink() wake up s_wait_unfrozen when ->freeze_fs fails
2012-01-19x86, syscall: Need __ARCH_WANT_SYS_IPC for 32 bitsH. Peter Anvin
In checkin 303395ac3bf3 x86: Generate system call tables and unistd_*.h from tables the feature macros in <asm/unistd.h> were unified between 32 and 64 bits. Unfortunately 32 bits requires __ARCH_WANT_SYS_IPC and this was inadvertently dropped. Reported-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/CALLzPKbeXN5gdngo8uYYU8mAow=XhrwBFBhKfG811f37BubQOg@mail.gmail.com
2012-01-19Merge remote-tracking branch 'linus/master' into x86/urgentH. Peter Anvin
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: KEYS: Permit key_serial() to be called with a const key pointer keys: fix user_defined key sparse messages ima: fix cred sparse warning MPILIB: Add a missing ENOMEM check
2012-01-19qnx4: don't leak ->BitMap on late failure exitsAl Viro
2012-01-19qnx4: reduce the insane nesting in qnx4_checkroot()Al Viro
2012-01-19qnx4: di_fname is an array, for crying out loud...Al Viro
(struct qnx4_inode_entry *)(bh->b_data + some_offset)->di_fname is not going to be NULL, TYVM... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-19KEYS: Permit key_serial() to be called with a const key pointerDavid Howells
Permit key_serial() to be called with a const key pointer. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-19keys: fix user_defined key sparse messagesMimi Zohar
Replace the rcu_assign_pointer() calls with rcu_assign_keypointer(). Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-19ima: fix cred sparse warningMimi Zohar
Fix ima_policy.c sparse "warning: dereference of noderef expression" message, by accessing cred->uid using current_cred(). Changelog v1: - Change __cred to just cred (based on David Howell's comment) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18uml: fix compile for x86-64Linus Torvalds
Randy Dunlap reports that we get arch/x86/um/shared/sysdep/ptrace.h:7:20: error: redefinition of 'regs_return_value' arch/x86/um/shared/sysdep/ptrace.h:7:20: note: previous definition of 'regs_return_value' was here when compiling UML for x86-64. Stephen Rothwell root-caused it and says: "Caused by commit d7e7528bcd45 ("Audit: push audit success and retcode into arch ptrace.h") (another patch that was never in linux-next :-(). This file now needs protection against double inclusion." so let's do as the man says. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Analyzed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-19MPILIB: Add a missing ENOMEM checkDavid Howells
Add a missing ENOMEM check. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18Merge branch 'for-next-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: ib_srpt: Initial SRP Target merge for v3.3-rc1
2012-01-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (26 commits) target: Set additional sense length field in sense data target: Remove legacy device status check from transport_execute_tasks target: Remove __transport_execute_tasks() for each processing context target: Remove extra se_device->execute_task_lock access in fast path target: Drop se_device TCQ queue_depth usage from I/O path target: Fix possible NULL pointer with __transport_execute_tasks target: Remove TFO->check_release_cmd() fabric API caller tcm_fc: Convert ft_send_work to use target_submit_cmd target: Add target_submit_cmd() for process context fabric submission target: Make target_put_sess_cmd use target_release_cmd_kref target: Set response format in INQUIRY response target: tcm_mod_builder: small fixups Documentation/target: Fix tcm_mod_builder.py build breakage target: remove overagressive ____cacheline_aligned annoations tcm_loop: bump max_sectors target/configs: remove trailing newline from udev_path and alias iscsi-target: fix chap identifier simple_strtoul usage target: remove useless casts target: simplify target_check_cdb_and_preempt target: Move core_scsi3_check_cdb_abort_and_preempt ...
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-18tpm: fix (ACPI S3) suspend regressionStefan Berger
This patch fixes an (ACPI S3) suspend regression introduced in commit 68d6e6713fcb ("tpm: Introduce function to poll for result of self test") and occurring with an Infineon TPM and tpm_tis and tpm_infineon drivers active. The suspend problem occurred if the TPM was disabled and/or deactivated and therefore the TPM_PCRRead checking the result of the (asynchronous) self test returned an error code which then caused the tpm_tis driver to become inactive and this then seemed to have negatively influenced the suspend support by the tpm_infineon driver... Besides that the tpm_tis drive may stay active even if the TPM is disabled and/or deactivated. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-18nvme: fix merge error due to change of 'make_request_fn' fn typeLinus Torvalds
The type of 'make_request_fn' changed in 5a7bbad27a4 ("block: remove support for bio remapping from ->make_request"), but the merge of the nvme driver didn't take that into account, and as a result the driver would compile with a warning: drivers/block/nvme.c: In function 'nvme_alloc_ns': drivers/block/nvme.c:1336:2: warning: passing argument 2 of 'blk_queue_make_request' from incompatible pointer type [enabled by default] include/linux/blkdev.h:830:13: note: expected 'void (*)(struct request_queue *, struct bio *)' but argument is of type 'int (*)(struct request_queue *, struct bio *)' It's benign, but the warning is annoying. Reported-by: Stephen Rothwell <sfr@canb.auug.org> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-18xen: using EXPORT_SYMBOL requires including export.hStephen Rothwell
Fix these warnings: drivers/xen/biomerge.c:14:1: warning: data definition has no type or storage class [enabled by default] drivers/xen/biomerge.c:14:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Wimplicit-int] drivers/xen/biomerge.c:14:1: warning: parameter names (without types) in function declaration [enabled by default] And this build error: ERROR: "xen_biovec_phys_mergeable" [drivers/block/nvme.ko] undefined! Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-18Merge branch 'for-linus/i2c-33' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c-33' of git://git.fluff.org/bjdooks/linux: i2c-eg20t: Change-company-name-OKI-SEMICONDUCTOR to LAPIS Semiconductor i2c-eg20t: Support new device LAPIS Semiconductor ML7831 IOH i2c-eg20t: modified the setting of transfer rate. i2c-eg20t: use i2c_add_numbered_adapter to get a fixed bus number i2c: OMAP: Add DT support for i2c controller I2C: OMAP: NACK without STP I2C: OMAP: correct SYSC register offset for OMAP4
2012-01-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (57 commits) [media] as3645a: Fix compilation by including slab.h [media] s5p-fimc: Remove linux/version.h include from fimc-mdevice.c [media] s5p-mfc: Remove linux/version.h include from s5p_mfc.c [media] ds3000: using logical && instead of bitwise & [media] v4l2-ctrls: make control names consistent [media] DVB: dib0700, add support for Nova-TD LEDs [media] DVB: dib0700, add corrected Nova-TD frontend_attach [media] DVB: dib0700, separate stk7070pd initialization [media] DVB: dib0700, move Nova-TD Stick to a separate set [media] : add MODULE_FIRMWARE to dib0700 [media] DVB-CORE: remove superfluous DTV_CMDs [media] s5p-jpeg: adapt to recent videobuf2 changes [media] s5p-g2d: fixed a bug in controls setting function [media] s5p-mfc: Fix volatile controls setup [media] drivers/media/video/s5p-mfc/s5p_mfc.c: adjust double test [media] drivers/media/video/s5p-fimc/fimc-capture.c: adjust double test [media] s5p-fimc: Fix incorrect control ID assignment [media] dvb_frontend: Don't call get_frontend() if idle [media] DocBook/dvbproperty.xml: Remove DTV_MODULATION from ISDB-T [media] DocBook/dvbproperty.xml: Fix ISDB-T delivery system parameters ...
2012-01-18Merge branch 'fix/asoc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'fix/asoc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: Wait for WM8993 FLL to stabilise ASoC: core - Free platform DAPM context at platform removal. ASoC: dapm - Fix check for codec context in dapm_power_widgets(). ASoC: sgtl5000: update author email address ASoC: Fix DMA channel leak in imx-pcm-dma-mx2 driver.
2012-01-18gpio: tps65910: Use correct offset for gpio initializationLaxman Dewangan
Using the correct gpio offset for setting the initial value of gpio when setting output direction. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-01-18Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 SCSI updates on 20120118 * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (49 commits) [SCSI] libfc: remove redundant timer init for fcp [SCSI] fcoe: Move fcoe_debug_logging from fcoe.h to fcoe.c [SCSI] libfc: Declare local functions static [SCSI] fcoe: fix regression on offload em matching function for initiator/target [SCSI] qla4xxx: Update driver version to 5.02.00-k12 [SCSI] qla4xxx: Cleanup modinfo display [SCSI] qla4xxx: Update license [SCSI] qla4xxx: Clear the RISC interrupt bit during FW init [SCSI] qla4xxx: Added error logging for firmware abort [SCSI] qla4xxx: Disable generating pause frames in case of FW hung [SCSI] qla4xxx: Temperature monitoring for ISP82XX core. [SCSI] megaraid: fix sparse warnings [SCSI] sg: convert to kstrtoul_from_user() [SCSI] don't change sdev starvation list order without request dispatched [SCSI] isci: fix, prevent port from getting stuck in the 'configuring' state [SCSI] isci: fix start OOB [SCSI] isci: fix io failures while wide port links are coming up [SCSI] isci: allow more time for wide port targets [SCSI] isci: enable wide port targets [SCSI] isci: Fix IO fails when pull cable from phy in x4 wideport in MPC mode. ...
2012-01-18Merge git://git.infradead.org/users/willy/linux-nvmeLinus Torvalds
* git://git.infradead.org/users/willy/linux-nvme: (105 commits) NVMe: Set number of queues correctly NVMe: Version 0.8 NVMe: Set queue flags correctly NVMe: Simplify nvme_unmap_user_pages NVMe: Mark the end of the sg list NVMe: Fix DMA mapping for admin commands NVMe: Rename IO_TIMEOUT to NVME_IO_TIMEOUT NVMe: Merge the nvme_bio and nvme_prp data structures NVMe: Change nvme_completion_fn to take a dev NVMe: Change get_nvmeq to take a dev instead of a namespace NVMe: Simplify completion handling NVMe: Update Identify Controller data structure NVMe: Implement doorbell stride capability NVMe: Version 0.7 NVMe: Don't probe namespace 0 Fix calculation of number of pages in a PRP List NVMe: Create nvme_identify and nvme_get_features functions NVMe: Fix memory leak in nvme_dev_add() NVMe: Fix calls to dma_unmap_sg NVMe: Correct sg list setup in nvme_map_user_pages ...
2012-01-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) tg3: Fix single-vector MSI-X code openvswitch: Fix multipart datapath dumps. ipv6: fix per device IP snmp counters inetpeer: initialize ->redirect_genid in inet_getpeer() net: fix NULL-deref in WARN() in skb_gso_segment() net: WARN if skb_checksum_help() is called on skb requiring segmentation caif: Remove bad WARN_ON in caif_dev caif: Fix typo in Vendor/Product-ID for CAIF modems bnx2x: Disable AN KR work-around for BCM57810 bnx2x: Remove AutoGrEEEn for BCM84833 bnx2x: Remove 100Mb force speed for BCM84833 bnx2x: Fix PFC setting on BCM57840 bnx2x: Fix Super-Isolate mode for BCM84833 net: fix some sparse errors net: kill duplicate included header net: sh-eth: Fix build error by the value which is not defined net: Use device model to get driver name in skb_gso_segment() bridge: BH already disabled in br_fdb_cleanup() net: move sock_update_memcg outside of CONFIG_INET mwl8k: Fixing Sparse ENDIAN CHECK warning ...
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-18acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi specTony Luck
ACPI 5.0 provides extensions to the EINJ mechanism to specify the target for the error injection - by APICID for cpu related errors, by address for memory related errors, and by segment/bus/device/function for PCIe related errors. Also extensions for vendor specific error injections. Tested-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-18Merge branch 'atomicio-remove' into releaseLen Brown
2012-01-18Merge branch 'apei' into releaseLen Brown
2012-01-17intel_idle: Split up and provide per CPU initialization funcThomas Renninger
Function split up, should have no functional change. Provides entry point for physically hotplugged CPUs to initialize and activate cpuidle. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> CC: Shaohua Li <shaohua.li@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2Thomas Renninger
V2: Fix typo: pr->handle -> pr, here: acpi_processor_hotadd_init(pr) This is a very small part taken from patches which afaik are coming from Yunhong Jiang (for a Xen not a Linus repo?). Cleanup only: no functional change. Advantage (beside cleanup) is that other data of the pr (acpi_processor) struct in the acpi_processor_hotadd_init() is needed later, for example a newly introduced flag: pr->flags.need_hotplug_init Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Bjorn Helgaas <bhelgaas@google.com> CC: Jiang, Yunhong <yunhong.jiang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17tg3: Fix single-vector MSI-X codeMatt Carlson
Kdump kernels leave MSI-X interrupts (as setup by the crashed kernel) enabled. However, kdump only enables one CPU in the new environment, thus causing tg3 to abort MSI-X setup. When the driver attempts to enable INTA or MSI interrupt modes on a kdump kernel, interrupt delivery fails. This patch attempts to workaround the problem by forcing the driver to enable a single MSI-X interrupt. In such a configuration, the device's multivector interrupt mode must be disabled. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17openvswitch: Fix multipart datapath dumps.Ben Pfaff
The logic to split up the list of datapaths into multiple Netlink messages was simply wrong, causing the list to be terminated after the first part. Only about the first 50 datapaths would be dumped. This fixes the problem. Reported-by: Paul Ingram <paul@nicira.com> Signed-off-by: Ben Pfaff <blp@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17ipv6: fix per device IP snmp countersEric Dumazet
In commit 4ce3c183fca (snmp: 64bit ipstats_mib for all arches), I forgot to change the /proc/net/dev_snmp6/xxx output for IP counters. percpu array is 64bit per counter but the folding still used the 'long' variant, and output garbage on 32bit arches. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17Merge tag 'arm-soc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc ARM: fixes for ARM platforms Some fallout from the 3.3. merge window as well as a couple bug fixes for older preexisting bugs that seem valid to include at this time: * sched_clock changes broke picoxcell, fix included * BSYM bugs causing issues with thumb2-built kernels on SMP * Missing module.h include on msm. * A collection of bugfixes for samsung platforms that didn't make it into the first pull requests. * tag 'arm-soc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: make BSYM macro assembly only ARM: highbank: remove incorrect BSYM usage ARM: imx: remove incorrect BSYM usage ARM: exynos: remove incorrect BSYM usage ARM: ux500: add missing ENDPROC to headsmp.S ARM: msm: Add missing ENDPROC to headsmp.S ARM: versatile: Add missing ENDPROC to headsmp.S ARM: EXYNOS: Invert VCLK polarity for framebuffer on ORIGEN ARM: S3C64XX: Fix interrupt configuration for PCA935x on Cragganmore ARM: S3C64XX: Fix the memory mapped GPIOs on Cragganmore ARM: S3C64XX: Remove hsmmc1 from Cragganmore ARM: S3C64XX: Remove unconditional power domain disables ARM: SAMSUNG: Declare struct platform_device in plat/s3c64xx-spi.h ARM: SAMSUNG: dma-ops.h needs mach/dma.h ARM: SAMSUNG: Guard against multiple inclusion of plat/dma.h ARM: picoxcell: fix sched_clock() cleanup fallout ARM: msm: vreg is a module and so needs module.h
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2012-01-17Merge branch 'upstream-linus' of git://github.com/jgarzik/libata-devLinus Torvalds
* 'upstream-linus' of git://github.com/jgarzik/libata-dev: [libata] ata_piix: Add Toshiba Satellite Pro A120 to the quirks list due to broken suspend functionality. [libata] add DVRTD08A and DVR-215 to NOSETXFER device quirk list [libata] pata_bf54x: Support sg list in bmdma transfer. [libata] sata_fsl: fix the controller operating mode [libata] enable ata port async suspend
2012-01-17x86-32: Fix build failure with AUDIT=y, AUDITSYSCALL=nAl Viro
JONGMAN HEO reports: With current linus git (commit a25a2b84), I got following build error, arch/x86/kernel/vm86_32.c: In function 'do_sys_vm86': arch/x86/kernel/vm86_32.c:340: error: implicit declaration of function '__audit_syscall_exit' make[3]: *** [arch/x86/kernel/vm86_32.o] Error 1 OK, I can reproduce it (32bit allmodconfig with AUDIT=y, AUDITSYSCALL=n) It's due to commit d7e7528bcd45: "Audit: push audit success and retcode into arch ptrace.h". Reported-by: JONGMAN HEO <jongman.heo@samsung.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-17[libata] ata_piix: Add Toshiba Satellite Pro A120 to the quirks listBenjamin Larsson
due to broken suspend functionality. Signed-off-by: Benjamin Larsson <benjamin@southpole.se> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-01-17[libata] add DVRTD08A and DVR-215 to NOSETXFER device quirk listVladimir LAVALLADE
2012-01-17[libata] pata_bf54x: Support sg list in bmdma transfer.Sonic Zhang
BF54x on-chip ATAPI controller allows maximum 0x1fffe bytes to be transfered in one ATAPI transfer. So, set the max sg_tablesize to 4. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-01-17[libata] sata_fsl: fix the controller operating modeJerry Huang
Configure the FSL SATA controller to the preferred, enterprise mode. Signed-off-by: Yutaka Ando <r46913@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> CC: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-01-17[libata] enable ata port async suspendLin Ming
This saves devices suspend/resume time. Tested system suspend/resume with SATA IDE/AHCI mode 3 times. Below is the time took for devices suspend/resume. SATA mode vanilla-kernel patched-kernel --------- --------------------- --------------------- IDE suspend: 0.744 suspend: 0.432 (0.716, 0.768, 0.748) (0.440, 0.428, 0.428) resume: 5.084 resume: 2.209 (5.100, 5.064, 5.088) (2.168, 2.232, 2.228) AHCI: suspend: 0.725 suspend: 0.449 (0.740, 0.708, 0.728) (0.456, 0.448, 0.444) resume: 2.556 resume: 1.896 (2.604, 2.492, 2.572) (1.932, 1.872, 1.884) Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-01-17[media] as3645a: Fix compilation by including slab.hLaurent Pinchart
The as3645a driver calls kzalloc(). Include slab.h. Reported-by: Fredrik Lingvall <fredrik.lingvall@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] s5p-fimc: Remove linux/version.h include from fimc-mdevice.cSachin Kamat
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] s5p-mfc: Remove linux/version.h include from s5p_mfc.cSachin Kamat
2012-01-17[media] ds3000: using logical && instead of bitwise &Dan Carpenter
The intent here was to test if the FE_HAS_LOCK was set. The current test is equivalent to "if (status) { ..." Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
